[U-Boot] [PATCH] arm/km: fix u-boot update functionality
Due to the new I2C framework we need to adapt the u-boot update function. Due to the new framework all i2c leafs behind a mux are present in the system and not only those who are defined and used. So it is bus number 5 after the rework.
Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Heiko Schocher hs@denx.de cc: Prafulla Wadaskar prafulla@marvell.com --- This patch is dependent to the already posted patchserie: http://lists.denx.de/pipermail/u-boot/2013-May/153452.html
include/configs/km/km_arm.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index ebbfa84..4da54d5 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -295,7 +295,8 @@ int get_scl(void); #else #define CONFIG_KM_NEW_ENV \ "newenv=setenv addr 0x100000 && " \ - "i2c dev 1; mw.b ${addr} 0 4 && " \ + "i2c dev " __stringify(CONFIG_I2C_ENV_EEPROM_BUS) "; " \ + "mw.b ${addr} 0 4 && " \ "eeprom write " __stringify(CONFIG_SYS_DEF_EEPROM_ADDR) \ " ${addr} " __stringify(CONFIG_ENV_OFFSET) " 4 && " \ "eeprom write " __stringify(CONFIG_SYS_DEF_EEPROM_ADDR) \
Hello Prafulla,
Am 06.05.2013 14:54, schrieb Holger Brunck:
I added this patch to my ToDo List in Patchwork, if it is OK for you?
bye, Heiko
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: 06 May 2013 19:32 To: Holger Brunck Cc: u-boot@lists.denx.de; Prafulla Wadaskar Subject: Re: [PATCH] arm/km: fix u-boot update functionality
Hello Prafulla,
boot update
behind a mux are
patchserie:
May/153452.html
Dear Heiko That should be okay, no issues, please go ahead.
Regards... Prafulla . . .
Heiko Schocher
Holger Brunck
Prafulla Wadaskar
