[U-Boot] [PATCH] MIPS: asm/errno.h: switch to asm-generic/errno.h
This fixes several warnings like
In file included from ./u-boot/include/linux/mtd/mtd.h:13:0, from env_onenand.c:37: ./u-boot/build/vct_platinumavc_onenand_small/include2/asm/errno.h:52:0: warning: "ENOMSG" redefined [enabled by default]
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/include/asm/errno.h | 144 +----------------------------------------- 1 file changed, 1 insertion(+), 143 deletions(-)
diff --git a/arch/mips/include/asm/errno.h b/arch/mips/include/asm/errno.h index 1665a63..4c82b50 100644 --- a/arch/mips/include/asm/errno.h +++ b/arch/mips/include/asm/errno.h @@ -1,143 +1 @@ -/* - * This file is subject to the terms and conditions of the GNU General Public - * License. See the file "COPYING" in the main directory of this archive - * for more details. - * - * Copyright (C) 1995, 1999, 2001, 2002 by Ralf Baechle - */ -#ifndef _ASM_MIPS_ERRNO_H -#define _ASM_MIPS_ERRNO_H - -/* - * These first 34 error codes are from Linux 2.6, <asm-generic/errno-base.h> - */ -#define EPERM 1 /* Operation not permitted */ -#define ENOENT 2 /* No such file or directory */ -#define ESRCH 3 /* No such process */ -#define EINTR 4 /* Interrupted system call */ -#define EIO 5 /* I/O error */ -#define ENXIO 6 /* No such device or address */ -#define E2BIG 7 /* Argument list too long */ -#define ENOEXEC 8 /* Exec format error */ -#define EBADF 9 /* Bad file number */ -#define ECHILD 10 /* No child processes */ -#define EAGAIN 11 /* Try again */ -#define ENOMEM 12 /* Out of memory */ -#define EACCES 13 /* Permission denied */ -#define EFAULT 14 /* Bad address */ -#define ENOTBLK 15 /* Block device required */ -#define EBUSY 16 /* Device or resource busy */ -#define EEXIST 17 /* File exists */ -#define EXDEV 18 /* Cross-device link */ -#define ENODEV 19 /* No such device */ -#define ENOTDIR 20 /* Not a directory */ -#define EISDIR 21 /* Is a directory */ -#define EINVAL 22 /* Invalid argument */ -#define ENFILE 23 /* File table overflow */ -#define EMFILE 24 /* Too many open files */ -#define ENOTTY 25 /* Not a typewriter */ -#define ETXTBSY 26 /* Text file busy */ -#define EFBIG 27 /* File too large */ -#define ENOSPC 28 /* No space left on device */ -#define ESPIPE 29 /* Illegal seek */ -#define EROFS 30 /* Read-only file system */ -#define EMLINK 31 /* Too many links */ -#define EPIPE 32 /* Broken pipe */ -#define EDOM 33 /* Math argument out of domain of func */ -#define ERANGE 34 /* Math result not representable */ - -/* - * These error numbers are intended to be MIPS ABI compatible - */ -#define ENOMSG 35 /* No message of desired type */ -#define EIDRM 36 /* Identifier removed */ -#define ECHRNG 37 /* Channel number out of range */ -#define EL2NSYNC 38 /* Level 2 not synchronized */ -#define EL3HLT 39 /* Level 3 halted */ -#define EL3RST 40 /* Level 3 reset */ -#define ELNRNG 41 /* Link number out of range */ -#define EUNATCH 42 /* Protocol driver not attached */ -#define ENOCSI 43 /* No CSI structure available */ -#define EL2HLT 44 /* Level 2 halted */ -#define EDEADLK 45 /* Resource deadlock would occur */ -#define ENOLCK 46 /* No record locks available */ -#define EBADE 50 /* Invalid exchange */ -#define EBADR 51 /* Invalid request descriptor */ -#define EXFULL 52 /* Exchange full */ -#define ENOANO 53 /* No anode */ -#define EBADRQC 54 /* Invalid request code */ -#define EBADSLT 55 /* Invalid slot */ -#define EDEADLOCK 56 /* File locking deadlock error */ -#define EBFONT 59 /* Bad font file format */ -#define ENOSTR 60 /* Device not a stream */ -#define ENODATA 61 /* No data available */ -#define ETIME 62 /* Timer expired */ -#define ENOSR 63 /* Out of streams resources */ -#define ENONET 64 /* Machine is not on the network */ -#define ENOPKG 65 /* Package not installed */ -#define EREMOTE 66 /* Object is remote */ -#define ENOLINK 67 /* Link has been severed */ -#define EADV 68 /* Advertise error */ -#define ESRMNT 69 /* Srmount error */ -#define ECOMM 70 /* Communication error on send */ -#define EPROTO 71 /* Protocol error */ -#define EDOTDOT 73 /* RFS specific error */ -#define EMULTIHOP 74 /* Multihop attempted */ -#define EBADMSG 77 /* Not a data message */ -#define ENAMETOOLONG 78 /* File name too long */ -#define EOVERFLOW 79 /* Value too large for defined data type */ -#define ENOTUNIQ 80 /* Name not unique on network */ -#define EBADFD 81 /* File descriptor in bad state */ -#define EREMCHG 82 /* Remote address changed */ -#define ELIBACC 83 /* Can not access a needed shared library */ -#define ELIBBAD 84 /* Accessing a corrupted shared library */ -#define ELIBSCN 85 /* .lib section in a.out corrupted */ -#define ELIBMAX 86 /* Attempting to link in too many shared libraries */ -#define ELIBEXEC 87 /* Cannot exec a shared library directly */ -#define EILSEQ 88 /* Illegal byte sequence */ -#define ENOSYS 89 /* Function not implemented */ -#define ELOOP 90 /* Too many symbolic links encountered */ -#define ERESTART 91 /* Interrupted system call should be restarted */ -#define ESTRPIPE 92 /* Streams pipe error */ -#define ENOTEMPTY 93 /* Directory not empty */ -#define EUSERS 94 /* Too many users */ -#define ENOTSOCK 95 /* Socket operation on non-socket */ -#define EDESTADDRREQ 96 /* Destination address required */ -#define EMSGSIZE 97 /* Message too long */ -#define EPROTOTYPE 98 /* Protocol wrong type for socket */ -#define ENOPROTOOPT 99 /* Protocol not available */ -#define EPROTONOSUPPORT 120 /* Protocol not supported */ -#define ESOCKTNOSUPPORT 121 /* Socket type not supported */ -#define EOPNOTSUPP 122 /* Operation not supported on transport endpoint */ -#define EPFNOSUPPORT 123 /* Protocol family not supported */ -#define EAFNOSUPPORT 124 /* Address family not supported by protocol */ -#define EADDRINUSE 125 /* Address already in use */ -#define EADDRNOTAVAIL 126 /* Cannot assign requested address */ -#define ENETDOWN 127 /* Network is down */ -#define ENETUNREACH 128 /* Network is unreachable */ -#define ENETRESET 129 /* Network dropped connection because of reset */ -#define ECONNABORTED 130 /* Software caused connection abort */ -#define ECONNRESET 131 /* Connection reset by peer */ -#define ENOBUFS 132 /* No buffer space available */ -#define EISCONN 133 /* Transport endpoint is already connected */ -#define ENOTCONN 134 /* Transport endpoint is not connected */ -#define EUCLEAN 135 /* Structure needs cleaning */ -#define ENOTNAM 137 /* Not a XENIX named type file */ -#define ENAVAIL 138 /* No XENIX semaphores available */ -#define EISNAM 139 /* Is a named type file */ -#define EREMOTEIO 140 /* Remote I/O error */ -#define EINIT 141 /* Reserved */ -#define EREMDEV 142 /* Error 142 */ -#define ESHUTDOWN 143 /* Cannot send after transport endpoint shutdown */ -#define ETOOMANYREFS 144 /* Too many references: cannot splice */ -#define ETIMEDOUT 145 /* Connection timed out */ -#define ECONNREFUSED 146 /* Connection refused */ -#define EHOSTDOWN 147 /* Host is down */ -#define EHOSTUNREACH 148 /* No route to host */ -#define EWOULDBLOCK EAGAIN /* Operation would block */ -#define EALREADY 149 /* Operation already in progress */ -#define EINPROGRESS 150 /* Operation now in progress */ -#define ESTALE 151 /* Stale NFS file handle */ -#define ECANCELED 158 /* AIO operation canceled */ - -#endif /* _ASM_MIPS_ERRNO_H */ +#include <asm-generic/errno.h>
Daniel Schwierzeck
