[U-Boot-Users] [PATCH] API: Fix compilation warnings in api_examples/demo.c.
Signed-off-by: Rafal Czubak rcz@semihalf.com --- api_examples/demo.c | 17 +++++++++-------- 1 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/api_examples/demo.c b/api_examples/demo.c index eae9712..7ccdb51 100644 --- a/api_examples/demo.c +++ b/api_examples/demo.c @@ -58,11 +58,12 @@ int main(int argc, char *argv[]) if (sig->version > API_SIG_VERSION) return -3;
- printf("API signature found @%x\n", sig); + printf("API signature found @%x\n", (unsigned int)sig); test_dump_sig(sig);
printf("\n*** Consumer API test ***\n"); - printf("syscall ptr 0x%08x@%08x\n", syscall_ptr, &syscall_ptr); + printf("syscall ptr 0x%08x@%08x\n", (unsigned int)syscall_ptr, + (unsigned int)&syscall_ptr);
/* console activities */ ub_putc('B'); @@ -180,7 +181,7 @@ void test_dump_sig(struct api_signature *sig) printf("signature:\n"); printf(" version\t= %d\n", sig->version); printf(" checksum\t= 0x%08x\n", sig->checksum); - printf(" sc entry\t= 0x%08x\n", sig->syscall); + printf(" sc entry\t= 0x%08x\n", (unsigned int)sig->syscall); }
void test_dump_si(struct sys_info *si) @@ -188,9 +189,9 @@ void test_dump_si(struct sys_info *si) int i;
printf("sys info:\n"); - printf(" clkbus\t= 0x%08x\n", si->clk_bus); - printf(" clkcpu\t= 0x%08x\n", si->clk_cpu); - printf(" bar\t\t= 0x%08x\n", si->bar); + printf(" clkbus\t= 0x%08x\n", (unsigned int)si->clk_bus); + printf(" clkcpu\t= 0x%08x\n", (unsigned int)si->clk_cpu); + printf(" bar\t\t= 0x%08x\n", (unsigned int)si->bar);
printf("---\n"); for (i = 0; i < si->mr_no; i++) { @@ -252,7 +253,7 @@ void test_dump_di(int handle)
} else if (di->type & DEV_TYP_STOR) { printf(" type\t\t= %s\n", test_stor_typ(di->type)); - printf(" blk size\t\t= %d\n", di->di_stor.block_size); - printf(" blk count\t\t= %d\n", di->di_stor.block_count); + printf(" blk size\t\t= %d\n", (unsigned int)di->di_stor.block_size); + printf(" blk count\t\t= %d\n", (unsigned int)di->di_stor.block_count); } }
Applied, thanks.
Rafal Jaworowski
