[U-Boot] [PATCH] cmd_nvedit.c: setenv_hex must prefix hex with '0x'
setenv_hex is only called with hex values, but does not prefix the strings with '0x', as in general U-Boot assumes hex values not decimal values, and this saves space in the environment. However, some functions such as 'load' take some values that are most easily described in hex (load address) and decimal (size, offset within a file).
This can lead to the situation where, for example, spl export is run, which leads to a call of setenv_hex of the fdtaddr, which will be re-set in the environment. Then 'saveenv' may be run (after updating other parts of the environment for falcon mode), causing an invalid for 'load' fdtaddr to be saved to the environment and leading to future boots to fail if using 'load' to read the fdt file.
Cc: Wolfgang Denk wd@denx.de Signed-off-by: Tom Rini trini@ti.com --- common/cmd_nvedit.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 778dca5..4cac794 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -321,7 +321,7 @@ int setenv_hex(const char *varname, ulong value) { char str[17];
- sprintf(str, "%lx", value); + sprintf(str, "0x%lx", value); return setenv(varname, str); }
Dear Tom Rini,
I think this is not a correct way to fix the issues at hand.
All U-Boot (with the single unfortunate exception of the "sleep" command) defaults to hex input - that's what's documented, and what people have always been using for many, many years. Applying your patch means that we modify just a single use case, while setting the same environment variables from the command line (without the leading 0x) would still trigger a problem.
I understand that the actual cause of these issues is commit 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". Reviewing this patch I think that it should have never been applied. The fact that "load" and "fatload" / "ext*load" behave differently are reason enough to reject this patch. "load" should just behave like every other command, and default to hex input.
I think we should NAK your patch, and suggest to fix the problem by reverting commit 3f83c87 and making "load" default to hex input mode.
On 10/04/2013 03:35 PM, Wolfgang Denk wrote:
Dear Tom Rini,
Reverting 3f83c87 would do the opposite of what you want; it'd make extload/fatload require 0x prefixes instead of assuming hex. Perhaps what you want is a tweak to that patch so that the generic load/ls commands always expect a hex value, rather than requiring the 0x prefix?
Dear Stephen,
Well, that should be the result, yes.
You mean the extload/fatload commands have been broken before that? OK, eventually the bug was introduced before that. BUt in any case it's a bug, and should be fixed.
On 10/04/2013 04:12 PM, Wolfgang Denk wrote:
Dear Stephen,
extload/fatload were broken between the following two commits:
3f83c87 fs: fix number base behaviour change in fatload/ext*load ... 045fa1e fs: add filesystem switch libary, implement ls and fsload commands
(i.e. for about 50 commits)
The generic load command has been "broken" (by design...) since it was introduced. I suppose you can change the behaviour if you want; anyone writing "0x..." for their values presumably won't be affected, and if people really do assume all values in U-Boot are in hex, presumably nobody currently relies upon using non-prefixed values with the generic load command, since it doesn't work like that right now.
A documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.)
This rule was broken for the "load" command; for details please see especially commits 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" and 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". In the result, the load command would always require an explicit "0x" prefix for regular (i. e. base 16 formatted) input.
Change this to use the standard notation of base 16 input format. While strictly speaking this is a change of the user interface, we hope that it will not cause trouble. Stephen Warren comments (see [1]):
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172
Signed-off-by: Wolfgang Denk wd@denx.de cc: Tom Rini trini@ti.com, u-boot@lists.denx.de cc: Stephen Warren swarren@nvidia.com --- The patch has been build-tested (running MAKEALL for Power and ARM architectures) only.
common/cmd_ext2.c | 5 ++--- common/cmd_ext4.c | 5 ++--- common/cmd_fat.c | 5 ++--- common/cmd_fs.c | 6 ++---- fs/fs.c | 16 ++++++++-------- include/fs.h | 4 ++-- 6 files changed, 18 insertions(+), 23 deletions(-)
diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 1731919..5a4bcc1 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -32,7 +32,7 @@ int do_ext2ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return do_load(cmdtp, flag, argc, argv, FS_TYPE_EXT, 16); + return do_load(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
U_BOOT_CMD( @@ -47,6 +47,5 @@ U_BOOT_CMD( "load binary file from a Ext2 filesystem", "<interface> <dev[:part]> [addr] [filename] [bytes]\n" " - load binary file 'filename' from 'dev' on 'interface'\n" - " to address 'addr' from ext2 filesystem.\n" - " All numeric parameters are assumed to be hex." + " to address 'addr' from ext2 filesystem." ); diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c index 4a27cd9..8289d25 100644 --- a/common/cmd_ext4.c +++ b/common/cmd_ext4.c @@ -45,7 +45,7 @@ int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { - return do_load(cmdtp, flag, argc, argv, FS_TYPE_EXT, 16); + return do_load(cmdtp, flag, argc, argv, FS_TYPE_EXT); }
int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) @@ -122,5 +122,4 @@ U_BOOT_CMD(ext4load, 6, 0, do_ext4_load, "load binary file from a Ext4 filesystem", "<interface> <dev[:part]> [addr] [filename] [bytes]\n" " - load binary file 'filename' from 'dev' on 'interface'\n" - " to address 'addr' from ext4 filesystem.\n" - " All numeric parameters are assumed to be hex."); + " to address 'addr' from ext4 filesystem"); diff --git a/common/cmd_fat.c b/common/cmd_fat.c index f6d7aff..a12d8fa 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -19,7 +19,7 @@
int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return do_load(cmdtp, flag, argc, argv, FS_TYPE_FAT, 16); + return do_load(cmdtp, flag, argc, argv, FS_TYPE_FAT); }
@@ -35,8 +35,7 @@ U_BOOT_CMD( " the load stops on end of file.\n" " If either 'pos' or 'bytes' are not aligned to\n" " ARCH_DMA_MINALIGN then a misaligned buffer warning will\n" - " be printed and performance will suffer for the load.\n" - " All numeric parameters are assumed to be hex." + " be printed and performance will suffer for the load." );
static int do_fat_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/common/cmd_fs.c b/common/cmd_fs.c index a681d03..91a205a 100644 --- a/common/cmd_fs.c +++ b/common/cmd_fs.c @@ -22,7 +22,7 @@
int do_load_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return do_load(cmdtp, flag, argc, argv, FS_TYPE_ANY, 0); + return do_load(cmdtp, flag, argc, argv, FS_TYPE_ANY); }
U_BOOT_CMD( @@ -34,9 +34,7 @@ U_BOOT_CMD( " 'bytes' gives the size to load in bytes.\n" " If 'bytes' is 0 or omitted, the file is read until the end.\n" " 'pos' gives the file byte position to start reading from.\n" - " If 'pos' is 0 or omitted, the file is read from the start.\n" - " All numeric parameters are assumed to be decimal,\n" - " unless specified otherwise using a leading "0x"." + " If 'pos' is 0 or omitted, the file is read from the start." );
int do_ls_wrapper(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/fs/fs.c b/fs/fs.c index 99e516a..be1855d 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -231,7 +231,7 @@ int fs_write(const char *filename, ulong addr, int offset, int len) }
int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], - int fstype, int cmdline_base) + int fstype) { unsigned long addr; const char *addr_str; @@ -250,7 +250,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], return 1;
if (argc >= 4) { - addr = simple_strtoul(argv[3], NULL, cmdline_base); + addr = simple_strtoul(argv[3], NULL, 16); } else { addr_str = getenv("loadaddr"); if (addr_str != NULL) @@ -268,11 +268,11 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], } } if (argc >= 6) - bytes = simple_strtoul(argv[5], NULL, cmdline_base); + bytes = simple_strtoul(argv[5], NULL, 16); else bytes = 0; if (argc >= 7) - pos = simple_strtoul(argv[6], NULL, cmdline_base); + pos = simple_strtoul(argv[6], NULL, 16); else pos = 0;
@@ -313,7 +313,7 @@ int do_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], }
int do_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], - int fstype, int cmdline_base) + int fstype) { unsigned long addr; const char *filename; @@ -329,10 +329,10 @@ int do_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], return 1;
filename = argv[3]; - addr = simple_strtoul(argv[4], NULL, cmdline_base); - bytes = simple_strtoul(argv[5], NULL, cmdline_base); + addr = simple_strtoul(argv[4], NULL, 16); + bytes = simple_strtoul(argv[5], NULL, 16); if (argc >= 7) - pos = simple_strtoul(argv[6], NULL, cmdline_base); + pos = simple_strtoul(argv[6], NULL, 16); else pos = 0;
diff --git a/include/fs.h b/include/fs.h index c837bae..7d9403e 100644 --- a/include/fs.h +++ b/include/fs.h @@ -59,10 +59,10 @@ int fs_read(const char *filename, ulong addr, int offset, int len); * to a specific filesystem type via the fstype parameter. */ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], - int fstype, int cmdline_base); + int fstype); int do_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], int fstype); int do_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], - int fstype, int cmdline_base); + int fstype);
#endif /* _FS_H */
s/A/As/ (btw, where?)
Acked-by: Stephen Warren swarren@nvidia.com
Dear Stephen,
Thanks for pointing out.
In TFM, section "5.9. U-Boot Command Line Interface", note 2 (see [1]):
ALERT! Almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the sleep command takes its argument in decimal input format.)
[1] http://www.denx.de/wiki/view/DULG/UBootCommandLineInterface
As documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.)
Signed-off-by: Wolfgang Denk wd@denx.de cc: Tom Rini trini@ti.com, u-boot@lists.denx.de cc: Stephen Warren swarren@nvidia.com --- Changes in V2: Fix typo in commit message.
#endif /* _FS_H */
Manually correcting the commit message typo, applied to u-boot/master, thanks!
Stephen Warren
