[PATCH 1/6] misc: sentinel: s400_api: Add get_events API
Add get_events API to retrieve any singular events that has occurred since the FW has started from sentinel
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/s400_api.h | 2 ++ drivers/misc/sentinel/s400_api.c | 45 ++++++++++++++++++++++++++++++++ 2 files changed, 47 insertions(+)
diff --git a/arch/arm/include/asm/mach-imx/s400_api.h b/arch/arm/include/asm/mach-imx/s400_api.h index 4819f20..79539b7 100644 --- a/arch/arm/include/asm/mach-imx/s400_api.h +++ b/arch/arm/include/asm/mach-imx/s400_api.h @@ -18,6 +18,7 @@ #define AHAB_FWD_LIFECYCLE_UP_REQ_CID 0x95 #define AHAB_READ_FUSE_REQ_CID 0x97 #define AHAB_GET_FW_VERSION_CID 0x9D +#define AHAB_GET_EVENTS_REQ_CID 0xA2 #define AHAB_RELEASE_RDC_REQ_CID 0xC4 #define AHAB_GET_FW_STATUS_CID 0xC5 #define AHAB_WRITE_FUSE_REQ_CID 0xD6 @@ -58,5 +59,6 @@ int ahab_dump_buffer(u32 *buffer, u32 buffer_length); int ahab_get_info(struct sentinel_get_info_data *info, u32 *response); int ahab_get_fw_status(u32 *status, u32 *response); int ahab_release_m33_trout(void); +int ahab_get_events(u32 *events, u32 *events_cnt, u32 *response);
#endif diff --git a/drivers/misc/sentinel/s400_api.c b/drivers/misc/sentinel/s400_api.c index 65032f7..c6b4ef5 100644 --- a/drivers/misc/sentinel/s400_api.c +++ b/drivers/misc/sentinel/s400_api.c @@ -445,3 +445,48 @@ int ahab_release_m33_trout(void)
return ret; } + +int ahab_get_events(u32 *events, u32 *events_cnt, u32 *response) +{ + struct udevice *dev = gd->arch.s400_dev; + int size = sizeof(struct sentinel_msg); + struct sentinel_msg msg; + int ret, i = 0; + u32 actual_events; + + if (!dev) { + printf("s400 dev is not initialized\n"); + return -ENODEV; + } + + if (!events || !events_cnt || *events_cnt == 0) { + printf("Invalid parameters for %s\n", __func__); + return -EINVAL; + } + + msg.version = AHAB_VERSION; + msg.tag = AHAB_CMD_TAG; + msg.size = 1; + msg.command = AHAB_GET_EVENTS_REQ_CID; + + ret = misc_call(dev, false, &msg, size, &msg, size); + if (ret) + printf("Error: %s: ret %d, response 0x%x\n", + __func__, ret, msg.data[0]); + + if (response) + *response = msg.data[0]; + + if (!ret) { + actual_events = msg.data[1] & 0xffff; + if (*events_cnt < actual_events) + actual_events = *events_cnt; + + for (; i < actual_events; i++) + events[i] = msg.data[i + 2]; + + *events_cnt = actual_events; + } + + return ret; +}
For ahab_status command, support to get and decode AHAB events
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/s400_api.h | 99 +++++++++++ arch/arm/mach-imx/imx9/ahab.c | 286 ++++++++++++++++++++++++++++--- 2 files changed, 359 insertions(+), 26 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/s400_api.h b/arch/arm/include/asm/mach-imx/s400_api.h index 79539b7..c87a7c1 100644 --- a/arch/arm/include/asm/mach-imx/s400_api.h +++ b/arch/arm/include/asm/mach-imx/s400_api.h @@ -10,6 +10,105 @@ #define AHAB_CMD_TAG 0x17 #define AHAB_RESP_TAG 0xe1
+/* ELE commands */ +#define ELE_PING_REQ (0x01) +#define ELE_FW_AUTH_REQ (0x02) +#define ELE_RESTART_RST_TIMER_REQ (0x04) +#define ELE_DUMP_DEBUG_BUFFER_REQ (0x21) +#define ELE_OEM_CNTN_AUTH_REQ (0x87) +#define ELE_VERIFY_IMAGE_REQ (0x88) +#define ELE_RELEASE_CONTAINER_REQ (0x89) +#define ELE_WRITE_SECURE_FUSE_REQ (0x91) +#define ELE_FWD_LIFECYCLE_UP_REQ (0x95) +#define ELE_READ_FUSE_REQ (0x97) +#define ELE_GET_FW_VERSION_REQ (0x9D) +#define ELE_RET_LIFECYCLE_UP_REQ (0xA0) +#define ELE_GET_EVENTS_REQ (0xA2) +#define ELE_ENABLE_PATCH_REQ (0xC3) +#define ELE_RELEASE_RDC_REQ (0xC4) +#define ELE_GET_FW_STATUS_REQ (0xC5) +#define ELE_ENABLE_OTFAD_REQ (0xC6) +#define ELE_RESET_REQ (0xC7) +#define ELE_UPDATE_OTP_CLKDIV_REQ (0xD0) +#define ELE_POWER_DOWN_REQ (0xD1) +#define ELE_ENABLE_APC_REQ (0xD2) +#define ELE_ENABLE_RTC_REQ (0xD3) +#define ELE_DEEP_POWER_DOWN_REQ (0xD4) +#define ELE_STOP_RST_TIMER_REQ (0xD5) +#define ELE_WRITE_FUSE_REQ (0xD6) +#define ELE_RELEASE_CAAM_REQ (0xD7) +#define ELE_RESET_A35_CTX_REQ (0xD8) +#define ELE_MOVE_TO_UNSECURED_REQ (0xD9) +#define ELE_GET_INFO_REQ (0xDA) +#define ELE_ATTEST_REQ (0xDB) +#define ELE_RELEASE_PATCH_REQ (0xDC) +#define ELE_OTP_SEQ_SWITH_REQ (0xDD) + +/* ELE failure indications */ +#define ELE_ROM_PING_FAILURE_IND (0x0A) +#define ELE_FW_PING_FAILURE_IND (0x1A) +#define ELE_BAD_SIGNATURE_FAILURE_IND (0xF0) +#define ELE_BAD_HASH_FAILURE_IND (0xF1) +#define ELE_INVALID_LIFECYCLE_IND (0xF2) +#define ELE_PERMISSION_DENIED_FAILURE_IND (0xF3) +#define ELE_INVALID_MESSAGE_FAILURE_IND (0xF4) +#define ELE_BAD_VALUE_FAILURE_IND (0xF5) +#define ELE_BAD_FUSE_ID_FAILURE_IND (0xF6) +#define ELE_BAD_CONTAINER_FAILURE_IND (0xF7) +#define ELE_BAD_VERSION_FAILURE_IND (0xF8) +#define ELE_INVALID_KEY_FAILURE_IND (0xF9) +#define ELE_BAD_KEY_HASH_FAILURE_IND (0xFA) +#define ELE_NO_VALID_CONTAINER_FAILURE_IND (0xFB) +#define ELE_BAD_CERTIFICATE_FAILURE_IND (0xFC) +#define ELE_BAD_UID_FAILURE_IND (0xFD) +#define ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND (0xFE) +#define ELE_MUST_SIGNED_FAILURE_IND (0xE0) +#define ELE_NO_AUTHENTICATION_FAILURE_IND (0xEE) +#define ELE_BAD_SRK_SET_FAILURE_IND (0xEF) +#define ELE_UNALIGNED_PAYLOAD_FAILURE_IND (0xA6) +#define ELE_WRONG_SIZE_FAILURE_IND (0xA7) +#define ELE_ENCRYPTION_FAILURE_IND (0xA8) +#define ELE_DECRYPTION_FAILURE_IND (0xA9) +#define ELE_OTP_PROGFAIL_FAILURE_IND (0xAA) +#define ELE_OTP_LOCKED_FAILURE_IND (0xAB) +#define ELE_OTP_INVALID_IDX_FAILURE_IND (0xAD) +#define ELE_TIME_OUT_FAILURE_IND (0xB0) +#define ELE_BAD_PAYLOAD_FAILURE_IND (0xB1) +#define ELE_WRONG_ADDRESS_FAILURE_IND (0xB4) +#define ELE_DMA_FAILURE_IND (0xB5) +#define ELE_DISABLED_FEATURE_FAILURE_IND (0xB6) +#define ELE_MUST_ATTEST_FAILURE_IND (0xB7) +#define ELE_RNG_NOT_STARTED_FAILURE_IND (0xB8) +#define ELE_CRC_ERROR_IND (0xB9) +#define ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND (0xBB) +#define ELE_INCONSISTENT_PAR_FAILURE_IND (0xBC) +#define ELE_RNG_INST_FAILURE_FAILURE_IND (0xBD) +#define ELE_LOCKED_REG_FAILURE_IND (0xBE) +#define ELE_BAD_ID_FAILURE_IND (0xBF) +#define ELE_INVALID_OPERATION_FAILURE_IND (0xC0) +#define ELE_NON_SECURE_STATE_FAILURE_IND (0xC1) +#define ELE_MSG_TRUNCATED_IND (0xC2) +#define ELE_BAD_IMAGE_NUM_FAILURE_IND (0xC3) +#define ELE_BAD_IMAGE_ADDR_FAILURE_IND (0xC4) +#define ELE_BAD_IMAGE_PARAM_FAILURE_IND (0xC5) +#define ELE_BAD_IMAGE_TYPE_FAILURE_IND (0xC6) +#define ELE_CORRUPTED_SRK_FAILURE_IND (0xD0) +#define ELE_OUT_OF_MEMORY_IND (0xD1) +#define ELE_CSTM_FAILURE_IND (0xCF) +#define ELE_OLD_VERSION_FAILURE_IND (0xCE) +#define ELE_WRONG_BOOT_MODE_FAILURE_IND (0xCD) +#define ELE_APC_ALREADY_ENABLED_FAILURE_IND (0xCB) +#define ELE_RTC_ALREADY_ENABLED_FAILURE_IND (0xCC) +#define ELE_ABORT_IND (0xFF) + +/* ELE IPC identifier */ +#define ELE_IPC_MU_RTD (0x1) +#define ELE_IPC_MU_APD (0x2) + +/* ELE Status*/ +#define ELE_SUCCESS_IND (0xD6) +#define ELE_FAILURE_IND (0x29) + #define AHAB_LOG_CID 0x21 #define AHAB_AUTH_OEM_CTNR_CID 0x87 #define AHAB_VERIFY_IMG_CID 0x88 diff --git a/arch/arm/mach-imx/imx9/ahab.c b/arch/arm/mach-imx/imx9/ahab.c index 6aa9496..ac69975 100644 --- a/arch/arm/mach-imx/imx9/ahab.c +++ b/arch/arm/mach-imx/imx9/ahab.c @@ -22,36 +22,239 @@ DECLARE_GLOBAL_DATA_PTR; #define IMG_CONTAINER_BASE (0x80000000UL) #define IMG_CONTAINER_END_BASE (IMG_CONTAINER_BASE + 0xFFFFUL)
-#define AHAB_NO_AUTHENTICATION_IND 0xee -#define AHAB_BAD_KEY_HASH_IND 0xfa -#define AHAB_INVALID_KEY_IND 0xf9 -#define AHAB_BAD_SIGNATURE_IND 0xf0 -#define AHAB_BAD_HASH_IND 0xf1 +#define AHAB_MAX_EVENTS 8 + +static char *ele_ipc_str[] = { + "IPC = MU RTD (0x1)\n", + "IPC = MU APD (0x2)\n", + "IPC = INVALID\n", + NULL +}; + +static char *ele_status_str[] = { + "STA = ELE_SUCCESS_IND (0xD6)\n", + "STA = ELE_FAILURE_IND (0x29)\n", + "STA = INVALID\n", + NULL +}; + +static char *ele_cmd_str[] = { + "CMD = ELE_PING_REQ (0x01)\n", + "CMD = ELE_FW_AUTH_REQ (0x02)\n", + "CMD = ELE_RESTART_RST_TIMER_REQ (0x04)\n", + "CMD = ELE_DUMP_DEBUG_BUFFER_REQ (0x21)\n", + "CMD = ELE_OEM_CNTN_AUTH_REQ (0x87)\n", + "CMD = ELE_VERIFY_IMAGE_REQ (0x88)\n", + "CMD = ELE_RELEASE_CONTAINER_REQ (0x89)\n", + "CMD = ELE_WRITE_SECURE_FUSE_REQ (0x91)\n", + "CMD = ELE_FWD_LIFECYCLE_UP_REQ (0x95)\n", + "CMD = ELE_READ_FUSE_REQ (0x97)\n", + "CMD = ELE_GET_FW_VERSION_REQ (0x9D)\n", + "CMD = ELE_RET_LIFECYCLE_UP_REQ (0xA0)\n", + "CMD = ELE_GET_EVENTS_REQ (0xA2)\n", + "CMD = ELE_ENABLE_PATCH_REQ (0xC3)\n", + "CMD = ELE_RELEASE_RDC_REQ (0xC4)\n", + "CMD = ELE_GET_FW_STATUS_REQ (0xC5)\n", + "CMD = ELE_ENABLE_OTFAD_REQ (0xC6)\n", + "CMD = ELE_RESET_REQ (0xC7)\n", + "CMD = ELE_UPDATE_OTP_CLKDIV_REQ (0xD0)\n", + "CMD = ELE_POWER_DOWN_REQ (0xD1)\n", + "CMD = ELE_ENABLE_APC_REQ (0xD2)\n", + "CMD = ELE_ENABLE_RTC_REQ (0xD3)\n", + "CMD = ELE_DEEP_POWER_DOWN_REQ (0xD4)\n", + "CMD = ELE_STOP_RST_TIMER_REQ (0xD5)\n", + "CMD = ELE_WRITE_FUSE_REQ (0xD6)\n", + "CMD = ELE_RELEASE_CAAM_REQ (0xD7)\n", + "CMD = ELE_RESET_A35_CTX_REQ (0xD8)\n", + "CMD = ELE_MOVE_TO_UNSECURED_REQ (0xD9)\n", + "CMD = ELE_GET_INFO_REQ (0xDA)\n", + "CMD = ELE_ATTEST_REQ (0xDB)\n", + "CMD = ELE_RELEASE_PATCH_REQ (0xDC)\n", + "CMD = ELE_OTP_SEQ_SWITH_REQ (0xDD)\n", + "CMD = INVALID\n", + NULL +}; + +static char *ele_ind_str[] = { + "IND = ELE_ROM_PING_FAILURE_IND (0x0A)\n", + "IND = ELE_FW_PING_FAILURE_IND (0x1A)\n", + "IND = ELE_BAD_SIGNATURE_FAILURE_IND (0xF0)\n", + "IND = ELE_BAD_HASH_FAILURE_IND (0xF1)\n", + "IND = ELE_INVALID_LIFECYCLE_IND (0xF2)\n", + "IND = ELE_PERMISSION_DENIED_FAILURE_IND (0xF3)\n", + "IND = ELE_INVALID_MESSAGE_FAILURE_IND (0xF4)\n", + "IND = ELE_BAD_VALUE_FAILURE_IND (0xF5)\n", + "IND = ELE_BAD_FUSE_ID_FAILURE_IND (0xF6)\n", + "IND = ELE_BAD_CONTAINER_FAILURE_IND (0xF7)\n", + "IND = ELE_BAD_VERSION_FAILURE_IND (0xF8)\n", + "IND = ELE_INVALID_KEY_FAILURE_IND (0xF9)\n", + "IND = ELE_BAD_KEY_HASH_FAILURE_IND (0xFA)\n", + "IND = ELE_NO_VALID_CONTAINER_FAILURE_IND (0xFB)\n", + "IND = ELE_BAD_CERTIFICATE_FAILURE_IND (0xFC)\n", + "IND = ELE_BAD_UID_FAILURE_IND (0xFD)\n", + "IND = ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND (0xFE)\n", + "IND = ELE_MUST_SIGNED_FAILURE_IND (0xE0)\n", + "IND = ELE_NO_AUTHENTICATION_FAILURE_IND (0xEE)\n", + "IND = ELE_BAD_SRK_SET_FAILURE_IND (0xEF)\n", + "IND = ELE_UNALIGNED_PAYLOAD_FAILURE_IND (0xA6)\n", + "IND = ELE_WRONG_SIZE_FAILURE_IND (0xA7)\n", + "IND = ELE_ENCRYPTION_FAILURE_IND (0xA8)\n", + "IND = ELE_DECRYPTION_FAILURE_IND (0xA9)\n", + "IND = ELE_OTP_PROGFAIL_FAILURE_IND (0xAA)\n", + "IND = ELE_OTP_LOCKED_FAILURE_IND (0xAB)\n", + "IND = ELE_OTP_INVALID_IDX_FAILURE_IND (0xAD)\n", + "IND = ELE_TIME_OUT_FAILURE_IND (0xB0)\n", + "IND = ELE_BAD_PAYLOAD_FAILURE_IND (0xB1)\n", + "IND = ELE_WRONG_ADDRESS_FAILURE_IND (0xB4)\n", + "IND = ELE_DMA_FAILURE_IND (0xB5)\n", + "IND = ELE_DISABLED_FEATURE_FAILURE_IND (0xB6)\n", + "IND = ELE_MUST_ATTEST_FAILURE_IND (0xB7)\n", + "IND = ELE_RNG_NOT_STARTED_FAILURE_IND (0xB8)\n", + "IND = ELE_CRC_ERROR_IND (0xB9)\n", + "IND = ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND (0xBB)\n", + "IND = ELE_INCONSISTENT_PAR_FAILURE_IND (0xBC)\n", + "IND = ELE_RNG_INST_FAILURE_FAILURE_IND (0xBD)\n", + "IND = ELE_LOCKED_REG_FAILURE_IND (0xBE)\n", + "IND = ELE_BAD_ID_FAILURE_IND (0xBF)\n", + "IND = ELE_INVALID_OPERATION_FAILURE_IND (0xC0)\n", + "IND = ELE_NON_SECURE_STATE_FAILURE_IND (0xC1)\n", + "IND = ELE_MSG_TRUNCATED_IND (0xC2)\n", + "IND = ELE_BAD_IMAGE_NUM_FAILURE_IND (0xC3)\n", + "IND = ELE_BAD_IMAGE_ADDR_FAILURE_IND (0xC4)\n", + "IND = ELE_BAD_IMAGE_PARAM_FAILURE_IND (0xC5)\n", + "IND = ELE_BAD_IMAGE_TYPE_FAILURE_IND (0xC6)\n", + "IND = ELE_CORRUPTED_SRK_FAILURE_IND (0xD0)\n", + "IND = ELE_OUT_OF_MEMORY_IND (0xD1)\n", + "IND = ELE_CSTM_FAILURE_IND (0xCF)\n", + "IND = ELE_OLD_VERSION_FAILURE_IND (0xCE)\n", + "IND = ELE_WRONG_BOOT_MODE_FAILURE_IND (0xCD)\n", + "IND = ELE_APC_ALREADY_ENABLED_FAILURE_IND (0xCB)\n", + "IND = ELE_RTC_ALREADY_ENABLED_FAILURE_IND (0xCC)\n", + "IND = ELE_ABORT_IND (0xFF)\n", + "IND = INVALID\n", + NULL +}; + +static u8 ele_cmd[] = { + ELE_PING_REQ, + ELE_FW_AUTH_REQ, + ELE_RESTART_RST_TIMER_REQ, + ELE_DUMP_DEBUG_BUFFER_REQ, + ELE_OEM_CNTN_AUTH_REQ, + ELE_VERIFY_IMAGE_REQ, + ELE_RELEASE_CONTAINER_REQ, + ELE_WRITE_SECURE_FUSE_REQ, + ELE_FWD_LIFECYCLE_UP_REQ, + ELE_READ_FUSE_REQ, + ELE_GET_FW_VERSION_REQ, + ELE_RET_LIFECYCLE_UP_REQ, + ELE_GET_EVENTS_REQ, + ELE_ENABLE_PATCH_REQ, + ELE_RELEASE_RDC_REQ, + ELE_GET_FW_STATUS_REQ, + ELE_ENABLE_OTFAD_REQ, + ELE_RESET_REQ, + ELE_UPDATE_OTP_CLKDIV_REQ, + ELE_POWER_DOWN_REQ, + ELE_ENABLE_APC_REQ, + ELE_ENABLE_RTC_REQ, + ELE_DEEP_POWER_DOWN_REQ, + ELE_STOP_RST_TIMER_REQ, + ELE_WRITE_FUSE_REQ, + ELE_RELEASE_CAAM_REQ, + ELE_RESET_A35_CTX_REQ, + ELE_MOVE_TO_UNSECURED_REQ, + ELE_GET_INFO_REQ, + ELE_ATTEST_REQ, + ELE_RELEASE_PATCH_REQ, + ELE_OTP_SEQ_SWITH_REQ +}; + +static u8 ele_ind[] = { + ELE_ROM_PING_FAILURE_IND, + ELE_FW_PING_FAILURE_IND, + ELE_BAD_SIGNATURE_FAILURE_IND, + ELE_BAD_HASH_FAILURE_IND, + ELE_INVALID_LIFECYCLE_IND, + ELE_PERMISSION_DENIED_FAILURE_IND, + ELE_INVALID_MESSAGE_FAILURE_IND, + ELE_BAD_VALUE_FAILURE_IND, + ELE_BAD_FUSE_ID_FAILURE_IND, + ELE_BAD_CONTAINER_FAILURE_IND, + ELE_BAD_VERSION_FAILURE_IND, + ELE_INVALID_KEY_FAILURE_IND, + ELE_BAD_KEY_HASH_FAILURE_IND, + ELE_NO_VALID_CONTAINER_FAILURE_IND, + ELE_BAD_CERTIFICATE_FAILURE_IND, + ELE_BAD_UID_FAILURE_IND, + ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND, + ELE_MUST_SIGNED_FAILURE_IND, + ELE_NO_AUTHENTICATION_FAILURE_IND, + ELE_BAD_SRK_SET_FAILURE_IND, + ELE_UNALIGNED_PAYLOAD_FAILURE_IND, + ELE_WRONG_SIZE_FAILURE_IND, + ELE_ENCRYPTION_FAILURE_IND, + ELE_DECRYPTION_FAILURE_IND, + ELE_OTP_PROGFAIL_FAILURE_IND, + ELE_OTP_LOCKED_FAILURE_IND, + ELE_OTP_INVALID_IDX_FAILURE_IND, + ELE_TIME_OUT_FAILURE_IND, + ELE_BAD_PAYLOAD_FAILURE_IND, + ELE_WRONG_ADDRESS_FAILURE_IND, + ELE_DMA_FAILURE_IND, + ELE_DISABLED_FEATURE_FAILURE_IND, + ELE_MUST_ATTEST_FAILURE_IND, + ELE_RNG_NOT_STARTED_FAILURE_IND, + ELE_CRC_ERROR_IND, + ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND, + ELE_INCONSISTENT_PAR_FAILURE_IND, + ELE_RNG_INST_FAILURE_FAILURE_IND, + ELE_LOCKED_REG_FAILURE_IND, + ELE_BAD_ID_FAILURE_IND, + ELE_INVALID_OPERATION_FAILURE_IND, + ELE_NON_SECURE_STATE_FAILURE_IND, + ELE_MSG_TRUNCATED_IND, + ELE_BAD_IMAGE_NUM_FAILURE_IND, + ELE_BAD_IMAGE_ADDR_FAILURE_IND, + ELE_BAD_IMAGE_PARAM_FAILURE_IND, + ELE_BAD_IMAGE_TYPE_FAILURE_IND, + ELE_CORRUPTED_SRK_FAILURE_IND, + ELE_OUT_OF_MEMORY_IND, + ELE_CSTM_FAILURE_IND, + ELE_OLD_VERSION_FAILURE_IND, + ELE_WRONG_BOOT_MODE_FAILURE_IND, + ELE_APC_ALREADY_ENABLED_FAILURE_IND, + ELE_RTC_ALREADY_ENABLED_FAILURE_IND, + ELE_ABORT_IND +}; + +static u8 ele_ipc[] = { + ELE_IPC_MU_RTD, + ELE_IPC_MU_APD +}; + +static u8 ele_status[] = { + ELE_SUCCESS_IND, + ELE_FAILURE_IND +}; + +static inline u32 get_idx(u8 *list, u8 tgt, u32 size) +{ + u32 i; + + for (i = 0; i < size; i++) { + if (list[i] == tgt) + return i; + } + + return i; /* last str is invalid */ +}
static void display_ahab_auth_ind(u32 event) { u8 resp_ind = (event >> 8) & 0xff;
- switch (resp_ind) { - case AHAB_NO_AUTHENTICATION_IND: - printf("AHAB_NO_AUTHENTICATION_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_KEY_HASH_IND: - printf("AHAB_BAD_KEY_HASH_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_INVALID_KEY_IND: - printf("AHAB_INVALID_KEY_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_SIGNATURE_IND: - printf("AHAB_BAD_SIGNATURE_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_HASH_IND: - printf("AHAB_BAD_HASH_IND (0x%02X)\n\n", resp_ind); - break; - default: - printf("Unknown Indicator (0x%02X)\n\n", resp_ind); - break; - } + printf("%s\n", ele_ind_str[get_idx(ele_ind, resp_ind, ARRAY_SIZE(ele_ind))]); }
int ahab_auth_cntr_hdr(struct container_hdr *container, u16 length) @@ -313,14 +516,45 @@ static int do_ahab_dump(struct cmd_tbl *cmdtp, int flag, int argc, char *const a return ahab_dump(); }
+static void display_event(u32 event) +{ + printf("\n\t0x%08x\n", event); + printf("\t%s", ele_ipc_str[get_idx(ele_ipc, + (event >> 24) & 0xFF, ARRAY_SIZE(ele_ipc))]); + printf("\t%s", ele_cmd_str[get_idx(ele_cmd, + (event >> 16) & 0xFF, ARRAY_SIZE(ele_cmd))]); + printf("\t%s", ele_ind_str[get_idx(ele_ind, + (event >> 8) & 0xFF, ARRAY_SIZE(ele_ind))]); + printf("\t%s", ele_status_str[get_idx(ele_status, + event & 0xFF, ARRAY_SIZE(ele_status))]); +} + static int do_ahab_status(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - u32 lc; + u32 lc, i; + u32 events[AHAB_MAX_EVENTS]; + u32 cnt = AHAB_MAX_EVENTS; + int ret;
lc = readl(FSB_BASE_ADDR + 0x41c); lc &= 0x3ff;
display_life_cycle(lc); + + ret = ahab_get_events(events, &cnt, NULL); + if (ret) { + printf("Get ELE EVENTS error %d\n", ret); + return CMD_RET_FAILURE; + } + + if (!cnt) { + puts("\n\tNo Events Found!\n"); + return 0; + } + + for (i = 0; i < cnt; i++) + display_event(events[i]); + return 0; }
For ahab_status command, support to get and decode AHAB events Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-imx, next, thanks !
Best regards, Stefano Babic
Use common file ele_ahab.c for i.MX9 and iMX8ULP AHAB support, since both of them use same sentinel ELE APIs
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/imx-regs.h | 2 + arch/arm/include/asm/arch-imx9/imx-regs.h | 2 + arch/arm/mach-imx/Makefile | 4 + arch/arm/mach-imx/ele_ahab.c | 579 ++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/ahab.c | 345 ---------------- arch/arm/mach-imx/imx9/Makefile | 1 - arch/arm/mach-imx/imx9/ahab.c | 580 --------------------------- 7 files changed, 587 insertions(+), 926 deletions(-) create mode 100644 arch/arm/mach-imx/ele_ahab.c delete mode 100644 arch/arm/mach-imx/imx8ulp/ahab.c delete mode 100644 arch/arm/mach-imx/imx9/ahab.c
diff --git a/arch/arm/include/asm/arch-imx8ulp/imx-regs.h b/arch/arm/include/asm/arch-imx8ulp/imx-regs.h index 723bab5..f5a2968 100644 --- a/arch/arm/include/asm/arch-imx8ulp/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8ulp/imx-regs.h @@ -62,6 +62,8 @@
#define FEC_QUIRK_ENET_MAC
+#define IMG_CONTAINER_BASE (0x22010000UL) + #if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) #include <asm/types.h>
diff --git a/arch/arm/include/asm/arch-imx9/imx-regs.h b/arch/arm/include/asm/arch-imx9/imx-regs.h index f575805..065fd1f 100644 --- a/arch/arm/include/asm/arch-imx9/imx-regs.h +++ b/arch/arm/include/asm/arch-imx9/imx-regs.h @@ -40,6 +40,8 @@ #define SRC_MIX_SLICE_FUNC_STAT_ISO_STAT BIT(4) #define SRC_MIX_SLICE_FUNC_STAT_MEM_STAT BIT(12)
+#define IMG_CONTAINER_BASE (0x80000000UL) + #define BCTRL_GPR_ENET_QOS_INTF_MODE_MASK GENMASK(3, 1) #define BCTRL_GPR_ENET_QOS_INTF_SEL_MII (0x0 << 1) #define BCTRL_GPR_ENET_QOS_INTF_SEL_RMII (0x4 << 1) diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 61b4f4f..4469826 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -77,6 +77,10 @@ ifeq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_SPL_LOAD_IMX_CONTAINER) += image-container.o parse-container.o endif
+ifeq ($(SOC),$(filter $(SOC),imx8ulp imx9)) +obj-$(CONFIG_AHAB_BOOT) += ele_ahab.o +endif + PLUGIN = board/$(BOARDDIR)/plugin
ifeq ($(CONFIG_USE_IMXIMG_PLUGIN),y) diff --git a/arch/arm/mach-imx/ele_ahab.c b/arch/arm/mach-imx/ele_ahab.c new file mode 100644 index 0000000..da8c99b --- /dev/null +++ b/arch/arm/mach-imx/ele_ahab.c @@ -0,0 +1,579 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + */ + +#include <common.h> +#include <command.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/mach-imx/s400_api.h> +#include <asm/mach-imx/sys_proto.h> +#include <asm/arch-imx/cpu.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/image.h> +#include <console.h> +#include <cpu_func.h> +#include <asm/mach-imx/ahab.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define IMG_CONTAINER_END_BASE (IMG_CONTAINER_BASE + 0xFFFFUL) + +#define AHAB_MAX_EVENTS 8 + +static char *ele_ipc_str[] = { + "IPC = MU RTD (0x1)\n", + "IPC = MU APD (0x2)\n", + "IPC = INVALID\n", + NULL +}; + +static char *ele_status_str[] = { + "STA = ELE_SUCCESS_IND (0xD6)\n", + "STA = ELE_FAILURE_IND (0x29)\n", + "STA = INVALID\n", + NULL +}; + +static char *ele_cmd_str[] = { + "CMD = ELE_PING_REQ (0x01)\n", + "CMD = ELE_FW_AUTH_REQ (0x02)\n", + "CMD = ELE_RESTART_RST_TIMER_REQ (0x04)\n", + "CMD = ELE_DUMP_DEBUG_BUFFER_REQ (0x21)\n", + "CMD = ELE_OEM_CNTN_AUTH_REQ (0x87)\n", + "CMD = ELE_VERIFY_IMAGE_REQ (0x88)\n", + "CMD = ELE_RELEASE_CONTAINER_REQ (0x89)\n", + "CMD = ELE_WRITE_SECURE_FUSE_REQ (0x91)\n", + "CMD = ELE_FWD_LIFECYCLE_UP_REQ (0x95)\n", + "CMD = ELE_READ_FUSE_REQ (0x97)\n", + "CMD = ELE_GET_FW_VERSION_REQ (0x9D)\n", + "CMD = ELE_RET_LIFECYCLE_UP_REQ (0xA0)\n", + "CMD = ELE_GET_EVENTS_REQ (0xA2)\n", + "CMD = ELE_ENABLE_PATCH_REQ (0xC3)\n", + "CMD = ELE_RELEASE_RDC_REQ (0xC4)\n", + "CMD = ELE_GET_FW_STATUS_REQ (0xC5)\n", + "CMD = ELE_ENABLE_OTFAD_REQ (0xC6)\n", + "CMD = ELE_RESET_REQ (0xC7)\n", + "CMD = ELE_UPDATE_OTP_CLKDIV_REQ (0xD0)\n", + "CMD = ELE_POWER_DOWN_REQ (0xD1)\n", + "CMD = ELE_ENABLE_APC_REQ (0xD2)\n", + "CMD = ELE_ENABLE_RTC_REQ (0xD3)\n", + "CMD = ELE_DEEP_POWER_DOWN_REQ (0xD4)\n", + "CMD = ELE_STOP_RST_TIMER_REQ (0xD5)\n", + "CMD = ELE_WRITE_FUSE_REQ (0xD6)\n", + "CMD = ELE_RELEASE_CAAM_REQ (0xD7)\n", + "CMD = ELE_RESET_A35_CTX_REQ (0xD8)\n", + "CMD = ELE_MOVE_TO_UNSECURED_REQ (0xD9)\n", + "CMD = ELE_GET_INFO_REQ (0xDA)\n", + "CMD = ELE_ATTEST_REQ (0xDB)\n", + "CMD = ELE_RELEASE_PATCH_REQ (0xDC)\n", + "CMD = ELE_OTP_SEQ_SWITH_REQ (0xDD)\n", + "CMD = INVALID\n", + NULL +}; + +static char *ele_ind_str[] = { + "IND = ELE_ROM_PING_FAILURE_IND (0x0A)\n", + "IND = ELE_FW_PING_FAILURE_IND (0x1A)\n", + "IND = ELE_BAD_SIGNATURE_FAILURE_IND (0xF0)\n", + "IND = ELE_BAD_HASH_FAILURE_IND (0xF1)\n", + "IND = ELE_INVALID_LIFECYCLE_IND (0xF2)\n", + "IND = ELE_PERMISSION_DENIED_FAILURE_IND (0xF3)\n", + "IND = ELE_INVALID_MESSAGE_FAILURE_IND (0xF4)\n", + "IND = ELE_BAD_VALUE_FAILURE_IND (0xF5)\n", + "IND = ELE_BAD_FUSE_ID_FAILURE_IND (0xF6)\n", + "IND = ELE_BAD_CONTAINER_FAILURE_IND (0xF7)\n", + "IND = ELE_BAD_VERSION_FAILURE_IND (0xF8)\n", + "IND = ELE_INVALID_KEY_FAILURE_IND (0xF9)\n", + "IND = ELE_BAD_KEY_HASH_FAILURE_IND (0xFA)\n", + "IND = ELE_NO_VALID_CONTAINER_FAILURE_IND (0xFB)\n", + "IND = ELE_BAD_CERTIFICATE_FAILURE_IND (0xFC)\n", + "IND = ELE_BAD_UID_FAILURE_IND (0xFD)\n", + "IND = ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND (0xFE)\n", + "IND = ELE_MUST_SIGNED_FAILURE_IND (0xE0)\n", + "IND = ELE_NO_AUTHENTICATION_FAILURE_IND (0xEE)\n", + "IND = ELE_BAD_SRK_SET_FAILURE_IND (0xEF)\n", + "IND = ELE_UNALIGNED_PAYLOAD_FAILURE_IND (0xA6)\n", + "IND = ELE_WRONG_SIZE_FAILURE_IND (0xA7)\n", + "IND = ELE_ENCRYPTION_FAILURE_IND (0xA8)\n", + "IND = ELE_DECRYPTION_FAILURE_IND (0xA9)\n", + "IND = ELE_OTP_PROGFAIL_FAILURE_IND (0xAA)\n", + "IND = ELE_OTP_LOCKED_FAILURE_IND (0xAB)\n", + "IND = ELE_OTP_INVALID_IDX_FAILURE_IND (0xAD)\n", + "IND = ELE_TIME_OUT_FAILURE_IND (0xB0)\n", + "IND = ELE_BAD_PAYLOAD_FAILURE_IND (0xB1)\n", + "IND = ELE_WRONG_ADDRESS_FAILURE_IND (0xB4)\n", + "IND = ELE_DMA_FAILURE_IND (0xB5)\n", + "IND = ELE_DISABLED_FEATURE_FAILURE_IND (0xB6)\n", + "IND = ELE_MUST_ATTEST_FAILURE_IND (0xB7)\n", + "IND = ELE_RNG_NOT_STARTED_FAILURE_IND (0xB8)\n", + "IND = ELE_CRC_ERROR_IND (0xB9)\n", + "IND = ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND (0xBB)\n", + "IND = ELE_INCONSISTENT_PAR_FAILURE_IND (0xBC)\n", + "IND = ELE_RNG_INST_FAILURE_FAILURE_IND (0xBD)\n", + "IND = ELE_LOCKED_REG_FAILURE_IND (0xBE)\n", + "IND = ELE_BAD_ID_FAILURE_IND (0xBF)\n", + "IND = ELE_INVALID_OPERATION_FAILURE_IND (0xC0)\n", + "IND = ELE_NON_SECURE_STATE_FAILURE_IND (0xC1)\n", + "IND = ELE_MSG_TRUNCATED_IND (0xC2)\n", + "IND = ELE_BAD_IMAGE_NUM_FAILURE_IND (0xC3)\n", + "IND = ELE_BAD_IMAGE_ADDR_FAILURE_IND (0xC4)\n", + "IND = ELE_BAD_IMAGE_PARAM_FAILURE_IND (0xC5)\n", + "IND = ELE_BAD_IMAGE_TYPE_FAILURE_IND (0xC6)\n", + "IND = ELE_CORRUPTED_SRK_FAILURE_IND (0xD0)\n", + "IND = ELE_OUT_OF_MEMORY_IND (0xD1)\n", + "IND = ELE_CSTM_FAILURE_IND (0xCF)\n", + "IND = ELE_OLD_VERSION_FAILURE_IND (0xCE)\n", + "IND = ELE_WRONG_BOOT_MODE_FAILURE_IND (0xCD)\n", + "IND = ELE_APC_ALREADY_ENABLED_FAILURE_IND (0xCB)\n", + "IND = ELE_RTC_ALREADY_ENABLED_FAILURE_IND (0xCC)\n", + "IND = ELE_ABORT_IND (0xFF)\n", + "IND = INVALID\n", + NULL +}; + +static u8 ele_cmd[] = { + ELE_PING_REQ, + ELE_FW_AUTH_REQ, + ELE_RESTART_RST_TIMER_REQ, + ELE_DUMP_DEBUG_BUFFER_REQ, + ELE_OEM_CNTN_AUTH_REQ, + ELE_VERIFY_IMAGE_REQ, + ELE_RELEASE_CONTAINER_REQ, + ELE_WRITE_SECURE_FUSE_REQ, + ELE_FWD_LIFECYCLE_UP_REQ, + ELE_READ_FUSE_REQ, + ELE_GET_FW_VERSION_REQ, + ELE_RET_LIFECYCLE_UP_REQ, + ELE_GET_EVENTS_REQ, + ELE_ENABLE_PATCH_REQ, + ELE_RELEASE_RDC_REQ, + ELE_GET_FW_STATUS_REQ, + ELE_ENABLE_OTFAD_REQ, + ELE_RESET_REQ, + ELE_UPDATE_OTP_CLKDIV_REQ, + ELE_POWER_DOWN_REQ, + ELE_ENABLE_APC_REQ, + ELE_ENABLE_RTC_REQ, + ELE_DEEP_POWER_DOWN_REQ, + ELE_STOP_RST_TIMER_REQ, + ELE_WRITE_FUSE_REQ, + ELE_RELEASE_CAAM_REQ, + ELE_RESET_A35_CTX_REQ, + ELE_MOVE_TO_UNSECURED_REQ, + ELE_GET_INFO_REQ, + ELE_ATTEST_REQ, + ELE_RELEASE_PATCH_REQ, + ELE_OTP_SEQ_SWITH_REQ +}; + +static u8 ele_ind[] = { + ELE_ROM_PING_FAILURE_IND, + ELE_FW_PING_FAILURE_IND, + ELE_BAD_SIGNATURE_FAILURE_IND, + ELE_BAD_HASH_FAILURE_IND, + ELE_INVALID_LIFECYCLE_IND, + ELE_PERMISSION_DENIED_FAILURE_IND, + ELE_INVALID_MESSAGE_FAILURE_IND, + ELE_BAD_VALUE_FAILURE_IND, + ELE_BAD_FUSE_ID_FAILURE_IND, + ELE_BAD_CONTAINER_FAILURE_IND, + ELE_BAD_VERSION_FAILURE_IND, + ELE_INVALID_KEY_FAILURE_IND, + ELE_BAD_KEY_HASH_FAILURE_IND, + ELE_NO_VALID_CONTAINER_FAILURE_IND, + ELE_BAD_CERTIFICATE_FAILURE_IND, + ELE_BAD_UID_FAILURE_IND, + ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND, + ELE_MUST_SIGNED_FAILURE_IND, + ELE_NO_AUTHENTICATION_FAILURE_IND, + ELE_BAD_SRK_SET_FAILURE_IND, + ELE_UNALIGNED_PAYLOAD_FAILURE_IND, + ELE_WRONG_SIZE_FAILURE_IND, + ELE_ENCRYPTION_FAILURE_IND, + ELE_DECRYPTION_FAILURE_IND, + ELE_OTP_PROGFAIL_FAILURE_IND, + ELE_OTP_LOCKED_FAILURE_IND, + ELE_OTP_INVALID_IDX_FAILURE_IND, + ELE_TIME_OUT_FAILURE_IND, + ELE_BAD_PAYLOAD_FAILURE_IND, + ELE_WRONG_ADDRESS_FAILURE_IND, + ELE_DMA_FAILURE_IND, + ELE_DISABLED_FEATURE_FAILURE_IND, + ELE_MUST_ATTEST_FAILURE_IND, + ELE_RNG_NOT_STARTED_FAILURE_IND, + ELE_CRC_ERROR_IND, + ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND, + ELE_INCONSISTENT_PAR_FAILURE_IND, + ELE_RNG_INST_FAILURE_FAILURE_IND, + ELE_LOCKED_REG_FAILURE_IND, + ELE_BAD_ID_FAILURE_IND, + ELE_INVALID_OPERATION_FAILURE_IND, + ELE_NON_SECURE_STATE_FAILURE_IND, + ELE_MSG_TRUNCATED_IND, + ELE_BAD_IMAGE_NUM_FAILURE_IND, + ELE_BAD_IMAGE_ADDR_FAILURE_IND, + ELE_BAD_IMAGE_PARAM_FAILURE_IND, + ELE_BAD_IMAGE_TYPE_FAILURE_IND, + ELE_CORRUPTED_SRK_FAILURE_IND, + ELE_OUT_OF_MEMORY_IND, + ELE_CSTM_FAILURE_IND, + ELE_OLD_VERSION_FAILURE_IND, + ELE_WRONG_BOOT_MODE_FAILURE_IND, + ELE_APC_ALREADY_ENABLED_FAILURE_IND, + ELE_RTC_ALREADY_ENABLED_FAILURE_IND, + ELE_ABORT_IND +}; + +static u8 ele_ipc[] = { + ELE_IPC_MU_RTD, + ELE_IPC_MU_APD +}; + +static u8 ele_status[] = { + ELE_SUCCESS_IND, + ELE_FAILURE_IND +}; + +static inline u32 get_idx(u8 *list, u8 tgt, u32 size) +{ + u32 i; + + for (i = 0; i < size; i++) { + if (list[i] == tgt) + return i; + } + + return i; /* last str is invalid */ +} + +static void display_ahab_auth_ind(u32 event) +{ + u8 resp_ind = (event >> 8) & 0xff; + + printf("%s\n", ele_ind_str[get_idx(ele_ind, resp_ind, ARRAY_SIZE(ele_ind))]); +} + +int ahab_auth_cntr_hdr(struct container_hdr *container, u16 length) +{ + int err; + u32 resp; + + memcpy((void *)IMG_CONTAINER_BASE, (const void *)container, + ALIGN(length, CONFIG_SYS_CACHELINE_SIZE)); + + flush_dcache_range(IMG_CONTAINER_BASE, + IMG_CONTAINER_BASE + ALIGN(length, CONFIG_SYS_CACHELINE_SIZE) - 1); + + err = ahab_auth_oem_ctnr(IMG_CONTAINER_BASE, &resp); + if (err) { + printf("Authenticate container hdr failed, return %d, resp 0x%x\n", + err, resp); + display_ahab_auth_ind(resp); + } + + return err; +} + +int ahab_auth_release(void) +{ + int err; + u32 resp; + + err = ahab_release_container(&resp); + if (err) { + printf("Error: release container failed, resp 0x%x!\n", resp); + display_ahab_auth_ind(resp); + } + + return err; +} + +int ahab_verify_cntr_image(struct boot_img_t *img, int image_index) +{ + int err; + u32 resp; + + err = ahab_verify_image(image_index, &resp); + if (err) { + printf("Authenticate img %d failed, return %d, resp 0x%x\n", + image_index, err, resp); + display_ahab_auth_ind(resp); + + return -EIO; + } + + return 0; +} + +static inline bool check_in_dram(ulong addr) +{ + int i; + struct bd_info *bd = gd->bd; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { + if (bd->bi_dram[i].size) { + if (addr >= bd->bi_dram[i].start && + addr < (bd->bi_dram[i].start + bd->bi_dram[i].size)) + return true; + } + } + + return false; +} + +int authenticate_os_container(ulong addr) +{ + struct container_hdr *phdr; + int i, ret = 0; + int err; + u16 length; + struct boot_img_t *img; + unsigned long s, e; + + if (addr % 4) { + puts("Error: Image's address is not 4 byte aligned\n"); + return -EINVAL; + } + + if (!check_in_dram(addr)) { + puts("Error: Image's address is invalid\n"); + return -EINVAL; + } + + phdr = (struct container_hdr *)addr; + if (phdr->tag != 0x87 || phdr->version != 0x0) { + printf("Error: Wrong container header\n"); + return -EFAULT; + } + + if (!phdr->num_images) { + printf("Error: Wrong container, no image found\n"); + return -EFAULT; + } + + length = phdr->length_lsb + (phdr->length_msb << 8); + + debug("container length %u\n", length); + + err = ahab_auth_cntr_hdr(phdr, length); + if (err) { + ret = -EIO; + goto exit; + } + + debug("Verify images\n"); + + /* Copy images to dest address */ + for (i = 0; i < phdr->num_images; i++) { + img = (struct boot_img_t *)(addr + + sizeof(struct container_hdr) + + i * sizeof(struct boot_img_t)); + + debug("img %d, dst 0x%x, src 0x%lx, size 0x%x\n", + i, (uint32_t)img->dst, img->offset + addr, img->size); + + memcpy((void *)img->dst, (const void *)(img->offset + addr), + img->size); + + s = img->dst & ~(CONFIG_SYS_CACHELINE_SIZE - 1); + e = ALIGN(img->dst + img->size, CONFIG_SYS_CACHELINE_SIZE) - 1; + + flush_dcache_range(s, e); + + ret = ahab_verify_cntr_image(img, i); + if (ret) + goto exit; + } + +exit: + debug("ahab_auth_release, 0x%x\n", ret); + ahab_auth_release(); + + return ret; +} + +static int do_authenticate(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + ulong addr; + + if (argc < 2) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[1], NULL, 16); + + printf("Authenticate OS container at 0x%lx\n", addr); + + if (authenticate_os_container(addr)) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +static void display_life_cycle(u32 lc) +{ + printf("Lifecycle: 0x%08X, ", lc); + switch (lc) { + case 0x1: + printf("BLANK\n\n"); + break; + case 0x2: + printf("FAB\n\n"); + break; + case 0x4: + printf("NXP Provisioned\n\n"); + break; + case 0x8: + printf("OEM Open\n\n"); + break; + case 0x10: + printf("OEM Secure World Closed\n\n"); + break; + case 0x20: + printf("OEM closed\n\n"); + break; + case 0x40: + printf("Field Return OEM\n\n"); + break; + case 0x80: + printf("Field Return NXP\n\n"); + break; + case 0x100: + printf("OEM Locked\n\n"); + break; + case 0x200: + printf("BRICKED\n\n"); + break; + default: + printf("Unknown\n\n"); + break; + } +} + +static int confirm_close(void) +{ + puts("Warning: Please ensure your sample is in NXP closed state, " + "OEM SRK hash has been fused, \n" + " and you are able to boot a signed image successfully " + "without any SECO events reported.\n" + " If not, your sample will be unrecoverable.\n" + "\nReally perform this operation? <y/N>\n"); + + if (confirm_yesno()) + return 1; + + puts("Ahab close aborted\n"); + return 0; +} + +static int do_ahab_close(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + int err; + u32 resp; + + if (!confirm_close()) + return -EACCES; + + err = ahab_forward_lifecycle(8, &resp); + if (err != 0) { + printf("Error in forward lifecycle to OEM closed\n"); + return -EIO; + } + + printf("Change to OEM closed successfully\n"); + + return 0; +} + +int ahab_dump(void) +{ + u32 buffer[32]; + int ret, i = 0; + + do { + ret = ahab_dump_buffer(buffer, 32); + if (ret < 0) { + printf("Error in dump AHAB log\n"); + return -EIO; + } + + if (ret == 1) + break; + for (i = 0; i < ret; i++) + printf("0x%x\n", buffer[i]); + } while (ret >= 21); + + return 0; +} + +static int do_ahab_dump(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + return ahab_dump(); +} + +static void display_event(u32 event) +{ + printf("\n\t0x%08x\n", event); + printf("\t%s", ele_ipc_str[get_idx(ele_ipc, + (event >> 24) & 0xFF, ARRAY_SIZE(ele_ipc))]); + printf("\t%s", ele_cmd_str[get_idx(ele_cmd, + (event >> 16) & 0xFF, ARRAY_SIZE(ele_cmd))]); + printf("\t%s", ele_ind_str[get_idx(ele_ind, + (event >> 8) & 0xFF, ARRAY_SIZE(ele_ind))]); + printf("\t%s", ele_status_str[get_idx(ele_status, + event & 0xFF, ARRAY_SIZE(ele_status))]); +} + +static int do_ahab_status(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + u32 lc, i; + u32 events[AHAB_MAX_EVENTS]; + u32 cnt = AHAB_MAX_EVENTS; + int ret; + + lc = readl(FSB_BASE_ADDR + 0x41c); + lc &= 0x3ff; + + display_life_cycle(lc); + + ret = ahab_get_events(events, &cnt, NULL); + if (ret) { + printf("Get ELE EVENTS error %d\n", ret); + return CMD_RET_FAILURE; + } + + if (!cnt) { + puts("\n\tNo Events Found!\n"); + return 0; + } + + for (i = 0; i < cnt; i++) + display_event(events[i]); + + return 0; +} + +U_BOOT_CMD(auth_cntr, CONFIG_SYS_MAXARGS, 1, do_authenticate, + "autenticate OS container via AHAB", + "addr\n" + "addr - OS container hex address\n" +); + +U_BOOT_CMD(ahab_close, CONFIG_SYS_MAXARGS, 1, do_ahab_close, + "Change AHAB lifecycle to OEM closed", + "" +); + +U_BOOT_CMD(ahab_dump, CONFIG_SYS_MAXARGS, 1, do_ahab_dump, + "Dump AHAB log for debug", + "" +); + +U_BOOT_CMD(ahab_status, CONFIG_SYS_MAXARGS, 1, do_ahab_status, + "display AHAB lifecycle only", + "" +); diff --git a/arch/arm/mach-imx/imx8ulp/ahab.c b/arch/arm/mach-imx/imx8ulp/ahab.c deleted file mode 100644 index 87c4c66..0000000 --- a/arch/arm/mach-imx/imx8ulp/ahab.c +++ /dev/null @@ -1,345 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2020 NXP - */ - -#include <common.h> -#include <command.h> -#include <errno.h> -#include <asm/io.h> -#include <asm/mach-imx/s400_api.h> -#include <asm/mach-imx/sys_proto.h> -#include <asm/arch-imx/cpu.h> -#include <asm/arch/sys_proto.h> -#include <asm/mach-imx/image.h> -#include <console.h> -#include <cpu_func.h> -#include <asm/mach-imx/ahab.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define IMG_CONTAINER_BASE (0x22010000UL) -#define IMG_CONTAINER_END_BASE (IMG_CONTAINER_BASE + 0xFFFFUL) - -#define AHAB_NO_AUTHENTICATION_IND 0xee -#define AHAB_BAD_KEY_HASH_IND 0xfa -#define AHAB_INVALID_KEY_IND 0xf9 -#define AHAB_BAD_SIGNATURE_IND 0xf0 -#define AHAB_BAD_HASH_IND 0xf1 - -static void display_ahab_auth_ind(u32 event) -{ - u8 resp_ind = (event >> 8) & 0xff; - - switch (resp_ind) { - case AHAB_NO_AUTHENTICATION_IND: - printf("AHAB_NO_AUTHENTICATION_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_KEY_HASH_IND: - printf("AHAB_BAD_KEY_HASH_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_INVALID_KEY_IND: - printf("AHAB_INVALID_KEY_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_SIGNATURE_IND: - printf("AHAB_BAD_SIGNATURE_IND (0x%02X)\n\n", resp_ind); - break; - case AHAB_BAD_HASH_IND: - printf("AHAB_BAD_HASH_IND (0x%02X)\n\n", resp_ind); - break; - default: - printf("Unknown Indicator (0x%02X)\n\n", resp_ind); - break; - } -} - -int ahab_auth_cntr_hdr(struct container_hdr *container, u16 length) -{ - int err; - u32 resp; - - memcpy((void *)IMG_CONTAINER_BASE, (const void *)container, - ALIGN(length, CONFIG_SYS_CACHELINE_SIZE)); - - flush_dcache_range(IMG_CONTAINER_BASE, - IMG_CONTAINER_BASE + ALIGN(length, CONFIG_SYS_CACHELINE_SIZE) - 1); - - err = ahab_auth_oem_ctnr(IMG_CONTAINER_BASE, &resp); - if (err) { - printf("Authenticate container hdr failed, return %d, resp 0x%x\n", - err, resp); - display_ahab_auth_ind(resp); - } - - return err; -} - -int ahab_auth_release(void) -{ - int err; - u32 resp; - - err = ahab_release_container(&resp); - if (err) { - printf("Error: release container failed, resp 0x%x!\n", resp); - display_ahab_auth_ind(resp); - } - - return err; -} - -int ahab_verify_cntr_image(struct boot_img_t *img, int image_index) -{ - int err; - u32 resp; - - err = ahab_verify_image(image_index, &resp); - if (err) { - printf("Authenticate img %d failed, return %d, resp 0x%x\n", - image_index, err, resp); - display_ahab_auth_ind(resp); - return -EIO; - } - - return 0; -} - -static inline bool check_in_dram(ulong addr) -{ - int i; - struct bd_info *bd = gd->bd; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { - if (bd->bi_dram[i].size) { - if (addr >= bd->bi_dram[i].start && - addr < (bd->bi_dram[i].start + bd->bi_dram[i].size)) - return true; - } - } - - return false; -} - -int authenticate_os_container(ulong addr) -{ - struct container_hdr *phdr; - int i, ret = 0; - int err; - u16 length; - struct boot_img_t *img; - unsigned long s, e; - - if (addr % 4) { - puts("Error: Image's address is not 4 byte aligned\n"); - return -EINVAL; - } - - if (!check_in_dram(addr)) { - puts("Error: Image's address is invalid\n"); - return -EINVAL; - } - - phdr = (struct container_hdr *)addr; - if (phdr->tag != 0x87 || phdr->version != 0x0) { - printf("Error: Wrong container header\n"); - return -EFAULT; - } - - if (!phdr->num_images) { - printf("Error: Wrong container, no image found\n"); - return -EFAULT; - } - - length = phdr->length_lsb + (phdr->length_msb << 8); - - debug("container length %u\n", length); - - err = ahab_auth_cntr_hdr(phdr, length); - if (err) { - ret = -EIO; - goto exit; - } - - debug("Verify images\n"); - - /* Copy images to dest address */ - for (i = 0; i < phdr->num_images; i++) { - img = (struct boot_img_t *)(addr + - sizeof(struct container_hdr) + - i * sizeof(struct boot_img_t)); - - debug("img %d, dst 0x%x, src 0x%lx, size 0x%x\n", - i, (uint32_t)img->dst, img->offset + addr, img->size); - - memcpy((void *)img->dst, (const void *)(img->offset + addr), img->size); - - s = img->dst & ~(CONFIG_SYS_CACHELINE_SIZE - 1); - e = ALIGN(img->dst + img->size, CONFIG_SYS_CACHELINE_SIZE) - 1; - - flush_dcache_range(s, e); - - ret = ahab_verify_cntr_image(img, i); - if (ret) - goto exit; - } - -exit: - debug("ahab_auth_release, 0x%x\n", ret); - ahab_auth_release(); - - return ret; -} - -static int do_authenticate(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - ulong addr; - - if (argc < 2) - return CMD_RET_USAGE; - - addr = simple_strtoul(argv[1], NULL, 16); - - printf("Authenticate OS container at 0x%lx\n", addr); - - if (authenticate_os_container(addr)) - return CMD_RET_FAILURE; - - return CMD_RET_SUCCESS; -} - -static void display_life_cycle(u32 lc) -{ - printf("Lifecycle: 0x%08X, ", lc); - switch (lc) { - case 0x1: - printf("BLANK\n\n"); - break; - case 0x2: - printf("FAB\n\n"); - break; - case 0x4: - printf("NXP Provisioned\n\n"); - break; - case 0x8: - printf("OEM Open\n\n"); - break; - case 0x10: - printf("OEM Secure World Closed\n\n"); - break; - case 0x20: - printf("OEM closed\n\n"); - break; - case 0x40: - printf("Field Return OEM\n\n"); - break; - case 0x80: - printf("Field Return NXP\n\n"); - break; - case 0x100: - printf("OEM Locked\n\n"); - break; - case 0x200: - printf("BRICKED\n\n"); - break; - default: - printf("Unknown\n\n"); - break; - } -} - -static int confirm_close(void) -{ - puts("Warning: Please ensure your sample is in NXP closed state, " - "OEM SRK hash has been fused, \n" - " and you are able to boot a signed image successfully " - "without any SECO events reported.\n" - " If not, your sample will be unrecoverable.\n" - "\nReally perform this operation? <y/N>\n"); - - if (confirm_yesno()) - return 1; - - puts("Ahab close aborted\n"); - return 0; -} - -static int do_ahab_close(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - int err; - u32 resp; - - if (!confirm_close()) - return -EACCES; - - err = ahab_forward_lifecycle(8, &resp); - if (err != 0) { - printf("Error in forward lifecycle to OEM closed\n"); - return -EIO; - } - - printf("Change to OEM closed successfully\n"); - - return 0; -} - -int ahab_dump(void) -{ - u32 buffer[32]; - int ret, i = 0; - - do { - ret = ahab_dump_buffer(buffer, 32); - if (ret < 0) { - printf("Error in dump AHAB log\n"); - return -EIO; - } - - if (ret == 1) - break; - - for (i = 0; i < ret; i++) - printf("0x%x\n", buffer[i]); - } while (ret >= 21); - - return 0; -} - -static int do_ahab_dump(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - return ahab_dump(); -} - -static int do_ahab_status(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - u32 lc; - - lc = readl(FSB_BASE_ADDR + 0x41c); - lc &= 0x3f; - - display_life_cycle(lc); - return 0; -} - -U_BOOT_CMD(auth_cntr, CONFIG_SYS_MAXARGS, 1, do_authenticate, - "autenticate OS container via AHAB", - "addr\n" - "addr - OS container hex address\n" -); - -U_BOOT_CMD(ahab_close, CONFIG_SYS_MAXARGS, 1, do_ahab_close, - "Change AHAB lifecycle to OEM closed", - "" -); - -U_BOOT_CMD(ahab_dump, CONFIG_SYS_MAXARGS, 1, do_ahab_dump, - "Dump AHAB log for debug", - "" -); - -U_BOOT_CMD(ahab_status, CONFIG_SYS_MAXARGS, 1, do_ahab_status, - "display AHAB lifecycle only", - "" -); diff --git a/arch/arm/mach-imx/imx9/Makefile b/arch/arm/mach-imx/imx9/Makefile index 6d038a6..e1b09ab 100644 --- a/arch/arm/mach-imx/imx9/Makefile +++ b/arch/arm/mach-imx/imx9/Makefile @@ -4,7 +4,6 @@
obj-y += lowlevel_init.o obj-y += soc.o clock.o clock_root.o trdc.o -obj-$(CONFIG_AHAB_BOOT) += ahab.o
#ifndef CONFIG_SPL_BUILD obj-y += imx_bootaux.o diff --git a/arch/arm/mach-imx/imx9/ahab.c b/arch/arm/mach-imx/imx9/ahab.c deleted file mode 100644 index ac69975..0000000 --- a/arch/arm/mach-imx/imx9/ahab.c +++ /dev/null @@ -1,580 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2022 NXP - */ - -#include <common.h> -#include <command.h> -#include <errno.h> -#include <asm/io.h> -#include <asm/mach-imx/s400_api.h> -#include <asm/mach-imx/sys_proto.h> -#include <asm/arch-imx/cpu.h> -#include <asm/arch/sys_proto.h> -#include <asm/mach-imx/image.h> -#include <console.h> -#include <cpu_func.h> -#include <asm/mach-imx/ahab.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define IMG_CONTAINER_BASE (0x80000000UL) -#define IMG_CONTAINER_END_BASE (IMG_CONTAINER_BASE + 0xFFFFUL) - -#define AHAB_MAX_EVENTS 8 - -static char *ele_ipc_str[] = { - "IPC = MU RTD (0x1)\n", - "IPC = MU APD (0x2)\n", - "IPC = INVALID\n", - NULL -}; - -static char *ele_status_str[] = { - "STA = ELE_SUCCESS_IND (0xD6)\n", - "STA = ELE_FAILURE_IND (0x29)\n", - "STA = INVALID\n", - NULL -}; - -static char *ele_cmd_str[] = { - "CMD = ELE_PING_REQ (0x01)\n", - "CMD = ELE_FW_AUTH_REQ (0x02)\n", - "CMD = ELE_RESTART_RST_TIMER_REQ (0x04)\n", - "CMD = ELE_DUMP_DEBUG_BUFFER_REQ (0x21)\n", - "CMD = ELE_OEM_CNTN_AUTH_REQ (0x87)\n", - "CMD = ELE_VERIFY_IMAGE_REQ (0x88)\n", - "CMD = ELE_RELEASE_CONTAINER_REQ (0x89)\n", - "CMD = ELE_WRITE_SECURE_FUSE_REQ (0x91)\n", - "CMD = ELE_FWD_LIFECYCLE_UP_REQ (0x95)\n", - "CMD = ELE_READ_FUSE_REQ (0x97)\n", - "CMD = ELE_GET_FW_VERSION_REQ (0x9D)\n", - "CMD = ELE_RET_LIFECYCLE_UP_REQ (0xA0)\n", - "CMD = ELE_GET_EVENTS_REQ (0xA2)\n", - "CMD = ELE_ENABLE_PATCH_REQ (0xC3)\n", - "CMD = ELE_RELEASE_RDC_REQ (0xC4)\n", - "CMD = ELE_GET_FW_STATUS_REQ (0xC5)\n", - "CMD = ELE_ENABLE_OTFAD_REQ (0xC6)\n", - "CMD = ELE_RESET_REQ (0xC7)\n", - "CMD = ELE_UPDATE_OTP_CLKDIV_REQ (0xD0)\n", - "CMD = ELE_POWER_DOWN_REQ (0xD1)\n", - "CMD = ELE_ENABLE_APC_REQ (0xD2)\n", - "CMD = ELE_ENABLE_RTC_REQ (0xD3)\n", - "CMD = ELE_DEEP_POWER_DOWN_REQ (0xD4)\n", - "CMD = ELE_STOP_RST_TIMER_REQ (0xD5)\n", - "CMD = ELE_WRITE_FUSE_REQ (0xD6)\n", - "CMD = ELE_RELEASE_CAAM_REQ (0xD7)\n", - "CMD = ELE_RESET_A35_CTX_REQ (0xD8)\n", - "CMD = ELE_MOVE_TO_UNSECURED_REQ (0xD9)\n", - "CMD = ELE_GET_INFO_REQ (0xDA)\n", - "CMD = ELE_ATTEST_REQ (0xDB)\n", - "CMD = ELE_RELEASE_PATCH_REQ (0xDC)\n", - "CMD = ELE_OTP_SEQ_SWITH_REQ (0xDD)\n", - "CMD = INVALID\n", - NULL -}; - -static char *ele_ind_str[] = { - "IND = ELE_ROM_PING_FAILURE_IND (0x0A)\n", - "IND = ELE_FW_PING_FAILURE_IND (0x1A)\n", - "IND = ELE_BAD_SIGNATURE_FAILURE_IND (0xF0)\n", - "IND = ELE_BAD_HASH_FAILURE_IND (0xF1)\n", - "IND = ELE_INVALID_LIFECYCLE_IND (0xF2)\n", - "IND = ELE_PERMISSION_DENIED_FAILURE_IND (0xF3)\n", - "IND = ELE_INVALID_MESSAGE_FAILURE_IND (0xF4)\n", - "IND = ELE_BAD_VALUE_FAILURE_IND (0xF5)\n", - "IND = ELE_BAD_FUSE_ID_FAILURE_IND (0xF6)\n", - "IND = ELE_BAD_CONTAINER_FAILURE_IND (0xF7)\n", - "IND = ELE_BAD_VERSION_FAILURE_IND (0xF8)\n", - "IND = ELE_INVALID_KEY_FAILURE_IND (0xF9)\n", - "IND = ELE_BAD_KEY_HASH_FAILURE_IND (0xFA)\n", - "IND = ELE_NO_VALID_CONTAINER_FAILURE_IND (0xFB)\n", - "IND = ELE_BAD_CERTIFICATE_FAILURE_IND (0xFC)\n", - "IND = ELE_BAD_UID_FAILURE_IND (0xFD)\n", - "IND = ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND (0xFE)\n", - "IND = ELE_MUST_SIGNED_FAILURE_IND (0xE0)\n", - "IND = ELE_NO_AUTHENTICATION_FAILURE_IND (0xEE)\n", - "IND = ELE_BAD_SRK_SET_FAILURE_IND (0xEF)\n", - "IND = ELE_UNALIGNED_PAYLOAD_FAILURE_IND (0xA6)\n", - "IND = ELE_WRONG_SIZE_FAILURE_IND (0xA7)\n", - "IND = ELE_ENCRYPTION_FAILURE_IND (0xA8)\n", - "IND = ELE_DECRYPTION_FAILURE_IND (0xA9)\n", - "IND = ELE_OTP_PROGFAIL_FAILURE_IND (0xAA)\n", - "IND = ELE_OTP_LOCKED_FAILURE_IND (0xAB)\n", - "IND = ELE_OTP_INVALID_IDX_FAILURE_IND (0xAD)\n", - "IND = ELE_TIME_OUT_FAILURE_IND (0xB0)\n", - "IND = ELE_BAD_PAYLOAD_FAILURE_IND (0xB1)\n", - "IND = ELE_WRONG_ADDRESS_FAILURE_IND (0xB4)\n", - "IND = ELE_DMA_FAILURE_IND (0xB5)\n", - "IND = ELE_DISABLED_FEATURE_FAILURE_IND (0xB6)\n", - "IND = ELE_MUST_ATTEST_FAILURE_IND (0xB7)\n", - "IND = ELE_RNG_NOT_STARTED_FAILURE_IND (0xB8)\n", - "IND = ELE_CRC_ERROR_IND (0xB9)\n", - "IND = ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND (0xBB)\n", - "IND = ELE_INCONSISTENT_PAR_FAILURE_IND (0xBC)\n", - "IND = ELE_RNG_INST_FAILURE_FAILURE_IND (0xBD)\n", - "IND = ELE_LOCKED_REG_FAILURE_IND (0xBE)\n", - "IND = ELE_BAD_ID_FAILURE_IND (0xBF)\n", - "IND = ELE_INVALID_OPERATION_FAILURE_IND (0xC0)\n", - "IND = ELE_NON_SECURE_STATE_FAILURE_IND (0xC1)\n", - "IND = ELE_MSG_TRUNCATED_IND (0xC2)\n", - "IND = ELE_BAD_IMAGE_NUM_FAILURE_IND (0xC3)\n", - "IND = ELE_BAD_IMAGE_ADDR_FAILURE_IND (0xC4)\n", - "IND = ELE_BAD_IMAGE_PARAM_FAILURE_IND (0xC5)\n", - "IND = ELE_BAD_IMAGE_TYPE_FAILURE_IND (0xC6)\n", - "IND = ELE_CORRUPTED_SRK_FAILURE_IND (0xD0)\n", - "IND = ELE_OUT_OF_MEMORY_IND (0xD1)\n", - "IND = ELE_CSTM_FAILURE_IND (0xCF)\n", - "IND = ELE_OLD_VERSION_FAILURE_IND (0xCE)\n", - "IND = ELE_WRONG_BOOT_MODE_FAILURE_IND (0xCD)\n", - "IND = ELE_APC_ALREADY_ENABLED_FAILURE_IND (0xCB)\n", - "IND = ELE_RTC_ALREADY_ENABLED_FAILURE_IND (0xCC)\n", - "IND = ELE_ABORT_IND (0xFF)\n", - "IND = INVALID\n", - NULL -}; - -static u8 ele_cmd[] = { - ELE_PING_REQ, - ELE_FW_AUTH_REQ, - ELE_RESTART_RST_TIMER_REQ, - ELE_DUMP_DEBUG_BUFFER_REQ, - ELE_OEM_CNTN_AUTH_REQ, - ELE_VERIFY_IMAGE_REQ, - ELE_RELEASE_CONTAINER_REQ, - ELE_WRITE_SECURE_FUSE_REQ, - ELE_FWD_LIFECYCLE_UP_REQ, - ELE_READ_FUSE_REQ, - ELE_GET_FW_VERSION_REQ, - ELE_RET_LIFECYCLE_UP_REQ, - ELE_GET_EVENTS_REQ, - ELE_ENABLE_PATCH_REQ, - ELE_RELEASE_RDC_REQ, - ELE_GET_FW_STATUS_REQ, - ELE_ENABLE_OTFAD_REQ, - ELE_RESET_REQ, - ELE_UPDATE_OTP_CLKDIV_REQ, - ELE_POWER_DOWN_REQ, - ELE_ENABLE_APC_REQ, - ELE_ENABLE_RTC_REQ, - ELE_DEEP_POWER_DOWN_REQ, - ELE_STOP_RST_TIMER_REQ, - ELE_WRITE_FUSE_REQ, - ELE_RELEASE_CAAM_REQ, - ELE_RESET_A35_CTX_REQ, - ELE_MOVE_TO_UNSECURED_REQ, - ELE_GET_INFO_REQ, - ELE_ATTEST_REQ, - ELE_RELEASE_PATCH_REQ, - ELE_OTP_SEQ_SWITH_REQ -}; - -static u8 ele_ind[] = { - ELE_ROM_PING_FAILURE_IND, - ELE_FW_PING_FAILURE_IND, - ELE_BAD_SIGNATURE_FAILURE_IND, - ELE_BAD_HASH_FAILURE_IND, - ELE_INVALID_LIFECYCLE_IND, - ELE_PERMISSION_DENIED_FAILURE_IND, - ELE_INVALID_MESSAGE_FAILURE_IND, - ELE_BAD_VALUE_FAILURE_IND, - ELE_BAD_FUSE_ID_FAILURE_IND, - ELE_BAD_CONTAINER_FAILURE_IND, - ELE_BAD_VERSION_FAILURE_IND, - ELE_INVALID_KEY_FAILURE_IND, - ELE_BAD_KEY_HASH_FAILURE_IND, - ELE_NO_VALID_CONTAINER_FAILURE_IND, - ELE_BAD_CERTIFICATE_FAILURE_IND, - ELE_BAD_UID_FAILURE_IND, - ELE_BAD_MONOTONIC_COUNTER_FAILURE_IND, - ELE_MUST_SIGNED_FAILURE_IND, - ELE_NO_AUTHENTICATION_FAILURE_IND, - ELE_BAD_SRK_SET_FAILURE_IND, - ELE_UNALIGNED_PAYLOAD_FAILURE_IND, - ELE_WRONG_SIZE_FAILURE_IND, - ELE_ENCRYPTION_FAILURE_IND, - ELE_DECRYPTION_FAILURE_IND, - ELE_OTP_PROGFAIL_FAILURE_IND, - ELE_OTP_LOCKED_FAILURE_IND, - ELE_OTP_INVALID_IDX_FAILURE_IND, - ELE_TIME_OUT_FAILURE_IND, - ELE_BAD_PAYLOAD_FAILURE_IND, - ELE_WRONG_ADDRESS_FAILURE_IND, - ELE_DMA_FAILURE_IND, - ELE_DISABLED_FEATURE_FAILURE_IND, - ELE_MUST_ATTEST_FAILURE_IND, - ELE_RNG_NOT_STARTED_FAILURE_IND, - ELE_CRC_ERROR_IND, - ELE_AUTH_SKIPPED_OR_FAILED_FAILURE_IND, - ELE_INCONSISTENT_PAR_FAILURE_IND, - ELE_RNG_INST_FAILURE_FAILURE_IND, - ELE_LOCKED_REG_FAILURE_IND, - ELE_BAD_ID_FAILURE_IND, - ELE_INVALID_OPERATION_FAILURE_IND, - ELE_NON_SECURE_STATE_FAILURE_IND, - ELE_MSG_TRUNCATED_IND, - ELE_BAD_IMAGE_NUM_FAILURE_IND, - ELE_BAD_IMAGE_ADDR_FAILURE_IND, - ELE_BAD_IMAGE_PARAM_FAILURE_IND, - ELE_BAD_IMAGE_TYPE_FAILURE_IND, - ELE_CORRUPTED_SRK_FAILURE_IND, - ELE_OUT_OF_MEMORY_IND, - ELE_CSTM_FAILURE_IND, - ELE_OLD_VERSION_FAILURE_IND, - ELE_WRONG_BOOT_MODE_FAILURE_IND, - ELE_APC_ALREADY_ENABLED_FAILURE_IND, - ELE_RTC_ALREADY_ENABLED_FAILURE_IND, - ELE_ABORT_IND -}; - -static u8 ele_ipc[] = { - ELE_IPC_MU_RTD, - ELE_IPC_MU_APD -}; - -static u8 ele_status[] = { - ELE_SUCCESS_IND, - ELE_FAILURE_IND -}; - -static inline u32 get_idx(u8 *list, u8 tgt, u32 size) -{ - u32 i; - - for (i = 0; i < size; i++) { - if (list[i] == tgt) - return i; - } - - return i; /* last str is invalid */ -} - -static void display_ahab_auth_ind(u32 event) -{ - u8 resp_ind = (event >> 8) & 0xff; - - printf("%s\n", ele_ind_str[get_idx(ele_ind, resp_ind, ARRAY_SIZE(ele_ind))]); -} - -int ahab_auth_cntr_hdr(struct container_hdr *container, u16 length) -{ - int err; - u32 resp; - - memcpy((void *)IMG_CONTAINER_BASE, (const void *)container, - ALIGN(length, CONFIG_SYS_CACHELINE_SIZE)); - - flush_dcache_range(IMG_CONTAINER_BASE, - IMG_CONTAINER_BASE + ALIGN(length, CONFIG_SYS_CACHELINE_SIZE) - 1); - - err = ahab_auth_oem_ctnr(IMG_CONTAINER_BASE, &resp); - if (err) { - printf("Authenticate container hdr failed, return %d, resp 0x%x\n", - err, resp); - display_ahab_auth_ind(resp); - } - - return err; -} - -int ahab_auth_release(void) -{ - int err; - u32 resp; - - err = ahab_release_container(&resp); - if (err) { - printf("Error: release container failed, resp 0x%x!\n", resp); - display_ahab_auth_ind(resp); - } - - return err; -} - -int ahab_verify_cntr_image(struct boot_img_t *img, int image_index) -{ - int err; - u32 resp; - - err = ahab_verify_image(image_index, &resp); - if (err) { - printf("Authenticate img %d failed, return %d, resp 0x%x\n", - image_index, err, resp); - display_ahab_auth_ind(resp); - - return -EIO; - } - - return 0; -} - -static inline bool check_in_dram(ulong addr) -{ - int i; - struct bd_info *bd = gd->bd; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { - if (bd->bi_dram[i].size) { - if (addr >= bd->bi_dram[i].start && - addr < (bd->bi_dram[i].start + bd->bi_dram[i].size)) - return true; - } - } - - return false; -} - -int authenticate_os_container(ulong addr) -{ - struct container_hdr *phdr; - int i, ret = 0; - int err; - u16 length; - struct boot_img_t *img; - unsigned long s, e; - - if (addr % 4) { - puts("Error: Image's address is not 4 byte aligned\n"); - return -EINVAL; - } - - if (!check_in_dram(addr)) { - puts("Error: Image's address is invalid\n"); - return -EINVAL; - } - - phdr = (struct container_hdr *)addr; - if (phdr->tag != 0x87 || phdr->version != 0x0) { - printf("Error: Wrong container header\n"); - return -EFAULT; - } - - if (!phdr->num_images) { - printf("Error: Wrong container, no image found\n"); - return -EFAULT; - } - - length = phdr->length_lsb + (phdr->length_msb << 8); - - debug("container length %u\n", length); - - err = ahab_auth_cntr_hdr(phdr, length); - if (err) { - ret = -EIO; - goto exit; - } - - debug("Verify images\n"); - - /* Copy images to dest address */ - for (i = 0; i < phdr->num_images; i++) { - img = (struct boot_img_t *)(addr + - sizeof(struct container_hdr) + - i * sizeof(struct boot_img_t)); - - debug("img %d, dst 0x%x, src 0x%lx, size 0x%x\n", - i, (uint32_t)img->dst, img->offset + addr, img->size); - - memcpy((void *)img->dst, (const void *)(img->offset + addr), - img->size); - - s = img->dst & ~(CONFIG_SYS_CACHELINE_SIZE - 1); - e = ALIGN(img->dst + img->size, CONFIG_SYS_CACHELINE_SIZE) - 1; - - flush_dcache_range(s, e); - - ret = ahab_verify_cntr_image(img, i); - if (ret) - goto exit; - } - -exit: - debug("ahab_auth_release, 0x%x\n", ret); - ahab_auth_release(); - - return ret; -} - -static int do_authenticate(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - ulong addr; - - if (argc < 2) - return CMD_RET_USAGE; - - addr = simple_strtoul(argv[1], NULL, 16); - - printf("Authenticate OS container at 0x%lx\n", addr); - - if (authenticate_os_container(addr)) - return CMD_RET_FAILURE; - - return CMD_RET_SUCCESS; -} - -static void display_life_cycle(u32 lc) -{ - printf("Lifecycle: 0x%08X, ", lc); - switch (lc) { - case 0x1: - printf("BLANK\n\n"); - break; - case 0x2: - printf("FAB\n\n"); - break; - case 0x4: - printf("NXP Provisioned\n\n"); - break; - case 0x8: - printf("OEM Open\n\n"); - break; - case 0x10: - printf("OEM Secure World Closed\n\n"); - break; - case 0x20: - printf("OEM closed\n\n"); - break; - case 0x40: - printf("Field Return OEM\n\n"); - break; - case 0x80: - printf("Field Return NXP\n\n"); - break; - case 0x100: - printf("OEM Locked\n\n"); - break; - case 0x200: - printf("BRICKED\n\n"); - break; - default: - printf("Unknown\n\n"); - break; - } -} - -static int confirm_close(void) -{ - puts("Warning: Please ensure your sample is in NXP closed state, " - "OEM SRK hash has been fused, \n" - " and you are able to boot a signed image successfully " - "without any SECO events reported.\n" - " If not, your sample will be unrecoverable.\n" - "\nReally perform this operation? <y/N>\n"); - - if (confirm_yesno()) - return 1; - - puts("Ahab close aborted\n"); - return 0; -} - -static int do_ahab_close(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - int err; - u32 resp; - - if (!confirm_close()) - return -EACCES; - - err = ahab_forward_lifecycle(8, &resp); - if (err != 0) { - printf("Error in forward lifecycle to OEM closed\n"); - return -EIO; - } - - printf("Change to OEM closed successfully\n"); - - return 0; -} - -int ahab_dump(void) -{ - u32 buffer[32]; - int ret, i = 0; - - do { - ret = ahab_dump_buffer(buffer, 32); - if (ret < 0) { - printf("Error in dump AHAB log\n"); - return -EIO; - } - - if (ret == 1) - break; - for (i = 0; i < ret; i++) - printf("0x%x\n", buffer[i]); - } while (ret >= 21); - - return 0; -} - -static int do_ahab_dump(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - return ahab_dump(); -} - -static void display_event(u32 event) -{ - printf("\n\t0x%08x\n", event); - printf("\t%s", ele_ipc_str[get_idx(ele_ipc, - (event >> 24) & 0xFF, ARRAY_SIZE(ele_ipc))]); - printf("\t%s", ele_cmd_str[get_idx(ele_cmd, - (event >> 16) & 0xFF, ARRAY_SIZE(ele_cmd))]); - printf("\t%s", ele_ind_str[get_idx(ele_ind, - (event >> 8) & 0xFF, ARRAY_SIZE(ele_ind))]); - printf("\t%s", ele_status_str[get_idx(ele_status, - event & 0xFF, ARRAY_SIZE(ele_status))]); -} - -static int do_ahab_status(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - u32 lc, i; - u32 events[AHAB_MAX_EVENTS]; - u32 cnt = AHAB_MAX_EVENTS; - int ret; - - lc = readl(FSB_BASE_ADDR + 0x41c); - lc &= 0x3ff; - - display_life_cycle(lc); - - ret = ahab_get_events(events, &cnt, NULL); - if (ret) { - printf("Get ELE EVENTS error %d\n", ret); - return CMD_RET_FAILURE; - } - - if (!cnt) { - puts("\n\tNo Events Found!\n"); - return 0; - } - - for (i = 0; i < cnt; i++) - display_event(events[i]); - - return 0; -} - -U_BOOT_CMD(auth_cntr, CONFIG_SYS_MAXARGS, 1, do_authenticate, - "autenticate OS container via AHAB", - "addr\n" - "addr - OS container hex address\n" -); - -U_BOOT_CMD(ahab_close, CONFIG_SYS_MAXARGS, 1, do_ahab_close, - "Change AHAB lifecycle to OEM closed", - "" -); - -U_BOOT_CMD(ahab_dump, CONFIG_SYS_MAXARGS, 1, do_ahab_dump, - "Dump AHAB log for debug", - "" -); - -U_BOOT_CMD(ahab_status, CONFIG_SYS_MAXARGS, 1, do_ahab_status, - "display AHAB lifecycle only", - "" -);
Use common file ele_ahab.c for i.MX9 and iMX8ULP AHAB support, since both of them use same sentinel ELE APIs Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
Remove legacy command definitions, change to use new ELE_xxx command request.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/s400_api.h | 15 --------------- arch/arm/mach-imx/imx8ulp/rdc.c | 2 +- arch/arm/mach-imx/imx9/trdc.c | 2 +- drivers/misc/sentinel/s400_api.c | 28 ++++++++++++++-------------- 4 files changed, 16 insertions(+), 31 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/s400_api.h b/arch/arm/include/asm/mach-imx/s400_api.h index c87a7c1..5582ff1 100644 --- a/arch/arm/include/asm/mach-imx/s400_api.h +++ b/arch/arm/include/asm/mach-imx/s400_api.h @@ -109,21 +109,6 @@ #define ELE_SUCCESS_IND (0xD6) #define ELE_FAILURE_IND (0x29)
-#define AHAB_LOG_CID 0x21 -#define AHAB_AUTH_OEM_CTNR_CID 0x87 -#define AHAB_VERIFY_IMG_CID 0x88 -#define AHAB_RELEASE_CTNR_CID 0x89 -#define AHAB_WRITE_SECURE_FUSE_REQ_CID 0x91 -#define AHAB_FWD_LIFECYCLE_UP_REQ_CID 0x95 -#define AHAB_READ_FUSE_REQ_CID 0x97 -#define AHAB_GET_FW_VERSION_CID 0x9D -#define AHAB_GET_EVENTS_REQ_CID 0xA2 -#define AHAB_RELEASE_RDC_REQ_CID 0xC4 -#define AHAB_GET_FW_STATUS_CID 0xC5 -#define AHAB_WRITE_FUSE_REQ_CID 0xD6 -#define AHAB_CAAM_RELEASE_CID 0xD7 -#define AHAB_GET_INFO_CID 0xDA - #define S400_MAX_MSG 255U
struct sentinel_msg { diff --git a/arch/arm/mach-imx/imx8ulp/rdc.c b/arch/arm/mach-imx/imx8ulp/rdc.c index 56df111..50b097b 100644 --- a/arch/arm/mach-imx/imx8ulp/rdc.c +++ b/arch/arm/mach-imx/imx8ulp/rdc.c @@ -210,7 +210,7 @@ int release_rdc(enum rdc_type type) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_RELEASE_RDC_REQ_CID; + msg.command = ELE_RELEASE_RDC_REQ; msg.data[0] = (rdc_id << 8) | 0x2; /* A35 XRDC */
mu_hal_init(s_mu_base); diff --git a/arch/arm/mach-imx/imx9/trdc.c b/arch/arm/mach-imx/imx9/trdc.c index 3f37ce7..e05c704 100644 --- a/arch/arm/mach-imx/imx9/trdc.c +++ b/arch/arm/mach-imx/imx9/trdc.c @@ -339,7 +339,7 @@ int release_rdc(u8 xrdc) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_RELEASE_RDC_REQ_CID; + msg.command = ELE_RELEASE_RDC_REQ; msg.data[0] = (rdc_id << 8) | 0x2; /* A55 */
mu_hal_init(s_mu_base); diff --git a/drivers/misc/sentinel/s400_api.c b/drivers/misc/sentinel/s400_api.c index c6b4ef5..6c0d0b3 100644 --- a/drivers/misc/sentinel/s400_api.c +++ b/drivers/misc/sentinel/s400_api.c @@ -29,7 +29,7 @@ int ahab_release_rdc(u8 core_id, u8 xrdc, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_RELEASE_RDC_REQ_CID; + msg.command = ELE_RELEASE_RDC_REQ; switch (xrdc) { case 0: msg.data[0] = (0x74 << 8) | core_id; @@ -74,7 +74,7 @@ int ahab_auth_oem_ctnr(ulong ctnr_addr, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 3; - msg.command = AHAB_AUTH_OEM_CTNR_CID; + msg.command = ELE_OEM_CNTN_AUTH_REQ; msg.data[0] = upper_32_bits(ctnr_addr); msg.data[1] = lower_32_bits(ctnr_addr);
@@ -104,7 +104,7 @@ int ahab_release_container(u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = AHAB_RELEASE_CTNR_CID; + msg.command = ELE_RELEASE_CONTAINER_REQ;
ret = misc_call(dev, false, &msg, size, &msg, size); if (ret) @@ -132,7 +132,7 @@ int ahab_verify_image(u32 img_id, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_VERIFY_IMG_CID; + msg.command = ELE_VERIFY_IMAGE_REQ; msg.data[0] = 1 << img_id;
ret = misc_call(dev, false, &msg, size, &msg, size); @@ -161,7 +161,7 @@ int ahab_forward_lifecycle(u16 life_cycle, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_FWD_LIFECYCLE_UP_REQ_CID; + msg.command = ELE_FWD_LIFECYCLE_UP_REQ; msg.data[0] = life_cycle;
ret = misc_call(dev, false, &msg, size, &msg, size); @@ -201,7 +201,7 @@ int ahab_read_common_fuse(u16 fuse_id, u32 *fuse_words, u32 fuse_num, u32 *respo msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_READ_FUSE_REQ_CID; + msg.command = ELE_READ_FUSE_REQ; msg.data[0] = fuse_id;
ret = misc_call(dev, false, &msg, size, &msg, size); @@ -238,7 +238,7 @@ int ahab_write_fuse(u16 fuse_id, u32 fuse_val, bool lock, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 3; - msg.command = AHAB_WRITE_FUSE_REQ_CID; + msg.command = ELE_WRITE_FUSE_REQ; msg.data[0] = (32 << 16) | (fuse_id << 5); if (lock) msg.data[0] |= (1 << 31); @@ -271,7 +271,7 @@ int ahab_release_caam(u32 core_did, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 2; - msg.command = AHAB_CAAM_RELEASE_CID; + msg.command = ELE_RELEASE_CAAM_REQ; msg.data[0] = core_did;
ret = misc_call(dev, false, &msg, size, &msg, size); @@ -310,7 +310,7 @@ int ahab_get_fw_version(u32 *fw_version, u32 *sha1, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = AHAB_GET_FW_VERSION_CID; + msg.command = ELE_GET_FW_VERSION_REQ;
ret = misc_call(dev, false, &msg, size, &msg, size); if (ret) @@ -341,7 +341,7 @@ int ahab_dump_buffer(u32 *buffer, u32 buffer_length) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = AHAB_LOG_CID; + msg.command = ELE_DUMP_DEBUG_BUFFER_REQ;
ret = misc_call(dev, false, &msg, size, &msg, size); if (ret) { @@ -375,7 +375,7 @@ int ahab_get_info(struct sentinel_get_info_data *info, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 4; - msg.command = AHAB_GET_INFO_CID; + msg.command = ELE_GET_INFO_REQ; msg.data[0] = upper_32_bits((ulong)info); msg.data[1] = lower_32_bits((ulong)info); msg.data[2] = sizeof(struct sentinel_get_info_data); @@ -406,7 +406,7 @@ int ahab_get_fw_status(u32 *status, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = AHAB_GET_FW_STATUS_CID; + msg.command = ELE_GET_FW_STATUS_REQ;
ret = misc_call(dev, false, &msg, size, &msg, size); if (ret) @@ -436,7 +436,7 @@ int ahab_release_m33_trout(void) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = 0xd3; + msg.command = ELE_ENABLE_RTC_REQ;
ret = misc_call(dev, false, &msg, size, &msg, size); if (ret) @@ -467,7 +467,7 @@ int ahab_get_events(u32 *events, u32 *events_cnt, u32 *response) msg.version = AHAB_VERSION; msg.tag = AHAB_CMD_TAG; msg.size = 1; - msg.command = AHAB_GET_EVENTS_REQ_CID; + msg.command = ELE_GET_EVENTS_REQ;
Remove legacy command definitions, change to use new ELE_xxx command request. Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
Before moving the lifecycle to OEM closed, confirm the lifecycle is OEM open, otherwise cancel to move forward the lifecycle.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/ele_ahab.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/mach-imx/ele_ahab.c b/arch/arm/mach-imx/ele_ahab.c index da8c99b..58b6542 100644 --- a/arch/arm/mach-imx/ele_ahab.c +++ b/arch/arm/mach-imx/ele_ahab.c @@ -474,10 +474,20 @@ static int do_ahab_close(struct cmd_tbl *cmdtp, int flag, int argc, { int err; u32 resp; + u32 lc;
if (!confirm_close()) return -EACCES;
+ lc = readl(FSB_BASE_ADDR + 0x41c); + lc &= 0x3ff; + + if (lc != 0x8) { + puts("Current lifecycle is NOT OEM open, can't move to OEM closed\n"); + display_life_cycle(lc); + return -EPERM; + } + err = ahab_forward_lifecycle(8, &resp); if (err != 0) { printf("Error in forward lifecycle to OEM closed\n");
Before moving the lifecycle to OEM closed, confirm the lifecycle is OEM open, otherwise cancel to move forward the lifecycle. Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
The OEM Secure World Closed is not a valid lifecycle on iMX8ULP/iMX9. So remove it from lifecycle print.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/ele_ahab.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/mach-imx/ele_ahab.c b/arch/arm/mach-imx/ele_ahab.c index 58b6542..99fc540 100644 --- a/arch/arm/mach-imx/ele_ahab.c +++ b/arch/arm/mach-imx/ele_ahab.c @@ -429,9 +429,6 @@ static void display_life_cycle(u32 lc) case 0x8: printf("OEM Open\n\n"); break; - case 0x10: - printf("OEM Secure World Closed\n\n"); - break; case 0x20: printf("OEM closed\n\n"); break;
The OEM Secure World Closed is not a valid lifecycle on iMX8ULP/iMX9. So remove it from lifecycle print. Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
Add get_events API to retrieve any singular events that has occurred since the FW has started from sentinel Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com
sbabic@denx.de
Ye Li
