[U-Boot] [PATCH 1/2] Blackfin: update anomaly lists to latest sheets
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/include/asm/mach-bf518/anomaly.h | 2 ++ arch/blackfin/include/asm/mach-bf527/anomaly.h | 4 +++- arch/blackfin/include/asm/mach-bf533/anomaly.h | 7 ++++++- arch/blackfin/include/asm/mach-bf537/anomaly.h | 7 ++++++- arch/blackfin/include/asm/mach-bf538/anomaly.h | 7 +++++-- arch/blackfin/include/asm/mach-bf548/anomaly.h | 7 ++++--- arch/blackfin/include/asm/mach-bf561/anomaly.h | 11 +++++++++-- 7 files changed, 35 insertions(+), 10 deletions(-)
diff --git a/arch/blackfin/include/asm/mach-bf518/anomaly.h b/arch/blackfin/include/asm/mach-bf518/anomaly.h index d808b45..24918c5 100644 --- a/arch/blackfin/include/asm/mach-bf518/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf518/anomaly.h @@ -88,6 +88,8 @@ #define ANOMALY_05000477 (1) /* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ #define ANOMALY_05000481 (1) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000099 (0) diff --git a/arch/blackfin/include/asm/mach-bf527/anomaly.h b/arch/blackfin/include/asm/mach-bf527/anomaly.h index 9358afa..72a6369 100644 --- a/arch/blackfin/include/asm/mach-bf527/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf527/anomaly.h @@ -12,7 +12,7 @@
/* This file should be up to date with: * - Revision E, 03/15/2010; ADSP-BF526 Blackfin Processor Anomaly List - * - Revision G, 08/25/2009; ADSP-BF527 Blackfin Processor Anomaly List + * - Revision H, 04/29/2010; ADSP-BF527 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -220,6 +220,8 @@ #define ANOMALY_05000483 (1) /* PLL_CTL Change Using bfrom_SysControl() Can Result in Processor Overclocking */ #define ANOMALY_05000485 (_ANOMALY_BF526_BF527(< 2, < 3)) +/* The CODEC Zero-Cross Detect Feature is not Functional */ +#define ANOMALY_05000487 (1) /* IFLUSH sucks at life */ #define ANOMALY_05000491 (1)
diff --git a/arch/blackfin/include/asm/mach-bf533/anomaly.h b/arch/blackfin/include/asm/mach-bf533/anomaly.h index 78f8721..30e0eba 100644 --- a/arch/blackfin/include/asm/mach-bf533/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf533/anomaly.h @@ -11,7 +11,7 @@ */
/* This file should be up to date with: - * - Revision E, 09/18/2008; ADSP-BF531/BF532/BF533 Blackfin Processor Anomaly List + * - Revision F, 05/25/2010; ADSP-BF531/BF532/BF533 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -206,6 +206,10 @@ #define ANOMALY_05000443 (1) /* False Hardware Error when RETI Points to Invalid Memory */ #define ANOMALY_05000461 (1) +/* Synchronization Problem at Startup May Cause SPORT Transmit Channels to Misalign */ +#define ANOMALY_05000462 (1) +/* Boot Failure When SDRAM Control Signals Toggle Coming Out Of Reset */ +#define ANOMALY_05000471 (1) /* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ #define ANOMALY_05000473 (1) /* Possible Lockup Condition whem Modifying PLL from External Memory */ @@ -357,6 +361,7 @@ #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000440 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) #define ANOMALY_05000456 (0) diff --git a/arch/blackfin/include/asm/mach-bf537/anomaly.h b/arch/blackfin/include/asm/mach-bf537/anomaly.h index 43df6af..d3a2966 100644 --- a/arch/blackfin/include/asm/mach-bf537/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf537/anomaly.h @@ -11,7 +11,7 @@ */
/* This file should be up to date with: - * - Revision D, 09/18/2008; ADSP-BF534/ADSP-BF536/ADSP-BF537 Blackfin Processor Anomaly List + * - Revision E, 05/25/2010; ADSP-BF534/ADSP-BF536/ADSP-BF537 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -160,12 +160,16 @@ #define ANOMALY_05000443 (1) /* False Hardware Error when RETI Points to Invalid Memory */ #define ANOMALY_05000461 (1) +/* Synchronization Problem at Startup May Cause SPORT Transmit Channels to Misalign */ +#define ANOMALY_05000462 (1) /* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ #define ANOMALY_05000473 (1) /* Possible Lockup Condition whem Modifying PLL from External Memory */ #define ANOMALY_05000475 (1) /* TESTSET Instruction Cannot Be Interrupted */ #define ANOMALY_05000477 (1) +/* Multiple Simultaneous Urgent DMA Requests May Cause DMA System Instability */ +#define ANOMALY_05000480 (__SILICON_REVISION__ < 3) /* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ #define ANOMALY_05000481 (1) /* IFLUSH sucks at life */ @@ -211,6 +215,7 @@ #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000440 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) #define ANOMALY_05000456 (0) diff --git a/arch/blackfin/include/asm/mach-bf538/anomaly.h b/arch/blackfin/include/asm/mach-bf538/anomaly.h index e22d23c..4bc1f4a 100644 --- a/arch/blackfin/include/asm/mach-bf538/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf538/anomaly.h @@ -11,8 +11,8 @@ */
/* This file should be up to date with: - * - Revision H, 07/10/2009; ADSP-BF538/BF538F Blackfin Processor Anomaly List - * - Revision M, 07/10/2009; ADSP-BF539/BF539F Blackfin Processor Anomaly List + * - Revision I, 05/25/2010; ADSP-BF538/BF538F Blackfin Processor Anomaly List + * - Revision N, 05/25/2010; ADSP-BF539/BF539F Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -142,6 +142,8 @@ #define ANOMALY_05000477 (1) /* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ #define ANOMALY_05000481 (1) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000099 (0) @@ -184,6 +186,7 @@ #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000440 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) #define ANOMALY_05000456 (0) diff --git a/arch/blackfin/include/asm/mach-bf548/anomaly.h b/arch/blackfin/include/asm/mach-bf548/anomaly.h index 7bda09c..b9f4ecc 100644 --- a/arch/blackfin/include/asm/mach-bf548/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf548/anomaly.h @@ -11,7 +11,7 @@ */
/* This file should be up to date with: - * - Revision I, 07/23/2009; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List + * - Revision J, 06/03/2010; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -110,8 +110,6 @@ #define ANOMALY_05000379 (1) /* 8-Bit NAND Flash Boot Mode Not Functional */ #define ANOMALY_05000382 (__SILICON_REVISION__ < 1) -/* Some ATAPI Modes Are Not Functional */ -#define ANOMALY_05000383 (1) /* Boot from OTP Memory Not Functional */ #define ANOMALY_05000385 (__SILICON_REVISION__ < 1) /* bfrom_SysControl() Firmware Routine Not Functional */ @@ -218,6 +216,8 @@ #define ANOMALY_05000481 (1) /* Possible USB Data Corruption When Multiple Endpoints Are Accessed by the Core */ #define ANOMALY_05000483 (1) +/* DDR Trim May Not Be Performed for Certain VLEV Values in OTP Page PBS00L */ +#define ANOMALY_05000484 (__SILICON_REVISION__ < 3) /* PLL_CTL Change Using bfrom_SysControl() Can Result in Processor Overclocking */ #define ANOMALY_05000485 (__SILICON_REVISION__ >= 2) /* IFLUSH sucks at life */ @@ -272,6 +272,7 @@ #define ANOMALY_05000412 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000440 (0) #define ANOMALY_05000475 (0)
#endif diff --git a/arch/blackfin/include/asm/mach-bf561/anomaly.h b/arch/blackfin/include/asm/mach-bf561/anomaly.h index 4c108c9..9313c27 100644 --- a/arch/blackfin/include/asm/mach-bf561/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf561/anomaly.h @@ -11,7 +11,7 @@ */
/* This file should be up to date with: - * - Revision Q, 11/07/2008; ADSP-BF561 Blackfin Processor Anomaly List + * - Revision R, 05/25/2010; ADSP-BF561 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -286,12 +286,18 @@ #define ANOMALY_05000428 (__SILICON_REVISION__ > 3) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) +/* SCKELOW Feature Is Not Functional */ +#define ANOMALY_05000458 (1) /* False Hardware Error when RETI Points to Invalid Memory */ #define ANOMALY_05000461 (1) +/* Synchronization Problem at Startup May Cause SPORT Transmit Channels to Misalign */ +#define ANOMALY_05000462 (1) +/* Boot Failure When SDRAM Control Signals Toggle Coming Out Of Reset */ +#define ANOMALY_05000471 (1) /* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ #define ANOMALY_05000473 (1) /* Possible Lockup Condition whem Modifying PLL from External Memory */ -#define ANOMALY_05000475 (__SILICON_REVISION__ < 4) +#define ANOMALY_05000475 (1) /* TESTSET Instruction Cannot Be Interrupted */ #define ANOMALY_05000477 (1) /* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ @@ -316,6 +322,7 @@ #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000440 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) #define ANOMALY_05000456 (0)
We cannot rely on the syscontrol rom func to program PLL_DIV with anomaly 05000440 is in effect, so manually program the MMR when necessary.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/initcode.c | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index 007f5ce..433d477 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -391,7 +391,9 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs)
/* Always programming PLL_LOCKCNT avoids Anomaly 05000430 */ ADI_SYSCTRL_VALUES memory_settings; - uint32_t actions = SYSCTRL_WRITE | SYSCTRL_PLLCTL | SYSCTRL_PLLDIV | SYSCTRL_LOCKCNT; + uint32_t actions = SYSCTRL_WRITE | SYSCTRL_PLLCTL | SYSCTRL_LOCKCNT; + if (!ANOMALY_05000440) + actions |= SYSCTRL_PLLDIV; if (CONFIG_HAS_VR) { actions |= SYSCTRL_VRCTL; if (CONFIG_VR_CTL_VAL & FREQ_MASK) @@ -410,6 +412,8 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs) serial_putc('e'); bfrom_SysControl(actions, &memory_settings, NULL); serial_putc('f'); + if (ANOMALY_05000440) + bfin_write_PLL_DIV(CONFIG_PLL_DIV_VAL); #if ANOMALY_05000432 bfin_write_SIC_IWR1(-1); #endif
Hello.
Signed-off-by: Mike Frysingervapier@gentoo.org
An empty line is needed here...
if (CONFIG_HAS_VR) { actions |= SYSCTRL_VRCTL; if (CONFIG_VR_CTL_VAL& FREQ_MASK)actions |= SYSCTRL_PLLDIV;
WBR, Sergei
Mike Frysinger
Sergei Shtylyov
