[PATCH v4 0/2] Enable split mode in binman
This series extends the functionality of ti-secure-rom entry type in binman to support enabling of split mode vs. the default lockstep mode via changing the field in the x509 certificate. A DONOTMERGE patch is added to give an example of how this can be done via the binman.dtsi
Changes in v4: - Simon: - correct function comments for setting bit for split and lockstep mode Changes in v3: - Simon: - added entries.rst change - updated function comments - removed inconsistency in setting bootcore_opts to 32
Changes in v2: - Udit: - included TRM link in commit message - added DONOTMERGE patch showing example
Neha Malcom Francis (2): binman: openssl: x509: ti_secure_rom: Add support for bootcore_opts DONOTMERGE: arm: dts: k3-j7200-binman: Enable split mode for MCU R5
arch/arm/dts/k3-j7200-binman.dtsi | 3 +++ tools/binman/btool/openssl.py | 6 ++++-- tools/binman/entries.rst | 1 + tools/binman/etype/ti_secure_rom.py | 11 +++++++++-- tools/binman/etype/x509_cert.py | 3 ++- tools/binman/test/297_ti_secure_rom.dts | 1 + 6 files changed, 20 insertions(+), 5 deletions(-)
According to the TRMs of K3 platform of devices, the ROM boot image format specifies a "Core Options Field" that provides the capability to set the boot core in lockstep when set to 0 or to split mode when set to 2. Add support for providing the same from the binman DTS. Also modify existing test case for ensuring future coverage.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Link to J721E TRM: https://www.ti.com/lit/zip/spruil1 Section 4.5.4.1 Boot Info
Changes in v4: - corrected function comments, 0 for lockstep, 2 for split mode
Changes in v3: - updated function comments - removed inconsistency in setting bootcore_opts to 32
Changes in v2: - included TRM link in commit message
tools/binman/btool/openssl.py | 6 ++++-- tools/binman/entries.rst | 1 + tools/binman/etype/ti_secure_rom.py | 11 +++++++++-- tools/binman/etype/x509_cert.py | 3 ++- tools/binman/test/297_ti_secure_rom.dts | 1 + 5 files changed, 17 insertions(+), 5 deletions(-)
diff --git a/tools/binman/btool/openssl.py b/tools/binman/btool/openssl.py index aad3b61ae2..7ee2683ab2 100644 --- a/tools/binman/btool/openssl.py +++ b/tools/binman/btool/openssl.py @@ -155,6 +155,7 @@ authInPlace = INTEGER:2 C, ST, L, O, OU, CN and emailAddress cert_type (int): Certification type bootcore (int): Booting core + bootcore_opts(int): Booting core option, lockstep (0) or split (2) mode load_addr (int): Load address of image sha (int): Hash function
@@ -225,7 +226,7 @@ emailAddress = {req_dist_name_dict['emailAddress']} imagesize_sbl, hashval_sbl, load_addr_sysfw, imagesize_sysfw, hashval_sysfw, load_addr_sysfw_data, imagesize_sysfw_data, hashval_sysfw_data, sysfw_inner_cert_ext_boot_block, - dm_data_ext_boot_block): + dm_data_ext_boot_block, bootcore_opts): """Create a certificate
Args: @@ -241,6 +242,7 @@ emailAddress = {req_dist_name_dict['emailAddress']} bootcore (int): Booting core load_addr (int): Load address of image sha (int): Hash function + bootcore_opts (int): Booting core option, lockstep (0) or split (2) mode
Returns: str: Tool output @@ -285,7 +287,7 @@ sysfw_data=SEQUENCE:sysfw_data [sbl] compType = INTEGER:1 bootCore = INTEGER:16 -compOpts = INTEGER:0 +compOpts = INTEGER:{bootcore_opts} destAddr = FORMAT:HEX,OCT:{load_addr:08x} compSize = INTEGER:{imagesize_sbl} shaType = OID:{sha_type} diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index e7b4e9380e..2402adb3d9 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1944,6 +1944,7 @@ Properties / Entry arguments: - core: core on which bootloader runs, valid cores are 'secure' and 'public' - content: phandle of SPL in case of legacy bootflow or phandles of component binaries in case of combined bootflow + - core-opts (optional): lockstep (0) or split (2) mode set to 0 by default
The following properties are only for generating a combined bootflow binary: - sysfw-inner-cert: boolean if binary contains sysfw inner certificate diff --git a/tools/binman/etype/ti_secure_rom.py b/tools/binman/etype/ti_secure_rom.py index 9a7ac9e9e0..f6fc3f90f8 100644 --- a/tools/binman/etype/ti_secure_rom.py +++ b/tools/binman/etype/ti_secure_rom.py @@ -32,6 +32,7 @@ class Entry_ti_secure_rom(Entry_x509_cert): - core: core on which bootloader runs, valid cores are 'secure' and 'public' - content: phandle of SPL in case of legacy bootflow or phandles of component binaries in case of combined bootflow + - core-opts (optional): lockstep (0) or split (2) mode set to 0 by default
The following properties are only for generating a combined bootflow binary: - sysfw-inner-cert: boolean if binary contains sysfw inner certificate @@ -69,6 +70,7 @@ class Entry_ti_secure_rom(Entry_x509_cert): self.sw_rev = fdt_util.GetInt(self._node, 'sw-rev', 1) self.sha = fdt_util.GetInt(self._node, 'sha', 512) self.core = fdt_util.GetString(self._node, 'core', 'secure') + self.bootcore_opts = fdt_util.GetInt(self._node, 'core-opts') self.key_fname = self.GetEntryArgsOrProps([ EntryArg('keyfile', str)], required=True)[0] if self.combined: @@ -97,17 +99,19 @@ class Entry_ti_secure_rom(Entry_x509_cert): bytes content of the entry, which is the certificate binary for the provided data """ + if self.bootcore_opts is None: + self.bootcore_opts = 0 + if self.core == 'secure': if self.countersign: self.cert_type = 3 else: self.cert_type = 2 self.bootcore = 0 - self.bootcore_opts = 32 else: self.cert_type = 1 self.bootcore = 16 - self.bootcore_opts = 0 + return super().GetCertificate(required=required, type='rom')
def CombinedGetCertificate(self, required): @@ -126,6 +130,9 @@ class Entry_ti_secure_rom(Entry_x509_cert): self.num_comps = 3 self.sha_type = SHA_OIDS[self.sha]
+ if self.bootcore_opts is None: + self.bootcore_opts = 0 + # sbl self.content = fdt_util.GetPhandleList(self._node, 'content-sbl') input_data_sbl = self.GetContents(required) diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py index d028cfe38c..fc0bb12278 100644 --- a/tools/binman/etype/x509_cert.py +++ b/tools/binman/etype/x509_cert.py @@ -136,7 +136,8 @@ class Entry_x509_cert(Entry_collection): imagesize_sysfw_data=self.imagesize_sysfw_data, hashval_sysfw_data=self.hashval_sysfw_data, sysfw_inner_cert_ext_boot_block=self.sysfw_inner_cert_ext_boot_block, - dm_data_ext_boot_block=self.dm_data_ext_boot_block + dm_data_ext_boot_block=self.dm_data_ext_boot_block, + bootcore_opts=self.bootcore_opts ) if stdout is not None: data = tools.read_file(output_fname) diff --git a/tools/binman/test/297_ti_secure_rom.dts b/tools/binman/test/297_ti_secure_rom.dts index d1313769f4..1a3eca9425 100644 --- a/tools/binman/test/297_ti_secure_rom.dts +++ b/tools/binman/test/297_ti_secure_rom.dts @@ -9,6 +9,7 @@ binman { ti-secure-rom { content = <&unsecure_binary>; + core-opts = <2>; }; unsecure_binary: blob-ext { filename = "ti_unsecure.bin";
Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-dm, thanks!
Set boot core-opts to enable split mode for MCU R5 cluster by default. This patch serves to demonstrate how this can be done.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- No change since v2
arch/arm/dts/k3-j7200-binman.dtsi | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi index 14f7dea65e..025a0bd071 100644 --- a/arch/arm/dts/k3-j7200-binman.dtsi +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -55,6 +55,7 @@ <&combined_dm_cfg>, <&sysfw_inner_cert>; combined; dm-data; + core-opts = <2>; sysfw-inner-cert; keyfile = "custMpk.pem"; sw-rev = <1>; @@ -100,6 +101,7 @@ <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; combined; dm-data; + core-opts = <2>; sysfw-inner-cert; keyfile = "custMpk.pem"; sw-rev = <1>; @@ -146,6 +148,7 @@ <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; combined; dm-data; + core-opts = <2>; content-sbl = <&u_boot_spl_unsigned>; load = <0x41c00000>; content-sysfw = <&ti_fs_gp>;
No change since v2
Neha Malcom Francis
