[PATCH 0/5] Add Silicon Linux EK874 board
Hi All,
This patch series adds support for Silicon Linux EK874 board support which is based on Renesas R8A774C0 SoC.
Cheers, Prabhakar
Lad Prabhakar (5): arm: dts: r8a774c0: Resync R8A774C0 SoC DTSI with Linux 5.11 pinctrl: renesas: pfc-r8a77990: Sync PFC tables with Linux 5.11 pinctrl: renesas: Add support for R8A774C0 arm: rmobile: Add Silicon Linux EK874 board support board: silinux: Enable recovery SPL for EK874 board
arch/arm/dts/Makefile | 1 + arch/arm/dts/cat875.dtsi | 64 ++++ arch/arm/dts/r8a774c0-cat874.dts | 453 +++++++++++++++++++++++++ arch/arm/dts/r8a774c0-ek874-u-boot.dts | 33 ++ arch/arm/dts/r8a774c0-ek874.dts | 14 + arch/arm/dts/r8a774c0-u-boot.dtsi | 53 +++ arch/arm/dts/r8a774c0.dtsi | 27 +- arch/arm/mach-rmobile/Kconfig.64 | 8 + arch/arm/mach-rmobile/Makefile | 2 +- board/silinux/ek874/Kconfig | 15 + board/silinux/ek874/MAINTAINERS | 6 + board/silinux/ek874/Makefile | 13 + board/silinux/ek874/ek874.c | 30 ++ configs/silinux_ek874_defconfig | 83 +++++ drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a77990.c | 87 ++++- drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + include/configs/silinux-ek874.h | 20 ++ include/dt-bindings/display/tda998x.h | 8 + 21 files changed, 933 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/cat875.dtsi create mode 100644 arch/arm/dts/r8a774c0-cat874.dts create mode 100644 arch/arm/dts/r8a774c0-ek874-u-boot.dts create mode 100644 arch/arm/dts/r8a774c0-ek874.dts create mode 100644 arch/arm/dts/r8a774c0-u-boot.dtsi create mode 100644 board/silinux/ek874/Kconfig create mode 100644 board/silinux/ek874/MAINTAINERS create mode 100644 board/silinux/ek874/Makefile create mode 100644 board/silinux/ek874/ek874.c create mode 100644 configs/silinux_ek874_defconfig create mode 100644 include/configs/silinux-ek874.h create mode 100644 include/dt-bindings/display/tda998x.h
Resync the R8A774C0 SoC DTSI with Linux kernel 5.11 commit f40ddce88593 ("Linux 5.11").
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/dts/r8a774c0.dtsi | 27 +++++++++++++++++++++++---- 1 file changed, 23 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/r8a774c0.dtsi b/arch/arm/dts/r8a774c0.dtsi index e14db4d363..2bdd571bd8 100644 --- a/arch/arm/dts/r8a774c0.dtsi +++ b/arch/arm/dts/r8a774c0.dtsi @@ -256,7 +256,7 @@ resets = <&cpg 906>; };
- pfc: pin-controller@e6060000 { + pfc: pinctrl@e6060000 { compatible = "renesas,pfc-r8a774c0"; reg = <0 0xe6060000 0 0x508>; }; @@ -960,6 +960,7 @@ power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; resets = <&cpg 812>; phy-mode = "rgmii"; + rx-internal-delay-ps = <0>; iommus = <&ipmmu_ds0 16>; #address-cells = <1>; #size-cells = <0>; @@ -1214,9 +1215,8 @@ reg = <0 0xe6ea0000 0 0x0064>; interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; + dmas = <&dmac0 0x43>, <&dmac0 0x42>; + dma-names = "tx", "rx"; power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; resets = <&cpg 210>; #address-cells = <1>; @@ -1698,6 +1698,25 @@ status = "disabled"; };
+ pciec0_ep: pcie-ep@fe000000 { + compatible = "renesas,r8a774c0-pcie-ep", + "renesas,rcar-gen3-pcie-ep"; + reg = <0x0 0xfe000000 0 0x80000>, + <0x0 0xfe100000 0 0x100000>, + <0x0 0xfe200000 0 0x200000>, + <0x0 0x30000000 0 0x8000000>, + <0x0 0x38000000 0 0x8000000>; + reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>; + clock-names = "pcie"; + resets = <&cpg 319>; + power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; + status = "disabled"; + }; + vspb0: vsp@fe960000 { compatible = "renesas,vsp2"; reg = <0 0xfe960000 0 0x8000>;
Sync the R8A77990 SoC PFC tables with Linux 5.11 , commit f40ddce88593.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- drivers/pinctrl/renesas/pfc-r8a77990.c | 87 +++++++++++++++++++++++++- 1 file changed, 85 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/renesas/pfc-r8a77990.c b/drivers/pinctrl/renesas/pfc-r8a77990.c index b13fc0ba63..572b041b83 100644 --- a/drivers/pinctrl/renesas/pfc-r8a77990.c +++ b/drivers/pinctrl/renesas/pfc-r8a77990.c @@ -1603,6 +1603,7 @@ static const unsigned int canfd1_data_mux[] = { CANFD1_TX_MARK, CANFD1_RX_MARK, };
+#ifdef CONFIG_PINCTRL_PFC_R8A77990 /* - DRIF0 --------------------------------------------------------------- */ static const unsigned int drif0_ctrl_a_pins[] = { /* CLK, SYNC */ @@ -1795,6 +1796,7 @@ static const unsigned int drif3_data1_b_pins[] = { static const unsigned int drif3_data1_b_mux[] = { RIF3_D1_B_MARK, }; +#endif /* CONFIG_PINCTRL_PFC_R8A77990 */
/* - DU --------------------------------------------------------------------- */ static const unsigned int du_rgb666_pins[] = { @@ -2818,6 +2820,57 @@ static const unsigned int pwm6_b_mux[] = { PWM6_B_MARK, };
+/* - QSPI0 ------------------------------------------------------------------ */ +static const unsigned int qspi0_ctrl_pins[] = { + /* QSPI0_SPCLK, QSPI0_SSL */ + RCAR_GP_PIN(2, 0), RCAR_GP_PIN(2, 5), +}; +static const unsigned int qspi0_ctrl_mux[] = { + QSPI0_SPCLK_MARK, QSPI0_SSL_MARK, +}; +static const unsigned int qspi0_data2_pins[] = { + /* QSPI0_MOSI_IO0, QSPI0_MISO_IO1 */ + RCAR_GP_PIN(2, 1), RCAR_GP_PIN(2, 2), +}; +static const unsigned int qspi0_data2_mux[] = { + QSPI0_MOSI_IO0_MARK, QSPI0_MISO_IO1_MARK, +}; +static const unsigned int qspi0_data4_pins[] = { + /* QSPI0_MOSI_IO0, QSPI0_MISO_IO1 */ + RCAR_GP_PIN(2, 1), RCAR_GP_PIN(2, 2), + /* QSPI0_IO2, QSPI0_IO3 */ + RCAR_GP_PIN(2, 3), RCAR_GP_PIN(2, 4), +}; +static const unsigned int qspi0_data4_mux[] = { + QSPI0_MOSI_IO0_MARK, QSPI0_MISO_IO1_MARK, + QSPI0_IO2_MARK, QSPI0_IO3_MARK, +}; +/* - QSPI1 ------------------------------------------------------------------ */ +static const unsigned int qspi1_ctrl_pins[] = { + /* QSPI1_SPCLK, QSPI1_SSL */ + RCAR_GP_PIN(2, 6), RCAR_GP_PIN(2, 11), +}; +static const unsigned int qspi1_ctrl_mux[] = { + QSPI1_SPCLK_MARK, QSPI1_SSL_MARK, +}; +static const unsigned int qspi1_data2_pins[] = { + /* QSPI1_MOSI_IO0, QSPI1_MISO_IO1 */ + RCAR_GP_PIN(2, 7), RCAR_GP_PIN(2, 8), +}; +static const unsigned int qspi1_data2_mux[] = { + QSPI1_MOSI_IO0_MARK, QSPI1_MISO_IO1_MARK, +}; +static const unsigned int qspi1_data4_pins[] = { + /* QSPI1_MOSI_IO0, QSPI1_MISO_IO1 */ + RCAR_GP_PIN(2, 7), RCAR_GP_PIN(2, 8), + /* QSPI1_IO2, QSPI1_IO3 */ + RCAR_GP_PIN(2, 9), RCAR_GP_PIN(2, 10), +}; +static const unsigned int qspi1_data4_mux[] = { + QSPI1_MOSI_IO0_MARK, QSPI1_MISO_IO1_MARK, + QSPI1_IO2_MARK, QSPI1_IO3_MARK, +}; + /* - SCIF0 ------------------------------------------------------------------ */ static const unsigned int scif0_data_a_pins[] = { /* RX, TX */ @@ -3770,8 +3823,10 @@ static const unsigned int vin5_clk_b_mux[] = { };
static const struct { - struct sh_pfc_pin_group common[247]; + struct sh_pfc_pin_group common[253]; +#ifdef CONFIG_PINCTRL_PFC_R8A77990 struct sh_pfc_pin_group automotive[21]; +#endif } pinmux_groups = { .common = { SH_PFC_PIN_GROUP(audio_clk_a), @@ -3916,6 +3971,12 @@ static const struct { SH_PFC_PIN_GROUP(pwm5_b), SH_PFC_PIN_GROUP(pwm6_a), SH_PFC_PIN_GROUP(pwm6_b), + SH_PFC_PIN_GROUP(qspi0_ctrl), + SH_PFC_PIN_GROUP(qspi0_data2), + SH_PFC_PIN_GROUP(qspi0_data4), + SH_PFC_PIN_GROUP(qspi1_ctrl), + SH_PFC_PIN_GROUP(qspi1_data2), + SH_PFC_PIN_GROUP(qspi1_data4), SH_PFC_PIN_GROUP(scif0_data_a), SH_PFC_PIN_GROUP(scif0_clk_a), SH_PFC_PIN_GROUP(scif0_ctrl_a), @@ -4022,6 +4083,7 @@ static const struct { SH_PFC_PIN_GROUP(vin5_clk_a), SH_PFC_PIN_GROUP(vin5_clk_b), }, +#ifdef CONFIG_PINCTRL_PFC_R8A77990 .automotive = { SH_PFC_PIN_GROUP(drif0_ctrl_a), SH_PFC_PIN_GROUP(drif0_data0_a), @@ -4045,6 +4107,7 @@ static const struct { SH_PFC_PIN_GROUP(drif3_data0_b), SH_PFC_PIN_GROUP(drif3_data1_b), } +#endif /* CONFIG_PINCTRL_PFC_R8A77990 */ };
static const char * const audio_clk_groups[] = { @@ -4098,6 +4161,7 @@ static const char * const canfd1_groups[] = { "canfd1_data", };
+#ifdef CONFIG_PINCTRL_PFC_R8A77990 static const char * const drif0_groups[] = { "drif0_ctrl_a", "drif0_data0_a", @@ -4130,6 +4194,7 @@ static const char * const drif3_groups[] = { "drif3_data0_b", "drif3_data1_b", }; +#endif /* CONFIG_PINCTRL_PFC_R8A77990 */
static const char * const du_groups[] = { "du_rgb666", @@ -4315,6 +4380,18 @@ static const char * const pwm6_groups[] = { "pwm6_b", };
+static const char * const qspi0_groups[] = { + "qspi0_ctrl", + "qspi0_data2", + "qspi0_data4", +}; + +static const char * const qspi1_groups[] = { + "qspi1_ctrl", + "qspi1_data2", + "qspi1_data4", +}; + static const char * const scif0_groups[] = { "scif0_data_a", "scif0_clk_a", @@ -4469,8 +4546,10 @@ static const char * const vin5_groups[] = { };
static const struct { - struct sh_pfc_function common[47]; + struct sh_pfc_function common[49]; +#ifdef CONFIG_PINCTRL_PFC_R8A77990 struct sh_pfc_function automotive[4]; +#endif } pinmux_functions = { .common = { SH_PFC_FUNCTION(audio_clk), @@ -4504,6 +4583,8 @@ static const struct { SH_PFC_FUNCTION(pwm4), SH_PFC_FUNCTION(pwm5), SH_PFC_FUNCTION(pwm6), + SH_PFC_FUNCTION(qspi0), + SH_PFC_FUNCTION(qspi1), SH_PFC_FUNCTION(scif0), SH_PFC_FUNCTION(scif1), SH_PFC_FUNCTION(scif2), @@ -4521,12 +4602,14 @@ static const struct { SH_PFC_FUNCTION(vin4), SH_PFC_FUNCTION(vin5), }, +#ifdef CONFIG_PINCTRL_PFC_R8A77990 .automotive = { SH_PFC_FUNCTION(drif0), SH_PFC_FUNCTION(drif1), SH_PFC_FUNCTION(drif2), SH_PFC_FUNCTION(drif3), } +#endif /* CONFIG_PINCTRL_PFC_R8A77990 */ };
static const struct pinmux_cfg_reg pinmux_config_regs[] = {
Renesas RZ/G2E (a.k.a. r8a774c0) is pin compatible with R-Car E3 (a.k.a. r8a77990), however it doesn't have several automotive specific peripherals.
This patch hooks R8A774C0 SoC with the pfc driver.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/pinctrl/renesas/Kconfig | 10 ++++++++++ drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc.c | 11 +++++++++++ drivers/pinctrl/renesas/sh_pfc.h | 1 + 5 files changed, 24 insertions(+)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 7eec65d8ea..28c2628a3c 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -15,6 +15,7 @@ config R8A774B1 config R8A774C0 bool "Renesas SoC R8A774C0" imply CLK_R8A774C0 + imply PINCTRL_PFC_R8A774C0
config R8A774E1 bool "Renesas SoC R8A774E1" diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index d2be4c84ba..8fb9cba387 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -77,6 +77,16 @@ config PINCTRL_PFC_R8A774B1 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_PFC_R8A774C0 + bool "Renesas RZ/G2 R8A774C0 pin control driver" + depends on PINCTRL_PFC + help + Support pin multiplexing control on Renesas RZ/G2E R8A774C0 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_PFC_R8A774E1 bool "Renesas RZ/G2 R8A774E1 pin control driver" depends on PINCTRL_PFC diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index 1d00752051..0e2ac3c513 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -1,6 +1,7 @@ obj-$(CONFIG_PINCTRL_PFC) += pfc.o obj-$(CONFIG_PINCTRL_PFC_R8A774A1) += pfc-r8a7796.o obj-$(CONFIG_PINCTRL_PFC_R8A774B1) += pfc-r8a77965.o +obj-$(CONFIG_PINCTRL_PFC_R8A774C0) += pfc-r8a77990.o obj-$(CONFIG_PINCTRL_PFC_R8A774E1) += pfc-r8a7795.o obj-$(CONFIG_PINCTRL_PFC_R8A7790) += pfc-r8a7790.o obj-$(CONFIG_PINCTRL_PFC_R8A7791) += pfc-r8a7791.o diff --git a/drivers/pinctrl/renesas/pfc.c b/drivers/pinctrl/renesas/pfc.c index 6ff948420c..07fcc3d393 100644 --- a/drivers/pinctrl/renesas/pfc.c +++ b/drivers/pinctrl/renesas/pfc.c @@ -34,6 +34,7 @@ enum sh_pfc_model { SH_PFC_R8A7796, SH_PFC_R8A774A1, SH_PFC_R8A774B1, + SH_PFC_R8A774C0, SH_PFC_R8A774E1, SH_PFC_R8A77965, SH_PFC_R8A77970, @@ -927,6 +928,10 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) if (model == SH_PFC_R8A774B1) priv->pfc.info = &r8a774b1_pinmux_info; #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774C0 + if (model == SH_PFC_R8A774C0) + priv->pfc.info = &r8a774c0_pinmux_info; +#endif #ifdef CONFIG_PINCTRL_PFC_R8A774E1 if (model == SH_PFC_R8A774E1) priv->pfc.info = &r8a774e1_pinmux_info; @@ -1014,6 +1019,12 @@ static const struct udevice_id sh_pfc_pinctrl_ids[] = { .data = SH_PFC_R8A774B1, }, #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774C0 + { + .compatible = "renesas,pfc-r8a774c0", + .data = SH_PFC_R8A774C0, + }, +#endif #ifdef CONFIG_PINCTRL_PFC_R8A774E1 { .compatible = "renesas,pfc-r8a774e1", diff --git a/drivers/pinctrl/renesas/sh_pfc.h b/drivers/pinctrl/renesas/sh_pfc.h index 22cc860f29..f563916f10 100644 --- a/drivers/pinctrl/renesas/sh_pfc.h +++ b/drivers/pinctrl/renesas/sh_pfc.h @@ -295,6 +295,7 @@ sh_pfc_pin_to_bias_reg(const struct sh_pfc *pfc, unsigned int pin,
extern const struct sh_pfc_soc_info r8a774a1_pinmux_info; extern const struct sh_pfc_soc_info r8a774b1_pinmux_info; +extern const struct sh_pfc_soc_info r8a774c0_pinmux_info; extern const struct sh_pfc_soc_info r8a774e1_pinmux_info; extern const struct sh_pfc_soc_info r8a7790_pinmux_info; extern const struct sh_pfc_soc_info r8a7791_pinmux_info;
The EK874 development kit from Silicon Linux is made of CAT874 (the main board) and CAT875 (the sub board that goes on top of CAT874).
This patch adds the required board support to boot Si-Linux EK874 board based on R8A774C0 SoC.
DTS files apart from r8a774c0-ek874-u-boot.dts and r8a774c0-u-boot.dtsi have been imported from Linux kernel 5.11 commit f40ddce88593 ("Linux 5.11").
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/cat875.dtsi | 64 ++++ arch/arm/dts/r8a774c0-cat874.dts | 453 +++++++++++++++++++++++++ arch/arm/dts/r8a774c0-ek874-u-boot.dts | 33 ++ arch/arm/dts/r8a774c0-ek874.dts | 14 + arch/arm/dts/r8a774c0-u-boot.dtsi | 53 +++ arch/arm/mach-rmobile/Kconfig.64 | 7 + board/silinux/ek874/Kconfig | 15 + board/silinux/ek874/MAINTAINERS | 6 + board/silinux/ek874/Makefile | 9 + board/silinux/ek874/ek874.c | 30 ++ configs/silinux_ek874_defconfig | 83 +++++ include/configs/silinux-ek874.h | 20 ++ include/dt-bindings/display/tda998x.h | 8 + 14 files changed, 796 insertions(+) create mode 100644 arch/arm/dts/cat875.dtsi create mode 100644 arch/arm/dts/r8a774c0-cat874.dts create mode 100644 arch/arm/dts/r8a774c0-ek874-u-boot.dts create mode 100644 arch/arm/dts/r8a774c0-ek874.dts create mode 100644 arch/arm/dts/r8a774c0-u-boot.dtsi create mode 100644 board/silinux/ek874/Kconfig create mode 100644 board/silinux/ek874/MAINTAINERS create mode 100644 board/silinux/ek874/Makefile create mode 100644 board/silinux/ek874/ek874.c create mode 100644 configs/silinux_ek874_defconfig create mode 100644 include/configs/silinux-ek874.h create mode 100644 include/dt-bindings/display/tda998x.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d2f2212f86..f5fe327b6c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -824,6 +824,7 @@ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774e1-beacon-rzg2h-kit.dtb \ r8a774a1-hihope-rzg2m-u-boot.dtb \ r8a774b1-hihope-rzg2n-u-boot.dtb \ + r8a774c0-ek874-u-boot.dtb \ r8a774e1-hihope-rzg2h-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ diff --git a/arch/arm/dts/cat875.dtsi b/arch/arm/dts/cat875.dtsi new file mode 100644 index 0000000000..4a2f6fa955 --- /dev/null +++ b/arch/arm/dts/cat875.dtsi @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the Silicon Linux sub board for CAT874 (CAT875) + * + * Copyright (C) 2021 Renesas Electronics Corp. + */ + +/ { + model = "Silicon Linux sub board for CAT874 (CAT875)"; + + aliases { + ethernet0 = &avb; + }; +}; + +&avb { + pinctrl-0 = <&avb_pins>; + pinctrl-names = "default"; + renesas,no-ether-link; + phy-handle = <&phy0>; + status = "okay"; + + phy0: ethernet-phy@0 { + reg = <0>; + interrupt-parent = <&gpio2>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; + }; +}; + +&can0 { + pinctrl-0 = <&can0_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&can1 { + pinctrl-0 = <&can1_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&pciec0 { + status = "okay"; +}; + +&pfc { + avb_pins: avb { + mux { + groups = "avb_mii"; + function = "avb"; + }; + }; + + can0_pins: can0 { + groups = "can0_data"; + function = "can0"; + }; + + can1_pins: can1 { + groups = "can1_data"; + function = "can1"; + }; +}; diff --git a/arch/arm/dts/r8a774c0-cat874.dts b/arch/arm/dts/r8a774c0-cat874.dts new file mode 100644 index 0000000000..676fdef9e0 --- /dev/null +++ b/arch/arm/dts/r8a774c0-cat874.dts @@ -0,0 +1,453 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the Silicon Linux RZ/G2E 96board platform (CAT874) + * + * Copyright (C) 2021 Renesas Electronics Corp. + */ + +/dts-v1/; +#include "r8a774c0.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/display/tda998x.h> + +/ { + model = "Silicon Linux RZ/G2E 96board platform (CAT874)"; + compatible = "si-linux,cat874", "renesas,r8a774c0"; + + aliases { + serial0 = &scif2; + serial1 = &hscif2; + }; + + chosen { + bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; + stdout-path = "serial0:115200n8"; + }; + + hdmi-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_out: endpoint { + remote-endpoint = <&tda19988_out>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led0 { + gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>; + label = "LED0"; + }; + + led1 { + gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>; + label = "LED1"; + }; + + led2 { + gpios = <&gpio4 10 GPIO_ACTIVE_HIGH>; + label = "LED2"; + }; + + led3 { + gpios = <&gpio6 4 GPIO_ACTIVE_HIGH>; + label = "LED3"; + }; + }; + + memory@48000000 { + device_type = "memory"; + /* first 128MB is reserved for secure area. */ + reg = <0x0 0x48000000 0x0 0x78000000>; + }; + + reg_12p0v: regulator-12p0v { + compatible = "regulator-fixed"; + regulator-name = "D12.0V"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-boot-on; + regulator-always-on; + }; + + sound: sound { + compatible = "simple-audio-card"; + + simple-audio-card,name = "CAT874 HDMI sound"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&sndcpu>; + simple-audio-card,frame-master = <&sndcpu>; + + sndcodec: simple-audio-card,codec { + sound-dai = <&tda19988>; + }; + + sndcpu: simple-audio-card,cpu { + sound-dai = <&rcar_sound>; + }; + }; + + vcc_sdhi0: regulator-vcc-sdhi0 { + compatible = "regulator-fixed"; + + regulator-name = "SDHI0 Vcc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + vccq_sdhi0: regulator-vccq-sdhi0 { + compatible = "regulator-gpio"; + + regulator-name = "SDHI0 VccQ"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; + gpios-states = <1>; + states = <3300000 1>, <1800000 0>; + }; + + wlan_en_reg: fixedregulator { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us = <70000>; + + gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + x13_clk: x13 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <74250000>; + }; + + connector { + compatible = "usb-c-connector"; + label = "USB-C"; + data-role = "dual"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + hs_ep: endpoint { + remote-endpoint = <&usb3_hs_ep>; + }; + }; + port@1 { + reg = <1>; + ss_ep: endpoint { + remote-endpoint = <&hd3ss3220_in_ep>; + }; + }; + }; + }; +}; + +&audio_clk_a { + clock-frequency = <22579200>; +}; + +&du { + pinctrl-0 = <&du_pins>; + pinctrl-names = "default"; + status = "okay"; + + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&x13_clk>; + clock-names = "du.0", "du.1", "dclkin.0"; + + ports { + port@0 { + endpoint { + remote-endpoint = <&tda19988_in>; + }; + }; + }; +}; + +&ehci0 { + dr_mode = "host"; + status = "okay"; +}; + +&extal_clk { + clock-frequency = <48000000>; +}; + +&hscif2 { + pinctrl-0 = <&hscif2_pins>; + pinctrl-names = "default"; + + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "ti,wl1837-st"; + enable-gpios = <&gpio4 6 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <100000>; + + hd3ss3220@47 { + compatible = "ti,hd3ss3220"; + reg = <0x47>; + interrupt-parent = <&gpio6>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + hd3ss3220_in_ep: endpoint { + remote-endpoint = <&ss_ep>; + }; + }; + port@1 { + reg = <1>; + hd3ss3220_out_ep: endpoint { + remote-endpoint = <&usb3_role_switch>; + }; + }; + }; + }; + + tda19988: tda19988@70 { + compatible = "nxp,tda998x"; + reg = <0x70>; + interrupt-parent = <&gpio1>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>; + + video-ports = <0x234501>; + + #sound-dai-cells = <0>; + audio-ports = <TDA998x_I2S 0x03>; + clocks = <&rcar_sound 1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + tda19988_in: endpoint { + remote-endpoint = <&du_out_rgb>; + }; + }; + + port@1 { + reg = <1>; + tda19988_out: endpoint { + remote-endpoint = <&hdmi_con_out>; + }; + }; + }; + }; +}; + +&i2c1 { + pinctrl-0 = <&i2c1_pins>; + pinctrl-names = "default"; + + status = "okay"; + clock-frequency = <400000>; + + rtc@32 { + compatible = "epson,rx8571"; + reg = <0x32>; + }; +}; + +&lvds0 { + status = "okay"; + + clocks = <&cpg CPG_MOD 727>, <&x13_clk>, <&extal_clk>; + clock-names = "fck", "dclkin.0", "extal"; +}; + +&ohci0 { + dr_mode = "host"; + status = "okay"; +}; + +&pcie_bus_clk { + clock-frequency = <100000000>; +}; + +&pciec0 { + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; +}; + +&pfc { + du_pins: du { + groups = "du_rgb888", "du_clk_out_0", "du_sync", "du_disp", + "du_clk_in_0"; + function = "du"; + }; + + hscif2_pins: hscif2 { + groups = "hscif2_data_a", "hscif2_ctrl_a"; + function = "hscif2"; + }; + + i2c1_pins: i2c1 { + groups = "i2c1_b"; + function = "i2c1"; + }; + + scif2_pins: scif2 { + groups = "scif2_data_a"; + function = "scif2"; + }; + + sdhi0_pins: sd0 { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <3300>; + }; + + sdhi0_pins_uhs: sd0_uhs { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <1800>; + }; + + sdhi3_pins: sd3 { + groups = "sdhi3_data4", "sdhi3_ctrl"; + function = "sdhi3"; + power-source = <1800>; + }; + + sound_clk_pins: sound_clk { + groups = "audio_clkout1_a"; + function = "audio_clk"; + }; + + sound_pins: sound { + groups = "ssi01239_ctrl", "ssi0_data"; + function = "ssi"; + }; + + usb30_pins: usb30 { + groups = "usb30", "usb30_id"; + function = "usb30"; + }; +}; + +&rcar_sound { + pinctrl-0 = <&sound_pins &sound_clk_pins>; + pinctrl-names = "default"; + + /* Single DAI */ + #sound-dai-cells = <0>; + + /* audio_clkout0/1/2/3 */ + #clock-cells = <1>; + clock-frequency = <11289600>; + + status = "okay"; + + rcar_sound,dai { + dai0 { + playback = <&ssi0 &src0 &dvc0>; + }; + }; +}; + +&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + +&scif2 { + pinctrl-0 = <&scif2_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +&sdhi0 { + pinctrl-0 = <&sdhi0_pins>; + pinctrl-1 = <&sdhi0_pins_uhs>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <&vcc_sdhi0>; + vqmmc-supply = <&vccq_sdhi0>; + cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; + bus-width = <4>; + sd-uhs-sdr50; + sd-uhs-sdr104; + status = "okay"; +}; + +&sdhi3 { + status = "okay"; + pinctrl-0 = <&sdhi3_pins>; + pinctrl-names = "default"; + + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + keep-power-in-suspend; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1837"; + reg = <2>; + interrupt-parent = <&gpio1>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; + }; +}; + +&usb2_phy0 { + renesas,no-otg-pins; + status = "okay"; +}; + +&usb3_peri0 { + companion = <&xhci0>; + status = "okay"; + usb-role-switch; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + usb3_hs_ep: endpoint { + remote-endpoint = <&hs_ep>; + }; + }; + port@1 { + reg = <1>; + usb3_role_switch: endpoint { + remote-endpoint = <&hd3ss3220_out_ep>; + }; + }; + }; +}; + +&xhci0 { + pinctrl-0 = <&usb30_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; diff --git a/arch/arm/dts/r8a774c0-ek874-u-boot.dts b/arch/arm/dts/r8a774c0-ek874-u-boot.dts new file mode 100644 index 0000000000..8fa6d8074b --- /dev/null +++ b/arch/arm/dts/r8a774c0-ek874-u-boot.dts @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope board + * + * Copyright (C) 2021 Renesas Electronisc Corporation + */ + +#include "r8a774c0-ek874.dts" +#include "r8a774c0-u-boot.dtsi" + +/ { + aliases { + spi0 = &rpc; + }; +}; + +&rpc { + num-cs = <1>; + status = "okay"; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + + flash0: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "w25m512jv", "spi-flash", "jedec,spi-nor"; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <1>; + reg = <0>; + }; +}; diff --git a/arch/arm/dts/r8a774c0-ek874.dts b/arch/arm/dts/r8a774c0-ek874.dts new file mode 100644 index 0000000000..d3ab28ba31 --- /dev/null +++ b/arch/arm/dts/r8a774c0-ek874.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the Silicon Linux RZ/G2E evaluation kit (EK874) + * + * Copyright (C) 2021 Renesas Electronics Corp. + */ + +#include "r8a774c0-cat874.dts" +#include "cat875.dtsi" + +/ { + model = "Silicon Linux RZ/G2E evaluation kit EK874 (CAT874 + CAT875)"; + compatible = "si-linux,cat875", "si-linux,cat874", "renesas,r8a774c0"; +}; diff --git a/arch/arm/dts/r8a774c0-u-boot.dtsi b/arch/arm/dts/r8a774c0-u-boot.dtsi new file mode 100644 index 0000000000..af1c86171b --- /dev/null +++ b/arch/arm/dts/r8a774c0-u-boot.dtsi @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot on R8A774C0 SoC + * + * Copyright (C) 2021 Renesas Electronics Corp. + * + */ + +#include "r8a779x-u-boot.dtsi" + +/ { + soc { + rpc: rpc@ee200000 { + compatible = "renesas,rcar-gen3-rpc", "renesas,rpc-r8a774c0"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; + }; +}; + +/delete-node/ &can0; +/delete-node/ &can1; +/delete-node/ &canfd; +/delete-node/ &pwm0; +/delete-node/ &pwm1; +/delete-node/ &pwm2; +/delete-node/ &pwm3; +/delete-node/ &pwm4; +/delete-node/ &pwm5; +/delete-node/ &pwm6; +/delete-node/ &vin4; +/delete-node/ &vin5; +/delete-node/ &rcar_sound; +/delete-node/ &audma0; +/delete-node/ &sdhi1; +/delete-node/ &sdhi3; +/delete-node/ &vspb0; +/delete-node/ &vspd0; +/delete-node/ &vspd1; +/delete-node/ &vspi0; +/delete-node/ &fcpvb0; +/delete-node/ &fcpvd0; +/delete-node/ &fcpvd1; +/delete-node/ &fcpvi0; +/delete-node/ &csi40; +/delete-node/ &du; +/delete-node/ &lvds0; +/delete-node/ &lvds1; +/delete-node/ &hdmi_con_out; +/delete-node/ &sound; +/delete-node/ &tda19988; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 28c2628a3c..8127d33f2d 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -113,6 +113,12 @@ config TARGET_HIHOPE_RZG2 help Support for RZG2 HiHope platform
+config TARGET_SILINUX_EK874 + bool "Silicon Linux EK874 board" + imply R8A774C0 + help + Support for Silicon Linux EK874 platform + config TARGET_SALVATOR_X bool "Salvator-X board" imply R8A7795 @@ -148,6 +154,7 @@ source "board/renesas/salvator-x/Kconfig" source "board/renesas/ulcb/Kconfig" source "board/beacon/beacon-rzg2m/Kconfig" source "board/hoperun/hihope-rzg2/Kconfig" +source "board/silinux/ek874/Kconfig"
config MULTI_DTB_FIT_UNCOMPRESS_SZ default 0x80000 if TARGET_HIHOPE_RZG2 diff --git a/board/silinux/ek874/Kconfig b/board/silinux/ek874/Kconfig new file mode 100644 index 0000000000..60b390a121 --- /dev/null +++ b/board/silinux/ek874/Kconfig @@ -0,0 +1,15 @@ +if TARGET_SILINUX_EK874 + +config SYS_SOC + default "rmobile" + +config SYS_BOARD + default "ek874" + +config SYS_VENDOR + default "silinux" + +config SYS_CONFIG_NAME + default "silinux-ek874" + +endif diff --git a/board/silinux/ek874/MAINTAINERS b/board/silinux/ek874/MAINTAINERS new file mode 100644 index 0000000000..57a71b83b2 --- /dev/null +++ b/board/silinux/ek874/MAINTAINERS @@ -0,0 +1,6 @@ +SILINUX_EK874 BOARD +M: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com +S: Maintained +F: board/silinux/ek874/ +F: include/configs/silinux-ek874.h +F: configs/silinux_ek874_defconfig diff --git a/board/silinux/ek874/Makefile b/board/silinux/ek874/Makefile new file mode 100644 index 0000000000..32a3a00990 --- /dev/null +++ b/board/silinux/ek874/Makefile @@ -0,0 +1,9 @@ +# +# board/silinux/ek874/Makefile +# +# Copyright (C) 2021 Renesas Electronics Corporation +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := ek874.o ../../renesas/rcar-common/common.o diff --git a/board/silinux/ek874/ek874.c b/board/silinux/ek874/ek874.c new file mode 100644 index 0000000000..5a219cd98d --- /dev/null +++ b/board/silinux/ek874/ek874.c @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board/silinux/ek874/ek874.c + * This file is ek874 board support. + * + * Copyright (C) 2021 Renesas Electronics Corporation + */ + +#include <common.h> +#include <asm/global_data.h> +#include <asm/io.h> + +#define RST_BASE 0xE6160000 +#define RST_CA53RESCNT (RST_BASE + 0x44) +#define RST_CA53_CODE 0x5A5A000F + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_TEXT_BASE + 0x50000; + + return 0; +} + +void reset_cpu(ulong addr) +{ + writel(RST_CA53_CODE, RST_CA53RESCNT); +} diff --git a/configs/silinux_ek874_defconfig b/configs/silinux_ek874_defconfig new file mode 100644 index 0000000000..442e24a3d7 --- /dev/null +++ b/configs/silinux_ek874_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_RMOBILE=y +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3F0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_RCAR_GEN3=y +CONFIG_TARGET_SILINUX_EK874=y +# CONFIG_BOARD_EARLY_INIT_F is not set +# CONFIG_SPL is not set +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_RENESAS=y +CONFIG_DEFAULT_DEVICE_TREE="r8a774c0-ek874-u-boot" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_FIT=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_DEFAULT_FDT_FILE="r8a774c0-ek874.dtb" +CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_BLK=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_DM_GPIO=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_USE_4K_SECTORS=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_RENESAS_SDHI=y +CONFIG_BITBANGMII=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_RENESAS_RAVB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SCIF_CONSOLE=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SMBIOS_MANUFACTURER="" diff --git a/include/configs/silinux-ek874.h b/include/configs/silinux-ek874.h new file mode 100644 index 0000000000..25c0cd2335 --- /dev/null +++ b/include/configs/silinux-ek874.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * include/configs/silinux-ek874.h + * This file is Silicon Linux EK874 board configuration. + * + * Copyright (C) 2021 Renesas Electronics Corporation + */ + +#ifndef __SILINUX_EK874_H +#define __SILINUX_EK874_H + +#include "rcar-gen3-common.h" + +/* Ethernet RAVB */ +#define CONFIG_BITBANGMII_MULTI + +/* Generic Timer Definitions (use in assembler source) */ +#define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */ + +#endif /* __SILINUX_EK874_H */ diff --git a/include/dt-bindings/display/tda998x.h b/include/dt-bindings/display/tda998x.h new file mode 100644 index 0000000000..746831ff39 --- /dev/null +++ b/include/dt-bindings/display/tda998x.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef _DT_BINDINGS_TDA998X_H +#define _DT_BINDINGS_TDA998X_H + +#define TDA998x_SPDIF 1 +#define TDA998x_I2S 2 + +#endif /*_DT_BINDINGS_TDA998X_H */
Enable building SPL for EK874 board which is based on R8A774C0 SoC.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- arch/arm/mach-rmobile/Makefile | 2 +- board/silinux/ek874/Makefile | 4 ++++ configs/silinux_ek874_defconfig | 2 +- 3 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rmobile/Makefile b/arch/arm/mach-rmobile/Makefile index 3206bce722..9f56af465e 100644 --- a/arch/arm/mach-rmobile/Makefile +++ b/arch/arm/mach-rmobile/Makefile @@ -22,7 +22,7 @@ cmd_objcopy = $(OBJCOPY) --gap-fill=0x00 $(OBJCOPYFLAGS) \ spl/u-boot-spl.srec: spl/u-boot-spl FORCE $(call if_changed,objcopy)
-ifneq ($(CONFIG_R8A77990)$(CONFIG_R8A77995),) +ifneq ($(CONFIG_R8A774C0)$(CONFIG_R8A77990)$(CONFIG_R8A77995),) # # The first 6 generate statements generate the R-Car Gen3 SCIF loader header. # The subsequent generate statements represent the following chunk of assembler diff --git a/board/silinux/ek874/Makefile b/board/silinux/ek874/Makefile index 32a3a00990..4c8f0925f1 100644 --- a/board/silinux/ek874/Makefile +++ b/board/silinux/ek874/Makefile @@ -6,4 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifdef CONFIG_SPL_BUILD +obj-y := ../../renesas/rcar-common/gen3-spl.o +else obj-y := ek874.o ../../renesas/rcar-common/common.o +endif diff --git a/configs/silinux_ek874_defconfig b/configs/silinux_ek874_defconfig index 442e24a3d7..dcd75604a2 100644 --- a/configs/silinux_ek874_defconfig +++ b/configs/silinux_ek874_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3F0000 @@ -9,7 +10,6 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_SILINUX_EK874=y # CONFIG_BOARD_EARLY_INIT_F is not set -# CONFIG_SPL is not set CONFIG_SOC_DEVICE=y CONFIG_SOC_DEVICE_RENESAS=y CONFIG_DEFAULT_DEVICE_TREE="r8a774c0-ek874-u-boot"
Lad Prabhakar
