[U-Boot] [PATCH 1/2] dfu: Fix up the Kconfig mess
Clean up the screaming mess of configuration options that DFU is. It was impossible to configure DFU such that TFTP is enabled and USB is not, this patch fixes that and assures that DFU TFTP and DFU USB can be enabled separatelly and that the correct pieces of code are compiled in.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Lukasz Majewski lukma@denx.de --- cmd/Kconfig | 3 ++- cmd/dfu.c | 18 +++++++++++++----- common/Makefile | 6 ++++-- drivers/dfu/Kconfig | 13 ++++++++++++- drivers/dfu/Makefile | 2 +- 5 files changed, 32 insertions(+), 10 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 7368b6df52..1ef4c31202 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -582,7 +582,8 @@ config CMD_DEMO
config CMD_DFU bool "dfu" - select USB_FUNCTION_DFU + imply USB_FUNCTION_DFU if USB_GADGET + imply TFTP_FUNCTION_DFU if NET help Enables the command "dfu" which is used to have U-Boot create a DFU class device via USB. This command requires that the "dfu_alt_info" diff --git a/cmd/dfu.c b/cmd/dfu.c index 04291f6c08..76b89ca5ed 100644 --- a/cmd/dfu.c +++ b/cmd/dfu.c @@ -25,12 +25,14 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (argc < 4) return CMD_RET_USAGE;
+#ifdef CONFIG_USB_FUNCTION_DFU char *usb_controller = argv[1]; +#endif char *interface = argv[2]; char *devstring = argv[3];
- int ret; -#ifdef CONFIG_DFU_TFTP + int ret = 0; +#ifdef CONFIG_TFTP_FUNCTION_DFU unsigned long addr = 0; if (!strcmp(argv[1], "tftp")) { if (argc == 5) @@ -39,7 +41,7 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return update_tftp(addr, interface, devstring); } #endif - +#ifdef CONFIG_USB_FUNCTION_DFU ret = dfu_init_env_entities(interface, devstring); if (ret) goto done; @@ -56,18 +58,24 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
done: dfu_free_entities(); +#endif return ret; }
U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu, "Device Firmware Upgrade", +#ifdef CONFIG_USB_FUNCTION_DFU "<USB_controller> <interface> <dev> [list]\n" " - device firmware upgrade via <USB_controller>\n" " on device <dev>, attached to interface\n" " <interface>\n" " [list] - list available alt settings\n" -#ifdef CONFIG_DFU_TFTP - "dfu tftp <interface> <dev> [<addr>]\n" +#endif +#ifdef CONFIG_TFTP_FUNCTION_DFU +#ifdef CONFIG_USB_FUNCTION_DFU + "dfu " +#endif + "tftp <interface> <dev> [<addr>]\n" " - device firmware upgrade via TFTP\n" " on device <dev>, attached to interface\n" " <interface>\n" diff --git a/common/Makefile b/common/Makefile index c7bde239c1..cdd0ab19d8 100644 --- a/common/Makefile +++ b/common/Makefile @@ -66,7 +66,9 @@ endif # !CONFIG_SPL_BUILD obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o
ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_SPL_DFU_SUPPORT) += dfu.o +ifdef CONFIG_SPL_DFU_SUPPORT +obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +endif obj-$(CONFIG_SPL_DFU_SUPPORT) += cli_hush.o obj-$(CONFIG_SPL_HASH_SUPPORT) += hash.o obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o @@ -128,7 +130,7 @@ endif
obj-y += cli.o obj-$(CONFIG_FSL_DDR_INTERACTIVE) += cli_simple.o cli_readline.o -obj-$(CONFIG_CMD_DFU) += dfu.o +obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o obj-y += command.o obj-$(CONFIG_$(SPL_)LOG) += log.o obj-$(CONFIG_$(SPL_)LOG_CONSOLE) += log_console.o diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index fa27efbb40..1a578546c7 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -1,12 +1,23 @@ menu "DFU support"
+config DFU + bool + config USB_FUNCTION_DFU bool select HASH + select DFU + depends on USB_GADGET + +config TFTP_FUNCTION_DFU + bool + select DFU + depends on NET
-if CMD_DFU +if DFU config DFU_TFTP bool "DFU via TFTP" + depends on TFTP_FUNCTION_DFU help This option allows performing update of DFU-managed medium with data sent via TFTP boot. diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index 61f2b71f91..7f35871ddc 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +obj-$(CONFIG_DFU) += dfu.o obj-$(CONFIG_DFU_MMC) += dfu_mmc.o obj-$(CONFIG_DFU_NAND) += dfu_nand.o obj-$(CONFIG_DFU_RAM) += dfu_ram.o
Fix two build warnings when building for arm64:
drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:59:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ret = dfu_write_from_mem_addr(dfu, (void *)addr, len); ^ and
drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:41:8: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 4 has type ‘__kernel_size_t {aka long unsigned int}’ [-Wformat=] debug("%s: image name: %s strlen: %u\n", __func__, sb, strlen(sb)); ^
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Lukasz Majewski lukma@denx.de --- drivers/dfu/dfu_tftp.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/dfu/dfu_tftp.c b/drivers/dfu/dfu_tftp.c index 62bf797dac..f0afbac477 100644 --- a/drivers/dfu/dfu_tftp.c +++ b/drivers/dfu/dfu_tftp.c @@ -38,7 +38,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, }
strsep(&s, "@"); - debug("%s: image name: %s strlen: %d\n", __func__, sb, strlen(sb)); + debug("%s: image name: %s strlen: %zd\n", __func__, sb, strlen(sb));
alt_setting_num = dfu_get_alt(sb); free(sb); @@ -56,7 +56,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, goto done; }
- ret = dfu_write_from_mem_addr(dfu, (void *)addr, len); + ret = dfu_write_from_mem_addr(dfu, (void *)(uintptr_t)addr, len);
Hi Marek,
Unfortunately, this change causes build breaks: https://travis-ci.org/lmajewski/u-boot-dfu/jobs/341189959
- imply USB_FUNCTION_DFU if USB_GADGET
- imply TFTP_FUNCTION_DFU if NET help Enables the command "dfu" which is used to have U-Boot
- int ret;
- int ret = 0;
+#ifdef CONFIG_USB_FUNCTION_DFU ret = dfu_init_env_entities(interface, devstring); if (ret) goto done; @@ -56,18 +58,24 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) done: dfu_free_entities(); +#endif return ret; }
- "dfu "
+#endif
- "tftp <interface> <dev> [<addr>]\n" " - device firmware upgrade via TFTP\n" " on device <dev>, attached to interface\n" " <interface>\n"
+config DFU
- bool
- select DFU
- depends on USB_GADGET
- bool
- select DFU
- depends on NET
- depends on TFTP_FUNCTION_DFU help This option allows performing update of DFU-managed medium
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Marek,
^^^^^^^^^^^- This name is OK. It is the same as other "gadget" names - like USB_FUNCTION_SDP, USB_FUNCTION_THOR, etc.
^^^^^^^^^^^^^^ - this name is a bit misleading Why we cannot select CONFIG_DFU_TFTP here directly and drop this config?
- int ret;
- int ret = 0;
Please exclude relevant pieces of code for TFTP and for USB in a separate static functions:
#ifdef CONFIG_USB_FUNCTION_DFU dfu_usb() {
} #else dfu_usb() {return 0}; #fi
#ifdef CONFIG_DFU_TFTP dfu_tftp() {
} #else dfu_tftp() {return 0}; #fi
do_dfu () { ... ret = dfu_usb(); ret = dfu_tftp(); .... }
return ret; }
- "dfu "
+#endif
Please simply use (in a way similar to ./cmd/mmc.c) :
#ifdef CONFIG_USB_FUNCTION_DFU "<USB_controller> <interface> <dev> [list]\n" " - device firmware upgrade via <USB_controller>\n" " on device <dev>, attached to interface\n" " <interface>\n" " [list] - list available alt settings\n" #endif #ifdef CONFIG_DFU_TFTP "dfu tftp <interface> <dev> [<addr>]\n" " - device firmware upgrade via TFTP\n" " on device <dev>, attached to interface\n" " <interface>\n" " [<addr>] - address where FIT image has been stored\n" #endif
This shall be left as it is - Faiz is going to clean up this. http://patchwork.ozlabs.org/patch/873372/
And side question - the CONFIG_SPL_DFU_SUPPORT shall be orthogonal to other DFU settings (as it is for SPL).
Does your board require DFU support in SPL ?
Yes, this is correct - only needed for USB DFU.
+config DFU
- bool
- select DFU
- bool
- select DFU
- depends on NET
This shall be dropped - we shall use CONFIG_DFU_TFTP directly
This is not needed.
+1
I do like the idea of first enabling CONFIG_CMD_DFU, which then if applicable enables USB_FUNCTION_DFU or DFU_TFTP.
Also CONFIG_DFU shall add generic drivers/dfu/dfu.o.
Lukasz Majewski
On 02/15/2018 01:24 AM, Lukasz Majewski wrote:
Hi Marek,
No, it just follows suit with the already messed up naming. But I have a subsequent patch doing
dfu: Rename _FUNCTION_DFU to DFU_OVER_
Do the following to make the symbol names less confusing.
sed -i "s/([TU][^_]+)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u`
This should make the purpose clear.
- int ret;
- int ret = 0;
This is kinda hard to split, but let's see.
return ret; }
- "dfu "
+#endif
This does not work, you see, if you use U_BOOT_CMD it prefixes only the first entry with the command name. Not the subsequent entries. That's why this extra ifdef is needed.
The code below, triggered by help dfu, would print "dfu dfu tftp" if CONFIG_USB_FUNCTION_DFU was disabled.
No, but I also don't want to break other boards.
+config DFU
- bool
- select DFU
- bool
- select DFU
- depends on NET
This is needed to not break boards which select CONFIG_DFU_TFTP
This is not needed.
So is this. It's another crutch to prevent this mess from completely unraveling.
+1
Lukasz Majewski
Hi Marek,
Hi Marek,
dfu: Rename _FUNCTION_DFU to DFU_OVER_ Do the following to make the symbol names less confusing. sed -i "s/\([TU][^_]\+\)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u`
Yes. Good idea.
- int ret;
- int ret = 0;
Ok.
return ret; }
- "dfu "
+#endif
Ach... the mmc has set of "common" commands, so it looks nice when extended in that way.
+config DFU
- bool
- select DFU
- bool
- select DFU
- depends on NET
This is not needed.
Ok.
+1
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
