[U-Boot] [PATCH] power: extend prefix match to regulator-name property
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. Signed-off-by: Felix Brack fb@ltec.ch ---
drivers/power/pmic/pmic-uclass.c | 15 +++++++++++++-- 1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/power/pmic/pmic-uclass.c b/drivers/power/pmic/pmic-uclass.c index 64964e4..5a034f0 100644 --- a/drivers/power/pmic/pmic-uclass.c +++ b/drivers/power/pmic/pmic-uclass.c @@ -26,6 +26,7 @@ int pmic_bind_children(struct udevice *pmic, ofnode parent, struct driver *drv; struct udevice *child; const char *node_name; + const char *reg_name; int bind_count = 0; ofnode node; int prefix_len; @@ -44,8 +45,18 @@ int pmic_bind_children(struct udevice *pmic, ofnode parent, debug(" - compatible prefix: '%s'\n", info->prefix);
prefix_len = strlen(info->prefix); - if (strncmp(info->prefix, node_name, prefix_len)) - continue; + if (strncmp(info->prefix, node_name, prefix_len)) { + reg_name = ofnode_read_string(node, + "regulator-name"); + if (reg_name) { + if (strncmp(info->prefix, reg_name, + prefix_len)) { + continue; + } + } else { + continue; + } + }
drv = lists_driver_lookup_name(info->driver); if (!drv) {
Hi Felix,
Can you please add a sandbox test and documentation for this?
See:
test/dm/pmic.c doc/driver-model/pmic-framework.txt
continue;
"regulator-name");
if (reg_name) {
prefix_len)) {
continue;
} else {
continue;
} drv = lists_driver_lookup_name(info->driver); if (!drv) {
-- 2.7.4
Hello Simon,
On 12.10.2017 04:07, Simon Glass wrote:
Hi Felix,
I just forgot to extend the documentation. I will do so of course as soon as the node property for matching has been fixed.
I think the test itself does already exist (test/dm/regulator.c). I will have to add a regulator to arch/sandbox/dts/sandbox_pmic.dtsi. This regulator will have a node name prefix other then 'buck' or 'ldo' for my code to do the matching. Some other files will also need modifications for the test to work correctly.
See:
continue;
"regulator-name");
if (reg_name) {
prefix_len)) {
continue;
} else {
continue;
-- 2.7.4
regards, Felix
No. See the regulator bindings:
Optional properties: - regulator-name: A string used as a descriptive name for regulator outputs
This can vary from board to board. The name should match the power rail name of the board (which may not be the same as the regulator chip's output name).
If you have multiple regulator nodes which need to be differentiated, you need to use the deprecated "regulator-compatible" property, or just use the standard compatible property.
ChenYu
The actual regulator.txt states:
Optional properties: - regulator-name: a string, required by the regulator uclass
This was the reason for choosing the regulator-name property.
Exactly. I totally agree but as stated in an earlier post: I did not define the names for the regulators and modifying them is almost certainly not the right way to go. Let me explain this briefly. The regulator names I'm trying to match are those from tps65910.dtsi, an include file. The exact same file is part of the LINUX kernel. Therefore I resigned suggesting the modification of the node names.
Good point. I would not use a deprecated property but the compatible property seems reasonable to me. So you agree that the patch's concept could be retained while substituting the node-name property by the compatible property?
Felix
Mine was from the Linux Kernel. Are there two sets of bindings? Shouldn't there be just one?
First, it is an include file. Board files are free to override the name. We did that for sunxi at first, have the .dtsi file provide some default names, then have board .dts files override them with names that make more sense. Later on we just dropped the default names altogether.
The same pattern is also seen in tps65910.dtsi and am3517-craneboard.dts. And also am335x-evm.dts, which the tps65910.dtsi was tested with.
Now I couldn't find the binding document for tps65910, but looking at tps65217 instead, it says:
- regulators: list of regulators provided by this controller, must be named after their hardware counterparts: dcdc[1-3] and ldo[1-4]
And indeed that is what's used in the example.
So clearly the dts files aren't following the binding.
If you're going to modify the binding and/or device tree files, please do it in both places. Ideally the platform should have one canonical source for them.
Linux's standard regulator DT matching code only matches against node names and the deprecated "regulator-compatible" property. Not even the standard "compatible" is used, though I see a few PMICs using that. So even if you do get them working this way in U-boot, it's still not going to work in Linux, and you might get other comments when pushing your changes.
Regards ChenYu
Mine was from U-Boot as this is the U-Boot mailing list and things do not seem to be fully synchronized between LINUX and U-Boot.
I am definitely confused now, maybe we are using same terms for different things. When I'm talking about a 'name' I mean the 'node name' according to DT specification (as for instance returned by ofnode_get_name). I'm not talking about a property or a node label. The following code defines a node name 'regulator@2' ore more precisely a node named 'regulator' having unit-address 2:
vdd1_reg: regulator@2 { reg = <2>; regulator-compatible = "vdd1"; };
This is found in tps65910.dtsi include file. You say "board files are free to override the name". Hence I could include the tps65910.dtsi into my board dts file and kind of rename node 'regulator@2' by let's say 'buck_vdd1@2'? The only way of "overriding" I can think of is by not including the dtsi file and redefining all nodes.
Looking at the am3517-craneboard.dts file I don't see how node names are getting overwritten. What gets set, changed or overwritten is the node property regulator-name.
Yes, exactly and correct. Again, this tps65217.txt does only exist in LINUX and not in U-Boot.
And what about the dtsi files? Are they correct in defining node names as 'regulator@[unit-address]'?
I guess if LINUX would not match against the regulator-compatible property but only against the node name things would not work properly. Again looking the file tps65217.dtsi shows that every regulator node (named regulator@0 to regulator@6) defines the regulator-compatible property. Only matching against this property therefore makes things working.
Felix
That seems to be the underlying problem. They really should be the same. I'm not sure which platforms really follow through with this though.
I'm talking about the "name" as defined in the "regulator-name" property, which is what you want to match against in your patch.
So boards are definitely free to override the property by setting a new value for it. And indeed boards do that.
Yes. That's what I'm referring to. Doesn't this work against your attempt to bind pmic-uclass against regulator-name properties?
Device tree bindings are a set of rules, contracts, ABIs, whatever you call it, between the hardware description that is the device tree, and software that implement support for the hardware. Having two or more diverging sets is not an improvement. Communities should work together to have a common set of bindings.
FreeBSD seems to be importing device tree bindings from Linux. There was also talk about importing bindings from other projects that have already created and implemented support for bindings that do not exist in Linux. This has been raised for the Device Tree Workshop this Thursday at OSSE/ELCE:
https://lists.linuxfoundation.org/pipermail/ksummit-discuss/2017-October/004... https://lists.linuxfoundation.org/pipermail/ksummit-discuss/2017-October/004...
I've also raised the issue of diverging device trees and bindings:
They are broken. Someone needs to fix them.
The dtsi file is not following the binding. It should be fixed. But I suppose that is an issue for the platform maintainer, and any concerned users.
Regards ChenYu
Felix
This is the driving idea behind my patch.
Well, yes, my patch works like charm. I didn't mention that it doesn't work ;-).
I totally agree.
If that wish from Andrew would become true it would be the ultimate solution: "I’d like it if there was a common repo for all devicetree consumers to share".
Thanks! I hope this helps moving things into the right direction. And yes, there is quite a lot of truth in calling my patch a "dirty workaround" for broken dts and even worse dtsi files. But for U-Boot this patch could help to bridge the time gap until the real fix. Sadly I now that it could also have the exact opposite effect and lead to even more broken (with respect to binding rules) dts and dtsi files.
Agreed.
I am not a platform maintainer but of course I am a concerned user. If I had been confident that fixing the include file tps65910.dtsi (and all its dependencies) in the U-Boot project would have been sufficient, I would have tried that first before sending in my patch. In my case, following the dt binding rules for this file is the most correct solution to the problem, not just a workaround. But this brings at least U-Boot and LINUX tps65910.dtsi files out of sync and I'm pretty sure that such a patch would be rejected for this reason. So we definitely have a chicken-egg problem here: who takes the lead, U-Boot or LINUX? And what about the others you mentioned FreeBSD or how Andrew said: "device-tree consumers"? I'm ending up in voting (like many others I guess) for a central dts/dtsi/dt-binding-rules repository.
Regards ChenYu
Felix
Felix
On Mon, Oct 9, 2017 at 6:04 PM, Felix Brack fb@ltec.ch wrote: > This patch extends pmic_bind_children prefix matching. In addition to > the node name the property regulator-name is used while trying to match > prefixes. This allows assigning different drivers to regulator nodes > named regulator@1 and regulator@10 for example.
I totally agree.
I'm OK with a temporary fix or workaround. But temporary means someone needs to follow up and get it where it needs to go. It should also be noted in the commit log. And the binding should be marked as a workaround for existing (broken) device trees, so people don't adapt it by mistake.
Agreed.
I guess this is mostly per-platform. For Allwinner SoCs, it seems Linux is the preferred source. U-boot typically falls behind in terms of device tree content and support, and in rare cases such as Ethernet support does end up implementing an earlier version of the binding that was not the final version that ended up in the kernel. The BSDs seem to be happy with taking our Linux bindings and implementing support for them. On the other hand, Allwinner is not a fully supported platform, meaning that with each kernel release, support for new peripherals is added, and additions to the device tree files reflect this as well. We also use separate device tree blobs for U-boot and Linux.
I'm not sure if it's possible to do this to the platform you're working on, as some maintainers do take DT compatibility very seriously. Then again, fixing something that doesn't work (in Linux) in the first place isn't really creating any regressions.
I see a few (Linux) people raising concern about synchronization between the kernel and whatever repository the bindings/DT end up in, but that is already what other projects are dealing with. I definitely hope some agreement is achieved.
ChenYu
On 12.10.2017 04:46, Chen-Yu Tsai wrote: > On Mon, Oct 9, 2017 at 6:04 PM, Felix Brack fb@ltec.ch wrote: >> This patch extends pmic_bind_children prefix matching. In addition to >> the node name the property regulator-name is used while trying to match >> prefixes. This allows assigning different drivers to regulator nodes >> named regulator@1 and regulator@10 for example. > > No. See the regulator bindings: > > Optional properties: > - regulator-name: A string used as a descriptive name for regulator outputs > The actual regulator.txt states:
> This can vary from board to board. The name should match the power rail > name of the board (which may not be the same as the regulator chip's > output name). > Exactly. I totally agree but as stated in an earlier post: I did not define the names for the regulators and modifying them is almost certainly not the right way to go. Let me explain this briefly. The regulator names I'm trying to match are those from tps65910.dtsi, an include file. The exact same file is part of the LINUX kernel. Therefore I resigned suggesting the modification of the node names.
I totally agree.
This has already been addressed in v2 patch I posted a week ago (https://patchwork.ozlabs.org/patch/827507/).
Agreed.
> If you have multiple regulator nodes which need to be differentiated, > you need to use the deprecated "regulator-compatible" property, or just > use the standard compatible property. > Good point. I would not use a deprecated property but the compatible property seems reasonable to me. So you agree that the patch's concept could be retained while substituting the node-name property by the compatible property?
ChenYu
regards, Felix
On Thu, Oct 12, 2017 at 8:24 PM, Felix Brack fb@ltec.ch wrote: > On 12.10.2017 04:46, Chen-Yu Tsai wrote: >> On Mon, Oct 9, 2017 at 6:04 PM, Felix Brack fb@ltec.ch wrote: >>> This patch extends pmic_bind_children prefix matching. In addition to >>> the node name the property regulator-name is used while trying to match >>> prefixes. This allows assigning different drivers to regulator nodes >>> named regulator@1 and regulator@10 for example. >> >> No. See the regulator bindings: >> >> Optional properties: >> - regulator-name: A string used as a descriptive name for regulator outputs >> > The actual regulator.txt states: > > Optional properties: > - regulator-name: a string, required by the regulator uclass > > This was the reason for choosing the regulator-name property.
>> This can vary from board to board. The name should match the power rail >> name of the board (which may not be the same as the regulator chip's >> output name). >> > Exactly. I totally agree but as stated in an earlier post: I did not > define the names for the regulators and modifying them is almost > certainly not the right way to go. Let me explain this briefly. The > regulator names I'm trying to match are those from tps65910.dtsi, an > include file. The exact same file is part of the LINUX kernel. Therefore > I resigned suggesting the modification of the node names.
I totally agree.
I see that now. Thanks
ChenYu
Chen-Yu Tsai
Felix Brack
