[U-Boot] [PATCH v2 00/10] MIPS: initial support for emulated Malta board
This patch set adds initial support for the MIPS Malta CoreLV board emulated under Qemu.
The patches are against the testing branch of the MIPS custodian tree. The changes since the previous version of the series are described in the individual patches.
Gabor Juhos (10): MIPS: qemu-malta: add support for emulated MIPS Malta board MIPS: qemu-malta: add reset support MIPS: qemu-malta: enable flash support MIPS: import gt64120.h header from Linux 3.8-rc3 MIPS: qemu-malta: setup GT64120 registers as done by YAMON MIPS: qemu-malta: add PCI support net: pcnet: use pci_virt_to_mem to obtain buffer addresses MIPS: qemu-malta: bring up ethernet MIPS: bootm.c: add YAMON style Linux preparation/jump code MIPS: start.S: emulate REVISION register for qemu-malta
arch/mips/cpu/mips32/start.S | 8 +- arch/mips/include/asm/gt64120.h | 550 ++++++++++++++++++++++++++++++++++++++ arch/mips/include/asm/malta.h | 23 ++ arch/mips/lib/bootm.c | 60 ++++- board/qemu-malta/Makefile | 48 ++++ board/qemu-malta/lowlevel_init.S | 70 +++++ board/qemu-malta/pci.c | 168 ++++++++++++ board/qemu-malta/qemu-malta.c | 37 +++ boards.cfg | 2 + drivers/net/pcnet.c | 2 +- include/configs/qemu-malta.h | 119 +++++++++ 11 files changed, 1083 insertions(+), 4 deletions(-) create mode 100644 arch/mips/include/asm/gt64120.h create mode 100644 arch/mips/include/asm/malta.h create mode 100644 board/qemu-malta/Makefile create mode 100644 board/qemu-malta/lowlevel_init.S create mode 100644 board/qemu-malta/pci.c create mode 100644 board/qemu-malta/qemu-malta.c create mode 100644 include/configs/qemu-malta.h
-- 1.7.10
Add minimal support for the MIPS Malta CoreLV board emulated by Qemu. The only supported peripherial is the UART.
This is enough to boot U-Boot to the command prompt both in little and big endian mode.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: - remove custom u-boot.lds file - rebased against mips/testing
Changes since RFC: ---
--- Screenshot:
U-Boot 2013.01-00075-g80fa5c7 (Feb 02 2013 - 16:59:19)
Board: MIPS Malta CoreLV (Qemu) DRAM: 256 MiB Using default environment
In: serial Out: serial Err: serial qemu-malta # version
U-Boot 2013.01-00075-g80fa5c7 (Feb 02 2013 - 16:59:19) mips-openwrt-linux-uclibc-gcc (Linaro GCC 4.6-2012.12) 4.6.4 20121210 (prerelease) GNU ld (GNU Binutils) 2.22 qemu-malta # help ? - alias for 'help' base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory cmp - memory compare coninfo - print console devices and information cp - memory copy crc32 - checksum calculation echo - echo args to console editenv - edit environment variable env - environment handling commands go - start application at address 'addr' help - print command description/usage iminfo - print header information for application image imxtract- extract a part of a multi-image itest - return true/false on integer compare loop - infinite loop on address range md - memory display mm - memory modify (auto-incrementing address) mtest - simple RAM read/write test mw - memory write (fill) nm - memory modify (constant address) printenv- print environment variables reset - Perform RESET of the CPU run - run commands in an environment variable setenv - set environment variables sleep - delay execution for some time source - run script from memory version - print monitor, compiler and linker version qemu-malta # --- arch/mips/include/asm/malta.h | 16 ++++++ board/qemu-malta/Makefile | 45 +++++++++++++++++ board/qemu-malta/lowlevel_init.S | 19 +++++++ board/qemu-malta/qemu-malta.c | 20 ++++++++ boards.cfg | 2 + include/configs/qemu-malta.h | 104 ++++++++++++++++++++++++++++++++++++++ 6 files changed, 206 insertions(+) create mode 100644 arch/mips/include/asm/malta.h create mode 100644 board/qemu-malta/Makefile create mode 100644 board/qemu-malta/lowlevel_init.S create mode 100644 board/qemu-malta/qemu-malta.c create mode 100644 include/configs/qemu-malta.h
diff --git a/arch/mips/include/asm/malta.h b/arch/mips/include/asm/malta.h new file mode 100644 index 0000000..b215164 --- /dev/null +++ b/arch/mips/include/asm/malta.h @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published + * by the Free Software Foundation. + */ + +#ifndef _MIPS_ASM_MALTA_H +#define _MIPS_ASM_MALTA_H + +#define MALTA_IO_PORT_BASE 0x10000000 + +#define MALTA_UART_BASE (MALTA_IO_PORT_BASE + 0x3f8) + +#endif /* _MIPS_ASM_MALTA_H */ diff --git a/board/qemu-malta/Makefile b/board/qemu-malta/Makefile new file mode 100644 index 0000000..6251bb8 --- /dev/null +++ b/board/qemu-malta/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS = $(BOARD).o +SOBJS = lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/qemu-malta/lowlevel_init.S b/board/qemu-malta/lowlevel_init.S new file mode 100644 index 0000000..c5c5bd9 --- /dev/null +++ b/board/qemu-malta/lowlevel_init.S @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published + * by the Free Software Foundation. + */ + +#include <asm/regdef.h> + + .text + .set noreorder + .set mips32 + + .globl lowlevel_init +lowlevel_init: + + jr ra + nop diff --git a/board/qemu-malta/qemu-malta.c b/board/qemu-malta/qemu-malta.c new file mode 100644 index 0000000..9ba711d --- /dev/null +++ b/board/qemu-malta/qemu-malta.c @@ -0,0 +1,20 @@ +/* + * Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published + * by the Free Software Foundation. + */ + +#include <common.h> + +phys_size_t initdram(int board_type) +{ + return CONFIG_SYS_MEM_SIZE; +} + +int checkboard(void) +{ + puts("Board: MIPS Malta CoreLV (Qemu)\n"); + return 0; +} diff --git a/boards.cfg b/boards.cfg index 98f7a14..7f919e5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -426,6 +426,8 @@ qemu_mips mips mips32 qemu-mips - qemu_mipsel mips mips32 qemu-mips - - qemu-mips:SYS_LITTLE_ENDIAN qemu_mips64 mips mips64 qemu-mips - - qemu-mips64:SYS_BIG_ENDIAN qemu_mips64el mips mips64 qemu-mips - - qemu-mips64:SYS_LITTLE_ENDIAN +qemu_malta mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_BIG_ENDIAN +qemu_maltael mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_LITTLE_ENDIAN vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND diff --git a/include/configs/qemu-malta.h b/include/configs/qemu-malta.h new file mode 100644 index 0000000..c72c5dd --- /dev/null +++ b/include/configs/qemu-malta.h @@ -0,0 +1,104 @@ +/* + * Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published + * by the Free Software Foundation. + */ + +#ifndef _QEMU_MALTA_CONFIG_H +#define _QEMU_MALTA_CONFIG_H + +#include <asm/addrspace.h> +#include <asm/malta.h> + +/* + * System configuration + */ +#define CONFIG_QEMU_MALTA + +/* + * CPU Configuration + */ +#define CONFIG_SYS_MHZ 250 /* arbitrary value */ +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_SYS_DCACHE_SIZE 16384 /* arbitrary value */ +#define CONFIG_SYS_ICACHE_SIZE 16384 /* arbitrary value */ +#define CONFIG_SYS_CACHELINE_SIZE 32 /* arbitrary value */ + +#define CONFIG_SWAP_IO_SPACE + +/* + * Memory map + */ +#define CONFIG_SYS_TEXT_BASE 0xbfc00000 /* Rom version */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 /* Cached addr */ +#define CONFIG_SYS_MEM_SIZE (256 * 1024 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x80800000 + +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) + +/* + * Console configuration + */ +#if defined(CONFIG_SYS_LITTLE_ENDIAN) +#define CONFIG_SYS_PROMPT "qemu-maltael # " +#else +#define CONFIG_SYS_PROMPT "qemu-malta # " +#endif + +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING + +/* + * Serial driver + */ +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK 115200 +#define CONFIG_SYS_NS16550_COM1 CKSEG1ADDR(MALTA_UART_BASE) +#define CONFIG_CONS_INDEX 1 + +/* + * Environment + */ +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x10000 + +/* + * Flash configuration + */ +#define CONFIG_SYS_NO_FLASH + +/* + * Commands + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS + +#define CONFIG_SYS_LONGHELP /* verbose help, undef to save memory */ + +#endif /* _QEMU_MALTA_CONFIG_H */
2013/2/2 Gabor Juhos juhosg@openwrt.org:
Changes since v1:
Screenshot:
- Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org
- This program is free software; you can redistribute it and/or modify it
- under the terms of the GNU General Public License version 2 as published
- by the Free Software Foundation.
.text
.set noreorder
.set mips32
+lowlevel_init:
jr ra
nop
can't we use CONFIG_SKIP_LOWLEVEL_INIT and drop this file? We neither need to initialize a memory controller nor caches on Qemu.
- System configuration
we should extend qemu-mips.h and define CONFIG_QEMU_MALTA respectively CONFIG_QEMU_MALTA in boards.cfg to avoid redundant code. All differences could be handled with these options.
- CPU Configuration
- Memory map
- Console configuration
- Serial driver
- Environment
- Flash configuration
- Commands
1.7.10
Hi Daniel,
.text
.set noreorder
.set mips32
+lowlevel_init:
jr ra
nop
We can use that option and drop the file from this patch. However in that case I will have to reintroduce it and remove the config option in a subsequent patch. The lowlevel_init will be used to initialize the Galileo system controller.
Sure, we can do it if you prefer that. In my opinion it is much cleaner to introduce a new config file, instead of adding random ifdef statements into another file.
-Gabor
The MIPS Malta board has a SOFTRES register. Writing a magic value into that register initiates a board reset.
Use this feature to implement reset support.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: - rebased against mips/testing
Changes since RFC: --- --- arch/mips/include/asm/malta.h | 3 +++ board/qemu-malta/qemu-malta.c | 11 +++++++++++ 2 files changed, 14 insertions(+)
diff --git a/arch/mips/include/asm/malta.h b/arch/mips/include/asm/malta.h index b215164..f2bbf0f 100644 --- a/arch/mips/include/asm/malta.h +++ b/arch/mips/include/asm/malta.h @@ -13,4 +13,7 @@
+#define MALTA_RESET_BASE 0x1f000500 +#define GORESET 0x42 + #endif /* _MIPS_ASM_MALTA_H */ diff --git a/board/qemu-malta/qemu-malta.c b/board/qemu-malta/qemu-malta.c index 9ba711d..9333242 100644 --- a/board/qemu-malta/qemu-malta.c +++ b/board/qemu-malta/qemu-malta.c @@ -8,6 +8,9 @@
#include <common.h>
+#include <asm/io.h> +#include <asm/malta.h> + phys_size_t initdram(int board_type) { return CONFIG_SYS_MEM_SIZE; @@ -18,3 +21,11 @@ int checkboard(void) puts("Board: MIPS Malta CoreLV (Qemu)\n"); return 0; } + +void _machine_restart(void) +{ + void __iomem *reset_base; + + reset_base = (void __iomem *) CKSEG1ADDR(MALTA_RESET_BASE); + __raw_writel(le32_to_cpu(GORESET), reset_base); +}
Changes since v1:
#include <common.h>
don't you need to swap from CPU endianess to register/bus endinaness? I think regisers/bus are always BE and only CPU changes between LE/BE. So we either need __raw_writel(cpu_to_be32(v),a) or writel_be32(v,a).
1.7.10
#include <common.h>
The register uses the same endianness as the CPU, so we have to write either a LE or BE value depending on the CPU endianness.
This means that we should use the __raw_writel accessor with a plain GORESET value. That method works in Linux but does not work in U-Boot.
The Malta board needs the CONFIG_SWAP_IO_SPACE for PCI device acccess. If this config options is set then the __raw_writel accessor will swap the given value on BE systems. So I have to pre-swap the value with le32_to_cpu to make it working correctly.
The relevant definitions from 'arch/mips/include/asm/io.h':
#if defined(CONFIG_SWAP_IO_SPACE) && defined(__MIPSEB__)
#define __ioswab8(x) (x) #define __ioswab16(x) swab16(x) #define __ioswab32(x) swab32(x)
#else ... #define writeb(b,addr) (*(volatile unsigned char *)(addr)) = (b) #define writew(b,addr) (*(volatile unsigned short *)(addr)) = (__ioswab16(b)) #define writel(b,addr) (*(volatile unsigned int *)(addr)) = (__ioswab32(b)) #define __raw_writeb writeb #define __raw_writew writew #define __raw_writel writel
Maybe here is the time to fix these accessors in asm/io.h?
-Gabor
Changes since RFC: --- --- arch/mips/include/asm/malta.h | 2 ++ include/configs/qemu-malta.h | 13 +++++++++++-- 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/mips/include/asm/malta.h b/arch/mips/include/asm/malta.h index f2bbf0f..ab951e6 100644 --- a/arch/mips/include/asm/malta.h +++ b/arch/mips/include/asm/malta.h @@ -16,4 +16,6 @@ #define MALTA_RESET_BASE 0x1f000500 #define GORESET 0x42
+#define MALTA_FLASH_BASE 0x1fc00000 + #endif /* _MIPS_ASM_MALTA_H */ diff --git a/include/configs/qemu-malta.h b/include/configs/qemu-malta.h index c72c5dd..881c15d 100644 --- a/include/configs/qemu-malta.h +++ b/include/configs/qemu-malta.h @@ -34,7 +34,7 @@ * Memory map */ #define CONFIG_SYS_TEXT_BASE 0xbfc00000 /* Rom version */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_SYS_SDRAM_BASE 0x80000000 /* Cached addr */ #define CONFIG_SYS_MEM_SIZE (256 * 1024 * 1024) @@ -86,7 +86,16 @@ /* * Flash configuration */ -#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_FLASH_BASE (KSEG1 | MALTA_FLASH_BASE) +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 128 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + +#if defined(CONFIG_SYS_BIG_ENDIAN) +#define CONFIG_SYS_WRITE_SWAPPED_DATA 1 +#endif
/* * Commands
The Linux specific register access macros, the extern function declarations and the UL suffixes has been removed.
The header file will be used for the qemu-malta board.
Changes since RFC: --- --- arch/mips/include/asm/gt64120.h | 550 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 550 insertions(+) create mode 100644 arch/mips/include/asm/gt64120.h
diff --git a/arch/mips/include/asm/gt64120.h b/arch/mips/include/asm/gt64120.h new file mode 100644 index 0000000..457d413 --- /dev/null +++ b/arch/mips/include/asm/gt64120.h @@ -0,0 +1,550 @@ +/* + * Copyright (C) 2000, 2004, 2005 MIPS Technologies, Inc. + * All rights reserved. + * Authors: Carsten Langgaard carstenl@mips.com + * Maciej W. Rozycki macro@mips.com + * Copyright (C) 2005 Ralf Baechle (ralf@linux-mips.org) + * + * This program is free software; you can distribute it and/or modify it + * under the terms of the GNU General Public License (Version 2) as + * published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 59 Temple Place - Suite 330, Boston MA 02111-1307, USA. + */ +#ifndef _ASM_GT64120_H +#define _ASM_GT64120_H + +#define MSK(n) ((1 << (n)) - 1) + +/* + * Register offset addresses + */ +/* CPU Configuration. */ +#define GT_CPU_OFS 0x000 + +#define GT_MULTI_OFS 0x120 + +/* CPU Address Decode. */ +#define GT_SCS10LD_OFS 0x008 +#define GT_SCS10HD_OFS 0x010 +#define GT_SCS32LD_OFS 0x018 +#define GT_SCS32HD_OFS 0x020 +#define GT_CS20LD_OFS 0x028 +#define GT_CS20HD_OFS 0x030 +#define GT_CS3BOOTLD_OFS 0x038 +#define GT_CS3BOOTHD_OFS 0x040 +#define GT_PCI0IOLD_OFS 0x048 +#define GT_PCI0IOHD_OFS 0x050 +#define GT_PCI0M0LD_OFS 0x058 +#define GT_PCI0M0HD_OFS 0x060 +#define GT_ISD_OFS 0x068 + +#define GT_PCI0M1LD_OFS 0x080 +#define GT_PCI0M1HD_OFS 0x088 +#define GT_PCI1IOLD_OFS 0x090 +#define GT_PCI1IOHD_OFS 0x098 +#define GT_PCI1M0LD_OFS 0x0a0 +#define GT_PCI1M0HD_OFS 0x0a8 +#define GT_PCI1M1LD_OFS 0x0b0 +#define GT_PCI1M1HD_OFS 0x0b8 +#define GT_PCI1M1LD_OFS 0x0b0 +#define GT_PCI1M1HD_OFS 0x0b8 + +#define GT_SCS10AR_OFS 0x0d0 +#define GT_SCS32AR_OFS 0x0d8 +#define GT_CS20R_OFS 0x0e0 +#define GT_CS3BOOTR_OFS 0x0e8 + +#define GT_PCI0IOREMAP_OFS 0x0f0 +#define GT_PCI0M0REMAP_OFS 0x0f8 +#define GT_PCI0M1REMAP_OFS 0x100 +#define GT_PCI1IOREMAP_OFS 0x108 +#define GT_PCI1M0REMAP_OFS 0x110 +#define GT_PCI1M1REMAP_OFS 0x118 + +/* CPU Error Report. */ +#define GT_CPUERR_ADDRLO_OFS 0x070 +#define GT_CPUERR_ADDRHI_OFS 0x078 + +#define GT_CPUERR_DATALO_OFS 0x128 /* GT-64120A only */ +#define GT_CPUERR_DATAHI_OFS 0x130 /* GT-64120A only */ +#define GT_CPUERR_PARITY_OFS 0x138 /* GT-64120A only */ + +/* CPU Sync Barrier. */ +#define GT_PCI0SYNC_OFS 0x0c0 +#define GT_PCI1SYNC_OFS 0x0c8 + +/* SDRAM and Device Address Decode. */ +#define GT_SCS0LD_OFS 0x400 +#define GT_SCS0HD_OFS 0x404 +#define GT_SCS1LD_OFS 0x408 +#define GT_SCS1HD_OFS 0x40c +#define GT_SCS2LD_OFS 0x410 +#define GT_SCS2HD_OFS 0x414 +#define GT_SCS3LD_OFS 0x418 +#define GT_SCS3HD_OFS 0x41c +#define GT_CS0LD_OFS 0x420 +#define GT_CS0HD_OFS 0x424 +#define GT_CS1LD_OFS 0x428 +#define GT_CS1HD_OFS 0x42c +#define GT_CS2LD_OFS 0x430 +#define GT_CS2HD_OFS 0x434 +#define GT_CS3LD_OFS 0x438 +#define GT_CS3HD_OFS 0x43c +#define GT_BOOTLD_OFS 0x440 +#define GT_BOOTHD_OFS 0x444 + +#define GT_ADERR_OFS 0x470 + +/* SDRAM Configuration. */ +#define GT_SDRAM_CFG_OFS 0x448 + +#define GT_SDRAM_OPMODE_OFS 0x474 +#define GT_SDRAM_BM_OFS 0x478 +#define GT_SDRAM_ADDRDECODE_OFS 0x47c + +/* SDRAM Parameters. */ +#define GT_SDRAM_B0_OFS 0x44c +#define GT_SDRAM_B1_OFS 0x450 +#define GT_SDRAM_B2_OFS 0x454 +#define GT_SDRAM_B3_OFS 0x458 + +/* Device Parameters. */ +#define GT_DEV_B0_OFS 0x45c +#define GT_DEV_B1_OFS 0x460 +#define GT_DEV_B2_OFS 0x464 +#define GT_DEV_B3_OFS 0x468 +#define GT_DEV_BOOT_OFS 0x46c + +/* ECC. */ +#define GT_ECC_ERRDATALO 0x480 /* GT-64120A only */ +#define GT_ECC_ERRDATAHI 0x484 /* GT-64120A only */ +#define GT_ECC_MEM 0x488 /* GT-64120A only */ +#define GT_ECC_CALC 0x48c /* GT-64120A only */ +#define GT_ECC_ERRADDR 0x490 /* GT-64120A only */ + +/* DMA Record. */ +#define GT_DMA0_CNT_OFS 0x800 +#define GT_DMA1_CNT_OFS 0x804 +#define GT_DMA2_CNT_OFS 0x808 +#define GT_DMA3_CNT_OFS 0x80c +#define GT_DMA0_SA_OFS 0x810 +#define GT_DMA1_SA_OFS 0x814 +#define GT_DMA2_SA_OFS 0x818 +#define GT_DMA3_SA_OFS 0x81c +#define GT_DMA0_DA_OFS 0x820 +#define GT_DMA1_DA_OFS 0x824 +#define GT_DMA2_DA_OFS 0x828 +#define GT_DMA3_DA_OFS 0x82c +#define GT_DMA0_NEXT_OFS 0x830 +#define GT_DMA1_NEXT_OFS 0x834 +#define GT_DMA2_NEXT_OFS 0x838 +#define GT_DMA3_NEXT_OFS 0x83c + +#define GT_DMA0_CUR_OFS 0x870 +#define GT_DMA1_CUR_OFS 0x874 +#define GT_DMA2_CUR_OFS 0x878 +#define GT_DMA3_CUR_OFS 0x87c + +/* DMA Channel Control. */ +#define GT_DMA0_CTRL_OFS 0x840 +#define GT_DMA1_CTRL_OFS 0x844 +#define GT_DMA2_CTRL_OFS 0x848 +#define GT_DMA3_CTRL_OFS 0x84c + +/* DMA Arbiter. */ +#define GT_DMA_ARB_OFS 0x860 + +/* Timer/Counter. */ +#define GT_TC0_OFS 0x850 +#define GT_TC1_OFS 0x854 +#define GT_TC2_OFS 0x858 +#define GT_TC3_OFS 0x85c + +#define GT_TC_CONTROL_OFS 0x864 + +/* PCI Internal. */ +#define GT_PCI0_CMD_OFS 0xc00 +#define GT_PCI0_TOR_OFS 0xc04 +#define GT_PCI0_BS_SCS10_OFS 0xc08 +#define GT_PCI0_BS_SCS32_OFS 0xc0c +#define GT_PCI0_BS_CS20_OFS 0xc10 +#define GT_PCI0_BS_CS3BT_OFS 0xc14 + +#define GT_PCI1_IACK_OFS 0xc30 +#define GT_PCI0_IACK_OFS 0xc34 + +#define GT_PCI0_BARE_OFS 0xc3c +#define GT_PCI0_PREFMBR_OFS 0xc40 + +#define GT_PCI0_SCS10_BAR_OFS 0xc48 +#define GT_PCI0_SCS32_BAR_OFS 0xc4c +#define GT_PCI0_CS20_BAR_OFS 0xc50 +#define GT_PCI0_CS3BT_BAR_OFS 0xc54 +#define GT_PCI0_SSCS10_BAR_OFS 0xc58 +#define GT_PCI0_SSCS32_BAR_OFS 0xc5c + +#define GT_PCI0_SCS3BT_BAR_OFS 0xc64 + +#define GT_PCI1_CMD_OFS 0xc80 +#define GT_PCI1_TOR_OFS 0xc84 +#define GT_PCI1_BS_SCS10_OFS 0xc88 +#define GT_PCI1_BS_SCS32_OFS 0xc8c +#define GT_PCI1_BS_CS20_OFS 0xc90 +#define GT_PCI1_BS_CS3BT_OFS 0xc94 + +#define GT_PCI1_BARE_OFS 0xcbc +#define GT_PCI1_PREFMBR_OFS 0xcc0 + +#define GT_PCI1_SCS10_BAR_OFS 0xcc8 +#define GT_PCI1_SCS32_BAR_OFS 0xccc +#define GT_PCI1_CS20_BAR_OFS 0xcd0 +#define GT_PCI1_CS3BT_BAR_OFS 0xcd4 +#define GT_PCI1_SSCS10_BAR_OFS 0xcd8 +#define GT_PCI1_SSCS32_BAR_OFS 0xcdc + +#define GT_PCI1_SCS3BT_BAR_OFS 0xce4 + +#define GT_PCI1_CFGADDR_OFS 0xcf0 +#define GT_PCI1_CFGDATA_OFS 0xcf4 +#define GT_PCI0_CFGADDR_OFS 0xcf8 +#define GT_PCI0_CFGDATA_OFS 0xcfc + +/* Interrupts. */ +#define GT_INTRCAUSE_OFS 0xc18 +#define GT_INTRMASK_OFS 0xc1c + +#define GT_PCI0_ICMASK_OFS 0xc24 +#define GT_PCI0_SERR0MASK_OFS 0xc28 + +#define GT_CPU_INTSEL_OFS 0xc70 +#define GT_PCI0_INTSEL_OFS 0xc74 + +#define GT_HINTRCAUSE_OFS 0xc98 +#define GT_HINTRMASK_OFS 0xc9c + +#define GT_PCI0_HICMASK_OFS 0xca4 +#define GT_PCI1_SERR1MASK_OFS 0xca8 + + +/* + * I2O Support Registers + */ +#define INBOUND_MESSAGE_REGISTER0_PCI_SIDE 0x010 +#define INBOUND_MESSAGE_REGISTER1_PCI_SIDE 0x014 +#define OUTBOUND_MESSAGE_REGISTER0_PCI_SIDE 0x018 +#define OUTBOUND_MESSAGE_REGISTER1_PCI_SIDE 0x01c +#define INBOUND_DOORBELL_REGISTER_PCI_SIDE 0x020 +#define INBOUND_INTERRUPT_CAUSE_REGISTER_PCI_SIDE 0x024 +#define INBOUND_INTERRUPT_MASK_REGISTER_PCI_SIDE 0x028 +#define OUTBOUND_DOORBELL_REGISTER_PCI_SIDE 0x02c +#define OUTBOUND_INTERRUPT_CAUSE_REGISTER_PCI_SIDE 0x030 +#define OUTBOUND_INTERRUPT_MASK_REGISTER_PCI_SIDE 0x034 +#define INBOUND_QUEUE_PORT_VIRTUAL_REGISTER_PCI_SIDE 0x040 +#define OUTBOUND_QUEUE_PORT_VIRTUAL_REGISTER_PCI_SIDE 0x044 +#define QUEUE_CONTROL_REGISTER_PCI_SIDE 0x050 +#define QUEUE_BASE_ADDRESS_REGISTER_PCI_SIDE 0x054 +#define INBOUND_FREE_HEAD_POINTER_REGISTER_PCI_SIDE 0x060 +#define INBOUND_FREE_TAIL_POINTER_REGISTER_PCI_SIDE 0x064 +#define INBOUND_POST_HEAD_POINTER_REGISTER_PCI_SIDE 0x068 +#define INBOUND_POST_TAIL_POINTER_REGISTER_PCI_SIDE 0x06c +#define OUTBOUND_FREE_HEAD_POINTER_REGISTER_PCI_SIDE 0x070 +#define OUTBOUND_FREE_TAIL_POINTER_REGISTER_PCI_SIDE 0x074 +#define OUTBOUND_POST_HEAD_POINTER_REGISTER_PCI_SIDE 0x078 +#define OUTBOUND_POST_TAIL_POINTER_REGISTER_PCI_SIDE 0x07c + +#define INBOUND_MESSAGE_REGISTER0_CPU_SIDE 0x1c10 +#define INBOUND_MESSAGE_REGISTER1_CPU_SIDE 0x1c14 +#define OUTBOUND_MESSAGE_REGISTER0_CPU_SIDE 0x1c18 +#define OUTBOUND_MESSAGE_REGISTER1_CPU_SIDE 0x1c1c +#define INBOUND_DOORBELL_REGISTER_CPU_SIDE 0x1c20 +#define INBOUND_INTERRUPT_CAUSE_REGISTER_CPU_SIDE 0x1c24 +#define INBOUND_INTERRUPT_MASK_REGISTER_CPU_SIDE 0x1c28 +#define OUTBOUND_DOORBELL_REGISTER_CPU_SIDE 0x1c2c +#define OUTBOUND_INTERRUPT_CAUSE_REGISTER_CPU_SIDE 0x1c30 +#define OUTBOUND_INTERRUPT_MASK_REGISTER_CPU_SIDE 0x1c34 +#define INBOUND_QUEUE_PORT_VIRTUAL_REGISTER_CPU_SIDE 0x1c40 +#define OUTBOUND_QUEUE_PORT_VIRTUAL_REGISTER_CPU_SIDE 0x1c44 +#define QUEUE_CONTROL_REGISTER_CPU_SIDE 0x1c50 +#define QUEUE_BASE_ADDRESS_REGISTER_CPU_SIDE 0x1c54 +#define INBOUND_FREE_HEAD_POINTER_REGISTER_CPU_SIDE 0x1c60 +#define INBOUND_FREE_TAIL_POINTER_REGISTER_CPU_SIDE 0x1c64 +#define INBOUND_POST_HEAD_POINTER_REGISTER_CPU_SIDE 0x1c68 +#define INBOUND_POST_TAIL_POINTER_REGISTER_CPU_SIDE 0x1c6c +#define OUTBOUND_FREE_HEAD_POINTER_REGISTER_CPU_SIDE 0x1c70 +#define OUTBOUND_FREE_TAIL_POINTER_REGISTER_CPU_SIDE 0x1c74 +#define OUTBOUND_POST_HEAD_POINTER_REGISTER_CPU_SIDE 0x1c78 +#define OUTBOUND_POST_TAIL_POINTER_REGISTER_CPU_SIDE 0x1c7c + +/* + * Register encodings + */ +#define GT_CPU_ENDIAN_SHF 12 +#define GT_CPU_ENDIAN_MSK (MSK(1) << GT_CPU_ENDIAN_SHF) +#define GT_CPU_ENDIAN_BIT GT_CPU_ENDIAN_MSK +#define GT_CPU_WR_SHF 16 +#define GT_CPU_WR_MSK (MSK(1) << GT_CPU_WR_SHF) +#define GT_CPU_WR_BIT GT_CPU_WR_MSK +#define GT_CPU_WR_DXDXDXDX 0 +#define GT_CPU_WR_DDDD 1 + + +#define GT_PCI_DCRM_SHF 21 +#define GT_PCI_LD_SHF 0 +#define GT_PCI_LD_MSK (MSK(15) << GT_PCI_LD_SHF) +#define GT_PCI_HD_SHF 0 +#define GT_PCI_HD_MSK (MSK(7) << GT_PCI_HD_SHF) +#define GT_PCI_REMAP_SHF 0 +#define GT_PCI_REMAP_MSK (MSK(11) << GT_PCI_REMAP_SHF) + + +#define GT_CFGADDR_CFGEN_SHF 31 +#define GT_CFGADDR_CFGEN_MSK (MSK(1) << GT_CFGADDR_CFGEN_SHF) +#define GT_CFGADDR_CFGEN_BIT GT_CFGADDR_CFGEN_MSK + +#define GT_CFGADDR_BUSNUM_SHF 16 +#define GT_CFGADDR_BUSNUM_MSK (MSK(8) << GT_CFGADDR_BUSNUM_SHF) + +#define GT_CFGADDR_DEVNUM_SHF 11 +#define GT_CFGADDR_DEVNUM_MSK (MSK(5) << GT_CFGADDR_DEVNUM_SHF) + +#define GT_CFGADDR_FUNCNUM_SHF 8 +#define GT_CFGADDR_FUNCNUM_MSK (MSK(3) << GT_CFGADDR_FUNCNUM_SHF) + +#define GT_CFGADDR_REGNUM_SHF 2 +#define GT_CFGADDR_REGNUM_MSK (MSK(6) << GT_CFGADDR_REGNUM_SHF) + + +#define GT_SDRAM_BM_ORDER_SHF 2 +#define GT_SDRAM_BM_ORDER_MSK (MSK(1) << GT_SDRAM_BM_ORDER_SHF) +#define GT_SDRAM_BM_ORDER_BIT GT_SDRAM_BM_ORDER_MSK +#define GT_SDRAM_BM_ORDER_SUB 1 +#define GT_SDRAM_BM_ORDER_LIN 0 + +#define GT_SDRAM_BM_RSVD_ALL1 0xffb + + +#define GT_SDRAM_ADDRDECODE_ADDR_SHF 0 +#define GT_SDRAM_ADDRDECODE_ADDR_MSK (MSK(3) << GT_SDRAM_ADDRDECODE_ADDR_SHF) +#define GT_SDRAM_ADDRDECODE_ADDR_0 0 +#define GT_SDRAM_ADDRDECODE_ADDR_1 1 +#define GT_SDRAM_ADDRDECODE_ADDR_2 2 +#define GT_SDRAM_ADDRDECODE_ADDR_3 3 +#define GT_SDRAM_ADDRDECODE_ADDR_4 4 +#define GT_SDRAM_ADDRDECODE_ADDR_5 5 +#define GT_SDRAM_ADDRDECODE_ADDR_6 6 +#define GT_SDRAM_ADDRDECODE_ADDR_7 7 + + +#define GT_SDRAM_B0_CASLAT_SHF 0 +#define GT_SDRAM_B0_CASLAT_MSK (MSK(2) << GT_SDRAM_B0__SHF) +#define GT_SDRAM_B0_CASLAT_2 1 +#define GT_SDRAM_B0_CASLAT_3 2 + +#define GT_SDRAM_B0_FTDIS_SHF 2 +#define GT_SDRAM_B0_FTDIS_MSK (MSK(1) << GT_SDRAM_B0_FTDIS_SHF) +#define GT_SDRAM_B0_FTDIS_BIT GT_SDRAM_B0_FTDIS_MSK + +#define GT_SDRAM_B0_SRASPRCHG_SHF 3 +#define GT_SDRAM_B0_SRASPRCHG_MSK (MSK(1) << GT_SDRAM_B0_SRASPRCHG_SHF) +#define GT_SDRAM_B0_SRASPRCHG_BIT GT_SDRAM_B0_SRASPRCHG_MSK +#define GT_SDRAM_B0_SRASPRCHG_2 0 +#define GT_SDRAM_B0_SRASPRCHG_3 1 + +#define GT_SDRAM_B0_B0COMPAB_SHF 4 +#define GT_SDRAM_B0_B0COMPAB_MSK (MSK(1) << GT_SDRAM_B0_B0COMPAB_SHF) +#define GT_SDRAM_B0_B0COMPAB_BIT GT_SDRAM_B0_B0COMPAB_MSK + +#define GT_SDRAM_B0_64BITINT_SHF 5 +#define GT_SDRAM_B0_64BITINT_MSK (MSK(1) << GT_SDRAM_B0_64BITINT_SHF) +#define GT_SDRAM_B0_64BITINT_BIT GT_SDRAM_B0_64BITINT_MSK +#define GT_SDRAM_B0_64BITINT_2 0 +#define GT_SDRAM_B0_64BITINT_4 1 + +#define GT_SDRAM_B0_BW_SHF 6 +#define GT_SDRAM_B0_BW_MSK (MSK(1) << GT_SDRAM_B0_BW_SHF) +#define GT_SDRAM_B0_BW_BIT GT_SDRAM_B0_BW_MSK +#define GT_SDRAM_B0_BW_32 0 +#define GT_SDRAM_B0_BW_64 1 + +#define GT_SDRAM_B0_BLODD_SHF 7 +#define GT_SDRAM_B0_BLODD_MSK (MSK(1) << GT_SDRAM_B0_BLODD_SHF) +#define GT_SDRAM_B0_BLODD_BIT GT_SDRAM_B0_BLODD_MSK + +#define GT_SDRAM_B0_PAR_SHF 8 +#define GT_SDRAM_B0_PAR_MSK (MSK(1) << GT_SDRAM_B0_PAR_SHF) +#define GT_SDRAM_B0_PAR_BIT GT_SDRAM_B0_PAR_MSK + +#define GT_SDRAM_B0_BYPASS_SHF 9 +#define GT_SDRAM_B0_BYPASS_MSK (MSK(1) << GT_SDRAM_B0_BYPASS_SHF) +#define GT_SDRAM_B0_BYPASS_BIT GT_SDRAM_B0_BYPASS_MSK + +#define GT_SDRAM_B0_SRAS2SCAS_SHF 10 +#define GT_SDRAM_B0_SRAS2SCAS_MSK (MSK(1) << GT_SDRAM_B0_SRAS2SCAS_SHF) +#define GT_SDRAM_B0_SRAS2SCAS_BIT GT_SDRAM_B0_SRAS2SCAS_MSK +#define GT_SDRAM_B0_SRAS2SCAS_2 0 +#define GT_SDRAM_B0_SRAS2SCAS_3 1 + +#define GT_SDRAM_B0_SIZE_SHF 11 +#define GT_SDRAM_B0_SIZE_MSK (MSK(1) << GT_SDRAM_B0_SIZE_SHF) +#define GT_SDRAM_B0_SIZE_BIT GT_SDRAM_B0_SIZE_MSK +#define GT_SDRAM_B0_SIZE_16M 0 +#define GT_SDRAM_B0_SIZE_64M 1 + +#define GT_SDRAM_B0_EXTPAR_SHF 12 +#define GT_SDRAM_B0_EXTPAR_MSK (MSK(1) << GT_SDRAM_B0_EXTPAR_SHF) +#define GT_SDRAM_B0_EXTPAR_BIT GT_SDRAM_B0_EXTPAR_MSK + +#define GT_SDRAM_B0_BLEN_SHF 13 +#define GT_SDRAM_B0_BLEN_MSK (MSK(1) << GT_SDRAM_B0_BLEN_SHF) +#define GT_SDRAM_B0_BLEN_BIT GT_SDRAM_B0_BLEN_MSK +#define GT_SDRAM_B0_BLEN_8 0 +#define GT_SDRAM_B0_BLEN_4 1 + + +#define GT_SDRAM_CFG_REFINT_SHF 0 +#define GT_SDRAM_CFG_REFINT_MSK (MSK(14) << GT_SDRAM_CFG_REFINT_SHF) + +#define GT_SDRAM_CFG_NINTERLEAVE_SHF 14 +#define GT_SDRAM_CFG_NINTERLEAVE_MSK (MSK(1) << GT_SDRAM_CFG_NINTERLEAVE_SHF) +#define GT_SDRAM_CFG_NINTERLEAVE_BIT GT_SDRAM_CFG_NINTERLEAVE_MSK + +#define GT_SDRAM_CFG_RMW_SHF 15 +#define GT_SDRAM_CFG_RMW_MSK (MSK(1) << GT_SDRAM_CFG_RMW_SHF) +#define GT_SDRAM_CFG_RMW_BIT GT_SDRAM_CFG_RMW_MSK + +#define GT_SDRAM_CFG_NONSTAGREF_SHF 16 +#define GT_SDRAM_CFG_NONSTAGREF_MSK (MSK(1) << GT_SDRAM_CFG_NONSTAGREF_SHF) +#define GT_SDRAM_CFG_NONSTAGREF_BIT GT_SDRAM_CFG_NONSTAGREF_MSK + +#define GT_SDRAM_CFG_DUPCNTL_SHF 19 +#define GT_SDRAM_CFG_DUPCNTL_MSK (MSK(1) << GT_SDRAM_CFG_DUPCNTL_SHF) +#define GT_SDRAM_CFG_DUPCNTL_BIT GT_SDRAM_CFG_DUPCNTL_MSK + +#define GT_SDRAM_CFG_DUPBA_SHF 20 +#define GT_SDRAM_CFG_DUPBA_MSK (MSK(1) << GT_SDRAM_CFG_DUPBA_SHF) +#define GT_SDRAM_CFG_DUPBA_BIT GT_SDRAM_CFG_DUPBA_MSK + +#define GT_SDRAM_CFG_DUPEOT0_SHF 21 +#define GT_SDRAM_CFG_DUPEOT0_MSK (MSK(1) << GT_SDRAM_CFG_DUPEOT0_SHF) +#define GT_SDRAM_CFG_DUPEOT0_BIT GT_SDRAM_CFG_DUPEOT0_MSK + +#define GT_SDRAM_CFG_DUPEOT1_SHF 22 +#define GT_SDRAM_CFG_DUPEOT1_MSK (MSK(1) << GT_SDRAM_CFG_DUPEOT1_SHF) +#define GT_SDRAM_CFG_DUPEOT1_BIT GT_SDRAM_CFG_DUPEOT1_MSK + +#define GT_SDRAM_OPMODE_OP_SHF 0 +#define GT_SDRAM_OPMODE_OP_MSK (MSK(3) << GT_SDRAM_OPMODE_OP_SHF) +#define GT_SDRAM_OPMODE_OP_NORMAL 0 +#define GT_SDRAM_OPMODE_OP_NOP 1 +#define GT_SDRAM_OPMODE_OP_PRCHG 2 +#define GT_SDRAM_OPMODE_OP_MODE 3 +#define GT_SDRAM_OPMODE_OP_CBR 4 + +#define GT_TC_CONTROL_ENTC0_SHF 0 +#define GT_TC_CONTROL_ENTC0_MSK (MSK(1) << GT_TC_CONTROL_ENTC0_SHF) +#define GT_TC_CONTROL_ENTC0_BIT GT_TC_CONTROL_ENTC0_MSK +#define GT_TC_CONTROL_SELTC0_SHF 1 +#define GT_TC_CONTROL_SELTC0_MSK (MSK(1) << GT_TC_CONTROL_SELTC0_SHF) +#define GT_TC_CONTROL_SELTC0_BIT GT_TC_CONTROL_SELTC0_MSK + + +#define GT_PCI0_BARE_SWSCS3BOOTDIS_SHF 0 +#define GT_PCI0_BARE_SWSCS3BOOTDIS_MSK \ + (MSK(1) << GT_PCI0_BARE_SWSCS3BOOTDIS_SHF) +#define GT_PCI0_BARE_SWSCS3BOOTDIS_BIT GT_PCI0_BARE_SWSCS3BOOTDIS_MSK + +#define GT_PCI0_BARE_SWSCS32DIS_SHF 1 +#define GT_PCI0_BARE_SWSCS32DIS_MSK (MSK(1) << GT_PCI0_BARE_SWSCS32DIS_SHF) +#define GT_PCI0_BARE_SWSCS32DIS_BIT GT_PCI0_BARE_SWSCS32DIS_MSK + +#define GT_PCI0_BARE_SWSCS10DIS_SHF 2 +#define GT_PCI0_BARE_SWSCS10DIS_MSK (MSK(1) << GT_PCI0_BARE_SWSCS10DIS_SHF) +#define GT_PCI0_BARE_SWSCS10DIS_BIT GT_PCI0_BARE_SWSCS10DIS_MSK + +#define GT_PCI0_BARE_INTIODIS_SHF 3 +#define GT_PCI0_BARE_INTIODIS_MSK (MSK(1) << GT_PCI0_BARE_INTIODIS_SHF) +#define GT_PCI0_BARE_INTIODIS_BIT GT_PCI0_BARE_INTIODIS_MSK + +#define GT_PCI0_BARE_INTMEMDIS_SHF 4 +#define GT_PCI0_BARE_INTMEMDIS_MSK (MSK(1) << GT_PCI0_BARE_INTMEMDIS_SHF) +#define GT_PCI0_BARE_INTMEMDIS_BIT GT_PCI0_BARE_INTMEMDIS_MSK + +#define GT_PCI0_BARE_CS3BOOTDIS_SHF 5 +#define GT_PCI0_BARE_CS3BOOTDIS_MSK (MSK(1) << GT_PCI0_BARE_CS3BOOTDIS_SHF) +#define GT_PCI0_BARE_CS3BOOTDIS_BIT GT_PCI0_BARE_CS3BOOTDIS_MSK + +#define GT_PCI0_BARE_CS20DIS_SHF 6 +#define GT_PCI0_BARE_CS20DIS_MSK (MSK(1) << GT_PCI0_BARE_CS20DIS_SHF) +#define GT_PCI0_BARE_CS20DIS_BIT GT_PCI0_BARE_CS20DIS_MSK + +#define GT_PCI0_BARE_SCS32DIS_SHF 7 +#define GT_PCI0_BARE_SCS32DIS_MSK (MSK(1) << GT_PCI0_BARE_SCS32DIS_SHF) +#define GT_PCI0_BARE_SCS32DIS_BIT GT_PCI0_BARE_SCS32DIS_MSK + +#define GT_PCI0_BARE_SCS10DIS_SHF 8 +#define GT_PCI0_BARE_SCS10DIS_MSK (MSK(1) << GT_PCI0_BARE_SCS10DIS_SHF) +#define GT_PCI0_BARE_SCS10DIS_BIT GT_PCI0_BARE_SCS10DIS_MSK + + +#define GT_INTRCAUSE_MASABORT0_SHF 18 +#define GT_INTRCAUSE_MASABORT0_MSK (MSK(1) << GT_INTRCAUSE_MASABORT0_SHF) +#define GT_INTRCAUSE_MASABORT0_BIT GT_INTRCAUSE_MASABORT0_MSK + +#define GT_INTRCAUSE_TARABORT0_SHF 19 +#define GT_INTRCAUSE_TARABORT0_MSK (MSK(1) << GT_INTRCAUSE_TARABORT0_SHF) +#define GT_INTRCAUSE_TARABORT0_BIT GT_INTRCAUSE_TARABORT0_MSK + + +#define GT_PCI0_CFGADDR_REGNUM_SHF 2 +#define GT_PCI0_CFGADDR_REGNUM_MSK (MSK(6) << GT_PCI0_CFGADDR_REGNUM_SHF) +#define GT_PCI0_CFGADDR_FUNCTNUM_SHF 8 +#define GT_PCI0_CFGADDR_FUNCTNUM_MSK (MSK(3) << GT_PCI0_CFGADDR_FUNCTNUM_SHF) +#define GT_PCI0_CFGADDR_DEVNUM_SHF 11 +#define GT_PCI0_CFGADDR_DEVNUM_MSK (MSK(5) << GT_PCI0_CFGADDR_DEVNUM_SHF) +#define GT_PCI0_CFGADDR_BUSNUM_SHF 16 +#define GT_PCI0_CFGADDR_BUSNUM_MSK (MSK(8) << GT_PCI0_CFGADDR_BUSNUM_SHF) +#define GT_PCI0_CFGADDR_CONFIGEN_SHF 31 +#define GT_PCI0_CFGADDR_CONFIGEN_MSK (MSK(1) << GT_PCI0_CFGADDR_CONFIGEN_SHF) +#define GT_PCI0_CFGADDR_CONFIGEN_BIT GT_PCI0_CFGADDR_CONFIGEN_MSK + +#define GT_PCI0_CMD_MBYTESWAP_SHF 0 +#define GT_PCI0_CMD_MBYTESWAP_MSK (MSK(1) << GT_PCI0_CMD_MBYTESWAP_SHF) +#define GT_PCI0_CMD_MBYTESWAP_BIT GT_PCI0_CMD_MBYTESWAP_MSK +#define GT_PCI0_CMD_MWORDSWAP_SHF 10 +#define GT_PCI0_CMD_MWORDSWAP_MSK (MSK(1) << GT_PCI0_CMD_MWORDSWAP_SHF) +#define GT_PCI0_CMD_MWORDSWAP_BIT GT_PCI0_CMD_MWORDSWAP_MSK +#define GT_PCI0_CMD_SBYTESWAP_SHF 16 +#define GT_PCI0_CMD_SBYTESWAP_MSK (MSK(1) << GT_PCI0_CMD_SBYTESWAP_SHF) +#define GT_PCI0_CMD_SBYTESWAP_BIT GT_PCI0_CMD_SBYTESWAP_MSK +#define GT_PCI0_CMD_SWORDSWAP_SHF 11 +#define GT_PCI0_CMD_SWORDSWAP_MSK (MSK(1) << GT_PCI0_CMD_SWORDSWAP_SHF) +#define GT_PCI0_CMD_SWORDSWAP_BIT GT_PCI0_CMD_SWORDSWAP_MSK + +#define GT_INTR_T0EXP_SHF 8 +#define GT_INTR_T0EXP_MSK (MSK(1) << GT_INTR_T0EXP_SHF) +#define GT_INTR_T0EXP_BIT GT_INTR_T0EXP_MSK +#define GT_INTR_RETRYCTR0_SHF 20 +#define GT_INTR_RETRYCTR0_MSK (MSK(1) << GT_INTR_RETRYCTR0_SHF) +#define GT_INTR_RETRYCTR0_BIT GT_INTR_RETRYCTR0_MSK + +/* + * Misc + */ +#define GT_DEF_PCI0_IO_BASE 0x10000000 +#define GT_DEF_PCI0_IO_SIZE 0x02000000 +#define GT_DEF_PCI0_MEM0_BASE 0x12000000 +#define GT_DEF_PCI0_MEM0_SIZE 0x02000000 +#define GT_DEF_BASE 0x14000000 + +#define GT_MAX_BANKSIZE (256 * 1024 * 1024) /* Max 256MB bank */ +#define GT_LATTIM_MIN 6 /* Minimum lat */ + +#endif /* _ASM_GT64120_H */
Move the GT64120 register base to 0x1be00000 and setup PCI BAR registers as done by the original YAMON bootloader.
This is needed for running Linux kernel.
Changes since RFC: --- --- arch/mips/include/asm/malta.h | 4 ++- board/qemu-malta/lowlevel_init.S | 51 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 54 insertions(+), 1 deletion(-)
diff --git a/arch/mips/include/asm/malta.h b/arch/mips/include/asm/malta.h index ab951e6..d4d44a2 100644 --- a/arch/mips/include/asm/malta.h +++ b/arch/mips/include/asm/malta.h @@ -9,10 +9,12 @@ #ifndef _MIPS_ASM_MALTA_H #define _MIPS_ASM_MALTA_H
-#define MALTA_IO_PORT_BASE 0x10000000 +#define MALTA_IO_PORT_BASE 0x18000000
+#define MALTA_GT_BASE 0x1be00000 + #define MALTA_RESET_BASE 0x1f000500 #define GORESET 0x42
diff --git a/board/qemu-malta/lowlevel_init.S b/board/qemu-malta/lowlevel_init.S index c5c5bd9..11544a8 100644 --- a/board/qemu-malta/lowlevel_init.S +++ b/board/qemu-malta/lowlevel_init.S @@ -6,7 +6,19 @@ * by the Free Software Foundation. */
+#include <config.h> +#include <asm/addrspace.h> #include <asm/regdef.h> +#include <asm/gt64120.h> +#include <asm/malta.h> + +#ifdef CONFIG_SYS_BIG_ENDIAN +#define CPU_TO_GT32(_x) ((_x)) +#else +#define CPU_TO_GT32(_x) ( \ + (((_x) & 0xff) << 24) | (((_x) & 0xff00) << 8) | \ + (((_x) & 0xff0000) >> 8) | (((_x) & 0xff000000) >> 24)) +#endif
.text .set noreorder @@ -15,5 +27,44 @@ .globl lowlevel_init lowlevel_init:
+ /* + * Load BAR registers of GT64120 as done by YAMON + * + * based on a patch sent by Antony Pavlov antonynpavlov@gmail.com + * to the barebox mailing list. + * The subject of the original patch: + * 'MIPS: qemu-malta: add YAMON-style GT64120 memory map' + * URL: + * http://www.mail-archive.com/barebox@lists.infradead.org/msg06128.html + * + * based on write_bootloader() in qemu.git/hw/mips_malta.c + * see GT64120 manual and qemu.git/hw/gt64xxx.c for details + */ + + /* move GT64120 registers from 0x14000000 to 0x1be00000 */ + li t1, KSEG1ADDR(GT_DEF_BASE) + li t0, CPU_TO_GT32(0xdf000000) + sw t0, GT_ISD_OFS(t1) + + /* setup MEM-to-PCI0 mapping */ + li t1, KSEG1ADDR(MALTA_GT_BASE) + + /* setup PCI0 io window to 0x18000000-0x181fffff */ + li t0, CPU_TO_GT32(0xc0000000) + sw t0, GT_PCI0IOLD_OFS(t1) + li t0, CPU_TO_GT32(0x40000000) + sw t0, GT_PCI0IOHD_OFS(t1) + + /* setup PCI0 mem windows */ + li t0, CPU_TO_GT32(0x80000000) + sw t0, GT_PCI0M0LD_OFS(t1) + li t0, CPU_TO_GT32(0x3f000000) + sw t0, GT_PCI0M0HD_OFS(t1) + + li t0, CPU_TO_GT32(0xc1000000) + sw t0, GT_PCI0M1LD_OFS(t1) + li t0, CPU_TO_GT32(0x5e000000) + sw t0, GT_PCI0M1HD_OFS(t1) + jr ra nop
Changes since v1:
+#endif
* based on a patch sent by Antony Pavlov <antonynpavlov@gmail.com>
* URL:
jr ra nop
-- 1.7.10
is this initialization really needed before relocation? If not this should be moved to pci_init_board()
Changes since v1:
+#endif
* URL:
jr ra nop
-- 1.7.10
After this initialization, the UART uses a different base address. If we want UART output before the relocation then we have to initialize it here.
-Gabor
Qemu emulates the Galileo GT64120 System Controller which provides a CPU bus to PCI bus bridge.
The patch adds driver for this bridge and enables PCI support for the emulated Malta board.
Changes since RFC: - use a C struct to define the register layout instead of using a base address plus offset notation - remove custom IO accessors --- board/qemu-malta/Makefile | 5 +- board/qemu-malta/pci.c | 168 ++++++++++++++++++++++++++++++++++++++++++ include/configs/qemu-malta.h | 6 ++ 3 files changed, 178 insertions(+), 1 deletion(-) create mode 100644 board/qemu-malta/pci.c
diff --git a/board/qemu-malta/Makefile b/board/qemu-malta/Makefile index 6251bb8..59c1b1d 100644 --- a/board/qemu-malta/Makefile +++ b/board/qemu-malta/Makefile @@ -25,7 +25,10 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o +COBJS-y += $(BOARD).o +COBJS-$(CONFIG_PCI) += pci.o + +COBJS := $(COBJS-y) SOBJS = lowlevel_init.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/board/qemu-malta/pci.c b/board/qemu-malta/pci.c new file mode 100644 index 0000000..fd9193b --- /dev/null +++ b/board/qemu-malta/pci.c @@ -0,0 +1,168 @@ +/* + * Copyright (C) 2013 Gabor Juhos juhosg@openwrt.org + * + * Based on the Linux implementation. + * Copyright (C) 1999, 2000, 2004 MIPS Technologies, Inc. + * Authors: Carsten Langgaard carstenl@mips.com + * Maciej W. Rozycki macro@mips.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published + * by the Free Software Foundation. + */ + +#include <common.h> +#include <asm/addrspace.h> +#include <asm/gt64120.h> +#include <asm/malta.h> +#include <asm/io.h> +#include <pci.h> + +#define PCI_ACCESS_READ 0 +#define PCI_ACCESS_WRITE 1 + +struct gt64120_regs { + u8 unused_000[0xc18]; + u32 intrcause; + u8 unused_c1c[0x0dc]; + u32 pci0_cfgaddr; + u32 pci0_cfgdata; +}; + +DECLARE_GLOBAL_DATA_PTR; + +static struct gt64120_regs *gt_regs; + +/* + * PCI controller "hose" value + */ +static struct pci_controller hose; + +#define GT_INTRCAUSE_ABORT_BITS \ + (GT_INTRCAUSE_MASABORT0_BIT | GT_INTRCAUSE_TARABORT0_BIT) + +static int gt_config_access(unsigned char access_type, pci_dev_t bdf, + int where, u32 *data) +{ + unsigned int bus = PCI_BUS(bdf); + unsigned int dev = PCI_DEV(bdf); + unsigned int devfn = PCI_DEV(bdf) << 3 | PCI_FUNC(bdf); + u32 intr; + u32 addr; + u32 val; + + if (bus == 0 && dev >= 31) { + /* Because of a bug in the galileo (for slot 31). */ + return -1; + } + + if (access_type == PCI_ACCESS_WRITE) + debug("PCI WR %02x:%02x.%x reg:%02d data:%08x\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), + where, *data); + + /* Clear cause register bits */ + __raw_writel(~GT_INTRCAUSE_ABORT_BITS, >_regs->intrcause); + + addr = GT_PCI0_CFGADDR_CONFIGEN_BIT; + addr |= bus << GT_PCI0_CFGADDR_BUSNUM_SHF; + addr |= devfn << GT_PCI0_CFGADDR_FUNCTNUM_SHF; + addr |= (where / 4) << GT_PCI0_CFGADDR_REGNUM_SHF; + + /* Setup address */ + __raw_writel(addr, >_regs->pci0_cfgaddr); + + if (access_type == PCI_ACCESS_WRITE) { + if (bus == 0 && dev == 0) { + /* + * The Galileo system controller is acting + * differently than other devices. + */ + val = *data; + } else + val = cpu_to_le32(*data); + + __raw_writel(val, >_regs->pci0_cfgdata); + } else { + val = __raw_readl(>_regs->pci0_cfgdata); + + if (bus == 0 && dev == 0) { + /* + * The Galileo system controller is acting + * differently than other devices. + */ + *data = val; + } else + *data = le32_to_cpu(val); + } + + /* Check for master or target abort */ + intr = __raw_readl(>_regs->intrcause); + if (intr & GT_INTRCAUSE_ABORT_BITS) { + /* Error occurred, clear abort bits */ + __raw_writel(~GT_INTRCAUSE_ABORT_BITS, >_regs->intrcause); + return -1; + } + + if (access_type == PCI_ACCESS_READ) + debug("PCI RD %02x:%02x.%x reg:%02d data:%08x\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), where, *data); + + return 0; +} + +static int gt_read_config_dword(struct pci_controller *hose, pci_dev_t dev, + int where, u32 *value) +{ + *value = 0xffffffff; + return gt_config_access(PCI_ACCESS_READ, dev, where, value); +} + +static int gt_write_config_dword(struct pci_controller *hose, pci_dev_t dev, + int where, u32 value) +{ + u32 data = value; + + return gt_config_access(PCI_ACCESS_WRITE, dev, where, &data); +} + +void pci_init_board(void) +{ + set_io_port_base(CKSEG1ADDR(MALTA_IO_PORT_BASE)); + + gt_regs = (struct gt64120_regs *) CKSEG1ADDR(MALTA_GT_BASE); + + hose.first_busno = 0; + hose.last_busno = 0xff; + + /* System memory space */ + pci_set_region(&hose.regions[0], + 0x00000000, 0x00000000, + CONFIG_SYS_MEM_SIZE, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + + /* PCI memory space */ + pci_set_region(&hose.regions[1], + 0x10000000, 0x10000000, + 128 * 1024 * 1024, + PCI_REGION_MEM); + + /* PCI I/O space */ + pci_set_region(&hose.regions[2], + 0x0000000, 0x0000000, + 0x20000, + PCI_REGION_IO); + + hose.region_count = 3; + + pci_set_ops(&hose, + pci_hose_read_config_byte_via_dword, + pci_hose_read_config_word_via_dword, + gt_read_config_dword, + pci_hose_write_config_byte_via_dword, + pci_hose_write_config_word_via_dword, + gt_write_config_dword); + + pci_register_hose(&hose); + hose.last_busno = pci_hose_scan(&hose); +} diff --git a/include/configs/qemu-malta.h b/include/configs/qemu-malta.h index 881c15d..36b584a 100644 --- a/include/configs/qemu-malta.h +++ b/include/configs/qemu-malta.h @@ -17,6 +17,9 @@ */ #define CONFIG_QEMU_MALTA
+#define CONFIG_PCI +#define CONFIG_PCI_PNP + /* * CPU Configuration */ @@ -30,6 +33,7 @@
+ /* * Memory map */ @@ -108,6 +112,8 @@ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
+#define CONFIG_CMD_PCI + #define CONFIG_SYS_LONGHELP /* verbose help, undef to save memory */
Changes since v1:
Changes since RFC:
- Based on the Linux implementation.
- Copyright (C) 1999, 2000, 2004 MIPS Technologies, Inc.
- Authors: Carsten Langgaard carstenl@mips.com
Maciej W. Rozycki <macro@mips.com>
u32 intrcause;
u32 pci0_cfgaddr;
u32 pci0_cfgdata;
- PCI controller "hose" value
u32 intr;
u32 addr;
u32 val;
return -1;
where, *data);
/* Setup address */
val = *data;
} else
} else {
*data = val;
} else
return -1;
u32 data = value;
128 * 1024 * 1024,
PCI_REGION_MEM);
/* PCI I/O space */
0x20000,
PCI_REGION_IO);
pci_set_ops(&hose,
I think this should be implemented as separate driver in drivers/pci/
- CPU Configuration
- Memory map
1.7.10
The pcnet driver uses the pci_phys_to_mem function to get the memory address of the DMA buffers. This This assumes an 1:1 mapping between the PCI and physical memory which is not true on all platforms.
On MIPS platform U-Boot is running within a mapped memory region, and the pci_phys_to_mem macro can't be used to obtain the memory address of the buffers.
--- Note:
This is only tested with the qemu-malta target. The change might break real platforms, however I have no suitable board to test it.
-Gabor --- drivers/net/pcnet.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/pcnet.c b/drivers/net/pcnet.c index c028a44..45a66fb 100644 --- a/drivers/net/pcnet.c +++ b/drivers/net/pcnet.c @@ -146,7 +146,7 @@ static int pcnet_recv (struct eth_device *dev); static void pcnet_halt (struct eth_device *dev); static int pcnet_probe (struct eth_device *dev, bd_t * bis, int dev_num);
-#define PCI_TO_MEM(d,a) pci_phys_to_mem((pci_dev_t)d->priv, (u_long)(a)) +#define PCI_TO_MEM(d, a) pci_virt_to_mem((pci_dev_t)d->priv, (a)) #define PCI_TO_MEM_LE(d,a) (u32)(cpu_to_le32(PCI_TO_MEM(d,a)))
static struct pci_device_id supported[] = {
Changes since v1:
Note:
the consumers of pcnet and NE2000 are qemu-mips, R7780MP and SHMIN. Nobuhiro, could you comment this change?
-Gabor
1.7.10
Hi, all.
This patch appears to have nothing to do with NE2000. I think that this is pcnet only.
Best regards, Nobuhiro
On Sun, Feb 3, 2013 at 4:42 AM, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Changes since v1:
Note:
-Gabor
1.7.10
-- Best regards, Daniel
Qemu emulates a PCNET PCI card for the Malta CoreLV board. Enable the pcnet driver and add board specific ethernet initialization function to bring it up. Also enable the CONFIG_CMD_NET and CONFIG_CMD_PING options.
Changes since RFC: --- --- board/qemu-malta/qemu-malta.c | 6 ++++++ include/configs/qemu-malta.h | 4 ++-- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/qemu-malta/qemu-malta.c b/board/qemu-malta/qemu-malta.c index 9333242..10b624d 100644 --- a/board/qemu-malta/qemu-malta.c +++ b/board/qemu-malta/qemu-malta.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <netdev.h>
#include <asm/io.h> #include <asm/malta.h> @@ -22,6 +23,11 @@ int checkboard(void) return 0; }
+int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} + void _machine_restart(void) { void __iomem *reset_base; diff --git a/include/configs/qemu-malta.h b/include/configs/qemu-malta.h index 36b584a..3e37224 100644 --- a/include/configs/qemu-malta.h +++ b/include/configs/qemu-malta.h @@ -19,6 +19,7 @@
#define CONFIG_PCI #define CONFIG_PCI_PNP +#define CONFIG_PCNET
/* * CPU Configuration @@ -33,7 +34,6 @@
- /* * Memory map */ @@ -109,10 +109,10 @@ #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_LOADB #undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING
Changes since RFC: --- --- arch/mips/lib/bootm.c | 60 +++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 58 insertions(+), 2 deletions(-)
diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index a36154a..747d790 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -33,6 +33,12 @@ DECLARE_GLOBAL_DATA_PTR; #define LINUX_MAX_ENVS 256 #define LINUX_MAX_ARGS 256
+#if defined(CONFIG_QEMU_MALTA) +#define board_is_qemu_malta 1 +#else +#define board_is_qemu_malta 0 +#endif + static int linux_argc; static char **linux_argv;
@@ -43,7 +49,7 @@ static int linux_env_idx; static void linux_params_init(ulong start, char *commandline); static void linux_env_set(char *env_name, char *env_val);
-static void boot_prep_linux(bootm_headers_t *images) +static void boot_prep_linux_legacy(bootm_headers_t *images) { char *commandline = getenv("bootargs"); char env_buf[12]; @@ -83,6 +89,52 @@ static void boot_prep_linux(bootm_headers_t *images) linux_env_set("eth1addr", cp); }
+static void malta_env_set(char *env_name, char *env_val) +{ + if (linux_env_idx >= LINUX_MAX_ENVS - 2) + return; + + linux_env[linux_env_idx] = linux_env_p; + + strcpy(linux_env_p, env_name); + linux_env_p += strlen(env_name); + + linux_env_p++; + linux_env[++linux_env_idx] = linux_env_p; + + strcpy(linux_env_p, env_val); + linux_env_p += strlen(env_val); + + linux_env_p++; + linux_env[++linux_env_idx] = 0; +} + +static void boot_prep_linux_qemu_malta(bootm_headers_t *images) +{ + char *bootargs = getenv("bootargs"); + char env_buf[12]; + char *cp; + + linux_params_init(UNCACHED_SDRAM(gd->bd->bi_boot_params), bootargs); + + /* setup environment variables */ + sprintf(env_buf, "%lu", (ulong)gd->ram_size); + malta_env_set("memsize", env_buf); + malta_env_set("modetty0", "38400n8r"); + + cp = getenv("ethaddr"); + if (cp) + malta_env_set("ethaddr", cp); +} + +static void boot_prep_linux(bootm_headers_t *images) +{ + if (board_is_qemu_malta) + boot_prep_linux_qemu_malta(images); + else + boot_prep_linux_legacy(images); +} + static void boot_jump_linux(bootm_headers_t *images) { void (*theKernel) (int, char **, char **, int *); @@ -98,7 +150,11 @@ static void boot_jump_linux(bootm_headers_t *images) /* we assume that the kernel is in place */ printf("\nStarting kernel ...\n\n");
- theKernel(linux_argc, linux_argv, linux_env, 0); + if (board_is_qemu_malta) + theKernel(linux_argc, linux_argv, linux_env, + (int *) gd->ram_size); + else + theKernel(linux_argc, linux_argv, linux_env, 0); }
int do_bootm_linux(int flag, int argc, char * const argv[],
On the origial Malta boards the REVISION register is accessible at the 0x1fc00010 address. The contents of this register gives information about the revision of the Malta and Core Boards.
This register is used by the Linux kernel to identify the actual board it is running on. However the register is not emulated properly by Qemu, so put a hardcoded value into the flash to make Linux work.
Changes since RFC: --- --- arch/mips/cpu/mips32/start.S | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index 7373d4e..6f6e92b 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -57,7 +57,7 @@ _start: nop
.org 0x10 -#ifdef CONFIG_SYS_XWAY_EBU_BOOTCFG +#if defined(CONFIG_SYS_XWAY_EBU_BOOTCFG) /* * Almost all Lantiq XWAY SoC devices have an external bus unit (EBU) to * access external NOR flashes. If the board boots from NOR flash the @@ -67,6 +67,12 @@ _start: */ .word CONFIG_SYS_XWAY_EBU_BOOTCFG .word 0x0 +#elif defined(CONFIG_QEMU_MALTA) + /* + * Linux expects the Board ID here. + */ + .word 0x00000420 # 0x420 (Malta Board with CoreLV) + .word 0x00000000 #endif
.org 0x200
Daniel Schwierzeck
Gabor Juhos
Nobuhiro Iwamatsu
