[U-Boot] [RFC] atmel:dataflash: remove unused mmc_mux
The command 'dataflash_mmc_mux' is nowhere used and uses an outdated interface since dataflash is handled via the sf command. This is a first step towards removing the dataflash and merging it with sf interfaces.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- common/Makefile | 1 - common/cmd_dataflash_mmc_mux.c | 64 ---------------------------------------- include/at45.h | 5 ---- 3 files changed, 70 deletions(-) delete mode 100644 common/cmd_dataflash_mmc_mux.c
diff --git a/common/Makefile b/common/Makefile index 3d62775..0500e87 100644 --- a/common/Makefile +++ b/common/Makefile @@ -71,7 +71,6 @@ COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o COBJS-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o -COBJS-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o COBJS-$(CONFIG_CMD_DATE) += cmd_date.o ifdef CONFIG_4xx COBJS-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o diff --git a/common/cmd_dataflash_mmc_mux.c b/common/cmd_dataflash_mmc_mux.c deleted file mode 100644 index f8f1787..0000000 --- a/common/cmd_dataflash_mmc_mux.c +++ /dev/null @@ -1,64 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> - -static int mmc_nspi (const char *); - -int do_dataflash_mmc_mux (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - switch (argc) { - case 2: /* on / off */ - switch (mmc_nspi (argv[1])) { - case 0: AT91F_SelectSPI (); - break; - case 1: AT91F_SelectMMC (); - break; - } - case 1: /* get status */ - printf ("Mux is configured to be %s\n", - AT91F_GetMuxStatus () ? "MMC" : "SPI"); - return 0; - default: - return CMD_RET_USAGE; - } - return 0; -} - -static int mmc_nspi (const char *s) -{ - if (strcmp (s, "mmc") == 0) { - return 1; - } else if (strcmp (s, "spi") == 0) { - return 0; - } - return -1; -} - -U_BOOT_CMD( - dataflash_mmc_mux, 2, 1, do_dataflash_mmc_mux, - "enable or disable MMC or SPI\n", - "[mmc, spi]\n" - " - enable or disable MMC or SPI" -); diff --git a/include/at45.h b/include/at45.h index e7e3711..fda87a5 100644 --- a/include/at45.h +++ b/include/at45.h @@ -1,11 +1,6 @@
#ifndef _AT45_H_ #define _AT45_H_ -#ifdef CONFIG_DATAFLASH_MMC_SELECT -extern void AT91F_SelectMMC(void); -extern void AT91F_SelectSPI(void); -extern int AT91F_GetMuxStatus(void); -#endif extern void AT91F_SpiInit(void); extern void AT91F_SpiEnable(int cs); extern unsigned int AT91F_SpiWrite ( AT91PS_DataflashDesc pDesc );
Andreas Bießmann
