[U-Boot] [PATCH v7] powerpc/mpc83xx: Add 33.33MHz support for mpc8360emds
The new MPC8360EMDS board changes the oscillator to 33.33MHz in order to support QE 500MHz since 2008.
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com CC: Kim Phillips kim.phillips@freescale.com --- cahnges for v2: - fix multiline comment wrong changes for v3: - change the oscillator to 33330000, not 33300000 changes for v4: - add the mandatory history of changes changes for v5: - move the code to platform file from lib/board.c - add 2011 copyright changes for v6: - split into two patch - add the CLKIN33 option for 33.33MHz oscillator - add the readme for CLKIN33 option - add CC changes for v7: - shorter the config names to _33 for 33.33MHz oscillator - change the default to _66 option for 66MHz oscillator - modify the README
boards.cfg | 15 ++++++++++----- doc/README.mpc8360emds | 18 +++++++++++++----- include/configs/MPC8360EMDS.h | 27 +++++++++++++++++++++++++++ 3 files changed, 50 insertions(+), 10 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 90dab8b..0f033ac 100644 --- a/boards.cfg +++ b/boards.cfg @@ -419,11 +419,16 @@ MPC8349EMDS powerpc mpc83xx mpc8349emds freesca MPC8349ITX powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX MPC8349ITXGP powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000 MPC8349ITX_LOWBOOT powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX,SYS_TEXT_BASE=0xFE000000 -MPC8360EMDS powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS: -MPC8360EMDS_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC8360EMDS_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:PCI,PCI_33M,PQ_MDS_PIB=1 -MPC8360EMDS_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:PCI,PCI_66M,PQ_MDS_PIB=1 -MPC8360EMDS_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:PCI,PCISLAVE +MPC8360EMDS_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ +MPC8360EMDS_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ +MPC8360EMDS_66_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 +MPC8360EMDS_33_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 +MPC8360EMDS_66_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 +MPC8360EMDS_33_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 +MPC8360EMDS_66_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 +MPC8360EMDS_33_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 +MPC8360EMDS_66_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE +MPC8360EMDS_33_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCISLAVE MPC8360ERDK powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK MPC8360ERDK_33 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK:CLKIN_33MHZ MPC8360ERDK_66 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK diff --git a/doc/README.mpc8360emds b/doc/README.mpc8360emds index d65a2a4..b20c9f6 100644 --- a/doc/README.mpc8360emds +++ b/doc/README.mpc8360emds @@ -87,28 +87,36 @@ Freescale MPC8360EMDS Board
4. Compilation
+ MPC8360EMDS shipped with 33.33MHz or 66MHz oscillator(check U41 chip). + Assuming you're using BASH shell:
export CROSS_COMPILE=your-cross-compile-prefix cd u-boot make distclean - make MPC8360EMDS_config + make MPC8360EMDS_XX_config make
- MPC8360 support PCI in host and slave mode. + MPC8360EMDS support ATM, PCI in host and slave mode. + + To make u-boot support ATM : + 1) Make MPC8360EMDS_XX_ATM_config
To make u-boot support PCI host 66M : 1) DIP SW support PCI mode as described in Section 1.1. - 2) Make MPC8360EMDS_HOST_66_config + 2) Make MPC8360EMDS_XX_HOST_66_config
To make u-boot support PCI host 33M : 1) DIP SW setting is similar as Section 1.1, except for SW3[4] is 1 - 2) Make MPC8360EMDS_HOST_33_config + 2) Make MPC8360EMDS_XX_HOST_33_config
To make u-boot support PCI slave 66M : 1) DIP SW setting is similar as Section 1.1, except for SW9[3] is 1 - 2) Make MPC8360EMDS_SLAVE_config + 2) Make MPC8360EMDS_XX_SLAVE_config
+ (where XX is: + 33 - 33.33MHz oscillator + 66 - 66MHz oscillator)
5. Downloading and Flashing Images
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index cfba894..3221023 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -39,6 +39,18 @@ /* * System Clock Setup */ +#ifdef CONFIG_CLKIN_33MHZ +#ifdef CONFIG_PCISLAVE +#define CONFIG_83XX_PCICLK 33330000 /* in HZ */ +#else +#define CONFIG_83XX_CLKIN 33330000 /* in Hz */ +#endif + +#ifndef CONFIG_SYS_CLK_FREQ +#define CONFIG_SYS_CLK_FREQ 33330000 +#endif + +#elif defined(CONFIG_CLKIN_66MHZ) #ifdef CONFIG_PCISLAVE #define CONFIG_83XX_PCICLK 66000000 /* in HZ */ #else @@ -48,10 +60,24 @@ #ifndef CONFIG_SYS_CLK_FREQ #define CONFIG_SYS_CLK_FREQ 66000000 #endif +#else +#error Unknown oscillator frequency. +#endif
/* * Hardware Reset Configuration Word */ +#ifdef CONFIG_CLKIN_33MHZ +#define CONFIG_SYS_HRCW_LOW (\ + HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ + HRCWL_DDR_TO_SCB_CLK_1X1 |\ + HRCWL_CSB_TO_CLKIN_8X1 |\ + HRCWL_VCO_1X2 |\ + HRCWL_CE_PLL_VCO_DIV_4 |\ + HRCWL_CE_PLL_DIV_1X1 |\ + HRCWL_CE_TO_PLL_1X15 |\ + HRCWL_CORE_TO_CSB_2X1) +#elif defined(CONFIG_CLKIN_66MHZ) #define CONFIG_SYS_HRCW_LOW (\ HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ HRCWL_DDR_TO_SCB_CLK_1X1 |\ @@ -61,6 +87,7 @@ HRCWL_CE_PLL_DIV_1X1 |\ HRCWL_CE_TO_PLL_1X6 |\ HRCWL_CORE_TO_CSB_2X1) +#endif
#ifdef CONFIG_PCISLAVE #define CONFIG_SYS_HRCW_HIGH (\
Applied to u-boot-mpc83xx/master, thanks.
Kim
Kim Phillips
