[U-Boot] [PATCH] ARM: omap3_logic_defconfig: Convert to DM_SPL
The OF_CONTROL and OF_PLATDATA are not really useful without DM. This patch supports DM_SPL, but it requires manual references both Serial and MMC.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index fbad89b696..620423bbc8 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -24,6 +24,7 @@ #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> +#include <asm/omap_mmc.h> #include <asm/mach-types.h> #include <linux/mtd/rawnand.h> #include <asm/omap_musb.h> @@ -39,6 +40,36 @@
DECLARE_GLOBAL_DATA_PTR;
+/* This is only needed until SPL gets OF support */ +#ifdef CONFIG_SPL_BUILD +static const struct ns16550_platdata omap3logic_serial = { + .base = OMAP34XX_UART1, + .reg_shift = 2, + .clock = V_NS16550_CLK, + .fcr = UART_FCR_DEFVAL, +}; + +U_BOOT_DEVICE(omap3logic_uart) = { + "ns16550_serial", + &omap3logic_serial +}; + +static const struct omap_hsmmc_plat omap3_logic_mmc0_platdata = { + .base_addr = (struct hsmmc *)OMAP_HSMMC1_BASE, + .cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_4BIT, + .cfg.f_min = 400000, + .cfg.f_max = 52000000, + .cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195, + .cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +U_BOOT_DEVICE(am335x_mmc0) = { + .name = "omap_hsmmc", + .platdata = &omap3_logic_mmc0_platdata, +}; + +#endif + /* * two dimensional array of strucures containining board name and Linux * machine IDs; row it selected based on CPU column is slected based diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 1807e280a4..c6acfab602 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -1,11 +1,11 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y +# CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y -CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set @@ -29,9 +29,11 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1792k(u-boot),128k(spl- CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" CONFIG_SPL_OF_PLATDATA=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_DM_I2C=y @@ -43,10 +45,10 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y -CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x08000000 CONFIG_SMC911X_32_BIT=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y
Adam Ford
