[U-Boot] [PATCH] arm: omap2: am43xx: Enable CONFIG_DM_USB
Enable CONFIG_DM_USB to remove compile warning for am43xx based targets:
===================== WARNING ====================== This board does not use CONFIG_DM_USB. Please update the board to use CONFIG_DM_USB before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Suniel Mahesh sunil.m@techveda.org --- configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 06268ba..b1bf670 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index caf761b..3064f31 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -49,6 +49,7 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index d634ab1..8be2102 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -59,6 +59,7 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y
