[U-Boot] [RFC 1/1] meson-gx: reserved memory regions
The Odroid C2 has two GiB of memory with two reserved regions. reg = <0x0 0x0 0x0 0x1000000>; reg = <0x0 0x10000000 0x0 0x200000>;
The description has been created with the following patches:
Patch bfcef28ae4cf (arm: add initial support for Amlogic Meson and ODROID-C2) defined the available memory in arch/arm/dts/meson-gxbb-odroidc2.dts as reg = <0x0 0x0 0x0 0x80000000> and the number of RAM banks as #define CONFIG_NR_DRAM_BANKS 1.
Patch 4b3ab59d21ef (configs: gxbb: Introduce a common config header file) moved the number of RAM banks to include/configs/meson-gxbb-common.h.
Patch a3b02a1d4926 (arm: dts: update Meson GXBB / Odroid-C2 DT with recent) defined two reserved memory regions in arch/arm/dts/meson-gx.dtsi.
U-Boot does not support the concept of reserved memory regions.
Amongst other mishaps this leads to a wrong memory configuration when calling bootefi which may cause a memory violation.
The easiest way to correct this is to define multiple memory banks.
In the long run fdt support for reserved-memory might be implemented.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/arm/dts/meson-gxbb-odroidc2.dts | 7 ++++++- include/configs/meson-gxbb-common.h | 2 +- 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index c737183a29..35b8300e23 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -61,7 +61,12 @@
memory@0 { device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; + reg =<0x0 0x1000000 0x0 0xf000000>; + }; + + memory@1 { + device_type = "memory"; + reg = <0x0 0x10200000 0x0 0x6fe00000>; };
usb_otg_pwr: regulator-usb-pwrs { diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h index 89e3807a14..ed55f441a4 100644 --- a/include/configs/meson-gxbb-common.h +++ b/include/configs/meson-gxbb-common.h @@ -10,7 +10,7 @@
#define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF -#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 32
Am 09.06.2017 um 17:43 schrieb Heinrich@suse.de:
Please share what symptoms you are seeing. I have been using bootefi with GRUB without problems for many months on Odroid-C2, Vega S95 and recently NanoPi K2. v4.12-rc3 was probably the last kernel I tested.
Have you looked into that at all? It seems a one-time change that would benefit all platforms rather than a single board here. I'd imagine a simple loop over sub-nodes of /reserved-memory that then calls the existing EFI memory reservation function. (In particular I would hope that might fix e.g. 32-bit sunxi.)
- memory@1 {
This is wrong. memory@10200000 if at all.
Please don't randomly modify the .dts in ways incompatible with Linux.
If we need two DRAM banks, then this needs to be implemented in board or mach code.
Regards, Andreas
Patch bfcef28ae4cf (arm: add initial support for Amlogic Meson and ODROID-C2) provided function dram_init_banksize to reserve the first 16 MiB of RAM for firmware in function dram_init_banksize in arch/arm/mach-meson/board.c and defined CONFIG_NR_DRAM_BANKS = 1.
With this patch dram_init_banksize is changed to additionally reserve the 2MiB region for the ARM Trusted Firmware (BL31). CONFIG_NR_DRAM_BANKS is set to 2.
Cc: Andreas Färber afaerber@suse.de Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Do not change the dtb but the board file as suggested by Andreas Färber. --- arch/arm/mach-meson/board.c | 8 +++++--- include/configs/meson-gxbb-common.h | 2 +- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c index 273dbeb020..e89c6aace9 100644 --- a/arch/arm/mach-meson/board.c +++ b/arch/arm/mach-meson/board.c @@ -37,9 +37,11 @@ int dram_init(void) int dram_init_banksize(void) { /* Reserve first 16 MiB of RAM for firmware */ - gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE + (16 * 1024 * 1024); - gd->bd->bi_dram[0].size = gd->ram_size - (16 * 1024 * 1024); - + gd->bd->bi_dram[0].start = 0x1000000; + gd->bd->bi_dram[0].size = 0xf000000; + /* Reserve 2 MiB for ARM Trusted Firmware (BL31) */ + gd->bd->bi_dram[1].start = 0x10000000; + gd->bd->bi_dram[1].size = gd->ram_size - 0x10200000; return 0; }
Hello Tom, hello Albert,
I did not see any objections.
Can this be merged? https://patchwork.ozlabs.org/patch/774142/
Best regards
Heinrich
- gd->bd->bi_dram[0].start = 0x1000000;
- gd->bd->bi_dram[0].size = 0xf000000;
- /* Reserve 2 MiB for ARM Trusted Firmware (BL31) */
- gd->bd->bi_dram[1].start = 0x10000000;
- gd->bd->bi_dram[1].size = gd->ram_size - 0x10200000; return 0;
Andreas Färber
Heinrich@lists.denx.de
