[U-Boot] [PATCH] arm: socfpga: Enabling U-Boot environment support in QSPI
Enabling the support of storing U-Boot environment within serial NOR flash. By default, its still store into SDMMC
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de --- include/configs/socfpga_common.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index a09e906..c1eef54 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -291,6 +291,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_ENV_OFFSET 512 /* just after the MBR */ #endif
+/* Environment for QSPI boot */ +#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) && !defined(CONFIG_ENV_OFFSET) +#define CONFIG_ENV_OFFSET 0x00100000 +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#endif + /* * mtd partitioning for serial NOR flash *
Chin Liang See
