[U-Boot] [PATCH] ARM: OMAP4+: Allow arch specfic code to use early DM
Early system initialization is being done before initf_dm is being called in U-Boot. Then system will fail to boot if any of the DM enabled driver is being called in this system initialization code. So, rearrange the code a bit so that DM enabled drivers can be called during early system initialization.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- - tested dt and non-dt boot on DRA72 and DRA74 evm. arch/arm/cpu/armv7/omap-common/hwinit-common.c | 30 ++++++++++++++++++-------- 1 file changed, 21 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 9e9376d..99634fd 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -107,21 +107,26 @@ void __weak do_board_detect(void) { }
-/* - * Routine: s_init - * Description: Does early system init of watchdog, muxing, andclocks +void s_init(void) +{ +} + +/** + * early_system_init - Does Early system initialization. + * + * Does early system init of watchdog, muxing, andclocks * Watchdog disable is done always. For the rest what gets done - * depends on the boot mode in which this function is executed - * 1. s_init of SPL running from SRAM - * 2. s_init of U-Boot running from FLASH - * 3. s_init of U-Boot loaded to SDRAM by SPL - * 4. s_init of U-Boot loaded to SDRAM by ROM code using the + * depends on the boot mode in which this function is executed when + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. U-Boot loaded to SDRAM by SPL + * 4. U-Boot loaded to SDRAM by ROM code using the * Configuration Header feature * Please have a look at the respective functions to see what gets * done in each of these cases * This function is called with SRAM stack. */ -void s_init(void) +void early_system_init(void) { init_omap_revision(); hw_data_init(); @@ -145,6 +150,7 @@ void s_init(void) #ifdef CONFIG_SPL_BUILD void board_init_f(ulong dummy) { + early_system_init(); #ifdef CONFIG_BOARD_EARLY_INIT_F board_early_init_f(); #endif @@ -153,6 +159,12 @@ void board_init_f(ulong dummy) } #endif
+int arch_cpu_init_dm(void) +{ + early_system_init(); + return 0; +} + /* * Routine: wait_for_command_complete * Description: Wait for posting to finish on watchdog
Reviewed-by: Tom Rini trini@konsulko.com
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Lokesh Vutla
