[U-Boot] [PATCH] Makefile: Prioritize external dtb if defined
Prioritize external dtb if its passed via EXT_DTB than the dtb that was built in the tree. With this patch it appends the specified external dtb to the u-boot image.
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com ---
Makefile | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/Makefile b/Makefile index c1af9307b38e..83da41d87d6e 100644 --- a/Makefile +++ b/Makefile @@ -1020,8 +1020,13 @@ MKIMAGEFLAGS_fit-dtb.blob = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ -a 0 -e 0 -E \ $(patsubst %,-b arch/$(ARCH)/dts/%.dtb,$(subst ",,$(CONFIG_OF_LIST))) -d /dev/null
+ifneq ($(EXT_DTB),) +u-boot-fit-dtb.bin: u-boot-nodtb.bin $(EXT_DTB) + $(call if_changed,cat) +else u-boot-fit-dtb.bin: u-boot-nodtb.bin fit-dtb.blob $(call if_changed,cat) +endif
u-boot.bin: u-boot-fit-dtb.bin FORCE $(call if_changed,copy)
Reviewed-by: Simon Glass sjg@chromium.org
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org
The R-Car Gen3 boards (r8a779{5,6}*_salvator-x_defconfig) u-boot.bin size grew from 986 kiB to 1240 kiB with this patch, rendering the boards unbootable. I expect there to be more such cases, so please revert until there's new version which has this fixed.
I must have messed something up when re-adjusting this to apply to top of tree. I'll revert this, thanks for reporting. Michal, please rebase the original patch and resend, thanks!
My guess is that it has to do with the LZO compression of the DTBs on Gen3 , that fit-blob.itb is probably appended uncompressed or something.
This patch is already applied to the tree (commit below). It means you please revert what was added by: 3eaf6dcd9362b56e3217559401287dd8fa35b5b2
Thanks, Michal
commit c8c5e2b84d5d928472b68a51854b727ee90295b2 Author: Michal Simek michal.simek@xilinx.com AuthorDate: Sat Mar 23 11:13:00 2019 +0530 Commit: Michal Simek michal.simek@xilinx.com CommitDate: Tue Apr 16 11:52:02 2019 +0200
Thanks, Michal
Makefile: Prioritize external dtb if defined Prioritize external dtb if its passed via EXT_DTB than the dtb that was built in the tree. With this patch it appends the specified external dtb to the u-boot image. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu
So I really did step in it, sigh. Revert pushed this morning.
Michal Simek
