Hi
I am currently porting u-boot to a new board based on Freescales iMX25 processor. I would like to add USB support. As I can see there is no support in current head for USB on iMX. Can someone give me some hints what I have to do to enable USB host support on iMX25.
Matthias
Matthias Weißer <weisserm <at> arcor.de> writes:
Hi
Matthias
Hi Matthias, I'm also trying the same, did you got solution for your problem, if so kindly share with me.
Sathish
Am 19.05.2011 07:29, schrieb Sathish:
Matthias Weißer<weisserm<at> arcor.de> writes:
Hi
Matthias
Hi Sathish
I got it working and plan to submit a patchset for our iMX25 based board when the next merge window opens. I can send you the patch (which will probably break other iMX based boards) privatly if you are interested.
Matthias
Matthias Weißer
Sathish
