[PATCH v2] disk: Use a helper function to reduce duplication
Reduce the duplicated code slightly by using a helper function to handle the common code.
This reduces the code size very slightly.
Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Rebase to -next
disk/disk-uclass.c | 46 +++++++++++++++++++++++++--------------------- 1 file changed, 25 insertions(+), 21 deletions(-)
diff --git a/disk/disk-uclass.c b/disk/disk-uclass.c index d32747e2242d..7f1fd80b2248 100644 --- a/disk/disk-uclass.c +++ b/disk/disk-uclass.c @@ -65,26 +65,38 @@ int part_create_block_devices(struct udevice *blk_dev) return 0; }
+static int blk_part_setup(struct udevice *dev, lbaint_t *startp, + lbaint_t blkcnt) +{ + struct disk_part *part; + + part = dev_get_uclass_plat(dev); + if (*startp >= part->gpt_part_info.size) + return -E2BIG; + + if (*startp + blkcnt > part->gpt_part_info.size) + blkcnt = part->gpt_part_info.size - *startp; + *startp += part->gpt_part_info.start; + + return 0; +} + static ulong part_blk_read(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, void *buffer) { struct udevice *parent; - struct disk_part *part; const struct blk_ops *ops; + int ret;
parent = dev_get_parent(dev); ops = blk_get_ops(parent); if (!ops->read) return -ENOSYS;
- part = dev_get_uclass_plat(dev); - if (start >= part->gpt_part_info.size) + ret = blk_part_setup(dev, &start, blkcnt); + if (ret) return 0;
- if ((start + blkcnt) > part->gpt_part_info.size) - blkcnt = part->gpt_part_info.size - start; - start += part->gpt_part_info.start; - return ops->read(parent, start, blkcnt, buffer); }
@@ -92,22 +104,18 @@ static ulong part_blk_write(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, const void *buffer) { struct udevice *parent; - struct disk_part *part; const struct blk_ops *ops; + int ret;
parent = dev_get_parent(dev); ops = blk_get_ops(parent); if (!ops->write) return -ENOSYS;
- if ((start + blkcnt) > part->gpt_part_info.size) - blkcnt = part->gpt_part_info.size - start; - start += part->gpt_part_info.start; - return ops->write(parent, start, blkcnt, buffer); }
@@ -115,22 +123,18 @@ static ulong part_blk_erase(struct udevice *dev, lbaint_t start, lbaint_t blkcnt) { struct udevice *parent; - struct disk_part *part; const struct blk_ops *ops; + int ret;
parent = dev_get_parent(dev); ops = blk_get_ops(parent); if (!ops->erase) return -ENOSYS;
- if ((start + blkcnt) > part->gpt_part_info.size) - blkcnt = part->gpt_part_info.size - start; - start += part->gpt_part_info.start; - return ops->erase(parent, start, blkcnt); }
Hi Simon,
Patch looks good, but isn't the new function name a bit misleading? Something like blk_part_find_start() sounds a bit more descriptive, or am I missing something?
Cheers /Ilias
Changes in v2:
- Rebase to -next
lbaint_t blkcnt)
- if (*startp >= part->gpt_part_info.size)
return -E2BIG;
- if (*startp + blkcnt > part->gpt_part_info.size)
- *startp += part->gpt_part_info.start;
int ret;
- ret = blk_part_setup(dev, &start, blkcnt);
- if (ret) return 0;
int ret;
int ret;
-- 2.40.0.rc1.284.g88254d51c5-goog
On Mon, Mar 20, 2023 at 09:31:58AM +0200, Ilias Apalodimas wrote:
Hi Simon,
I don't think that the helper function works as my original code does.
Cheers /Ilias
Changes in v2:
- Rebase to -next
lbaint_t blkcnt)
return -E2BIG;
int ret;
We cannot read out more blocks than the size of the partition.
So blkcnt must also be adjusted, otherwise we may see extra blocks beyond the partition boundary.
-Takahiro Akashi
int ret;
int ret;
Applied to u-boot/next, thanks!
Hi Tom,
I think I said nak against this patch. https://lists.denx.de/pipermail/u-boot/2023-March/512677.html
-Takahiro Akashi
-- Tom
On Mon, 3 Apr 2023, 12:06 AKASHI Takahiro, takahiro.akashi@linaro.org wrote:
Hi Tom,
handle
the common code.
Yes,sorry I did'nt get back to it. If this applied I wonder if there is test coverage missing. Do you think you could add a test for it?
I am afk so cannot send a revert for a few days,if someone else can?
-Takahiro Akashi
-- Tom
On Mon, Apr 03, 2023 at 09:06:13AM +0900, AKASHI Takahiro wrote:
Hi Tom,
Ah I missed that, sorry, reverting.
AKASHI Takahiro
Ilias Apalodimas
