Re: [U-Boot] [PATCH] mtest: Disable dcache during test
On 08/11/2012 21:47, Andrew Dyer wrote:
I agree with Mike, use the current dcache settings. U-boot has always assumed the user knew what they were doing. If you want to print a small message with the dcache setting that makes sense to me, but no big warning.
Then, something like the following at runtime in the first lines printed my mtest?
dcache state: on
Best regards, Benoît
dcache state: on
i'd be fine with that. something like below (if you want to test & post, that'd be good). -mike
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 18f0a3f..5628f6a 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -651,8 +651,10 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) else iteration_limit = 0;
+ printf("Testing %08x ... %08x (dcache: %s):\n", (uint)start, (uint)end, + dcache_status() ? "on" : "off"); + #if defined(CONFIG_SYS_ALT_MEMTEST) - printf ("Testing %08x ... %08x:\n", (uint)start, (uint)end); debug("%s:%d: start 0x%p end 0x%p\n", __FUNCTION__, __LINE__, start, end);
dcache state: on
- printf("Testing %08x ... %08x (dcache: %s):\n", (uint)start,
(uint)end,
OK, I'll do that next week.
mtest tests many types of memory accesses in many different conditions. If dcache is enabled, memory accesses are likely bursts, and some memory accesses are simply skipped. Hence, mtest results may change depending on dcache state.
This patch prints the dcache state at the beginning of mtest so as to keep the user informed of the test conditions.
Signed-off-by: Mike Frysinger vapier@gentoo.org Tested-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de Cc: Mike Frysinger vapier@gentoo.org --- .../common/cmd_mem.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git u-boot-4d3c95f.orig/common/cmd_mem.c u-boot-4d3c95f/common/cmd_mem.c index 18f0a3f..5628f6a 100644 --- u-boot-4d3c95f.orig/common/cmd_mem.c +++ u-boot-4d3c95f/common/cmd_mem.c @@ -651,8 +651,10 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) else iteration_limit = 0;
Signed-off-by: Mike Frysinger vapier@gentoo.org Tested-by: Beno??t Th??baudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de Cc: Mike Frysinger vapier@gentoo.org
NAK, this breaks x86 which has no dcache_status.
Hi Tom,
IIRC the general idea of printing the cache status in mtest had already been NAKed (though not formally) by Wolfgang.
Amicalement,
Hi Albert, Tom,
On Thursday, October 4, 2012 1:03:48 PM, Albert ARIBAUD wrote:
Hi Tom,
Indeed. This subject has already been closed. Perhaps the patch status had just not been updated in Patchwork.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 10/04/12 04:13, Benoît Thébaudeau wrote:
Hi Albert, Tom,
Hi Tom,
OK, thanks guys.
- -- Tom
Hi Mike,
dcache state: on
I'd disagree with this solution; one can easily overlook casual test messages like these. To me it is better that the person doing mtest not trust the cache state at all and check / set it.
Amicalement,
Albert ARIBAUD
Benoît Thébaudeau
Mike Frysinger
