[U-Boot] [PATCH] powerpc/BSC9131RDB: add mtdparts suppport
Use mtdparts to create partitions dynamically rather than using static partitions in device tree
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- include/configs/BSC9131RDB.h | 15 +++++++++++++++ 1 files changed, 15 insertions(+), 0 deletions(-)
diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 56a3e94..5c7b64e 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -393,6 +393,21 @@ extern unsigned long get_sdram_size(void); #endif
/* + * Dynamic MTD Partition support with mtdparts + */ +#ifndef CONFIG_SYS_NO_FLASH +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nand0=ff800000.flash," \ + "spi0=SPIFLASH0" +#define MTDPARTS_DEFAULT "mtdparts=ff800000.flash:3m(uboot)," \ + "8m(kernel),1m(dtb),-(user);SPIFLASH0:" \ + "1m(uboot),4m(kernel),512k(dtb),11m(fs),-(user)" +#endif + +/* * Environment Configuration */
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- include/configs/BSC9132QDS.h | 16 ++++++++++++++++ 1 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index aeded6d..9015b76 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -630,6 +630,22 @@ combinations. this should be removed later #endif
/* + * Dynamic MTD Partition support with mtdparts + */ +#ifndef CONFIG_SYS_NO_FLASH +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=88000000.nor,nand0=ff800000.flash," \ + "spi0=spiff707000.0" +#define MTDPARTS_DEFAULT "mtdparts=88000000.nor:128k(dtb),1m(uboot)," \ + "7m(kernel),55m(fs);ff800000.flash:3m(uboot)," \ + "8m(kernel),1m(dtb),-(user);spiff707000.0:" \ + "1m(uboot),4m(kernel),512k(dtb),8m(fs),-(user)" +#endif + +/* * Environment Configuration */
Ashish Kumar
