[PATCH] arm: mvebu: Espressobin: Add NVMe to boot targets
NVMe support is already enabled, so add it into boot targets.
Signed-off-by: Pali Rohár pali@kernel.org --- include/configs/mvebu_armada-37xx.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 778f8b828aa8..953dfe812558 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -50,6 +50,7 @@ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ + func(NVME, nvme, 0) \ func(SCSI, scsi, 0) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
Reviewed-by: Stefan Roese sr@denx.de
Thanks, Stefan
- func(NVME, nvme, 0) \ func(SCSI, scsi, 0) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
Viele Grüße, Stefan Roese
Hi Pali,
This patch generates build issues. E.g. on mvebu_db-88f3720_defconfig and most likely other platforms as well:
$ make -s -j20 In file included from include/configs/mvebu_armada-37xx.h:60, from include/config.h:4, from include/common.h:16, from env/common.c:10: include/config_distro_bootcmd.h:215:9: error: expected '}' before 'BOOT_TARGET_DEVICES_references_NVME_without_CONFIG_NVME' 215 | BOOT_TARGET_DEVICES_references_NVME_without_CONFIG_NVME | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/config_distro_bootcmd.h:215:9: note: in definition of macro 'BOOTENV_DEV_NAME_NVME' 215 | BOOT_TARGET_DEVICES_references_NVME_without_CONFIG_NVME | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/configs/mvebu_armada-37xx.h:55:9: note: in expansion of macro 'BOOTENV_DEV_NAME' 55 | func(NVME, nvme, 0) \ | ^~~~ include/config_distro_bootcmd.h:417:25: note: in expansion of macro 'BOOT_TARGET_DEVICES' 417 | "boot_targets=" BOOT_TARGET_DEVICES(BOOTENV_DEV_NAME) "\0" | ^~~~~~~~~~~~~~~~~~~ include/config_distro_bootcmd.h:436:9: note: in expansion of macro 'BOOTENV_BOOT_TARGETS' 436 | BOOTENV_BOOT_TARGETS \ | ^~~~~~~~~~~~~~~~~~~~ include/configs/mvebu_armada-37xx.h:80:9: note: in expansion of macro 'BOOTENV' 80 | BOOTENV \ | ^~~~~~~ include/env_default.h:119:9: note: in expansion of macro 'CONFIG_EXTRA_ENV_SETTINGS' 119 | CONFIG_EXTRA_ENV_SETTINGS | ^~~~~~~~~~~~~~~~~~~~~~~~~ In file included from env/common.c:32: include/env_default.h:27:30: note: to match this '{' 27 | char default_environment[] = { | ^ make[1]: *** [scripts/Makefile.build:257: env/common.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [Makefile:1906: env] Error 2 make: *** Waiting for unfinished jobs....
Please check and resubmit once it builds "world" without problems.
Thanks, Stefan
On Monday 16 May 2022 11:30:54 Stefan Roese wrote:
Hi Pali,
I see. This file is used by more A3720 boards and therefore it needs different approach to enable NVMe support in distroboot.
Here is a new patch series which do it: https://patchwork.ozlabs.org/project/uboot/patch/20220523091436.15251-2-pali...
Thanks, Stefan
Pali Rohár
Stefan Roese
