[PATCH v3 00/29] patman: Collect review tags and comments from Patchwork
Patman is a useful tool for creating, checking sending out patches. It automates the creation of patches, simplifies checking them and handles cover letters and change logs.
However once patches are sent and reviewers add Reviewed-by tags, etc., these must be manually added into the commits using git before the next version of the series is sent. Also, the only way to look at patches is in the web interface.
It would be nice if patman could talk to Patchwork and collect the review tags itself. Even better if it could show the review comments in a command-line view patch-by-patch to speed up addressing comments.
This series adds these features to patman, talking directly to the Patchwork REST API. While pwclient seems like it could handle some of this, or at least provide a library to patman, the documentation[1] doesn't really explain what the commands do and it doesn't seem to work with the current Patchwork (e.g. pwclient git-am requires a patch number but Patchwork seems to use an ID now).
With these changes it is possible to type 'patman status' and see a list of new review tags. It is also possible to create a new branch with those tags and list out the review comments as small snippets on the command line.
I have been using these features for a little while and they seem useful, so herewith a series.
Some of the patches here clean up style problems in patman and other minor problems. See the last four patches for the main changes.
You can find it at u-boot-dm/patman-working[2]
[1] https://patchwork.readthedocs.io/projects/pwclient/en/latest/usage/ [2] https://gitlab.denx.de/u-boot/custodians/u-boot-dm/-/tree/patman-working
Changes in v3: - Rename GetMetaData() function to snake case - Fix incorrect commenting on a line in prepare_patches() - Allow tags to be inserted in the middle of the commit message
Changes in v2: - Adjust the algorithm to handle patch/commit mismatch - Correct Python style problems - Use REST API instead of web pages - Many changes to the whole series, including new patches - Use of REST API instead of the web site
Simon Glass (29): patman: Correct operation of -n azure/gitLab/travis: Add pygit2 as a dependency for tests patman: Update how tests are run patman: Fix whitespace errors in func_test patman: Use capture_sys_output() consistently patman: Fix remaining pylint3 warnings in func_test patman: Allow linking a series with patchwork patman: Fix indenting in patchstream patman: Fix constant style in patchstream patman: Rename functions in patchstream patman: Rename variables in patchstream patman: Drop unused args in patchstream patman: Fix up argument/return docs in patchstream patman: Move warning collection to a function patman: Attach warnings to individual patches patman: Convert 'Series-xxx' tag errors into warnings patman: Drop unused signoff member patman: Add a test for PatchStream tags patman: Add some tests for warnings patman: Convert testBasic() to use an interator patman: Fix spelling of plural for warning patman: Don't ignore lines starting with hash patman: Allow showing a Commit as a string patman: Improve handling of files patman: Detect missing upstream in CountCommitsToBranch patman: Support checking for review tags in patchwork patman: Support updating a branch with review tags patman: Support parsing of review snippets patman: Support listing comments from patchwork
.azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- .travis.yml | 1 + tools/buildman/control.py | 6 +- tools/patman/README | 110 +++- tools/patman/checkpatch.py | 18 +- tools/patman/commit.py | 5 + tools/patman/control.py | 71 ++- tools/patman/func_test.py | 983 +++++++++++++++++++++++++++++--- tools/patman/gitutil.py | 10 +- tools/patman/main.py | 42 +- tools/patman/patchstream.py | 485 +++++++++++----- tools/patman/series.py | 8 +- tools/patman/status.py | 482 ++++++++++++++++ tools/patman/terminal.py | 21 +- tools/patman/test_checkpatch.py | 6 +- 16 files changed, 1981 insertions(+), 271 deletions(-) create mode 100644 tools/patman/status.py
This operation was unfortunately broken by a recent change. It is now necessary to use -i in addition to -n, if there are errors or warnings in the patches.
Correct this by always showing the summary information.
Fixes: f3653759758 ("patman: Move main code out to a control module") Signed-off-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
tools/patman/control.py | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/tools/patman/control.py b/tools/patman/control.py index 67e8f397efd..aea9df8c8d1 100644 --- a/tools/patman/control.py +++ b/tools/patman/control.py @@ -170,9 +170,8 @@ def send(args): ok = ok and gitutil.CheckSuppressCCConfig()
its_a_go = ok or args.ignore_errors - if its_a_go: - email_patches( - col, series, cover_fname, patch_files, args.process_tags, - its_a_go, args.ignore_bad_tags, args.add_maintainers, - args.limit, args.dry_run, args.in_reply_to, args.thread, - args.smtp_server) + email_patches( + col, series, cover_fname, patch_files, args.process_tags, + its_a_go, args.ignore_bad_tags, args.add_maintainers, + args.limit, args.dry_run, args.in_reply_to, args.thread, + args.smtp_server)
Applied to u-boot-dm, thanks!
This lets patman run all of its tests, rather than skipping quite a few.
.azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- .travis.yml | 1 + 3 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 473ddee3835..132daa358f5 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -140,7 +140,7 @@ jobs: export USER=azure virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate - pip install pyelftools pytest + pip install pyelftools pytest pygit2 export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl export PYTHONPATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt export PATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH} diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 9ac2b336a11..74aabe53016 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -161,7 +161,7 @@ Run binman, buildman, dtoc, Kconfig and patman testsuites: export USER=gitlab; virtualenv -p /usr/bin/python3 /tmp/venv; . /tmp/venv/bin/activate; - pip install pyelftools pytest; + pip install pyelftools pytest pygit2; export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl; export PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt"; export PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}"; diff --git a/.travis.yml b/.travis.yml index fb8f73157d7..bfcc74cd62a 100644 --- a/.travis.yml +++ b/.travis.yml @@ -26,6 +26,7 @@ addons: - python3-sphinx - python3-virtualenv - python3-pip + - python3-pygit2 - swig - libpython-dev - iasl
The current instructions are out-of-date. Fix them.
tools/patman/README | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 52b2cf70bd0..7ede1068ee1 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -533,12 +533,10 @@ Most of these are indicated by a TODO in the code.
It would be nice if this could handle the In-reply-to side of things.
-The tests are incomplete, as is customary. Use the --test flag to run them, -and make sure you are in the tools/patman directory first: +The tests are incomplete, as is customary. Use the 'test' subcommand to run +them:
- $ cd /path/to/u-boot - $ cd tools/patman - $ ./patman --test + $ tools/patman/patman test
Error handling doesn't always produce friendly error messages - e.g. putting an incorrect tag in a commit may provide a confusing message.
Fix up various indentation and other minor things to make pylint3 happier.
tools/patman/func_test.py | 37 +++++++++++++++++++------------------ 1 file changed, 19 insertions(+), 18 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 810af9c6042..7fffe649974 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -24,20 +24,20 @@ from patman.test_util import capture_sys_output
try: import pygit2 - HAVE_PYGIT2= True + HAVE_PYGIT2 = True except ModuleNotFoundError: HAVE_PYGIT2 = False
@contextlib.contextmanager def capture(): - oldout,olderr = sys.stdout, sys.stderr + oldout, olderr = sys.stdout, sys.stderr try: - out=[StringIO(), StringIO()] - sys.stdout,sys.stderr = out + out = [StringIO(), StringIO()] + sys.stdout, sys.stderr = out yield out finally: - sys.stdout,sys.stderr = oldout, olderr + sys.stdout, sys.stderr = oldout, olderr out[0] = out[0].getvalue() out[1] = out[1].getvalue()
@@ -160,10 +160,10 @@ class TestFunctional(unittest.TestCase): in_reply_to = mel count = 2 settings.alias = { - 'fdt': ['simon'], - 'u-boot': ['u-boot@lists.denx.de'], - 'simon': [ed], - 'fred': [fred], + 'fdt': ['simon'], + 'u-boot': ['u-boot@lists.denx.de'], + 'simon': [ed], + 'fred': [fred], }
text = self.GetText('test01.txt') @@ -177,9 +177,9 @@ class TestFunctional(unittest.TestCase): cc_file = series.MakeCcFile(process_tags, cover_fname, not ignore_bad_tags, add_maintainers, None) - cmd = gitutil.EmailPatches(series, cover_fname, args, - dry_run, not ignore_bad_tags, cc_file, - in_reply_to=in_reply_to, thread=None) + cmd = gitutil.EmailPatches( + series, cover_fname, args, dry_run, not ignore_bad_tags, + cc_file, in_reply_to=in_reply_to, thread=None) series.ShowActions(args, cmd, process_tags) cc_lines = open(cc_file, encoding='utf-8').read().splitlines() os.remove(cc_file) @@ -221,8 +221,9 @@ class TestFunctional(unittest.TestCase):
self.assertEqual(('%s %s\0%s' % (args[0], rick, stefan)), tools.ToUnicode(cc_lines[0])) - self.assertEqual(('%s %s\0%s\0%s\0%s' % (args[1], fred, ed, rick, - stefan)), tools.ToUnicode(cc_lines[1])) + self.assertEqual( + '%s %s\0%s\0%s\0%s' % (args[1], fred, ed, rick, stefan), + tools.ToUnicode(cc_lines[1]))
expected = ''' This is a test of how the cover @@ -256,8 +257,8 @@ Simon Glass (2): ''' lines = open(cover_fname, encoding='utf-8').read().splitlines() self.assertEqual( - 'Subject: [RFC PATCH v3 0/2] test: A test patch series', - lines[3]) + 'Subject: [RFC PATCH v3 0/2] test: A test patch series', + lines[3]) self.assertEqual(expected.splitlines(), lines[7:])
for i, fname in enumerate(args): @@ -310,7 +311,7 @@ Changes in v2: tools.WriteFile(path, text, binary=False) index = self.repo.index index.add(fname) - author = pygit2.Signature('Test user', 'test@email.com') + author = pygit2.Signature('Test user', 'test@email.com') committer = author tree = index.write_tree() message = subject + '\n' + body @@ -335,7 +336,7 @@ Changes in v2: author = pygit2.Signature('Test user', 'test@email.com') committer = author commit = repo.create_commit('HEAD', author, committer, - 'Created master', new_tree, []) + 'Created master', new_tree, [])
self.make_commit_with_file('Initial commit', ''' Add a README
One test still uses its own function for capturing output. Modify it to use the standard one in test_util
tools/patman/func_test.py | 20 ++------------------ 1 file changed, 2 insertions(+), 18 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 7fffe649974..263cb340ef5 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -4,7 +4,6 @@ # Copyright 2017 Google, Inc #
-import contextlib import os import re import shutil @@ -12,8 +11,6 @@ import sys import tempfile import unittest
-from io import StringIO - from patman import control from patman import gitutil from patman import patchstream @@ -29,19 +26,6 @@ except ModuleNotFoundError: HAVE_PYGIT2 = False
-@contextlib.contextmanager -def capture(): - oldout, olderr = sys.stdout, sys.stderr - try: - out = [StringIO(), StringIO()] - sys.stdout, sys.stderr = out - yield out - finally: - sys.stdout, sys.stderr = oldout, olderr - out[0] = out[0].getvalue() - out[1] = out[1].getvalue() - - class TestFunctional(unittest.TestCase): def setUp(self): self.tmpdir = tempfile.mkdtemp(prefix='patman.') @@ -169,7 +153,7 @@ class TestFunctional(unittest.TestCase): text = self.GetText('test01.txt') series = patchstream.GetMetaDataForTest(text) cover_fname, args = self.CreatePatchesForTest(series) - with capture() as out: + with capture_sys_output() as out: patchstream.FixPatches(series, args) if cover_fname and series.get('cover'): patchstream.InsertCoverLetter(cover_fname, series, count) @@ -184,7 +168,7 @@ class TestFunctional(unittest.TestCase): cc_lines = open(cc_file, encoding='utf-8').read().splitlines() os.remove(cc_file)
- lines = out[0].splitlines() + lines = out[0].getvalue().splitlines() self.assertEqual('Cleaned %s patches' % len(series.commits), lines[0]) self.assertEqual('Change log missing for v2', lines[1]) self.assertEqual('Change log missing for v3', lines[2])
This fixes all but the ones about too many variables/statements.
tools/patman/func_test.py | 76 +++++++++++++++++++++++++++++---------- 1 file changed, 58 insertions(+), 18 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 263cb340ef5..b3c3e5796ad 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -4,6 +4,8 @@ # Copyright 2017 Google, Inc #
+"""Functional tests for checking that patman behaves correctly""" + import os import re import shutil @@ -27,6 +29,7 @@ except ModuleNotFoundError:
class TestFunctional(unittest.TestCase): + """Functional tests for checking that patman behaves correctly""" def setUp(self): self.tmpdir = tempfile.mkdtemp(prefix='patman.') self.gitdir = os.path.join(self.tmpdir, 'git') @@ -36,33 +39,69 @@ class TestFunctional(unittest.TestCase): shutil.rmtree(self.tmpdir)
@staticmethod - def GetPath(fname): + def _get_path(fname): + """Get the path to a test file + + Args: + fname (str): Filename to obtain + + Returns: + str: Full path to file in the test directory + """ return os.path.join(os.path.dirname(os.path.realpath(sys.argv[0])), 'test', fname)
@classmethod - def GetText(self, fname): - return open(self.GetPath(fname), encoding='utf-8').read() + def _get_text(cls, fname): + """Read a file as text + + Args: + fname (str): Filename to read + + Returns: + str: Contents of file + """ + return open(cls._get_path(fname), encoding='utf-8').read()
@classmethod - def GetPatchName(self, subject): + def _get_patch_name(cls, subject): + """Get the filename of a patch given its subject + + Args: + subject (str): Patch subject + + Returns: + str: Filename for that patch + """ fname = re.sub('[ :]', '-', subject) return fname.replace('--', '-')
- def CreatePatchesForTest(self, series): + def _create_patches_for_test(self, series): + """Create patch files for use by tests + + This copies patch files from the test directory as needed by the series + + Args: + series (Series): Series containing commits to convert + + Returns: + tuple: + str: Cover-letter filename, or None if none + fname_list: list of str, each a patch filename + """ cover_fname = None fname_list = [] for i, commit in enumerate(series.commits): - clean_subject = self.GetPatchName(commit.subject) + clean_subject = self._get_patch_name(commit.subject) src_fname = '%04d-%s.patch' % (i + 1, clean_subject[:52]) fname = os.path.join(self.tmpdir, src_fname) - shutil.copy(self.GetPath(src_fname), fname) + shutil.copy(self._get_path(src_fname), fname) fname_list.append(fname) if series.get('cover'): src_fname = '0000-cover-letter.patch' cover_fname = os.path.join(self.tmpdir, src_fname) fname = os.path.join(self.tmpdir, src_fname) - shutil.copy(self.GetPath(src_fname), fname) + shutil.copy(self._get_path(src_fname), fname)
return cover_fname, fname_list
@@ -137,7 +176,8 @@ class TestFunctional(unittest.TestCase): stefan = b'Stefan Br\xc3\xbcns stefan.bruens@rwth-aachen.de'.decode('utf-8') rick = 'Richard III richard@palace.gov' mel = b'Lord M\xc3\xablchett clergy@palace.gov'.decode('utf-8') - ed = b'Lond Edmund Blackadd\xc3\xabr <weasel@blackadder.org'.decode('utf-8') + leb = (b'Lond Edmund Blackadd\xc3\xabr <weasel@blackadder.org'. + decode('utf-8')) fred = 'Fred Bloggs f.bloggs@napier.net' add_maintainers = [stefan, rick] dry_run = True @@ -146,13 +186,13 @@ class TestFunctional(unittest.TestCase): settings.alias = { 'fdt': ['simon'], 'u-boot': ['u-boot@lists.denx.de'], - 'simon': [ed], + 'simon': [leb], 'fred': [fred], }
- text = self.GetText('test01.txt') + text = self._get_text('test01.txt') series = patchstream.GetMetaDataForTest(text) - cover_fname, args = self.CreatePatchesForTest(series) + cover_fname, args = self._create_patches_for_test(series) with capture_sys_output() as out: patchstream.FixPatches(series, args) if cover_fname and series.get('cover'): @@ -177,7 +217,7 @@ class TestFunctional(unittest.TestCase): self.assertIn('Dry run', lines[5]) self.assertIn('Send a total of %d patches' % count, lines[7]) line = 8 - for i, commit in enumerate(series.commits): + for i in range(len(series.commits)): self.assertEqual(' %s' % args[i], lines[line + 0]) line += 1 while 'Cc:' in lines[line]: @@ -190,7 +230,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual('Cover: 4 lines', lines[line + 4]) line += 5 self.assertEqual(' Cc: %s' % fred, lines[line + 0]) - self.assertEqual(' Cc: %s' % tools.FromUnicode(ed), + self.assertEqual(' Cc: %s' % tools.FromUnicode(leb), lines[line + 1]) self.assertEqual(' Cc: %s' % tools.FromUnicode(mel), lines[line + 2]) @@ -206,7 +246,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual(('%s %s\0%s' % (args[0], rick, stefan)), tools.ToUnicode(cc_lines[0])) self.assertEqual( - '%s %s\0%s\0%s\0%s' % (args[1], fred, ed, rick, stefan), + '%s %s\0%s\0%s\0%s' % (args[1], fred, leb, rick, stefan), tools.ToUnicode(cc_lines[1]))
expected = ''' @@ -311,7 +351,7 @@ Changes in v2: 'second' has base as upstream and three more: video, serial, bootm
Returns: - pygit2 repository + pygit2.Repository: repository """ repo = pygit2.init_repository(self.gitdir) self.repo = repo @@ -319,8 +359,8 @@ Changes in v2:
author = pygit2.Signature('Test user', 'test@email.com') committer = author - commit = repo.create_commit('HEAD', author, committer, - 'Created master', new_tree, []) + _ = repo.create_commit('HEAD', author, committer, 'Created master', + new_tree, [])
Add a new Series-links tag to tell patman how to find the series in patchwork. Each item is the series ID optionally preceded by the series version that the link refers to. An empty version indicates this is the latest series.
For example:
Series-links: 209816 1:203302
Documentation is added in a later patch.
tools/patman/README | 15 +++++++++++++++ tools/patman/func_test.py | 1 + tools/patman/series.py | 2 +- 3 files changed, 17 insertions(+), 1 deletion(-)
diff --git a/tools/patman/README b/tools/patman/README index 7ede1068ee1..6664027ed7d 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -187,6 +187,21 @@ Series-name: name patman does not yet use it, but it is convenient to put the branch name here to help you keep track of multiple upstreaming efforts.
+Series-links: [id | version:id]... + Set the ID of the series in patchwork. You can set this after you send + out the series and look in patchwork for the resulting series. The + URL you want is the one for the series itself, not any particular patch. + E.g. for http://patchwork.ozlabs.org/project/uboot/list/?series=187331 + the series ID is 187331. This property can have a list of series IDs, + one for each version of the series, e.g. + + Series-links: 1:187331 2:188434 189372 + + Patman always uses the one without a version, since it assumes this is + the latest one. When this tag is provided, patman can compare your local + branch against patchwork to see what new reviews your series has + collected ('patman status'). + Cover-letter: This is the patch set title blah blah diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index b3c3e5796ad..ea3c84632c0 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -417,6 +417,7 @@ Series for my board This series implements support for my glorious board. END +Series-links: 183237 ''', 'serial.c', '''The code for the serial driver is here''') self.make_commit_with_file('bootm: Make it boot', ''' diff --git a/tools/patman/series.py b/tools/patman/series.py index 9f885c89873..393a44241bd 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -16,7 +16,7 @@ from patman import tools
# Series-xxx tags that we understand valid_series = ['to', 'cc', 'version', 'changes', 'prefix', 'notes', 'name', - 'cover_cc', 'process_log'] + 'cover_cc', 'process_log', 'links']
class Series(dict): """Holds information about a patch series, including all tags.
For example:
Update the indenting to keep pylint3 happy.
tools/patman/patchstream.py | 29 ++++++++++++++++------------- 1 file changed, 16 insertions(+), 13 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index ba0a13f6325..5fff74918ab 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -2,6 +2,8 @@ # Copyright (c) 2011 The Chromium OS Authors. #
+"""Handles parsing a stream of commits/emails from 'git log' or other source""" + import datetime import math import os @@ -15,8 +17,8 @@ from patman import gitutil from patman.series import Series
# Tags that we detect and remove -re_remove = re.compile('^BUG=|^TEST=|^BRANCH=|^Review URL:' - '|Reviewed-on:|Commit-\w*:') +re_remove = re.compile(r'^BUG=|^TEST=|^BRANCH=|^Review URL:' + r'|Reviewed-on:|Commit-\w*:')
# Lines which are allowed after a TEST= line re_allowed_after_test = re.compile('^Signed-off-by:') @@ -46,7 +48,7 @@ re_commit = re.compile('^commit ([0-9a-f]*)$') re_space_before_tab = re.compile('^[+].* \t')
# Match indented lines for changes -re_leading_whitespace = re.compile('^\s') +re_leading_whitespace = re.compile(r'^\s')
# States we can be in - can we use range() and still have comments? STATE_MSG_HEADER = 0 # Still in the message header @@ -149,7 +151,7 @@ class PatchStream: return int(value) except ValueError as str: raise ValueError("%s: Cannot decode version info '%s'" % - (self.commit.hash, line)) + (self.commit.hash, line))
def FinalizeChange(self): """Finalize a (multi-line) change and add it to the series or commit""" @@ -271,7 +273,7 @@ class PatchStream:
# If we are not in a section, it is an unexpected END elif line == 'END': - raise ValueError("'END' wihout section") + raise ValueError("'END' wihout section")
# Detect the commit subject elif not is_blank and self.state == STATE_PATCH_SUBJECT: @@ -336,8 +338,9 @@ class PatchStream: value = change_id_match.group(1) if self.is_log: if self.commit.change_id: - raise ValueError("%s: Two Change-Ids: '%s' vs. '%s'" % - (self.commit.hash, self.commit.change_id, value)) + raise ValueError( + "%s: Two Change-Ids: '%s' vs. '%s'" % self.commit.hash, + self.commit.change_id, value) self.commit.change_id = value self.skip_blank = True
@@ -353,7 +356,7 @@ class PatchStream: self.change_version = self.ParseVersion(value, line) else: self.warn.append('Line %d: Ignoring Commit-%s' % - (self.linenum, name)) + (self.linenum, name))
# Detect the start of a new commit elif commit_match: @@ -376,7 +379,7 @@ class PatchStream: # Suppress duplicate signoffs elif signoff_match: if (self.is_log or not self.commit or - self.commit.CheckDuplicateSignoff(signoff_match.group(1))): + self.commit.CheckDuplicateSignoff(signoff_match.group(1))): out = [line]
# Well that means this is an ordinary line @@ -385,7 +388,7 @@ class PatchStream: m = re_space_before_tab.match(line) if m: self.warn.append('Line %d/%d has space before tab' % - (self.linenum, m.start())) + (self.linenum, m.start()))
# OK, we have a valid non-blank line out = [line] @@ -418,7 +421,7 @@ class PatchStream: self.CloseCommit() if self.lines_after_test: self.warn.append('Found %d lines after TEST=' % - self.lines_after_test) + self.lines_after_test)
def WriteMessageId(self, outfd): """Write the Message-Id into the output. @@ -494,7 +497,7 @@ class PatchStream: else: if self.blank_count and (line == '-- ' or match): self.warn.append("Found possible blank line(s) at " - "end of file '%s'" % last_fname) + "end of file '%s'" % last_fname) outfd.write('+\n' * self.blank_count) outfd.write(line + '\n') self.blank_count = 0 @@ -502,7 +505,7 @@ class PatchStream:
def GetMetaDataForList(commit_range, git_dir=None, count=None, - series = None, allow_overwrite=False): + series=None, allow_overwrite=False): """Reads out patch series metadata from the commits
This does a 'git log' on the relevant commits and pulls out the tags we
These constants should use upper case. Update them to keep pylint3 happy.
tools/patman/patchstream.py | 44 ++++++++++++++++++------------------- 1 file changed, 22 insertions(+), 22 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 5fff74918ab..86b03a7a30b 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -17,38 +17,38 @@ from patman import gitutil from patman.series import Series
# Tags that we detect and remove -re_remove = re.compile(r'^BUG=|^TEST=|^BRANCH=|^Review URL:' +RE_REMOVE = re.compile(r'^BUG=|^TEST=|^BRANCH=|^Review URL:' r'|Reviewed-on:|Commit-\w*:')
# Lines which are allowed after a TEST= line -re_allowed_after_test = re.compile('^Signed-off-by:') +RE_ALLOWED_AFTER_TEST = re.compile('^Signed-off-by:')
# Signoffs -re_signoff = re.compile('^Signed-off-by: *(.*)') +RE_SIGNOFF = re.compile('^Signed-off-by: *(.*)')
# Cover letter tag -re_cover = re.compile('^Cover-([a-z-]*): *(.*)') +RE_COVER = re.compile('^Cover-([a-z-]*): *(.*)')
# Patch series tag -re_series_tag = re.compile('^Series-([a-z-]*): *(.*)') +RE_SERIES_TAG = re.compile('^Series-([a-z-]*): *(.*)')
# Change-Id will be used to generate the Message-Id and then be stripped -re_change_id = re.compile('^Change-Id: *(.*)') +RE_CHANGE_ID = re.compile('^Change-Id: *(.*)')
# Commit series tag -re_commit_tag = re.compile('^Commit-([a-z-]*): *(.*)') +RE_COMMIT_TAG = re.compile('^Commit-([a-z-]*): *(.*)')
# Commit tags that we want to collect and keep -re_tag = re.compile('^(Tested-by|Acked-by|Reviewed-by|Patch-cc|Fixes): (.*)') +RE_TAG = re.compile('^(Tested-by|Acked-by|Reviewed-by|Patch-cc|Fixes): (.*)')
# The start of a new commit in the git log -re_commit = re.compile('^commit ([0-9a-f]*)$') +RE_COMMIT = re.compile('^commit ([0-9a-f]*)$')
# We detect these since checkpatch doesn't always do it -re_space_before_tab = re.compile('^[+].* \t') +RE_SPACE_BEFORE_TAB = re.compile('^[+].* \t')
# Match indented lines for changes -re_leading_whitespace = re.compile(r'^\s') +RE_LEADING_WHITESPACE = re.compile(r'^\s')
# States we can be in - can we use range() and still have comments? STATE_MSG_HEADER = 0 # Still in the message header @@ -195,22 +195,22 @@ class PatchStream: out = [] line = line.rstrip('\n')
- commit_match = re_commit.match(line) if self.is_log else None + commit_match = RE_COMMIT.match(line) if self.is_log else None
if self.is_log: if line[:4] == ' ': line = line[4:]
# Handle state transition and skipping blank lines - series_tag_match = re_series_tag.match(line) - change_id_match = re_change_id.match(line) - commit_tag_match = re_commit_tag.match(line) - cover_match = re_cover.match(line) - signoff_match = re_signoff.match(line) - leading_whitespace_match = re_leading_whitespace.match(line) + series_tag_match = RE_SERIES_TAG.match(line) + change_id_match = RE_CHANGE_ID.match(line) + commit_tag_match = RE_COMMIT_TAG.match(line) + cover_match = RE_COVER.match(line) + signoff_match = RE_SIGNOFF.match(line) + leading_whitespace_match = RE_LEADING_WHITESPACE.match(line) tag_match = None if self.state == STATE_PATCH_HEADER: - tag_match = re_tag.match(line) + tag_match = RE_TAG.match(line) is_blank = not line.strip() if is_blank: if (self.state == STATE_MSG_HEADER @@ -280,7 +280,7 @@ class PatchStream: self.commit.subject = line
# Detect the tags we want to remove, and skip blank lines - elif re_remove.match(line) and not commit_tag_match: + elif RE_REMOVE.match(line) and not commit_tag_match: self.skip_blank = True
# TEST= should be the last thing in the commit, so remove @@ -385,7 +385,7 @@ class PatchStream: # Well that means this is an ordinary line else: # Look for space before tab - m = re_space_before_tab.match(line) + m = RE_SPACE_BEFORE_TAB.match(line) if m: self.warn.append('Line %d/%d has space before tab' % (self.linenum, m.start())) @@ -410,7 +410,7 @@ class PatchStream: out += self.commit.notes out += [''] + log elif self.found_test: - if not re_allowed_after_test.match(line): + if not RE_ALLOWED_AFTER_TEST.match(line): self.lines_after_test += 1
return out
Rename these functions to lower case as per PEP8.
tools/buildman/control.py | 6 +-- tools/patman/control.py | 6 +-- tools/patman/func_test.py | 6 +-- tools/patman/patchstream.py | 88 ++++++++++++++++----------------- tools/patman/test_checkpatch.py | 6 +-- 5 files changed, 56 insertions(+), 56 deletions(-)
diff --git a/tools/buildman/control.py b/tools/buildman/control.py index b81ecf6a539..fe874b8165b 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -276,14 +276,14 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None, options.branch) upstream_commit = gitutil.GetUpstream(options.git_dir, options.branch) - series = patchstream.GetMetaDataForList(upstream_commit, + series = patchstream.get_metadata_for_list(upstream_commit, options.git_dir, 1, series=None, allow_overwrite=True)
- series = patchstream.GetMetaDataForList(range_expr, + series = patchstream.get_metadata_for_list(range_expr, options.git_dir, None, series, allow_overwrite=True) else: # Honour the count - series = patchstream.GetMetaDataForList(options.branch, + series = patchstream.get_metadata_for_list(options.branch, options.git_dir, count, series=None, allow_overwrite=True) else: series = None diff --git a/tools/patman/control.py b/tools/patman/control.py index aea9df8c8d1..6555a4018a4 100644 --- a/tools/patman/control.py +++ b/tools/patman/control.py @@ -54,14 +54,14 @@ def prepare_patches(col, branch, count, start, end, ignore_binary):
# Read the metadata from the commits to_do = count - end - series = patchstream.GetMetaData(branch, start, to_do) + series = patchstream.get_metadata(branch, start, to_do) cover_fname, patch_files = gitutil.CreatePatches( branch, start, to_do, ignore_binary, series)
# Fix up the patch files to our liking, and insert the cover letter - patchstream.FixPatches(series, patch_files) + patchstream.fix_patches(series, patch_files) if cover_fname and series.get('cover'): - patchstream.InsertCoverLetter(cover_fname, series, to_do) + patchstream.insert_cover_letter(cover_fname, series, to_do) return series, cover_fname, patch_files
def check_patches(series, patch_files, run_checkpatch, verbose): diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index ea3c84632c0..bdeccafda0b 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -191,12 +191,12 @@ class TestFunctional(unittest.TestCase): }
text = self._get_text('test01.txt') - series = patchstream.GetMetaDataForTest(text) + series = patchstream.get_metadata_for_test(text) cover_fname, args = self._create_patches_for_test(series) with capture_sys_output() as out: - patchstream.FixPatches(series, args) + patchstream.fix_patches(series, args) if cover_fname and series.get('cover'): - patchstream.InsertCoverLetter(cover_fname, series, count) + patchstream.insert_cover_letter(cover_fname, series, count) series.DoChecks() cc_file = series.MakeCcFile(process_tags, cover_fname, not ignore_bad_tags, add_maintainers, diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 86b03a7a30b..5487799bbee 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -83,7 +83,7 @@ class PatchStream: self.signoff = [] # Contents of signoff line self.commit = None # Current commit
- def AddToSeries(self, line, name, value): + def _add_to_series(self, line, name, value): """Add a new Series-xxx tag.
When a Series-xxx tag is detected, we come here to record it, if we @@ -100,7 +100,7 @@ class PatchStream: if self.is_log: self.series.AddTag(self.commit, line, name, value)
- def AddToCommit(self, line, name, value): + def _add_to_commit(self, line, name, value): """Add a new Commit-xxx tag.
When a Commit-xxx tag is detected, we come here to record it. @@ -114,7 +114,7 @@ class PatchStream: self.in_section = 'commit-' + name self.skip_blank = False
- def AddCommitRtag(self, rtag_type, who): + def _add_commit_rtag(self, rtag_type, who): """Add a response tag to the current commit
Args: @@ -123,7 +123,7 @@ class PatchStream: """ self.commit.AddRtag(rtag_type, who)
- def CloseCommit(self): + def _close_commit(self): """Save the current commit into our commit list, and reset our state""" if self.commit and self.is_log: self.series.AddCommit(self.commit) @@ -137,7 +137,7 @@ class PatchStream: self.skip_blank = True self.section = []
- def ParseVersion(self, value, line): + def _parse_version(self, value, line): """Parse a version from a *-changes tag
Args: @@ -153,8 +153,8 @@ class PatchStream: raise ValueError("%s: Cannot decode version info '%s'" % (self.commit.hash, line))
- def FinalizeChange(self): - """Finalize a (multi-line) change and add it to the series or commit""" + def _finalise_change(self): + """_finalise a (multi-line) change and add it to the series or commit""" if not self.change_lines: return change = '\n'.join(self.change_lines) @@ -167,7 +167,7 @@ class PatchStream: self.commit.AddChange(self.change_version, change) self.change_lines = []
- def ProcessLine(self, line): + def process_line(self, line): """Process a single line of a patch file or commit log
This process a line and returns a list of lines to output. The list @@ -248,7 +248,7 @@ class PatchStream: # is missing, fix it up. if self.in_change: self.warn.append("Missing 'blank line' in section '%s-changes'" % self.in_change) - self.FinalizeChange() + self._finalise_change() self.in_change = None self.change_version = 0
@@ -298,26 +298,26 @@ class PatchStream: self.in_section = 'cover' self.skip_blank = False elif name == 'letter-cc': - self.AddToSeries(line, 'cover-cc', value) + self._add_to_series(line, 'cover-cc', value) elif name == 'changes': self.in_change = 'Cover' - self.change_version = self.ParseVersion(value, line) + self.change_version = self._parse_version(value, line)
# If we are in a change list, key collected lines until a blank one elif self.in_change: if is_blank: # Blank line ends this change list - self.FinalizeChange() + self._finalise_change() self.in_change = None self.change_version = 0 elif line == '---': - self.FinalizeChange() + self._finalise_change() self.in_change = None self.change_version = 0 - out = self.ProcessLine(line) + out = self.process_line(line) elif self.is_log: if not leading_whitespace_match: - self.FinalizeChange() + self._finalise_change() self.change_lines.append(line) self.skip_blank = False
@@ -328,9 +328,9 @@ class PatchStream: if name == 'changes': # value is the version number: e.g. 1, or 2 self.in_change = 'Series' - self.change_version = self.ParseVersion(value, line) + self.change_version = self._parse_version(value, line) else: - self.AddToSeries(line, name, value) + self._add_to_series(line, name, value) self.skip_blank = True
# Detect Change-Id tags @@ -349,24 +349,24 @@ class PatchStream: name = commit_tag_match.group(1) value = commit_tag_match.group(2) if name == 'notes': - self.AddToCommit(line, name, value) + self._add_to_commit(line, name, value) self.skip_blank = True elif name == 'changes': self.in_change = 'Commit' - self.change_version = self.ParseVersion(value, line) + self.change_version = self._parse_version(value, line) else: self.warn.append('Line %d: Ignoring Commit-%s' % (self.linenum, name))
# Detect the start of a new commit elif commit_match: - self.CloseCommit() + self._close_commit() self.commit = commit.Commit(commit_match.group(1))
# Detect tags in the commit message elif tag_match: rtag_type, who = tag_match.groups() - self.AddCommitRtag(rtag_type, who) + self._add_commit_rtag(rtag_type, who) # Remove Tested-by self, since few will take much notice if (rtag_type == 'Tested-by' and who.find(os.getenv('USER') + '@') != -1): @@ -415,15 +415,15 @@ class PatchStream:
return out
- def Finalize(self): + def finalise(self): """Close out processing of this patch stream""" - self.FinalizeChange() - self.CloseCommit() + self._finalise_change() + self._close_commit() if self.lines_after_test: self.warn.append('Found %d lines after TEST=' % self.lines_after_test)
- def WriteMessageId(self, outfd): + def _write_message_id(self, outfd): """Write the Message-Id into the output.
This is based on the Change-Id in the original patch, the version, @@ -464,7 +464,7 @@ class PatchStream: # Join parts together with "." and write it out. outfd.write('Message-Id: %s@changeid\n' % '.'.join(parts))
- def ProcessStream(self, infd, outfd): + def process_stream(self, infd, outfd): """Copy a stream from infd to outfd, filtering out unwanting things.
This is used to process patch files one at a time. @@ -478,13 +478,13 @@ class PatchStream: last_fname = None re_fname = re.compile('diff --git a/(.*) b/.*')
- self.WriteMessageId(outfd) + self._write_message_id(outfd)
while True: line = infd.readline() if not line: break - out = self.ProcessLine(line) + out = self.process_line(line)
# Try to detect blank lines at EOF for line in out: @@ -501,11 +501,11 @@ class PatchStream: outfd.write('+\n' * self.blank_count) outfd.write(line + '\n') self.blank_count = 0 - self.Finalize() + self.finalise()
-def GetMetaDataForList(commit_range, git_dir=None, count=None, - series=None, allow_overwrite=False): +def get_metadata_for_list(commit_range, git_dir=None, count=None, + series=None, allow_overwrite=False): """Reads out patch series metadata from the commits
This does a 'git log' on the relevant commits and pulls out the tags we @@ -529,11 +529,11 @@ def GetMetaDataForList(commit_range, git_dir=None, count=None, stdout = command.RunPipe([params], capture=True).stdout ps = PatchStream(series, is_log=True) for line in stdout.splitlines(): - ps.ProcessLine(line) - ps.Finalize() + ps.process_line(line) + ps.finalise() return series
-def GetMetaData(branch, start, count): +def get_metadata(branch, start, count): """Reads out patch series metadata from the commits
This does a 'git log' on the relevant commits and pulls out the tags we @@ -544,10 +544,10 @@ def GetMetaData(branch, start, count): start: Commit to start from: 0=branch HEAD, 1=next one, etc. count: Number of commits to list """ - return GetMetaDataForList('%s~%d' % (branch if branch else 'HEAD', start), - None, count) + return get_metadata_for_list( + '%s~%d' % (branch if branch else 'HEAD', start), None, count)
-def GetMetaDataForTest(text): +def get_metadata_for_test(text): """Process metadata from a file containing a git log. Used for tests
Args: @@ -556,11 +556,11 @@ def GetMetaDataForTest(text): series = Series() ps = PatchStream(series, is_log=True) for line in text.splitlines(): - ps.ProcessLine(line) - ps.Finalize() + ps.process_line(line) + ps.finalise() return series
-def FixPatch(backup_dir, fname, series, commit): +def fix_patch(backup_dir, fname, series, commit): """Fix up a patch file, by adding/removing as required.
We remove our tags from the patch file, insert changes lists, etc. @@ -580,7 +580,7 @@ def FixPatch(backup_dir, fname, series, commit): infd = open(fname, 'r', encoding='utf-8') ps = PatchStream(series) ps.commit = commit - ps.ProcessStream(infd, outfd) + ps.process_stream(infd, outfd) infd.close() outfd.close()
@@ -590,7 +590,7 @@ def FixPatch(backup_dir, fname, series, commit): shutil.move(tmpname, fname) return ps.warn
-def FixPatches(series, fnames): +def fix_patches(series, fnames): """Fix up a list of patches identified by filenames
The patch files are processed in place, and overwritten. @@ -606,7 +606,7 @@ def FixPatches(series, fnames): commit = series.commits[count] commit.patch = fname commit.count = count - result = FixPatch(backup_dir, fname, series, commit) + result = fix_patch(backup_dir, fname, series, commit) if result: print('%d warnings for %s:' % (len(result), fname)) for warn in result: @@ -615,7 +615,7 @@ def FixPatches(series, fnames): count += 1 print('Cleaned %d patches' % count)
-def InsertCoverLetter(fname, series, count): +def insert_cover_letter(fname, series, count): """Inserts a cover letter with the required info into patch 0
Args: diff --git a/tools/patman/test_checkpatch.py b/tools/patman/test_checkpatch.py index f71c70fb13a..1f7c38c4e90 100644 --- a/tools/patman/test_checkpatch.py +++ b/tools/patman/test_checkpatch.py @@ -148,15 +148,15 @@ Signed-off-by: Simon Glass sjg@chromium.org expfd.write(expected) expfd.close()
- # Normally by the time we call FixPatch we've already collected + # Normally by the time we call fix_patch we've already collected # metadata. Here, we haven't, but at least fake up something. - # Set the "count" to -1 which tells FixPatch to use a bogus/fixed + # Set the "count" to -1 which tells fix_patch to use a bogus/fixed # time for generating the Message-Id. com = commit.Commit('') com.change_id = 'I80fe1d0c0b7dd10aa58ce5bb1d9290b6664d5413' com.count = -1
- patchstream.FixPatch(None, inname, series.Series(), com) + patchstream.fix_patch(None, inname, series.Series(), com)
rc = os.system('diff -u %s %s' % (inname, expname)) self.assertEqual(rc, 0)
Some variables are too short or shadow other variables or types. Fix these to keep pylint3 happy.
tools/patman/patchstream.py | 52 ++++++++++++++++++------------------- 1 file changed, 26 insertions(+), 26 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 5487799bbee..3a057fbd6c4 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -149,7 +149,7 @@ class PatchStream: """ try: return int(value) - except ValueError as str: + except ValueError: raise ValueError("%s: Cannot decode version info '%s'" % (self.commit.hash, line))
@@ -385,10 +385,10 @@ class PatchStream: # Well that means this is an ordinary line else: # Look for space before tab - m = RE_SPACE_BEFORE_TAB.match(line) - if m: + mat = RE_SPACE_BEFORE_TAB.match(line) + if mat: self.warn.append('Line %d/%d has space before tab' % - (self.linenum, m.start())) + (self.linenum, mat.start()))
# OK, we have a valid non-blank line out = [line] @@ -527,10 +527,10 @@ def get_metadata_for_list(commit_range, git_dir=None, count=None, params = gitutil.LogCmd(commit_range, reverse=True, count=count, git_dir=git_dir) stdout = command.RunPipe([params], capture=True).stdout - ps = PatchStream(series, is_log=True) + pst = PatchStream(series, is_log=True) for line in stdout.splitlines(): - ps.process_line(line) - ps.finalise() + pst.process_line(line) + pst.finalise() return series
def get_metadata(branch, start, count): @@ -554,13 +554,13 @@ def get_metadata_for_test(text): text: """ series = Series() - ps = PatchStream(series, is_log=True) + pst = PatchStream(series, is_log=True) for line in text.splitlines(): - ps.process_line(line) - ps.finalise() + pst.process_line(line) + pst.finalise() return series
-def fix_patch(backup_dir, fname, series, commit): +def fix_patch(backup_dir, fname, series, cmt): """Fix up a patch file, by adding/removing as required.
We remove our tags from the patch file, insert changes lists, etc. @@ -571,16 +571,16 @@ def fix_patch(backup_dir, fname, series, commit): Args: fname: Filename to patch file to process series: Series information about this patch set - commit: Commit object for this patch file + cmt: Commit object for this patch file Return: A list of errors, or [] if all ok. """ handle, tmpname = tempfile.mkstemp() outfd = os.fdopen(handle, 'w', encoding='utf-8') infd = open(fname, 'r', encoding='utf-8') - ps = PatchStream(series) - ps.commit = commit - ps.process_stream(infd, outfd) + pst = PatchStream(series) + pst.commit = cmt + pst.process_stream(infd, outfd) infd.close() outfd.close()
@@ -588,7 +588,7 @@ def fix_patch(backup_dir, fname, series, commit): if backup_dir: shutil.copy(fname, os.path.join(backup_dir, os.path.basename(fname))) shutil.move(tmpname, fname) - return ps.warn + return pst.warn
def fix_patches(series, fnames): """Fix up a list of patches identified by filenames @@ -603,10 +603,10 @@ def fix_patches(series, fnames): backup_dir = None #tempfile.mkdtemp('clean-patch') count = 0 for fname in fnames: - commit = series.commits[count] - commit.patch = fname - commit.count = count - result = fix_patch(backup_dir, fname, series, commit) + cmt = series.commits[count] + cmt.patch = fname + cmt.count = count + result = fix_patch(backup_dir, fname, series, cmt) if result: print('%d warnings for %s:' % (len(result), fname)) for warn in result: @@ -623,11 +623,11 @@ def insert_cover_letter(fname, series, count): series: Series object count: Number of patches in the series """ - fd = open(fname, 'r') - lines = fd.readlines() - fd.close() + fil = open(fname, 'r') + lines = fil.readlines() + fil.close()
- fd = open(fname, 'w') + fil = open(fname, 'w') text = series.cover prefix = series.GetPatchPrefix() for line in lines: @@ -647,5 +647,5 @@ def insert_cover_letter(fname, series, count): # Now the change list out = series.MakeChangeLog(None) line += '\n' + '\n'.join(out) - fd.write(line) - fd.close() + fil.write(line) + fil.close()
Drop a few arguments that are not used in functions.
tools/patman/patchstream.py | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 3a057fbd6c4..c5402dd896a 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -64,7 +64,7 @@ class PatchStream: unwanted tags or inject additional ones. These correspond to the two phases of processing. """ - def __init__(self, series, name=None, is_log=False): + def __init__(self, series, is_log=False): self.skip_blank = False # True to skip a single blank line self.found_test = False # Found a TEST= line self.lines_after_test = 0 # Number of lines found after TEST= @@ -100,15 +100,13 @@ class PatchStream: if self.is_log: self.series.AddTag(self.commit, line, name, value)
- def _add_to_commit(self, line, name, value): + def _add_to_commit(self, name): """Add a new Commit-xxx tag.
Args: - line: Source line containing tag (useful for debug/error messages) name: Tag name (part after 'Commit-') - value: Tag value (part after 'Commit-xxx: ') """ if name == 'notes': self.in_section = 'commit-' + name @@ -349,7 +347,7 @@ class PatchStream: name = commit_tag_match.group(1) value = commit_tag_match.group(2) if name == 'notes': - self._add_to_commit(line, name, value) + self._add_to_commit(name) self.skip_blank = True elif name == 'changes': self.in_change = 'Commit'
Add missing documentation and type information. Fix up some missing docs on exceptions also.
tools/patman/patchstream.py | 82 ++++++++++++++++++++++--------------- 1 file changed, 50 insertions(+), 32 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index c5402dd896a..b2cb2debeee 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -90,9 +90,10 @@ class PatchStream: are scanning a 'git log'.
Args: - line: Source line containing tag (useful for debug/error messages) - name: Tag name (part after 'Series-') - value: Tag value (part after 'Series-xxx: ') + line (str): Source line containing tag (useful for debug/error + messages) + name (str): Tag name (part after 'Series-') + value (str): Tag value (part after 'Series-xxx: ') """ if name == 'notes': self.in_section = name @@ -106,7 +107,7 @@ class PatchStream: When a Commit-xxx tag is detected, we come here to record it.
Args: - name: Tag name (part after 'Commit-') + name (str): Tag name (part after 'Commit-') """ if name == 'notes': self.in_section = 'commit-' + name @@ -116,8 +117,9 @@ class PatchStream: """Add a response tag to the current commit
Args: - key: rtag type (e.g. 'Reviewed-by') - who: Person who gave that rtag, e.g. 'Fred Bloggs fred@bloggs.org' + rtag_type (str): rtag type (e.g. 'Reviewed-by') + who (str): Person who gave that rtag, e.g. + 'Fred Bloggs fred@bloggs.org' """ self.commit.AddRtag(rtag_type, who)
@@ -139,11 +141,14 @@ class PatchStream: """Parse a version from a *-changes tag
Args: - value: Tag value (part after 'xxx-changes: ' - line: Source line containing tag + value (str): Tag value (part after 'xxx-changes: ' + line (str): Source line containing tag
Returns: - The version as an integer + int: The version as an integer + + Raises: + ValueError: the value cannot be converted """ try: return int(value) @@ -184,10 +189,14 @@ class PatchStream: don't want, and add things we think are required.
Args: - line: text line to process + line (str): text line to process
Returns: - list of output lines, or [] if nothing should be output + list: list of output lines, or [] if nothing should be output + + Raises: + ValueError: a fatal error occurred while parsing, e.g. an END + without a starting tag, or two commits with two change IDs """ # Initially we have no output. Prepare the input line string out = [] @@ -428,7 +437,7 @@ class PatchStream: and the prefix.
Args: - outfd: Output stream file object + outfd (io.IOBase): Output stream file object """ if not self.commit.change_id: return @@ -468,8 +477,8 @@ class PatchStream: This is used to process patch files one at a time.
Args: - infd: Input stream file object - outfd: Output stream file object + infd (io.IOBase): Input stream file object + outfd (io.IOBase): Output stream file object """ # Extract the filename from each diff, for nice warnings fname = None @@ -510,14 +519,15 @@ def get_metadata_for_list(commit_range, git_dir=None, count=None, are interested in.
Args: - commit_range: Range of commits to count (e.g. 'HEAD..base') - git_dir: Path to git repositiory (None to use default) - count: Number of commits to list, or None for no limit - series: Series object to add information into. By default a new series + commit_range (str): Range of commits to count (e.g. 'HEAD..base') + git_dir (str): Path to git repositiory (None to use default) + count (int): Number of commits to list, or None for no limit + series (Series): Object to add information into. By default a new series is started. - allow_overwrite: Allow tags to overwrite an existing tag + allow_overwrite (bool): Allow tags to overwrite an existing tag + Returns: - A Series object containing information about the commits. + Series: Object containing information about the commits. """ if not series: series = Series() @@ -538,9 +548,12 @@ def get_metadata(branch, start, count): are interested in.
Args: - branch: Branch to use (None for current branch) - start: Commit to start from: 0=branch HEAD, 1=next one, etc. - count: Number of commits to list + branch (str): Branch to use (None for current branch) + start (int): Commit to start from: 0=branch HEAD, 1=next one, etc. + count (int): Number of commits to list + + Returns: + Series: Object containing information about the commits. """ return get_metadata_for_list( '%s~%d' % (branch if branch else 'HEAD', start), None, count) @@ -550,6 +563,9 @@ def get_metadata_for_test(text):
Args: text: + + Returns: + Series: Object containing information about the commits. """ series = Series() pst = PatchStream(series, is_log=True) @@ -567,11 +583,13 @@ def fix_patch(backup_dir, fname, series, cmt): A backup file is put into backup_dir (if not None).
Args: - fname: Filename to patch file to process - series: Series information about this patch set - cmt: Commit object for this patch file + backup_dir (str): Path to directory to use to backup the file + fname (str): Filename to patch file to process + series (Series): Series information about this patch set + cmt (Commit): Commit object for this patch file + Return: - A list of errors, or [] if all ok. + list: A list of errors, each str, or [] if all ok. """ handle, tmpname = tempfile.mkstemp() outfd = os.fdopen(handle, 'w', encoding='utf-8') @@ -594,8 +612,8 @@ def fix_patches(series, fnames): The patch files are processed in place, and overwritten.
Args: - series: The series object - fnames: List of patch files to process + series (Series): The Series object + fnames (:type: list of str): List of patch files to process """ # Current workflow creates patches, so we shouldn't need a backup backup_dir = None #tempfile.mkdtemp('clean-patch') @@ -617,9 +635,9 @@ def insert_cover_letter(fname, series, count): """Inserts a cover letter with the required info into patch 0
Args: - fname: Input / output filename of the cover letter file - series: Series object - count: Number of patches in the series + fname (str): Input / output filename of the cover letter file + series (Series): Series object + count (int): Number of patches in the series """ fil = open(fname, 'r') lines = fil.readlines()
Add a new function in PatchStream to collect the warnings generated while parsing the stream. This will allow us to adjust the logic, such as dealing with per-commit warnings.
Two of the warnings are in fact internal errors, so change them to raise and exception.
tools/patman/patchstream.py | 36 +++++++++++++++++++++++------------- 1 file changed, 23 insertions(+), 13 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index b2cb2debeee..9f283470bc2 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -83,6 +83,14 @@ class PatchStream: self.signoff = [] # Contents of signoff line self.commit = None # Current commit
+ def _add_warn(self, warn): + """Add a new warning to report to the user + + Args: + warn (str): Warning to report + """ + self.warn.append(warn) + def _add_to_series(self, line, name, value): """Add a new Series-xxx tag.
@@ -237,7 +245,7 @@ class PatchStream: # but we are already in a section, this means 'END' is missing # for that section, fix it up. if self.in_section: - self.warn.append("Missing 'END' in section '%s'" % self.in_section) + self._add_warn("Missing 'END' in section '%s'" % self.in_section) if self.in_section == 'cover': self.series.cover = self.section elif self.in_section == 'notes': @@ -247,14 +255,16 @@ class PatchStream: if self.is_log: self.commit.notes += self.section else: - self.warn.append("Unknown section '%s'" % self.in_section) + # This should not happen + raise ValueError("Unknown section '%s'" % self.in_section) self.in_section = None self.skip_blank = True self.section = [] # but we are already in a change list, that means a blank line # is missing, fix it up. if self.in_change: - self.warn.append("Missing 'blank line' in section '%s-changes'" % self.in_change) + self._add_warn("Missing 'blank line' in section '%s-changes'" % + self.in_change) self._finalise_change() self.in_change = None self.change_version = 0 @@ -271,7 +281,8 @@ class PatchStream: if self.is_log: self.commit.notes += self.section else: - self.warn.append("Unknown section '%s'" % self.in_section) + # This should not happen + raise ValueError("Unknown section '%s'" % self.in_section) self.in_section = None self.skip_blank = True self.section = [] @@ -362,8 +373,8 @@ class PatchStream: self.in_change = 'Commit' self.change_version = self._parse_version(value, line) else: - self.warn.append('Line %d: Ignoring Commit-%s' % - (self.linenum, name)) + self._add_warn('Line %d: Ignoring Commit-%s' % + (self.linenum, name))
# Detect the start of a new commit elif commit_match: @@ -377,7 +388,7 @@ class PatchStream: # Remove Tested-by self, since few will take much notice if (rtag_type == 'Tested-by' and who.find(os.getenv('USER') + '@') != -1): - self.warn.append("Ignoring %s" % line) + self._add_warn("Ignoring %s" % line) elif rtag_type == 'Patch-cc': self.commit.AddCc(who.split(',')) else: @@ -394,8 +405,8 @@ class PatchStream: # Look for space before tab mat = RE_SPACE_BEFORE_TAB.match(line) if mat: - self.warn.append('Line %d/%d has space before tab' % - (self.linenum, mat.start())) + self._add_warn('Line %d/%d has space before tab' % + (self.linenum, mat.start()))
# OK, we have a valid non-blank line out = [line] @@ -427,8 +438,7 @@ class PatchStream: self._finalise_change() self._close_commit() if self.lines_after_test: - self.warn.append('Found %d lines after TEST=' % - self.lines_after_test) + self._add_warn('Found %d lines after TEST=' % self.lines_after_test)
def _write_message_id(self, outfd): """Write the Message-Id into the output. @@ -503,8 +513,8 @@ class PatchStream: self.blank_count += 1 else: if self.blank_count and (line == '-- ' or match): - self.warn.append("Found possible blank line(s) at " - "end of file '%s'" % last_fname) + self._add_warn("Found possible blank line(s) at end of file '%s'" % + last_fname) outfd.write('+\n' * self.blank_count) outfd.write(line + '\n') self.blank_count = 0
At present warnings are produced across the whole set of patches when parsing them. It is more useful to associate each warning with the patch (or commit) that generated it.
Attach warnings to the Commit object and move them out of PatchStream. Also avoid generating duplicate warnings for the same commit.
tools/patman/commit.py | 2 ++ tools/patman/patchstream.py | 15 +++++++++++---- 2 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/tools/patman/commit.py b/tools/patman/commit.py index 8d583c4ed39..e49bf87dfc8 100644 --- a/tools/patman/commit.py +++ b/tools/patman/commit.py @@ -27,6 +27,7 @@ class Commit: rtags: Response tags (e.g. Reviewed-by) collected by the commit, dict: key: rtag type (e.g. 'Reviewed-by') value: Set of people who gave that rtag, each a name/email string + warn: List of warnings for this commit, each a str """ def __init__(self, hash): self.hash = hash @@ -38,6 +39,7 @@ class Commit: self.notes = [] self.change_id = None self.rtags = collections.defaultdict(set) + self.warn = []
def AddChange(self, version, info): """Add a new change line to the change list for a version. diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 9f283470bc2..880d7ddc7f2 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -68,7 +68,6 @@ class PatchStream: self.skip_blank = False # True to skip a single blank line self.found_test = False # Found a TEST= line self.lines_after_test = 0 # Number of lines found after TEST= - self.warn = [] # List of warnings we have collected self.linenum = 1 # Output line number we are up to self.in_section = None # Name of start...END section we are in self.notes = [] # Series notes @@ -84,12 +83,20 @@ class PatchStream: self.commit = None # Current commit
def _add_warn(self, warn): - """Add a new warning to report to the user + """Add a new warning to report to the user about the current commit + + The new warning is added to the current commit if not already present.
Args: warn (str): Warning to report + + Raises: + ValueError: Warning is generated with no commit associated """ - self.warn.append(warn) + if not self.commit: + raise ValueError('Warning outside commit: %s' % warn) + if warn not in self.commit.warn: + self.commit.warn.append(warn)
def _add_to_series(self, line, name, value): """Add a new Series-xxx tag. @@ -614,7 +621,7 @@ def fix_patch(backup_dir, fname, series, cmt): if backup_dir: shutil.copy(fname, os.path.join(backup_dir, os.path.basename(fname))) shutil.move(tmpname, fname) - return pst.warn + return cmt.warn
If the Series-xxx tag is not recognised patman currently reports a fatal error. This is inconvenient if a new feature is later added to patman that an earlier version does not support.
Report a warning instead, to allow the user to take action if needed, but still allow operation to proceed.
tools/patman/patchstream.py | 4 +++- tools/patman/series.py | 6 +++++- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 880d7ddc7f2..24040d43d62 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -114,7 +114,9 @@ class PatchStream: self.in_section = name self.skip_blank = False if self.is_log: - self.series.AddTag(self.commit, line, name, value) + warn = self.series.AddTag(self.commit, line, name, value) + if warn: + self.commit.warn.append(warn)
def _add_to_commit(self, name): """Add a new Commit-xxx tag. diff --git a/tools/patman/series.py b/tools/patman/series.py index 393a44241bd..4457719f2ef 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -59,6 +59,9 @@ class Series(dict): line: Source line containing tag (useful for debug/error messages) name: Tag name (part after 'Series-') value: Tag value (part after 'Series-xxx: ') + + Returns: + String warning if something went wrong, else None """ # If we already have it, then add to our list name = name.replace('-', '_') @@ -78,9 +81,10 @@ class Series(dict): else: self[name] = value else: - raise ValueError("In %s: line '%s': Unknown 'Series-%s': valid " + return ("In %s: line '%s': Unknown 'Series-%s': valid " "options are %s" % (commit.hash, line, name, ', '.join(valid_series))) + return None
def AddCommit(self, commit): """Add a commit into our list of commits
This is not used. Drop it.
tools/patman/func_test.py | 1 + tools/patman/patchstream.py | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index bdeccafda0b..2290ba95e9d 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -16,6 +16,7 @@ import unittest from patman import control from patman import gitutil from patman import patchstream +from patman.patchstream import PatchStream from patman import settings from patman import terminal from patman import tools diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 24040d43d62..cf591b27573 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -79,7 +79,6 @@ class PatchStream: self.change_lines = [] # Lines of the current change self.blank_count = 0 # Number of blank lines stored up self.state = STATE_MSG_HEADER # What state are we in? - self.signoff = [] # Contents of signoff line self.commit = None # Current commit
The current functional tests run most of patman. Add a smaller test that just checks tag handling with the PatchStream class.
tools/patman/func_test.py | 26 +++++++++++++++++++++----- tools/patman/patchstream.py | 23 +++++++++++++++++++++++ 2 files changed, 44 insertions(+), 5 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 2290ba95e9d..2a0da8b3ccf 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -31,6 +31,9 @@ except ModuleNotFoundError:
class TestFunctional(unittest.TestCase): """Functional tests for checking that patman behaves correctly""" + leb = (b'Lord Edmund Blackadd\xc3\xabr weasel@blackadder.org'. + decode('utf-8')) + def setUp(self): self.tmpdir = tempfile.mkdtemp(prefix='patman.') self.gitdir = os.path.join(self.tmpdir, 'git') @@ -177,8 +180,6 @@ class TestFunctional(unittest.TestCase): stefan = b'Stefan Br\xc3\xbcns stefan.bruens@rwth-aachen.de'.decode('utf-8') rick = 'Richard III richard@palace.gov' mel = b'Lord M\xc3\xablchett clergy@palace.gov'.decode('utf-8') - leb = (b'Lond Edmund Blackadd\xc3\xabr <weasel@blackadder.org'. - decode('utf-8')) fred = 'Fred Bloggs f.bloggs@napier.net' add_maintainers = [stefan, rick] dry_run = True @@ -187,7 +188,7 @@ class TestFunctional(unittest.TestCase): settings.alias = { 'fdt': ['simon'], 'u-boot': ['u-boot@lists.denx.de'], - 'simon': [leb], + 'simon': [self.leb], 'fred': [fred], }
@@ -231,7 +232,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual('Cover: 4 lines', lines[line + 4]) line += 5 self.assertEqual(' Cc: %s' % fred, lines[line + 0]) - self.assertEqual(' Cc: %s' % tools.FromUnicode(leb), + self.assertEqual(' Cc: %s' % tools.FromUnicode(self.leb), lines[line + 1]) self.assertEqual(' Cc: %s' % tools.FromUnicode(mel), lines[line + 2]) @@ -247,7 +248,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual(('%s %s\0%s' % (args[0], rick, stefan)), tools.ToUnicode(cc_lines[0])) self.assertEqual( - '%s %s\0%s\0%s\0%s' % (args[1], fred, leb, rick, stefan), + '%s %s\0%s\0%s\0%s' % (args[1], fred, self.leb, rick, stefan), tools.ToUnicode(cc_lines[1]))
expected = ''' @@ -480,3 +481,18 @@ complicated as possible''') self.assertEqual(2, len(patch_files)) finally: os.chdir(orig_dir) + + def testTags(self): + """Test collection of tags in a patchstream""" + text = '''This is a patch + +Signed-off-by: Terminator +Reviewed-by: Joe Bloggs joe@napierwallies.co.nz +Reviewed-by: Mary Bloggs mary@napierwallies.co.nz +Tested-by: %s +''' % self.leb + pstrm = PatchStream.process_text(text) + self.assertEqual(pstrm.commit.rtags, { + 'Reviewed-by': {'Mary Bloggs mary@napierwallies.co.nz', + 'Joe Bloggs joe@napierwallies.co.nz'}, + 'Tested-by': {self.leb}}) diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index cf591b27573..d6f6ae92513 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -5,6 +5,7 @@ """Handles parsing a stream of commits/emails from 'git log' or other source"""
import datetime +import io import math import os import re @@ -81,6 +82,28 @@ class PatchStream: self.state = STATE_MSG_HEADER # What state are we in? self.commit = None # Current commit
+ @staticmethod + def process_text(text, is_comment=False): + """Process some text through this class using a default Commit/Series + + Args: + text (str): Text to parse + is_comment (bool): True if this is a comment rather than a patch. + If True, PatchStream doesn't expect a patch subject at the + start, but jumps straight into the body + + Returns: + PatchStream: object with results + """ + pstrm = PatchStream(Series()) + pstrm.commit = commit.Commit(None) + infd = io.StringIO(text) + outfd = io.StringIO() + if is_comment: + pstrm.state = STATE_PATCH_HEADER + pstrm.process_stream(infd, outfd) + return pstrm + def _add_warn(self, warn): """Add a new warning to report to the user about the current commit
Signed-off-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
Applied to u-boot-dm, thanks!
Add tests that check that warnings are generated when expected.
tools/patman/func_test.py | 111 +++++++++++++++++++++++++++++++++--- tools/patman/main.py | 16 +++++- tools/patman/patchstream.py | 2 +- 3 files changed, 116 insertions(+), 13 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 2a0da8b3ccf..02d46ae5f73 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -33,6 +33,9 @@ class TestFunctional(unittest.TestCase): """Functional tests for checking that patman behaves correctly""" leb = (b'Lord Edmund Blackadd\xc3\xabr weasel@blackadder.org'. decode('utf-8')) + fred = 'Fred Bloggs f.bloggs@napier.net' + joe = 'Joe Bloggs joe@napierwallies.co.nz' + mary = 'Mary Bloggs mary@napierwallies.co.nz'
def setUp(self): self.tmpdir = tempfile.mkdtemp(prefix='patman.') @@ -180,7 +183,6 @@ class TestFunctional(unittest.TestCase): stefan = b'Stefan Br\xc3\xbcns stefan.bruens@rwth-aachen.de'.decode('utf-8') rick = 'Richard III richard@palace.gov' mel = b'Lord M\xc3\xablchett clergy@palace.gov'.decode('utf-8') - fred = 'Fred Bloggs f.bloggs@napier.net' add_maintainers = [stefan, rick] dry_run = True in_reply_to = mel @@ -189,7 +191,7 @@ class TestFunctional(unittest.TestCase): 'fdt': ['simon'], 'u-boot': ['u-boot@lists.denx.de'], 'simon': [self.leb], - 'fred': [fred], + 'fred': [self.fred], }
text = self._get_text('test01.txt') @@ -231,7 +233,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual('Prefix:\t RFC', lines[line + 3]) self.assertEqual('Cover: 4 lines', lines[line + 4]) line += 5 - self.assertEqual(' Cc: %s' % fred, lines[line + 0]) + self.assertEqual(' Cc: %s' % self.fred, lines[line + 0]) self.assertEqual(' Cc: %s' % tools.FromUnicode(self.leb), lines[line + 1]) self.assertEqual(' Cc: %s' % tools.FromUnicode(mel), @@ -248,7 +250,7 @@ class TestFunctional(unittest.TestCase): self.assertEqual(('%s %s\0%s' % (args[0], rick, stefan)), tools.ToUnicode(cc_lines[0])) self.assertEqual( - '%s %s\0%s\0%s\0%s' % (args[1], fred, self.leb, rick, stefan), + '%s %s\0%s\0%s\0%s' % (args[1], self.fred, self.leb, rick, stefan), tools.ToUnicode(cc_lines[1]))
expected = ''' @@ -487,12 +489,103 @@ complicated as possible''') text = '''This is a patch
Signed-off-by: Terminator -Reviewed-by: Joe Bloggs joe@napierwallies.co.nz -Reviewed-by: Mary Bloggs mary@napierwallies.co.nz +Reviewed-by: %s +Reviewed-by: %s Tested-by: %s -''' % self.leb +''' % (self.joe, self.mary, self.leb) pstrm = PatchStream.process_text(text) self.assertEqual(pstrm.commit.rtags, { - 'Reviewed-by': {'Mary Bloggs mary@napierwallies.co.nz', - 'Joe Bloggs joe@napierwallies.co.nz'}, + 'Reviewed-by': {self.joe, self.mary}, 'Tested-by': {self.leb}}) + + def testMissingEnd(self): + """Test a missing END tag""" + text = '''This is a patch + +Cover-letter: +This is the title +missing END after this line +Signed-off-by: Fred +''' + pstrm = PatchStream.process_text(text) + self.assertEqual(["Missing 'END' in section 'cover'"], + pstrm.commit.warn) + + def testMissingBlankLine(self): + """Test a missing blank line after a tag""" + text = '''This is a patch + +Series-changes: 2 +- First line of changes +- Missing blank line after this line +Signed-off-by: Fred +''' + pstrm = PatchStream.process_text(text) + self.assertEqual(["Missing 'blank line' in section 'Series-changes'"], + pstrm.commit.warn) + + def testInvalidCommitTag(self): + """Test an invalid Commit-xxx tag""" + text = '''This is a patch + +Commit-fred: testing +''' + pstrm = PatchStream.process_text(text) + self.assertEqual(["Line 3: Ignoring Commit-fred"], pstrm.commit.warn) + + def testSelfTest(self): + """Test a tested by tag by this user""" + test_line = 'Tested-by: %s@napier.com' % os.getenv('USER') + text = '''This is a patch + +%s +''' % test_line + pstrm = PatchStream.process_text(text) + self.assertEqual(["Ignoring '%s'" % test_line], pstrm.commit.warn) + + def testSpaceBeforeTab(self): + """Test a space before a tab""" + text = '''This is a patch + ++ \tSomething +''' + pstrm = PatchStream.process_text(text) + self.assertEqual(["Line 3/0 has space before tab"], pstrm.commit.warn) + + def testLinesAfterTest(self): + """Test detecting lines after TEST= line""" + text = '''This is a patch + +TEST=sometest +more lines +here +''' + pstrm = PatchStream.process_text(text) + self.assertEqual(["Found 2 lines after TEST="], pstrm.commit.warn) + + def testBlankLineAtEnd(self): + """Test detecting a blank line at the end of a file""" + text = '''This is a patch + +diff --git a/lib/fdtdec.c b/lib/fdtdec.c +index c072e54..942244f 100644 +--- a/lib/fdtdec.c ++++ b/lib/fdtdec.c +@@ -1200,7 +1200,8 @@ int fdtdec_setup_mem_size_base(void) + } + + gd->ram_size = (phys_size_t)(res.end - res.start + 1); +- debug("%s: Initial DRAM size %llx\n", __func__, (u64)gd->ram_size); ++ debug("%s: Initial DRAM size %llx\n", __func__, ++ (unsigned long long)gd->ram_size); ++ +diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c + +-- +2.7.4 + + ''' + pstrm = PatchStream.process_text(text) + self.assertEqual( + ["Found possible blank line(s) at end of file 'lib/fdtdec.c'"], + pstrm.commit.warn) diff --git a/tools/patman/main.py b/tools/patman/main.py index b96000807eb..d1a43c44fcd 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -86,6 +86,8 @@ AddCommonArgs(send) send.add_argument('patchfiles', nargs='*')
test_parser = subparsers.add_parser('test', help='Run tests') +test_parser.add_argument('testname', type=str, default=None, nargs='?', + help="Specify the test to run") AddCommonArgs(test_parser)
# Parse options twice: first to get the project and second to handle @@ -111,15 +113,23 @@ if args.cmd == 'test':
sys.argv = [sys.argv[0]] result = unittest.TestResult() + suite = unittest.TestSuite() + loader = unittest.TestLoader() for module in (test_checkpatch.TestPatch, func_test.TestFunctional): - suite = unittest.TestLoader().loadTestsFromTestCase(module) - suite.run(result) + if args.testname: + try: + suite.addTests(loader.loadTestsFromName(args.testname, module)) + except AttributeError: + continue + else: + suite.addTests(loader.loadTestsFromTestCase(module)) + suite.run(result)
for module in ['gitutil', 'settings', 'terminal']: suite = doctest.DocTestSuite(module) suite.run(result)
- sys.exit(test_util.ReportResult('patman', None, result)) + sys.exit(test_util.ReportResult('patman', args.testname, result))
# Process commits, produce patches files, check them, email them elif args.cmd == 'send': diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index d6f6ae92513..1cb4d6ed0dd 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -419,7 +419,7 @@ class PatchStream: # Remove Tested-by self, since few will take much notice if (rtag_type == 'Tested-by' and who.find(os.getenv('USER') + '@') != -1): - self._add_warn("Ignoring %s" % line) + self._add_warn("Ignoring '%s'" % line) elif rtag_type == 'Patch-cc': self.commit.AddCc(who.split(',')) else:
On balance it is easier to use an iterator here, particularly if we need to insert lines due to new functionality. The only niggle is the need to keep the previous iterator value around in one case.
Convert this test to use iter().
tools/patman/func_test.py | 55 +++++++++++++++++++-------------------- 1 file changed, 27 insertions(+), 28 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 02d46ae5f73..b39e3f671dc 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -212,40 +212,39 @@ class TestFunctional(unittest.TestCase): cc_lines = open(cc_file, encoding='utf-8').read().splitlines() os.remove(cc_file)
- lines = out[0].getvalue().splitlines() - self.assertEqual('Cleaned %s patches' % len(series.commits), lines[0]) - self.assertEqual('Change log missing for v2', lines[1]) - self.assertEqual('Change log missing for v3', lines[2]) - self.assertEqual('Change log for unknown version v4', lines[3]) - self.assertEqual("Alias 'pci' not found", lines[4]) - self.assertIn('Dry run', lines[5]) - self.assertIn('Send a total of %d patches' % count, lines[7]) - line = 8 - for i in range(len(series.commits)): - self.assertEqual(' %s' % args[i], lines[line + 0]) - line += 1 - while 'Cc:' in lines[line]: - line += 1 - self.assertEqual('To: u-boot@lists.denx.de', lines[line]) - self.assertEqual('Cc: %s' % tools.FromUnicode(stefan), - lines[line + 1]) - self.assertEqual('Version: 3', lines[line + 2]) - self.assertEqual('Prefix:\t RFC', lines[line + 3]) - self.assertEqual('Cover: 4 lines', lines[line + 4]) - line += 5 - self.assertEqual(' Cc: %s' % self.fred, lines[line + 0]) + lines = iter(out[0].getvalue().splitlines()) + self.assertEqual('Cleaned %s patches' % len(series.commits), + next(lines)) + self.assertEqual('Change log missing for v2', next(lines)) + self.assertEqual('Change log missing for v3', next(lines)) + self.assertEqual('Change log for unknown version v4', next(lines)) + self.assertEqual("Alias 'pci' not found", next(lines)) + self.assertIn('Dry run', next(lines)) + self.assertEqual('', next(lines)) + self.assertIn('Send a total of %d patches' % count, next(lines)) + prev = next(lines) + for i, commit in enumerate(series.commits): + self.assertEqual(' %s' % args[i], prev) + while True: + prev = next(lines) + if 'Cc:' not in prev: + break + self.assertEqual('To: u-boot@lists.denx.de', prev) + self.assertEqual('Cc: %s' % tools.FromUnicode(stefan), next(lines)) + self.assertEqual('Version: 3', next(lines)) + self.assertEqual('Prefix:\t RFC', next(lines)) + self.assertEqual('Cover: 4 lines', next(lines)) + self.assertEqual(' Cc: %s' % self.fred, next(lines)) self.assertEqual(' Cc: %s' % tools.FromUnicode(self.leb), - lines[line + 1]) - self.assertEqual(' Cc: %s' % tools.FromUnicode(mel), - lines[line + 2]) - self.assertEqual(' Cc: %s' % rick, lines[line + 3]) + next(lines)) + self.assertEqual(' Cc: %s' % tools.FromUnicode(mel), next(lines)) + self.assertEqual(' Cc: %s' % rick, next(lines)) expected = ('Git command: git send-email --annotate ' '--in-reply-to="%s" --to "u-boot@lists.denx.de" ' '--cc "%s" --cc-cmd "%s --cc-cmd %s" %s %s' % (in_reply_to, stefan, sys.argv[0], cc_file, cover_fname, ' '.join(args))) - line += 4 - self.assertEqual(expected, tools.ToUnicode(lines[line])) + self.assertEqual(expected, tools.ToUnicode(next(lines)))
Tidy up the extra 's' when there is only a single warning. Fix the empty print statement also.
tools/patman/patchstream.py | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 1cb4d6ed0dd..cf6a6c6fc3e 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -665,12 +665,13 @@ def fix_patches(series, fnames): cmt.count = count result = fix_patch(backup_dir, fname, series, cmt) if result: - print('%d warnings for %s:' % (len(result), fname)) + print('%d warning%s for %s:' % + (len(result), 's' if len(result) > 1 else '', fname)) for warn in result: - print('\t', warn) - print + print('\t%s' % warn) + print() count += 1 - print('Cleaned %d patches' % count) + print('Cleaned %d patche%s' % (count, 's' if count > 1 else ''))
These lines can indicate a continuation of an error and should not be ignored. Fix this.
Fixes: 666eb15e923 ("patman: Handle checkpatch output with notes and code")
tools/patman/checkpatch.py | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tools/patman/checkpatch.py b/tools/patman/checkpatch.py index 263bac3fc90..98d962cd50d 100644 --- a/tools/patman/checkpatch.py +++ b/tools/patman/checkpatch.py @@ -95,6 +95,7 @@ def CheckPatch(fname, verbose=False, show_types=False): re_check = re.compile('CHECK:%s (.*)' % type_name) re_file = re.compile('#\d+: FILE: ([^:]*):(\d+):') re_note = re.compile('NOTE: (.*)') + re_new_file = re.compile('new file mode .*') indent = ' ' * 6 for line in result.stdout.splitlines(): if verbose: @@ -111,8 +112,10 @@ def CheckPatch(fname, verbose=False, show_types=False): # Skip lines which quote code if line.startswith(indent): continue - # Skip code quotes and #<n> - if line.startswith('+') or line.startswith('#'): + # Skip code quotes + if line.startswith('+'): + continue + if re_new_file.match(line): continue match = re_stats_full.match(line) if not match:
Use the subject of the Commit object when printing it out.
tools/patman/commit.py | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/patman/commit.py b/tools/patman/commit.py index e49bf87dfc8..5bf2b940299 100644 --- a/tools/patman/commit.py +++ b/tools/patman/commit.py @@ -41,6 +41,9 @@ class Commit: self.rtags = collections.defaultdict(set) self.warn = []
+ def __str__(self): + return self.subject + def AddChange(self, version, info): """Add a new change line to the change list for a version.
Sometimes warnings are associated with a file and sometimes with the patch as a whole. Update the regular expression to handle both cases, even in emacs mode. Also add support for detecting new files.
tools/patman/checkpatch.py | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/tools/patman/checkpatch.py b/tools/patman/checkpatch.py index 98d962cd50d..63a8e37e8c5 100644 --- a/tools/patman/checkpatch.py +++ b/tools/patman/checkpatch.py @@ -93,7 +93,7 @@ def CheckPatch(fname, verbose=False, show_types=False): re_error = re.compile('ERROR:%s (.*)' % type_name) re_warning = re.compile(emacs_prefix + 'WARNING:%s (.*)' % type_name) re_check = re.compile('CHECK:%s (.*)' % type_name) - re_file = re.compile('#\d+: FILE: ([^:]*):(\d+):') + re_file = re.compile('#(\d+): (FILE: ([^:]*):(\d+):)?') re_note = re.compile('NOTE: (.*)') re_new_file = re.compile('new file mode .*') indent = ' ' * 6 @@ -153,8 +153,13 @@ def CheckPatch(fname, verbose=False, show_types=False): item['msg'] = check_match.group(2) item['type'] = 'check' elif file_match: - item['file'] = file_match.group(1) - item['line'] = int(file_match.group(2)) + err_fname = file_match.group(3) + if err_fname: + item['file'] = err_fname + item['line'] = int(file_match.group(4)) + else: + item['file'] = '<patch>' + item['line'] = int(file_match.group(1)) elif subject_match: item['file'] = '<patch subject>' item['line'] = None
At present if we fail to find the upstream then the error output is piped to wc, resulting in bogus results. Avoid the pipe and check the output directly.
tools/patman/func_test.py | 19 +++++++++++++++++++ tools/patman/gitutil.py | 10 +++++++--- 2 files changed, 26 insertions(+), 3 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index b39e3f671dc..cce3905c093 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -588,3 +588,22 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual( ["Found possible blank line(s) at end of file 'lib/fdtdec.c'"], pstrm.commit.warn) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testNoUpstream(self): + """Test CountCommitsToBranch when there is no upstream""" + repo = self.make_git_tree() + target = repo.lookup_reference('refs/heads/base') + self.repo.checkout(target, strategy=pygit2.GIT_CHECKOUT_FORCE) + + # Check that it can detect the current branch + try: + orig_dir = os.getcwd() + os.chdir(self.gitdir) + with self.assertRaises(ValueError) as exc: + gitutil.CountCommitsToBranch(None) + self.assertIn( + "Failed to determine upstream: fatal: no upstream configured for branch 'base'", + str(exc.exception)) + finally: + os.chdir(orig_dir) diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index 27a0a9fbc1f..3a2366bcf59 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -66,9 +66,13 @@ def CountCommitsToBranch(branch): rev_range = '%s..%s' % (us, branch) else: rev_range = '@{upstream}..' - pipe = [LogCmd(rev_range, oneline=True), ['wc', '-l']] - stdout = command.RunPipe(pipe, capture=True, oneline=True).stdout - patch_count = int(stdout) + pipe = [LogCmd(rev_range, oneline=True)] + result = command.RunPipe(pipe, capture=True, capture_stderr=True, + oneline=True, raise_on_error=False) + if result.return_code: + raise ValueError('Failed to determine upstream: %s' % + result.stderr.strip()) + patch_count = len(result.stdout.splitlines()) return patch_count
def NameRevision(commit_hash):
Before sending out a new version of a series for review, it is important to add any review tags (e.g. Reviewed-by, Acked-by) collected by patchwork. Otherwise people waste time reviewing the same patch repeatedly, become frustrated and stop reviewing your patches.
To help with this, add a new 'status' subcommand that checks patchwork for review tags, showing those which are not present in the local branch.
This allows users to see what new review tags have been received and then add them.
Sample output: $ patman status 1 Subject 1 Reviewed-by: Joe Bloggs joe@napierwallies.co.nz 2 Subject 2 Tested-by: Lord Edmund Blackaddër weasel@blackadder.org Reviewed-by: Fred Bloggs f.bloggs@napier.net + Reviewed-by: Mary Bloggs mary@napierwallies.co.nz 1 new response available in patchwork
The '+' indicates a new tag. Colours are used to make it easier to read.
Changes in v3: - Rename GetMetaData() function to snake case - Fix incorrect commenting on a line in prepare_patches()
Changes in v2: - Adjust the algorithm to handle patch/commit mismatch - Correct Python style problems - Use REST API instead of web pages
tools/patman/README | 34 ++++ tools/patman/control.py | 46 +++++ tools/patman/func_test.py | 315 +++++++++++++++++++++++++++++++++ tools/patman/main.py | 18 ++ tools/patman/status.py | 356 ++++++++++++++++++++++++++++++++++++++ tools/patman/terminal.py | 21 ++- 6 files changed, 784 insertions(+), 6 deletions(-) create mode 100644 tools/patman/status.py
diff --git a/tools/patman/README b/tools/patman/README index 6664027ed7d..46b8e251ca5 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -11,6 +11,8 @@ This tool is a Python script which: - Runs the patches through checkpatch.pl and its own checks - Optionally emails them out to selected people
+It also shows review tags from Patchwork so you can update your local patches. + It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, since it uses the checkpatch.pl script. @@ -352,6 +354,38 @@ These people will get the cover letter even if they are not on the To/Cc list for any of the patches.
+Patchwork Integration +===================== + +Patman has a very basic integration with Patchwork. If you point patman to +your series on patchwork it can show you what new reviews have appears since +you sent your series. + +To set this up, add a Series-link tag to one of the commits in your series +(see above). + +Then you can type + + patman status + +and patman will show you each patch and what review tags have been collected, +for example: + +... + 21 x86: mtrr: Update the command to use the new mtrr + Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com + + Reviewed-by: Bin Meng bmeng.cn@gmail.com + 22 x86: mtrr: Restructure so command execution is in + Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com + + Reviewed-by: Bin Meng bmeng.cn@gmail.com +... + +This shows that patch 21 and 22 were sent out with one review but have since +attracted another review each. If the series needs changes, you can update +these commits with the new review tag before sending the next version of the +series. + + Example Work Flow =================
diff --git a/tools/patman/control.py b/tools/patman/control.py index 6555a4018a4..7a5469add1b 100644 --- a/tools/patman/control.py +++ b/tools/patman/control.py @@ -175,3 +175,49 @@ def send(args): its_a_go, args.ignore_bad_tags, args.add_maintainers, args.limit, args.dry_run, args.in_reply_to, args.thread, args.smtp_server) + +def patchwork_status(branch, count, start, end): + """Check the status of patches in patchwork + + This finds the series in patchwork using the Series-link tag, checks for new + comments / review tags and displays them + + Args: + branch (str): Branch to create patches from (None = current) + count (int): Number of patches to produce, or -1 to produce patches for + the current branch back to the upstream commit + start (int): Start partch to use (0=first / top of branch) + end (int): End patch to use (0=last one in series, 1=one before that, + etc.) + + Raises: + ValueError: if the branch has no Series-link value + """ + if count == -1: + # Work out how many patches to send if we can + count = (gitutil.CountCommitsToBranch(branch) - start) + + series = patchstream.get_metadata(branch, start, count - end) + warnings = 0 + for cmt in series.commits: + if cmt.warn: + print('%d warnings for %s:' % (len(cmt.warn), cmt.hash)) + for warn in cmt.warn: + print('\t', warn) + warnings += 1 + print + if warnings: + raise ValueError('Please fix warnings before running status') + links = series.get('links') + if not links: + raise ValueError("Branch has no Series-links value") + + # Find the link without a version number (we don't support versions yet) + found = [link for link in links.split() if not ':' in link] + if not found: + raise ValueError('Series-links has no current version (without :)') + + # Import this here to avoid failing on other commands if the dependencies + # are not present + from patman import status + status.check_patchwork_status(series, found[0]) diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index cce3905c093..722844e15d3 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -13,10 +13,13 @@ import sys import tempfile import unittest
+ +from patman.commit import Commit from patman import control from patman import gitutil from patman import patchstream from patman.patchstream import PatchStream +from patman.series import Series from patman import settings from patman import terminal from patman import tools @@ -25,6 +28,7 @@ from patman.test_util import capture_sys_output try: import pygit2 HAVE_PYGIT2 = True + from patman import status except ModuleNotFoundError: HAVE_PYGIT2 = False
@@ -36,6 +40,8 @@ class TestFunctional(unittest.TestCase): fred = 'Fred Bloggs f.bloggs@napier.net' joe = 'Joe Bloggs joe@napierwallies.co.nz' mary = 'Mary Bloggs mary@napierwallies.co.nz' + commits = None + patches = None
def setUp(self): self.tmpdir = tempfile.mkdtemp(prefix='patman.') @@ -44,6 +50,7 @@ class TestFunctional(unittest.TestCase):
def tearDown(self): shutil.rmtree(self.tmpdir) + terminal.SetPrintTestMode(False)
@staticmethod def _get_path(fname): @@ -607,3 +614,311 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c str(exc.exception)) finally: os.chdir(orig_dir) + + @staticmethod + def _fake_patchwork(subpath): + """Fake Patchwork server for the function below + + This handles accessing a series, providing a list consisting of a + single patch + """ + re_series = re.match(r'series/(\d*)/$', subpath) + if re_series: + series_num = re_series.group(1) + if series_num == '1234': + return {'patches': [ + {'id': '1', 'name': 'Some patch'}]} + raise ValueError('Fake Patchwork does not understand: %s' % subpath) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testStatusMismatch(self): + """Test Patchwork patches not matching the series""" + series = Series() + + with capture_sys_output() as (_, err): + status.collect_patches(series, 1234, self._fake_patchwork) + self.assertIn('Warning: Patchwork reports 1 patches, series has 0', + err.getvalue()) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testStatusReadPatch(self): + """Test handling a single patch in Patchwork""" + series = Series() + series.commits = [Commit('abcd')] + + patches = status.collect_patches(series, 1234, self._fake_patchwork) + self.assertEqual(1, len(patches)) + patch = patches[0] + self.assertEqual('1', patch.id) + self.assertEqual('Some patch', patch.raw_subject) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testParseSubject(self): + """Test parsing of the patch subject""" + patch = status.Patch('1') + + # Simple patch not in a series + patch.parse_subject('Testing') + self.assertEqual('Testing', patch.raw_subject) + self.assertEqual('Testing', patch.subject) + self.assertEqual(1, patch.seq) + self.assertEqual(1, patch.count) + self.assertEqual(None, patch.prefix) + self.assertEqual(None, patch.version) + + # First patch in a series + patch.parse_subject('[1/2] Testing') + self.assertEqual('[1/2] Testing', patch.raw_subject) + self.assertEqual('Testing', patch.subject) + self.assertEqual(1, patch.seq) + self.assertEqual(2, patch.count) + self.assertEqual(None, patch.prefix) + self.assertEqual(None, patch.version) + + # Second patch in a series + patch.parse_subject('[2/2] Testing') + self.assertEqual('Testing', patch.subject) + self.assertEqual(2, patch.seq) + self.assertEqual(2, patch.count) + self.assertEqual(None, patch.prefix) + self.assertEqual(None, patch.version) + + # RFC patch + patch.parse_subject('[RFC,3/7] Testing') + self.assertEqual('Testing', patch.subject) + self.assertEqual(3, patch.seq) + self.assertEqual(7, patch.count) + self.assertEqual('RFC', patch.prefix) + self.assertEqual(None, patch.version) + + # Version patch + patch.parse_subject('[v2,3/7] Testing') + self.assertEqual('Testing', patch.subject) + self.assertEqual(3, patch.seq) + self.assertEqual(7, patch.count) + self.assertEqual(None, patch.prefix) + self.assertEqual('v2', patch.version) + + # All fields + patch.parse_subject('[RESEND,v2,3/7] Testing') + self.assertEqual('Testing', patch.subject) + self.assertEqual(3, patch.seq) + self.assertEqual(7, patch.count) + self.assertEqual('RESEND', patch.prefix) + self.assertEqual('v2', patch.version) + + # RFC only + patch.parse_subject('[RESEND] Testing') + self.assertEqual('Testing', patch.subject) + self.assertEqual(1, patch.seq) + self.assertEqual(1, patch.count) + self.assertEqual('RESEND', patch.prefix) + self.assertEqual(None, patch.version) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testCompareSeries(self): + """Test operation of compare_with_series()""" + commit1 = Commit('abcd') + commit1.subject = 'Subject 1' + commit2 = Commit('ef12') + commit2.subject = 'Subject 2' + commit3 = Commit('3456') + commit3.subject = 'Subject 2' + + patch1 = status.Patch('1') + patch1.subject = 'Subject 1' + patch2 = status.Patch('2') + patch2.subject = 'Subject 2' + patch3 = status.Patch('3') + patch3.subject = 'Subject 2' + + series = Series() + series.commits = [commit1] + patches = [patch1] + patch_for_commit, commit_for_patch, warnings = ( + status.compare_with_series(series, patches)) + self.assertEqual(1, len(patch_for_commit)) + self.assertEqual(patch1, patch_for_commit[0]) + self.assertEqual(1, len(commit_for_patch)) + self.assertEqual(commit1, commit_for_patch[0]) + + series.commits = [commit1] + patches = [patch1, patch2] + patch_for_commit, commit_for_patch, warnings = ( + status.compare_with_series(series, patches)) + self.assertEqual(1, len(patch_for_commit)) + self.assertEqual(patch1, patch_for_commit[0]) + self.assertEqual(1, len(commit_for_patch)) + self.assertEqual(commit1, commit_for_patch[0]) + self.assertEqual(["Cannot find commit for patch 2 ('Subject 2')"], + warnings) + + series.commits = [commit1, commit2] + patches = [patch1] + patch_for_commit, commit_for_patch, warnings = ( + status.compare_with_series(series, patches)) + self.assertEqual(1, len(patch_for_commit)) + self.assertEqual(patch1, patch_for_commit[0]) + self.assertEqual(1, len(commit_for_patch)) + self.assertEqual(commit1, commit_for_patch[0]) + self.assertEqual(["Cannot find patch for commit 2 ('Subject 2')"], + warnings) + + series.commits = [commit1, commit2, commit3] + patches = [patch1, patch2] + patch_for_commit, commit_for_patch, warnings = ( + status.compare_with_series(series, patches)) + self.assertEqual(2, len(patch_for_commit)) + self.assertEqual(patch1, patch_for_commit[0]) + self.assertEqual(patch2, patch_for_commit[1]) + self.assertEqual(1, len(commit_for_patch)) + self.assertEqual(commit1, commit_for_patch[0]) + self.assertEqual(["Cannot find patch for commit 3 ('Subject 2')", + "Multiple commits match patch 2 ('Subject 2'):\n" + ' Subject 2\n Subject 2'], + warnings) + + series.commits = [commit1, commit2] + patches = [patch1, patch2, patch3] + patch_for_commit, commit_for_patch, warnings = ( + status.compare_with_series(series, patches)) + self.assertEqual(1, len(patch_for_commit)) + self.assertEqual(patch1, patch_for_commit[0]) + self.assertEqual(2, len(commit_for_patch)) + self.assertEqual(commit1, commit_for_patch[0]) + self.assertEqual(["Multiple patches match commit 2 ('Subject 2'):\n" + ' Subject 2\n Subject 2', + "Cannot find commit for patch 3 ('Subject 2')"], + warnings) + + def _fake_patchwork2(self, subpath): + """Fake Patchwork server for the function below + + This handles accessing series, patches and comments, providing the data + in self.patches to the caller + """ + re_series = re.match(r'series/(\d*)/$', subpath) + re_patch = re.match(r'patches/(\d*)/$', subpath) + re_comments = re.match(r'patches/(\d*)/comments/$', subpath) + if re_series: + series_num = re_series.group(1) + if series_num == '1234': + return {'patches': self.patches} + elif re_patch: + patch_num = int(re_patch.group(1)) + patch = self.patches[patch_num - 1] + return patch + elif re_comments: + patch_num = int(re_comments.group(1)) + patch = self.patches[patch_num - 1] + return patch.comments + raise ValueError('Fake Patchwork does not understand: %s' % subpath) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testFindNewResponses(self): + """Test operation of find_new_responses()""" + commit1 = Commit('abcd') + commit1.subject = 'Subject 1' + commit2 = Commit('ef12') + commit2.subject = 'Subject 2' + + patch1 = status.Patch('1') + patch1.parse_subject('[1/2] Subject 1') + patch1.name = patch1.raw_subject + patch1.content = 'This is my patch content' + comment1a = {'content': 'Reviewed-by: %s\n' % self.joe} + + patch1.comments = [comment1a] + + patch2 = status.Patch('2') + patch2.parse_subject('[2/2] Subject 2') + patch2.name = patch2.raw_subject + patch2.content = 'Some other patch content' + comment2a = { + 'content': 'Reviewed-by: %s\nTested-by: %s\n' % + (self.mary, self.leb)} + comment2b = {'content': 'Reviewed-by: %s' % self.fred} + patch2.comments = [comment2a, comment2b] + + # This test works by setting up commits and patch for use by the fake + # Rest API function _fake_patchwork2(). It calls various functions in + # the status module after setting up tags in the commits, checking that + # things behaves as expected + self.commits = [commit1, commit2] + self.patches = [patch1, patch2] + count = 2 + new_rtag_list = [None] * count + + # Check that the tags are picked up on the first patch + status.find_new_responses(new_rtag_list, 0, commit1, patch1, + self._fake_patchwork2) + self.assertEqual(new_rtag_list[0], {'Reviewed-by': {self.joe}}) + + # Now the second patch + status.find_new_responses(new_rtag_list, 1, commit2, patch2, + self._fake_patchwork2) + self.assertEqual(new_rtag_list[1], { + 'Reviewed-by': {self.mary, self.fred}, + 'Tested-by': {self.leb}}) + + # Now add some tags to the commit, which means they should not appear as + # 'new' tags when scanning comments + new_rtag_list = [None] * count + commit1.rtags = {'Reviewed-by': {self.joe}} + status.find_new_responses(new_rtag_list, 0, commit1, patch1, + self._fake_patchwork2) + self.assertEqual(new_rtag_list[0], {}) + + # For the second commit, add Ed and Fred, so only Mary should be left + commit2.rtags = { + 'Tested-by': {self.leb}, + 'Reviewed-by': {self.fred}} + status.find_new_responses(new_rtag_list, 1, commit2, patch2, + self._fake_patchwork2) + self.assertEqual(new_rtag_list[1], {'Reviewed-by': {self.mary}}) + + # Check that the output patches expectations: + # 1 Subject 1 + # Reviewed-by: Joe Bloggs joe@napierwallies.co.nz + # 2 Subject 2 + # Tested-by: Lord Edmund Blackaddër weasel@blackadder.org + # Reviewed-by: Fred Bloggs f.bloggs@napier.net + # + Reviewed-by: Mary Bloggs mary@napierwallies.co.nz + # 1 new response available in patchwork + + series = Series() + series.commits = [commit1, commit2] + terminal.SetPrintTestMode() + status.check_patchwork_status(series, '1234', self._fake_patchwork2) + lines = iter(terminal.GetPrintTestLines()) + col = terminal.Color() + self.assertEqual(terminal.PrintLine(' 1 Subject 1', col.BLUE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' Reviewed-by: ', col.GREEN, newline=False, + bright=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.joe, col.WHITE, bright=False), + next(lines)) + + self.assertEqual(terminal.PrintLine(' 2 Subject 2', col.BLUE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' Tested-by: ', col.GREEN, newline=False, + bright=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.leb, col.WHITE, bright=False), + next(lines)) + self.assertEqual( + terminal.PrintLine(' Reviewed-by: ', col.GREEN, newline=False, + bright=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.fred, col.WHITE, bright=False), + next(lines)) + self.assertEqual( + terminal.PrintLine(' + Reviewed-by: ', col.GREEN, newline=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.mary, col.WHITE), + next(lines)) + self.assertEqual(terminal.PrintLine( + '1 new response available in patchwork', None), next(lines)) diff --git a/tools/patman/main.py b/tools/patman/main.py index d1a43c44fcd..7f4ae1125a1 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -90,6 +90,10 @@ test_parser.add_argument('testname', type=str, default=None, nargs='?', help="Specify the test to run") AddCommonArgs(test_parser)
+status = subparsers.add_parser('status', + help='Check status of patches in patchwork') +AddCommonArgs(status) + # Parse options twice: first to get the project and second to handle # defaults properly (which depends on project). argv = sys.argv[1:] @@ -157,3 +161,17 @@ elif args.cmd == 'send':
else: control.send(args) + +# Check status of patches in patchwork +elif args.cmd == 'status': + ret_code = 0 + try: + control.patchwork_status(args.branch, args.count, args.start, args.end) + except Exception as e: + terminal.Print('patman: %s: %s' % (type(e).__name__, e), + colour=terminal.Color.RED) + if args.debug: + print() + traceback.print_exc() + ret_code = 1 + sys.exit(ret_code) diff --git a/tools/patman/status.py b/tools/patman/status.py new file mode 100644 index 00000000000..f41b2d4c776 --- /dev/null +++ b/tools/patman/status.py @@ -0,0 +1,356 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2020 Google LLC +# +"""Talks to the patchwork service to figure out what patches have been reviewed +and commented on. +""" + +import collections +import concurrent.futures +from itertools import repeat +import re +import requests + +from patman.patchstream import PatchStream +from patman import terminal +from patman import tout + +# Patches which are part of a multi-patch series are shown with a prefix like +# [prefix, version, sequence], for example '[RFC, v2, 3/5]'. All but the last +# part is optional. This decodes the string into groups. For single patches +# the [] part is not present: +# Groups: (ignore, ignore, ignore, prefix, version, sequence, subject) +RE_PATCH = re.compile(r'([(((.*),)?(.*),)?(.*)]\s)?(.*)$') + +# This decodes the sequence string into a patch number and patch count +RE_SEQ = re.compile(r'(\d+)/(\d+)') + +def to_int(vals): + """Convert a list of strings into integers, using 0 if not an integer + + Args: + vals (list): List of strings + + Returns: + list: List of integers, one for each input string + """ + out = [int(val) if val.isdigit() else 0 for val in vals] + return out + + +class Patch(dict): + """Models a patch in patchwork + + This class records information obtained from patchwork + + Some of this information comes from the 'Patch' column: + + [RFC,v2,1/3] dm: Driver and uclass changes for tiny-dm + + This shows the prefix, version, seq, count and subject. + + The other properties come from other columns in the display. + + Properties: + pid (str): ID of the patch (typically an integer) + seq (int): Sequence number within series (1=first) parsed from sequence + string + count (int): Number of patches in series, parsed from sequence string + raw_subject (str): Entire subject line, e.g. + "[1/2,v2] efi_loader: Sort header file ordering" + prefix (str): Prefix string or None (e.g. 'RFC') + version (str): Version string or None (e.g. 'v2') + raw_subject (str): Raw patch subject + subject (str): Patch subject with [..] part removed (same as commit + subject) + """ + def __init__(self, pid): + super().__init__() + self.id = pid # Use 'id' to match what the Rest API provides + self.seq = None + self.count = None + self.prefix = None + self.version = None + self.raw_subject = None + self.subject = None + + # These make us more like a dictionary + def __setattr__(self, name, value): + self[name] = value + + def __getattr__(self, name): + return self[name] + + def __hash__(self): + return hash(frozenset(self.items())) + + def __str__(self): + return self.raw_subject + + def parse_subject(self, raw_subject): + """Parse the subject of a patch into its component parts + + See RE_PATCH for details. The parsed info is placed into seq, count, + prefix, version, subject + + Args: + raw_subject (str): Subject string to parse + + Raises: + ValueError: the subject cannot be parsed + """ + self.raw_subject = raw_subject.strip() + mat = RE_PATCH.search(raw_subject.strip()) + if not mat: + raise ValueError("Cannot parse subject '%s'" % raw_subject) + self.prefix, self.version, seq_info, self.subject = mat.groups()[3:] + mat_seq = RE_SEQ.match(seq_info) if seq_info else False + if mat_seq is None: + self.version = seq_info + seq_info = None + if self.version and not self.version.startswith('v'): + self.prefix = self.version + self.version = None + if seq_info: + if mat_seq: + self.seq = int(mat_seq.group(1)) + self.count = int(mat_seq.group(2)) + else: + self.seq = 1 + self.count = 1 + +def compare_with_series(series, patches): + """Compare a list of patches with a series it came from + + This prints any problems as warnings + + Args: + series (Series): Series to compare against + patches (:type: list of Patch): list of Patch objects to compare with + + Returns: + tuple + dict: + key: Commit number (0...n-1) + value: Patch object for that commit + dict: + key: Patch number (0...n-1) + value: Commit object for that patch + """ + # Check the names match + warnings = [] + patch_for_commit = {} + all_patches = set(patches) + for seq, cmt in enumerate(series.commits): + pmatch = [p for p in all_patches if p.subject == cmt.subject] + if len(pmatch) == 1: + patch_for_commit[seq] = pmatch[0] + all_patches.remove(pmatch[0]) + elif len(pmatch) > 1: + warnings.append("Multiple patches match commit %d ('%s'):\n %s" % + (seq + 1, cmt.subject, + '\n '.join([p.subject for p in pmatch]))) + else: + warnings.append("Cannot find patch for commit %d ('%s')" % + (seq + 1, cmt.subject)) + + + # Check the names match + commit_for_patch = {} + all_commits = set(series.commits) + for seq, patch in enumerate(patches): + cmatch = [c for c in all_commits if c.subject == patch.subject] + if len(cmatch) == 1: + commit_for_patch[seq] = cmatch[0] + all_commits.remove(cmatch[0]) + elif len(cmatch) > 1: + warnings.append("Multiple commits match patch %d ('%s'):\n %s" % + (seq + 1, patch.subject, + '\n '.join([c.subject for c in cmatch]))) + else: + warnings.append("Cannot find commit for patch %d ('%s')" % + (seq + 1, patch.subject)) + + return patch_for_commit, commit_for_patch, warnings + +def call_rest_api(subpath): + """Call the patchwork API and return the result as JSON + + Args: + subpath (str): URL subpath to use + + Returns: + dict: Json result + + Raises: + ValueError: the URL could not be read + """ + url = 'https://patchwork.ozlabs.org/api/1.2/%s' % subpath + response = requests.get(url) + if response.status_code != 200: + raise ValueError("Could not read URL '%s'" % url) + return response.json() + +def collect_patches(series, series_id, rest_api=call_rest_api): + """Collect patch information about a series from patchwork + + Uses the Patchwork REST API to collect information provided by patchwork + about the status of each patch. + + Args: + series (Series): Series object corresponding to the local branch + containing the series + series_id (str): Patch series ID number + rest_api (function): API function to call to access Patchwork, for + testing + + Returns: + list: List of patches sorted by sequence number, each a Patch object + + Raises: + ValueError: if the URL could not be read or the web page does not follow + the expected structure + """ + data = rest_api('series/%s/' % series_id) + + # Get all the rows, which are patches + patch_dict = data['patches'] + count = len(patch_dict) + num_commits = len(series.commits) + if count != num_commits: + tout.Warning('Warning: Patchwork reports %d patches, series has %d' % + (count, num_commits)) + + patches = [] + + # Work through each row (patch) one at a time, collecting the information + warn_count = 0 + for pw_patch in patch_dict: + patch = Patch(pw_patch['id']) + patch.parse_subject(pw_patch['name']) + patches.append(patch) + if warn_count > 1: + tout.Warning(' (total of %d warnings)' % warn_count) + + # Sort patches by patch number + patches = sorted(patches, key=lambda x: x.seq) + return patches + +def find_new_responses(new_rtag_list, seq, cmt, patch, rest_api=call_rest_api): + """Find new rtags collected by patchwork that we don't know about + + This is designed to be run in parallel, once for each commit/patch + + Args: + new_rtag_list (list): New rtags are written to new_rtag_list[seq] + list, each a dict: + key: Response tag (e.g. 'Reviewed-by') + value: Set of people who gave that response, each a name/email + string + seq (int): Position in new_rtag_list to update + cmt (Commit): Commit object for this commit + patch (Patch): Corresponding Patch object for this patch + rest_api (function): API function to call to access Patchwork, for + testing + """ + if not patch: + return + + # Get the content for the patch email itself as well as all comments + data = rest_api('patches/%s/' % patch.id) + pstrm = PatchStream.process_text(data['content'], True) + + rtags = collections.defaultdict(set) + for response, people in pstrm.commit.rtags.items(): + rtags[response].update(people) + + data = rest_api('patches/%s/comments/' % patch.id) + + for comment in data: + pstrm = PatchStream.process_text(comment['content'], True) + for response, people in pstrm.commit.rtags.items(): + rtags[response].update(people) + + # Find the tags that are not in the commit + new_rtags = collections.defaultdict(set) + base_rtags = cmt.rtags + for tag, people in rtags.items(): + for who in people: + is_new = (tag not in base_rtags or + who not in base_rtags[tag]) + if is_new: + new_rtags[tag].add(who) + new_rtag_list[seq] = new_rtags + +def show_responses(rtags, indent, is_new): + """Show rtags collected + + Args: + rtags (dict): review tags to show + key: Response tag (e.g. 'Reviewed-by') + value: Set of people who gave that response, each a name/email string + indent (str): Indentation string to write before each line + is_new (bool): True if this output should be highlighted + + Returns: + int: Number of review tags displayed + """ + col = terminal.Color() + count = 0 + for tag, people in rtags.items(): + for who in people: + terminal.Print(indent + '%s %s: ' % ('+' if is_new else ' ', tag), + newline=False, colour=col.GREEN, bright=is_new) + terminal.Print(who, colour=col.WHITE, bright=is_new) + count += 1 + return count + +def check_patchwork_status(series, series_id, rest_api=call_rest_api): + """Check the status of a series on Patchwork + + This finds review tags and comments for a series in Patchwork, displaying + them to show what is new compared to the local series. + + Args: + series (Series): Series object for the existing branch + series_id (str): Patch series ID number + rest_api (function): API function to call to access Patchwork, for + testing + """ + patches = collect_patches(series, series_id, rest_api) + col = terminal.Color() + count = len(series.commits) + new_rtag_list = [None] * count + + patch_for_commit, _, warnings = compare_with_series(series, patches) + for warn in warnings: + tout.Warning(warn) + + patch_list = [patch_for_commit.get(c) for c in range(len(series.commits))] + + with concurrent.futures.ThreadPoolExecutor(max_workers=16) as executor: + futures = executor.map( + find_new_responses, repeat(new_rtag_list), range(count), + series.commits, patch_list, repeat(rest_api)) + for fresponse in futures: + if fresponse: + raise fresponse.exception() + + num_to_add = 0 + for seq, cmt in enumerate(series.commits): + patch = patch_for_commit.get(seq) + if not patch: + continue + terminal.Print('%3d %s' % (patch.seq, patch.subject[:50]), + colour=col.BLUE) + cmt = series.commits[seq] + base_rtags = cmt.rtags + new_rtags = new_rtag_list[seq] + + indent = ' ' * 2 + show_responses(base_rtags, indent, False) + num_to_add += show_responses(new_rtags, indent, True) + + terminal.Print("%d new response%s available in patchwork" % + (num_to_add, 's' if num_to_add != 1 else '')) diff --git a/tools/patman/terminal.py b/tools/patman/terminal.py index 60dbce3ce1f..9be03b3a6fd 100644 --- a/tools/patman/terminal.py +++ b/tools/patman/terminal.py @@ -34,14 +34,22 @@ class PrintLine: newline: True to output a newline after the text colour: Text colour to use """ - def __init__(self, text, newline, colour): + def __init__(self, text, colour, newline=True, bright=True): self.text = text self.newline = newline self.colour = colour + self.bright = bright + + def __eq__(self, other): + return (self.text == other.text and + self.newline == other.newline and + self.colour == other.colour and + self.bright == other.bright)
def __str__(self): - return 'newline=%s, colour=%s, text=%s' % (self.newline, self.colour, - self.text) + return ("newline=%s, colour=%s, bright=%d, text='%s'" % + (self.newline, self.colour, self.bright, self.text)) +
def CalcAsciiLen(text): """Calculate the length of a string, ignoring any ANSI sequences @@ -136,7 +144,7 @@ def Print(text='', newline=True, colour=None, limit_to_line=False, bright=True): global last_print_len
if print_test_mode: - print_test_list.append(PrintLine(text, newline, colour)) + print_test_list.append(PrintLine(text, colour, newline, bright)) else: if colour: col = Color() @@ -159,11 +167,12 @@ def PrintClear(): print('\r%s\r' % (' '* last_print_len), end='', flush=True) last_print_len = None
-def SetPrintTestMode(): +def SetPrintTestMode(enable=True): """Go into test mode, where all printing is recorded""" global print_test_mode
- print_test_mode = True + print_test_mode = enable + GetPrintTestLines()
def GetPrintTestLines(): """Get a list of all lines output through Print()
It is tedious to add review tags into the local branch and errors can sometimes be made. Add an option to create a new branch with the review tags obtained from patchwork.
Changes in v3: - Allow tags to be inserted in the middle of the commit message
tools/patman/README | 19 +++++- tools/patman/control.py | 9 ++- tools/patman/func_test.py | 127 +++++++++++++++++++++++++++++++++++- tools/patman/main.py | 7 +- tools/patman/patchstream.py | 52 ++++++++++++++- tools/patman/status.py | 91 ++++++++++++++++++++++++-- 6 files changed, 289 insertions(+), 16 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 46b8e251ca5..15da6dc33cb 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -11,11 +11,13 @@ This tool is a Python script which: - Runs the patches through checkpatch.pl and its own checks - Optionally emails them out to selected people
-It also shows review tags from Patchwork so you can update your local patches. +It also has some Patchwork features: +- shows review tags from Patchwork so you can update your local patches +- pulls these down into a new branch on request
It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, -since it uses the checkpatch.pl script. +since they use the checkpatch.pl script.
It is configured almost entirely by tags it finds in your commits. This means that you can work on a number of different branches at @@ -385,6 +387,19 @@ attracted another review each. If the series needs changes, you can update these commits with the new review tag before sending the next version of the series.
+To automatically pull into these tags into a new branch, use the -d option: + + patman status -d mtrr4 + +This will create a new 'mtrr4' branch which is the same as your current branch +but has the new review tags in it. The tags are added in alphabetic order and +are placed immediately after any existing ack/review/test/fixes tags, or at the +end. You can check that this worked with: + + patman -b mtrr4 status + +which should show that there are no new responses compared to this new branch. +
Example Work Flow ================= diff --git a/tools/patman/control.py b/tools/patman/control.py index 7a5469add1b..6ac258d41d7 100644 --- a/tools/patman/control.py +++ b/tools/patman/control.py @@ -176,11 +176,11 @@ def send(args): args.limit, args.dry_run, args.in_reply_to, args.thread, args.smtp_server)
-def patchwork_status(branch, count, start, end): +def patchwork_status(branch, count, start, end, dest_branch, force): """Check the status of patches in patchwork
This finds the series in patchwork using the Series-link tag, checks for new - comments / review tags and displays them + review tags, displays then and creates a new branch with the review tags.
Args: branch (str): Branch to create patches from (None = current) @@ -189,6 +189,9 @@ def patchwork_status(branch, count, start, end): start (int): Start partch to use (0=first / top of branch) end (int): End patch to use (0=last one in series, 1=one before that, etc.) + dest_branch (str): Name of new branch to create with the updated tags + (None to not create a branch) + force (bool): With dest_branch, force overwriting an existing branch
Raises: ValueError: if the branch has no Series-link value @@ -220,4 +223,4 @@ def patchwork_status(branch, count, start, end): # Import this here to avoid failing on other commands if the dependencies # are not present from patman import status - status.check_patchwork_status(series, found[0]) + status.check_patchwork_status(series, found[0], branch, dest_branch, force) diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 722844e15d3..2e1529525eb 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -403,7 +403,16 @@ with some I2C-related things in it''') self.make_commit_with_file('spi: SPI fixes', ''' SPI needs some fixes and here they are -''', 'spi.c', '''Some fixes for SPI in this + +Signed-off-by: %s + +Series-to: u-boot +Commit-notes: +title of the series +This is the cover letter for the series +with various details +END +''' % self.leb, 'spi.c', '''Some fixes for SPI in this file to make SPI work better than before''') first_target = repo.revparse_single('HEAD') @@ -889,7 +898,8 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c series = Series() series.commits = [commit1, commit2] terminal.SetPrintTestMode() - status.check_patchwork_status(series, '1234', self._fake_patchwork2) + status.check_patchwork_status(series, '1234', None, None, False, + self._fake_patchwork2) lines = iter(terminal.GetPrintTestLines()) col = terminal.Color() self.assertEqual(terminal.PrintLine(' 1 Subject 1', col.BLUE), @@ -921,4 +931,115 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual(terminal.PrintLine(self.mary, col.WHITE), next(lines)) self.assertEqual(terminal.PrintLine( - '1 new response available in patchwork', None), next(lines)) + '1 new response available in patchwork (use -d to write them to a new branch)', + None), next(lines)) + + def _fake_patchwork3(self, subpath): + """Fake Patchwork server for the function below + + This handles accessing series, patches and comments, providing the data + in self.patches to the caller + """ + re_series = re.match(r'series/(\d*)/$', subpath) + re_patch = re.match(r'patches/(\d*)/$', subpath) + re_comments = re.match(r'patches/(\d*)/comments/$', subpath) + if re_series: + series_num = re_series.group(1) + if series_num == '1234': + return {'patches': self.patches} + elif re_patch: + patch_num = int(re_patch.group(1)) + patch = self.patches[patch_num - 1] + return patch + elif re_comments: + patch_num = int(re_comments.group(1)) + patch = self.patches[patch_num - 1] + return patch.comments + raise ValueError('Fake Patchwork does not understand: %s' % subpath) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testCreateBranch(self): + """Test operation of create_branch()""" + repo = self.make_git_tree() + branch = 'first' + dest_branch = 'first2' + count = 2 + gitdir = os.path.join(self.gitdir, '.git') + + # Set up the test git tree. We use branch 'first' which has two commits + # in it + series = patchstream.get_metadata_for_list(branch, gitdir, count) + self.assertEqual(2, len(series.commits)) + + patch1 = status.Patch('1') + patch1.parse_subject('[1/2] %s' % series.commits[0].subject) + patch1.name = patch1.raw_subject + patch1.content = 'This is my patch content' + comment1a = {'content': 'Reviewed-by: %s\n' % self.joe} + + patch1.comments = [comment1a] + + patch2 = status.Patch('2') + patch2.parse_subject('[2/2] %s' % series.commits[1].subject) + patch2.name = patch2.raw_subject + patch2.content = 'Some other patch content' + comment2a = { + 'content': 'Reviewed-by: %s\nTested-by: %s\n' % + (self.mary, self.leb)} + comment2b = { + 'content': 'Reviewed-by: %s' % self.fred} + patch2.comments = [comment2a, comment2b] + + # This test works by setting up patches for use by the fake Rest API + # function _fake_patchwork3(). The fake patch comments above should + # result in new review tags that are collected and added to the commits + # created in the destination branch. + self.patches = [patch1, patch2] + count = 2 + + # Expected output: + # 1 i2c: I2C things + # + Reviewed-by: Joe Bloggs joe@napierwallies.co.nz + # 2 spi: SPI fixes + # + Reviewed-by: Fred Bloggs f.bloggs@napier.net + # + Reviewed-by: Mary Bloggs mary@napierwallies.co.nz + # + Tested-by: Lord Edmund Blackaddër weasel@blackadder.org + # 4 new responses available in patchwork + # 4 responses added from patchwork into new branch 'first2' + # <unittest.result.TestResult run=8 errors=0 failures=0> + + terminal.SetPrintTestMode() + status.check_patchwork_status(series, '1234', branch, dest_branch, + False, self._fake_patchwork3, repo) + lines = terminal.GetPrintTestLines() + self.assertEqual(12, len(lines)) + self.assertEqual( + "4 responses added from patchwork into new branch 'first2'", + lines[11].text) + + # Check that the destination branch has the new tags + new_series = patchstream.get_metadata_for_list(dest_branch, gitdir, + count) + self.assertEqual( + {'Reviewed-by': {self.joe}}, + new_series.commits[0].rtags) + self.assertEqual( + {'Tested-by': {self.leb}, + 'Reviewed-by': {self.fred, self.mary}}, + new_series.commits[1].rtags) + + # Now check the actual test of the first commit message. We expect to + # see the new tags immediately below the old ones. + stdout = patchstream.get_list(dest_branch, count=count, git_dir=gitdir) + lines = iter([line.strip() for line in stdout.splitlines() + if '-by:' in line]) + + # First patch should have the review tag + self.assertEqual('Reviewed-by: %s' % self.joe, next(lines)) + + # Second patch should have the sign-off then the tested-by and two + # reviewed-by tags + self.assertEqual('Signed-off-by: %s' % self.leb, next(lines)) + self.assertEqual('Reviewed-by: %s' % self.fred, next(lines)) + self.assertEqual('Reviewed-by: %s' % self.mary, next(lines)) + self.assertEqual('Tested-by: %s' % self.leb, next(lines)) diff --git a/tools/patman/main.py b/tools/patman/main.py index 7f4ae1125a1..8f139a6e3ba 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -92,6 +92,10 @@ AddCommonArgs(test_parser)
status = subparsers.add_parser('status', help='Check status of patches in patchwork') +status.add_argument('-d', '--dest-branch', type=str, + help='Name of branch to create with collected responses') +status.add_argument('-f', '--force', action='store_true', + help='Force overwriting an existing branch') AddCommonArgs(status)
# Parse options twice: first to get the project and second to handle @@ -166,7 +170,8 @@ elif args.cmd == 'send': elif args.cmd == 'status': ret_code = 0 try: - control.patchwork_status(args.branch, args.count, args.start, args.end) + control.patchwork_status(args.branch, args.count, args.start, args.end, + args.dest_branch, args.force) except Exception as e: terminal.Print('patman: %s: %s' % (type(e).__name__, e), colour=terminal.Color.RED) diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index cf6a6c6fc3e..7b0805e9e14 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -551,6 +551,54 @@ class PatchStream: self.blank_count = 0 self.finalise()
+def insert_tags(msg, tags_to_emit): + """Add extra tags to a commit message + + The tags are added after an existing block of tags if found, otherwise at + the end. + + Args: + msg (str): Commit message + tags_to_emit (list): List of tags to emit, each a str + + Returns: + (str) new message + """ + out = [] + done = False + emit_tags = False + for line in msg.splitlines(): + if not done: + signoff_match = RE_SIGNOFF.match(line) + tag_match = RE_TAG.match(line) + if tag_match or signoff_match: + emit_tags = True + if emit_tags and not tag_match and not signoff_match: + out += tags_to_emit + emit_tags = False + done = True + out.append(line) + if not done: + out.append('') + out += tags_to_emit + return '\n'.join(out) + +def get_list(commit_range, git_dir=None, count=None): + """Get a log of a list of comments + + This returns the output of 'git log' for the selected commits + + Args: + commit_range (str): Range of commits to count (e.g. 'HEAD..base') + git_dir (str): Path to git repositiory (None to use default) + count (int): Number of commits to list, or None for no limit + + Returns + str: String containing the contents of the git log + """ + params = gitutil.LogCmd(commit_range, reverse=True, count=count, + git_dir=git_dir) + return command.RunPipe([params], capture=True).stdout
def get_metadata_for_list(commit_range, git_dir=None, count=None, series=None, allow_overwrite=False): @@ -573,9 +621,7 @@ def get_metadata_for_list(commit_range, git_dir=None, count=None, if not series: series = Series() series.allow_overwrite = allow_overwrite - params = gitutil.LogCmd(commit_range, reverse=True, count=count, - git_dir=git_dir) - stdout = command.RunPipe([params], capture=True).stdout + stdout = get_list(commit_range, git_dir, count) pst = PatchStream(series, is_log=True) for line in stdout.splitlines(): pst.process_line(line) diff --git a/tools/patman/status.py b/tools/patman/status.py index f41b2d4c776..f3a654160ec 100644 --- a/tools/patman/status.py +++ b/tools/patman/status.py @@ -3,15 +3,19 @@ # Copyright 2020 Google LLC # """Talks to the patchwork service to figure out what patches have been reviewed -and commented on. +and commented on. Allows creation of a new branch based on the old but with the +review tags collected from patchwork. """
import collections import concurrent.futures from itertools import repeat import re + +import pygit2 import requests
+from patman import patchstream from patman.patchstream import PatchStream from patman import terminal from patman import tout @@ -306,7 +310,73 @@ def show_responses(rtags, indent, is_new): count += 1 return count
-def check_patchwork_status(series, series_id, rest_api=call_rest_api): +def create_branch(series, new_rtag_list, branch, dest_branch, overwrite, + repo=None): + """Create a new branch with review tags added + + Args: + series (Series): Series object for the existing branch + new_rtag_list (list): List of review tags to add, one for each commit, + each a dict: + key: Response tag (e.g. 'Reviewed-by') + value: Set of people who gave that response, each a name/email + string + branch (str): Existing branch to update + dest_branch (str): Name of new branch to create + overwrite (bool): True to force overwriting dest_branch if it exists + repo (pygit2.Repository): Repo to use (use None unless testing) + + Returns: + int: Total number of review tags added across all commits + + Raises: + ValueError: if the destination branch name is the same as the original + branch, or it already exists and @overwrite is False + """ + if branch == dest_branch: + raise ValueError( + 'Destination branch must not be the same as the original branch') + if not repo: + repo = pygit2.Repository('.') + count = len(series.commits) + new_br = repo.branches.get(dest_branch) + if new_br: + if not overwrite: + raise ValueError("Branch '%s' already exists (-f to overwrite)" % + dest_branch) + new_br.delete() + if not branch: + branch = 'HEAD' + target = repo.revparse_single('%s~%d' % (branch, count)) + repo.branches.local.create(dest_branch, target) + + num_added = 0 + for seq in range(count): + parent = repo.branches.get(dest_branch) + cherry = repo.revparse_single('%s~%d' % (branch, count - seq - 1)) + + repo.merge_base(cherry.oid, parent.target) + base_tree = cherry.parents[0].tree + + index = repo.merge_trees(base_tree, parent, cherry) + tree_id = index.write_tree(repo) + + lines = [] + if new_rtag_list[seq]: + for tag, people in new_rtag_list[seq].items(): + for who in people: + lines.append('%s: %s' % (tag, who)) + num_added += 1 + message = patchstream.insert_tags(cherry.message.rstrip(), + sorted(lines)) + + repo.create_commit( + parent.name, cherry.author, cherry.committer, message, tree_id, + [parent.target]) + return num_added + +def check_patchwork_status(series, series_id, branch, dest_branch, force, + rest_api=call_rest_api, test_repo=None): """Check the status of a series on Patchwork
This finds review tags and comments for a series in Patchwork, displaying @@ -315,8 +385,12 @@ def check_patchwork_status(series, series_id, rest_api=call_rest_api): Args: series (Series): Series object for the existing branch series_id (str): Patch series ID number + branch (str): Existing branch to update, or None + dest_branch (str): Name of new branch to create, or None + force (bool): True to force overwriting dest_branch if it exists rest_api (function): API function to call to access Patchwork, for testing + test_repo (pygit2.Repository): Repo to use (use None unless testing) """ patches = collect_patches(series, series_id, rest_api) col = terminal.Color() @@ -352,5 +426,14 @@ def check_patchwork_status(series, series_id, rest_api=call_rest_api): show_responses(base_rtags, indent, False) num_to_add += show_responses(new_rtags, indent, True)
- terminal.Print("%d new response%s available in patchwork" % - (num_to_add, 's' if num_to_add != 1 else '')) + terminal.Print("%d new response%s available in patchwork%s" % + (num_to_add, 's' if num_to_add != 1 else '', + '' if dest_branch + else ' (use -d to write them to a new branch)')) + + if dest_branch: + num_added = create_branch(series, new_rtag_list, branch, + dest_branch, force, test_repo) + terminal.Print( + "%d response%s added from patchwork into new branch '%s'" % + (num_added, 's' if num_added != 1 else '', dest_branch))
Signed-off-by: Simon Glass sjg@chromium.org ---
Applied to u-boot-dm, thanks!
Add support for parsing the contents of a patchwork 'patch' web page containing comments received from reviewers. This allows patman to show these comments in a simple 'snippets' format.
A snippet is some quoted code plus some unquoted comments below it. Each review is from a unique person/email and can produce multiple snippets, one for each part of the code that attracts a comment.
Show the file and line-number info at the top of each snippet if available.
(no changes since v1)
tools/patman/func_test.py | 83 ++++++++++++++++++++++++++++++++++++ tools/patman/patchstream.py | 85 +++++++++++++++++++++++++++++++++++++ 2 files changed, 168 insertions(+)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 2e1529525eb..bbee4b77d66 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -1043,3 +1043,86 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual('Reviewed-by: %s' % self.fred, next(lines)) self.assertEqual('Reviewed-by: %s' % self.mary, next(lines)) self.assertEqual('Tested-by: %s' % self.leb, next(lines)) + + def testParseSnippets(self): + """Test parsing of review snippets""" + text = '''Hi Fred, + +This is a comment from someone. + +Something else + +On some recent date, Fred wrote: +> This is why I wrote the patch +> so here it is + +Now a comment about the commit message +A little more to say + +Even more + +> diff --git a/file.c b/file.c +> Some more code +> Code line 2 +> Code line 3 +> Code line 4 +> Code line 5 +> Code line 6 +> Code line 7 +> Code line 8 +> Code line 9 + +And another comment + +> @@ -153,8 +143,13 @@ def CheckPatch(fname, show_types=False): +> further down on the file +> and more code +> +Addition here +> +Another addition here +> codey +> more codey + +and another thing in same file + +> @@ -253,8 +243,13 @@ +> with no function context + +one more thing + +> diff --git a/tools/patman/main.py b/tools/patman/main.py +> +line of code +now a very long comment in a different file +line2 +line3 +line4 +line5 +line6 +line7 +line8 +''' + pstrm = PatchStream.process_text(text, True) + self.assertEqual([], pstrm.commit.warn) + + # We expect to the filename and up to 5 lines of code context before + # each comment. The 'On xxx wrote:' bit should be removed. + self.assertEqual( + [['Hi Fred,', + 'This is a comment from someone.', + 'Something else'], + ['> This is why I wrote the patch', + '> so here it is', + 'Now a comment about the commit message', + 'A little more to say', 'Even more'], + ['> File: file.c', '> Code line 5', '> Code line 6', + '> Code line 7', '> Code line 8', '> Code line 9', + 'And another comment'], + ['> File: file.c', + '> Line: 153 / 143: def CheckPatch(fname, show_types=False):', + '> and more code', '> +Addition here', '> +Another addition here', + '> codey', '> more codey', 'and another thing in same file'], + ['> File: file.c', '> Line: 253 / 243', + '> with no function context', 'one more thing'], + ['> File: tools/patman/main.py', '> +line of code', + 'now a very long comment in a different file', + 'line2', 'line3', 'line4', 'line5', 'line6', 'line7', 'line8']], + pstrm.snippets) diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 7b0805e9e14..9dc3b29216d 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -4,11 +4,13 @@
"""Handles parsing a stream of commits/emails from 'git log' or other source"""
+import collections import datetime import io import math import os import re +import queue import shutil import tempfile
@@ -51,6 +53,12 @@ RE_SPACE_BEFORE_TAB = re.compile('^[+].* \t') # Match indented lines for changes RE_LEADING_WHITESPACE = re.compile(r'^\s')
+# Detect a 'diff' line +RE_DIFF = re.compile(r'^>.*diff --git a/(.*) b/(.*)$') + +# Detect a context line, like '> @@ -153,8 +153,13 @@ CheckPatch +RE_LINE = re.compile(r'>.*@@ -(\d+),\d+ +(\d+),\d+ @@ *(.*)') + # States we can be in - can we use range() and still have comments? STATE_MSG_HEADER = 0 # Still in the message header STATE_PATCH_SUBJECT = 1 # In patch subject (first line of log for a commit) @@ -81,6 +89,14 @@ class PatchStream: self.blank_count = 0 # Number of blank lines stored up self.state = STATE_MSG_HEADER # What state are we in? self.commit = None # Current commit + self.snippets = [] # List of unquoted test blocks + self.cur_diff = None # Last 'diff' line seen (str) + self.cur_line = None # Last context (@@) line seen (str) + self.recent_diff= None # 'diff' line for current snippet (str) + self.recent_line= None # '@@' line for current snippet (str) + self.recent_quoted = collections.deque([], 5) + self.recent_unquoted = queue.Queue() + self.was_quoted = None
@staticmethod def process_text(text, is_comment=False): @@ -176,6 +192,10 @@ class PatchStream: self.skip_blank = True self.section = []
+ self.cur_diff = None + self.recent_diff = None + self.recent_line = None + def _parse_version(self, value, line): """Parse a version from a *-changes tag
@@ -209,6 +229,47 @@ class PatchStream: self.commit.AddChange(self.change_version, change) self.change_lines = []
+ def _finalise_snippet(self): + """Finish off a snippet and add it to the list + + This is called when we get to the end of a snippet, i.e. the we enter + the next block of quoted text: + + This is a comment from someone. + + Something else + + > Now we have some code <----- end of snippet + > more code + + Now a comment about the above code + + This adds the snippet to our list + """ + quoted_lines = [] + while self.recent_quoted: + quoted_lines.append(self.recent_quoted.popleft()) + unquoted_lines = [] + valid = False + while not self.recent_unquoted.empty(): + text = self.recent_unquoted.get() + if not (text.startswith('On ') and text.endswith('wrote:')): + unquoted_lines.append(text) + if text: + valid = True + if valid: + lines = [] + if self.recent_diff: + lines.append('> File: %s' % self.recent_diff) + if self.recent_line: + out = '> Line: %s / %s' % self.recent_line[:2] + if self.recent_line[2]: + out += ': %s' % self.recent_line[2] + lines.append(out) + lines += quoted_lines + unquoted_lines + if lines: + self.snippets.append(lines) + def process_line(self, line): """Process a single line of a patch file or commit log
@@ -254,6 +315,8 @@ class PatchStream: cover_match = RE_COVER.match(line) signoff_match = RE_SIGNOFF.match(line) leading_whitespace_match = RE_LEADING_WHITESPACE.match(line) + diff_match = RE_DIFF.match(line) + line_match = RE_LINE.match(line) tag_match = None if self.state == STATE_PATCH_HEADER: tag_match = RE_TAG.match(line) @@ -443,6 +506,27 @@ class PatchStream: out = [line] self.linenum += 1 self.skip_blank = False + + if diff_match: + self.cur_diff = diff_match.group(1) + + # If this is quoted, keep recent lines + if not diff_match and self.linenum > 1 and line: + if line.startswith('>'): + if not self.was_quoted: + self._finalise_snippet() + self.recent_line = None + if not line_match: + self.recent_quoted.append(line) + self.was_quoted = True + self.recent_diff = self.cur_diff + else: + self.recent_unquoted.put(line) + self.was_quoted = False + + if line_match: + self.recent_line = line_match.groups() + if self.state == STATE_DIFFS: pass
@@ -466,6 +550,7 @@ class PatchStream:
def finalise(self): """Close out processing of this patch stream""" + self._finalise_snippet() self._finalise_change() self._close_commit() if self.lines_after_test:
While reviewing feedback it is helpful to see the review comments on the command line to check that each has been addressed. Add an option to support that.
Update the workflow documentation to describe the new features.
(no changes since v2)
Changes in v2: - Many changes to the whole series, including new patches - Use of REST API instead of the web site
tools/patman/README | 36 +++++-- tools/patman/control.py | 11 ++- tools/patman/func_test.py | 186 +++++++++++++++++++++++++++++++++--- tools/patman/main.py | 5 +- tools/patman/patchstream.py | 7 +- tools/patman/status.py | 59 ++++++++++-- 6 files changed, 268 insertions(+), 36 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 15da6dc33cb..49b73590cf0 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -14,6 +14,7 @@ This tool is a Python script which: It also has some Patchwork features: - shows review tags from Patchwork so you can update your local patches - pulls these down into a new branch on request +- lists comments received on a series
It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, @@ -400,6 +401,8 @@ end. You can check that this worked with:
+There is also a -C option to list the comments received for each patch. +
Example Work Flow ================= @@ -484,17 +487,33 @@ people on the list don't see your secret info. Of course patches often attract comments and you need to make some updates. Let's say one person sent comments and you get an Acked-by: on one patch. Also, the patch on the list that you were waiting for has been merged, -so you can drop your wip commit. So you resync with upstream: +so you can drop your wip commit. + +Take a look on patchwork and find out the URL of the series. This will be +something like http://patchwork.ozlabs.org/project/uboot/list/?series=187331 +Add this to a tag in your top commit: + + Series-link: http://patchwork.ozlabs.org/project/uboot/list/?series=187331 + +You can use then patman to collect the Acked-by tag to the correct commit, +creating a new 'version 2' branch for us-cmd: + + patman status -d us-cmd2 + git checkout us-cmd2 + +You can look at the comments in Patchwork or with: + + patman status -C + +Then you can resync with upstream:
git fetch origin (or whatever upstream is called) git rebase origin/master
-and use git rebase -i to edit the commits, dropping the wip one. You add -the ack tag to one commit: - - Acked-by: Heiko Schocher hs@denx.de +and use git rebase -i to edit the commits, dropping the wip one.
-update the Series-cc: in the top commit: +Then update the Series-cc: in the top commit to add the person who reviewed +the v1 series:
Series-cc: bfin, marex, Heiko Schocher hs@denx.de
@@ -533,7 +552,9 @@ so to send them:
and it will create and send the version 2 series.
-General points: + +General points +==============
1. When you change back to the us-cmd branch days or weeks later all your information is still there, safely stored in the commits. You don't need @@ -613,3 +634,4 @@ a bad thing. Simon Glass sjg@chromium.org v1, v2, 19-Oct-11 revised v3 24-Nov-11 +revised v4 Independence Day 2020, with Patchwork integration diff --git a/tools/patman/control.py b/tools/patman/control.py index 6ac258d41d7..f4a6ca145d4 100644 --- a/tools/patman/control.py +++ b/tools/patman/control.py @@ -176,11 +176,13 @@ def send(args): args.limit, args.dry_run, args.in_reply_to, args.thread, args.smtp_server)
-def patchwork_status(branch, count, start, end, dest_branch, force): +def patchwork_status(branch, count, start, end, dest_branch, force, + show_comments): """Check the status of patches in patchwork
This finds the series in patchwork using the Series-link tag, checks for new - review tags, displays then and creates a new branch with the review tags. + comments and review tags, displays then and creates a new branch with the + review tags.
Args: branch (str): Branch to create patches from (None = current) @@ -192,6 +194,8 @@ def patchwork_status(branch, count, start, end, dest_branch, force): dest_branch (str): Name of new branch to create with the updated tags (None to not create a branch) force (bool): With dest_branch, force overwriting an existing branch + show_comments (bool): True to display snippets from the comments + provided by reviewers
Raises: ValueError: if the branch has no Series-link value @@ -223,4 +227,5 @@ def patchwork_status(branch, count, start, end, dest_branch, force): # Import this here to avoid failing on other commands if the dependencies # are not present from patman import status - status.check_patchwork_status(series, found[0], branch, dest_branch, force) + status.check_patchwork_status(series, found[0], branch, dest_branch, force, + show_comments) diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index bbee4b77d66..e2adf32c739 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -857,15 +857,16 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.patches = [patch1, patch2] count = 2 new_rtag_list = [None] * count + review_list = [None, None]
# Check that the tags are picked up on the first patch - status.find_new_responses(new_rtag_list, 0, commit1, patch1, - self._fake_patchwork2) + status.find_new_responses(new_rtag_list, review_list, 0, commit1, + patch1, self._fake_patchwork2) self.assertEqual(new_rtag_list[0], {'Reviewed-by': {self.joe}})
# Now the second patch - status.find_new_responses(new_rtag_list, 1, commit2, patch2, - self._fake_patchwork2) + status.find_new_responses(new_rtag_list, review_list, 1, commit2, + patch2, self._fake_patchwork2) self.assertEqual(new_rtag_list[1], { 'Reviewed-by': {self.mary, self.fred}, 'Tested-by': {self.leb}}) @@ -874,16 +875,16 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c # 'new' tags when scanning comments new_rtag_list = [None] * count commit1.rtags = {'Reviewed-by': {self.joe}} - status.find_new_responses(new_rtag_list, 0, commit1, patch1, - self._fake_patchwork2) + status.find_new_responses(new_rtag_list, review_list, 0, commit1, + patch1, self._fake_patchwork2) self.assertEqual(new_rtag_list[0], {})
# For the second commit, add Ed and Fred, so only Mary should be left commit2.rtags = { 'Tested-by': {self.leb}, 'Reviewed-by': {self.fred}} - status.find_new_responses(new_rtag_list, 1, commit2, patch2, - self._fake_patchwork2) + status.find_new_responses(new_rtag_list, review_list, 1, commit2, + patch2, self._fake_patchwork2) self.assertEqual(new_rtag_list[1], {'Reviewed-by': {self.mary}})
# Check that the output patches expectations: @@ -898,7 +899,7 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c series = Series() series.commits = [commit1, commit2] terminal.SetPrintTestMode() - status.check_patchwork_status(series, '1234', None, None, False, + status.check_patchwork_status(series, '1234', None, None, False, False, self._fake_patchwork2) lines = iter(terminal.GetPrintTestLines()) col = terminal.Color() @@ -914,16 +915,16 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual(terminal.PrintLine(' 2 Subject 2', col.BLUE), next(lines)) self.assertEqual( - terminal.PrintLine(' Tested-by: ', col.GREEN, newline=False, + terminal.PrintLine(' Reviewed-by: ', col.GREEN, newline=False, bright=False), next(lines)) - self.assertEqual(terminal.PrintLine(self.leb, col.WHITE, bright=False), + self.assertEqual(terminal.PrintLine(self.fred, col.WHITE, bright=False), next(lines)) self.assertEqual( - terminal.PrintLine(' Reviewed-by: ', col.GREEN, newline=False, + terminal.PrintLine(' Tested-by: ', col.GREEN, newline=False, bright=False), next(lines)) - self.assertEqual(terminal.PrintLine(self.fred, col.WHITE, bright=False), + self.assertEqual(terminal.PrintLine(self.leb, col.WHITE, bright=False), next(lines)) self.assertEqual( terminal.PrintLine(' + Reviewed-by: ', col.GREEN, newline=False), @@ -1010,7 +1011,7 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c
terminal.SetPrintTestMode() status.check_patchwork_status(series, '1234', branch, dest_branch, - False, self._fake_patchwork3, repo) + False, False, self._fake_patchwork3, repo) lines = terminal.GetPrintTestLines() self.assertEqual(12, len(lines)) self.assertEqual( @@ -1044,6 +1045,7 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual('Reviewed-by: %s' % self.mary, next(lines)) self.assertEqual('Tested-by: %s' % self.leb, next(lines))
+ @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testParseSnippets(self): """Test parsing of review snippets""" text = '''Hi Fred, @@ -1126,3 +1128,159 @@ line8 'now a very long comment in a different file', 'line2', 'line3', 'line4', 'line5', 'line6', 'line7', 'line8']], pstrm.snippets) + + @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') + def testReviewSnippets(self): + """Test showing of review snippets""" + def _to_submitter(who): + m_who = re.match('(.*) <(.*)>', who) + return { + 'name': m_who.group(1), + 'email': m_who.group(2) + } + + commit1 = Commit('abcd') + commit1.subject = 'Subject 1' + commit2 = Commit('ef12') + commit2.subject = 'Subject 2' + + patch1 = status.Patch('1') + patch1.parse_subject('[1/2] Subject 1') + patch1.name = patch1.raw_subject + patch1.content = 'This is my patch content' + comment1a = {'submitter': _to_submitter(self.joe), + 'content': '''Hi Fred, + +On some date Fred wrote: + +> diff --git a/file.c b/file.c +> Some code +> and more code + +Here is my comment above the above... + + +Reviewed-by: %s +''' % self.joe} + + patch1.comments = [comment1a] + + patch2 = status.Patch('2') + patch2.parse_subject('[2/2] Subject 2') + patch2.name = patch2.raw_subject + patch2.content = 'Some other patch content' + comment2a = { + 'content': 'Reviewed-by: %s\nTested-by: %s\n' % + (self.mary, self.leb)} + comment2b = {'submitter': _to_submitter(self.fred), + 'content': '''Hi Fred, + +On some date Fred wrote: + +> diff --git a/tools/patman/commit.py b/tools/patman/commit.py +> @@ -41,6 +41,9 @@ class Commit: +> self.rtags = collections.defaultdict(set) +> self.warn = [] +> +> + def __str__(self): +> + return self.subject +> + +> def AddChange(self, version, info): +> """Add a new change line to the change list for a version. +> +A comment + +Reviewed-by: %s +''' % self.fred} + patch2.comments = [comment2a, comment2b] + + # This test works by setting up commits and patch for use by the fake + # Rest API function _fake_patchwork2(). It calls various functions in + # the status module after setting up tags in the commits, checking that + # things behaves as expected + self.commits = [commit1, commit2] + self.patches = [patch1, patch2] + + # Check that the output patches expectations: + # 1 Subject 1 + # Reviewed-by: Joe Bloggs joe@napierwallies.co.nz + # 2 Subject 2 + # Tested-by: Lord Edmund Blackaddër weasel@blackadder.org + # Reviewed-by: Fred Bloggs f.bloggs@napier.net + # + Reviewed-by: Mary Bloggs mary@napierwallies.co.nz + # 1 new response available in patchwork + + series = Series() + series.commits = [commit1, commit2] + terminal.SetPrintTestMode() + status.check_patchwork_status(series, '1234', None, None, False, True, + self._fake_patchwork2) + lines = iter(terminal.GetPrintTestLines()) + col = terminal.Color() + self.assertEqual(terminal.PrintLine(' 1 Subject 1', col.BLUE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' + Reviewed-by: ', col.GREEN, newline=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.joe, col.WHITE), next(lines)) + + self.assertEqual(terminal.PrintLine('Review: %s' % self.joe, col.RED), + next(lines)) + self.assertEqual(terminal.PrintLine(' Hi Fred,', None), next(lines)) + self.assertEqual(terminal.PrintLine('', None), next(lines)) + self.assertEqual(terminal.PrintLine(' > File: file.c', col.MAGENTA), + next(lines)) + self.assertEqual(terminal.PrintLine(' > Some code', col.MAGENTA), + next(lines)) + self.assertEqual(terminal.PrintLine(' > and more code', col.MAGENTA), + next(lines)) + self.assertEqual(terminal.PrintLine( + ' Here is my comment above the above...', None), next(lines)) + self.assertEqual(terminal.PrintLine('', None), next(lines)) + + self.assertEqual(terminal.PrintLine(' 2 Subject 2', col.BLUE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' + Reviewed-by: ', col.GREEN, newline=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.fred, col.WHITE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' + Reviewed-by: ', col.GREEN, newline=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.mary, col.WHITE), + next(lines)) + self.assertEqual( + terminal.PrintLine(' + Tested-by: ', col.GREEN, newline=False), + next(lines)) + self.assertEqual(terminal.PrintLine(self.leb, col.WHITE), + next(lines)) + + self.assertEqual(terminal.PrintLine('Review: %s' % self.fred, col.RED), + next(lines)) + self.assertEqual(terminal.PrintLine(' Hi Fred,', None), next(lines)) + self.assertEqual(terminal.PrintLine('', None), next(lines)) + self.assertEqual(terminal.PrintLine( + ' > File: tools/patman/commit.py', col.MAGENTA), next(lines)) + self.assertEqual(terminal.PrintLine( + ' > Line: 41 / 41: class Commit:', col.MAGENTA), next(lines)) + self.assertEqual(terminal.PrintLine( + ' > + return self.subject', col.MAGENTA), next(lines)) + self.assertEqual(terminal.PrintLine( + ' > +', col.MAGENTA), next(lines)) + self.assertEqual( + terminal.PrintLine(' > def AddChange(self, version, info):', + col.MAGENTA), + next(lines)) + self.assertEqual(terminal.PrintLine( + ' > """Add a new change line to the change list for a version.', + col.MAGENTA), next(lines)) + self.assertEqual(terminal.PrintLine( + ' >', col.MAGENTA), next(lines)) + self.assertEqual(terminal.PrintLine( + ' A comment', None), next(lines)) + self.assertEqual(terminal.PrintLine('', None), next(lines)) + + self.assertEqual(terminal.PrintLine( + '4 new responses available in patchwork (use -d to write them to a new branch)', + None), next(lines)) diff --git a/tools/patman/main.py b/tools/patman/main.py index 8f139a6e3ba..c7f425522b2 100755 --- a/tools/patman/main.py +++ b/tools/patman/main.py @@ -92,6 +92,8 @@ AddCommonArgs(test_parser)
status = subparsers.add_parser('status', help='Check status of patches in patchwork') +status.add_argument('-C', '--show-comments', action='store_true', + help='Show comments from each patch') status.add_argument('-d', '--dest-branch', type=str, help='Name of branch to create with collected responses') status.add_argument('-f', '--force', action='store_true', @@ -171,7 +173,8 @@ elif args.cmd == 'status': ret_code = 0 try: control.patchwork_status(args.branch, args.count, args.start, args.end, - args.dest_branch, args.force) + args.dest_branch, args.force, + args.show_comments) except Exception as e: terminal.Print('patman: %s: %s' % (type(e).__name__, e), colour=terminal.Color.RED) diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index 9dc3b29216d..d8dcf8c4561 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -89,11 +89,12 @@ class PatchStream: self.blank_count = 0 # Number of blank lines stored up self.state = STATE_MSG_HEADER # What state are we in? self.commit = None # Current commit - self.snippets = [] # List of unquoted test blocks + # List of unquoted test blocks, each a list of str lines + self.snippets = [] self.cur_diff = None # Last 'diff' line seen (str) self.cur_line = None # Last context (@@) line seen (str) - self.recent_diff= None # 'diff' line for current snippet (str) - self.recent_line= None # '@@' line for current snippet (str) + self.recent_diff = None # 'diff' line for current snippet (str) + self.recent_line = None # '@@' line for current snippet (str) self.recent_quoted = collections.deque([], 5) self.recent_unquoted = queue.Queue() self.was_quoted = None diff --git a/tools/patman/status.py b/tools/patman/status.py index f3a654160ec..a369d655c5e 100644 --- a/tools/patman/status.py +++ b/tools/patman/status.py @@ -3,8 +3,9 @@ # Copyright 2020 Google LLC # """Talks to the patchwork service to figure out what patches have been reviewed -and commented on. Allows creation of a new branch based on the old but with the -review tags collected from patchwork. +and commented on. Provides a way to display review tags and comments. +Allows creation of a new branch based on the old but with the review tags +collected from patchwork. """
import collections @@ -124,6 +125,25 @@ class Patch(dict): self.seq = 1 self.count = 1
+ +class Review: + """Represents a single review email collected in Patchwork + + Patches can attract multiple reviews. Each consists of an author/date and + a variable number of 'snippets', which are groups of quoted and unquoted + text. + """ + def __init__(self, meta, snippets): + """Create new Review object + + Args: + meta (str): Text containing review author and date + snippets (list): List of snippets in th review, each a list of text + lines + """ + self.meta = ' : '.join([line for line in meta.splitlines() if line]) + self.snippets = snippets + def compare_with_series(series, patches): """Compare a list of patches with a series it came from
@@ -241,7 +261,8 @@ def collect_patches(series, series_id, rest_api=call_rest_api): patches = sorted(patches, key=lambda x: x.seq) return patches
-def find_new_responses(new_rtag_list, seq, cmt, patch, rest_api=call_rest_api): +def find_new_responses(new_rtag_list, review_list, seq, cmt, patch, + rest_api=call_rest_api): """Find new rtags collected by patchwork that we don't know about
This is designed to be run in parallel, once for each commit/patch @@ -252,6 +273,9 @@ def find_new_responses(new_rtag_list, seq, cmt, patch, rest_api=call_rest_api): key: Response tag (e.g. 'Reviewed-by') value: Set of people who gave that response, each a name/email string + review_list (list): New reviews are written to review_list[seq] + list, each a + List of reviews for the patch, each a Review seq (int): Position in new_rtag_list to update cmt (Commit): Commit object for this commit patch (Patch): Corresponding Patch object for this patch @@ -271,8 +295,13 @@ def find_new_responses(new_rtag_list, seq, cmt, patch, rest_api=call_rest_api):
+ reviews = [] for comment in data: pstrm = PatchStream.process_text(comment['content'], True) + if pstrm.snippets: + submitter = comment['submitter'] + person = '%s <%s>' % (submitter['name'], submitter['email']) + reviews.append(Review(person, pstrm.snippets)) for response, people in pstrm.commit.rtags.items(): rtags[response].update(people)
@@ -286,6 +315,7 @@ def find_new_responses(new_rtag_list, seq, cmt, patch, rest_api=call_rest_api): if is_new: new_rtags[tag].add(who) new_rtag_list[seq] = new_rtags + review_list[seq] = reviews
def show_responses(rtags, indent, is_new): """Show rtags collected @@ -302,8 +332,9 @@ def show_responses(rtags, indent, is_new): """ col = terminal.Color() count = 0 - for tag, people in rtags.items(): - for who in people: + for tag in sorted(rtags.keys()): + people = rtags[tag] + for who in sorted(people): terminal.Print(indent + '%s %s: ' % ('+' if is_new else ' ', tag), newline=False, colour=col.GREEN, bright=is_new) terminal.Print(who, colour=col.WHITE, bright=is_new) @@ -376,7 +407,8 @@ def create_branch(series, new_rtag_list, branch, dest_branch, overwrite, return num_added
def check_patchwork_status(series, series_id, branch, dest_branch, force, - rest_api=call_rest_api, test_repo=None): + show_comments, rest_api=call_rest_api, + test_repo=None): """Check the status of a series on Patchwork
This finds review tags and comments for a series in Patchwork, displaying @@ -388,6 +420,7 @@ def check_patchwork_status(series, series_id, branch, dest_branch, force, branch (str): Existing branch to update, or None dest_branch (str): Name of new branch to create, or None force (bool): True to force overwriting dest_branch if it exists + show_comments (bool): True to show the comments on each patch rest_api (function): API function to call to access Patchwork, for testing test_repo (pygit2.Repository): Repo to use (use None unless testing) @@ -396,6 +429,7 @@ def check_patchwork_status(series, series_id, branch, dest_branch, force, col = terminal.Color() count = len(series.commits) new_rtag_list = [None] * count + review_list = [None] * count
patch_for_commit, _, warnings = compare_with_series(series, patches) for warn in warnings: @@ -405,8 +439,8 @@ def check_patchwork_status(series, series_id, branch, dest_branch, force,
with concurrent.futures.ThreadPoolExecutor(max_workers=16) as executor: futures = executor.map( - find_new_responses, repeat(new_rtag_list), range(count), - series.commits, patch_list, repeat(rest_api)) + find_new_responses, repeat(new_rtag_list), repeat(review_list), + range(count), series.commits, patch_list, repeat(rest_api)) for fresponse in futures: if fresponse: raise fresponse.exception() @@ -425,6 +459,15 @@ def check_patchwork_status(series, series_id, branch, dest_branch, force, indent = ' ' * 2 show_responses(base_rtags, indent, False) num_to_add += show_responses(new_rtags, indent, True) + if show_comments: + for review in review_list[seq]: + terminal.Print('Review: %s' % review.meta, colour=col.RED) + for snippet in review.snippets: + for line in snippet: + quoted = line.startswith('>') + terminal.Print(' %s' % line, + colour=col.MAGENTA if quoted else None) + terminal.Print()
terminal.Print("%d new response%s available in patchwork%s" % (num_to_add, 's' if num_to_add != 1 else '',
