[PATCH 1/1] tools: value checks in rkcommon_check_params()
Building with -Wtype-limits yields
tools/rkcommon.c: In function ‘rkcommon_check_params’: tools/rkcommon.c:158:27: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] 158 | if (spl_params.init_size < 0) | ^ tools/rkcommon.c:165:28: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] 165 | if (spl_params.boot_size < 0) |
Fix the value checks.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- tools/rkcommon.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 8f281f5901..61c392e27d 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -133,7 +133,7 @@ static int rkcommon_get_aligned_size(struct image_tool_params *params,
int rkcommon_check_params(struct image_tool_params *params) { - int i; + int i, size;
/* * If this is a operation (list or extract), the don't require @@ -153,17 +153,17 @@ int rkcommon_check_params(struct image_tool_params *params) spl_params.boot_file += 1; }
- spl_params.init_size = - rkcommon_get_aligned_size(params, spl_params.init_file); - if (spl_params.init_size < 0) + size = rkcommon_get_aligned_size(params, spl_params.init_file); + if (size < 0) return EXIT_FAILURE; + spl_params.init_size = size;
/* Boot file is optional, and only for back-to-bootrom functionality. */ if (spl_params.boot_file) { - spl_params.boot_size = - rkcommon_get_aligned_size(params, spl_params.boot_file); - if (spl_params.boot_size < 0) + size = rkcommon_get_aligned_size(params, spl_params.boot_file); + if (size < 0) return EXIT_FAILURE; + spl_params.boot_size = size; }
if (spl_params.init_size > rkcommon_get_spl_size(params)) { -- 2.26.2
Hi Heinrich,
Good catch!
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- int i;
int i, size;
- If this is a operation (list or extract), the don't require
-- 2.26.2
Kever Yang
