[PATCH] mips: dts: Fix device tree warnings for PIC32MZDA
Signed-off-by: John Robertson john.robertson@simiatec.com ---
arch/mips/dts/pic32mzda.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/mips/dts/pic32mzda.dtsi b/arch/mips/dts/pic32mzda.dtsi index 4c8b7a9a0b..8aff9eb812 100644 --- a/arch/mips/dts/pic32mzda.dtsi +++ b/arch/mips/dts/pic32mzda.dtsi @@ -26,8 +26,13 @@ };
cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { compatible = "mips,mips14kc"; + device-type = "cpu"; + reg = <0>; }; };
@@ -40,6 +45,7 @@ uart1: serial@1f822000 { compatible = "microchip,pic32mzda-uart"; reg = <0x1f822000 0x50>; + interrupt-parent = <&evic>; interrupts = <112 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; clocks = <&clock PB2CLK>; @@ -48,6 +54,7 @@ uart2: serial@1f822200 { compatible = "microchip,pic32mzda-uart"; reg = <0x1f822200 0x50>; + interrupt-parent = <&evic>; interrupts = <145 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clock PB2CLK>; status = "disabled"; @@ -56,6 +63,7 @@ uart6: serial@1f822a00 { compatible = "microchip,pic32mzda-uart"; reg = <0x1f822a00 0x50>; + interrupt-parent = <&evic>; interrupts = <188 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clock PB2CLK>; status = "disabled"; @@ -153,6 +161,7 @@ sdhci: sdhci@1f8ec000 { compatible = "microchip,pic32mzda-sdhci"; reg = <0x1f8ec000 0x100>; + interrupt-parent = <&evic>; interrupts = <191 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clock REF4CLK>, <&clock PB5CLK>; clock-names = "base_clk", "sys_clk"; @@ -164,6 +173,7 @@ ethernet: ethernet@1f882000 { compatible = "microchip,pic32mzda-eth"; reg = <0x1f882000 0x1000>; + interrupt-parent = <&evic>; interrupts = <153 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clock PB5CLK>; status = "disabled"; @@ -176,6 +186,7 @@ reg = <0x1f8e3000 0x1000>, <0x1f884000 0x1000>; reg-names = "mc", "control"; + interrupt-parent = <&evic>; interrupts = <132 IRQ_TYPE_EDGE_RISING>, <133 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clock PB5CLK>;
Am Dienstag, den 01.09.2020, 04:14 +0000 schrieb John Robertson:
applied to u-boot-mips/fixes, thanks.
Daniel Schwierzeck
John Robertson
