RE: [U-Boot-Users] silent console, nulldev and CONFIG_AUTOBOOT_KEYED
Ladislav Michl wrote:
If "silent" env variable is set GD_FLG_SILENT is added to gd->flags (in console_init_f). That effectively causes all console output to be suppresed. That flag also causes nulldev to become outputdev (in console_init_r). Btw, shouldn't CONFIG_SILENT_CONSOLE depend on CFG_DEVICE_NULLDEV in this case?
The current implementation of CONFIG_SILENT_CONSOLE needs CFG_DEVICE_NULLDEV. I suppose a check could be added to flag the error at build time if CFG_DEVICE_NULLDEV is not defined.
Now we are entering into abortboot (CONFIG_AUTOBOOT_KEYED) and because "silent" env variable is set and also CONFIG_SILENT_CONSOLE defined console_assign (stdout, "serial");
is
called, doing basicaly nothing, because GD_FLG_SILENT which is still set prevents any console output.
In abortboot the "silent" operation is suspended by setting the console back to serial so you can use the console to abort the boot. If the boot is aborted GD_FLG_SILENT is cleared, and the serial console works. If the boot is not aborted the console is set back to "nulldev" and the boot continues silently.
There are various solutions from this situation, but I'd like first understand what is CFG_DEVICE_NULLDEV good for when we have
GD_FLG_SILENT?
Or better, how should all these three things in question behave?
You can boot silently (if "silent" is set), you can decide to see the output (by removing "silent" from the environment) and in either case if you abort the boot the console works. Isn't that exactly what the feature should do?
Dave Ellis
~~~~~~~~~~~~~~~~~~~~~~~~~~ SIXNET - "Leading the Industrial Ethernet Revolution" 331 Ushers Road, P.O. Box 767, Clifton Park, NY 12065 USA Tel +1 (518) 877-5173 Fax +1 (518) 877-8346 Email me at: dge@sixnetio.com Detailed product info: www.sixnetio.com ~~~~~~~~~~~~~~~~~~~~~~~~~~
GD_FLG_SILENT flag is checked on every output to console, nulldev device seems redundant to me.
Indeed, console is set back to serial, but it doesn't help you to see any output. I would assume you should see at least something like "Enter password - autoboot in n seconds"
Yes, that's what I'd expect. But is it done somehow complicated way. Again, why there is nulldev device when GD_FLG_SILENT is checked on every console output? Is CONFIG_AUTOBOOT_PROMPT supposed to be displayed even with "silent" console? Would it break any user setup if I remove nulldev?
thanks, ladis
device
Once devices are set up GD_FLG_SILENT would only block output that implies stdout, not output that specifies it. I think (I haven't tried it) printf("abc") would be blocked by GD_FLG_SILENT but fprintf(stdout, "abc") would not. The fprintf() would be blocked because stdout is nulldev. So I guess it is mostly redundant, but not for the fprintf() case.
[snip]
[snip]
every
even
nulldev?
I think I see the problem. CONFIG_AUTOBOOT_PROMPT should be displayed, but it isn't because printf() is checking GD_FLG_SILENT. The cleanest solution I see is to check GD_FLG_SILENT only when sending directly to the handler, not when sending to the device. That keeps printf(...) and fprintf(stdout, ...) consistent. Below is a patch to try:
Dave Ellis
--- u-boot.cvs/common/console.c Thu Mar 31 13:42:16 2005 +++ u-boot.patched/common/console.c Thu Jun 30 16:21:07 2005 @@ -189,16 +189,17 @@ void putc (const char c) { DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_SILENT_CONSOLE - if (gd->flags & GD_FLG_SILENT) - return; -#endif - if (gd->flags & GD_FLG_DEVINIT) { /* Send to the standard output */ fputc (stdout, c); } else { /* Send directly to the handler */ + +#ifdef CONFIG_SILENT_CONSOLE + if (gd->flags & GD_FLG_SILENT) + return; +#endif + serial_putc (c); } } @@ -207,16 +208,16 @@ void puts (const char *s) { DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_SILENT_CONSOLE - if (gd->flags & GD_FLG_SILENT) - return; -#endif - if (gd->flags & GD_FLG_DEVINIT) { /* Send to the standard output */ fputs (stdout, s); } else { /* Send directly to the handler */ + +#ifdef CONFIG_SILENT_CONSOLE + if (gd->flags & GD_FLG_SILENT) + return; +#endif serial_puts (s); } }
Dave Ellis
Dave Ellis
Ladislav Michl
