[U-Boot] [PATCH 1/5] mx31ads: Provide proper range for memtest
memtest adresses should contain proper DRAM address range.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx31ads.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 87638a4..fe073ba 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -146,8 +146,8 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
-#define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x10000 +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE/2) +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE)
#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx35pdk.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 0c62b9f..f2d4112 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -156,8 +156,8 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */
Personally I do not like that the memory test runs taking automatically the input parameters - even if the test must run automatically, I think it is better to put the parameters inside a script else to compile them with U-Boot.
But if we want to change them, why to put the start address at the middle of RAM ? The mx35pdk can have two banks of RAM, and the second one will still not tested. What I mean is that it is quite arbitrary where to set CONFIG_SYS_MEMTEST_START and CONFIG_SYS_MEMTEST_END, and with the possibility on some boards to have different RAM configurations this setup should be not decided at compile time.
And setting the end of test at the end of RAM (but this can open a debate: really the RAM size is computed at runtime with get_ram_size()) will overwrite U-Boot.
Stefano
Applied to u-boot-imx, thans.
Best regards, Stefano Babic
Dear Stefano Babic,
But this looks broken to me.
U-Boot will relocate itself to the end of RAM, and pout malloc arena and stack below. All this will be overwritten with this setup.
Has anybody actually tested this configuration?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Always borrow money from a pessimist; they don't expect to be paid back.
On 07/03/2012 13:38, Wolfgang Denk wrote:
Dear Stefano Babic,
Me too. I have not applied this patch. Rather I sent the "applied" message to the wrong patchset.
This was stated also in the thread related this patchset. Sorry for the confusion, I have really applied another patchset by Fabio, as you can see on u-boot-imx:
mx31pdk: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx51evk: Fix CONFIG_SYS_MEMTEST_END
In patchworks things are ok, only my e-mail was wrong (reply to wrong e-mail).
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/flea3.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 649e272..748d2b4 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -140,8 +140,8 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
Dear Stefano Babic,
Ditto - same for the other "Provide proper range for memtest" patches.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/imx31_litekit.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index bbcbce1..fcbd4a5 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -130,8 +130,8 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
#define CONFIG_SYS_LOAD_ADDR 0 /* default load address */
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/imx31_phycore.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 3153eb5..f0766d4 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -134,8 +134,8 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
args */
Buffer
Size */
PHYS_SDRAM_1_SIZE)
Won't this overwrite teh u-boot at the end of the RAM?
Fabio Estevam
Stefano Babic
