[U-Boot] [PATCH 1/2] Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
README | 6 ------ configs/colibri_pxa270_defconfig | 1 + configs/s5p_goni_defconfig | 1 + env/Kconfig | 10 ++++++++++ include/configs/am335x_evm.h | 2 -- include/configs/am335x_igep003x.h | 2 -- include/configs/am335x_shc.h | 2 -- include/configs/am335x_sl50.h | 2 -- include/configs/am43xx_evm.h | 2 -- include/configs/apalis_imx6.h | 1 - include/configs/baltos.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/cgtqmx6eval.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t43.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 2 -- include/configs/colibri_pxa270.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/duovero.h | 2 -- include/configs/el6x_common.h | 1 - include/configs/imx6_logic.h | 2 -- include/configs/k2g_evm.h | 2 -- include/configs/mccmon6.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 2 -- include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 2 -- include/configs/mx6ullevk.h | 2 -- include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 1 - include/configs/omap4_panda.h | 1 - include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 2 -- include/configs/pepper.h | 1 - include/configs/rpi.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 2 -- include/configs/sama5d3xek.h | 2 -- include/configs/ti814x_evm.h | 1 - include/configs/ti_omap5_common.h | 1 - include/configs/trats.h | 2 -- include/configs/trats2.h | 2 -- include/configs/udoo.h | 2 -- include/configs/udoo_neo.h | 1 - include/configs/vining_2000.h | 1 - include/configs/wandboard.h | 1 - include/configs/wb50n.h | 1 - scripts/config_whitelist.txt | 1 - 50 files changed, 12 insertions(+), 72 deletions(-)
diff --git a/README b/README index 5fd6428..3d7b511 100644 --- a/README +++ b/README @@ -2213,12 +2213,6 @@ The following options need to be configured: the environment like the "source" command or the boot command first.
- CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - - Define this in order to add variables describing certain - run-time determined information about the hardware to the - environment. These will be named board_name, board_rev. - CONFIG_DELAY_ENVIRONMENT
Normally the environment is loaded when the board is diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index e21068e..958fbbbf 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_BOOTP_BOOTPATH=y CONFIG_BOOTP_GATEWAY=y CONFIG_BOOTP_HOSTNAME=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 237b590..a54dd5f 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_NET is not set CONFIG_DFU_MMC=y CONFIG_DM_I2C_GPIO=y diff --git a/env/Kconfig b/env/Kconfig index a3c6298..bf13cbf 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -486,4 +486,14 @@ config ENV_SIZE
endif
+config ENV_VARS_UBOOT_RUNTIME_CONFIG + bool "Add run-time information to the environment" + default y if ARCH_OMAP2PLUS || ARCH_MX6 || ARCH_AT91 || \ + ARCH_BCM283X || ARCH_KEYSTONE || ARCH_VF610 || \ + ARCH_EXYNOS || ARCH_MX7 + help + Enable this in order to add variables describing certain + run-time determined information about the hardware to the + environment. These will be named board_name, board_rev. + endmenu diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 158b7d4..6e8477c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -56,8 +56,6 @@ #define NANDARGS "" #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define BOOTENV_DEV_LEGACY_MMC(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ "setenv mmcdev " #instance"; "\ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 50fd46a..42db594 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -26,8 +26,6 @@ #define CONFIG_UBI_SILENCE_MSG #define CONFIG_UBIFS_SILENCE_MSG
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index 6fa117e..017e9e5 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -65,8 +65,6 @@ # define CONFIG_RESET_TO_RETRY #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index 739a998..9687f37 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -26,8 +26,6 @@ /* Always 128 KiB env size */ #define CONFIG_ENV_SIZE (128 << 10)
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 663f861..8cd93e8 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -62,8 +62,6 @@ /* Always 64 KiB env size */ #define CONFIG_ENV_SIZE (64 << 10)
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* Clock Defines */ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK) diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 9e5a7e5..780e6cf 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -41,7 +41,6 @@
/* Make the HW version stuff available in U-Boot env */ #define CONFIG_VERSION_VARIABLE /* ver environment variable */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 943a6f8..19db350 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -69,8 +69,6 @@ #define NANDARGS "" #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index e7f65d6..a044329 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -56,8 +56,6 @@ #define NANDARGS "" #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index afc0bae..b3814a6 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -99,7 +99,6 @@ #define CONFIG_MMCROOT "/dev/mmcblk0p2" #define CONFIG_SYS_MMC_ENV_DEV 0
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 596e060..51686cd 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -45,7 +45,6 @@
/* Environment */ #define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB env size */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
#define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 4f36930..9cf559e 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -63,7 +63,6 @@ #define CONFIG_ENV_OFFSET (768 * 1024)
#ifndef CONFIG_SPL_BUILD -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index da78519..a1dd599 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -84,7 +84,6 @@ #undef CONFIG_SYS_MONITOR_LEN
#define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
#define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK) diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 72db44d..42396e8 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -39,7 +39,6 @@
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 27f44ac..1a742a6 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -19,8 +19,6 @@
#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 484483d..6a77c39 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -26,7 +26,6 @@ * Environment settings */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_SYS_MALLOC_LEN (128 * 1024) #define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 1078480..782e007 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -39,7 +39,6 @@
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
/* NAND support */ #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/duovero.h b/include/configs/duovero.h index 96644b1..1fecac2 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -34,6 +34,4 @@
/* ENV related config options */
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #endif /* __CONFIG_DUOVERO_H */ diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index 94e0bdf..53902d1 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -56,7 +56,6 @@
#define CONFIG_BOARD_NAME EL6Q
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "board="__stringify(CONFIG_BOARD_NAME)"\0" \ "cma_size="__stringify(EL6Q_CMA_SIZE)"\0" \ diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 1bc7f2a..bfc9b33 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -28,8 +28,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index f00ca1c..b14f6c5 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -16,8 +16,6 @@ /* Platform type */ #define CONFIG_SOC_K2G
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* U-Boot general configuration */ #define CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ DEFAULT_MMC_TI_ARGS \ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 8eb248a..0aa797a 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -94,7 +94,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 1
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200 quiet\0" \ "fdtfile=imx6q-mccmon6.dtb\0" \ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 0e1d18c..9fbd162 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -71,7 +71,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 1 #define CONFIG_SYS_MMC_ENV_DEV 0 /* SDHC2 */
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "fdtfile=undefined\0" \ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index d976e77..6f970a4 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -57,8 +57,6 @@ #define EMMC_ENV "" #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 1eaaf01..713ebf6 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -43,7 +43,6 @@ #define UPDATE_M4_ENV "" #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ UPDATE_M4_ENV \ "script=boot.scr\0" \ diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 1c1671e..733538f 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -18,8 +18,6 @@ /* SPL options */ #include "imx6_spl.h"
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 2142913..cf9f8ab 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -22,8 +22,6 @@
#define PHYS_SDRAM_SIZE SZ_512M
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 2c8ee7a..8faa7a3 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -185,7 +185,6 @@ * TODO: Add Odroid X support */ #define CONFIG_MISC_COMMON -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_BOARD_TYPES #define CONFIG_MISC_INIT_R
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 9067ba6..53edd23 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -88,7 +88,6 @@ #define CONFIG_SET_DFU_ALT_BUF_LEN (SZ_1K)
/* Set soc_rev, soc_id, board_rev, boardname, fdtfile */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_ODROID_REV_AIN 9 #define CONFIG_REVISION_TAG #define CONFIG_BOARD_TYPES diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 75203b2..8cded99 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -30,7 +30,6 @@
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_ENV_OVERWRITE
#endif /* __CONFIG_PANDA_H */ diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 411403e..4f72350 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -25,7 +25,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_PCM051
/* set to negative value for no autoboot */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80007fc0\0" \ "fdtaddr=0x80000000\0" \ diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 74bfde7..545f859 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -22,8 +22,6 @@ /* set env size */ #define CONFIG_ENV_SIZE 0x4000
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ diff --git a/include/configs/pepper.h b/include/configs/pepper.h index f0ffc51..44dcfba 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -20,7 +20,6 @@
#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ "bootdir=/boot\0" \ diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 17cdecd..325e52a 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -86,7 +86,6 @@ #define CONFIG_INITRD_TAG
/* Environment */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define ENV_DEVICE_SETTINGS \ "stdin=serial,usbkbd\0" \ "stdout=serial,vidconsole\0" \ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 1b40c29..40f037e 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -103,7 +103,6 @@ #define CONFIG_MISC_INIT_R
#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ CONFIG_UPDATEB \ "updatek=" \ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 841dedd..410d20b 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -71,8 +71,6 @@
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "updateb=" \ "onenand erase 0x0 0x100000;" \ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 843aaa6..be19d8d 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -15,8 +15,6 @@
#include "at91-sama5_common.h"
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* * This needs to be defined for the OHCI code to work but it is defined as * ATMEL_ID_UHPHS in the CPU specific header files. diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 2f9056c..a951118 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -28,7 +28,6 @@
/* commands to include */
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ "fdtaddr=0x80F80000\0" \ diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 5391641..d6ea17b 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -58,7 +58,6 @@ #include <environment/ti/boot.h> #include <environment/ti/mmc.h>
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ DEFAULT_MMC_TI_ARGS \ diff --git a/include/configs/trats.h b/include/configs/trats.h index e6649ff..e892b59 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -57,8 +57,6 @@
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOT "boot" diff --git a/include/configs/trats2.h b/include/configs/trats2.h index c3eb7c9..aecac07 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -52,8 +52,6 @@
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOT "boot" diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 989014a..dd86dee 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -46,8 +46,6 @@ /* MMC Configuration */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index 35a6eca..7e6b980 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 /*USDHC2*/
/* Linux only */ -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200\0" \ "fdt_high=0xffffffff\0" \ diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index f054c99..45d1c35 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -92,7 +92,6 @@ #define CONFIG_PWM_IMX #define CONFIG_IMX6_PWM_PER_CLK 66000000
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET_REDUND (9 * SZ_64K) diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 487cb1f..fb392f8 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -79,7 +79,6 @@ #define CONFIG_IMX_VIDEO_SKIP #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200\0" \ "splashpos=m,m\0" \ diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index c61865f..76a02bc 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -23,7 +23,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
-#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_IMAGE_FORMAT_LEGACY
/* general purpose I/O */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d6fd150..38996ea 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -538,7 +538,6 @@ CONFIG_ENV_TOTAL_SIZE CONFIG_ENV_UBIFS_OPTION CONFIG_ENV_UBI_MTD CONFIG_ENV_UBI_VOLUME_REDUND -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG CONFIG_ENV_VERSION CONFIG_EP9302 CONFIG_EP9307
CONFIG_VERSION_VARIABLE had already been mostly migrated to Kconfig, but two headers still referenced it. Also set defaults so that most of the defconfigs inherit the default rather than needing it to be set explicitly.
README | 8 -------- common/Kconfig | 6 +++++- configs/alt_defconfig | 1 - configs/am335x_baltos_defconfig | 1 - configs/am335x_boneblack_defconfig | 1 - configs/am335x_boneblack_vboot_defconfig | 1 - configs/am335x_evm_defconfig | 1 - configs/am335x_evm_nor_defconfig | 1 - configs/am335x_evm_norboot_defconfig | 1 - configs/am335x_evm_spiboot_defconfig | 1 - configs/am335x_evm_usbspl_defconfig | 1 - configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/am335x_igep003x_defconfig | 1 - configs/am335x_shc_defconfig | 1 - configs/am335x_shc_ict_defconfig | 1 - configs/am335x_shc_netboot_defconfig | 1 - configs/am335x_shc_prompt_defconfig | 1 - configs/am335x_shc_sdboot_defconfig | 1 - configs/am335x_shc_sdboot_prompt_defconfig | 1 - configs/am335x_sl50_defconfig | 1 - configs/am3517_evm_defconfig | 1 - configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_ethboot_defconfig | 1 - configs/am43xx_evm_qspiboot_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/apx4devkit_defconfig | 1 - configs/armadillo-800eva_defconfig | 1 - configs/bg0900_defconfig | 1 - configs/birdland_bav335a_defconfig | 1 - configs/birdland_bav335b_defconfig | 1 - configs/blanche_defconfig | 1 - configs/brppt1_mmc_defconfig | 1 - configs/brppt1_nand_defconfig | 1 - configs/brppt1_spi_defconfig | 1 - configs/brxre1_defconfig | 1 - configs/cairo_defconfig | 1 - configs/calimain_defconfig | 1 - configs/cl-som-am57x_defconfig | 1 - configs/cm_t335_defconfig | 1 - configs/cm_t43_defconfig | 1 - configs/cm_t54_defconfig | 1 - configs/colibri_vf_defconfig | 1 - configs/da850_am18xxevm_defconfig | 1 - configs/da850evm_defconfig | 1 - configs/da850evm_direct_nor_defconfig | 1 - configs/devkit8000_defconfig | 1 - configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/duovero_defconfig | 1 - configs/ea20_defconfig | 1 - configs/gose_defconfig | 1 - configs/igep0032_defconfig | 1 - configs/igep00x0_defconfig | 1 - configs/ipam390_defconfig | 1 - configs/k2e_evm_defconfig | 1 - configs/k2e_hs_evm_defconfig | 1 - configs/k2g_evm_defconfig | 1 - configs/k2g_hs_evm_defconfig | 1 - configs/k2hk_evm_defconfig | 1 - configs/k2hk_hs_evm_defconfig | 1 - configs/k2l_evm_defconfig | 1 - configs/koelsch_defconfig | 1 - configs/kzm9g_defconfig | 1 - configs/lager_defconfig | 1 - configs/legoev3_defconfig | 1 - configs/m28evk_defconfig | 1 - configs/m53evk_defconfig | 1 - configs/ma5d4evk_defconfig | 1 - configs/mx23_olinuxino_defconfig | 1 - configs/mx23evk_defconfig | 1 - configs/mx28evk_auart_console_defconfig | 1 - configs/mx28evk_defconfig | 1 - configs/mx28evk_nand_defconfig | 1 - configs/mx28evk_spi_defconfig | 1 - configs/novena_defconfig | 1 - configs/omap3_beagle_defconfig | 1 - configs/omap3_evm_defconfig | 2 -- configs/omap3_logic_defconfig | 1 - configs/omap3_overo_defconfig | 1 - configs/omap3_pandora_defconfig | 1 - configs/omap3_zoom1_defconfig | 1 - configs/omap4_panda_defconfig | 1 - configs/omap4_sdp4430_defconfig | 1 - configs/omap5_uevm_defconfig | 1 - configs/omapl138_lcdk_defconfig | 1 - configs/opos6uldev_defconfig | 1 - configs/pcm051_rev1_defconfig | 1 - configs/pcm051_rev3_defconfig | 1 - configs/pengwyn_defconfig | 1 - configs/pepper_defconfig | 1 - configs/porter_defconfig | 1 - configs/r8a7795_salvator-x_defconfig | 1 - configs/r8a7795_ulcb_defconfig | 1 - configs/r8a77965_salvator-x_defconfig | 1 - configs/r8a7796_salvator-x_defconfig | 1 - configs/r8a7796_ulcb_defconfig | 1 - configs/r8a77970_eagle_defconfig | 1 - configs/r8a77995_draak_defconfig | 1 - configs/sansa_fuze_plus_defconfig | 1 - configs/sc_sps_1_defconfig | 1 - configs/silk_defconfig | 1 - configs/sksimx6_defconfig | 1 - configs/socfpga_arria5_defconfig | 1 - configs/socfpga_cyclone5_defconfig | 1 - configs/socfpga_dbm_soc1_defconfig | 1 - configs/socfpga_de0_nano_soc_defconfig | 1 - configs/socfpga_de10_nano_defconfig | 1 - configs/socfpga_de1_soc_defconfig | 1 - configs/socfpga_is1_defconfig | 1 - configs/socfpga_mcvevk_defconfig | 1 - configs/socfpga_sockit_defconfig | 1 - configs/socfpga_socrates_defconfig | 1 - configs/socfpga_sr1500_defconfig | 1 - configs/socfpga_vining_fpga_defconfig | 1 - configs/stout_defconfig | 1 - configs/ti814x_evm_defconfig | 1 - configs/ti816x_evm_defconfig | 1 - configs/xfi3_defconfig | 1 - include/configs/apalis_imx6.h | 3 --- include/configs/colibri_imx6.h | 3 --- 124 files changed, 5 insertions(+), 136 deletions(-)
diff --git a/README b/README index 3d7b511..622cfaa 100644 --- a/README +++ b/README @@ -812,14 +812,6 @@ The following options need to be configured: CONFIG_AT91_HW_WDT_TIMEOUT specify the timeout in seconds. default 2 seconds.
-- U-Boot Version: - CONFIG_VERSION_VARIABLE - If this variable is defined, an environment variable - named "ver" is created by U-Boot showing the U-Boot - version as printed by the "version" command. - Any change to this variable will be reverted at the - next reset. - - Real-Time Clock:
When CONFIG_CMD_DATE is selected, the type of the RTC diff --git a/common/Kconfig b/common/Kconfig index b92d0e3..ab01ba3 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -534,7 +534,11 @@ config DEFAULT_FDT_FILE
config VERSION_VARIABLE bool "add U-Boot environment variable vers" - default n + default y if ARCH_OMAP2PLUS || ARCH_MX6 || ARCH_AT91 || \ + ARCH_BCM283X || ARCH_KEYSTONE || ARCH_VF610 || \ + ARCH_EXYNOS || ARCH_MX7 || ARCH_DAVINCI || \ + ARCH_MX23 || ARCH_MX28 || ARCH_MX5 || ARCH_RMOBILE || \ + ARCH_SOCFPGA help If this variable is defined, an environment variable named "ver" is created by U-Boot showing the U-Boot diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 172461a..44377c0 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7794=y CONFIG_TARGET_ALT=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-alt-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index ab7d96d..9d30722 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index f45e409..bcdbc93 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index df73f65..246dfc4 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -10,7 +10,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 60120bf..f1c08e6 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 6598879..678c918 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -6,7 +6,6 @@ CONFIG_NOR=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 22182f5..cd3ee49 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -9,7 +9,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NOR_BOOT=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_FASTBOOT=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 079f69d..2fc762f 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -10,7 +10,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index e4bf757..6f00412 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index c903cc7..a9268a1 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_FIT_IMAGE_TINY=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 6971e57..e9e6886 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -14,7 +14,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y # CONFIG_SPL_ENV_SUPPORT is not set diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index d2026da..9142b3b 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -16,7 +16,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0033" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index fb714da..2156208 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -15,7 +15,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 2568e3d..066d62a 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -16,7 +16,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 16071fb..dbbc128 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -16,7 +16,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index bbad6dd..aa6a776 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -15,7 +15,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 82a61a3..f7e1b7f 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -16,7 +16,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index 82a61a3..f7e1b7f 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -16,7 +16,6 @@ CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index cd1b78e..8cc77ec 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 8b4e7ea..ea05bf8 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -11,7 +11,6 @@ CONFIG_DEFAULT_DEVICE_TREE="am3517-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=10 # CONFIG_USE_BOOTCOMMAND is not set -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_EXT_SUPPORT is not set diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 172b292..0a3a4d3 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 835a58d..2a00b7b 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -5,7 +5,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_SYS_MALLOC_SIMPLE is not set CONFIG_SPL_ETH_SUPPORT=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 2bc302c..cfdcf7e 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -8,7 +8,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_QSPI_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 7ca24d5..d21fe8d 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index b69d855..7dbf487 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -17,7 +17,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 7ed010f..334c94a 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -16,7 +16,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=am57xevmboard" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index d9fb6ec..e841c5f 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -22,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=am57xevmboard" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 5ba086a..14c9ad5 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_APX4DEVKIT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 2c212e2..80b7835 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_TEXT_BASE=0xE80C0000 CONFIG_R8A7740=y CONFIG_TARGET_ARMADILLO_800EVA=y CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_CMD_BDI is not set diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 29dc6bd..c742ad3 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 823fc74..9809274 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -16,7 +16,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 6d12aba..1ef1ead 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -16,7 +16,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index d9c08e1..f89a86d 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_R8A7792=y CONFIG_TARGET_BLANCHE=y CONFIG_DEFAULT_DEVICE_TREE="r8a7792-blanche-u-boot" -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 6de9a78..c5b297f 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -16,7 +16,6 @@ CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index a1a5590..c22f5c0 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -14,7 +14,6 @@ CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 0052d16..0516222 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -19,7 +19,6 @@ CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 3f37573..8e0627e 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -14,7 +14,6 @@ CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 827ac33..471aa68 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -6,7 +6,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=-2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 234b1a5..e052c24 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_TARGET_CALIMAIN=y CONFIG_DA850_LOWLEVEL=y CONFIG_BOOTDELAY=0 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index 3904321..19883e4 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -5,7 +5,6 @@ CONFIG_TARGET_CL_SOM_AM57X=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 46979b3..cc145b0 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 4e7978c..468a881 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 2c37128..b36be54 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -9,7 +9,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_SATA_SUPPORT=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index d30f3eb..0c10cff 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -8,7 +8,6 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,IMX_NAND" CONFIG_BOOTDELAY=1 CONFIG_LOGLEVEL=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 93c833d..ebbfbb3 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -12,7 +12,6 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index f1e0671..28699c4 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -11,7 +11,6 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 5ff12ac..c038fba 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -10,7 +10,6 @@ CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="mem=32M console=ttyS2,115200n8 root=/dev/mtdblock2 rw noinitrd ip=dhcp" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 5c68bc9..210c002 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -5,7 +5,6 @@ CONFIG_TARGET_DEVKIT8000=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y # CONFIG_CMD_IMI is not set diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 2b83a0c..5b93a2a 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -16,7 +16,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 5a8129c..f678843 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -22,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index c5771e6..3c77e6a 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_I2C_SUPPORT is not set CONFIG_SYS_PROMPT="duovero # " diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 5997b33..fb7723f 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -7,7 +7,6 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index baa8d85..2117afe 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7793=y CONFIG_TARGET_GOSE=y CONFIG_DEFAULT_DEVICE_TREE="r8a7793-gose-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 0a3dff7..c33c56c 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -7,7 +7,6 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 8727669..183b011 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -7,7 +7,6 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index f2d327a..45aff4b 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index c8bf8f2..eec8748 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index a79ce60..e4392b1 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 2afb768..4fec97c 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 5402cd3..74fab90 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 2252e45..c4c16f2 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 09ac21e..9a6c478 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 791bbae..754d01e 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 1246dde..6ef36d6 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7791=y CONFIG_TARGET_KOELSCH=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-koelsch-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index f34fe9b..0f9848f 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -6,7 +6,6 @@ CONFIG_TARGET_KZM9G=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/null console=ttySC4,115200" -CONFIG_VERSION_VARIABLE=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="KZM-A9-GT# " diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 1ce7949..b1c1352 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7790=y CONFIG_TARGET_LAGER=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-lager-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 469af7e..05f380d 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_LEGOEV3=y CONFIG_BOOTDELAY=0 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 1aea6bf..374d477 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200n8 " # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 52eb303..13fd00a 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -15,7 +15,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttymxc1,115200" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index 8322ed7..4189f2d 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS3,115200" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 52aeb69..75fcc66 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MX23_OLINUXINO=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index cc149a9..160ec61 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_MX23EVK=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 5417d07..bb15ada 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 6fc81a6..21376f8 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index bed676f..86ff1ac 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 4e4ef43..7f4405f 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 75cc57b..1aa2bdb 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -18,7 +18,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttymxc1,115200 " CONFIG_BOOTCOMMAND="run distro_bootcmd ; run net_nfs" -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 1ace7dd..67141b9 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 55fc944..3b73e99 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -6,7 +6,6 @@ CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y @@ -48,7 +47,6 @@ CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x2C000000 CONFIG_SMC911X_32_BIT=y -CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index b6a3e23..e0f974f 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -7,7 +7,6 @@ CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 894859f..88b4720 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -5,7 +5,6 @@ CONFIG_TARGET_OMAP3_OVERO=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index a0c8a36..4c46467 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -6,7 +6,6 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="Pandora # " # CONFIG_CMD_IMI is not set CONFIG_CMD_ASKENV=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e6712ce..81bdd4f 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -5,7 +5,6 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_IMI is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 8e85292..a28d63f 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -7,7 +7,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_EXT_SUPPORT is not set # CONFIG_SPL_I2C_SUPPORT is not set diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 1c2eb2f..8a97fe8 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -10,7 +10,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y # CONFIG_SPL_I2C_SUPPORT is not set CONFIG_CMD_ASKENV=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index e9c61e0..b5a77ad 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -8,7 +8,6 @@ CONFIG_ARMV7_LPAE=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y CONFIG_CMD_SPL=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index ccb308b..0a14544 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -11,7 +11,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_LOGLEVEL=3 -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index d4c8db2..5bfaeae 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -17,7 +17,6 @@ CONFIG_BOOTARGS="console=ttymxc0,115200" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="imx6ul-opos6uldev.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index a7094a6..779f046 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -15,7 +15,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index ee1165a..cebd83d 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -15,7 +15,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV3" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 6218471..4a42d49 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index a802e57..14f4a72 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 736576c..9c10c67 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-porter-u-boot" CONFIG_FIT=y CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 44921d9..ffef69f 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -11,7 +11,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a7795-salvator-x.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index e85d0a4..cec0bc0 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -11,7 +11,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a7795-h3ulcb.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index 6420249..fa2ddf2 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77965-salvator-x.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index e0cf17a..49c8f77 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a7796-salvator-x.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index 5a65982..f24b24c 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a7796-m3ulcb.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 3d421d2..bb20cb3 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77970-eagle.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 99a8089..4c04e5a 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -12,7 +12,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77995-draak.dtb" -CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 50d182f..cba1f00 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -11,7 +11,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200n8 " # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index eebe008..405db98 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index bba0ce7..59d73af 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7794=y CONFIG_TARGET_SILK=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-silk-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index c5cb713..b059972 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -19,7 +19,6 @@ CONFIG_BOOTDELAY=1 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y -CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 5f80232..7f05743 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_arria5_socdk.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 5202f47..e76931d 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socdk.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index d14fceb..f640c0e 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -11,7 +11,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 4736def..2efa550 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de0_nano_soc.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 5a876dd..f145295 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de10_nano.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 33381da..ecef9b4 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -13,7 +13,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de1_soc.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 53b5c34..360f020 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -13,7 +13,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_STACK_R=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index c97dcd0..5712daa 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -13,7 +13,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index f421740..3a7e616 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_sockit.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 3873c2b..d8e93b3 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -12,7 +12,6 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socrates.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index d7df688..264f99d 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -13,7 +13,6 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_sr1500.dtb" -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index a245c54..c9ede59 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -14,7 +14,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index fd7e2dc..5b468ac 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -6,7 +6,6 @@ CONFIG_R8A7790=y CONFIG_TARGET_STOUT=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-stout-u-boot" CONFIG_BOOTDELAY=3 -CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 61c3a7a..f86c648 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -12,7 +12,6 @@ CONFIG_SPL_FAT_SUPPORT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 77038db..beb2335 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -17,7 +17,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyO2,115200n8 noinitrd earlyprintk" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index aa3236c..09573fe 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -11,7 +11,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200n8 " # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 780e6cf..bd8a6ee 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -39,9 +39,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
-/* Make the HW version stuff available in U-Boot env */ -#define CONFIG_VERSION_VARIABLE /* ver environment variable */ - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 42396e8..ba7708c 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -37,9 +37,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
Alex Kiernan
