[U-Boot] [PATCH] at91: Factored out common serial hardware initialization
Created a new function at91_serial_hw_init() which sets up the dedicated PIO pins of several at91 SoC according to CONFIG_USARTx.
Please note that the used pins for serial communication varies on different at91 SoC independently of the logic functionality equality of the serial hardware.
Signed-off-by: Michael Roth mroth@nessie.de --- board/afeb9260/afeb9260.c | 30 +----- board/atmel/at91cap9adk/at91cap9adk.c | 30 +----- board/atmel/at91sam9260ek/at91sam9260ek.c | 30 +----- board/atmel/at91sam9261ek/at91sam9261ek.c | 30 +----- board/atmel/at91sam9263ek/at91sam9263ek.c | 30 +----- board/atmel/at91sam9rlek/at91sam9rlek.c | 30 +----- include/at91_serial.h | 23 ++++ lib_arm/Makefile | 1 + lib_arm/at91_serial.c | 168 +++++++++++++++++++++++++++++ 9 files changed, 204 insertions(+), 168 deletions(-) create mode 100644 include/at91_serial.h create mode 100644 lib_arm/at91_serial.c
diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index 32445ab..ea90850 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -32,6 +32,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <netdev.h> #include <net.h> @@ -44,33 +45,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void afeb9260_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - static void afeb9260_nand_hw_init(void) { unsigned long csa; @@ -201,7 +175,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- afeb9260_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND afeb9260_nand_hw_init(); #endif diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index f7d68b7..0030e8c 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -33,6 +33,7 @@ #include <asm/arch/hardware.h> #include <lcd.h> #include <atmel_lcdc.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -47,33 +48,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91cap9_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - static void at91cap9_slowclock_hw_init(void) { /* @@ -367,7 +341,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91cap9_serial_hw_init(); + at91_serial_hw_init(); at91cap9_slowclock_hw_init(); at91cap9_nor_hw_init(); #ifdef CONFIG_CMD_NAND diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index ef99b8b..6c6084d 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -31,6 +31,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9260ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9260ek_nand_hw_init(void) { @@ -217,7 +191,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9260ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9260ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 14f236d..591d8ca 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -32,6 +32,7 @@ #include <asm/arch/io.h> #include <lcd.h> #include <atmel_lcdc.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) #include <net.h> #endif @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9261ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9261ek_nand_hw_init(void) { @@ -250,7 +224,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9261ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9261ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index ebd4649..74f608a 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -34,6 +34,7 @@ #include <asm/arch/hardware.h> #include <lcd.h> #include <atmel_lcdc.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -46,33 +47,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9263ek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9263ek_nand_hw_init(void) { @@ -301,7 +275,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9263ek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9263ek_nand_hw_init(); #endif diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index b6fef9d..801a912 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -32,6 +32,7 @@ #include <asm/arch/io.h> #include <lcd.h> #include <atmel_lcdc.h> +#include <at91_serial.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -43,33 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
-static void at91sam9rlek_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); -#endif - -#ifdef CONFIG_USART1 - at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); -#endif - -#ifdef CONFIG_USART2 - at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); -#endif -} - #ifdef CONFIG_CMD_NAND static void at91sam9rlek_nand_hw_init(void) { @@ -223,7 +197,7 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91sam9rlek_serial_hw_init(); + at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND at91sam9rlek_nand_hw_init(); #endif diff --git a/include/at91_serial.h b/include/at91_serial.h new file mode 100644 index 0000000..e0d9ce3 --- /dev/null +++ b/include/at91_serial.h @@ -0,0 +1,23 @@ +/* + * Copyright (C) 2009 Michael Roth mroth@nessie.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef __AT91_SERIAL_H__ +#define __AT91_SERIAL_H__ + +extern void at91_serial_hw_init(void); + +#endif /* __AT91_SERIAL_H__ */ diff --git a/lib_arm/Makefile b/lib_arm/Makefile index c8795b2..53eba85 100644 --- a/lib_arm/Makefile +++ b/lib_arm/Makefile @@ -32,6 +32,7 @@ SOBJS-y += _modsi3.o SOBJS-y += _udivsi3.o SOBJS-y += _umodsi3.o
+COBJS-y += at91_serial.o COBJS-y += board.o COBJS-y += bootm.o COBJS-y += cache.o diff --git a/lib_arm/at91_serial.c b/lib_arm/at91_serial.c new file mode 100644 index 0000000..d12e7c8 --- /dev/null +++ b/lib_arm/at91_serial.c @@ -0,0 +1,168 @@ +/* + * (C) Copyright 2009 Michael Roth mroth@nessie.de + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#include <common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <asm/arch/gpio.h> + +#ifdef CONFIG_ATMEL_USART + +#if !defined(CONFIG_USART0) && !defined(CONFIG_USART1) && \ + !defined(CONFIG_USART2) && !defined(CONFIG_USART3) +# error CONFIG_ATMEL_USART defined without CONFIG_USARTx defined +#endif + +#ifdef CONFIG_AT91CAP9 +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} +#endif + +#ifdef CONFIG_AT91SAM9260 +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} +#endif + +#ifdef CONFIG_AT91SAM9261 +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} +#endif + +#ifdef CONFIG_AT91SAM9263 +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} +#endif + +#ifdef CONFIG_AT91SAM9RL +void at91_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); +#endif +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); +#endif +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); +#endif +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} +#endif + +#endif /* CONFIG_ATMEL_USART */
I've send similar patch before please use it
Best Regards, J.
Dear Michael Roth,
In message 498AE474.2070304@nessie.de you wrote:
Can't find it.
Neither can I.
Jean-Christophe - it would be really helpful if you could include at least subject and posting date, or even better a URL for the postingin one of the mailing list archives, instead of just stating "I've send similar patch". Please keep this in mind for the future.
Can't find it.
[PATCH RFC] at91sam9/at91cap: move common initialisation to cpu
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Similar, but Michel's patch looks better to me. Fr example, he get's rid of all the many #ifdef CONFIG_USARTx which you still keep for no good reason.
My vote is: please apply Michael's patch.
Michael Roth
