[U-Boot] [PATCH] common: block: fix error with CONFIG_FASTBOOT_FLASH_MMC_DEV
This fixes the following compiler error:
common/fb_mmc.c: In function ‘fb_mmc_erase’: common/fb_mmc.c:209:17: error: ‘struct blk_desc’ has no member named ‘block_erase’
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com ---
common/fb_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index e3abcc8..26025dc 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -206,7 +206,7 @@ void fb_mmc_erase(const char *cmd, char *response) printf("Erasing blocks " LBAFU " to " LBAFU " due to alignment\n", blks_start, blks_start + blks_size);
- blks = dev_desc->block_erase(dev_desc, blks_start, blks_size); + blks = blk_derase(dev_desc, blks_start, blks_size); if (blks != blks_size) { error("failed erasing from device %d", dev_desc->devnum); fastboot_fail(response_str, "failed erasing from device");
Ziyuan Xu
