[U-Boot-Users] [PATCH] New board support for the Xilinx ML300 platform
At ftp://customer:xilinx@ftp.xilinx.com/upload/ml300.patch.gz find a patch that adds support for the Xilinx ML300 platform to U-Boot. Some documentation is provided in doc/README.ml300.
The CHANGELOG entry is attached to this email.
Please apply the patch to the repository.
Thanks and with best regards, - Peter
* Patch by Peter Ryser, 20 Feb 2004: Add support for the Xilinx ML300 platform (http://www.xilinx.com/ml300).
In message 4037B5A5.3030407@lucent.com you wrote:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html> <head> <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type"> <title></title> </head> <body bgcolor="#ffffff" text="#000000">
Please do not send HTML messages.
Please send plain text only.
Message unreadable, ignored. Sorry.
Wolfgang et al.,
here is the relevant message in plain text:
The CHANGELOG entry follows further down.
CHANGELOG entry:
Mike,
the patch applies cleanly against the latest CVS kernel tree. After checking out the CVS tree from sourceforge (see http://sourceforge.net/cvs/?group_id=65938 for instructions, use u-boot as modulename) change into the root directory of U-Boot and do: $ gzip -cd ml300.patch.gz | patch -p1 -F0 --dry-run
If that goes well remove --dry-run to really apply the patch.
- Peter
Mike Welliington wrote:
Great! - I've been working on a port of PPCBoot to the ML300, but got yanked off to work on our kernel port, which we are booting without a bootloader for the time being. But I knew I was going to have to come back and finish the port anyway - you just saved me.
I'm new to U-Boot so:
Is this patch intended to be applied to U-Boot 1.0.0 ?
Where can I find out how to apply the patch?
Best Regards,
-mike wellington wellington@lucent.com Denver, Colorado, USA
- Peter
- Patch by Peter Ryser, 20 Feb 2004:
------------------------------------------------------- SF.Net is sponsored by: Speed Start Your Linux Apps Now. Build and deploy apps & Web services for Linux with a free DVD software kit from IBM. Click Now! http://ads.osdn.com/?ad_id=1356&alloc_id=3438&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Peter- Thanks. I had already applied the patch incorrectly and mangled my build tree. But I re-un-hacked it and I am now building u-boot for the ML300. I have downloaded it and it is running right now. If I start having unexplainable problems I'll start fresh with the latest top-of-tree and re-apply the patch according to your instructions.
All I need to do is to figure out how to set the ethernet address (no help needed here) and download my kernel which is already built.
I may be gone for an hour or two - getting hungry, may walk over to CB & Potts for dinner but I'll be back.
Thanks a million!
-mike
Peter Ryser wrote:
Mike,
- Peter
Best Regards,
- Peter
Best Regards,
- Peter
- Is this patch intended to be applied to U-Boot 1.0.0 ?
No, more likely to a recent version like 1.0.2 or top-of-tree.
- Where can I find out how to apply the patch?
Type: "man patch".
In message 40392B34.5060409@lucent.com you wrote:
How do I get the top-of-tree?
"cvs checkout" ? See http://www.cvshome.org/docs/manual/cvs-1.11.13/cvs.html
Never mind. I found the 1.0.2 tar ball. Downloading now...
-mike w..
-mike
You should learn to use CVS nevertheless.
I understand this is the same patch you sent before which got rejected because of the list's attachment size limit?
Can you please verify that the code in CVS is complete and up to date?
Yes, that's correct.
I just did an update as well as a complete checkout and cannot (yet?) see the code. I will try again later.
- Peter
Dear Peter,
Thanks for the confirmation.
Please do. Updates and access to SourceForge's anonymous server is always awfully slow.
Hi Wolfgang,
the code for the Xilinx ML300 checks out, compiles, and works as expected.
Thanks, - Peter
Mike Welliington
Mike Wellington
Peter Ryser
