[U-Boot] [PATCH 1/1] efi_loader: refactor efi_setup_loaded_image()
Create the handle of loaded images and the EFI_LOADED_IMAGE_PROTOCOL inside efi_setup_loaded_image(). Do not use local variables.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 61 +++++++++++++++++++---------------- include/efi_loader.h | 8 ++--- lib/efi_loader/efi_boottime.c | 48 ++++++++++++++------------- 3 files changed, 64 insertions(+), 53 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a890f414e8..db753aaf7c 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -342,19 +342,26 @@ static efi_status_t efi_install_fdt(ulong fdt_addr) return ret; }
-/* - * Load an EFI payload into a newly allocated piece of memory, register all - * EFI objects it would want to access and jump to it. +/** + * do_bootefi_exec() - execute EFI binary + * + * @efi: address of the binary + * @device_path: path of the device from which the binary was loaded + * @image_path: device path of the binary + * Return: status code + * + * Load the EFI binary into a newly assigned memory unwinding the relocation + * information, install the loaded image protocol, and call the binary. */ static efi_status_t do_bootefi_exec(void *efi, struct efi_device_path *device_path, struct efi_device_path *image_path) { - struct efi_loaded_image loaded_image_info = {}; - struct efi_object loaded_image_info_obj = {}; efi_handle_t mem_handle = NULL; struct efi_device_path *memdp = NULL; efi_status_t ret; + efi_handle_t image_handle; + struct efi_loaded_image *loaded_image_info;
EFIAPI efi_status_t (*entry)(efi_handle_t image_handle, struct efi_system_table *st); @@ -384,8 +391,8 @@ static efi_status_t do_bootefi_exec(void *efi, assert(device_path && image_path); }
- efi_setup_loaded_image(&loaded_image_info, &loaded_image_info_obj, - device_path, image_path); + efi_setup_loaded_image(device_path, image_path, &image_handle, + &loaded_image_info);
/* * gd lives in a fixed register which may get clobbered while we execute @@ -394,9 +401,9 @@ static efi_status_t do_bootefi_exec(void *efi, efi_save_gd();
/* Transfer environment variable bootargs as load options */ - set_load_options(&loaded_image_info, "bootargs"); + set_load_options(loaded_image_info, "bootargs"); /* Load the EFI payload */ - entry = efi_load_pe(efi, &loaded_image_info); + entry = efi_load_pe(efi, loaded_image_info); if (!entry) { ret = EFI_LOAD_ERROR; goto exit; @@ -404,10 +411,10 @@ static efi_status_t do_bootefi_exec(void *efi,
if (memdp) { struct efi_device_path_memory *mdp = (void *)memdp; - mdp->memory_type = loaded_image_info.image_code_type; - mdp->start_address = (uintptr_t)loaded_image_info.image_base; + mdp->memory_type = loaded_image_info->image_code_type; + mdp->start_address = (uintptr_t)loaded_image_info->image_base; mdp->end_address = mdp->start_address + - loaded_image_info.image_size; + loaded_image_info->image_size; }
/* we don't support much: */ @@ -417,8 +424,8 @@ static efi_status_t do_bootefi_exec(void *efi, /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
- if (setjmp(&loaded_image_info.exit_jmp)) { - ret = loaded_image_info.exit_status; + if (setjmp(&loaded_image_info->exit_jmp)) { + ret = loaded_image_info->exit_status; goto exit; }
@@ -430,7 +437,7 @@ static efi_status_t do_bootefi_exec(void *efi,
/* Move into EL2 and keep running there */ armv8_switch_to_el2((ulong)entry, - (ulong)&loaded_image_info_obj.handle, + (ulong)&image_handle, (ulong)&systab, 0, (ulong)efi_run_in_el2, ES_TO_AARCH64);
@@ -447,7 +454,7 @@ static efi_status_t do_bootefi_exec(void *efi, secure_ram_addr(_do_nonsec_entry)( efi_run_in_hyp, (uintptr_t)entry, - (uintptr_t)loaded_image_info_obj.handle, + (uintptr_t)image_handle, (uintptr_t)&systab);
/* Should never reach here, efi exits with longjmp */ @@ -455,11 +462,12 @@ static efi_status_t do_bootefi_exec(void *efi, } #endif
- ret = efi_do_enter(loaded_image_info_obj.handle, &systab, entry); + ret = efi_do_enter(image_handle, &systab, entry);
exit: /* image has returned, loaded-image obj goes *poof*: */ - list_del(&loaded_image_info_obj.link); + if (image_handle) + efi_delete_handle(image_handle); if (mem_handle) efi_delete_handle(mem_handle);
@@ -500,6 +508,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *saddr; efi_status_t r; unsigned long fdt_addr; + efi_handle_t image_handle; + struct efi_loaded_image *loaded_image_info;
/* Allow unaligned memory access */ allow_unaligned(); @@ -544,8 +554,6 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { - struct efi_loaded_image loaded_image_info = {}; - struct efi_object loaded_image_info_obj = {};
/* Construct a dummy device path. */ bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, @@ -553,9 +561,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) (uintptr_t)&efi_selftest); bootefi_image_path = efi_dp_from_file(NULL, 0, "\selftest");
- efi_setup_loaded_image(&loaded_image_info, - &loaded_image_info_obj, - bootefi_device_path, bootefi_image_path); + efi_setup_loaded_image(bootefi_device_path, bootefi_image_path, + &image_handle, &loaded_image_info); /* * gd lives in a fixed register which may get clobbered while we * execute the payload. So save it here and restore it on every @@ -563,12 +570,12 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ efi_save_gd(); /* Transfer environment variable efi_selftest as load options */ - set_load_options(&loaded_image_info, "efi_selftest"); + set_load_options(loaded_image_info, "efi_selftest"); /* Execute the test */ - r = efi_selftest(loaded_image_info_obj.handle, &systab); + r = efi_selftest(image_handle, &systab); efi_restore_gd(); - free(loaded_image_info.load_options); - list_del(&loaded_image_info_obj.link); + free(loaded_image_info->load_options); + efi_delete_handle(image_handle); return r != EFI_SUCCESS; } else #endif diff --git a/include/efi_loader.h b/include/efi_loader.h index f0d086daff..e5bc7d043e 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -342,10 +342,10 @@ int efi_memory_init(void); /* Adds new or overrides configuration table entry to the system table */ efi_status_t efi_install_configuration_table(const efi_guid_t *guid, void *table); /* Sets up a loaded image */ -efi_status_t efi_setup_loaded_image( - struct efi_loaded_image *info, struct efi_object *obj, - struct efi_device_path *device_path, - struct efi_device_path *file_path); +efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, + struct efi_device_path *file_path, + efi_handle_t *handle_ptr, + struct efi_loaded_image **info_ptr); efi_status_t efi_load_image_from_path(struct efi_device_path *file_path, void **buffer); /* Print information about a loaded image */ diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 3bcea647c8..730124a119 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1478,18 +1478,34 @@ static efi_status_t EFIAPI efi_install_configuration_table_ext(efi_guid_t *guid, * * Return: status code */ -efi_status_t efi_setup_loaded_image( - struct efi_loaded_image *info, struct efi_object *obj, - struct efi_device_path *device_path, - struct efi_device_path *file_path) +efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, + struct efi_device_path *file_path, + efi_handle_t *handle_ptr, + struct efi_loaded_image **info_ptr) { efi_status_t ret; + struct efi_loaded_image *info; + struct efi_object *obj; + + info = calloc(1, sizeof(*info)); + if (!info) + return EFI_OUT_OF_RESOURCES; + obj = calloc(1, sizeof(*obj)); + if (!obj) { + free(info); + return EFI_OUT_OF_RESOURCES; + }
/* Add internal object to object list */ efi_add_handle(obj); /* efi_exit() assumes that the handle points to the info */ obj->handle = info;
+ if (handle_ptr) + *handle_ptr = obj->handle; + if (info_ptr) + *info_ptr = info; + info->revision = EFI_LOADED_IMAGE_PROTOCOL_REVISION; info->file_path = file_path; info->system_table = &systab; @@ -1629,7 +1645,6 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, efi_handle_t *image_handle) { struct efi_loaded_image *info; - struct efi_object *obj; efi_status_t ret;
EFI_ENTRY("%d, %p, %pD, %p, %zd, %p", boot_policy, parent_image, @@ -1645,18 +1660,6 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, goto error; }
- info = calloc(1, sizeof(*info)); - if (!info) { - ret = EFI_OUT_OF_RESOURCES; - goto error; - } - obj = calloc(1, sizeof(*obj)); - if (!obj) { - free(info); - ret = EFI_OUT_OF_RESOURCES; - goto error; - } - if (!source_buffer) { struct efi_device_path *dp, *fp;
@@ -1668,16 +1671,17 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, * file parts: */ efi_dp_split_file_path(file_path, &dp, &fp); - ret = efi_setup_loaded_image(info, obj, dp, fp); + ret = efi_setup_loaded_image(dp, fp, image_handle, &info); if (ret != EFI_SUCCESS) goto failure; } else { /* In this case, file_path is the "device" path, i.e. * something like a HARDWARE_DEVICE:MEMORY_MAPPED */ - ret = efi_setup_loaded_image(info, obj, file_path, NULL); + ret = efi_setup_loaded_image(file_path, NULL, image_handle, + &info); if (ret != EFI_SUCCESS) - goto failure; + goto error; } info->reserved = efi_load_pe(source_buffer, info); if (!info->reserved) { @@ -1686,11 +1690,11 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, } info->system_table = &systab; info->parent_handle = parent_image; - *image_handle = obj->handle; return EFI_EXIT(EFI_SUCCESS); failure: + efi_delete_handle(*image_handle); + *image_handle = NULL; free(info); - efi_delete_handle(obj); error: return EFI_EXIT(ret); }
