[PATCH 1/2] rpi: fix dram bank initialization
To update the dram bank information from device-tree we use fdtdec_decode_ram_size() which expectes the the size-cells and address-cells to be defined in the memory node. For normal system RAM these values are defined in the root node. When the values differ from the default values defined in the spec, we can end up with wrong RAM bank information.
Switch to the "standard" way to update the RAM bank information to avoid this.
Fixes: 9de5b89e4c ("rpi4: enable dram bank initialization")
Signed-off-by: Matthias Brugger mbrugger@suse.com ---
board/raspberrypi/rpi/rpi.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 3d4afaf653..76f1c55b65 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -274,8 +274,13 @@ int dram_init(void) #ifdef CONFIG_BCM2711 int dram_init_banksize(void) { - return fdtdec_decode_ram_size(gd->fdt_blob, NULL, 0, NULL, - (phys_size_t *)&gd->ram_size, gd->bd); + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + return fdtdec_setup_mem_size_base(); } #endif #endif
Up to now we only update the DRAM banks when we are define CONFIG_BCM2711. But our one binary approach uses a config that supports BCM2837 and BCM2711. As a result we only see one gigabyte of RAM on Raspberry Pi 4, although it has more RAM. Fix this by calling dram_init_banksize when we are booting a U-Boot build for arm64.
Fixes: 5694090670 ("ARM: defconfig: add unified config for RPi3 and RPi4")
board/raspberrypi/rpi/rpi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 76f1c55b65..35fcef2b56 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -271,7 +271,7 @@ int dram_init(void) }
#ifdef CONFIG_OF_BOARD -#ifdef CONFIG_BCM2711 +#ifdef CONFIG_ARM64 int dram_init_banksize(void) { int ret;
%s/gigabyte/gibibyte/
There are RPi 4 with 1GiB, 2GiB, 4GiB. All have more than 1 GB but only some have more than 1GiB.
I guess this should be changed to "even if it has more RAM" as you can also buy a RPi 4 with 1 GiB of RAM.
The change does not relate to your commit message.
Please, explain why you enable fdtdec_decode_ram_size() on the RPi 3 in 64bit configuration and disables it on the RPi 4 in 32bit configuration.
What happens here if we have a RPi 4 with more than 1 GiB of memory and use a 32bit U-Boot?
Best regards
Heinrich
Right, I'll test with 32 bit, but I think it does no harm. Will delete the ARM64 ifdef.
Just tested that. It will always show you 1 GiB of memory because the rpi_4_32b_defconfig states only one DRAM banks. I'll fix this as well.
Regards, Matthias
Best regards
Heinrich
Matthias Brugger
