[U-Boot] [PATCH] rockchip: enable rk322x sysreset driver
The sysreset driver for rk322x is ready but not enabled, add it to Makefile to make sure it's enabled.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/sysreset/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index a5200d3..476d361 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -13,6 +13,7 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3036) += sysreset_rk3036.o endif obj-$(CONFIG_ROCKCHIP_RK3188) += sysreset_rk3188.o +obj-$(CONFIG_ROCKCHIP_RK322X) += sysreset_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) += sysreset_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) += sysreset_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += sysreset_rk3368.o
Reviewed-by: Simon Glass sjg@chromium.org
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Hi Philipp,
Could you share how long will you applied the patches after you review and ack?
I want to use U-Boot v2017.09 as a base for rk3229 and rk3399, but many patches are
still pending in the list.
Kever,
Most of the patches are queued for next (as they came in after the close of the merge window). I will open a next-branch later this week/early next week—around the time that -rc4 comes out.
I generally pick off the patches for the current merge-window around the time the merge window closes and the two weeks after… and I try to open the next-branch around the time of the final -rc (so rebasing to the final release doesn’t get tricky).
Regards, Philipp.
On 5 Sep 2017, at 04:31, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
Thanks,
- Kever
Dr. Philipp Tomsich Theobroma Systems Design und Consulting GmbH Seestadtstrasse 27 (Aspern IQ), A-1220 Wien, Austria Phone: +43 1 2369893-401, Fax: +43 1 2369893-9-401 Cell phone: +43 664 8346109 http://www.theobroma-systems.com http://www.theobroma-systems.com/
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip/next, thanks!
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
