[U-Boot-Users] [patch #9/11] VLAN/CDP networking support.
Hello
The following patch adds networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol).
You control the sending/receiving of VLAN tagged packets with the "vlan" environmental variable. When not present no tagging is performed.
CDP is used mainly to discover your device VLAN(s) when connected to a Cisco switch.
Note: In order to enable CDP support a small change is needed in the networking driver. You have to enable reception of the 01:00:0c:cc:cc:cc mac address which is a multicast address.
Various defines control CDP; see the README section.
Regards
Pantelis
README | 63 +++++ common/cmd_net.c | 55 ++++ include/cmd_confdefs.h | 4 include/net.h | 52 ++++ net/bootp.c | 6 net/eth.c | 50 ++++ net/net.c | 577 ++++++++++++++++++++++++++++++++++++++++++++++--- net/nfs.c | 2 net/rarp.c | 5 net/tftp.c | 2 10 files changed, 775 insertions(+), 41 deletions(-)
diff -ruNb u-boot-original/README u-boot-net/README --- u-boot-original/README 2004-03-30 14:37:28.395972064 +0300 +++ u-boot-net/README 2004-03-30 16:48:11.265674640 +0300 @@ -581,6 +581,7 @@ CFG_CMD_USB * USB support CFG_CMD_VFD * VFD support (TRAB) CFG_CMD_BSP * Board SPecific functions + CFG_CMD_CDP * Cisco Discover Protocol support ----------------------------------------------- CFG_CMD_ALL all
@@ -949,6 +950,48 @@ environment variable is passed as option 12 to the DHCP server.
+ - CDP Options: + CONFIG_CDP_DEVICE_ID + + The device id used in CDP trigger frames. + + CONFIG_CDP_DEVICE_ID_PREFIX + + A two character string which is prefixed to the MAC address + of the device. + + CONFIG_CDP_PORT_ID + + A printf format string which contains the ascii name of + the port. Normally is set to "eth%d" which sets + eth0 for the first ethernet, eth1 for the second etc. + + CONFIG_CDP_CAPABILITIES + + A 32bit integer which indicates the device capabilities; + 0x00000010 for a normal host which does not forwards. + + CONFIG_CDP_VERSION + + An ascii string containing the version of the software. + + CONFIG_CDP_PLATFORM + + An ascii string containing the name of the platform. + + CONFIG_CDP_TRIGGER + + A 32bit integer sent on the trigger. + + CONFIG_CDP_POWER_CONSUMPTION + + A 16bit integer containing the power consumption of the + device in .1 of milliwatts. + + CONFIG_CDP_APPLIANCE_VLAN_TYPE + + A byte containing the id of the VLAN. + - Status LED: CONFIG_STATUS_LED
Several configurations allow to display the current @@ -2182,6 +2225,26 @@
bootstopkey - see CONFIG_AUTOBOOT_STOP_STR
+ ethprime - When CONFIG_NET_MULTI is enabled controls which + interface is used first. + + ethact - When CONFIG_NET_MULTI is enabled controls which + interface is currently active. For example you + can do the following + + => setenv ethact FEC ETHERNET + => ping 192.168.0.1 # traffic sent on FEC ETHERNET + => setenv ethact SCC ETHERNET + => ping 10.0.0.1 # traffic sent on SCC ETHERNET + + netretry - When set to "no" each network operation will + either succeed or fail without retrying. + Useful on scripts which control the retry operation + themselves. + + vlan - When set to a value < 4095 the traffic over + ethernet is encapsulated/received over 802.1q + VLAN tagged frames.
The following environment variables may be used and automatically updated by the network boot commands ("bootp" and "rarpboot"), diff -ruNb u-boot-original/common/cmd_net.c u-boot-net/common/cmd_net.c --- u-boot-original/common/cmd_net.c 2004-03-30 14:37:28.664931176 +0300 +++ u-boot-net/common/cmd_net.c 2004-03-30 15:41:00.406458384 +0300 @@ -96,7 +96,7 @@
static void netboot_update_env(void) { - char tmp[16] ; + char tmp[22] ;
if (NetOurGatewayIP) { ip_to_string (NetOurGatewayIP, tmp); @@ -139,6 +139,16 @@ if (NetOurNISDomain[0]) setenv("domain", NetOurNISDomain);
+ if (ntohs(NetOurVLAN) != (ushort)-1) { + VLAN_to_string(NetOurVLAN, tmp); + setenv("vlan", tmp); + } + + if (ntohs(NetOurNativeVLAN) != (ushort)-1) { + VLAN_to_string(NetOurNativeVLAN, tmp); + setenv("vlan", tmp); + } + } static int netboot_common (int proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) @@ -238,4 +248,47 @@ ); #endif /* CFG_CMD_PING */
+#if (CONFIG_COMMANDS & CFG_CMD_CDP) + +static void cdp_update_env(void) +{ + char tmp[16]; + + if (CDPApplianceVLAN != htons(-1)) { + printf("CDP offered appliance VLAN %d\n", ntohs(CDPApplianceVLAN)); + VLAN_to_string(CDPApplianceVLAN, tmp); + setenv("vlan", tmp); + NetOurVLAN = CDPApplianceVLAN; + } + + if (CDPNativeVLAN != htons(-1)) { + printf("CDP offered native VLAN %d\n", ntohs(CDPNativeVLAN)); + VLAN_to_string(CDPNativeVLAN, tmp); + setenv("nvlan", tmp); + NetOurNativeVLAN = CDPNativeVLAN; + } + +} + +int do_cdp (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int r; + + r = NetLoop(CDP); + if (r < 0) { + printf("cdp failed; perhaps not a CISCO switch?\n"); + return 1; + } + + cdp_update_env(); + + return 0; +} + +U_BOOT_CMD( + cdp, 1, 1, do_cdp, + "cdp - Perform CDP network configuration\n", +); +#endif /* CFG_CMD_CDP */ + #endif /* CFG_CMD_NET */ diff -ruNb u-boot-original/include/cmd_confdefs.h u-boot-net/include/cmd_confdefs.h --- u-boot-original/include/cmd_confdefs.h 2004-03-30 14:37:28.749918256 +0300 +++ u-boot-net/include/cmd_confdefs.h 2004-03-30 15:41:00.407458232 +0300 @@ -88,6 +88,7 @@ #define CFG_CMD_ITEST 0x0040000000000000U /* Integer (and string) test */ #define CFG_CMD_NFS 0x0080000000000000U /* NFS support */ #define CFG_CMD_REISER 0x0100000000000000U /* Reiserfs support */ +#define CFG_CMD_CDP 0x0200000000000000U /* Cisco Discovery Protocol */
#define CFG_CMD_ALL 0xFFFFFFFFFFFFFFFFU /* ALL commands */
@@ -131,7 +132,8 @@ CFG_CMD_SDRAM | \ CFG_CMD_SPI | \ CFG_CMD_USB | \ - CFG_CMD_VFD ) + CFG_CMD_VFD | \ + CFG_CMD_CDP )
/* Default configuration */ diff -ruNb u-boot-original/include/net.h u-boot-net/include/net.h --- u-boot-original/include/net.h 2004-03-30 14:37:28.756917192 +0300 +++ u-boot-net/include/net.h 2004-03-30 15:41:00.408458080 +0300 @@ -110,7 +110,11 @@ extern int eth_initialize(bd_t *bis); /* Initialize network subsystem */ extern int eth_register(struct eth_device* dev);/* Register network device */ extern void eth_try_another(int first_restart); /* Change the device */ +#ifdef CONFIG_NET_MULTI +extern void eth_set_current(void); /* set nterface to ethcur var. */ +#endif extern struct eth_device *eth_get_dev(void); /* get the current device MAC */ +extern int eth_get_dev_index (void); /* get the device index */ extern void eth_set_enetaddr(int num, char* a); /* Set new MAC address */
extern int eth_init(bd_t *bis); /* Initialize the device */ @@ -143,9 +147,24 @@
#define ETHER_HDR_SIZE 14 /* Ethernet header size */ #define E802_HDR_SIZE 22 /* 802 ethernet header size */ + +/* + * Ethernet header + */ +typedef struct { + uchar vet_dest[6]; /* Destination node */ + uchar vet_src[6]; /* Source node */ + ushort vet_vlan_type; /* PROT_VLAN */ + ushort vet_tag; /* TAG of VLAN */ + ushort vet_type; /* protocol type */ +} VLAN_Ethernet_t; + +#define VLAN_ETHER_HDR_SIZE 18 /* VLAN Ethernet header size */ + #define PROT_IP 0x0800 /* IP protocol */ #define PROT_ARP 0x0806 /* IP ARP protocol */ #define PROT_RARP 0x8035 /* IP ARP protocol */ +#define PROT_VLAN 0x8100 /* IEEE 802.1q protocol */
#define IPPROTO_ICMP 1 /* Internet Control Message Protocol */ #define IPPROTO_UDP 17 /* User Datagram Protocol */ @@ -296,6 +315,15 @@ extern unsigned NetIPID; /* IP ID (counting) */ extern uchar NetBcastAddr[6]; /* Ethernet boardcast address */
+#define VLAN_NONE 4095 /* untagged */ +#define VLAN_IDMASK 0x0fff /* mask of valid vlan id */ +extern ushort NetOurVLAN; /* Our VLAN */ +extern ushort NetOurNativeVLAN; /* Our Native VLAN */ + +extern uchar NetCDPAddr[6]; /* Ethernet CDP address */ +extern ushort CDPNativeVLAN; /* CDP returned native VLAN */ +extern ushort CDPApplianceVLAN; /* CDP returned appliance VLAN */ + extern int NetState; /* Network loop state */ #define NETLOOP_CONTINUE 1 #define NETLOOP_RESTART 2 @@ -306,7 +334,7 @@ extern int NetRestartWrap; /* Tried all network devices */ #endif
-typedef enum { BOOTP, RARP, ARP, TFTP, DHCP, PING, DNS, NFS } proto_t; +typedef enum { BOOTP, RARP, ARP, TFTP, DHCP, PING, DNS, NFS, CDP } proto_t;
/* from net/net.c */ extern char BootFile[128]; /* Boot File name */ @@ -315,6 +343,12 @@ extern IPaddr_t NetPingIP; /* the ip address to ping */ #endif
+#if (CONFIG_COMMANDS & CFG_CMD_CDP) +/* when CDP completes these hold the return values */ +extern ushort CDPNativeVLAN; +extern ushort CDPApplianceVLAN; +#endif + /* Initialize the network adapter */ extern int NetLoop(proto_t);
@@ -324,8 +358,11 @@ /* Load failed. Start again. */ extern void NetStartAgain(void);
-/* Set ethernet header */ -extern void NetSetEther(volatile uchar *, uchar *, uint); +/* Get size of the ethernet header when we send */ +extern int NetEthHdrSize(void); + +/* Set ethernet header; returns the size of the header */ +extern int NetSetEther(volatile uchar *, uchar *, uint);
/* Set IP header */ extern void NetSetIP(volatile uchar *, IPaddr_t, int, int, int); @@ -397,9 +434,18 @@ /* Convert a string to ip address */ extern IPaddr_t string_to_ip(char *s);
+/* Convert a VLAN id to a string */ +extern void VLAN_to_string (ushort x, char *s); + +/* Convert a string to a vlan id */ +extern ushort string_to_VLAN(char *s); + /* read an IP address from a environment variable */ extern IPaddr_t getenv_IPaddr (char *);
+/* read a VLAN id from an environment variable */ +extern ushort getenv_VLAN(char *); + /* copy a filename (allow for "..." notation, limit length) */ extern void copy_filename (uchar *dst, uchar *src, int size);
diff -ruNb u-boot-original/net/bootp.c u-boot-net/net/bootp.c --- u-boot-original/net/bootp.c 2004-03-30 14:37:28.828906248 +0300 +++ u-boot-net/net/bootp.c 2004-03-30 15:41:00.409457928 +0300 @@ -644,8 +644,7 @@ pkt = NetTxPacket; memset ((void*)pkt, 0, PKTSIZE);
- NetSetEther(pkt, NetBcastAddr, PROT_IP); - pkt += ETHER_HDR_SIZE; + pkt += NetSetEther(pkt, NetBcastAddr, PROT_IP);
/* * Next line results in incorrect packet size being transmitted, resulting @@ -791,8 +790,7 @@ pkt = NetTxPacket; memset ((void*)pkt, 0, PKTSIZE);
iphdr = pkt; /* We'll need this later to set proper pkt size */ pkt += IP_HDR_SIZE; diff -ruNb u-boot-original/net/eth.c u-boot-net/net/eth.c --- u-boot-original/net/eth.c 2004-03-30 14:37:28.828906248 +0300 +++ u-boot-net/net/eth.c 2004-03-30 15:41:00.410457776 +0300 @@ -87,6 +87,14 @@
if (!eth_devices) { eth_current = eth_devices = dev; +#ifdef CONFIG_NET_MULTI + /* update current ethernet name */ + { + char *act = getenv("ethact"); + if (act == NULL || strcmp(act, eth_current->name) != 0) + setenv("ethact", eth_current->name); + } +#endif } else { for (d=eth_devices; d->next!=eth_devices; d=d->next); d->next = dev; @@ -221,6 +229,16 @@ dev = dev->next; } while(dev != eth_devices);
+#ifdef CONFIG_NET_MULTI + /* update current ethernet name */ + if (eth_current) { + char *act = getenv("ethact"); + if (act == NULL || strcmp(act, eth_current->name) != 0) + setenv("ethact", eth_current->name); + } else + setenv("ethact", NULL); +#endif + putc ('\n'); }
@@ -326,12 +344,44 @@
eth_current = eth_current->next;
+#ifdef CONFIG_NET_MULTI + /* update current ethernet name */ + { + char *act = getenv("ethact"); + if (act == NULL || strcmp(act, eth_current->name) != 0) + setenv("ethact", eth_current->name); + } +#endif + if (first_failed == eth_current) { NetRestartWrap = 1; } }
+#ifdef CONFIG_NET_MULTI +void eth_set_current(void) +{ + char *act; + struct eth_device* old_current; + + if (!eth_current) /* XXX no current */ + return; + + act = getenv("ethact"); + if (act != NULL) { + old_current = eth_current; + do { + if (strcmp(eth_current->name, act) == 0) + return; + eth_current = eth_current->next; + } while (old_current != eth_current); + } + + setenv("ethact", eth_current->name); +} +#endif + char *eth_get_name (void) { return (eth_current ? eth_current->name : "unknown"); diff -ruNb u-boot-original/net/net.c u-boot-net/net/net.c --- u-boot-original/net/net.c 2004-03-30 14:37:28.829906096 +0300 +++ u-boot-net/net/net.c 2004-03-30 15:41:00.412457472 +0300 @@ -121,6 +121,10 @@ { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff }; uchar NetEtherNullAddr[6] = { 0, 0, 0, 0, 0, 0 }; +#if (CONFIG_COMMANDS & CFG_CMD_CDP) +uchar NetCDPAddr[6] = /* Ethernet bcast address */ + { 0x01, 0x00, 0x0c, 0xcc, 0xcc, 0xcc }; +#endif int NetState; /* Network loop state */ #ifdef CONFIG_NET_MULTI int NetRestartWrap = 0; /* Tried all network devices */ @@ -128,6 +132,9 @@ static int NetDevExists = 0; /* At least one device configured */ #endif
+ushort NetOurVLAN = ntohs(-1); /* default is without VLAN */ +ushort NetOurNativeVLAN = htons(-1); /* dido */ + char BootFile[128]; /* Boot File name */
#if (CONFIG_COMMANDS & CFG_CMD_PING) @@ -136,6 +143,14 @@ static void PingStart(void); #endif
+#if (CONFIG_COMMANDS & CFG_CMD_CDP) + +static void CDPStart(void); + + + +#endif + volatile uchar PktBuf[(PKTBUFSRX+1) * PKTSIZE_ALIGN + PKTALIGN];
volatile uchar *NetRxPackets[PKTBUFSRX]; /* Receive packets */ @@ -170,8 +185,7 @@ #endif pkt = NetTxPacket;
- NetSetEther(pkt, NetBcastAddr, PROT_ARP); - pkt += ETHER_HDR_SIZE; + pkt += NetSetEther(pkt, NetBcastAddr, PROT_ARP);
arp = (ARP_t *)pkt;
@@ -196,7 +210,7 @@ NetArpWaitReplyIP = NetArpWaitPacketIP;
NetWriteIP((uchar*)&arp->ar_data[16], NetArpWaitReplyIP); - (void) eth_send(NetTxPacket, ETHER_HDR_SIZE + ARP_HDR_SIZE); + (void) eth_send(NetTxPacket, (pkt - NetTxPacket) + ARP_HDR_SIZE); }
void ArpTimeoutCheck(void) @@ -269,6 +283,7 @@ }
eth_halt(); + eth_set_current(); if(eth_init(bd) < 0) return(-1);
@@ -298,6 +313,8 @@ NetCopyIP(&NetOurIP, &bd->bi_ip_addr); NetOurGatewayIP = getenv_IPaddr ("gatewayip"); NetOurSubnetMask= getenv_IPaddr ("netmask"); + NetOurVLAN = getenv_VLAN("vlan"); + NetOurNativeVLAN = getenv_VLAN("nvlan");
switch (protocol) { #if (CONFIG_COMMANDS & CFG_CMD_NFS) @@ -324,6 +341,11 @@ */ NetOurIP = 0; NetServerIP = getenv_IPaddr ("serverip"); + NetOurVLAN = getenv_VLAN("vlan"); /* VLANs must be read */ + NetOurNativeVLAN = getenv_VLAN("nvlan"); + case CDP: + NetOurVLAN = getenv_VLAN("vlan"); /* VLANs must be read */ + NetOurNativeVLAN = getenv_VLAN("nvlan"); break; default: break; @@ -378,6 +400,11 @@ NfsStart(); break; #endif +#if (CONFIG_COMMANDS & CFG_CMD_CDP) + case CDP: + CDPStart(); + break; +#endif default: break; } @@ -469,6 +496,9 @@ NetBootFileXferSize); sprintf(buf, "%lx", NetBootFileXferSize); setenv("filesize", buf); + + sprintf(buf, "%lX", (unsigned long)load_addr); + setenv("fileaddr", buf); } eth_halt(); return NetBootFileXferSize; @@ -496,12 +526,19 @@ void NetStartAgain(void) { + DECLARE_GLOBAL_DATA_PTR; + char *s; + + if ((s = getenv("netretry")) != NULL && *s == 'n') { + eth_halt(); + NetState = NETLOOP_FAIL; + return; + } + #ifndef CONFIG_NET_MULTI NetSetTimeout(10 * CFG_HZ, startAgainTimeout); NetSetHandler(startAgainHandler); #else - DECLARE_GLOBAL_DATA_PTR; - eth_halt(); eth_try_another(!NetRestarted); eth_init(gd->bd); @@ -559,6 +596,8 @@ int NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) { + uchar *pkt; + /* convert to new style broadcast */ if (dest == 0) dest = 0xFFFFFFFF; @@ -573,16 +612,17 @@ #ifdef ET_DEBUG printf("sending ARP for %08lx\n", dest); #endif - NetArpWaitPacketIP = dest; NetArpWaitPacketMAC = ether; - NetSetEther (NetArpWaitTxPacket, NetArpWaitPacketMAC, PROT_IP); - NetSetIP (NetArpWaitTxPacket + ETHER_HDR_SIZE, dest, dport, sport, len); - memcpy(NetArpWaitTxPacket + ETHER_HDR_SIZE + IP_HDR_SIZE, - (uchar *)NetTxPacket + ETHER_HDR_SIZE + IP_HDR_SIZE, len); + + pkt = NetArpWaitTxPacket; + pkt += NetSetEther (pkt, NetArpWaitPacketMAC, PROT_IP); + + NetSetIP (pkt, dest, dport, sport, len); + memcpy(pkt + IP_HDR_SIZE, (uchar *)NetTxPacket + (pkt - (uchar *)NetArpWaitTxPacket) + IP_HDR_SIZE, len);
/* size of the waiting packet */ - NetArpWaitTxPacketSize = ETHER_HDR_SIZE + IP_HDR_SIZE + len; + NetArpWaitTxPacketSize = (pkt - NetArpWaitTxPacket) + IP_HDR_SIZE + len;
/* and do the ARP request */ NetArpWaitTry = 1; @@ -596,9 +636,10 @@ dest, ether[0], ether[1], ether[2], ether[3], ether[4], ether[5]); #endif
- NetSetEther (NetTxPacket, ether, PROT_IP); - NetSetIP (NetTxPacket + ETHER_HDR_SIZE, dest, dport, sport, len); - (void) eth_send(NetTxPacket, ETHER_HDR_SIZE + IP_HDR_SIZE + len); + pkt = (uchar *)NetTxPacket; + pkt += NetSetEther (pkt, ether, PROT_IP); + NetSetIP (pkt, dest, dport, sport, len); + (void) eth_send(NetTxPacket, (pkt - NetTxPacket) + IP_HDR_SIZE + len);
return 0; /* transmited */ } @@ -611,6 +652,7 @@ static uchar mac[6]; volatile IP_t *ip; volatile ushort *s; + uchar *pkt;
/* XXX always send arp request */
@@ -623,9 +665,10 @@ NetArpWaitPacketIP = NetPingIP; NetArpWaitPacketMAC = mac;
- NetSetEther(NetArpWaitTxPacket, mac, PROT_IP); + pkt = NetArpWaitTxPacket; + pkt += NetSetEther(pkt, mac, PROT_IP);
- ip = (volatile IP_t *)(NetArpWaitTxPacket + ETHER_HDR_SIZE); + ip = (volatile IP_t *)pkt;
/* * Construct an IP and ICMP header. (need to set no fragment bit - XXX) @@ -650,7 +693,7 @@ s[1] = ~NetCksum((uchar *)s, 8/2);
/* size of the waiting packet */ - NetArpWaitTxPacketSize = ETHER_HDR_SIZE + IP_HDR_SIZE_NO_UDP + 8; + NetArpWaitTxPacketSize = (pkt - NetArpWaitTxPacket) + IP_HDR_SIZE_NO_UDP + 8;
/* and do the ARP request */ NetArpWaitTry = 1; @@ -681,6 +724,9 @@
static void PingStart(void) { +#if defined(CONFIG_NET_MULTI) + printf ("Using %s device\n", eth_get_name()); +#endif NetSetTimeout (10 * CFG_HZ, PingTimeout); NetSetHandler (PingHandler);
@@ -689,37 +735,454 @@
#endif
+#if (CONFIG_COMMANDS & CFG_CMD_CDP) + +#define CDP_DEVICE_ID_TLV 0x0001 +#define CDP_ADDRESS_TLV 0x0002 +#define CDP_PORT_ID_TLV 0x0003 +#define CDP_CAPABILITIES_TLV 0x0004 +#define CDP_VERSION_TLV 0x0005 +#define CDP_PLATFORM_TLV 0x0006 +#define CDP_NATIVE_VLAN_TLV 0x000a +#define CDP_APPLIANCE_VLAN_TLV 0x000e +#define CDP_TRIGGER_TLV 0x000f +#define CDP_POWER_CONSUMPTION_TLV 0x0010 +#define CDP_SYSNAME_TLV 0x0014 +#define CDP_SYSOBJECT_TLV 0x0015 +#define CDP_MANAGEMENT_ADDRESS_TLV 0x0016 + +#define CDP_TIMEOUT (CFG_HZ/4) /* one packet every 250ms */ + +static int CDPSeq; +static int CDPOK; + +ushort CDPNativeVLAN; +ushort CDPApplianceVLAN; + +static const uchar CDP_SNAP_hdr[8] = { 0xAA, 0xAA, 0x03, 0x00, 0x00, 0x0C, 0x20, 0x00 }; + +static ushort CDP_compute_csum(const uchar *buff, ushort len) +{ + ushort csum; + int odd; + ulong result = 0; + ushort leftover; + + if (len > 0) { + odd = 1 & (ulong)buff; + if (odd) { + result = *buff << 8; + len--; + buff++; + } + while (len > 1) { + result += *((const ushort *)buff)++; + if (result & 0x80000000) + result = (result & 0xFFFF) + (result >> 16); + len -= 2; + } + if (len) { + leftover = (signed short)(*(const signed char *)buff); + /* * XXX CISCO SUCKS big time! (and blows too) */ + result = (result & 0xffff0000) | ((result + leftover) & 0x0000ffff); + } + while (result >> 16) + result = (result & 0xFFFF) + (result >> 16); + + if (odd) + result = ((result >> 8) & 0xff) | ((result & 0xff) << 8); + } + + /* add up 16-bit and 17-bit words for 17+c bits */ + result = (result & 0xffff) + (result >> 16); + /* add up 16-bit and 2-bit for 16+c bit */ + result = (result & 0xffff) + (result >> 16); + /* add up carry.. */ + result = (result & 0xffff) + (result >> 16); + + /* negate */ + csum = ~(ushort)result; + + /* run time endian detection */ + if (csum != htons(csum)) /* little endian */ + csum = htons(csum); + + return csum; +} + +int CDPSendTrigger(void) +{ + volatile uchar *pkt; + volatile ushort *s; + volatile ushort *cp; + Ethernet_t *et; + char buf[32]; + int len; + ushort chksum; + + pkt = NetTxPacket; + et = (Ethernet_t *)pkt; + + /* NOTE: trigger sent not on any VLAN */ + + /* form ethernet header */ + memcpy(et->et_dest, NetCDPAddr, 6); + memcpy(et->et_src, NetOurEther, 6); + + pkt += ETHER_HDR_SIZE; + + /* SNAP header */ + memcpy((uchar *)pkt, CDP_SNAP_hdr, sizeof(CDP_SNAP_hdr)); + pkt += sizeof(CDP_SNAP_hdr); + + /* CDP header */ + *pkt++ = 0x02; /* CDP version 2 */ + *pkt++ = 180; /* TTL */ + s = (volatile ushort *)pkt; + cp = s; + *s++ = htons(0); /* checksum (0 for later calculation) */ + + /* CDP fields */ +#ifdef CONFIG_CDP_DEVICE_ID + *s++ = htons(CDP_DEVICE_ID_TLV); + *s++ = htons(CONFIG_CDP_DEVICE_ID); + memset(buf, 0, sizeof(buf)); + sprintf(buf, CONFIG_CDP_DEVICE_ID_PREFIX "%02X%02X%02X%02X%02X%02X", + NetOurEther[0] & 0xff, NetOurEther[1] & 0xff, + NetOurEther[2] & 0xff, NetOurEther[3] & 0xff, + NetOurEther[4] & 0xff, NetOurEther[5] & 0xff); + memcpy((uchar *)s, buf, 16); + s += 16 / 2; +#endif + +#ifdef CONFIG_CDP_PORT_ID + *s++ = htons(CDP_PORT_ID_TLV); + memset(buf, 0, sizeof(buf)); + sprintf(buf, CONFIG_CDP_PORT_ID, eth_get_dev_index()); + len = strlen(buf); + if (len & 1) /* make it even */ + len++; + *s++ = htons(len + 4); + memcpy((uchar *)s, buf, len); + s += len / 2; +#endif + +#ifdef CONFIG_CDP_CAPABILITIES + *s++ = htons(CDP_CAPABILITIES_TLV); + *s++ = htons(8); + *(ulong *)s = htonl(CONFIG_CDP_CAPABILITIES); + s += 2; +#endif + +#ifdef CONFIG_CDP_VERSION + *s++ = htons(CDP_VERSION_TLV); + memset(buf, 0, sizeof(buf)); + strcpy(buf, CONFIG_CDP_VERSION); + len = strlen(buf); + if (len & 1) /* make it even */ + len++; + *s++ = htons(len + 4); + memcpy((uchar *)s, buf, len); + s += len / 2; +#endif + +#ifdef CONFIG_CDP_PLATFORM + *s++ = htons(CDP_PLATFORM_TLV); + memset(buf, 0, sizeof(buf)); + strcpy(buf, CONFIG_CDP_PLATFORM); + len = strlen(buf); + if (len & 1) /* make it even */ + len++; + *s++ = htons(len + 4); + memcpy((uchar *)s, buf, len); + s += len / 2; +#endif + +#ifdef CONFIG_CDP_TRIGGER + *s++ = htons(CDP_TRIGGER_TLV); + *s++ = htons(8); + *(ulong *)s = htonl(CONFIG_CDP_TRIGGER); + s += 2; +#endif + +#ifdef CONFIG_CDP_POWER_CONSUMPTION + *s++ = htons(CDP_POWER_CONSUMPTION_TLV); + *s++ = htons(6); + *s++ = htons(CONFIG_CDP_POWER_CONSUMPTION); +#endif + + /* length of ethernet packet */ + len = (uchar *)s - ((uchar *)NetTxPacket + ETHER_HDR_SIZE); + et->et_protlen = htons(len); + + len = ETHER_HDR_SIZE + sizeof(CDP_SNAP_hdr); + chksum = CDP_compute_csum((uchar *)NetTxPacket + len, (uchar *)s - (NetTxPacket + len)); + if (chksum == 0) + chksum = 0xFFFF; + *cp = htons(chksum); + + (void) eth_send(NetTxPacket, (uchar *)s - NetTxPacket); + return 0; +} + +static void +CDPTimeout (void) +{ + CDPSeq++; + + if (CDPSeq < 3) { + NetSetTimeout (CDP_TIMEOUT, CDPTimeout); + CDPSendTrigger(); + return; + } + + /* if not OK try again */ + if (!CDPOK) + NetStartAgain(); + else + NetState = NETLOOP_SUCCESS; +} + +static void +CDPDummyHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) +{ + /* nothing */ +} + +static void +CDPHandler(const uchar * pkt, unsigned len) +{ + const uchar *t; + const ushort *ss; + ushort type, tlen; + uchar applid; + ushort vlan, nvlan; + + /* minimum size? */ + if (len < sizeof(CDP_SNAP_hdr) + 4) + goto pkt_short; + + /* check for valid CDP SNAP header */ + if (memcmp(pkt, CDP_SNAP_hdr, sizeof(CDP_SNAP_hdr)) != 0) + return; + + pkt += sizeof(CDP_SNAP_hdr); + len -= sizeof(CDP_SNAP_hdr); + + /* Version of CDP protocol must be >= 2 and TTL != 0 */ + if (pkt[0] < 0x02 || pkt[1] == 0) + return; + + /* if version is greater than 0x02 maybe we'll have a problem; output a warning */ + if (pkt[0] != 0x02) + printf("** WARNING: CDP packet received with a protocol version %d > 2\n", + pkt[0] & 0xff); + + if (CDP_compute_csum(pkt, len) != 0) + return; + + pkt += 4; + len -= 4; + + vlan = htons(-1); + nvlan = htons(-1); + while (len > 0) { + if (len < 4) + goto pkt_short; + + ss = (const ushort *)pkt; + type = ntohs(ss[0]); + tlen = ntohs(ss[1]); + if (tlen > len) { + goto pkt_short; + } + + pkt += tlen; + len -= tlen; + + ss += 2; /* point ss to the data of the TLV */ + tlen -= 4; + + switch (type) { + case CDP_DEVICE_ID_TLV: + break; + case CDP_ADDRESS_TLV: + break; + case CDP_PORT_ID_TLV: + break; + case CDP_CAPABILITIES_TLV: + break; + case CDP_VERSION_TLV: + break; + case CDP_PLATFORM_TLV: + break; + case CDP_NATIVE_VLAN_TLV: + nvlan = *ss; + break; + case CDP_APPLIANCE_VLAN_TLV: + t = (const uchar *)ss; + while (tlen > 0) { + if (tlen < 3) + goto pkt_short; + + applid = t[0]; + ss = (const ushort *)(t + 1); + +#ifdef CONFIG_CDP_APPLIANCE_VLAN_TYPE + if (applid == CONFIG_CDP_APPLIANCE_VLAN_TYPE) + vlan = *ss; +#else + vlan = ntohs(*ss); /* XXX will this work; dunno */ +#endif + t += 3; tlen -= 3; + } + break; + case CDP_TRIGGER_TLV: + break; + case CDP_POWER_CONSUMPTION_TLV: + break; + case CDP_SYSNAME_TLV: + break; + case CDP_SYSOBJECT_TLV: + break; + case CDP_MANAGEMENT_ADDRESS_TLV: + break; + } + } + + CDPApplianceVLAN = vlan; + CDPNativeVLAN = nvlan; + + CDPOK = 1; + return; + + pkt_short: + printf("** CDP packet is too short\n"); + return; +} + +static void CDPStart(void) +{ +#if defined(CONFIG_NET_MULTI) + printf ("Using %s device\n", eth_get_name()); +#endif + CDPSeq = 0; + CDPOK = 0; + + CDPNativeVLAN = htons(-1); + CDPApplianceVLAN = htons(-1); + + NetSetTimeout (CDP_TIMEOUT, CDPTimeout); + NetSetHandler (CDPDummyHandler); + + CDPSendTrigger(); +} + +#endif + + void -NetReceive(volatile uchar * pkt, int len) +NetReceive(volatile uchar * inpkt, int len) { Ethernet_t *et; IP_t *ip; ARP_t *arp; IPaddr_t tmp; int x; + uchar *pkt; +#if (CONFIG_COMMANDS & CFG_CMD_CDP) + int iscdp; +#endif + ushort cti = 0, vlanid = VLAN_NONE, myvlanid, mynvlanid;
- NetRxPkt = pkt; +#ifdef ET_DEBUG + printf("packet received\n"); +#endif + + NetRxPkt = inpkt; NetRxPktLen = len; - et = (Ethernet_t *)pkt; + et = (Ethernet_t *)inpkt; + + /* too small packet? */ + if (len < ETHER_HDR_SIZE) + return; + +#if (CONFIG_COMMANDS & CFG_CMD_CDP) + /* keep track if packet is CDP */ + iscdp = memcmp(et->et_dest, NetCDPAddr, 6) == 0; +#endif + + myvlanid = ntohs(NetOurVLAN); + if (myvlanid == (ushort)-1) + myvlanid = VLAN_NONE; + mynvlanid = ntohs(NetOurNativeVLAN); + if (mynvlanid == (ushort)-1) + mynvlanid = VLAN_NONE;
x = ntohs(et->et_protlen);
+#ifdef ET_DEBUG + printf("packet received\n"); +#endif + if (x < 1514) { /* * Got a 802 packet. Check the other protocol field. */ x = ntohs(et->et_prot); - ip = (IP_t *)(pkt + E802_HDR_SIZE); + + ip = (IP_t *)(inpkt + E802_HDR_SIZE); len -= E802_HDR_SIZE; - } else { - ip = (IP_t *)(pkt + ETHER_HDR_SIZE); + + } else if (x != PROT_VLAN) { /* normal packet */ + ip = (IP_t *)(inpkt + ETHER_HDR_SIZE); len -= ETHER_HDR_SIZE; + + } else { /* VLAN packet */ + VLAN_Ethernet_t *vet = (VLAN_Ethernet_t *)et; + +#ifdef ET_DEBUG + printf("VLAN packet received\n"); +#endif + /* too small packet? */ + if (len < VLAN_ETHER_HDR_SIZE) + return; + + /* if no VLAN active */ + if ((ntohs(NetOurVLAN) & VLAN_IDMASK) == VLAN_NONE +#if (CONFIG_COMMANDS & CFG_CMD_CDP) + && iscdp == 0 +#endif + ) + return; + + cti = ntohs(vet->vet_tag); + vlanid = cti & VLAN_IDMASK; + x = ntohs(vet->vet_type); + + ip = (IP_t *)(inpkt + VLAN_ETHER_HDR_SIZE); + len -= VLAN_ETHER_HDR_SIZE; }
#ifdef ET_DEBUG printf("Receive from protocol 0x%x\n", x); #endif
+#if (CONFIG_COMMANDS & CFG_CMD_CDP) + if (iscdp) { + CDPHandler((uchar *)ip, len); + return; + } +#endif + + if ((myvlanid & VLAN_IDMASK) != VLAN_NONE) { + if (vlanid == VLAN_NONE) + vlanid = (mynvlanid & VLAN_IDMASK); + /* not matched? */ + if (vlanid != (myvlanid & VLAN_IDMASK)) + return; + } + switch (x) {
case PROT_ARP: @@ -766,13 +1229,14 @@ #ifdef ET_DEBUG puts ("Got ARP REQUEST, return our IP\n"); #endif - NetSetEther((uchar *)et, et->et_src, PROT_ARP); + pkt = (uchar *)et; + pkt += NetSetEther(pkt, et->et_src, PROT_ARP); arp->ar_op = htons(ARPOP_REPLY); memcpy (&arp->ar_data[10], &arp->ar_data[0], 6); NetCopyIP(&arp->ar_data[16], &arp->ar_data[6]); memcpy (&arp->ar_data[ 0], NetOurEther, 6); NetCopyIP(&arp->ar_data[ 6], &NetOurIP); - (void) eth_send((uchar *)et, ((uchar *)arp-pkt) + ARP_HDR_SIZE); + (void) eth_send((uchar *)et, (pkt - (uchar *)et) + ARP_HDR_SIZE); return;
case ARPOP_REPLY: /* arp reply */ @@ -963,6 +1427,7 @@ case DHCP: case RARP: case BOOTP: + case CDP: if (memcmp(NetOurEther, "\0\0\0\0\0\0", 6) == 0) { #ifdef CONFIG_NET_MULTI extern int eth_get_dev_index (void); @@ -1016,17 +1481,42 @@ return (xsum & 0xffff); }
+int +NetEthHdrSize(void) +{ + ushort myvlanid;
-void + myvlanid = ntohs(NetOurVLAN); + if (myvlanid == (ushort)-1) + myvlanid = VLAN_NONE; + + return ((myvlanid & VLAN_IDMASK) == VLAN_NONE) ? ETHER_HDR_SIZE : VLAN_ETHER_HDR_SIZE; +} + +int NetSetEther(volatile uchar * xet, uchar * addr, uint prot) { Ethernet_t *et = (Ethernet_t *)xet; + ushort myvlanid; + + myvlanid = ntohs(NetOurVLAN); + if (myvlanid == (ushort)-1) + myvlanid = VLAN_NONE;
memcpy (et->et_dest, addr, 6); memcpy (et->et_src, NetOurEther, 6); + if ((myvlanid & VLAN_IDMASK) == VLAN_NONE) { et->et_protlen = htons(prot); -} + return ETHER_HDR_SIZE; + } else { + VLAN_Ethernet_t *vet = (VLAN_Ethernet_t *)xet;
+ vet->vet_vlan_type = htons(PROT_VLAN); + vet->vet_tag = htons((0 << 5) | (myvlanid & VLAN_IDMASK)); + vet->vet_type = htons(prot); + return VLAN_ETHER_HDR_SIZE; + } +}
void NetSetIP(volatile uchar * xip, IPaddr_t dest, int dport, int sport, int len) @@ -1109,6 +1599,34 @@ return (htonl(addr)); }
+void VLAN_to_string(ushort x, char *s) +{ + x = ntohs(x); + + if (x == (ushort)-1) + x = VLAN_NONE; + + if (x == VLAN_NONE) + strcpy(s, "none"); + else + sprintf(s, "%d", x & VLAN_IDMASK); +} + +ushort string_to_VLAN(char *s) +{ + ushort id; + + if (s == NULL) + return VLAN_NONE; + + if (*s < '0' || *s > '9') + id = VLAN_NONE; + else + id = (ushort)simple_strtoul(s, NULL, 10); + + return id; +} + void print_IPaddr (IPaddr_t x) { char tmp[16]; @@ -1122,3 +1640,8 @@ { return (string_to_ip(getenv(var))); } + +ushort getenv_VLAN(char *var) +{ + return (string_to_VLAN(getenv(var))); +} diff -ruNb u-boot-original/net/nfs.c u-boot-net/net/nfs.c --- u-boot-original/net/nfs.c 2004-03-30 14:37:28.829906096 +0300 +++ u-boot-net/net/nfs.c 2004-03-30 15:41:00.413457320 +0300 @@ -192,7 +192,7 @@
pktlen = (char *)p + datalen*sizeof(uint32_t) - (char *)&pkt;
- memcpy ((char *)NetTxPacket+ETHER_HDR_SIZE+IP_HDR_SIZE, (char *)&pkt, pktlen); + memcpy ((char *)NetTxPacket + NetEthHdrSize() + IP_HDR_SIZE, (char *)&pkt, pktlen);
if (rpc_prog == PROG_PORTMAP) sport = SUNRPC_PORT; diff -ruNb u-boot-original/net/rarp.c u-boot-net/net/rarp.c --- u-boot-original/net/rarp.c 2004-03-30 14:37:28.829906096 +0300 +++ u-boot-net/net/rarp.c 2004-03-30 15:41:00.414457168 +0300 @@ -96,8 +96,7 @@ printf("RARP broadcast %d\n", ++RarpTry); pkt = NetTxPacket;
- NetSetEther(pkt, NetBcastAddr, PROT_RARP); - pkt += ETHER_HDR_SIZE; + pkt += NetSetEther(pkt, NetBcastAddr, PROT_RARP);
rarp = (ARP_t *)pkt;
@@ -114,7 +113,7 @@ rarp->ar_data[16 + i] = 0xff; }
- NetSendPacket(NetTxPacket, ETHER_HDR_SIZE + ARP_HDR_SIZE); + NetSendPacket(NetTxPacket, (pkt - NetTxPacket) + ARP_HDR_SIZE);
NetSetTimeout(TIMEOUT * CFG_HZ, RarpTimeout); NetSetHandler(RarpHandler); diff -ruNb u-boot-original/net/tftp.c u-boot-net/net/tftp.c --- u-boot-original/net/tftp.c 2004-03-30 14:37:28.829906096 +0300 +++ u-boot-net/net/tftp.c 2004-03-30 15:41:00.414457168 +0300 @@ -111,7 +111,7 @@ * We will always be sending some sort of packet, so * cobble together the packet headers now. */ - pkt = NetTxPacket + ETHER_HDR_SIZE + IP_HDR_SIZE; + pkt = NetTxPacket + NetEthHdrSize() + IP_HDR_SIZE;
switch (TftpState) {
Cool!!! Added. Thanks.
Dear Pantelis,
Unfortunately this patch breaks supoort for ARM boards:
Configuring for assabet board... net.c:135: initializer element is not constant net.c:136: initializer element is not constant net.c: In function `NetLoop': net.c:282: warning: implicit declaration of function `eth_set_current' net.c: In function `NetStartAgain': net.c:525: warning: unused variable `gd' net/libnet.a(net.o): In function `NetLoop': /home/wd/u-boot/net/net.c:282: undefined reference to `eth_set_current'
Can you please provide a patch to clean this up?
Wolfgang Denk wrote:
Dear Pantelis,
Hmm.
Let me download the CVS version and try again. My version passed the MAKEALL tests...
Regards
Pantelis
Hi, I am porting u-boot-1.1.0 for the blackfin proceor. Anybody is using the smc driver present in the drivers directory It seems incomplete to use in u-boot. because the driver is not hooked with upper eth layer(eth.c).
Is it need to be ported ?
Thanks and Regards Ganapathi C
In message 08df01c423a2$bcf937e0$af00a8c0@tidelpark.isofttechindia.com you wrote:
I think you must be missing something. A quick check shows:
-> grep CONFIG_DRIVER_SMC91111 include/configs/* include/configs/ADNPESC1.h:#define CONFIG_DRIVER_SMC91111 /* Using SMC91c111 */ include/configs/DK1C20.h:#define CONFIG_DRIVER_SMC91111 /* Using SMC91c111 */ include/configs/DK1S10.h:#define CONFIG_DRIVER_SMC91111 /* Using SMC91c111 */ include/configs/cradle.h:#define CONFIG_DRIVER_SMC91111 include/configs/dnp1110.h:#define CONFIG_DRIVER_SMC91111 include/configs/innokom.h:#define CONFIG_DRIVER_SMC91111 1 include/configs/integratorcp.h:#define CONFIG_DRIVER_SMC91111 include/configs/logodl.h:#define CONFIG_DRIVER_SMC91111 1 include/configs/versatile.h:#define CONFIG_DRIVER_SMC91111 include/configs/xm250.h:#define CONFIG_DRIVER_SMC91111
I don't think so. It seems that at least 10 different boards already use this driver without problems.
Dear Pantelis,
net/net.c can't be compiled with my poor mipsel-linux-gcc 2.96. The message is : mipsel-linux-gcc -g -Os -D__KERNEL__ -DTEXT_BASE=0xBFC00000 -I/home/mkomiya/u-boot.mk/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/lib/gcc-lib/mipsel-linux/2.96-sdelinuxmips-030324/include -pipe -DCONFIG_MIPS -D__MIPS__ -mcpu=r4600 -EL -mabicalls -Wall -Wstrict-prototypes -c -o net.o net.c net.c:135: initializer element is not constant net.c:136: initializer element is not constant
It seems to be falled in the loop by ushort NetOurVLAN = ntohs(-1) ushort NetOurNativeVLAN = htons(-1)
Could you intialize these variables in the program ?
Masami Komiya
Fixed now in CVS.
ganapathi
Masami Komiya
Pantelis Antoniou
