[U-Boot] SPL and FIT images
I'm looking into the FIT support in the SPL, because we are planning to load bootloader from a filesystem (on a MMC device); the SPL will be stored in a write-protected SPI flash. To make sure that a user does not accidentally put a wrong bootloader image on the filesystem, we would like to do some kind of compatiblity checking. I guess this can be done with the FIT image and its compatibility node. Looking into the code I found out, that FIT images only seems to be supported when the bootloader is loaded from raw MMC.
Simon, since this code is from you, might I ask, why you didn't put it into the common spl.c (spl_parse_image_header(), etc) so it could be used for all other methods, too? I just want to make sure, there is no reason not to do it for our case.
-michael
Hi Michael,
FIT support for other boot media was recently posted. Links below:
Fat FS: http://patchwork.ozlabs.org/patch/618400/ http://patchwork.ozlabs.org/patch/618403/ http://patchwork.ozlabs.org/patch/618405/
SPI: http://patchwork.ozlabs.org/patch/606959/
NAND: http://patchwork.ozlabs.org/patch/609326/
UART: http://patchwork.ozlabs.org/patch/623918/ http://patchwork.ozlabs.org/patch/623919/ http://patchwork.ozlabs.org/patch/623920/
Let me know if you need more info.
Thanks and regards, Lokesh
-michael _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Am 2016-05-19 14:05, schrieb Lokesh Vutla:
Hi Michael,
Ah, thanks :)
-michael
Lokesh Vutla
michael@walle.cc
