[U-Boot] [PATCH v2 1/3] arm: ls1021a: Adjust memory mapping for Flash/SD card on LS1021AQDS/TWR
This patch is to adjust the memory mapping for FLash/SD card on LS1021AQDS and LS1021ATWR, such as U-Boot start address on serial Flash, QE firmware load address and environment address.
Signed-off-by: Alison Wang alison.wang@nxp.com --- Changes: - None
include/configs/ls1021aqds.h | 10 +++++----- include/configs/ls1021atwr.h | 10 +++++----- 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index c3224c8..97f6c43 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -69,7 +69,7 @@ unsigned long get_board_ddr_clk(void); #endif
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_SYS_TEXT_BASE 0x40010000 +#define CONFIG_SYS_TEXT_BASE 0x40100000 #endif
#ifdef CONFIG_NAND_BOOT @@ -499,7 +499,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DEVICE_DISABLE
-#define CONFIG_SYS_QE_FW_ADDR 0x600c0000 +#define CONFIG_SYS_QE_FW_ADDR 0x60940000
#ifdef CONFIG_LPUART #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -550,14 +550,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_NAND_BOOT) #define CONFIG_ENV_IS_IN_NAND @@ -565,7 +565,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1d0b469..aecbee0 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -133,7 +133,7 @@ #endif
#ifndef CONFIG_SYS_TEXT_BASE @@ -410,7 +410,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ #endif
/* * Environment @@ -418,18 +418,18 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x20000 #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
This patch is to adjust the memory mapping for FLash/SD card on LS1043AQDS and LS1043ARDB, such as PPA firmware load address, FMAN firmware load address, QE firmware load address, U-Boot start address on serial flash and environment address.
Signed-off-by: Alison Wang alison.wang@nxp.com --- Changes: - Update the comments.
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 ++++---- include/configs/ls1043a_common.h | 12 ++++++------ include/configs/ls1043aqds.h | 10 +++++----- include/configs/ls1043ardb.h | 8 ++++---- 4 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 4c16c4c..82c76e2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -163,11 +163,11 @@ endchoice config SYS_LS_PPA_FW_ADDR hex "Address of PPA firmware loading from" depends on FSL_LS_PPA - default 0x40500000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT + default 0x40400000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT default 0x580a00000 if SYS_LS_PPA_FW_IN_XIP && ARCH_LS2080A - default 0x60500000 if SYS_LS_PPA_FW_IN_XIP - default 0x500000 if SYS_LS_PPA_FW_IN_MMC - default 0x500000 if SYS_LS_PPA_FW_IN_NAND + default 0x60400000 if SYS_LS_PPA_FW_IN_XIP + default 0x400000 if SYS_LS_PPA_FW_IN_MMC + default 0x400000 if SYS_LS_PPA_FW_IN_NAND
help If the PPA firmware locate at XIP flash, such as NOR or diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index e269248..05419fe 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -208,20 +208,20 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x60000
#ifdef CONFIG_NAND_BOOT -/* Store Fman ucode at offeset 0x160000(11 blocks). */ +/* Store Fman ucode at offeset 0x900000(72 blocks). */ #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (72 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is * about 1MB (2040 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 2040 + 16 = 2064, enlarge it to 2080(0x820). + * 0x2000 (16 blocks), 8 + 2040 + 16 = 2064, enlarge it to 18432(0x4800). */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x4800) #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x40900000 #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 1000000 @@ -229,7 +229,7 @@ #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR /* FMan fireware Pre-load address */ -#define CONFIG_SYS_FMAN_FW_ADDR 0x60300000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x60900000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index b14e944..04d74ac 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -12,7 +12,7 @@ #if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) #define CONFIG_SYS_TEXT_BASE 0x82000000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_SYS_TEXT_BASE 0x40010000 +#define CONFIG_SYS_TEXT_BASE 0x40100000 #else #define CONFIG_SYS_TEXT_BASE 0x60100000 #endif @@ -413,20 +413,20 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_NAND_BOOT #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 #endif diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 5e570cd..a162378 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -235,15 +235,15 @@ #if defined(CONFIG_NAND_BOOT) #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 #endif @@ -281,7 +281,7 @@ !defined(CONFIG_QSPI_BOOT) #define CONFIG_U_QE #endif -#define CONFIG_SYS_QE_FW_ADDR 0x60600000 +#define CONFIG_SYS_QE_FW_ADDR 0x60940000 #endif
/* USB */
Changes:
Reformatted commit message. Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
This patch is to adjust the memory mapping for FLash/SD card on LS1046AQDS and LS1046ARDB, such as FMAN firmware load address, U-Boot start address on serial flash and environment address.
Signed-off-by: Alison Wang alison.wang@nxp.com --- Changes: - Update the comments and README.
board/freescale/ls1046ardb/README | 16 ++++++++-------- include/configs/ls1046a_common.h | 10 +++++----- include/configs/ls1046aqds.h | 10 +++++----- include/configs/ls1046ardb.h | 4 ++-- 4 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/board/freescale/ls1046ardb/README b/board/freescale/ls1046ardb/README index 1ef7d47..a38c9d4 100644 --- a/board/freescale/ls1046ardb/README +++ b/board/freescale/ls1046ardb/README @@ -59,14 +59,14 @@ Start Address End Address Description Size QSPI flash map: Start Address End Address Description Size 0x00_4000_0000 - 0x00_400F_FFFF RCW + PBI 1MB -0x00_4010_0000 - 0x00_401F_FFFF U-Boot 1MB -0x00_4020_0000 - 0x00_402F_FFFF U-Boot Env 1MB -0x00_4030_0000 - 0x00_403F_FFFF FMan ucode 1MB -0x00_4040_0000 - 0x00_404F_FFFF UEFI 1MB -0x00_4050_0000 - 0x00_406F_FFFF PPA 2MB -0x00_4070_0000 - 0x00_408F_FFFF Secure boot header - + bootscript 2MB -0x00_4090_0000 - 0x00_40FF_FFFF Reserved 7MB +0x00_4010_0000 - 0x00_402F_FFFF U-Boot 2MB +0x00_4030_0000 - 0x00_403F_FFFF U-Boot Env 1MB +0x00_4040_0000 - 0x00_405F_FFFF PPA 2MB +0x00_4060_0000 - 0x00_408F_FFFF Secure boot header + + bootscript 3MB +0x00_4090_0000 - 0x00_4093_FFFF FMan ucode 256KB +0x00_4094_0000 - 0x00_4097_FFFF QE/uQE firmware 256KB +0x00_4098_0000 - 0x00_40FF_FFFF Reserved 6MB 0x00_4100_0000 - 0x00_43FF_FFFF FIT Image 48MB
Booting Options diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 957ffd3..61bf3eb 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -166,23 +166,23 @@ /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is * about 1MB (2048 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080(0x820). + * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 18432(0x4800). */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x4800) #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_FMAN_FW_ADDR 0x40300000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x40900000 #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 1000000 #define CONFIG_ENV_SPI_MODE 0x03 #elif defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (72 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_FMAN_FW_ADDR 0x60300000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x60900000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 0cf6010..5d2e819 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -12,7 +12,7 @@ #if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) #define CONFIG_SYS_TEXT_BASE 0x82000000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_SYS_TEXT_BASE 0x40010000 +#define CONFIG_SYS_TEXT_BASE 0x40100000 #else #define CONFIG_SYS_TEXT_BASE 0x60100000 #endif @@ -447,20 +447,20 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_NAND_BOOT #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 #endif diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 67ee626..38dd4d7 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -169,12 +169,12 @@ #if defined(CONFIG_SD_BOOT) #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ #endif
Changes:
+ bootscript 2MB
+ bootscript 3MB
- PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is
- about 1MB (2048 blocks), Env is stored after the image, and the env size is
- 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080(0x820).
- 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 18432(0x4800).
I was expecting a good reason for this offset change. Guess there isn't one, except to align the offset for all boards.
York
Changes:
York
Changes:
- None
Reformatted commit message to wrap back at or before 70 characters. Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Alison Wang
york sun
