[U-Boot] [PATCH] ppc4xx: Big lwmon5 board support rework/update
This patch brings the lwmon5 board support up-to-date. Here a summary of the changes:
lwmon5 board port related: - GPIO's changed to control the LSB transmitter - Reset USB PHY's upon power-up - Enable CAN upon power-up - USB init error workaround (errata CHIP_6) - EBC: Enable burstmode and modify the timings for the GDC memory - EBC: Speed up NOR flash timings
lwmon5 board POST related: - Add FPGA memory test - Add GDC memory test - DSP POST reworked - SYSMON POST: Fix handling of negative temperatures - Add output for sysmon1 POST - HW-watchdog min. time test reworked
Additionally some coding-style changes were done.
Signed-off-by: Sascha Laue sascha.laue@liebherr.com Signed-off-by: Stefan Roese sr@denx.de --- board/lwmon5/kbd.c | 45 ++++++ board/lwmon5/lwmon5.c | 249 ++++++++++++++++++++++------------ include/configs/lwmon5.h | 283 ++++++++++++++++++++++----------------- post/board/lwmon5/dsp.c | 21 +++- post/board/lwmon5/dspic.c | 56 +++++--- post/board/lwmon5/fpga.c | 308 +++++++++++++++++++++++++++++++++++------ post/board/lwmon5/gdc.c | 308 ++++++++++++++++++++++++++++++++++++++++-- post/board/lwmon5/sysmon.c | 160 ++++++++++++++--------- post/board/lwmon5/watchdog.c | 19 ++- 9 files changed, 1090 insertions(+), 359 deletions(-)
diff --git a/board/lwmon5/kbd.c b/board/lwmon5/kbd.c index 0e26b89..5231c7a 100644 --- a/board/lwmon5/kbd.c +++ b/board/lwmon5/kbd.c @@ -45,6 +45,10 @@ static int compare_magic (uchar *kbd_data, uchar *str); /*--------------------- Local macros and constants --------------------*/ #define _NOT_USED_ 0xFFFFFFFF
+/*------------------------- dspic io expander -----------------------*/ +#define DSPIC_PON_STATUS_REG 0x80A +#define DSPIC_PON_INV_STATUS_REG 0x80C +#define DSPIC_PON_KEY_REG 0x810 /*------------------------- Keyboard controller -----------------------*/ /* command codes */ #define KEYBD_CMD_READ_KEYS 0x01 @@ -75,6 +79,7 @@ static int compare_magic (uchar *kbd_data, uchar *str); /* maximum number of "magic" key codes that can be assigned */
static uchar kbd_addr = CONFIG_SYS_I2C_KEYBD_ADDR; +static uchar dspic_addr = CONFIG_SYS_I2C_DSPIC_IO_ADDR;
static uchar *key_match (uchar *);
@@ -167,6 +172,23 @@ static void kbd_init (void) } }
+ +/* Read a register from the dsPIC. */ +int _dspic_read(ushort reg, ushort *data) +{ + uchar buf[sizeof(*data)]; + int rval; + + if (i2c_read(dspic_addr, reg, 2, buf, 2)) + return -1; + + rval = i2c_read(dspic_addr, reg, sizeof(reg), buf, sizeof(*data)); + *data = (buf[0] << 8) | buf[1]; + + return rval; +} + + /*********************************************************************** F* Function: int misc_init_r (void) P*A*Z* * @@ -197,6 +219,7 @@ int misc_init_r_kbd (void) uchar kbd_init_status = gd->kbd_status >> 8; uchar kbd_status = gd->kbd_status; uchar val; + ushort data, inv_data; char *str; int i;
@@ -231,9 +254,31 @@ int misc_init_r_kbd (void) i2c_write (kbd_addr, 0, 0, &val, 1); i2c_read (kbd_addr, 0, 0, kbd_data, KEYBD_DATALEN);
+ /* read out start key from bse01 received via can */ + _dspic_read(DSPIC_PON_STATUS_REG, &data); + /* check highbyte from status register */ + if (data > 0xFF) { + _dspic_read(DSPIC_PON_INV_STATUS_REG, &inv_data); + + /* check inverse data */ + if ((data+inv_data) == 0xFFFF) { + /* don't overwrite local key */ + if (kbd_data[1] == 0) { + /* read key value */ + _dspic_read(DSPIC_PON_KEY_REG, &data); + str = (char *)&data; + /* swap bytes */ + kbd_data[1] = str[1]; + kbd_data[2] = str[0]; + printf("CAN received startkey: 0x%X\n", data); + } + } + } + for (i = 0; i < KEYBD_DATALEN; ++i) { sprintf (keybd_env + i + i, "%02X", kbd_data[i]); } + setenv ("keybd", keybd_env);
str = strdup ((char *)key_match (kbd_data)); /* decode keys */ diff --git a/board/lwmon5/lwmon5.c b/board/lwmon5/lwmon5.c index 9622b70..dd275bf 100644 --- a/board/lwmon5/lwmon5.c +++ b/board/lwmon5/lwmon5.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007-2010 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * This program is free software; you can redistribute it and/or @@ -24,10 +24,13 @@ #include <asm/processor.h> #include <asm/ppc4xx-gpio.h> #include <asm/io.h> +#include <post.h> +#include <flash.h> +#include <mtd/cfi_flash.h>
DECLARE_GLOBAL_DATA_PTR;
-extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ +static phys_addr_t lwmon5_cfi_flash_bank_addr[2] = CONFIG_SYS_FLASH_BANKS_LIST;
ulong flash_get_size(ulong base, int banknum); int misc_init_r_kbd(void); @@ -97,16 +100,18 @@ int board_early_init_f(void) gpio_write_bit(CONFIG_SYS_GPIO_FLASH_WP, 1);
#if CONFIG_POST & CONFIG_SYS_POST_BSPEC1 - gpio_write_bit(CONFIG_SYS_GPIO_HIGHSIDE, 1); + /* enable the LSB transmitter */ + gpio_write_bit(CONFIG_SYS_GPIO_LSB_ENABLE, 1); + /* enable the CAN transmitter */ + gpio_write_bit(CONFIG_SYS_GPIO_CAN_ENABLE, 1);
reg = 0; /* reuse as counter */ out_be32((void *)CONFIG_SYS_DSPIC_TEST_ADDR, in_be32((void *)CONFIG_SYS_DSPIC_TEST_ADDR) & ~CONFIG_SYS_DSPIC_TEST_MASK); - while (!gpio_read_in_bit(CONFIG_SYS_GPIO_DSPIC_READY) && reg++ < 1000) { + while (gpio_read_in_bit(CONFIG_SYS_GPIO_DSPIC_READY) && reg++ < 1000) { udelay(1000); } - gpio_write_bit(CONFIG_SYS_GPIO_HIGHSIDE, 0); if (gpio_read_in_bit(CONFIG_SYS_GPIO_DSPIC_READY)) { /* set "boot error" flag */ out_be32((void *)CONFIG_SYS_DSPIC_TEST_ADDR, @@ -135,9 +140,61 @@ int board_early_init_f(void) return 0; }
-/*---------------------------------------------------------------------------+ - | misc_init_r. - +---------------------------------------------------------------------------*/ +/* + * Override weak default with board specific version + */ +phys_addr_t cfi_flash_bank_addr(int bank) +{ + return lwmon5_cfi_flash_bank_addr[bank]; +} + +/* + * Override the weak default mapping function with a board specific one + */ +u32 flash_get_bank_size(int cs, int idx) +{ + return flash_info[idx].size; +} + +int board_early_init_r(void) +{ + u32 val0, val1; + + /* + * lwmon5 is manufactured in 2 different board versions: + * The lwmon5a board has 64MiB NOR flash instead of the + * 128MiB of the original lwmon5. Unfortunately the CFI driver + * will report 2 banks of 64MiB even for the smaller flash + * chip, since the bank is mirrored. To fix this, we bring + * one bank into CFI query mode and read its response. This + * enables us to detect the real number of flash devices/ + * banks which will be used later on by the common CFI driver. + */ + + /* Put bank 0 into CFI command mode and read */ + out_be32((void *)CONFIG_SYS_FLASH0, 0x00980098); + val0 = in_be32((void *)CONFIG_SYS_FLASH0 + FLASH_OFFSET_CFI_RESP); + val1 = in_be32((void *)CONFIG_SYS_FLASH1 + FLASH_OFFSET_CFI_RESP); + + /* Reset flash again out of query mode */ + out_be32((void *)CONFIG_SYS_FLASH0, 0x00f000f0); + + /* When not identical, we have 2 different flash devices/banks */ + if (val0 != val1) + return 0; + + /* + * Now we're sure that we're running on a LWMON5a board with + * only 64MiB NOR flash in one bank: + * + * Set flash base address and bank count for CFI driver probing. + */ + cfi_flash_num_flash_banks = 1; + lwmon5_cfi_flash_bank_addr[0] = CONFIG_SYS_FLASH0; + + return 0; +} + int misc_init_r(void) { u32 pbcr; @@ -145,7 +202,7 @@ int misc_init_r(void) u32 reg; unsigned long usb2d0cr = 0; unsigned long usb2phy0cr, usb2h0cr = 0; - unsigned long sdr0_pfc1; + unsigned long sdr0_pfc1, sdr0_srst;
/* * FLASH stuff... @@ -158,32 +215,7 @@ int misc_init_r(void) gd->bd->bi_flashoffset = 0;
mfebc(PB0CR, pbcr); - switch (gd->bd->bi_flashsize) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - case 32 << 20: - size_val = 5; - break; - case 64 << 20: - size_val = 6; - break; - case 128 << 20: - size_val = 7; - break; - } + size_val = ffs(gd->bd->bi_flashsize) - 21; pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); mtebc(PB0CR, pbcr);
@@ -193,53 +225,92 @@ int misc_init_r(void) flash_get_size(gd->bd->bi_flashstart, 0);
/* Monitor protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, - -CONFIG_SYS_MONITOR_LEN, - 0xffffffff, - &flash_info[1]); + flash_protect(FLAG_PROTECT_SET, -CONFIG_SYS_MONITOR_LEN, 0xffffffff, + &flash_info[cfi_flash_num_flash_banks - 1]);
/* Env protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR_REDUND, - CONFIG_ENV_ADDR_REDUND + 2*CONFIG_ENV_SECT_SIZE - 1, - &flash_info[1]); + flash_protect(FLAG_PROTECT_SET, CONFIG_ENV_ADDR_REDUND, + CONFIG_ENV_ADDR_REDUND + 2 * CONFIG_ENV_SECT_SIZE - 1, + &flash_info[cfi_flash_num_flash_banks - 1]);
/* * USB suff... */ + + /* Reset USB */ + /* Reset of USB2PHY0 must be active at least 10 us */ + mtsdr(SDR0_SRST0, SDR0_SRST0_USB2H | SDR0_SRST0_USB2D); + udelay(2000); + + mtsdr(SDR0_SRST1, SDR0_SRST1_USB20PHY | SDR0_SRST1_USB2HUTMI | + SDR0_SRST1_USB2HPHY | SDR0_SRST1_OPBA2 | + SDR0_SRST1_PLB42OPB1 | SDR0_SRST1_OPB2PLB40); + udelay(2000); + + /* Errata CHIP_6 */ + + /* 1. Set internal PHY configuration */ /* SDR Setting */ mfsdr(SDR0_PFC1, sdr0_pfc1); mfsdr(SDR0_USB0, usb2d0cr); mfsdr(SDR0_USB2PHY0CR, usb2phy0cr); mfsdr(SDR0_USB2H0CR, usb2h0cr);
- usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ - usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_WDINT_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; /*1*/ - usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DVBUS_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PURDIS; /*0*/ - usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_DWNSTR_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; /*1*/ - usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_UTMICN_MASK; - usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; /*1*/ - - /* An 8-bit/60MHz interface is the only possible alternative - when connecting the Device to the PHY */ - usb2h0cr = usb2h0cr &~SDR0_USB2H0CR_WDINT_MASK; - usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ; /*1*/ + usb2phy0cr = usb2phy0cr & ~SDR0_USB2PHY0CR_XOCLK_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_XOCLK_EXTERNAL; /*0*/ + usb2phy0cr = usb2phy0cr & ~SDR0_USB2PHY0CR_WDINT_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ; /*1*/ + usb2phy0cr = usb2phy0cr & ~SDR0_USB2PHY0CR_DVBUS_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DVBUS_PUREN; /*1*/ + usb2phy0cr = usb2phy0cr & ~SDR0_USB2PHY0CR_DWNSTR_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_DWNSTR_HOST; /*1*/ + usb2phy0cr = usb2phy0cr & ~SDR0_USB2PHY0CR_UTMICN_MASK; + usb2phy0cr = usb2phy0cr | SDR0_USB2PHY0CR_UTMICN_HOST; /*1*/ + + /* + * An 8-bit/60MHz interface is the only possible alternative + * when connecting the Device to the PHY + */ + usb2h0cr = usb2h0cr & ~SDR0_USB2H0CR_WDINT_MASK; + usb2h0cr = usb2h0cr | SDR0_USB2H0CR_WDINT_16BIT_30MHZ; /*1*/
mtsdr(SDR0_PFC1, sdr0_pfc1); mtsdr(SDR0_USB0, usb2d0cr); mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); mtsdr(SDR0_USB2H0CR, usb2h0cr);
+ /* 2. De-assert internal PHY reset */ + mfsdr(SDR0_SRST1, sdr0_srst); + sdr0_srst = sdr0_srst & ~SDR0_SRST1_USB20PHY; + mtsdr(SDR0_SRST1, sdr0_srst); + + /* 3. Wait for more than 1 ms */ + udelay(2000); + + /* 4. De-assert USB 2.0 Host main reset */ + mfsdr(SDR0_SRST0, sdr0_srst); + sdr0_srst = sdr0_srst &~ SDR0_SRST0_USB2H; + mtsdr(SDR0_SRST0, sdr0_srst); + udelay(1000); + + /* 5. De-assert reset of OPB2 cores */ + mfsdr(SDR0_SRST1, sdr0_srst); + sdr0_srst = sdr0_srst &~ SDR0_SRST1_PLB42OPB1; + sdr0_srst = sdr0_srst &~ SDR0_SRST1_OPB2PLB40; + sdr0_srst = sdr0_srst &~ SDR0_SRST1_OPBA2; + mtsdr(SDR0_SRST1, sdr0_srst); + udelay(1000); + + /* 6. Set EHCI Configure FLAG */ + + /* 7. Reassert internal PHY reset: */ + mtsdr(SDR0_SRST1, SDR0_SRST1_USB20PHY); + udelay(1000); + /* * Clear resets */ - udelay (1000); mtsdr(SDR0_SRST1, 0x00000000); - udelay (1000); mtsdr(SDR0_SRST0, 0x00000000);
printf("USB: Host(int phy) Device(ext phy)\n"); @@ -264,7 +335,7 @@ int checkboard(void) { char *s = getenv("serial#");
- printf("Board: lwmon5"); + puts("Board: lwmon5");
if (s != NULL) { puts(", serial# "); @@ -331,34 +402,33 @@ U_BOOT_CMD(
extern GraphicDevice mb862xx;
-static const gdc_regs init_regs [] = -{ - {0x0100, 0x00000f00}, - {0x0020, 0x801401df}, - {0x0024, 0x00000000}, - {0x0028, 0x00000000}, - {0x002c, 0x00000000}, - {0x0110, 0x00000000}, - {0x0114, 0x00000000}, - {0x0118, 0x01df0280}, - {0x0004, 0x031f0000}, - {0x0008, 0x027f027f}, - {0x000c, 0x015f028f}, - {0x0010, 0x020c0000}, - {0x0014, 0x01df01ea}, - {0x0018, 0x00000000}, - {0x001c, 0x01e00280}, - {0x0100, 0x80010f00}, - {0x0, 0x0} +static const gdc_regs init_regs [] = { + { 0x0100, 0x00000f00 }, + { 0x0020, 0x801401df }, + { 0x0024, 0x00000000 }, + { 0x0028, 0x00000000 }, + { 0x002c, 0x00000000 }, + { 0x0110, 0x00000000 }, + { 0x0114, 0x00000000 }, + { 0x0118, 0x01df0280 }, + { 0x0004, 0x031f0000 }, + { 0x0008, 0x027f027f }, + { 0x000c, 0x015f028f }, + { 0x0010, 0x020c0000 }, + { 0x0014, 0x01df01ea }, + { 0x0018, 0x00000000 }, + { 0x001c, 0x01e00280 }, + { 0x0100, 0x80010f00 }, + { 0x0, 0x0 } };
-const gdc_regs *board_get_regs (void) +const gdc_regs *board_get_regs(void) { return init_regs; }
/* Returns Lime base address */ -unsigned int board_video_init (void) +unsigned int board_video_init(void) { /* * Reset Lime controller @@ -375,7 +445,7 @@ unsigned int board_video_init (void) return CONFIG_SYS_LIME_BASE_0; }
-#define DEFAULT_BRIGHTNESS 0x64 +#define DEFAULT_BRIGHTNESS 0x64
static void board_backlight_brightness(int brightness) { @@ -390,7 +460,7 @@ static void board_backlight_brightness(int brightness) } }
-void board_backlight_switch (int flag) +void board_backlight_switch(int flag) { char * param; int rc; @@ -410,15 +480,14 @@ void board_backlight_switch (int flag) /* * Return text to be printed besides the logo. */ -void video_get_info_str (int line_number, char *info) +void video_get_info_str(int line_number, char *info) { - if (line_number == 1) { - strcpy (info, " Board: Lwmon5 (Liebherr Elektronik GmbH)"); - } else { + if (line_number == 1) + strcpy(info, " Board: Lwmon5 (Liebherr Elektronik GmbH)"); + else info [0] = '\0'; - } } -#endif +#endif /* CONFIG_CONSOLE_EXTRA_INFO */ #endif /* CONFIG_VIDEO */
void board_reset(void) diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 72e02f8..2349583 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007-2008 + * (C) Copyright 2007-2010 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * This program is free software; you can redistribute it and/or @@ -18,58 +18,63 @@ * MA 02111-1307 USA */
-/************************************************************************ +/* * lwmon5.h - configuration for lwmon5 board - ***********************************************************************/ + */ #ifndef __CONFIG_H #define __CONFIG_H
-/*----------------------------------------------------------------------- +/* + * Liebherr extra version info + */ +#define CONFIG_IDENT_STRING " - v2.0" + +/* * High Level Configuration Options - *----------------------------------------------------------------------*/ + */ #define CONFIG_LWMON5 1 /* Board is lwmon5 */ #define CONFIG_440EPX 1 /* Specific PPC440EPx */ #define CONFIG_440 1 /* ... PPC440 family */ #define CONFIG_4xx 1 /* ... PPC4xx family */ #define CONFIG_SYS_CLK_FREQ 33300000 /* external freq to pll */
-#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ -#define CONFIG_BOARD_POSTCLK_INIT 1 /* Call board_postclk_init */ -#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ -#define CONFIG_BOARD_RESET 1 /* Call board_reset */ +#define CONFIG_BOARD_EARLY_INIT_F /* Call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_R /* Call board_early_init_r */ +#define CONFIG_BOARD_POSTCLK_INIT /* Call board_postclk_init */ +#define CONFIG_MISC_INIT_R /* Call misc_init_r */ +#define CONFIG_BOARD_RESET /* Call board_reset */
-/*----------------------------------------------------------------------- +/* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserve 512 kB for malloc() */ + */ +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* Start of U-Boot */ +#define CONFIG_SYS_MONITOR_LEN (0xFFFFFFFF - CONFIG_SYS_MONITOR_BASE + 1) +#define CONFIG_SYS_MALLOC_LEN (1 << 20) /* Reserved for malloc */
#define CONFIG_SYS_BOOT_BASE_ADDR 0xf0000000 #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* _must_ be 0 */ #define CONFIG_SYS_FLASH_BASE 0xf8000000 /* start of FLASH */ -#define CONFIG_SYS_MONITOR_BASE TEXT_BASE -#define CONFIG_SYS_LIME_BASE_0 0xc0000000 -#define CONFIG_SYS_LIME_BASE_1 0xc1000000 -#define CONFIG_SYS_LIME_BASE_2 0xc2000000 -#define CONFIG_SYS_LIME_BASE_3 0xc3000000 -#define CONFIG_SYS_FPGA_BASE_0 0xc4000000 -#define CONFIG_SYS_FPGA_BASE_1 0xc4200000 +#define CONFIG_SYS_LIME_BASE_0 0xc0000000 +#define CONFIG_SYS_LIME_BASE_1 0xc1000000 +#define CONFIG_SYS_LIME_BASE_2 0xc2000000 +#define CONFIG_SYS_LIME_BASE_3 0xc3000000 +#define CONFIG_SYS_FPGA_BASE_0 0xc4000000 +#define CONFIG_SYS_FPGA_BASE_1 0xc4200000 #define CONFIG_SYS_OCM_BASE 0xe0010000 /* ocm */ #define CONFIG_SYS_PCI_BASE 0xe0000000 /* Internal PCI regs */ #define CONFIG_SYS_PCI_MEMBASE 0x80000000 /* mapped pci memory */ -#define CONFIG_SYS_PCI_MEMBASE1 CONFIG_SYS_PCI_MEMBASE + 0x10000000 -#define CONFIG_SYS_PCI_MEMBASE2 CONFIG_SYS_PCI_MEMBASE1 + 0x10000000 -#define CONFIG_SYS_PCI_MEMBASE3 CONFIG_SYS_PCI_MEMBASE2 + 0x10000000 +#define CONFIG_SYS_PCI_MEMBASE1 (CONFIG_SYS_PCI_MEMBASE + 0x10000000) +#define CONFIG_SYS_PCI_MEMBASE2 (CONFIG_SYS_PCI_MEMBASE1 + 0x10000000) +#define CONFIG_SYS_PCI_MEMBASE3 (CONFIG_SYS_PCI_MEMBASE2 + 0x10000000)
#define CONFIG_SYS_USB2D0_BASE 0xe0000100 #define CONFIG_SYS_USB_DEVICE 0xe0000000 #define CONFIG_SYS_USB_HOST 0xe0000400
-/*----------------------------------------------------------------------- - * Initial RAM & stack pointer - *----------------------------------------------------------------------*/ /* + * Initial RAM & stack pointer + * * On LWMON5 we use D-cache as init-ram and stack pointer. We also move * the POST_WORD from OCM to a 440EPx register that preserves it's * content during reset (GPT0_COMP6). This way we reserve the OCM (16k) @@ -77,18 +82,18 @@ */ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_END (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET +/* unused GPT0 COMP reg */ #define CONFIG_SYS_POST_WORD_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_COMP6) - /* unused GPT0 COMP reg */ -#define CONFIG_SYS_MEM_TOP_HIDE (4 << 10) /* don't use last 4kbytes */ - /* 440EPx errata CHIP 11 */ #define CONFIG_SYS_OCM_SIZE (16 << 10) +/* 440EPx errata CHIP 11: don't use last 4kbytes */ +#define CONFIG_SYS_MEM_TOP_HIDE (4 << 10)
/* Additional registers for watchdog timer post test */ - #define CONFIG_SYS_WATCHDOG_TIME_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_MASK2) #define CONFIG_SYS_WATCHDOG_FLAGS_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_MASK1) #define CONFIG_SYS_DSPIC_TEST_ADDR CONFIG_SYS_WATCHDOG_FLAGS_ADDR @@ -100,9 +105,9 @@ #define CONFIG_SYS_OCM_STATUS_FAIL 0x0000A300 #define CONFIG_SYS_OCM_STATUS_MASK 0x0000FF00
-/*----------------------------------------------------------------------- +/* * Serial Port - *----------------------------------------------------------------------*/ + */ #define CONFIG_CONS_INDEX 2 /* Use UART1 */ #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL @@ -110,77 +115,79 @@ #define CONFIG_SYS_NS16550_CLK get_serial_clock() #undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external clock provided */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SERIAL_MULTI 1 +#define CONFIG_SERIAL_MULTI
#define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
-/*----------------------------------------------------------------------- +/* * Environment - *----------------------------------------------------------------------*/ -#define CONFIG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ + */ +#define CONFIG_ENV_IS_IN_FLASH /* use FLASH for environment vars */
-/*----------------------------------------------------------------------- +/* * FLASH related - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ + */ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ #define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */
#define CONFIG_SYS_FLASH0 0xFC000000 #define CONFIG_SYS_FLASH1 0xF8000000 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH1, CONFIG_SYS_FLASH0 }
-#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 2 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */
#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
-#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* use hardware flash protection */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* use buffered writes (20x faster) */ +#define CONFIG_SYS_FLASH_PROTECTION /* use hardware flash protection */
#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ -#define CONFIG_SYS_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ +#define CONFIG_SYS_FLASH_QUIET_TEST /* don't warn upon unknown flash */
#define CONFIG_ENV_SECT_SIZE 0x40000 /* size of one complete sector */ -#define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN) - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
-/*----------------------------------------------------------------------- +/* * DDR SDRAM - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MBYTES_SDRAM (256) /* 256MB */ + */ +#define CONFIG_SYS_MBYTES_SDRAM 256 #define CONFIG_SYS_DDR_CACHED_ADDR 0x40000000 /* setup 2nd TLB cached here */ -#define CONFIG_DDR_DATA_EYE 1 /* use DDR2 optimization */ -#define CONFIG_DDR_ECC 1 /* enable ECC */ -#define CONFIG_SYS_POST_ECC_ON CONFIG_SYS_POST_ECC +#define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ +#define CONFIG_DDR_ECC /* enable ECC */
/* POST support */ -#define CONFIG_POST (CONFIG_SYS_POST_CACHE | \ - CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_ECC_ON | \ - CONFIG_SYS_POST_ETHER | \ - CONFIG_SYS_POST_FPU | \ - CONFIG_SYS_POST_I2C | \ - CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_OCM | \ - CONFIG_SYS_POST_RTC | \ - CONFIG_SYS_POST_SPR | \ - CONFIG_SYS_POST_UART | \ - CONFIG_SYS_POST_SYSMON | \ - CONFIG_SYS_POST_WATCHDOG | \ - CONFIG_SYS_POST_DSP | \ - CONFIG_SYS_POST_BSPEC1 | \ - CONFIG_SYS_POST_BSPEC2 | \ - CONFIG_SYS_POST_BSPEC3 | \ - CONFIG_SYS_POST_BSPEC4 | \ +#define CONFIG_POST (CONFIG_SYS_POST_CACHE | \ + CONFIG_SYS_POST_CPU | \ + CONFIG_SYS_POST_ECC | \ + CONFIG_SYS_POST_ETHER | \ + CONFIG_SYS_POST_FPU | \ + CONFIG_SYS_POST_I2C | \ + CONFIG_SYS_POST_MEMORY | \ + CONFIG_SYS_POST_OCM | \ + CONFIG_SYS_POST_RTC | \ + CONFIG_SYS_POST_SPR | \ + CONFIG_SYS_POST_UART | \ + CONFIG_SYS_POST_SYSMON | \ + CONFIG_SYS_POST_WATCHDOG | \ + CONFIG_SYS_POST_DSP | \ + CONFIG_SYS_POST_BSPEC1 | \ + CONFIG_SYS_POST_BSPEC2 | \ + CONFIG_SYS_POST_BSPEC3 | \ + CONFIG_SYS_POST_BSPEC4 | \ CONFIG_SYS_POST_BSPEC5)
-#define CONFIG_POST_WATCHDOG {\ +/* Define here the base-addresses of the UARTs to test in POST */ +#define CONFIG_SYS_POST_UART_TABLE { UART0_BASE, UART1_BASE } + +#define CONFIG_POST_WATCHDOG { \ "Watchdog timer test", \ "watchdog", \ "This test checks the watchdog timer.", \ @@ -188,10 +195,10 @@ &lwmon5_watchdog_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_WATCHDOG \ + CONFIG_SYS_POST_WATCHDOG \ }
-#define CONFIG_POST_BSPEC1 {\ +#define CONFIG_POST_BSPEC1 { \ "dsPIC init test", \ "dspic_init", \ "This test returns result of dsPIC READY test run earlier.", \ @@ -199,10 +206,10 @@ &dspic_init_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_BSPEC1 \ + CONFIG_SYS_POST_BSPEC1 \ }
-#define CONFIG_POST_BSPEC2 {\ +#define CONFIG_POST_BSPEC2 { \ "dsPIC test", \ "dspic", \ "This test gets result of dsPIC POST and dsPIC version.", \ @@ -210,32 +217,32 @@ &dspic_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_BSPEC2 \ + CONFIG_SYS_POST_BSPEC2 \ }
-#define CONFIG_POST_BSPEC3 {\ +#define CONFIG_POST_BSPEC3 { \ "FPGA test", \ "fpga", \ "This test checks FPGA registers and memory.", \ - POST_RAM | POST_ALWAYS, \ + POST_RAM | POST_ALWAYS | POST_MANUAL, \ &fpga_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_BSPEC3 \ + CONFIG_SYS_POST_BSPEC3 \ }
-#define CONFIG_POST_BSPEC4 {\ +#define CONFIG_POST_BSPEC4 { \ "GDC test", \ "gdc", \ "This test checks GDC registers and memory.", \ - POST_RAM | POST_ALWAYS, \ + POST_RAM | POST_ALWAYS | POST_MANUAL,\ &gdc_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_BSPEC4 \ + CONFIG_SYS_POST_BSPEC4 \ }
-#define CONFIG_POST_BSPEC5 {\ +#define CONFIG_POST_BSPEC5 { \ "SYSMON1 test", \ "sysmon1", \ "This test checks GPIO_62_EPX pin indicating power failure.", \ @@ -243,7 +250,7 @@ &sysmon1_post_test, \ NULL, \ NULL, \ - CONFIG_SYS_POST_BSPEC5 \ + CONFIG_SYS_POST_BSPEC5 \ }
#define CONFIG_SYS_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */ @@ -253,34 +260,53 @@ #define CONFIG_ALT_LB_ADDR (CONFIG_SYS_OCM_BASE) #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */
-/*----------------------------------------------------------------------- +/* * I2C - *----------------------------------------------------------------------*/ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ + */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_PPC4XX_I2C /* use PPC4xx driver */ #define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed and slave address */ #define CONFIG_SYS_I2C_SLAVE 0x7F
-#define CONFIG_SYS_I2C_EEPROM_ADDR 0x53 /* EEPROM AT24C128 */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* RTC */ +#define CONFIG_SYS_I2C_EEPROM_CPU_ADDR 0x52 /* EEPROM (CPU Modul) */ +#define CONFIG_SYS_I2C_EEPROM_MB_ADDR 0x53 /* EEPROM AT24C128 (MainBoard) */ +#define CONFIG_SYS_I2C_DSPIC_ADDR 0x54 /* dsPIC */ +#define CONFIG_SYS_I2C_DSPIC_2_ADDR 0x55 /* dsPIC */ +#define CONFIG_SYS_I2C_DSPIC_KEYB_ADDR 0x56 /* dsPIC */ +#define CONFIG_SYS_I2C_DSPIC_IO_ADDR 0x57 /* dsPIC */ + #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* Bytes of address */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 /* The Atmel AT24C128 has */ /* 64 byte page write mode using*/ /* last 6 bits of the address */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE + +#define CONFIG_RTC_PCF8563 /* enable Philips PCF8563 RTC */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Philips PCF8563 RTC address */ +#define CONFIG_SYS_I2C_KEYBD_ADDR 0x56 /* PIC LWE keyboard */ +#define CONFIG_SYS_I2C_DSPIC_IO_ADDR 0x57 /* PIC I/O addr */ + +#define I2C_ADDR_LIST { \ + CONFIG_SYS_I2C_RTC_ADDR, \ + CONFIG_SYS_I2C_EEPROM_CPU_ADDR, \ + CONFIG_SYS_I2C_EEPROM_MB_ADDR, \ + CONFIG_SYS_I2C_DSPIC_ADDR, \ + CONFIG_SYS_I2C_DSPIC_2_ADDR, \ + CONFIG_SYS_I2C_DSPIC_KEYB_ADDR, \ + CONFIG_SYS_I2C_DSPIC_IO_ADDR }
-#define CONFIG_RTC_PCF8563 1 /* enable Philips PCF8563 RTC */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Philips PCF8563 RTC address */ -#define CONFIG_SYS_I2C_KEYBD_ADDR 0x56 /* PIC LWE keyboard */ -#define CONFIG_SYS_I2C_DSPIC_IO_ADDR 0x57 /* PIC I/O addr */ +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +/* Update size in "reg" property of NOR FLASH device tree nodes */ +#define CONFIG_FDT_FIXUP_NOR_FLASH_SIZE
#define CONFIG_POST_KEY_MAGIC "3C+3E" /* press F3 + F5 keys to force POST */ -#if 0 -#define CONFIG_AUTOBOOT_KEYED /* Enable "password" protection */ -#define CONFIG_AUTOBOOT_PROMPT \ - "\nEnter password - autoboot in %d sec...\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR " " /* "password" */ -#endif
#define CONFIG_PREBOOT "setenv bootdelay 15"
@@ -314,15 +340,11 @@ "cp.b 200000 FFF80000 80000\0" \ "upd=run load update\0" \ "lwe_env=tftp 200000 /tftpboot.dev/lwmon5/env_uboot.bin;" \ - "source 200000\0" \ + "autoscr 200000\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
-#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ @@ -410,9 +432,9 @@ #define CONFIG_CMD_USB #endif
-/*----------------------------------------------------------------------- +/* * Miscellaneous configurable options - *----------------------------------------------------------------------*/ + */ #define CONFIG_SUPPORT_VFAT
#define CONFIG_SYS_LONGHELP /* undef to save memory */ @@ -445,9 +467,9 @@ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-/*----------------------------------------------------------------------- +/* * PCI stuff - *----------------------------------------------------------------------*/ + */ /* General PCI */ #define CONFIG_PCI /* include pci support */ #undef CONFIG_PCI_PNP /* do (not) pci plug-and-play */ @@ -461,29 +483,32 @@ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x10e8 /* AMCC */ #define CONFIG_SYS_PCI_SUBSYS_ID 0xcafe /* Whatever */
+#ifndef DEBUG #define CONFIG_HW_WATCHDOG 1 /* Use external HW-Watchdog */ +#endif #define CONFIG_WD_PERIOD 40000 /* in usec */ #define CONFIG_WD_MAX_RATE 66600 /* in ticks */
/* * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the 40x Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */
-/*----------------------------------------------------------------------- +/* * External Bus Controller (EBC) Setup - *----------------------------------------------------------------------*/ + */ #define CONFIG_SYS_FLASH CONFIG_SYS_FLASH_BASE
/* Memory Bank 0 (NOR-FLASH) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x03050200 +#define CONFIG_SYS_EBC_PB0AP 0x03000280 #define CONFIG_SYS_EBC_PB0CR (CONFIG_SYS_FLASH | 0xfc000)
/* Memory Bank 1 (Lime) initialization */ #define CONFIG_SYS_EBC_PB1AP 0x01004380 -#define CONFIG_SYS_EBC_PB1CR (CONFIG_SYS_LIME_BASE_0 | 0xdc000) +#define CONFIG_SYS_EBC_PB1CR (CONFIG_SYS_LIME_BASE_0 | 0xbc000)
/* Memory Bank 2 (FPGA) initialization */ #define CONFIG_SYS_EBC_PB2AP 0x01004400 @@ -495,19 +520,27 @@
#define CONFIG_SYS_EBC_CFG 0xb8400000
-/*----------------------------------------------------------------------- +/* * Graphics (Fujitsu Lime) - *----------------------------------------------------------------------*/ + */ +/* SDRAM Clock frequency adjustment register */ +#define CONFIG_SYS_LIME_SDRAM_CLOCK 0xC1FC0038 +#if 1 /* 133MHz is not tested enough, use 100MHz for now */ /* Lime Clock frequency is to set 100MHz */ #define CONFIG_SYS_LIME_CLOCK_100MHZ 0x00000 -#if 0 +#else /* Lime Clock frequency for 133MHz */ #define CONFIG_SYS_LIME_CLOCK_133MHZ 0x10000 #endif
-/* SDRAM parameter value; was 0x414FB7F2, caused several vertical bars - and pixel flare on display when 133MHz was configured. According to - SDRAM chip datasheet CAS Latency is 3 for 133MHz and -75 Speed Grade */ +/* SDRAM Parameter register */ +#define CONFIG_SYS_LIME_MMR 0xC1FCFFFC +/* + * SDRAM parameter value; was 0x414FB7F2, caused several vertical bars + * and pixel flare on display when 133MHz was configured. According to + * SDRAM chip datasheet CAS Latency is 3 for 133MHz and -75 Speed + * Grade + */ #ifdef CONFIG_SYS_LIME_CLOCK_133MHZ #define CONFIG_SYS_MB862xx_MMR 0x414FB7F3 #define CONFIG_SYS_MB862xx_CCF CONFIG_SYS_LIME_CLOCK_133MHZ @@ -516,13 +549,15 @@ #define CONFIG_SYS_MB862xx_CCF CONFIG_SYS_LIME_CLOCK_100MHZ #endif
-/*----------------------------------------------------------------------- +/* * GPIO Setup - *----------------------------------------------------------------------*/ + */ #define CONFIG_SYS_GPIO_PHY1_RST 12 #define CONFIG_SYS_GPIO_FLASH_WP 14 #define CONFIG_SYS_GPIO_PHY0_RST 22 #define CONFIG_SYS_GPIO_DSPIC_READY 51 +#define CONFIG_SYS_GPIO_CAN_ENABLE 53 +#define CONFIG_SYS_GPIO_LSB_ENABLE 54 #define CONFIG_SYS_GPIO_EEPROM_EXT_WP 55 #define CONFIG_SYS_GPIO_HIGHSIDE 56 #define CONFIG_SYS_GPIO_EEPROM_INT_WP 57 @@ -532,7 +567,7 @@ #define CONFIG_SYS_GPIO_SYSMON_STATUS 62 #define CONFIG_SYS_GPIO_WATCHDOG 63
-/*----------------------------------------------------------------------- +/* * PPC440 GPIO Configuration */ #define CONFIG_SYS_4xx_GPIO_TABLE { /* Out GPIO Alternate1 Alternate2 Alternate3 */ \ diff --git a/post/board/lwmon5/dsp.c b/post/board/lwmon5/dsp.c index 0e6d908..913cd97 100644 --- a/post/board/lwmon5/dsp.c +++ b/post/board/lwmon5/dsp.c @@ -33,20 +33,37 @@
-#define DSP_STATUS_REG 0xC4000008 +#define DSP_STATUS_REG 0xC4000008 +#define FPGA_STATUS_REG 0xC400000C
int dsp_post_test(int flags) { + uint old_value; uint read_value; int ret;
+ /* momorize fpga status */ + old_value = in_be32((void *)FPGA_STATUS_REG); + /* enable outputs */ + out_be32((void *)FPGA_STATUS_REG, 0x30); + + /* generate sync signal */ + out_be32((void *)DSP_STATUS_REG, 0x300); + udelay(5); + out_be32((void *)DSP_STATUS_REG, 0); + udelay(500); + + /* read status */ ret = 0; read_value = in_be32((void *)DSP_STATUS_REG) & 0x3; - if (read_value != 0x3) { + if (read_value != 0x03) { post_log("\nDSP status read %08X\n", read_value); ret = 1; }
+ /* restore fpga status */ + out_be32((void *)FPGA_STATUS_REG, old_value); + return ret; }
diff --git a/post/board/lwmon5/dspic.c b/post/board/lwmon5/dspic.c index ff2ed05..8616739 100644 --- a/post/board/lwmon5/dspic.c +++ b/post/board/lwmon5/dspic.c @@ -38,14 +38,16 @@ DECLARE_GLOBAL_DATA_PTR;
#define DSPIC_POST_ERROR_REG 0x800 #define DSPIC_SYS_ERROR_REG 0x802 -#define DSPIC_VERSION_REG 0x804 +#define DSPIC_SYS_VERSION_REG 0x804 +#define DSPIC_FW_VERSION_REG 0x808
/* Verify that dsPIC ready test done early at hw init passed ok */ int dspic_init_post_test(int flags) { - if (in_be32((void *)CONFIG_SYS_DSPIC_TEST_ADDR) & CONFIG_SYS_DSPIC_TEST_MASK) { + if (in_be32((void *)CONFIG_SYS_DSPIC_TEST_ADDR) & + CONFIG_SYS_DSPIC_TEST_MASK) { post_log("dsPIC init test failed\n"); return 1; } @@ -57,46 +59,60 @@ int dspic_init_post_test(int flags)
#if CONFIG_POST & CONFIG_SYS_POST_BSPEC2 /* Read a register from the dsPIC. */ -int dspic_read(ushort reg) +int dspic_read(ushort reg, ushort *data) { - uchar buf[2]; + uchar buf[sizeof(*data)]; + int rval;
if (i2c_read(CONFIG_SYS_I2C_DSPIC_IO_ADDR, reg, 2, buf, 2)) return -1; + rval = i2c_read(CONFIG_SYS_I2C_DSPIC_IO_ADDR, reg, sizeof(reg), + buf, sizeof(*data)); + *data = (buf[0] << 8) | buf[1];
- return (uint)((buf[0] << 8) | buf[1]); + return rval; }
/* Verify error codes regs, display version */ int dspic_post_test(int flags) { - int data; + ushort data; int ret = 0;
post_log("\n"); - data = dspic_read(DSPIC_VERSION_REG); - if (data == -1) { - post_log("dsPIC : failed read version\n"); + + /* read dspic FW-Version */ + if (dspic_read(DSPIC_FW_VERSION_REG, &data)) { + post_log("dsPIC: failed read FW-Version\n"); + ret = 1; + } else { + post_log("dsPIC FW-Version: %u.%u\n", + (data >> 8) & 0xFF, data & 0xFF); + } + + /* read dspic SYS-Version */ + if (dspic_read(DSPIC_SYS_VERSION_REG, &data)) { + post_log("dsPIC: failed read version\n"); ret = 1; } else { - post_log("dsPIC version: %u.%u\n", - (data >> 8) & 0xFF, data & 0xFF); + post_log("dsPIC SYS-Version: %u.%u\n", + (data >> 8) & 0xFF, data & 0xFF); }
- data = dspic_read(DSPIC_POST_ERROR_REG); - if (data != 0) ret = 1; - if (data == -1) { - post_log("dsPIC : failed read POST code\n"); + /* read dspic POST error code */ + if (dspic_read(DSPIC_POST_ERROR_REG, &data)) { + post_log("dsPIC: failed read POST code\n"); + ret = 1; } else { - post_log("dsPIC POST code 0x%04X\n", data); + post_log("dsPIC POST-ERROR code: 0x%04X\n", data); }
- data = dspic_read(DSPIC_SYS_ERROR_REG); - if (data == -1) { - post_log("dsPIC : failed read system error\n"); + /* read dspic SYS error code */ + if ((data = dspic_read(DSPIC_SYS_ERROR_REG, &data))) { + post_log("dsPIC: failed read system error\n"); ret = 1; } else { - post_log("dsPIC SYS-ERROR code: 0x%04X\n", data); + post_log("dsPIC SYS-ERROR code: 0x%04X\n", data); }
return ret; diff --git a/post/board/lwmon5/fpga.c b/post/board/lwmon5/fpga.c index 2b84290..3067548 100644 --- a/post/board/lwmon5/fpga.c +++ b/post/board/lwmon5/fpga.c @@ -28,7 +28,7 @@ */
#include <post.h> - +#include <watchdog.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; @@ -38,18 +38,28 @@ DECLARE_GLOBAL_DATA_PTR; #define FPGA_RAM_START 0xC4200000 #define FPGA_RAM_END 0xC4203FFF #define FPGA_STAT 0xC400000C +#define FPGA_BUFFER 0x00800000 +#define FPGA_RAM_SIZE (FPGA_RAM_END - FPGA_RAM_START + 1)
#if CONFIG_POST & CONFIG_SYS_POST_BSPEC3
-/* Testpattern for fpga memorytest */ -static uint pattern[] = { +const static unsigned long pattern[] = { + 0xffffffff, + 0xaaaaaaaa, + 0xcccccccc, + 0xf0f0f0f0, + 0xff00ff00, + 0xffff0000, + 0x0000ffff, + 0x00ff00ff, + 0x0f0f0f0f, + 0x33333333, 0x55555555, - 0xAAAAAAAA, - 0xAA5555AA, - 0x55AAAA55, - 0x0 + 0x00000000, };
+const static unsigned long otherpattern = 0x01234567; + static int one_scratch_test(uint value) { uint read_value; @@ -62,51 +72,226 @@ static int one_scratch_test(uint value) read_value = in_be32((void *)FPGA_SCRATCH_REG); if (read_value != value) { post_log("FPGA SCRATCH test failed write %08X, read %08X\n", - value, read_value); - ret = 1; + value, read_value); + ret = -1; + } + + return ret; +} + +static int fpga_post_test1(ulong *start, ulong size, ulong val) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = val; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != val) { + post_log("FPGA Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, val, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + return ret; +} + +static int fpga_post_test2(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = 1 << (i % 32); + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != 1 << (i % 32)) { + post_log("FPGA Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, 1 << (i % 32), readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +static int fpga_post_test3(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = i; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != i) { + post_log("FPGA Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, i, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +static int fpga_post_test4(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = ~i; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != ~i) { + post_log("FPGA Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, ~i, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); }
return ret; }
/* FPGA Memory-pattern-test */ -static int fpga_mem_test(void * address) +static int fpga_mem_test(void) { - int ret = 1; - uint read_value; - uint old_value; - uint i = 0; - /* save content */ - old_value = in_be32(address); - - while (pattern[i] != 0) { - out_be32(address, pattern[i]); - /* read other location (protect against data lines capacity) */ - ret = in_be16((void *)FPGA_VERSION_REG); - /* verify test pattern */ - read_value = in_be32(address); - - if (read_value != pattern[i]) { - post_log("FPGA Memory test failed."); - post_log(" write %08X, read %08X at address %08X\n", - pattern[i], read_value, address); + int ret = 0; + ulong* start = (ulong *)FPGA_RAM_START; + ulong size = FPGA_RAM_SIZE; + + if (ret == 0) + ret = fpga_post_test1(start, size, 0x00000000); + + if (ret == 0) + ret = fpga_post_test1(start, size, 0xffffffff); + + if (ret == 0) + ret = fpga_post_test1(start, size, 0x55555555); + + if (ret == 0) + ret = fpga_post_test1(start, size, 0xaaaaaaaa); + + WATCHDOG_RESET(); + + if (ret == 0) + ret = fpga_post_test2(start, size); + + if (ret == 0) + ret = fpga_post_test3(start, size); + + if (ret == 0) + ret = fpga_post_test4(start, size); + + return ret; +} + + + +/* Verify FPGA addresslines */ +static int fpga_post_addrline(ulong *address, ulong *base, ulong size) +{ + unsigned long *target; + unsigned long *end; + unsigned long readback; + unsigned long xor; + int ret = 0; + + end = (ulong *)((ulong)base + size); + xor = 0; + + for (xor = sizeof(ulong); xor > 0; xor <<= 1) { + target = (ulong*)((ulong)address ^ xor); + if ((target >= base) && (target < end)) { + *address = ~*target; + readback = *target; + + if (readback == *address) { + post_log("Memory (address line) error at %08x" + "XOR value %08x !\n", + address, target, xor); + ret = -1; + break; + } + } + } + + return ret; +} + +/* Verify FPGA addresslines */ +static int fpga_post_dataline(ulong *address) +{ + unsigned long temp32 = 0; + int i = 0; + int ret = 0; + + for (i = 0; i < ARRAY_SIZE(pattern); i++) { + *address = pattern[i]; + /* + * Put a different pattern on the data lines: otherwise they + * may float long enough to read back what we wrote. + */ + *(address + 1) = otherpattern; + temp32 = *address; + + if (temp32 != pattern[i]){ + post_log("Memory (date line) error at %08x, " + "wrote %08x, read %08x !\n", + address, pattern[i], temp32); ret = 1; - goto out; } - i++; }
- ret = 0; -out: - out_be32(address, old_value); return ret; } + /* Verify FPGA, get version & memory size */ int fpga_post_test(int flags) { - uint address; uint old_value; - ushort version; + uint version; uint read_value; int ret = 0;
@@ -120,24 +305,57 @@ int fpga_post_test(int flags)
out_be32((void *)FPGA_SCRATCH_REG, old_value);
- version = in_be16((void *)FPGA_VERSION_REG); - post_log("FPGA : version %u.%u\n", - (version >> 8) & 0xFF, version & 0xFF); + version = in_be32((void *)FPGA_VERSION_REG); + post_log("FPGA version %u.%u\n", + (version >> 8) & 0xFF, version & 0xFF);
/* Enable write to FPGA RAM */ out_be32((void *)FPGA_STAT, in_be32((void *)FPGA_STAT) | 0x1000);
- read_value = get_ram_size((void *)CONFIG_SYS_FPGA_BASE_1, 0x4000); - post_log("FPGA RAM size: %d bytes\n", read_value); + /* get RAM size */ + read_value = get_ram_size((void *)CONFIG_SYS_FPGA_BASE_1, FPGA_RAM_SIZE); + post_log("FPGA RAM size %d bytes\n", read_value); + WATCHDOG_RESET();
- for (address = 0; address < 0x1000; address++) { - if (fpga_mem_test((void *)(FPGA_RAM_START + 4*address)) == 1) { - ret = 1; - goto out; - } + /* copy fpga memory to DDR2 RAM*/ + memcpy((void *)FPGA_BUFFER,(void *)FPGA_RAM_START, FPGA_RAM_SIZE); + WATCHDOG_RESET(); + + /* Test datalines */ + if (fpga_post_dataline((ulong *)FPGA_RAM_START)) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + + /* Test addresslines */ + if (fpga_post_addrline((ulong *)FPGA_RAM_START, + (ulong *)FPGA_RAM_START, FPGA_RAM_SIZE)) { + ret = 1; + goto out; } + WATCHDOG_RESET(); + if (fpga_post_addrline((ulong *)FPGA_RAM_END - sizeof(long), + (ulong *)FPGA_RAM_START, FPGA_RAM_SIZE)) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + + /* Memory Pattern Test */ + if (fpga_mem_test()) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + + /* restore memory */ + memcpy((void *)FPGA_RAM_START,(void *)FPGA_BUFFER, FPGA_RAM_SIZE); + WATCHDOG_RESET();
out: + /* Disable write to RAM */ + out_be32((void *)FPGA_STAT, in_be32((void *)FPGA_STAT) & 0xEFFF); return ret; }
diff --git a/post/board/lwmon5/gdc.c b/post/board/lwmon5/gdc.c index eb16e36..719194b 100644 --- a/post/board/lwmon5/gdc.c +++ b/post/board/lwmon5/gdc.c @@ -28,18 +28,39 @@ */
#include <post.h> - +#include <watchdog.h> #include <asm/io.h> +#include <video.h>
-#define GDC_SCRATCH_REG 0xC1FF8044 -#define GDC_VERSION_REG 0xC1FF8084 -#define GDC_RAM_START 0xC0000000 -#define GDC_RAM_END 0xC2000000 +#define GDC_SCRATCH_REG 0xC1FF8044 +#define GDC_VERSION_REG 0xC1FF8084 +#define GDC_HOST_BASE 0xC1FC0000 +#define GDC_RAM_START 0xC0000000 +#define GDC_RAM_END (GDC_HOST_BASE - 1) +#define GDC_RAM_SIZE (GDC_RAM_END - GDC_RAM_START)
#if CONFIG_POST & CONFIG_SYS_POST_BSPEC4
+const static unsigned long pattern[] = { + 0xffffffff, + 0xaaaaaaaa, + 0xcccccccc, + 0xf0f0f0f0, + 0xff00ff00, + 0xffff0000, + 0x0000ffff, + 0x00ff00ff, + 0x0f0f0f0f, + 0x33333333, + 0x55555555, + 0x00000000 +}; + +const static unsigned long otherpattern = 0x01234567; + +/* test write/read og a given LIME Register */ static int gdc_test_reg_one(uint value) { int ret; @@ -53,17 +74,229 @@ static int gdc_test_reg_one(uint value) read_value = in_be32((void *)GDC_SCRATCH_REG); if (read_value != value) { post_log("GDC SCRATCH test failed write %08X, read %08X\n", - value, read_value); + value, read_value); }
return (read_value != value); }
-/* Verify GDC, get memory size */ +/* test with a given static 32 bit pattern in a given memory addressrange */ +static int gdc_post_test1(ulong *start, ulong size, ulong val) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = val; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != val) { + post_log("GDC Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, val, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +/* test with dynamic 32 bit pattern in a given memory addressrange */ +static int gdc_post_test2(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = 1 << (i % 32); + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != 1 << (i % 32)) { + post_log("GDC Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, 1 << (i % 32), readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +/* test with dynamic 32 bit pattern in a given memory addressrange */ +static int gdc_post_test3(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = i; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != i) { + post_log("GDC Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, i, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +/* test with dynamic 32 bit pattern in a given memory addressrange */ +static int gdc_post_test4(ulong *start, ulong size) +{ + int ret = 0; + ulong i = 0; + ulong *mem = start; + ulong readback; + + for (i = 0; i < size / sizeof(ulong); i++) { + mem[i] = ~i; + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + for (i = 0; i < size / sizeof(ulong); i++) { + readback = mem[i]; + if (readback != ~i) { + post_log("GDC Memory error at %08x, " + "wrote %08x, read %08x !\n", + mem + i, ~i, readback); + ret = -1; + break; + } + if (i % 1024 == 0) + WATCHDOG_RESET(); + } + + return ret; +} + +/* do some patterntests in a given addressrange */ +int gdc_mem_test(ulong *start, ulong size) +{ + int ret = 0; + + /* + * check addressrange and do different static and dynamic + * pattern tests with it. + */ + if (((void *)start) + size <= (void *)GDC_RAM_END) { + if (ret == 0) + ret = gdc_post_test1(start, size, 0x00000000); + + if (ret == 0) + ret = gdc_post_test1(start, size, 0xffffffff); + + if (ret == 0) + ret = gdc_post_test1(start, size, 0x55555555); + + if (ret == 0) + ret = gdc_post_test1(start, size, 0xaaaaaaaa); + + if (ret == 0) + ret = gdc_post_test2(start, size); + + if (ret == 0) + ret = gdc_post_test3(start, size); + + if (ret == 0) + ret = gdc_post_test4(start, size); + } + + return ret; +} + +/* test function of gdc memory addresslines*/ +static int gdc_post_addrline(ulong *address, ulong *base, ulong size) +{ + ulong *target; + ulong *end; + ulong readback = 0; + ulong xor = 0; + int ret = 0; + + end = (ulong *)((ulong)base + size); + + for (xor = sizeof(long); xor > 0; xor <<= 1) { + target = (ulong *)((ulong)address ^ xor); + if ((target >= base) && (target < end)) { + *address = ~*target; + readback = *target; + } + + if (readback == *address) { + post_log("GDC Memory (address line) error at %08x" + "XOR value %08x !\n", + address, target , xor); + ret = -1; + break; + } + } + + return ret; +} + +static int gdc_post_dataline(ulong *address) +{ + unsigned long temp32 = 0; + int i = 0; + int ret = 0; + + for (i = 0; i < ARRAY_SIZE(pattern); i++) { + *address = pattern[i]; + /* + * Put a different pattern on the data lines: otherwise they + * may float long enough to read back what we wrote. + */ + *(address + 1) = otherpattern; + temp32 = *address; + + if (temp32 != pattern[i]){ + post_log("GDC Memory (date line) error at %08x, " + "wrote %08x, read %08x !\n", + address, pattern[i], temp32); + ret = 1; + } + } + + return ret; +} + +/* Verify GDC, get memory size, verify GDC memory */ int gdc_post_test(int flags) { - uint old_value; - int ret = 0; + uint old_value; + int i = 0; + int ret = 0;
post_log("\n"); old_value = in_be32((void *)GDC_SCRATCH_REG); @@ -84,13 +317,64 @@ int gdc_post_test(int flags)
old_value = in_be32((void *)GDC_VERSION_REG); post_log("GDC chip version %u.%u, year %04X\n", - (old_value >> 8) & 0xFF, old_value & 0xFF, - (old_value >> 16) & 0xFFFF); + (old_value >> 8) & 0xFF, old_value & 0xFF, + (old_value >> 16) & 0xFFFF);
old_value = get_ram_size((void *)GDC_RAM_START, - GDC_RAM_END - GDC_RAM_START); + 0x02000000); + + debug("GDC RAM size (ist): %d bytes\n", old_value); + debug("GDC RAM size (soll): %d bytes\n", GDC_RAM_SIZE); post_log("GDC RAM size: %d bytes\n", old_value);
+ /* Test SDRAM datalines */ + if (gdc_post_dataline((ulong *)GDC_RAM_START)) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + + /* Test SDRAM adresslines */ + if (gdc_post_addrline((ulong *)GDC_RAM_START, + (ulong *)GDC_RAM_START, GDC_RAM_SIZE)) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + if (gdc_post_addrline((ulong *)GDC_RAM_END - sizeof(long), + (ulong *)GDC_RAM_START, GDC_RAM_SIZE)) { + ret = 1; + goto out; + } + WATCHDOG_RESET(); + + /* memory pattern test */ + debug("GDC Memory test (flags %8x:%8x)\n", flags, + POST_SLOWTEST | POST_MANUAL); + + if (flags & POST_MANUAL) { + debug("Full memory test\n"); + if (gdc_mem_test((ulong *)GDC_RAM_START, GDC_RAM_SIZE)) { + ret = 1; + goto out; + } + /* load splashscreen again */ + } else { + debug("smart memory test\n"); + for (i = 0; i < (GDC_RAM_SIZE >> 20) && ret == 0; i++) { + if (ret == 0) + ret = gdc_mem_test((ulong *)(GDC_RAM_START + + (i << 20)), + 0x800); + if (ret == 0) + ret = gdc_mem_test((ulong *)(GDC_RAM_START + + (i << 20) + 0xff800), + 0x800); + } + } + WATCHDOG_RESET(); + +out: return ret; } #endif /* CONFIG_POST & CONFIG_SYS_POST_BSPEC4 */ diff --git a/post/board/lwmon5/sysmon.c b/post/board/lwmon5/sysmon.c index 9c49d0e..4a78240 100644 --- a/post/board/lwmon5/sysmon.c +++ b/post/board/lwmon5/sysmon.c @@ -56,7 +56,7 @@ DECLARE_GLOBAL_DATA_PTR;
/* from dspic.c */ -extern int dspic_read(ushort reg); +extern int dspic_read(ushort reg, ushort *data);
#define REG_TEMPERATURE 0x12BC #define REG_VOLTAGE_5V 0x12CA @@ -76,31 +76,38 @@ extern int dspic_read(ushort reg); typedef struct sysmon_s sysmon_t; typedef struct sysmon_table_s sysmon_table_t;
-static void sysmon_dspic_init (sysmon_t * this); -static int sysmon_dspic_read (sysmon_t * this, uint addr); -static void sysmon_backlight_disable (sysmon_table_t * this); +static void sysmon_dspic_init(sysmon_t *this); +static int sysmon_dspic_read(sysmon_t *this, uint addr, int *val); +static int sysmon_dspic_read_sgn(sysmon_t *this, uint addr, int *val); +static void sysmon_backlight_disable(sysmon_table_t *this);
-struct sysmon_s -{ +struct sysmon_s { uchar chip; void (*init)(sysmon_t *); - int (*read)(sysmon_t *, uint); + int (*read)(sysmon_t *, uint, int *); };
-static sysmon_t sysmon_dspic = - {CONFIG_SYS_I2C_DSPIC_IO_ADDR, sysmon_dspic_init, sysmon_dspic_read}; +static sysmon_t sysmon_dspic = { + CONFIG_SYS_I2C_DSPIC_IO_ADDR, + sysmon_dspic_init, + sysmon_dspic_read +};
-static sysmon_t * sysmon_list[] = -{ +static sysmon_t sysmon_dspic_sgn = { + CONFIG_SYS_I2C_DSPIC_IO_ADDR, + sysmon_dspic_init, + sysmon_dspic_read_sgn +}; + +static sysmon_t *sysmon_list[] = { &sysmon_dspic, NULL };
-struct sysmon_table_s -{ - char * name; - char * unit_name; - sysmon_t * sysmon; +struct sysmon_table_s { + char *name; + char *unit_name; + sysmon_t *sysmon; void (*exec_before)(sysmon_table_t *); void (*exec_after)(sysmon_table_t *);
@@ -118,37 +125,43 @@ struct sysmon_table_s uint addr; };
-static sysmon_table_t sysmon_table[] = -{ +static sysmon_table_t sysmon_table[] = { { - "Temperature", " C", &sysmon_dspic, NULL, sysmon_backlight_disable, - 1, 1, -32768, 32767, 0xFFFF, - 0x8000 + TEMPERATURE_MIN, 0x8000 + TEMPERATURE_MAX, 0, - 0x8000 + TEMPERATURE_DISPLAY_MIN, 0x8000 + TEMPERATURE_DISPLAY_MAX, 0, - REG_TEMPERATURE, + "Temperature", " C", &sysmon_dspic, NULL, sysmon_backlight_disable, + 1, 1, -32768, 32767, 0xFFFF, + 0x8000 + TEMPERATURE_MIN, 0x8000 + TEMPERATURE_MAX, 0, + 0x8000 + TEMPERATURE_DISPLAY_MIN, 0x8000 + TEMPERATURE_DISPLAY_MAX, 0, + REG_TEMPERATURE, },
{ - "+ 5 V", "V", &sysmon_dspic, NULL, NULL, - 100, 1000, -0x8000, 0x7FFF, 0xFFFF, - 0x8000 + VOLTAGE_5V_MIN, 0x8000 + VOLTAGE_5V_MAX, 0, - 0x8000 + VOLTAGE_5V_MIN, 0x8000 + VOLTAGE_5V_MAX, 0, - REG_VOLTAGE_5V, + "+ 5 V", "V", &sysmon_dspic, NULL, NULL, + 100, 1000, -0x8000, 0x7FFF, 0xFFFF, + 0x8000 + VOLTAGE_5V_MIN, 0x8000 + VOLTAGE_5V_MAX, 0, + 0x8000 + VOLTAGE_5V_MIN, 0x8000 + VOLTAGE_5V_MAX, 0, + REG_VOLTAGE_5V, },
{ - "+ 5 V standby", "V", &sysmon_dspic, NULL, NULL, - 100, 1000, -0x8000, 0x7FFF, 0xFFFF, - 0x8000 + VOLTAGE_5V_STANDBY_MIN, 0x8000 + VOLTAGE_5V_STANDBY_MAX, 0, - 0x8000 + VOLTAGE_5V_STANDBY_MIN, 0x8000 + VOLTAGE_5V_STANDBY_MAX, 0, - REG_VOLTAGE_5V_STANDBY, + "+ 5 V standby", "V", &sysmon_dspic, NULL, NULL, + 100, 1000, -0x8000, 0x7FFF, 0xFFFF, + 0x8000 + VOLTAGE_5V_STANDBY_MIN, 0x8000 + VOLTAGE_5V_STANDBY_MAX, 0, + 0x8000 + VOLTAGE_5V_STANDBY_MIN, 0x8000 + VOLTAGE_5V_STANDBY_MAX, 0, + REG_VOLTAGE_5V_STANDBY, + }, + + { + "Temperature", "°C", &sysmon_dspic_sgn, NULL, sysmon_backlight_disable, + 1, 1, -32768, 32767, 0xFFFF, + 0x8000 + TEMPERATURE_MIN, 0x8000 + TEMPERATURE_MAX, 0, + 0x8000 + TEMPERATURE_DISPLAY_MIN, 0x8000 + TEMPERATURE_DISPLAY_MAX, 0, + REG_TEMPERATURE, }, }; -static int sysmon_table_size = sizeof(sysmon_table) / sizeof(sysmon_table[0]);
-int sysmon_init_f (void) +int sysmon_init_f(void) { - sysmon_t ** l; + sysmon_t **l;
for (l = sysmon_list; *l; l++) (*l)->init(*l); @@ -156,12 +169,12 @@ int sysmon_init_f (void) return 0; }
-void sysmon_reloc (void) +void sysmon_reloc(void) { /* Do nothing for now, sysmon_reloc() is required by the sysmon post */ }
-static char *sysmon_unit_value (sysmon_table_t *s, uint val) +static char *sysmon_unit_value(sysmon_table_t *s, uint val) { static char buf[32]; char *p, sign; @@ -176,14 +189,13 @@ static char *sysmon_unit_value (sysmon_table_t *s, uint val) if (unit_val < 0) { sign = '-'; unit_val = -unit_val; - } else + } else { sign = '+'; + }
p = buf + sprintf(buf, "%c%2d", sign, unit_val / s->unit_div);
- frac = unit_val % s->unit_div; - frac /= (s->unit_div / s->unit_precision);
decimal = s->unit_precision; @@ -197,58 +209,84 @@ static char *sysmon_unit_value (sysmon_table_t *s, uint val) return buf; }
-static void sysmon_dspic_init (sysmon_t * this) +static void sysmon_dspic_init(sysmon_t *this) { }
-static int sysmon_dspic_read (sysmon_t * this, uint addr) +static int sysmon_dspic_read(sysmon_t *this, uint addr, int *val) { - int res = dspic_read(addr); + ushort data; + + if (dspic_read(addr, &data) == 0){ + /* To fit into the table range we should add 0x8000 */ + *val = data + 0x8000; + return 0; + }
- /* To fit into the table range we should add 0x8000 */ - return (res == -1) ? -1 : (res + 0x8000); + return -1; }
-static void sysmon_backlight_disable (sysmon_table_t * this) +static int sysmon_dspic_read_sgn(sysmon_t *this, uint addr, int *val) +{ + ushort data; + + if (dspic_read(addr, &data) == 0){ + /* To fit into the table range we should add 0x8000 */ + *val = (signed short)data + 0x8000; + return 0; + } + + return -1; +} + +static void sysmon_backlight_disable(sysmon_table_t *this) { #if defined(CONFIG_VIDEO) board_backlight_switch(this->val_valid_alt); #endif }
-int sysmon_post_test (int flags) +int sysmon_post_test(int flags) { int res = 0; sysmon_table_t * t; int val;
- for (t = sysmon_table; t < sysmon_table + sysmon_table_size; t ++) { + for (t = sysmon_table; t < sysmon_table + ARRAY_SIZE(sysmon_table); t++) { + t->val_valid = 1; if (t->exec_before) t->exec_before(t);
- val = t->sysmon->read(t->sysmon, t->addr); - if (val != -1) { - t->val_valid = val >= t->val_min && val <= t->val_max; - t->val_valid_alt = val >= t->val_min_alt && val <= t->val_max_alt; - } else { + if (t->sysmon->read(t->sysmon, t->addr, &val) != 0) { t->val_valid = 0; t->val_valid_alt = 0; + post_log(": read failed\n"); + res = 1; + break; + } + + if (t->val_valid != 0) { + t->val_valid = val >= t->val_min && val <= t->val_max; + t->val_valid_alt = val >= t->val_min_alt && val <= t->val_max_alt; }
if (t->exec_after) t->exec_after(t);
- if ((!t->val_valid) || (flags & POST_MANUAL)) { - printf("%-17s = %-10s ", t->name, sysmon_unit_value(t, val)); - printf("allowed range"); - printf(" %-8s ..", sysmon_unit_value(t, t->val_min)); - printf(" %-8s", sysmon_unit_value(t, t->val_max)); - printf(" %s\n", t->val_valid ? "OK" : "FAIL"); + if ((!t->val_valid) || (flags)) { + post_log("\n\t%-17s = %-10s ", t->name, sysmon_unit_value(t, val)); + post_log("allowed range"); + post_log(" %-8s ..", sysmon_unit_value(t, t->val_min)); + post_log(" %-8s", sysmon_unit_value(t, t->val_max)); + post_log(" %s", t->val_valid ? "OK" : "FAIL"); }
- if (!t->val_valid) + if (!t->val_valid) { res = 1; + break; + } } + post_log("\n");
return res; } diff --git a/post/board/lwmon5/watchdog.c b/post/board/lwmon5/watchdog.c index f181506..4e5ed0d 100644 --- a/post/board/lwmon5/watchdog.c +++ b/post/board/lwmon5/watchdog.c @@ -57,8 +57,11 @@ int sysmon1_post_test(int flags) * 3.1. GPIO62 is low * Assuming system voltage failure. */ - post_log("Abnormal voltage detected (GPIO62)\n"); + post_log("sysmon1 Abnormal voltage detected (GPIO62)\n"); + post_log("POST sysmon1 FAILED\n"); return 1; + } else { + post_log("sysmon1 PASSED\n"); }
return 0; @@ -117,10 +120,16 @@ int lwmon5_watchdog_post_test(int flags) ulong time; /* 3.3.1. So, the test succeed, save measured time to syslog. */ time = in_be32((void *)CONFIG_SYS_WATCHDOG_TIME_ADDR); - post_log("hw watchdog time : %u ms, passed ", time); - /* 3.3.2. Set scratch register 1 to 0x0000xxxx */ - watchdog_magic_write(0); - return 0; + if (time > 90 ) { /* ms*/ + post_log("hw watchdog time : %u ms, passed ", time); + /* 3.3.2. Set scratch register 1 to 0x0000xxxx */ + watchdog_magic_write(0); + return 0; + } else { + /*test minimum watchdogtime */ + post_log("hw watchdog time : %u ms, failed ", time); + return 2; + } } return -1; }
On Wednesday 29 September 2010 17:20:10 Stefan Roese wrote:
This patch brings the lwmon5 board support up-to-date. Here a summary of the changes:
lwmon5 board port related:
- GPIO's changed to control the LSB transmitter
- Reset USB PHY's upon power-up
- Enable CAN upon power-up
- USB init error workaround (errata CHIP_6)
- EBC: Enable burstmode and modify the timings for the GDC memory
- EBC: Speed up NOR flash timings
lwmon5 board POST related:
- Add FPGA memory test
- Add GDC memory test
- DSP POST reworked
- SYSMON POST: Fix handling of negative temperatures
- Add output for sysmon1 POST
- HW-watchdog min. time test reworked
Additionally some coding-style changes were done.
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
