[U-Boot] [PATCH] env: allow people to force envcrc building
For people who want to manually extract the embedded environment so that it can be manually packed into the final u-boot image, add a config opt to force building of the envcrc tool.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- README | 5 +++++ common/env_embedded.c | 2 +- include/common.h | 5 +++++ tools/Makefile | 1 + tools/envcrc.c | 10 +++++++--- 5 files changed, 19 insertions(+), 4 deletions(-)
diff --git a/README b/README index beb1cbb..c517204 100644 --- a/README +++ b/README @@ -2447,6 +2447,11 @@ The following definitions that deal with the placement and management of environment data (variable area); in general, we support the following configurations:
+- CONFIG_BUILD_ENVCRC: + + Builds up envcrc with the target environment so that external utils + may easily extract it and embed it in final U-Boot images. + - CONFIG_ENV_IS_IN_FLASH:
Define this if the environment is in flash memory. diff --git a/common/env_embedded.c b/common/env_embedded.c index ae6cac4..e438575 100644 --- a/common/env_embedded.c +++ b/common/env_embedded.c @@ -44,7 +44,7 @@ * Generate embedded environment table * inside U-Boot image, if needed. */ -#if defined(ENV_IS_EMBEDDED) +#if defined(ENV_IS_EMBEDDED) || defined(CONFIG_BUILD_ENVCRC) /* * Only put the environment in it's own section when we are building * U-Boot proper. The host based program "tools/envcrc" does not need diff --git a/include/common.h b/include/common.h index 21c05db..9253cd1 100644 --- a/include/common.h +++ b/include/common.h @@ -756,4 +756,9 @@ int cpu_release(int nr, int argc, char * const argv[]); #define ALIGN(x,a) __ALIGN_MASK((x),(typeof(x))(a)-1) #define __ALIGN_MASK(x,mask) (((x)+(mask))&~(mask))
+/* Pull in stuff for the build system */ +#ifdef DO_DEPS_ONLY +# include <environment.h> +#endif + #endif /* __COMMON_H_ */ diff --git a/tools/Makefile b/tools/Makefile index 623f908..5784f51 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -51,6 +51,7 @@ endif # Generated executable files BIN_FILES-$(CONFIG_LCD_LOGO) += bmp_logo$(SFX) BIN_FILES-$(CONFIG_VIDEO_LOGO) += bmp_logo$(SFX) +BIN_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc$(SFX) BIN_FILES-$(CONFIG_ENV_IS_EMBEDDED) += envcrc$(SFX) BIN_FILES-$(CONFIG_ENV_IS_IN_DATAFLASH) += envcrc$(SFX) BIN_FILES-$(CONFIG_ENV_IS_IN_EEPROM) += envcrc$(SFX) diff --git a/tools/envcrc.c b/tools/envcrc.c index c8c50d7..feebbab 100644 --- a/tools/envcrc.c +++ b/tools/envcrc.c @@ -60,6 +60,10 @@ # endif #endif /* CONFIG_ENV_IS_IN_FLASH */
+#if defined(ENV_IS_EMBEDDED) && !defined(CONFIG_BUILD_ENVCRC) +# define CONFIG_BUILD_ENVCRC 1 +#endif + #ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT # define ENV_HEADER_SIZE (sizeof(uint32_t) + 1) #else @@ -71,14 +75,14 @@
extern uint32_t crc32 (uint32_t, const unsigned char *, unsigned int);
-#ifdef ENV_IS_EMBEDDED +#ifdef CONFIG_BUILD_ENVCRC extern unsigned int env_size; extern unsigned char environment; -#endif /* ENV_IS_EMBEDDED */ +#endif /* CONFIG_BUILD_ENVCRC */
int main (int argc, char **argv) { -#ifdef ENV_IS_EMBEDDED +#ifdef CONFIG_BUILD_ENVCRC unsigned char pad = 0x00; uint32_t crc; unsigned char *envptr = &environment,
Dear Mike Frysinger,
How would that be used? Can you please provide an example?
for Blackfin targets, i have to generate an LDR format. this is the file that is ultimately burned into the flash. since i cant embed the env in the original ELF/binary (since offsets in that will not correlate to actual flash offsets), i have to let the ldr-utils do the embedding.
so after the final ELF has been linked, Blackfin targets run: tools/envcrc --binary > env-ldr.o bfin-uclinux-ldr -T bf548-0.0 -c u-boot.ldr u-boot --bmode PARA --use-vmas --initcode arch/blackfin/cpu/initcode.o -J --punchit $((0x2000)):$((0x2000)):env-ldr.o --dma 6
and this produces the LDR: DXE 1 at 0x00000000: Offset BlockCode Address Bytes Argument Block 1 0x00000000: 0xADC85006 0xFFA00000 0x00000000 0x00049CF4 ( 16bit-dma-from-16bit ignore first ) Block 2 0x00000010: 0xADAF0806 0xFFA00000 0x00000170 0xDEADBEEF ( 16bit-dma-from-16bit init ) Block 3 0x00000190: 0xAD340006 0x03F00000 0x00001E50 0xDEADBEEF ( 16bit-dma-from-16bit ) Block 4 0x00001FF0: 0xAD711006 0x00000000 0x00002000 0xBAADF00D ( 16bit-dma-from-16bit ignore ) Block 5 0x00004000: 0xADE50006 0x03F01E50 0x000061B0 0xDEADBEEF ( 16bit-dma-from-16bit ) .... more Blocks ....
and now the embedded environment is at the right offset -- 0x2000 (it's Block 4 in the above output) -mike
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - updated to master after tools/ changes
README | 5 +++++ common/env_embedded.c | 2 +- include/common.h | 5 +++++ tools/envcrc.c | 10 +++++++--- 4 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/README b/README index 446966d..ccefabb 100644 --- a/README +++ b/README @@ -2494,6 +2494,11 @@ The following definitions that deal with the placement and management of environment data (variable area); in general, we support the following configurations:
Define this if the environment is in flash memory. diff --git a/common/env_embedded.c b/common/env_embedded.c index ae6cac4..e438575 100644 --- a/common/env_embedded.c +++ b/common/env_embedded.c @@ -44,7 +44,7 @@ * Generate embedded environment table * inside U-Boot image, if needed. */ -#if defined(ENV_IS_EMBEDDED) +#if defined(ENV_IS_EMBEDDED) || defined(CONFIG_BUILD_ENVCRC) /* * Only put the environment in it's own section when we are building * U-Boot proper. The host based program "tools/envcrc" does not need diff --git a/include/common.h b/include/common.h index 1e21b7a..6b1a458 100644 --- a/include/common.h +++ b/include/common.h @@ -759,4 +759,9 @@ int cpu_release(int nr, int argc, char * const argv[]); #define ALIGN(x,a) __ALIGN_MASK((x),(typeof(x))(a)-1) #define __ALIGN_MASK(x,mask) (((x)+(mask))&~(mask))
+/* Pull in stuff for the build system */ +#ifdef DO_DEPS_ONLY +# include <environment.h> +#endif + #endif /* __COMMON_H_ */ diff --git a/tools/envcrc.c b/tools/envcrc.c index c8c50d7..feebbab 100644 --- a/tools/envcrc.c +++ b/tools/envcrc.c @@ -60,6 +60,10 @@ # endif #endif /* CONFIG_ENV_IS_IN_FLASH */
v2
Applied, thanks.
v2
This commit causes build warnings for a number of boards, for example:
-> ./MAKEALL acadia_nand In file included from include/common.h:766: /home/wd/git/u-boot/work/include/environment.h:127:1: warning: "CONFIG_ENV_IS_EMBEDDED" redefined In file included from /home/wd/git/u-boot/work/include/config.h:7, from include/common.h:37: /home/wd/git/u-boot/work/include/configs/acadia.h:106:1: warning: this is the location of the previous definition Configuring for acadia_nand - Board: acadia, Options: NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 In file included from include/common.h:766: /home/wd/git/u-boot/work/include/environment.h:127:1: warning: "CONFIG_ENV_IS_EMBEDDED" redefined In file included from /home/wd/git/u-boot/work/include/config.h:7, from include/common.h:37: /home/wd/git/u-boot/work/include/configs/acadia.h:106:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/common.h:766, from lib/asm-offsets.c:18: /home/wd/git/u-boot/work/include/environment.h:127:1: warning: "CONFIG_ENV_IS_EMBEDDED" redefined In file included from /home/wd/git/u-boot/work/include/config.h:7, from /home/wd/git/u-boot/work/include/common.h:37, from lib/asm-offsets.c:18: /home/wd/git/u-boot/work/include/configs/acadia.h:106:1: warning: this is the location of the previous definition ...
Please fix.
sorry, i had another patch locally that i missed squashing in that fixed this. but i see you've already taken care of it. -mike
Mike Frysinger
