[U-Boot] [PATCH 1/2] serial: Support serial multi for Microblaze
enable serial multi for Microblaze.
Signed-off-by: Michal Simek monstr@monstr.eu --- include/serial.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/serial.h b/include/serial.h index 5173499..9475779 100644 --- a/include/serial.h +++ b/include/serial.h @@ -31,7 +31,8 @@ extern struct serial_device *default_serial_console(void); defined(CONFIG_MB86R0x) || defined(CONFIG_MPC5xxx) || \ defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || \ defined(CONFIG_MPC86xx) || defined(CONFIG_SYS_SC520) || \ - defined(CONFIG_TEGRA2) || defined(CONFIG_SYS_COREBOOT) + defined(CONFIG_TEGRA2) || defined(CONFIG_SYS_COREBOOT) || \ + defined(CONFIG_MICROBLAZE) extern struct serial_device serial0_device; extern struct serial_device serial1_device; #if defined(CONFIG_SYS_NS16550_SERIAL)
Initialize all possible uartlites and return the first initialized port. For static configuration is initialization done in userial_ports array.
Signed-off-by: Michal Simek monstr@monstr.eu --- drivers/serial/serial_xuartlite.c | 34 +++++++++++++++++++--------------- 1 files changed, 19 insertions(+), 15 deletions(-)
diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 3a38f9e..2bdb68b 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -89,11 +89,17 @@ int uartlite_serial_tstc(const int port) return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA; }
+static int uartlite_serial_init(const int port) +{ + if (userial_ports[port]) + return 0; + return -1; +} + #if !defined(CONFIG_SERIAL_MULTI) int serial_init(void) { - /* FIXME: Nothing for now. We should initialize fifo, etc */ - return 0; + return uartlite_serial_init(0); }
void serial_setbrg(void) @@ -126,7 +132,7 @@ int serial_tstc(void) /* Multi serial device functions */ #define DECLARE_ESERIAL_FUNCTIONS(port) \ int userial##port##_init(void) \ - { return(0); } \ + { return uartlite_serial_init(port); } \ void userial##port##_setbrg(void) {} \ int userial##port##_getc(void) \ { return uartlite_serial_getc(port); } \ @@ -163,17 +169,15 @@ struct serial_device uartlite_serial3_device =
__weak struct serial_device *default_serial_console(void) { -# ifdef XILINX_UARTLITE_BASEADDR - return &uartlite_serial0_device; -# endif /* XILINX_UARTLITE_BASEADDR */ -# ifdef XILINX_UARTLITE_BASEADDR1 - return &uartlite_serial1_device; -# endif /* XILINX_UARTLITE_BASEADDR1 */ -# ifdef XILINX_UARTLITE_BASEADDR2 - return &uartlite_serial2_device; -# endif /* XILINX_UARTLITE_BASEADDR2 */ -# ifdef XILINX_UARTLITE_BASEADDR3 - return &uartlite_serial3_device; -# endif /* XILINX_UARTLITE_BASEADDR3 */ + if (userial_ports[0]) + return &uartlite_serial0_device; + if (userial_ports[1]) + return &uartlite_serial1_device; + if (userial_ports[2]) + return &uartlite_serial2_device; + if (userial_ports[3]) + return &uartlite_serial3_device; + + return NULL; } #endif /* CONFIG_SERIAL_MULTI */
Am Dienstag, den 07.08.2012, 14:20 +0200 schrieb Michal Simek:
Acked-by: Stephan Linz linz@li-pro.net
Tested with AXI system on Avnet S6LX9 micro-evaluation.
- if (userial_ports[port])
- return -1;
- return uartlite_serial_init(0);
{ return(0); } \
void userial##port##_setbrg(void) {} \ int userial##port##_getc(void) \ { return uartlite_serial_getc(port); } \{ return uartlite_serial_init(port); } \
- if (userial_ports[0])
- if (userial_ports[1])
- if (userial_ports[2])
- if (userial_ports[3])
- return NULL;
- defined(CONFIG_TEGRA2) || defined(CONFIG_SYS_COREBOOT) || \
- defined(CONFIG_MICROBLAZE)
Michal Simek
Stephan Linz
