[U-Boot] ls2085ardb not booting
I'm unable to boot ls2085ardb on the current tree. I get no console output. v2015.07 gives some output, but hangs at:
U-Boot 2015.07 (Aug 27 2015 - 16:24:43 -0500) LS2085A-RDB
Clock Configuration: CPU0(A57):1600 MHz CPU1(A57):1600 MHz CPU2(A57):1600 MHz CPU3(A57):1600 MHz CPU4(A57):1600 MHz CPU5(A57):1600 MHz CPU6(A57):1600 MHz CPU7(A57):1600 MHz Bus: 600 MHz DDR: 1333.333 MHz DP-DDR: 1333.333 MHz Reset Configuration Word (RCW): 00: 40282830 40400040 00000000 00000000 10: 00000000 00200000 00200000 00000000 20: 00c12980 00002580 00000000 00000000 30: 00000e0b 00000000 00000000 00000000 40: 00000000 00000000 00000000 00000000 50: 00000000 00000000 00000000 00000000 60: 00000000 00000000 00027000 00000000 70: 412a0000 00000000 00000000 00000000 Board: LS2085A-RDB, Board Arch: V1, Board version: C, boot from vBank: 4 FPGA: v1.18 SERDES1 Reference : Clock1 = 156.25MHz Clock2 = 156.25MHz SERDES2 Reference : Clock1 = 100MHz Clock2 = 100MHz I2C: ready DRAM: Initializing DDR....using SPD Detected UDIMM 18ASF1G72AZ-2G1A1 Detected UDIMM 18ASF1G72AZ-2G1A1 There is no rank on CS0 for controller 1. Controler 1 timeout, debug_2 = 2100 Controler 1 timeout, debug_2 = 2500 Waiting for D_INIT timeout. Memory may not work. DP-DDR: Detected UDIMM 18ASF1G72AZ-2G1A1 19.5 GiB DDR 15.5 GiB (DDR4, 64-bit, CL=9, ECC on) DDR Chip-Select Interleaving Mode: CS0+CS1 DP-DDR 4 GiB (DDR4, 32-bit, CL=9, ECC on) DDR Chip-Select Interleaving Mode: CS0+CS1
The internal bringup branch does boot on the same board, with the same RCW.
-Scott
Scott,
Did you use u-boot.bin file? It is now u-boot-dtb.bin image.
York
-------- Original message -------- From: Wood Scott-B07421 Date:08/27/2015 4:32 PM (GMT-06:00) To: Sun York-R58495 Cc: u-boot@lists.denx.de Subject: ls2085ardb not booting
-Scott
On Thu, 2015-08-27 at 21:37 -0500, Sun York-R58495 wrote:
Scott,
York
That must have been it (though I'm currently trying on QDS, not RDB, due to board availability). It would be nice if the name of the file that gets burned into a particular boot source didn't change based on internal implementation details...
-Scott
MHz
-Scott
Scott,
York
I agree that would be nice. The change wasn't made internally. Once we enable the device tree (to use driver model), we have to use the new file name.
York
Scott Wood
York Sun
