[NXP-IMX] Please pull nxp-imx-4-23-2021
Hi Stefano,
Please pull nxp-imx-4-23-2021, This PR is based on Tom's master branch. CI: https://source.denx.de/u-boot/custodians/u-boot-mmc/-/pipelines/7264
I have updated the patches's status. This is a quite large patchset, but actually only do two things as below: ----------------------------------------------------- Add i.MX8ULP support(without uPower API) Enable the DWC EQoS for i.MX8MP EVK ----------------------------------------------------
Thanks, Peng.
The following changes since commit 842d049be23976ebcbb2522fa8d752d3aae8631a:
Merge branch '2021-04-20-assorted-improvements' (2021-04-20 07:32:04 -0400)
are available in the Git repository at:
https://github.com/MrVan/u-boot.git tags/nxp-imx-4-23-2021
for you to fetch changes up to 489b20683a2b51d519145d8cca1dd2b8afcf9397:
imx8mp_evk: Enable the DWC EQoS iMX driver (2021-04-23 19:01:54 +0800)
---------------------------------------------------------------- Peng Fan (22): imx: cmd: use struct cmd_tbl arm: imx: add i.MX8ULP basic Kconfig option arm: imx: add i.MX8ULP cpu type and helper arm: imx: sys_proto: move boot mode define to common header arm: imx8ulp: support print cpu info imx: imx8ulp: add get reset cause arm: imx: basic i.MX8ULP support arm: imx: parse-container: guard included header files arm: imx: move container Kconfig under mach-imx net: fec_mxc: support i.MX8ULP driver: serial: fsl_lpuart: support i.MX8ULP arm: imx8ulp: add clock support drivers: mmc: fsl_esdhc_imx: support i.MX8ULP arm: imx8ulp: disable wdog3 arm: imx8ulp: add xrdc support arm: imx8ulp: add trdc release request arm: imx8ulp: release trdc and assign lpav from RTD to APD arm: imx8ulp: add dummy imx_get_mac_from_fuse arm: imx8ulp: add iomuxc support arm: dts: add i.MX8ULP dtsi arm: imx: add i.MX8ULP EVK support arm: mach-imx: Allow to build mac.c for EQoS driver
Ye Li (25): arm: imx8: Move container parser and image to mach-imx common folder arm: imx8: Move container image header file to mach-imx arm: imx8ulp: add container support driver: misc: Add MU and S400 API to communicate with Sentinel pinctrl: Add pinctrl driver for imx8ulp arm: imx8ulp: soc: Change to use CMC1 to get bootcfg arm: imx8ulp: Enable full L2 cache in SPL arm: imx8ulp: Update the reset vector in u-boot drivers: misc: s400_api: Update S400_SUCCESS_IND to 0xd6 drivers: misc: imx8ulp: Add S400 API for image authentication drivers: misc: imx8ulp: Update S400 API for release RDC drivers: misc: s400_api: Update API for fuse read and write arm: imx8ulp: release and configure XRDC at early phase arm: imx8ulp: Probe the S400 MU device in arch init arm: iMX8ULP: Add boot device relevant functions arm: imx8ulp: Allocate DCNANO and MIPI_DSI to AD domain driver: misc: imx8ulp: Add fuse driver for imx8ulp net: eqos: Add PHY reset control for i.MX platform arm: mach-imx: Update MAC fuse for i.MX8MP arm: dts: imx8mp: Add EQoS controller node arm: dts: imx8mp-evk: Enable the EQoS ethernet port imx8mp_evk: Fix incorrect cascade for FEC and EQOS setup imx8mp_evk: Remove EQoS PHY reset codes imx8mp_evk: Delete noncached memory config imx8mp_evk: Enable the DWC EQoS iMX driver
arch/arm/Kconfig | 10 + arch/arm/Makefile | 4 +- arch/arm/dts/Makefile | 3 + arch/arm/dts/imx8mp-evk-u-boot.dtsi | 11 + arch/arm/dts/imx8mp-evk.dts | 40 +++ arch/arm/dts/imx8mp.dtsi | 23 ++ arch/arm/dts/imx8ulp-evk-u-boot.dtsi | 32 +++ arch/arm/dts/imx8ulp-evk.dts | 204 ++++++++++++++ arch/arm/dts/imx8ulp-pinfunc.h | 978 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8ulp.dtsi | 706 +++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx/cpu.h | 2 + arch/arm/include/asm/arch-imx8ulp/cgc.h | 130 +++++++++ arch/arm/include/asm/arch-imx8ulp/clock.h | 41 +++ arch/arm/include/asm/arch-imx8ulp/ddr.h | 38 +++ arch/arm/include/asm/arch-imx8ulp/gpio.h | 20 ++ arch/arm/include/asm/arch-imx8ulp/imx-regs.h | 134 ++++++++++ arch/arm/include/asm/arch-imx8ulp/imx8ulp-pins.h | 60 +++++ arch/arm/include/asm/arch-imx8ulp/iomux.h | 82 ++++++ arch/arm/include/asm/arch-imx8ulp/mu_hal.h | 12 + arch/arm/include/asm/arch-imx8ulp/pcc.h | 139 ++++++++++ arch/arm/include/asm/arch-imx8ulp/s400_api.h | 41 +++ arch/arm/include/asm/arch-imx8ulp/sys_proto.h | 19 ++ arch/arm/include/asm/arch-mx7ulp/sys_proto.h | 9 - arch/arm/include/asm/global_data.h | 5 + arch/arm/include/asm/{arch-imx8 => mach-imx}/image.h | 2 + arch/arm/include/asm/mach-imx/sys_proto.h | 13 +- arch/arm/mach-imx/Kconfig | 15 +- arch/arm/mach-imx/Makefile | 6 + arch/arm/mach-imx/cmd_dek.c | 2 +- arch/arm/mach-imx/cmd_mfgprot.c | 2 +- arch/arm/mach-imx/{imx8/image.c => image-container.c} | 44 +++- arch/arm/mach-imx/imx8/Kconfig | 13 - arch/arm/mach-imx/imx8/Makefile | 3 - arch/arm/mach-imx/imx8/ahab.c | 2 +- arch/arm/mach-imx/imx8ulp/Kconfig | 23 ++ arch/arm/mach-imx/imx8ulp/Makefile | 7 + arch/arm/mach-imx/imx8ulp/cgc.c | 459 ++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/clock.c | 390 +++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/iomux.c | 65 +++++ arch/arm/mach-imx/imx8ulp/lowlevel_init.S | 26 ++ arch/arm/mach-imx/imx8ulp/pcc.c | 449 +++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/soc.c | 685 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8ulp/xrdc.c | 144 ++++++++++ arch/arm/mach-imx/mac.c | 2 +- arch/arm/mach-imx/{imx8 => }/parse-container.c | 4 +- arch/arm/mach-imx/priblob.c | 2 +- arch/arm/mach-imx/spl_imx_romapi.c | 171 +++++++++--- board/freescale/imx8mp_evk/imx8mp_evk.c | 24 +- board/freescale/imx8ulp_evk/Kconfig | 14 + board/freescale/imx8ulp_evk/MAINTAINERS | 6 + board/freescale/imx8ulp_evk/Makefile | 7 + board/freescale/imx8ulp_evk/ddr_init.c | 207 +++++++++++++++ board/freescale/imx8ulp_evk/imx8ulp_evk.c | 67 +++++ board/freescale/imx8ulp_evk/lpddr4_timing.c | 1696 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/freescale/imx8ulp_evk/spl.c | 146 ++++++++++ configs/imx8mp_evk_defconfig | 2 + configs/imx8ulp_evk_defconfig | 103 ++++++++ drivers/misc/Makefile | 1 + drivers/misc/imx8ulp/Makefile | 4 + drivers/misc/imx8ulp/fuse.c | 198 ++++++++++++++ drivers/misc/imx8ulp/imx8ulp_mu.c | 251 ++++++++++++++++++ drivers/misc/imx8ulp/s400_api.c | 244 +++++++++++++++++ drivers/mmc/Kconfig | 2 +- drivers/mmc/fsl_esdhc_imx.c | 12 +- drivers/net/Kconfig | 2 +- drivers/net/dwc_eth_qos.c | 55 ++++ drivers/net/fec_mxc.c | 2 +- drivers/pinctrl/nxp/Kconfig | 14 + drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-imx8ulp.c | 44 ++++ include/configs/imx8mp_evk.h | 3 - include/configs/imx8ulp_evk.h | 108 ++++++++ include/dt-bindings/clock/imx8ulp-clock.h | 247 +++++++++++++++++ include/fsl_lpuart.h | 2 +- 74 files changed, 8621 insertions(+), 113 deletions(-) create mode 100644 arch/arm/dts/imx8ulp-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8ulp-evk.dts create mode 100644 arch/arm/dts/imx8ulp-pinfunc.h create mode 100644 arch/arm/dts/imx8ulp.dtsi create mode 100644 arch/arm/include/asm/arch-imx8ulp/cgc.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/clock.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/ddr.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/gpio.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/imx-regs.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/imx8ulp-pins.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/iomux.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/mu_hal.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/pcc.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/s400_api.h create mode 100644 arch/arm/include/asm/arch-imx8ulp/sys_proto.h rename arch/arm/include/asm/{arch-imx8 => mach-imx}/image.h (95%) rename arch/arm/mach-imx/{imx8/image.c => image-container.c} (82%) create mode 100644 arch/arm/mach-imx/imx8ulp/Kconfig create mode 100644 arch/arm/mach-imx/imx8ulp/Makefile create mode 100644 arch/arm/mach-imx/imx8ulp/cgc.c create mode 100644 arch/arm/mach-imx/imx8ulp/clock.c create mode 100644 arch/arm/mach-imx/imx8ulp/iomux.c create mode 100644 arch/arm/mach-imx/imx8ulp/lowlevel_init.S create mode 100644 arch/arm/mach-imx/imx8ulp/pcc.c create mode 100644 arch/arm/mach-imx/imx8ulp/soc.c create mode 100644 arch/arm/mach-imx/imx8ulp/xrdc.c rename arch/arm/mach-imx/{imx8 => }/parse-container.c (98%) create mode 100644 board/freescale/imx8ulp_evk/Kconfig create mode 100644 board/freescale/imx8ulp_evk/MAINTAINERS create mode 100644 board/freescale/imx8ulp_evk/Makefile create mode 100644 board/freescale/imx8ulp_evk/ddr_init.c create mode 100644 board/freescale/imx8ulp_evk/imx8ulp_evk.c create mode 100644 board/freescale/imx8ulp_evk/lpddr4_timing.c create mode 100644 board/freescale/imx8ulp_evk/spl.c create mode 100644 configs/imx8ulp_evk_defconfig create mode 100644 drivers/misc/imx8ulp/Makefile create mode 100644 drivers/misc/imx8ulp/fuse.c create mode 100644 drivers/misc/imx8ulp/imx8ulp_mu.c create mode 100644 drivers/misc/imx8ulp/s400_api.c create mode 100644 drivers/pinctrl/nxp/pinctrl-imx8ulp.c create mode 100644 include/configs/imx8ulp_evk.h create mode 100644 include/dt-bindings/clock/imx8ulp-clock.h
Hi Peng,
On Fri, Apr 23, 2021 at 1:27 PM Peng Fan peng.fan@nxp.com wrote:
Hi Stefano,
I think these long i.MX8ULP series need more time to be reviewed.
On 2021/4/24 0:59, Fabio Estevam wrote:
Hi Peng,
Hi Stefano,
Please pull nxp-imx-4-23-2021, This PR is based on Tom's master branch. CI: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource.den...
Well.It almost 2 weeks since the patchset, and no comments, I wanna to catch the merge window, so sent this PR.
Thanks, Peng.
Fabio Estevam
Peng Fan
Peng Fan (OSS)
