[PATCH v13 00/19] RISC-V SiFive FU540 support SPL
This series add support for SPL to FU540. U-Boot SPL can boot from L2 LIM (0x0800_0000) and jump to OpenSBI(FW_DYNAMIC firmware) and U-Boot proper from MMC devices.
This series is also available here [1] for testing [1] https://github.com/pragnesh26992/u-boot/tree/spl
How to test this patch: 1) Go to OpenSBI-dir : make PLATFORM=generic FW_DYNAMIC=y 2) export OPENSBI=<path to opensbi/build/platform/generic/firmware/fw_dynamic.bin> 3) Change to u-boot-dir 4) make sifive_fu540_defconfig 5) make all 6) Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch)
# sudo sgdisk --clear \ > --set-alignment=2 \ > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ > /dev/sda
7) sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 8) sudo dd if=u-boot.itb of=/dev/sda seek=2082
Changes in v13: - Add a new patch to set the ethernet clock rate (riscv: sifive: dts: fu540: set ethernet clock rate)
Changes in v12: - Rebase on mainline U-Boot Added necessary include files which are not part of common header now Remove unnecessary include files
drivers/misc/sifive-otp.c +#include <linux/bitops.h> +#include <linux/delay.h>
board/sifive/fu540/fu540.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c +#include <init.h> +#include <log.h> +#include <linux/delay.h>
drivers/ram/sifive/fu540_ddr.c +#include <linux/bitops.h>
arch/riscv/cpu/fu540/cpu.c -#include <common.h> +#include <asm/cache.h>
arch/riscv/cpu/fu540/spl.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c -#include <common.h> +#include <init.h> +#include <log.h> +#include <linux/delay.h>
- Update commit description for Release ethernet clock reset - Update OpenSBI building section in "doc/board/sifive/fu540.rst"
Changes in v11: - Remove TPL related code and OF_PLATDATA from FU540 DDR driver (drivers/ram/sifive/fu540_ddr.c) - Update FU540 doc (doc/board/sifive/fu540.rst) Remove unnecessary print
Changes in v10: - Update commit description for ethernet clock reset (https://patchwork.ozlabs.org/patch/1289003) - Update commit description for ddr clock initialization (https://patchwork.ozlabs.org/patch/1289000)
Changes in v9: - Remove cache related patches from this series sifive: dts: fu540: Enable L2 Cache in U-Boot (https://patchwork.ozlabs.org/patch/1286705) riscv: sifive: fu540: enable all cache ways from U-Boot proper (https://patchwork.ozlabs.org/patch/1286706) - Rename SiFive DDR driver from sdram_fu540.c to fu540_ddr.c and also do some typo correction in driver - Remove CONFIG_SPL_BUILD for __prci_ddr_release_reset() - Release ethernet clock reset instead of ethernet clock initialization (https://patchwork.ozlabs.org/patch/1286697) - Squash fu540 cpu patches (https://patchwork.ozlabs.org/patch/1286699) (https://patchwork.ozlabs.org/patch/1286700) - Use spl_boot_device() instead of board_boot_order()
Changes in v8: - Remove SPL_CRC7_SUPPORT Kconfig option and compile crc7.o when CONFIG_MMC_SPI selected - Add "TODO" in drivers/ram/sifive/sdram_fu540.c - Remove unnecessary TODO from drivers/clk/sifive/fu540-prci.c - Make fu540-hifive-unleashed-a00-sdram-ddr4.dtsi file dual-licensed - Add 2 new patches sifive: fu540: Add sample SD gpt partition layout (https://patchwork.ozlabs.org/patch/1092) sifive: fu540: Add U-Boot proper sector start (https://patchwork.ozlabs.org/patch/1093) - Remove patch riscv: Enable cpu clock if it is present (https://patchwork.ozlabs.org/patch/1281573) - Update doc/board/sifive/fu540.rst for PLATFORM=generic
Changes in v7: - Standardize SD gpt partition layout - Add delay for SiFive OTP driver - Use DM way for corepll and ddrpll - Add new cpu fu540 (arch/riscv/cpu/fu540) - Update document for FU540 (doc/board/sifive/fu540.rst)
Changes in v6: - Typo Correction - Make fu540-c000-u-boot.dtsi and hifive-unleashed-a00-u-boot.dtsi Dual Licensed - Sync Hifive unleashed dts from Linux - Add arch/riscv/fu540 for FU540 specific code
Changes in v5: - Return read/write bytes for sifive_otp_read and sifive_otp_write - Correct Palmer's email address
Changes in v4: - Split misc DM driver patch into multiple patches - Added new SPL_CRC7_SUPPORT Kconfig option - Added DM driver for DDR - Added clk_enable and clk_disable ops in SiFive PRCI driver - Added early clock initialization for SPL in SiFive PRCI driver - Added early clock initialization for SPL in SiFive PRCI driver - Added SPL config options in sifive_fu540_defconfig instead of creatiing a new config file for SPL - Update fu540.rst on how to build and flash U-boot SPL
Changes in v3: - Remove arch-fu540 and arch-sifive from arch/riscv/include/asm/ - Split SPL patches into DDR and SPL and spl defconfig - Update fu540/MAINTAINERS file - Update fu540.rst on how to build and flash U-boot SPL
Changes in v2: - Add DM driver Sifive OTP - Split SPL patches into multiple patches - Add a seprate patch for _image_binary_end and crc7.c - Add a seprate patch to add board -u-boot.dtsi files - Update FU540 RISC-V documentation
Jagan Teki (2): sifive: fu540: Add sample SD gpt partition layout sifive: fu540: Add U-Boot proper sector start
Pragnesh Patel (17): misc: add driver for the SiFive otp controller riscv: sifive: fu540: Use OTP DM driver for serial environment variable riscv: Add _image_binary_end for SPL lib: Makefile: build crc7.c when CONFIG_MMC_SPI riscv: sifive: dts: fu540: Add board -u-boot.dtsi files sifive: fu540: add ddr driver sifive: dts: fu540: Add DDR controller and phy register settings riscv: sifive: dts: fu540: add U-Boot dmc node clk: sifive: fu540-prci: Add clock enable and disable ops clk: sifive: fu540-prci: Add ddr clock initialization clk: sifive: fu540-prci: Release ethernet clock reset riscv: sifive: dts: fu540: set ethernet clock rate riscv: dts: sifive: Sync hifive-unleashed-a00 dts from linux riscv: cpu: fu540: Add support for cpu fu540 riscv: sifive: fu540: add SPL configuration configs: fu540: Add config options for U-Boot SPL doc: sifive: fu540: Add description for OpenSBI generic platform
arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu540/Kconfig | 15 + arch/riscv/cpu/fu540/Makefile | 11 + arch/riscv/cpu/fu540/cpu.c | 22 + arch/riscv/cpu/fu540/dram.c | 38 + arch/riscv/cpu/fu540/spl.c | 23 + arch/riscv/cpu/u-boot-spl.lds | 1 + arch/riscv/dts/fu540-c000-u-boot.dtsi | 89 + arch/riscv/dts/fu540-c000.dtsi | 37 +- .../dts/fu540-hifive-unleashed-a00-ddr.dtsi | 1489 +++++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 22 + arch/riscv/dts/hifive-unleashed-a00.dts | 9 + arch/riscv/include/asm/arch-fu540/clk.h | 14 + arch/riscv/include/asm/arch-fu540/gpio.h | 38 + arch/riscv/include/asm/arch-fu540/spl.h | 14 + board/sifive/fu540/Kconfig | 18 +- board/sifive/fu540/Makefile | 4 + board/sifive/fu540/fu540.c | 134 +- board/sifive/fu540/spl.c | 74 + common/spl/Kconfig | 3 +- configs/sifive_fu540_defconfig | 8 + doc/board/sifive/fu540.rst | 135 +- drivers/clk/sifive/fu540-prci.c | 177 +- drivers/misc/Kconfig | 7 + drivers/misc/Makefile | 1 + drivers/misc/sifive-otp.c | 275 +++ drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/sifive/Kconfig | 13 + drivers/ram/sifive/Makefile | 6 + drivers/ram/sifive/fu540_ddr.c | 410 +++++ include/configs/sifive-fu540.h | 31 + lib/Makefile | 2 +- 33 files changed, 3018 insertions(+), 106 deletions(-) create mode 100644 arch/riscv/cpu/fu540/Kconfig create mode 100644 arch/riscv/cpu/fu540/Makefile create mode 100644 arch/riscv/cpu/fu540/cpu.c create mode 100644 arch/riscv/cpu/fu540/dram.c create mode 100644 arch/riscv/cpu/fu540/spl.c create mode 100644 arch/riscv/dts/fu540-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi create mode 100644 arch/riscv/include/asm/arch-fu540/clk.h create mode 100644 arch/riscv/include/asm/arch-fu540/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu540/spl.h create mode 100644 board/sifive/fu540/spl.c create mode 100644 drivers/misc/sifive-otp.c create mode 100644 drivers/ram/sifive/Kconfig create mode 100644 drivers/ram/sifive/Makefile create mode 100644 drivers/ram/sifive/fu540_ddr.c
Added a misc driver to handle OTP memory in SiFive SoCs.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- drivers/misc/Kconfig | 7 + drivers/misc/Makefile | 1 + drivers/misc/sifive-otp.c | 275 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 283 insertions(+) create mode 100644 drivers/misc/sifive-otp.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 81ed9eb209..6bb5bc77e9 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -68,6 +68,13 @@ config ROCKCHIP_OTP addressing and a length or through child-nodes that are generated based on the e-fuse map retrieved from the DTS.
+config SIFIVE_OTP + bool "SiFive eMemory OTP driver" + depends on MISC + help + Enable support for reading and writing the eMemory OTP on the + SiFive SoCs. + config VEXPRESS_CONFIG bool "Enable support for Arm Versatile Express config bus" depends on MISC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 68e0e7ad17..947bd3a647 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o obj-$(CONFIG_ROCKCHIP_OTP) += rockchip-otp.o obj-$(CONFIG_SANDBOX) += syscon_sandbox.o misc_sandbox.o +obj-$(CONFIG_SIFIVE_OTP) += sifive-otp.o obj-$(CONFIG_SMSC_LPC47M) += smsc_lpc47m.o obj-$(CONFIG_SMSC_SIO1007) += smsc_sio1007.o obj-$(CONFIG_STM32MP_FUSE) += stm32mp_fuse.o diff --git a/drivers/misc/sifive-otp.c b/drivers/misc/sifive-otp.c new file mode 100644 index 0000000000..92f08dde01 --- /dev/null +++ b/drivers/misc/sifive-otp.c @@ -0,0 +1,275 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * This is a driver for the eMemory EG004K32TQ028XW01 NeoFuse + * One-Time-Programmable (OTP) memory used within the SiFive FU540. + * It is documented in the FU540 manual here: + * https://www.sifive.com/documentation/chips/freedom-u540-c000-manual/ + * + * Copyright (C) 2018 Philipp Hug philipp@hug.cx + * Copyright (C) 2018 Joey Hewitt joey@joeyhewitt.com + * + * Copyright (C) 2020 SiFive, Inc + */ + +/* + * The FU540 stores 4096x32 bit (16KiB) values. + * Index 0x00-0xff are reserved for SiFive internal use. (first 1KiB) + * Right now first 1KiB is used to store only serial number. + */ + +#include <common.h> +#include <dm/device.h> +#include <dm/read.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/io.h> +#include <misc.h> + +#define BYTES_PER_FUSE 4 + +#define PA_RESET_VAL 0x00 +#define PAS_RESET_VAL 0x00 +#define PAIO_RESET_VAL 0x00 +#define PDIN_RESET_VAL 0x00 +#define PTM_RESET_VAL 0x00 + +#define PCLK_ENABLE_VAL BIT(0) +#define PCLK_DISABLE_VAL 0x00 + +#define PWE_WRITE_ENABLE BIT(0) +#define PWE_WRITE_DISABLE 0x00 + +#define PTM_FUSE_PROGRAM_VAL BIT(1) + +#define PCE_ENABLE_INPUT BIT(0) +#define PCE_DISABLE_INPUT 0x00 + +#define PPROG_ENABLE_INPUT BIT(0) +#define PPROG_DISABLE_INPUT 0x00 + +#define PTRIM_ENABLE_INPUT BIT(0) +#define PTRIM_DISABLE_INPUT 0x00 + +#define PDSTB_DEEP_STANDBY_ENABLE BIT(0) +#define PDSTB_DEEP_STANDBY_DISABLE 0x00 + +/* Tpw - Program Pulse width delay */ +#define TPW_DELAY 20 + +/* Tpwi - Program Pulse interval delay */ +#define TPWI_DELAY 5 + +/* Tasp - Program address setup delay */ +#define TASP_DELAY 1 + +/* Tcd - read data access delay */ +#define TCD_DELAY 40 + +/* Tkl - clok pulse low delay */ +#define TKL_DELAY 10 + +/* Tms - PTM mode setup delay */ +#define TMS_DELAY 1 + +struct sifive_otp_regs { + u32 pa; /* Address input */ + u32 paio; /* Program address input */ + u32 pas; /* Program redundancy cell selection input */ + u32 pce; /* OTP Macro enable input */ + u32 pclk; /* Clock input */ + u32 pdin; /* Write data input */ + u32 pdout; /* Read data output */ + u32 pdstb; /* Deep standby mode enable input (active low) */ + u32 pprog; /* Program mode enable input */ + u32 ptc; /* Test column enable input */ + u32 ptm; /* Test mode enable input */ + u32 ptm_rep;/* Repair function test mode enable input */ + u32 ptr; /* Test row enable input */ + u32 ptrim; /* Repair function enable input */ + u32 pwe; /* Write enable input (defines program cycle) */ +}; + +struct sifive_otp_platdata { + struct sifive_otp_regs __iomem *regs; + u32 total_fuses; +}; + +/* + * offset and size are assumed aligned to the size of the fuses (32-bit). + */ +static int sifive_otp_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + struct sifive_otp_regs *regs = (struct sifive_otp_regs *)plat->regs; + + /* Check if offset and size are multiple of BYTES_PER_FUSE */ + if ((size % BYTES_PER_FUSE) || (offset % BYTES_PER_FUSE)) { + printf("%s: size and offset must be multiple of 4.\n", + __func__); + return -EINVAL; + } + + int fuseidx = offset / BYTES_PER_FUSE; + int fusecount = size / BYTES_PER_FUSE; + + /* check bounds */ + if (offset < 0 || size < 0) + return -EINVAL; + if (fuseidx >= plat->total_fuses) + return -EINVAL; + if ((fuseidx + fusecount) > plat->total_fuses) + return -EINVAL; + + u32 fusebuf[fusecount]; + + /* init OTP */ + writel(PDSTB_DEEP_STANDBY_ENABLE, ®s->pdstb); + writel(PTRIM_ENABLE_INPUT, ®s->ptrim); + writel(PCE_ENABLE_INPUT, ®s->pce); + + /* read all requested fuses */ + for (unsigned int i = 0; i < fusecount; i++, fuseidx++) { + writel(fuseidx, ®s->pa); + + /* cycle clock to read */ + writel(PCLK_ENABLE_VAL, ®s->pclk); + ndelay(TCD_DELAY * 1000); + writel(PCLK_DISABLE_VAL, ®s->pclk); + ndelay(TKL_DELAY * 1000); + + /* read the value */ + fusebuf[i] = readl(®s->pdout); + } + + /* shut down */ + writel(PCE_DISABLE_INPUT, ®s->pce); + writel(PTRIM_DISABLE_INPUT, ®s->ptrim); + writel(PDSTB_DEEP_STANDBY_DISABLE, ®s->pdstb); + + /* copy out */ + memcpy(buf, fusebuf, size); + + return size; +} + +/* + * Caution: + * OTP can be written only once, so use carefully. + * + * offset and size are assumed aligned to the size of the fuses (32-bit). + */ +static int sifive_otp_write(struct udevice *dev, int offset, + const void *buf, int size) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + struct sifive_otp_regs *regs = (struct sifive_otp_regs *)plat->regs; + + /* Check if offset and size are multiple of BYTES_PER_FUSE */ + if ((size % BYTES_PER_FUSE) || (offset % BYTES_PER_FUSE)) { + printf("%s: size and offset must be multiple of 4.\n", + __func__); + return -EINVAL; + } + + int fuseidx = offset / BYTES_PER_FUSE; + int fusecount = size / BYTES_PER_FUSE; + u32 *write_buf = (u32 *)buf; + u32 write_data; + int i, pas, bit; + + /* check bounds */ + if (offset < 0 || size < 0) + return -EINVAL; + if (fuseidx >= plat->total_fuses) + return -EINVAL; + if ((fuseidx + fusecount) > plat->total_fuses) + return -EINVAL; + + /* init OTP */ + writel(PDSTB_DEEP_STANDBY_ENABLE, ®s->pdstb); + writel(PTRIM_ENABLE_INPUT, ®s->ptrim); + + /* reset registers */ + writel(PCLK_DISABLE_VAL, ®s->pclk); + writel(PA_RESET_VAL, ®s->pa); + writel(PAS_RESET_VAL, ®s->pas); + writel(PAIO_RESET_VAL, ®s->paio); + writel(PDIN_RESET_VAL, ®s->pdin); + writel(PWE_WRITE_DISABLE, ®s->pwe); + writel(PTM_FUSE_PROGRAM_VAL, ®s->ptm); + ndelay(TMS_DELAY * 1000); + + writel(PCE_ENABLE_INPUT, ®s->pce); + writel(PPROG_ENABLE_INPUT, ®s->pprog); + + /* write all requested fuses */ + for (i = 0; i < fusecount; i++, fuseidx++) { + writel(fuseidx, ®s->pa); + write_data = *(write_buf++); + + for (pas = 0; pas < 2; pas++) { + writel(pas, ®s->pas); + + for (bit = 0; bit < 32; bit++) { + writel(bit, ®s->paio); + writel(((write_data >> bit) & 1), + ®s->pdin); + ndelay(TASP_DELAY * 1000); + + writel(PWE_WRITE_ENABLE, ®s->pwe); + udelay(TPW_DELAY); + writel(PWE_WRITE_DISABLE, ®s->pwe); + udelay(TPWI_DELAY); + } + } + + writel(PAS_RESET_VAL, ®s->pas); + } + + /* shut down */ + writel(PWE_WRITE_DISABLE, ®s->pwe); + writel(PPROG_DISABLE_INPUT, ®s->pprog); + writel(PCE_DISABLE_INPUT, ®s->pce); + writel(PTM_RESET_VAL, ®s->ptm); + + writel(PTRIM_DISABLE_INPUT, ®s->ptrim); + writel(PDSTB_DEEP_STANDBY_DISABLE, ®s->pdstb); + + return size; +} + +static int sifive_otp_ofdata_to_platdata(struct udevice *dev) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + int ret; + + plat->regs = dev_read_addr_ptr(dev); + + ret = dev_read_u32(dev, "fuse-count", &plat->total_fuses); + if (ret < 0) { + pr_err(""fuse-count" not found\n"); + return ret; + } + + return 0; +} + +static const struct misc_ops sifive_otp_ops = { + .read = sifive_otp_read, + .write = sifive_otp_write, +}; + +static const struct udevice_id sifive_otp_ids[] = { + { .compatible = "sifive,fu540-c000-otp" }, + {} +}; + +U_BOOT_DRIVER(sifive_otp) = { + .name = "sifive_otp", + .id = UCLASS_MISC, + .of_match = sifive_otp_ids, + .ofdata_to_platdata = sifive_otp_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sifive_otp_platdata), + .ops = &sifive_otp_ops, +};
Use the OTP DM driver to set the serial environment variable.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 14 +++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 2 + board/sifive/fu540/Kconfig | 2 + board/sifive/fu540/fu540.c | 113 +++++++----------- 4 files changed, 58 insertions(+), 73 deletions(-) create mode 100644 arch/riscv/dts/fu540-c000-u-boot.dtsi
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi new file mode 100644 index 0000000000..db55773bd2 --- /dev/null +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2019 SiFive, Inc + */ + +/ { + soc { + otp: otp@10070000 { + compatible = "sifive,fu540-c000-otp"; + reg = <0x0 0x10070000 0x0 0x0FFF>; + fuse-count = <0x1000>; + }; + }; +}; diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 2aebfab646..9af089ffe7 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "fu540-c000-u-boot.dtsi" + / { aliases { spi0 = &qspi0; diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 75661f35f8..4330ac4491 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -51,5 +51,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SIFIVE_GPIO imply CMD_GPIO imply SMP + imply MISC + imply SIFIVE_OTP
endif diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index df57b6ecc2..ef2c40da27 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -6,101 +6,68 @@ * Anup Patel anup.patel@wdc.com */
-#include <common.h> #include <dm.h> #include <env.h> #include <init.h> +#include <log.h> #include <linux/bug.h> #include <linux/delay.h> #include <linux/io.h> +#include <misc.h> + +/* + * This define is a value used for error/unknown serial. + * If we really care about distinguishing errors and 0 is + * valid, we'll need a different one. + */ +#define ERROR_READING_SERIAL_NUMBER 0
#ifdef CONFIG_MISC_INIT_R
-#define FU540_OTP_BASE_ADDR 0x10070000 - -struct fu540_otp_regs { - u32 pa; /* Address input */ - u32 paio; /* Program address input */ - u32 pas; /* Program redundancy cell selection input */ - u32 pce; /* OTP Macro enable input */ - u32 pclk; /* Clock input */ - u32 pdin; /* Write data input */ - u32 pdout; /* Read data output */ - u32 pdstb; /* Deep standby mode enable input (active low) */ - u32 pprog; /* Program mode enable input */ - u32 ptc; /* Test column enable input */ - u32 ptm; /* Test mode enable input */ - u32 ptm_rep;/* Repair function test mode enable input */ - u32 ptr; /* Test row enable input */ - u32 ptrim; /* Repair function enable input */ - u32 pwe; /* Write enable input (defines program cycle) */ -} __packed; - -#define BYTES_PER_FUSE 4 -#define NUM_FUSES 0x1000 - -static int fu540_otp_read(int offset, void *buf, int size) +#if CONFIG_IS_ENABLED(SIFIVE_OTP) +static u32 otp_read_serialnum(struct udevice *dev) { - struct fu540_otp_regs *regs = (void __iomem *)FU540_OTP_BASE_ADDR; - unsigned int i; - int fuseidx = offset / BYTES_PER_FUSE; - int fusecount = size / BYTES_PER_FUSE; - u32 fusebuf[fusecount]; - - /* check bounds */ - if (offset < 0 || size < 0) - return -EINVAL; - if (fuseidx >= NUM_FUSES) - return -EINVAL; - if ((fuseidx + fusecount) > NUM_FUSES) - return -EINVAL; + int ret; + u32 serial[2] = {0};
- /* init OTP */ - writel(0x01, ®s->pdstb); /* wake up from stand-by */ - writel(0x01, ®s->ptrim); /* enable repair function */ - writel(0x01, ®s->pce); /* enable input */ - - /* read all requested fuses */ - for (i = 0; i < fusecount; i++, fuseidx++) { - writel(fuseidx, ®s->pa); - - /* cycle clock to read */ - writel(0x01, ®s->pclk); - mdelay(1); - writel(0x00, ®s->pclk); - mdelay(1); - - /* read the value */ - fusebuf[i] = readl(®s->pdout); - } + for (int i = 0xfe * 4; i > 0; i -= 8) { + ret = misc_read(dev, i, serial, sizeof(serial));
- /* shut down */ - writel(0, ®s->pce); - writel(0, ®s->ptrim); - writel(0, ®s->pdstb); + if (ret != sizeof(serial)) { + printf("%s: error reading serial from OTP\n", __func__); + break; + }
- /* copy out */ - memcpy(buf, fusebuf, size); + if (serial[0] == ~serial[1]) + return serial[0]; + }
- return 0; + return ERROR_READING_SERIAL_NUMBER; } +#endif
static u32 fu540_read_serialnum(void) { + u32 serial = ERROR_READING_SERIAL_NUMBER; + +#if CONFIG_IS_ENABLED(SIFIVE_OTP) + struct udevice *dev; int ret; - u32 serial[2] = {0};
- for (int i = 0xfe * 4; i > 0; i -= 8) { - ret = fu540_otp_read(i, serial, sizeof(serial)); - if (ret) { - printf("%s: error reading from OTP\n", __func__); - break; - } - if (serial[0] == ~serial[1]) - return serial[0]; + /* init OTP */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(sifive_otp), &dev); + + if (ret) { + debug("%s: could not find otp device\n", __func__); + return serial; }
- return 0; + /* read serial from OTP and set env var */ + serial = otp_read_serialnum(dev); +#endif + + return serial; }
static void fu540_setup_macaddr(u32 serialnum)
For SPL_SEPARATE_BSS, Device tree will be put at _image_binary_end
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Anup Patel anup.patel@wdc.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/cpu/u-boot-spl.lds | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/riscv/cpu/u-boot-spl.lds b/arch/riscv/cpu/u-boot-spl.lds index 955dd3106d..d0495ce248 100644 --- a/arch/riscv/cpu/u-boot-spl.lds +++ b/arch/riscv/cpu/u-boot-spl.lds @@ -72,6 +72,7 @@ SECTIONS . = ALIGN(4);
_end = .; + _image_binary_end = .;
.bss : { __bss_start = .;
When build U-Boot SPL, meet an issue of undefined reference to 'crc7' for drivers/mmc/mmc_spi.c, so let's compile crc7.c when CONFIG_MMC_SPI selected.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Bin Meng bmeng.cn@gmail.com Acked-by: Jagan Teki jagan@amarulasolutions.com --- lib/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/Makefile b/lib/Makefile index 6e688afa68..dc5761966c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -30,7 +30,6 @@ obj-y += charset.o endif endif obj-$(CONFIG_USB_TTY) += circbuf.o -obj-y += crc7.o obj-y += crc8.o obj-y += crc16.o obj-$(CONFIG_ERRNO_STR) += errno_str.o @@ -90,6 +89,7 @@ obj-y += errno.o obj-y += display_options.o CFLAGS_display_options.o := $(if $(BUILD_TAG),-DBUILD_TAG='"$(BUILD_TAG)"') obj-$(CONFIG_BCH) += bch.o +obj-$(CONFIG_MMC_SPI) += crc7.o obj-y += crc32.o obj-$(CONFIG_CRC32C) += crc32c.o obj-y += ctype.o
Devicetree files in FU540 platform is synced from Linux, like other platforms does. Apart from these U-Boot in FU540 would also require some U-Boot specific node like clint.
So, create board specific -u-boot.dtsi files. This would help of maintain U-Boot specific changes separately without touching Linux dts(i) files which indeed easy for syncing from Linux between releases.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Bin Meng bmeng.cn@gmail.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 61 +++++++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 15 +++++ 2 files changed, 76 insertions(+)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index db55773bd2..fbfe296a03 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -4,11 +4,72 @@ */
/ { + cpus { + assigned-clocks = <&prci PRCI_CLK_COREPLL>; + assigned-clock-rates = <1000000000>; + u-boot,dm-spl; + cpu0: cpu@0 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + status = "okay"; + cpu0_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu1: cpu@1 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu1_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu2: cpu@2 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu2_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu3: cpu@3 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu3_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu4: cpu@4 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu4_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + }; + soc { + u-boot,dm-spl; otp: otp@10070000 { compatible = "sifive,fu540-c000-otp"; reg = <0x0 0x10070000 0x0 0x0FFF>; fuse-count = <0x1000>; }; + clint@2000000 { + compatible = "riscv,clint0"; + interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 &cpu1_intc 3 &cpu1_intc 7 &cpu2_intc 3 &cpu2_intc 7 &cpu3_intc 3 &cpu3_intc 7 &cpu4_intc 3 &cpu4_intc 7>; + reg = <0x0 0x2000000 0x0 0xc0000>; + u-boot,dm-spl; + }; }; }; + +&prci { + u-boot,dm-spl; +}; + +&uart0 { + u-boot,dm-spl; +}; + +&qspi2 { + u-boot,dm-spl; +}; diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 9af089ffe7..9787332bf1 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -10,4 +10,19 @@ spi0 = &qspi0; spi2 = &qspi2; }; + + hfclk { + u-boot,dm-spl; + }; + + rtcclk { + u-boot,dm-spl; + }; + +}; + +&qspi2 { + mmc@0 { + u-boot,dm-spl; + }; };
Add driver for fu540 to support ddr initialization in SPL. This driver is based on FSBL (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Tested-by: Bin Meng bmeng.cn@gmail.com --- board/sifive/fu540/Kconfig | 2 + drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/sifive/Kconfig | 13 ++ drivers/ram/sifive/Makefile | 6 + drivers/ram/sifive/fu540_ddr.c | 410 +++++++++++++++++++++++++++++++++ 6 files changed, 434 insertions(+) create mode 100644 drivers/ram/sifive/Kconfig create mode 100644 drivers/ram/sifive/Makefile create mode 100644 drivers/ram/sifive/fu540_ddr.c
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 4330ac4491..d41c305227 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -19,6 +19,8 @@ config SYS_TEXT_BASE config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select GENERIC_RISCV + select RAM + select SPL_RAM if SPL imply CMD_DHCP imply CMD_EXT2 imply CMD_EXT4 diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 56fea7c94c..7e6e981897 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -74,4 +74,5 @@ config IMXRT_SDRAM This driver is for the sdram memory interface with the SEMC.
source "drivers/ram/rockchip/Kconfig" +source "drivers/ram/sifive/Kconfig" source "drivers/ram/stm32mp1/Kconfig" diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 5c897410c6..769c9d6218 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -17,3 +17,5 @@ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_K3_J721E_DDRSS) += k3-j721e/
obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o + +obj-$(CONFIG_RAM_SIFIVE) += sifive/ diff --git a/drivers/ram/sifive/Kconfig b/drivers/ram/sifive/Kconfig new file mode 100644 index 0000000000..6aca22ab2a --- /dev/null +++ b/drivers/ram/sifive/Kconfig @@ -0,0 +1,13 @@ +config RAM_SIFIVE + bool "Ram drivers support for SiFive SoCs" + depends on RAM && RISCV + default y + help + This enables support for ram drivers of SiFive SoCs. + +config SIFIVE_FU540_DDR + bool "SiFive FU540 DDR driver" + depends on RAM_SIFIVE + default y if TARGET_SIFIVE_FU540 + help + This enables DDR support for the platforms based on SiFive FU540 SoC. diff --git a/drivers/ram/sifive/Makefile b/drivers/ram/sifive/Makefile new file mode 100644 index 0000000000..d66efec264 --- /dev/null +++ b/drivers/ram/sifive/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2020 SiFive, Inc +# + +obj-$(CONFIG_SIFIVE_FU540_DDR) += fu540_ddr.o diff --git a/drivers/ram/sifive/fu540_ddr.c b/drivers/ram/sifive/fu540_ddr.c new file mode 100644 index 0000000000..f8f8ca9ad5 --- /dev/null +++ b/drivers/ram/sifive/fu540_ddr.c @@ -0,0 +1,410 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * (C) Copyright 2020 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <ram.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <clk.h> +#include <wait_bit.h> +#include <linux/bitops.h> + +#define DENALI_CTL_0 0 +#define DENALI_CTL_21 21 +#define DENALI_CTL_120 120 +#define DENALI_CTL_132 132 +#define DENALI_CTL_136 136 +#define DENALI_CTL_170 170 +#define DENALI_CTL_181 181 +#define DENALI_CTL_182 182 +#define DENALI_CTL_184 184 +#define DENALI_CTL_208 208 +#define DENALI_CTL_209 209 +#define DENALI_CTL_210 210 +#define DENALI_CTL_212 212 +#define DENALI_CTL_214 214 +#define DENALI_CTL_216 216 +#define DENALI_CTL_224 224 +#define DENALI_CTL_225 225 +#define DENALI_CTL_260 260 + +#define DENALI_PHY_1152 1152 +#define DENALI_PHY_1214 1214 + +#define PAYLOAD_DEST 0x80000000 +#define DDR_MEM_SIZE (8UL * 1024UL * 1024UL * 1024UL) + +#define DRAM_CLASS_OFFSET 8 +#define DRAM_CLASS_DDR4 0xA +#define OPTIMAL_RMODW_EN_OFFSET 0 +#define DISABLE_RD_INTERLEAVE_OFFSET 16 +#define OUT_OF_RANGE_OFFSET 1 +#define MULTIPLE_OUT_OF_RANGE_OFFSET 2 +#define PORT_COMMAND_CHANNEL_ERROR_OFFSET 7 +#define MC_INIT_COMPLETE_OFFSET 8 +#define LEVELING_OPERATION_COMPLETED_OFFSET 22 +#define DFI_PHY_WRLELV_MODE_OFFSET 24 +#define DFI_PHY_RDLVL_MODE_OFFSET 24 +#define DFI_PHY_RDLVL_GATE_MODE_OFFSET 0 +#define VREF_EN_OFFSET 24 +#define PORT_ADDR_PROTECTION_EN_OFFSET 0 +#define AXI0_ADDRESS_RANGE_ENABLE 8 +#define AXI0_RANGE_PROT_BITS_0_OFFSET 24 +#define RDLVL_EN_OFFSET 16 +#define RDLVL_GATE_EN_OFFSET 24 +#define WRLVL_EN_OFFSET 0 + +#define PHY_RX_CAL_DQ0_0_OFFSET 0 +#define PHY_RX_CAL_DQ1_0_OFFSET 16 + +struct fu540_ddrctl { + volatile u32 denali_ctl[265]; +}; + +struct fu540_ddrphy { + volatile u32 denali_phy[1215]; +}; + +/** + * struct fu540_ddr_info + * + * @dev : pointer for the device + * @info : UCLASS RAM information + * @ctl : DDR controller base address + * @phy : DDR PHY base address + * @ctrl : DDR control base address + * @physical_filter_ctrl : DDR physical filter control base address + */ +struct fu540_ddr_info { + struct udevice *dev; + struct ram_info info; + struct fu540_ddrctl *ctl; + struct fu540_ddrphy *phy; + struct clk ddr_clk; + u32 *physical_filter_ctrl; +}; + +#if defined(CONFIG_SPL_BUILD) +struct fu540_ddr_params { + struct fu540_ddrctl pctl_regs; + struct fu540_ddrphy phy_regs; +}; + +struct sifive_dmc_plat { + struct fu540_ddr_params ddr_params; +}; + +/* + * TODO : It can be possible to use common sdram_copy_to_reg() API + * n: Unit bytes + */ +static void sdram_copy_to_reg(volatile u32 *dest, + volatile u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) { + writel(*src, dest); + src++; + dest++; + } +} + +static void fu540_ddr_setup_range_protection(volatile u32 *ctl, u64 end_addr) +{ + u32 end_addr_16kblocks = ((end_addr >> 14) & 0x7FFFFF) - 1; + + writel(0x0, DENALI_CTL_209 + ctl); + writel(end_addr_16kblocks, DENALI_CTL_210 + ctl); + writel(0x0, DENALI_CTL_212 + ctl); + writel(0x0, DENALI_CTL_214 + ctl); + writel(0x0, DENALI_CTL_216 + ctl); + setbits_le32(DENALI_CTL_224 + ctl, + 0x3 << AXI0_RANGE_PROT_BITS_0_OFFSET); + writel(0xFFFFFFFF, DENALI_CTL_225 + ctl); + setbits_le32(DENALI_CTL_208 + ctl, 0x1 << AXI0_ADDRESS_RANGE_ENABLE); + setbits_le32(DENALI_CTL_208 + ctl, + 0x1 << PORT_ADDR_PROTECTION_EN_OFFSET); +} + +static void fu540_ddr_start(volatile u32 *ctl, u32 *physical_filter_ctrl, + u64 ddr_end) +{ + volatile u64 *filterreg = (volatile u64 *)physical_filter_ctrl; + + setbits_le32(DENALI_CTL_0 + ctl, 0x1); + + wait_for_bit_le32((void *)ctl + DENALI_CTL_132, + BIT(MC_INIT_COMPLETE_OFFSET), false, 100, false); + + /* Disable the BusBlocker in front of the controller AXI slave ports */ + filterreg[0] = 0x0f00000000000000UL | (ddr_end >> 2); +} + +static void fu540_ddr_check_errata(u32 regbase, u32 updownreg) +{ + u64 fails = 0; + u32 dq = 0; + u32 down, up; + u8 failc0, failc1; + u32 phy_rx_cal_dqn_0_offset; + + for (u32 bit = 0; bit < 2; bit++) { + if (bit == 0) { + phy_rx_cal_dqn_0_offset = + PHY_RX_CAL_DQ0_0_OFFSET; + } else { + phy_rx_cal_dqn_0_offset = + PHY_RX_CAL_DQ1_0_OFFSET; + } + + down = (updownreg >> + phy_rx_cal_dqn_0_offset) & 0x3F; + up = (updownreg >> + (phy_rx_cal_dqn_0_offset + 6)) & + 0x3F; + + failc0 = ((down == 0) && (up == 0x3F)); + failc1 = ((up == 0) && (down == 0x3F)); + + /* print error message on failure */ + if (failc0 || failc1) { + if (fails == 0) + printf("DDR error in fixing up\n"); + + fails |= (1 << dq); + + char slicelsc = '0'; + char slicemsc = '0'; + + slicelsc += (dq % 10); + slicemsc += (dq / 10); + printf("S "); + printf("%c", slicemsc); + printf("%c", slicelsc); + + if (failc0) + printf("U"); + else + printf("D"); + + printf("\n"); + } + dq++; + } +} + +static u64 fu540_ddr_phy_fixup(volatile u32 *ddrphyreg) +{ + u32 slicebase = 0; + + /* check errata condition */ + for (u32 slice = 0; slice < 8; slice++) { + u32 regbase = slicebase + 34; + + for (u32 reg = 0; reg < 4; reg++) { + u32 updownreg = readl(regbase + reg + ddrphyreg); + + fu540_ddr_check_errata(regbase, updownreg); + } + slicebase += 128; + } + + return(0); +} + +static u32 fu540_ddr_get_dram_class(volatile u32 *ctl) +{ + u32 reg = readl(DENALI_CTL_0 + ctl); + + return ((reg >> DRAM_CLASS_OFFSET) & 0xF); +} + +static int fu540_ddr_setup(struct udevice *dev) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + struct sifive_dmc_plat *plat = dev_get_platdata(dev); + struct fu540_ddr_params *params = &plat->ddr_params; + volatile u32 *denali_ctl = priv->ctl->denali_ctl; + volatile u32 *denali_phy = priv->phy->denali_phy; + const u64 ddr_size = DDR_MEM_SIZE; + const u64 ddr_end = PAYLOAD_DEST + ddr_size; + int ret, i; + u32 physet; + + ret = dev_read_u32_array(dev, "sifive,ddr-params", + (u32 *)&plat->ddr_params, + sizeof(plat->ddr_params) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read sifive,ddr-params %d\n", + __func__, ret); + return ret; + } + + sdram_copy_to_reg(priv->ctl->denali_ctl, + params->pctl_regs.denali_ctl, + sizeof(struct fu540_ddrctl)); + + /* phy reset */ + for (i = DENALI_PHY_1152; i <= DENALI_PHY_1214; i++) { + physet = params->phy_regs.denali_phy[i]; + priv->phy->denali_phy[i] = physet; + } + + for (i = 0; i < DENALI_PHY_1152; i++) { + physet = params->phy_regs.denali_phy[i]; + priv->phy->denali_phy[i] = physet; + } + + /* Disable read interleave DENALI_CTL_120 */ + setbits_le32(DENALI_CTL_120 + denali_ctl, + 1 << DISABLE_RD_INTERLEAVE_OFFSET); + + /* Disable optimal read/modify/write logic DENALI_CTL_21 */ + clrbits_le32(DENALI_CTL_21 + denali_ctl, 1 << OPTIMAL_RMODW_EN_OFFSET); + + /* Enable write Leveling DENALI_CTL_170 */ + setbits_le32(DENALI_CTL_170 + denali_ctl, (1 << WRLVL_EN_OFFSET) + | (1 << DFI_PHY_WRLELV_MODE_OFFSET)); + + /* Enable read leveling DENALI_CTL_181 and DENALI_CTL_260 */ + setbits_le32(DENALI_CTL_181 + denali_ctl, + 1 << DFI_PHY_RDLVL_MODE_OFFSET); + setbits_le32(DENALI_CTL_260 + denali_ctl, 1 << RDLVL_EN_OFFSET); + + /* Enable read leveling gate DENALI_CTL_260 and DENALI_CTL_182 */ + setbits_le32(DENALI_CTL_260 + denali_ctl, 1 << RDLVL_GATE_EN_OFFSET); + setbits_le32(DENALI_CTL_182 + denali_ctl, + 1 << DFI_PHY_RDLVL_GATE_MODE_OFFSET); + + if (fu540_ddr_get_dram_class(denali_ctl) == DRAM_CLASS_DDR4) { + /* Enable vref training DENALI_CTL_184 */ + setbits_le32(DENALI_CTL_184 + denali_ctl, 1 << VREF_EN_OFFSET); + } + + /* Mask off leveling completion interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, + 1 << LEVELING_OPERATION_COMPLETED_OFFSET); + + /* Mask off MC init complete interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, 1 << MC_INIT_COMPLETE_OFFSET); + + /* Mask off out of range interrupts DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, (1 << OUT_OF_RANGE_OFFSET) + | (1 << MULTIPLE_OUT_OF_RANGE_OFFSET)); + + /* set up range protection */ + fu540_ddr_setup_range_protection(denali_ctl, DDR_MEM_SIZE); + + /* Mask off port command error interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, + 1 << PORT_COMMAND_CHANNEL_ERROR_OFFSET); + + fu540_ddr_start(denali_ctl, priv->physical_filter_ctrl, ddr_end); + + fu540_ddr_phy_fixup(denali_phy); + + /* check size */ + priv->info.size = get_ram_size((long *)priv->info.base, + DDR_MEM_SIZE); + + debug("%s : %lx\n", __func__, priv->info.size); + + /* check memory access for all memory */ + if (priv->info.size != DDR_MEM_SIZE) { + printf("DDR invalid size : 0x%lx, expected 0x%lx\n", + priv->info.size, DDR_MEM_SIZE); + return -EINVAL; + } + + return 0; +} +#endif + +static int fu540_ddr_probe(struct udevice *dev) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + +#if defined(CONFIG_SPL_BUILD) + struct regmap *map; + int ret; + u32 clock = 0; + + debug("FU540 DDR probe\n"); + priv->dev = dev; + + ret = regmap_init_mem(dev_ofnode(dev), &map); + if (ret) + return ret; + + ret = clk_get_by_index(dev, 0, &priv->ddr_clk); + if (ret) { + debug("clk get failed %d\n", ret); + return ret; + } + + ret = dev_read_u32(dev, "clock-frequency", &clock); + if (ret) { + debug("clock-frequency not found in dt %d\n", ret); + return ret; + } else { + ret = clk_set_rate(&priv->ddr_clk, clock); + if (ret < 0) { + debug("Could not set DDR clock\n"); + return ret; + } + } + + ret = clk_enable(&priv->ddr_clk); + priv->ctl = regmap_get_range(map, 0); + priv->phy = regmap_get_range(map, 1); + priv->physical_filter_ctrl = regmap_get_range(map, 2); + + priv->info.base = CONFIG_SYS_SDRAM_BASE; + + priv->info.size = 0; + return fu540_ddr_setup(dev); +#else + priv->info.base = CONFIG_SYS_SDRAM_BASE; + priv->info.size = DDR_MEM_SIZE; +#endif + return 0; +} + +static int fu540_ddr_get_info(struct udevice *dev, struct ram_info *info) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops fu540_ddr_ops = { + .get_info = fu540_ddr_get_info, +}; + +static const struct udevice_id fu540_ddr_ids[] = { + { .compatible = "sifive,fu540-c000-ddr" }, + { } +}; + +U_BOOT_DRIVER(fu540_ddr) = { + .name = "fu540_ddr", + .id = UCLASS_RAM, + .of_match = fu540_ddr_ids, + .ops = &fu540_ddr_ops, + .probe = fu540_ddr_probe, + .priv_auto_alloc_size = sizeof(struct fu540_ddr_info), +#if defined(CONFIG_SPL_BUILD) + .platdata_auto_alloc_size = sizeof(struct sifive_dmc_plat), +#endif +};
Add DDR controller and phy register settings, taken from fsbl (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- .../dts/fu540-hifive-unleashed-a00-ddr.dtsi | 1489 +++++++++++++++++ 1 file changed, 1489 insertions(+) create mode 100644 arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi
diff --git a/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi b/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi new file mode 100644 index 0000000000..6ed5ccdbcb --- /dev/null +++ b/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi @@ -0,0 +1,1489 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2020 SiFive, Inc + */ + +&dmc { + sifive,ddr-params = < + 0x00000a00 /* DENALI_CTL_00_DATA */ + 0x00000000 /* DENALI_CTL_01_DATA */ + 0x00000000 /* DENALI_CTL_02_DATA */ + 0x00000000 /* DENALI_CTL_03_DATA */ + 0x00000000 /* DENALI_CTL_04_DATA */ + 0x00000000 /* DENALI_CTL_05_DATA */ + 0x0000000a /* DENALI_CTL_06_DATA */ + 0x0002d362 /* DENALI_CTL_07_DATA */ + 0x00071073 /* DENALI_CTL_08_DATA */ + 0x0a1c0255 /* DENALI_CTL_09_DATA */ + 0x1c1c0400 /* DENALI_CTL_10_DATA */ + 0x0404990b /* DENALI_CTL_11_DATA */ + 0x2b050405 /* DENALI_CTL_12_DATA */ + 0x0e0c081e /* DENALI_CTL_13_DATA */ + 0x08090914 /* DENALI_CTL_14_DATA */ + 0x00fde718 /* DENALI_CTL_15_DATA */ + 0x00180a05 /* DENALI_CTL_16_DATA */ + 0x008b130e /* DENALI_CTL_17_DATA */ + 0x01000118 /* DENALI_CTL_18_DATA */ + 0x0e032101 /* DENALI_CTL_19_DATA */ + 0x00000000 /* DENALI_CTL_20_DATA */ + 0x00000101 /* DENALI_CTL_21_DATA */ + 0x00000000 /* DENALI_CTL_22_DATA */ + 0x0a000000 /* DENALI_CTL_23_DATA */ + 0x00000000 /* DENALI_CTL_24_DATA */ + 0x01450100 /* DENALI_CTL_25_DATA */ + 0x00001c36 /* DENALI_CTL_26_DATA */ + 0x00000005 /* DENALI_CTL_27_DATA */ + 0x00170006 /* DENALI_CTL_28_DATA */ + 0x014e0300 /* DENALI_CTL_29_DATA */ + 0x03010000 /* DENALI_CTL_30_DATA */ + 0x000a0e00 /* DENALI_CTL_31_DATA */ + 0x04030200 /* DENALI_CTL_32_DATA */ + 0x0000031f /* DENALI_CTL_33_DATA */ + 0x00070004 /* DENALI_CTL_34_DATA */ + 0x00000000 /* DENALI_CTL_35_DATA */ + 0x00000000 /* DENALI_CTL_36_DATA */ + 0x00000000 /* DENALI_CTL_37_DATA */ + 0x00000000 /* DENALI_CTL_38_DATA */ + 0x00000000 /* DENALI_CTL_39_DATA */ + 0x00000000 /* DENALI_CTL_40_DATA */ + 0x00000000 /* DENALI_CTL_41_DATA */ + 0x00000000 /* DENALI_CTL_42_DATA */ + 0x00000000 /* DENALI_CTL_43_DATA */ + 0x00000000 /* DENALI_CTL_44_DATA */ + 0x00000000 /* DENALI_CTL_45_DATA */ + 0x00000000 /* DENALI_CTL_46_DATA */ + 0x00000000 /* DENALI_CTL_47_DATA */ + 0x00000000 /* DENALI_CTL_48_DATA */ + 0x00000000 /* DENALI_CTL_49_DATA */ + 0x00000000 /* DENALI_CTL_50_DATA */ + 0x00000000 /* DENALI_CTL_51_DATA */ + 0x00000000 /* DENALI_CTL_52_DATA */ + 0x00000000 /* DENALI_CTL_53_DATA */ + 0x00000000 /* DENALI_CTL_54_DATA */ + 0x00000000 /* DENALI_CTL_55_DATA */ + 0x00000000 /* DENALI_CTL_56_DATA */ + 0x00000000 /* DENALI_CTL_57_DATA */ + 0x00000000 /* DENALI_CTL_58_DATA */ + 0x00000000 /* DENALI_CTL_59_DATA */ + 0x00000424 /* DENALI_CTL_60_DATA */ + 0x00000201 /* DENALI_CTL_61_DATA */ + 0x00001008 /* DENALI_CTL_62_DATA */ + 0x00000000 /* DENALI_CTL_63_DATA */ + 0x00000200 /* DENALI_CTL_64_DATA */ + 0x00000000 /* DENALI_CTL_65_DATA */ + 0x00000481 /* DENALI_CTL_66_DATA */ + 0x00000400 /* DENALI_CTL_67_DATA */ + 0x00000424 /* DENALI_CTL_68_DATA */ + 0x00000201 /* DENALI_CTL_69_DATA */ + 0x00001008 /* DENALI_CTL_70_DATA */ + 0x00000000 /* DENALI_CTL_71_DATA */ + 0x00000200 /* DENALI_CTL_72_DATA */ + 0x00000000 /* DENALI_CTL_73_DATA */ + 0x00000481 /* DENALI_CTL_74_DATA */ + 0x00000400 /* DENALI_CTL_75_DATA */ + 0x01010000 /* DENALI_CTL_76_DATA */ + 0x00000000 /* DENALI_CTL_77_DATA */ + 0x00000000 /* DENALI_CTL_78_DATA */ + 0x00000000 /* DENALI_CTL_79_DATA */ + 0x00000000 /* DENALI_CTL_80_DATA */ + 0x00000000 /* DENALI_CTL_81_DATA */ + 0x00000000 /* DENALI_CTL_82_DATA */ + 0x00000000 /* DENALI_CTL_83_DATA */ + 0x00000000 /* DENALI_CTL_84_DATA */ + 0x00000000 /* DENALI_CTL_85_DATA */ + 0x00000000 /* DENALI_CTL_86_DATA */ + 0x00000000 /* DENALI_CTL_87_DATA */ + 0x00000000 /* DENALI_CTL_88_DATA */ + 0x00000000 /* DENALI_CTL_89_DATA */ + 0x00000000 /* DENALI_CTL_90_DATA */ + 0x00000000 /* DENALI_CTL_91_DATA */ + 0x00000000 /* DENALI_CTL_92_DATA */ + 0x00000000 /* DENALI_CTL_93_DATA */ + 0x00000000 /* DENALI_CTL_94_DATA */ + 0x00000000 /* DENALI_CTL_95_DATA */ + 0x00000000 /* DENALI_CTL_96_DATA */ + 0x00000000 /* DENALI_CTL_97_DATA */ + 0x00000000 /* DENALI_CTL_98_DATA */ + 0x00000000 /* DENALI_CTL_99_DATA */ + 0x00000000 /* DENALI_CTL_100_DATA */ + 0x00000000 /* DENALI_CTL_101_DATA */ + 0x00000000 /* DENALI_CTL_102_DATA */ + 0x00000000 /* DENALI_CTL_103_DATA */ + 0x00000000 /* DENALI_CTL_104_DATA */ + 0x00000003 /* DENALI_CTL_105_DATA */ + 0x00000000 /* DENALI_CTL_106_DATA */ + 0x00000000 /* DENALI_CTL_107_DATA */ + 0x00000000 /* DENALI_CTL_108_DATA */ + 0x00000000 /* DENALI_CTL_109_DATA */ + 0x01000000 /* DENALI_CTL_110_DATA */ + 0x00040000 /* DENALI_CTL_111_DATA */ + 0x00800200 /* DENALI_CTL_112_DATA */ + 0x00000200 /* DENALI_CTL_113_DATA */ + 0x00000040 /* DENALI_CTL_114_DATA */ + 0x01000100 /* DENALI_CTL_115_DATA */ + 0x0a000002 /* DENALI_CTL_116_DATA */ + 0x0101ffff /* DENALI_CTL_117_DATA */ + 0x01010101 /* DENALI_CTL_118_DATA */ + 0x01010101 /* DENALI_CTL_119_DATA */ + 0x0000010b /* DENALI_CTL_120_DATA */ + 0x00000c01 /* DENALI_CTL_121_DATA */ + 0x00000000 /* DENALI_CTL_122_DATA */ + 0x00000000 /* DENALI_CTL_123_DATA */ + 0x00000000 /* DENALI_CTL_124_DATA */ + 0x00000000 /* DENALI_CTL_125_DATA */ + 0x00030300 /* DENALI_CTL_126_DATA */ + 0x00000000 /* DENALI_CTL_127_DATA */ + 0x00010001 /* DENALI_CTL_128_DATA */ + 0x00000000 /* DENALI_CTL_129_DATA */ + 0x00000000 /* DENALI_CTL_130_DATA */ + 0x00000000 /* DENALI_CTL_131_DATA */ + 0x00000000 /* DENALI_CTL_132_DATA */ + 0x00000000 /* DENALI_CTL_133_DATA */ + 0x00000000 /* DENALI_CTL_134_DATA */ + 0x00000000 /* DENALI_CTL_135_DATA */ + 0x00000000 /* DENALI_CTL_136_DATA */ + 0x00000000 /* DENALI_CTL_137_DATA */ + 0x00000000 /* DENALI_CTL_138_DATA */ + 0x00000000 /* DENALI_CTL_139_DATA */ + 0x00000000 /* DENALI_CTL_140_DATA */ + 0x00000000 /* DENALI_CTL_141_DATA */ + 0x00000000 /* DENALI_CTL_142_DATA */ + 0x00000000 /* DENALI_CTL_143_DATA */ + 0x00000000 /* DENALI_CTL_144_DATA */ + 0x00000000 /* DENALI_CTL_145_DATA */ + 0x00000000 /* DENALI_CTL_146_DATA */ + 0x00000000 /* DENALI_CTL_147_DATA */ + 0x00000000 /* DENALI_CTL_148_DATA */ + 0x00000000 /* DENALI_CTL_149_DATA */ + 0x00000000 /* DENALI_CTL_150_DATA */ + 0x00000000 /* DENALI_CTL_151_DATA */ + 0x00000000 /* DENALI_CTL_152_DATA */ + 0x00000000 /* DENALI_CTL_153_DATA */ + 0x00000000 /* DENALI_CTL_154_DATA */ + 0x00000000 /* DENALI_CTL_155_DATA */ + 0x00000000 /* DENALI_CTL_156_DATA */ + 0x00000000 /* DENALI_CTL_157_DATA */ + 0x00000000 /* DENALI_CTL_158_DATA */ + 0x00000000 /* DENALI_CTL_159_DATA */ + 0x00000000 /* DENALI_CTL_160_DATA */ + 0x02010102 /* DENALI_CTL_161_DATA */ + 0x0107070d /* DENALI_CTL_162_DATA */ + 0x04040400 /* DENALI_CTL_163_DATA */ + 0x03000503 /* DENALI_CTL_164_DATA */ + 0x00000000 /* DENALI_CTL_165_DATA */ + 0x00000000 /* DENALI_CTL_166_DATA */ + 0x00000000 /* DENALI_CTL_167_DATA */ + 0x00000000 /* DENALI_CTL_168_DATA */ + 0x280d0000 /* DENALI_CTL_169_DATA */ + 0x01000000 /* DENALI_CTL_170_DATA */ + 0x00000000 /* DENALI_CTL_171_DATA */ + 0x00010001 /* DENALI_CTL_172_DATA */ + 0x00000000 /* DENALI_CTL_173_DATA */ + 0x00000000 /* DENALI_CTL_174_DATA */ + 0x00000000 /* DENALI_CTL_175_DATA */ + 0x00000000 /* DENALI_CTL_176_DATA */ + 0x00000000 /* DENALI_CTL_177_DATA */ + 0x00000000 /* DENALI_CTL_178_DATA */ + 0x00000000 /* DENALI_CTL_179_DATA */ + 0x00000000 /* DENALI_CTL_180_DATA */ + 0x01000000 /* DENALI_CTL_181_DATA */ + 0x00000001 /* DENALI_CTL_182_DATA */ + 0x00000100 /* DENALI_CTL_183_DATA */ + 0x00000101 /* DENALI_CTL_184_DATA */ + 0x67676701 /* DENALI_CTL_185_DATA */ + 0x67676767 /* DENALI_CTL_186_DATA */ + 0x67676767 /* DENALI_CTL_187_DATA */ + 0x67676767 /* DENALI_CTL_188_DATA */ + 0x67676767 /* DENALI_CTL_189_DATA */ + 0x67676767 /* DENALI_CTL_190_DATA */ + 0x67676767 /* DENALI_CTL_191_DATA */ + 0x67676767 /* DENALI_CTL_192_DATA */ + 0x67676767 /* DENALI_CTL_193_DATA */ + 0x01000067 /* DENALI_CTL_194_DATA */ + 0x00000001 /* DENALI_CTL_195_DATA */ + 0x00000101 /* DENALI_CTL_196_DATA */ + 0x00000000 /* DENALI_CTL_197_DATA */ + 0x00000000 /* DENALI_CTL_198_DATA */ + 0x00000000 /* DENALI_CTL_199_DATA */ + 0x00000000 /* DENALI_CTL_200_DATA */ + 0x00000000 /* DENALI_CTL_201_DATA */ + 0x00000000 /* DENALI_CTL_202_DATA */ + 0x00000000 /* DENALI_CTL_203_DATA */ + 0x00000000 /* DENALI_CTL_204_DATA */ + 0x00000000 /* DENALI_CTL_205_DATA */ + 0x00000000 /* DENALI_CTL_206_DATA */ + 0x00000000 /* DENALI_CTL_207_DATA */ + 0x00000001 /* DENALI_CTL_208_DATA */ + 0x00000000 /* DENALI_CTL_209_DATA */ + 0x007fffff /* DENALI_CTL_210_DATA */ + 0x00000000 /* DENALI_CTL_211_DATA */ + 0x007fffff /* DENALI_CTL_212_DATA */ + 0x00000000 /* DENALI_CTL_213_DATA */ + 0x007fffff /* DENALI_CTL_214_DATA */ + 0x00000000 /* DENALI_CTL_215_DATA */ + 0x007fffff /* DENALI_CTL_216_DATA */ + 0x00000000 /* DENALI_CTL_217_DATA */ + 0x007fffff /* DENALI_CTL_218_DATA */ + 0x00000000 /* DENALI_CTL_219_DATA */ + 0x007fffff /* DENALI_CTL_220_DATA */ + 0x00000000 /* DENALI_CTL_221_DATA */ + 0x007fffff /* DENALI_CTL_222_DATA */ + 0x00000000 /* DENALI_CTL_223_DATA */ + 0x037fffff /* DENALI_CTL_224_DATA */ + 0xffffffff /* DENALI_CTL_225_DATA */ + 0x000f000f /* DENALI_CTL_226_DATA */ + 0x00ffff03 /* DENALI_CTL_227_DATA */ + 0x000fffff /* DENALI_CTL_228_DATA */ + 0x0003000f /* DENALI_CTL_229_DATA */ + 0xffffffff /* DENALI_CTL_230_DATA */ + 0x000f000f /* DENALI_CTL_231_DATA */ + 0x00ffff03 /* DENALI_CTL_232_DATA */ + 0x000fffff /* DENALI_CTL_233_DATA */ + 0x0003000f /* DENALI_CTL_234_DATA */ + 0xffffffff /* DENALI_CTL_235_DATA */ + 0x000f000f /* DENALI_CTL_236_DATA */ + 0x00ffff03 /* DENALI_CTL_237_DATA */ + 0x000fffff /* DENALI_CTL_238_DATA */ + 0x0003000f /* DENALI_CTL_239_DATA */ + 0xffffffff /* DENALI_CTL_240_DATA */ + 0x000f000f /* DENALI_CTL_241_DATA */ + 0x00ffff03 /* DENALI_CTL_242_DATA */ + 0x000fffff /* DENALI_CTL_243_DATA */ + 0x6407000f /* DENALI_CTL_244_DATA */ + 0x01640001 /* DENALI_CTL_245_DATA */ + 0x00000000 /* DENALI_CTL_246_DATA */ + 0x00000000 /* DENALI_CTL_247_DATA */ + 0x00001700 /* DENALI_CTL_248_DATA */ + 0x00386c05 /* DENALI_CTL_249_DATA */ + 0x02000200 /* DENALI_CTL_250_DATA */ + 0x02000200 /* DENALI_CTL_251_DATA */ + 0x0000386c /* DENALI_CTL_252_DATA */ + 0x00023438 /* DENALI_CTL_253_DATA */ + 0x02020d10 /* DENALI_CTL_254_DATA */ + 0x00140303 /* DENALI_CTL_255_DATA */ + 0x00000000 /* DENALI_CTL_256_DATA */ + 0x00000000 /* DENALI_CTL_257_DATA */ + 0x00001403 /* DENALI_CTL_258_DATA */ + 0x00000000 /* DENALI_CTL_259_DATA */ + 0x00000000 /* DENALI_CTL_260_DATA */ + 0x00000000 /* DENALI_CTL_261_DATA */ + 0x00000000 /* DENALI_CTL_262_DATA */ + 0x0d010000 /* DENALI_CTL_263_DATA */ + 0x00000008 /* DENALI_CTL_264_DATA */ + 0x31706542 /* DENALI_PHY_00_DATA */ + 0x0004c008 /* DENALI_PHY_01_DATA */ + 0x000000da /* DENALI_PHY_02_DATA */ + 0x00000000 /* DENALI_PHY_03_DATA */ + 0x00000000 /* DENALI_PHY_04_DATA */ + 0x00010000 /* DENALI_PHY_05_DATA */ + 0x01DDDD90 /* DENALI_PHY_06_DATA */ + 0x01DDDD90 /* DENALI_PHY_07_DATA */ + 0x01030000 /* DENALI_PHY_08_DATA */ + 0x01000000 /* DENALI_PHY_09_DATA */ + 0x00c00000 /* DENALI_PHY_10_DATA */ + 0x00000007 /* DENALI_PHY_11_DATA */ + 0x00000000 /* DENALI_PHY_12_DATA */ + 0x00000000 /* DENALI_PHY_13_DATA */ + 0x04000408 /* DENALI_PHY_14_DATA */ + 0x00000408 /* DENALI_PHY_15_DATA */ + 0x00e4e400 /* DENALI_PHY_16_DATA */ + 0x00000000 /* DENALI_PHY_17_DATA */ + 0x00000000 /* DENALI_PHY_18_DATA */ + 0x00000000 /* DENALI_PHY_19_DATA */ + 0x00000000 /* DENALI_PHY_20_DATA */ + 0x00000000 /* DENALI_PHY_21_DATA */ + 0x00000000 /* DENALI_PHY_22_DATA */ + 0x00000000 /* DENALI_PHY_23_DATA */ + 0x00000000 /* DENALI_PHY_24_DATA */ + 0x00000000 /* DENALI_PHY_25_DATA */ + 0x00000000 /* DENALI_PHY_26_DATA */ + 0x00000000 /* DENALI_PHY_27_DATA */ + 0x00000000 /* DENALI_PHY_28_DATA */ + 0x00000000 /* DENALI_PHY_29_DATA */ + 0x00000000 /* DENALI_PHY_30_DATA */ + 0x00000000 /* DENALI_PHY_31_DATA */ + 0x00000000 /* DENALI_PHY_32_DATA */ + 0x00200000 /* DENALI_PHY_33_DATA */ + 0x00000000 /* DENALI_PHY_34_DATA */ + 0x00000000 /* DENALI_PHY_35_DATA */ + 0x00000000 /* DENALI_PHY_36_DATA */ + 0x00000000 /* DENALI_PHY_37_DATA */ + 0x00000000 /* DENALI_PHY_38_DATA */ + 0x00000000 /* DENALI_PHY_39_DATA */ + 0x02800280 /* DENALI_PHY_40_DATA */ + 0x02800280 /* DENALI_PHY_41_DATA */ + 0x02800280 /* DENALI_PHY_42_DATA */ + 0x02800280 /* DENALI_PHY_43_DATA */ + 0x00000280 /* DENALI_PHY_44_DATA */ + 0x00000000 /* DENALI_PHY_45_DATA */ + 0x00000000 /* DENALI_PHY_46_DATA */ + 0x00000000 /* DENALI_PHY_47_DATA */ + 0x00000000 /* DENALI_PHY_48_DATA */ + 0x00000000 /* DENALI_PHY_49_DATA */ + 0x00800080 /* DENALI_PHY_50_DATA */ + 0x00800080 /* DENALI_PHY_51_DATA */ + 0x00800080 /* DENALI_PHY_52_DATA */ + 0x00800080 /* DENALI_PHY_53_DATA */ + 0x00800080 /* DENALI_PHY_54_DATA */ + 0x00800080 /* DENALI_PHY_55_DATA */ + 0x00800080 /* DENALI_PHY_56_DATA */ + 0x00800080 /* DENALI_PHY_57_DATA */ + 0x00800080 /* DENALI_PHY_58_DATA */ + 0x000100da /* DENALI_PHY_59_DATA */ + 0x01000200 /* DENALI_PHY_60_DATA */ + 0x00000000 /* DENALI_PHY_61_DATA */ + 0x00000000 /* DENALI_PHY_62_DATA */ + 0x00000002 /* DENALI_PHY_63_DATA */ + 0x51313152 /* DENALI_PHY_64_DATA */ + 0x80013130 /* DENALI_PHY_65_DATA */ + 0x02000080 /* DENALI_PHY_66_DATA */ + 0x00100001 /* DENALI_PHY_67_DATA */ + 0x0c064208 /* DENALI_PHY_68_DATA */ + 0x000f0c0f /* DENALI_PHY_69_DATA */ + 0x01000140 /* DENALI_PHY_70_DATA */ + 0x0000000c /* DENALI_PHY_71_DATA */ + 0x00000000 /* DENALI_PHY_72_DATA */ + 0x00000000 /* DENALI_PHY_73_DATA */ + 0x00000000 /* DENALI_PHY_74_DATA */ + 0x00000000 /* DENALI_PHY_75_DATA */ + 0x00000000 /* DENALI_PHY_76_DATA */ + 0x00000000 /* DENALI_PHY_77_DATA */ + 0x00000000 /* DENALI_PHY_78_DATA */ + 0x00000000 /* DENALI_PHY_79_DATA */ + 0x00000000 /* DENALI_PHY_80_DATA */ + 0x00000000 /* DENALI_PHY_81_DATA */ + 0x00000000 /* DENALI_PHY_82_DATA */ + 0x00000000 /* DENALI_PHY_83_DATA */ + 0x00000000 /* DENALI_PHY_84_DATA */ + 0x00000000 /* DENALI_PHY_85_DATA */ + 0x00000000 /* DENALI_PHY_86_DATA */ + 0x00000000 /* DENALI_PHY_87_DATA */ + 0x00000000 /* DENALI_PHY_88_DATA */ + 0x00000000 /* DENALI_PHY_89_DATA */ + 0x00000000 /* DENALI_PHY_90_DATA */ + 0x00000000 /* DENALI_PHY_91_DATA */ + 0x00000000 /* DENALI_PHY_92_DATA */ + 0x00000000 /* DENALI_PHY_93_DATA */ + 0x00000000 /* DENALI_PHY_94_DATA */ + 0x00000000 /* DENALI_PHY_95_DATA */ + 0x00000000 /* DENALI_PHY_96_DATA */ + 0x00000000 /* DENALI_PHY_97_DATA */ + 0x00000000 /* DENALI_PHY_98_DATA */ + 0x00000000 /* DENALI_PHY_99_DATA */ + 0x00000000 /* DENALI_PHY_100_DATA */ + 0x00000000 /* DENALI_PHY_101_DATA */ + 0x00000000 /* DENALI_PHY_102_DATA */ + 0x00000000 /* DENALI_PHY_103_DATA */ + 0x00000000 /* DENALI_PHY_104_DATA */ + 0x00000000 /* DENALI_PHY_105_DATA */ + 0x00000000 /* DENALI_PHY_106_DATA */ + 0x00000000 /* DENALI_PHY_107_DATA */ + 0x00000000 /* DENALI_PHY_108_DATA */ + 0x00000000 /* DENALI_PHY_109_DATA */ + 0x00000000 /* DENALI_PHY_110_DATA */ + 0x00000000 /* DENALI_PHY_111_DATA */ + 0x00000000 /* DENALI_PHY_112_DATA */ + 0x00000000 /* DENALI_PHY_113_DATA */ + 0x00000000 /* DENALI_PHY_114_DATA */ + 0x00000000 /* DENALI_PHY_115_DATA */ + 0x00000000 /* DENALI_PHY_116_DATA */ + 0x00000000 /* DENALI_PHY_117_DATA */ + 0x00000000 /* DENALI_PHY_118_DATA */ + 0x00000000 /* DENALI_PHY_119_DATA */ + 0x00000000 /* DENALI_PHY_120_DATA */ + 0x00000000 /* DENALI_PHY_121_DATA */ + 0x00000000 /* DENALI_PHY_122_DATA */ + 0x00000000 /* DENALI_PHY_123_DATA */ + 0x00000000 /* DENALI_PHY_124_DATA */ + 0x00000000 /* DENALI_PHY_125_DATA */ + 0x00000000 /* DENALI_PHY_126_DATA */ + 0x00000000 /* DENALI_PHY_127_DATA */ + 0x40263571 /* DENALI_PHY_128_DATA */ + 0x0004c008 /* DENALI_PHY_129_DATA */ + 0x000000da /* DENALI_PHY_130_DATA */ + 0x00000000 /* DENALI_PHY_131_DATA */ + 0x00000000 /* DENALI_PHY_132_DATA */ + 0x00010000 /* DENALI_PHY_133_DATA */ + 0x01DDDD90 /* DENALI_PHY_134_DATA */ + 0x01DDDD90 /* DENALI_PHY_135_DATA */ + 0x01030000 /* DENALI_PHY_136_DATA */ + 0x01000000 /* DENALI_PHY_137_DATA */ + 0x00c00000 /* DENALI_PHY_138_DATA */ + 0x00000007 /* DENALI_PHY_139_DATA */ + 0x00000000 /* DENALI_PHY_140_DATA */ + 0x00000000 /* DENALI_PHY_141_DATA */ + 0x04000408 /* DENALI_PHY_142_DATA */ + 0x00000408 /* DENALI_PHY_143_DATA */ + 0x00e4e400 /* DENALI_PHY_144_DATA */ + 0x00000000 /* DENALI_PHY_145_DATA */ + 0x00000000 /* DENALI_PHY_146_DATA */ + 0x00000000 /* DENALI_PHY_147_DATA */ + 0x00000000 /* DENALI_PHY_148_DATA */ + 0x00000000 /* DENALI_PHY_149_DATA */ + 0x00000000 /* DENALI_PHY_150_DATA */ + 0x00000000 /* DENALI_PHY_151_DATA */ + 0x00000000 /* DENALI_PHY_152_DATA */ + 0x00000000 /* DENALI_PHY_153_DATA */ + 0x00000000 /* DENALI_PHY_154_DATA */ + 0x00000000 /* DENALI_PHY_155_DATA */ + 0x00000000 /* DENALI_PHY_156_DATA */ + 0x00000000 /* DENALI_PHY_157_DATA */ + 0x00000000 /* DENALI_PHY_158_DATA */ + 0x00000000 /* DENALI_PHY_159_DATA */ + 0x00000000 /* DENALI_PHY_160_DATA */ + 0x00200000 /* DENALI_PHY_161_DATA */ + 0x00000000 /* DENALI_PHY_162_DATA */ + 0x00000000 /* DENALI_PHY_163_DATA */ + 0x00000000 /* DENALI_PHY_164_DATA */ + 0x00000000 /* DENALI_PHY_165_DATA */ + 0x00000000 /* DENALI_PHY_166_DATA */ + 0x00000000 /* DENALI_PHY_167_DATA */ + 0x02800280 /* DENALI_PHY_168_DATA */ + 0x02800280 /* DENALI_PHY_169_DATA */ + 0x02800280 /* DENALI_PHY_170_DATA */ + 0x02800280 /* DENALI_PHY_171_DATA */ + 0x00000280 /* DENALI_PHY_172_DATA */ + 0x00000000 /* DENALI_PHY_173_DATA */ + 0x00000000 /* DENALI_PHY_174_DATA */ + 0x00000000 /* DENALI_PHY_175_DATA */ + 0x00000000 /* DENALI_PHY_176_DATA */ + 0x00000000 /* DENALI_PHY_177_DATA */ + 0x00800080 /* DENALI_PHY_178_DATA */ + 0x00800080 /* DENALI_PHY_179_DATA */ + 0x00800080 /* DENALI_PHY_180_DATA */ + 0x00800080 /* DENALI_PHY_181_DATA */ + 0x00800080 /* DENALI_PHY_182_DATA */ + 0x00800080 /* DENALI_PHY_183_DATA */ + 0x00800080 /* DENALI_PHY_184_DATA */ + 0x00800080 /* DENALI_PHY_185_DATA */ + 0x00800080 /* DENALI_PHY_186_DATA */ + 0x000100da /* DENALI_PHY_187_DATA */ + 0x01000200 /* DENALI_PHY_188_DATA */ + 0x00000000 /* DENALI_PHY_189_DATA */ + 0x00000000 /* DENALI_PHY_190_DATA */ + 0x00000002 /* DENALI_PHY_191_DATA */ + 0x51313152 /* DENALI_PHY_192_DATA */ + 0x80013130 /* DENALI_PHY_193_DATA */ + 0x02000080 /* DENALI_PHY_194_DATA */ + 0x00100001 /* DENALI_PHY_195_DATA */ + 0x0c064208 /* DENALI_PHY_196_DATA */ + 0x000f0c0f /* DENALI_PHY_197_DATA */ + 0x01000140 /* DENALI_PHY_198_DATA */ + 0x0000000c /* DENALI_PHY_199_DATA */ + 0x00000000 /* DENALI_PHY_200_DATA */ + 0x00000000 /* DENALI_PHY_201_DATA */ + 0x00000000 /* DENALI_PHY_202_DATA */ + 0x00000000 /* DENALI_PHY_203_DATA */ + 0x00000000 /* DENALI_PHY_204_DATA */ + 0x00000000 /* DENALI_PHY_205_DATA */ + 0x00000000 /* DENALI_PHY_206_DATA */ + 0x00000000 /* DENALI_PHY_207_DATA */ + 0x00000000 /* DENALI_PHY_208_DATA */ + 0x00000000 /* DENALI_PHY_209_DATA */ + 0x00000000 /* DENALI_PHY_210_DATA */ + 0x00000000 /* DENALI_PHY_211_DATA */ + 0x00000000 /* DENALI_PHY_212_DATA */ + 0x00000000 /* DENALI_PHY_213_DATA */ + 0x00000000 /* DENALI_PHY_214_DATA */ + 0x00000000 /* DENALI_PHY_215_DATA */ + 0x00000000 /* DENALI_PHY_216_DATA */ + 0x00000000 /* DENALI_PHY_217_DATA */ + 0x00000000 /* DENALI_PHY_218_DATA */ + 0x00000000 /* DENALI_PHY_219_DATA */ + 0x00000000 /* DENALI_PHY_220_DATA */ + 0x00000000 /* DENALI_PHY_221_DATA */ + 0x00000000 /* DENALI_PHY_222_DATA */ + 0x00000000 /* DENALI_PHY_223_DATA */ + 0x00000000 /* DENALI_PHY_224_DATA */ + 0x00000000 /* DENALI_PHY_225_DATA */ + 0x00000000 /* DENALI_PHY_226_DATA */ + 0x00000000 /* DENALI_PHY_227_DATA */ + 0x00000000 /* DENALI_PHY_228_DATA */ + 0x00000000 /* DENALI_PHY_229_DATA */ + 0x00000000 /* DENALI_PHY_230_DATA */ + 0x00000000 /* DENALI_PHY_231_DATA */ + 0x00000000 /* DENALI_PHY_232_DATA */ + 0x00000000 /* DENALI_PHY_233_DATA */ + 0x00000000 /* DENALI_PHY_234_DATA */ + 0x00000000 /* DENALI_PHY_235_DATA */ + 0x00000000 /* DENALI_PHY_236_DATA */ + 0x00000000 /* DENALI_PHY_237_DATA */ + 0x00000000 /* DENALI_PHY_238_DATA */ + 0x00000000 /* DENALI_PHY_239_DATA */ + 0x00000000 /* DENALI_PHY_240_DATA */ + 0x00000000 /* DENALI_PHY_241_DATA */ + 0x00000000 /* DENALI_PHY_242_DATA */ + 0x00000000 /* DENALI_PHY_243_DATA */ + 0x00000000 /* DENALI_PHY_244_DATA */ + 0x00000000 /* DENALI_PHY_245_DATA */ + 0x00000000 /* DENALI_PHY_246_DATA */ + 0x00000000 /* DENALI_PHY_247_DATA */ + 0x00000000 /* DENALI_PHY_248_DATA */ + 0x00000000 /* DENALI_PHY_249_DATA */ + 0x00000000 /* DENALI_PHY_250_DATA */ + 0x00000000 /* DENALI_PHY_251_DATA */ + 0x00000000 /* DENALI_PHY_252_DATA */ + 0x00000000 /* DENALI_PHY_253_DATA */ + 0x00000000 /* DENALI_PHY_254_DATA */ + 0x00000000 /* DENALI_PHY_255_DATA */ + 0x46052371 /* DENALI_PHY_256_DATA */ + 0x0004c008 /* DENALI_PHY_257_DATA */ + 0x000000da /* DENALI_PHY_258_DATA */ + 0x00000000 /* DENALI_PHY_259_DATA */ + 0x00000000 /* DENALI_PHY_260_DATA */ + 0x00010000 /* DENALI_PHY_261_DATA */ + 0x01DDDD90 /* DENALI_PHY_262_DATA */ + 0x01DDDD90 /* DENALI_PHY_263_DATA */ + 0x01030000 /* DENALI_PHY_264_DATA */ + 0x01000000 /* DENALI_PHY_265_DATA */ + 0x00c00000 /* DENALI_PHY_266_DATA */ + 0x00000007 /* DENALI_PHY_267_DATA */ + 0x00000000 /* DENALI_PHY_268_DATA */ + 0x00000000 /* DENALI_PHY_269_DATA */ + 0x04000408 /* DENALI_PHY_270_DATA */ + 0x00000408 /* DENALI_PHY_271_DATA */ + 0x00e4e400 /* DENALI_PHY_272_DATA */ + 0x00000000 /* DENALI_PHY_273_DATA */ + 0x00000000 /* DENALI_PHY_274_DATA */ + 0x00000000 /* DENALI_PHY_275_DATA */ + 0x00000000 /* DENALI_PHY_276_DATA */ + 0x00000000 /* DENALI_PHY_277_DATA */ + 0x00000000 /* DENALI_PHY_278_DATA */ + 0x00000000 /* DENALI_PHY_279_DATA */ + 0x00000000 /* DENALI_PHY_280_DATA */ + 0x00000000 /* DENALI_PHY_281_DATA */ + 0x00000000 /* DENALI_PHY_282_DATA */ + 0x00000000 /* DENALI_PHY_283_DATA */ + 0x00000000 /* DENALI_PHY_284_DATA */ + 0x00000000 /* DENALI_PHY_285_DATA */ + 0x00000000 /* DENALI_PHY_286_DATA */ + 0x00000000 /* DENALI_PHY_287_DATA */ + 0x00000000 /* DENALI_PHY_288_DATA */ + 0x00200000 /* DENALI_PHY_289_DATA */ + 0x00000000 /* DENALI_PHY_290_DATA */ + 0x00000000 /* DENALI_PHY_291_DATA */ + 0x00000000 /* DENALI_PHY_292_DATA */ + 0x00000000 /* DENALI_PHY_293_DATA */ + 0x00000000 /* DENALI_PHY_294_DATA */ + 0x00000000 /* DENALI_PHY_295_DATA */ + 0x02800280 /* DENALI_PHY_296_DATA */ + 0x02800280 /* DENALI_PHY_297_DATA */ + 0x02800280 /* DENALI_PHY_298_DATA */ + 0x02800280 /* DENALI_PHY_299_DATA */ + 0x00000280 /* DENALI_PHY_300_DATA */ + 0x00000000 /* DENALI_PHY_301_DATA */ + 0x00000000 /* DENALI_PHY_302_DATA */ + 0x00000000 /* DENALI_PHY_303_DATA */ + 0x00000000 /* DENALI_PHY_304_DATA */ + 0x00000000 /* DENALI_PHY_305_DATA */ + 0x00800080 /* DENALI_PHY_306_DATA */ + 0x00800080 /* DENALI_PHY_307_DATA */ + 0x00800080 /* DENALI_PHY_308_DATA */ + 0x00800080 /* DENALI_PHY_309_DATA */ + 0x00800080 /* DENALI_PHY_310_DATA */ + 0x00800080 /* DENALI_PHY_311_DATA */ + 0x00800080 /* DENALI_PHY_312_DATA */ + 0x00800080 /* DENALI_PHY_313_DATA */ + 0x00800080 /* DENALI_PHY_314_DATA */ + 0x000100da /* DENALI_PHY_315_DATA */ + 0x00000200 /* DENALI_PHY_316_DATA */ + 0x00000000 /* DENALI_PHY_317_DATA */ + 0x00000000 /* DENALI_PHY_318_DATA */ + 0x00000002 /* DENALI_PHY_319_DATA */ + 0x51313152 /* DENALI_PHY_320_DATA */ + 0x80013130 /* DENALI_PHY_321_DATA */ + 0x02000080 /* DENALI_PHY_322_DATA */ + 0x00100001 /* DENALI_PHY_323_DATA */ + 0x0c064208 /* DENALI_PHY_324_DATA */ + 0x000f0c0f /* DENALI_PHY_325_DATA */ + 0x01000140 /* DENALI_PHY_326_DATA */ + 0x0000000c /* DENALI_PHY_327_DATA */ + 0x00000000 /* DENALI_PHY_328_DATA */ + 0x00000000 /* DENALI_PHY_329_DATA */ + 0x00000000 /* DENALI_PHY_330_DATA */ + 0x00000000 /* DENALI_PHY_331_DATA */ + 0x00000000 /* DENALI_PHY_332_DATA */ + 0x00000000 /* DENALI_PHY_333_DATA */ + 0x00000000 /* DENALI_PHY_334_DATA */ + 0x00000000 /* DENALI_PHY_335_DATA */ + 0x00000000 /* DENALI_PHY_336_DATA */ + 0x00000000 /* DENALI_PHY_337_DATA */ + 0x00000000 /* DENALI_PHY_338_DATA */ + 0x00000000 /* DENALI_PHY_339_DATA */ + 0x00000000 /* DENALI_PHY_340_DATA */ + 0x00000000 /* DENALI_PHY_341_DATA */ + 0x00000000 /* DENALI_PHY_342_DATA */ + 0x00000000 /* DENALI_PHY_343_DATA */ + 0x00000000 /* DENALI_PHY_344_DATA */ + 0x00000000 /* DENALI_PHY_345_DATA */ + 0x00000000 /* DENALI_PHY_346_DATA */ + 0x00000000 /* DENALI_PHY_347_DATA */ + 0x00000000 /* DENALI_PHY_348_DATA */ + 0x00000000 /* DENALI_PHY_349_DATA */ + 0x00000000 /* DENALI_PHY_350_DATA */ + 0x00000000 /* DENALI_PHY_351_DATA */ + 0x00000000 /* DENALI_PHY_352_DATA */ + 0x00000000 /* DENALI_PHY_353_DATA */ + 0x00000000 /* DENALI_PHY_354_DATA */ + 0x00000000 /* DENALI_PHY_355_DATA */ + 0x00000000 /* DENALI_PHY_356_DATA */ + 0x00000000 /* DENALI_PHY_357_DATA */ + 0x00000000 /* DENALI_PHY_358_DATA */ + 0x00000000 /* DENALI_PHY_359_DATA */ + 0x00000000 /* DENALI_PHY_360_DATA */ + 0x00000000 /* DENALI_PHY_361_DATA */ + 0x00000000 /* DENALI_PHY_362_DATA */ + 0x00000000 /* DENALI_PHY_363_DATA */ + 0x00000000 /* DENALI_PHY_364_DATA */ + 0x00000000 /* DENALI_PHY_365_DATA */ + 0x00000000 /* DENALI_PHY_366_DATA */ + 0x00000000 /* DENALI_PHY_367_DATA */ + 0x00000000 /* DENALI_PHY_368_DATA */ + 0x00000000 /* DENALI_PHY_369_DATA */ + 0x00000000 /* DENALI_PHY_370_DATA */ + 0x00000000 /* DENALI_PHY_371_DATA */ + 0x00000000 /* DENALI_PHY_372_DATA */ + 0x00000000 /* DENALI_PHY_373_DATA */ + 0x00000000 /* DENALI_PHY_374_DATA */ + 0x00000000 /* DENALI_PHY_375_DATA */ + 0x00000000 /* DENALI_PHY_376_DATA */ + 0x00000000 /* DENALI_PHY_377_DATA */ + 0x00000000 /* DENALI_PHY_378_DATA */ + 0x00000000 /* DENALI_PHY_379_DATA */ + 0x00000000 /* DENALI_PHY_380_DATA */ + 0x00000000 /* DENALI_PHY_381_DATA */ + 0x00000000 /* DENALI_PHY_382_DATA */ + 0x00000000 /* DENALI_PHY_383_DATA */ + 0x37654120 /* DENALI_PHY_384_DATA */ + 0x0004c008 /* DENALI_PHY_385_DATA */ + 0x000000da /* DENALI_PHY_386_DATA */ + 0x00000000 /* DENALI_PHY_387_DATA */ + 0x00000000 /* DENALI_PHY_388_DATA */ + 0x00010000 /* DENALI_PHY_389_DATA */ + 0x01DDDD90 /* DENALI_PHY_390_DATA */ + 0x01DDDD90 /* DENALI_PHY_391_DATA */ + 0x01030000 /* DENALI_PHY_392_DATA */ + 0x01000000 /* DENALI_PHY_393_DATA */ + 0x00c00000 /* DENALI_PHY_394_DATA */ + 0x00000007 /* DENALI_PHY_395_DATA */ + 0x00000000 /* DENALI_PHY_396_DATA */ + 0x00000000 /* DENALI_PHY_397_DATA */ + 0x04000408 /* DENALI_PHY_398_DATA */ + 0x00000408 /* DENALI_PHY_399_DATA */ + 0x00e4e400 /* DENALI_PHY_400_DATA */ + 0x00000000 /* DENALI_PHY_401_DATA */ + 0x00000000 /* DENALI_PHY_402_DATA */ + 0x00000000 /* DENALI_PHY_403_DATA */ + 0x00000000 /* DENALI_PHY_404_DATA */ + 0x00000000 /* DENALI_PHY_405_DATA */ + 0x00000000 /* DENALI_PHY_406_DATA */ + 0x00000000 /* DENALI_PHY_407_DATA */ + 0x00000000 /* DENALI_PHY_408_DATA */ + 0x00000000 /* DENALI_PHY_409_DATA */ + 0x00000000 /* DENALI_PHY_410_DATA */ + 0x00000000 /* DENALI_PHY_411_DATA */ + 0x00000000 /* DENALI_PHY_412_DATA */ + 0x00000000 /* DENALI_PHY_413_DATA */ + 0x00000000 /* DENALI_PHY_414_DATA */ + 0x00000000 /* DENALI_PHY_415_DATA */ + 0x00000000 /* DENALI_PHY_416_DATA */ + 0x00200000 /* DENALI_PHY_417_DATA */ + 0x00000000 /* DENALI_PHY_418_DATA */ + 0x00000000 /* DENALI_PHY_419_DATA */ + 0x00000000 /* DENALI_PHY_420_DATA */ + 0x00000000 /* DENALI_PHY_421_DATA */ + 0x00000000 /* DENALI_PHY_422_DATA */ + 0x00000000 /* DENALI_PHY_423_DATA */ + 0x02800280 /* DENALI_PHY_424_DATA */ + 0x02800280 /* DENALI_PHY_425_DATA */ + 0x02800280 /* DENALI_PHY_426_DATA */ + 0x02800280 /* DENALI_PHY_427_DATA */ + 0x00000280 /* DENALI_PHY_428_DATA */ + 0x00000000 /* DENALI_PHY_429_DATA */ + 0x00000000 /* DENALI_PHY_430_DATA */ + 0x00000000 /* DENALI_PHY_431_DATA */ + 0x00000000 /* DENALI_PHY_432_DATA */ + 0x00000000 /* DENALI_PHY_433_DATA */ + 0x00800080 /* DENALI_PHY_434_DATA */ + 0x00800080 /* DENALI_PHY_435_DATA */ + 0x00800080 /* DENALI_PHY_436_DATA */ + 0x00800080 /* DENALI_PHY_437_DATA */ + 0x00800080 /* DENALI_PHY_438_DATA */ + 0x00800080 /* DENALI_PHY_439_DATA */ + 0x00800080 /* DENALI_PHY_440_DATA */ + 0x00800080 /* DENALI_PHY_441_DATA */ + 0x00800080 /* DENALI_PHY_442_DATA */ + 0x000100da /* DENALI_PHY_443_DATA */ + 0x00000200 /* DENALI_PHY_444_DATA */ + 0x00000000 /* DENALI_PHY_445_DATA */ + 0x00000000 /* DENALI_PHY_446_DATA */ + 0x00000002 /* DENALI_PHY_447_DATA */ + 0x51313152 /* DENALI_PHY_448_DATA */ + 0x80013130 /* DENALI_PHY_449_DATA */ + 0x02000080 /* DENALI_PHY_450_DATA */ + 0x00100001 /* DENALI_PHY_451_DATA */ + 0x0c064208 /* DENALI_PHY_452_DATA */ + 0x000f0c0f /* DENALI_PHY_453_DATA */ + 0x01000140 /* DENALI_PHY_454_DATA */ + 0x0000000c /* DENALI_PHY_455_DATA */ + 0x00000000 /* DENALI_PHY_456_DATA */ + 0x00000000 /* DENALI_PHY_457_DATA */ + 0x00000000 /* DENALI_PHY_458_DATA */ + 0x00000000 /* DENALI_PHY_459_DATA */ + 0x00000000 /* DENALI_PHY_460_DATA */ + 0x00000000 /* DENALI_PHY_461_DATA */ + 0x00000000 /* DENALI_PHY_462_DATA */ + 0x00000000 /* DENALI_PHY_463_DATA */ + 0x00000000 /* DENALI_PHY_464_DATA */ + 0x00000000 /* DENALI_PHY_465_DATA */ + 0x00000000 /* DENALI_PHY_466_DATA */ + 0x00000000 /* DENALI_PHY_467_DATA */ + 0x00000000 /* DENALI_PHY_468_DATA */ + 0x00000000 /* DENALI_PHY_469_DATA */ + 0x00000000 /* DENALI_PHY_470_DATA */ + 0x00000000 /* DENALI_PHY_471_DATA */ + 0x00000000 /* DENALI_PHY_472_DATA */ + 0x00000000 /* DENALI_PHY_473_DATA */ + 0x00000000 /* DENALI_PHY_474_DATA */ + 0x00000000 /* DENALI_PHY_475_DATA */ + 0x00000000 /* DENALI_PHY_476_DATA */ + 0x00000000 /* DENALI_PHY_477_DATA */ + 0x00000000 /* DENALI_PHY_478_DATA */ + 0x00000000 /* DENALI_PHY_479_DATA */ + 0x00000000 /* DENALI_PHY_480_DATA */ + 0x00000000 /* DENALI_PHY_481_DATA */ + 0x00000000 /* DENALI_PHY_482_DATA */ + 0x00000000 /* DENALI_PHY_483_DATA */ + 0x00000000 /* DENALI_PHY_484_DATA */ + 0x00000000 /* DENALI_PHY_485_DATA */ + 0x00000000 /* DENALI_PHY_486_DATA */ + 0x00000000 /* DENALI_PHY_487_DATA */ + 0x00000000 /* DENALI_PHY_488_DATA */ + 0x00000000 /* DENALI_PHY_489_DATA */ + 0x00000000 /* DENALI_PHY_490_DATA */ + 0x00000000 /* DENALI_PHY_491_DATA */ + 0x00000000 /* DENALI_PHY_492_DATA */ + 0x00000000 /* DENALI_PHY_493_DATA */ + 0x00000000 /* DENALI_PHY_494_DATA */ + 0x00000000 /* DENALI_PHY_495_DATA */ + 0x00000000 /* DENALI_PHY_496_DATA */ + 0x00000000 /* DENALI_PHY_497_DATA */ + 0x00000000 /* DENALI_PHY_498_DATA */ + 0x00000000 /* DENALI_PHY_499_DATA */ + 0x00000000 /* DENALI_PHY_500_DATA */ + 0x00000000 /* DENALI_PHY_501_DATA */ + 0x00000000 /* DENALI_PHY_502_DATA */ + 0x00000000 /* DENALI_PHY_503_DATA */ + 0x00000000 /* DENALI_PHY_504_DATA */ + 0x00000000 /* DENALI_PHY_505_DATA */ + 0x00000000 /* DENALI_PHY_506_DATA */ + 0x00000000 /* DENALI_PHY_507_DATA */ + 0x00000000 /* DENALI_PHY_508_DATA */ + 0x00000000 /* DENALI_PHY_509_DATA */ + 0x00000000 /* DENALI_PHY_510_DATA */ + 0x00000000 /* DENALI_PHY_511_DATA */ + 0x24316750 /* DENALI_PHY_512_DATA */ + 0x0004c008 /* DENALI_PHY_513_DATA */ + 0x000000da /* DENALI_PHY_514_DATA */ + 0x00000000 /* DENALI_PHY_515_DATA */ + 0x00000000 /* DENALI_PHY_516_DATA */ + 0x00010000 /* DENALI_PHY_517_DATA */ + 0x01DDDD90 /* DENALI_PHY_518_DATA */ + 0x01DDDD90 /* DENALI_PHY_519_DATA */ + 0x01030000 /* DENALI_PHY_520_DATA */ + 0x01000000 /* DENALI_PHY_521_DATA */ + 0x00c00000 /* DENALI_PHY_522_DATA */ + 0x00000007 /* DENALI_PHY_523_DATA */ + 0x00000000 /* DENALI_PHY_524_DATA */ + 0x00000000 /* DENALI_PHY_525_DATA */ + 0x04000408 /* DENALI_PHY_526_DATA */ + 0x00000408 /* DENALI_PHY_527_DATA */ + 0x00e4e400 /* DENALI_PHY_528_DATA */ + 0x00000000 /* DENALI_PHY_529_DATA */ + 0x00000000 /* DENALI_PHY_530_DATA */ + 0x00000000 /* DENALI_PHY_531_DATA */ + 0x00000000 /* DENALI_PHY_532_DATA */ + 0x00000000 /* DENALI_PHY_533_DATA */ + 0x00000000 /* DENALI_PHY_534_DATA */ + 0x00000000 /* DENALI_PHY_535_DATA */ + 0x00000000 /* DENALI_PHY_536_DATA */ + 0x00000000 /* DENALI_PHY_537_DATA */ + 0x00000000 /* DENALI_PHY_538_DATA */ + 0x00000000 /* DENALI_PHY_539_DATA */ + 0x00000000 /* DENALI_PHY_540_DATA */ + 0x00000000 /* DENALI_PHY_541_DATA */ + 0x00000000 /* DENALI_PHY_542_DATA */ + 0x00000000 /* DENALI_PHY_543_DATA */ + 0x00000000 /* DENALI_PHY_544_DATA */ + 0x00200000 /* DENALI_PHY_545_DATA */ + 0x00000000 /* DENALI_PHY_546_DATA */ + 0x00000000 /* DENALI_PHY_547_DATA */ + 0x00000000 /* DENALI_PHY_548_DATA */ + 0x00000000 /* DENALI_PHY_549_DATA */ + 0x00000000 /* DENALI_PHY_550_DATA */ + 0x00000000 /* DENALI_PHY_551_DATA */ + 0x02800280 /* DENALI_PHY_552_DATA */ + 0x02800280 /* DENALI_PHY_553_DATA */ + 0x02800280 /* DENALI_PHY_554_DATA */ + 0x02800280 /* DENALI_PHY_555_DATA */ + 0x00000280 /* DENALI_PHY_556_DATA */ + 0x00000000 /* DENALI_PHY_557_DATA */ + 0x00000000 /* DENALI_PHY_558_DATA */ + 0x00000000 /* DENALI_PHY_559_DATA */ + 0x00000000 /* DENALI_PHY_560_DATA */ + 0x00000000 /* DENALI_PHY_561_DATA */ + 0x00800080 /* DENALI_PHY_562_DATA */ + 0x00800080 /* DENALI_PHY_563_DATA */ + 0x00800080 /* DENALI_PHY_564_DATA */ + 0x00800080 /* DENALI_PHY_565_DATA */ + 0x00800080 /* DENALI_PHY_566_DATA */ + 0x00800080 /* DENALI_PHY_567_DATA */ + 0x00800080 /* DENALI_PHY_568_DATA */ + 0x00800080 /* DENALI_PHY_569_DATA */ + 0x00800080 /* DENALI_PHY_570_DATA */ + 0x000100da /* DENALI_PHY_571_DATA */ + 0x00000200 /* DENALI_PHY_572_DATA */ + 0x00000000 /* DENALI_PHY_573_DATA */ + 0x00000000 /* DENALI_PHY_574_DATA */ + 0x00000002 /* DENALI_PHY_575_DATA */ + 0x51313152 /* DENALI_PHY_576_DATA */ + 0x80013130 /* DENALI_PHY_577_DATA */ + 0x02000080 /* DENALI_PHY_578_DATA */ + 0x00100001 /* DENALI_PHY_579_DATA */ + 0x0c064208 /* DENALI_PHY_580_DATA */ + 0x000f0c0f /* DENALI_PHY_581_DATA */ + 0x01000140 /* DENALI_PHY_582_DATA */ + 0x0000000c /* DENALI_PHY_583_DATA */ + 0x00000000 /* DENALI_PHY_584_DATA */ + 0x00000000 /* DENALI_PHY_585_DATA */ + 0x00000000 /* DENALI_PHY_586_DATA */ + 0x00000000 /* DENALI_PHY_587_DATA */ + 0x00000000 /* DENALI_PHY_588_DATA */ + 0x00000000 /* DENALI_PHY_589_DATA */ + 0x00000000 /* DENALI_PHY_590_DATA */ + 0x00000000 /* DENALI_PHY_591_DATA */ + 0x00000000 /* DENALI_PHY_592_DATA */ + 0x00000000 /* DENALI_PHY_593_DATA */ + 0x00000000 /* DENALI_PHY_594_DATA */ + 0x00000000 /* DENALI_PHY_595_DATA */ + 0x00000000 /* DENALI_PHY_596_DATA */ + 0x00000000 /* DENALI_PHY_597_DATA */ + 0x00000000 /* DENALI_PHY_598_DATA */ + 0x00000000 /* DENALI_PHY_599_DATA */ + 0x00000000 /* DENALI_PHY_600_DATA */ + 0x00000000 /* DENALI_PHY_601_DATA */ + 0x00000000 /* DENALI_PHY_602_DATA */ + 0x00000000 /* DENALI_PHY_603_DATA */ + 0x00000000 /* DENALI_PHY_604_DATA */ + 0x00000000 /* DENALI_PHY_605_DATA */ + 0x00000000 /* DENALI_PHY_606_DATA */ + 0x00000000 /* DENALI_PHY_607_DATA */ + 0x00000000 /* DENALI_PHY_608_DATA */ + 0x00000000 /* DENALI_PHY_609_DATA */ + 0x00000000 /* DENALI_PHY_610_DATA */ + 0x00000000 /* DENALI_PHY_611_DATA */ + 0x00000000 /* DENALI_PHY_612_DATA */ + 0x00000000 /* DENALI_PHY_613_DATA */ + 0x00000000 /* DENALI_PHY_614_DATA */ + 0x00000000 /* DENALI_PHY_615_DATA */ + 0x00000000 /* DENALI_PHY_616_DATA */ + 0x00000000 /* DENALI_PHY_617_DATA */ + 0x00000000 /* DENALI_PHY_618_DATA */ + 0x00000000 /* DENALI_PHY_619_DATA */ + 0x00000000 /* DENALI_PHY_620_DATA */ + 0x00000000 /* DENALI_PHY_621_DATA */ + 0x00000000 /* DENALI_PHY_622_DATA */ + 0x00000000 /* DENALI_PHY_623_DATA */ + 0x00000000 /* DENALI_PHY_624_DATA */ + 0x00000000 /* DENALI_PHY_625_DATA */ + 0x00000000 /* DENALI_PHY_626_DATA */ + 0x00000000 /* DENALI_PHY_627_DATA */ + 0x00000000 /* DENALI_PHY_628_DATA */ + 0x00000000 /* DENALI_PHY_629_DATA */ + 0x00000000 /* DENALI_PHY_630_DATA */ + 0x00000000 /* DENALI_PHY_631_DATA */ + 0x00000000 /* DENALI_PHY_632_DATA */ + 0x00000000 /* DENALI_PHY_633_DATA */ + 0x00000000 /* DENALI_PHY_634_DATA */ + 0x00000000 /* DENALI_PHY_635_DATA */ + 0x00000000 /* DENALI_PHY_636_DATA */ + 0x00000000 /* DENALI_PHY_637_DATA */ + 0x00000000 /* DENALI_PHY_638_DATA */ + 0x00000000 /* DENALI_PHY_639_DATA */ + 0x35174620 /* DENALI_PHY_640_DATA */ + 0x0004c008 /* DENALI_PHY_641_DATA */ + 0x000000da /* DENALI_PHY_642_DATA */ + 0x00000000 /* DENALI_PHY_643_DATA */ + 0x00000000 /* DENALI_PHY_644_DATA */ + 0x00010000 /* DENALI_PHY_645_DATA */ + 0x01DDDD90 /* DENALI_PHY_646_DATA */ + 0x01DDDD90 /* DENALI_PHY_647_DATA */ + 0x01030000 /* DENALI_PHY_648_DATA */ + 0x01000000 /* DENALI_PHY_649_DATA */ + 0x00c00000 /* DENALI_PHY_650_DATA */ + 0x00000007 /* DENALI_PHY_651_DATA */ + 0x00000000 /* DENALI_PHY_652_DATA */ + 0x00000000 /* DENALI_PHY_653_DATA */ + 0x04000408 /* DENALI_PHY_654_DATA */ + 0x00000408 /* DENALI_PHY_655_DATA */ + 0x00e4e400 /* DENALI_PHY_656_DATA */ + 0x00000000 /* DENALI_PHY_657_DATA */ + 0x00000000 /* DENALI_PHY_658_DATA */ + 0x00000000 /* DENALI_PHY_659_DATA */ + 0x00000000 /* DENALI_PHY_660_DATA */ + 0x00000000 /* DENALI_PHY_661_DATA */ + 0x00000000 /* DENALI_PHY_662_DATA */ + 0x00000000 /* DENALI_PHY_663_DATA */ + 0x00000000 /* DENALI_PHY_664_DATA */ + 0x00000000 /* DENALI_PHY_665_DATA */ + 0x00000000 /* DENALI_PHY_666_DATA */ + 0x00000000 /* DENALI_PHY_667_DATA */ + 0x00000000 /* DENALI_PHY_668_DATA */ + 0x00000000 /* DENALI_PHY_669_DATA */ + 0x00000000 /* DENALI_PHY_670_DATA */ + 0x00000000 /* DENALI_PHY_671_DATA */ + 0x00000000 /* DENALI_PHY_672_DATA */ + 0x00200000 /* DENALI_PHY_673_DATA */ + 0x00000000 /* DENALI_PHY_674_DATA */ + 0x00000000 /* DENALI_PHY_675_DATA */ + 0x00000000 /* DENALI_PHY_676_DATA */ + 0x00000000 /* DENALI_PHY_677_DATA */ + 0x00000000 /* DENALI_PHY_678_DATA */ + 0x00000000 /* DENALI_PHY_679_DATA */ + 0x02800280 /* DENALI_PHY_680_DATA */ + 0x02800280 /* DENALI_PHY_681_DATA */ + 0x02800280 /* DENALI_PHY_682_DATA */ + 0x02800280 /* DENALI_PHY_683_DATA */ + 0x00000280 /* DENALI_PHY_684_DATA */ + 0x00000000 /* DENALI_PHY_685_DATA */ + 0x00000000 /* DENALI_PHY_686_DATA */ + 0x00000000 /* DENALI_PHY_687_DATA */ + 0x00000000 /* DENALI_PHY_688_DATA */ + 0x00000000 /* DENALI_PHY_689_DATA */ + 0x00800080 /* DENALI_PHY_690_DATA */ + 0x00800080 /* DENALI_PHY_691_DATA */ + 0x00800080 /* DENALI_PHY_692_DATA */ + 0x00800080 /* DENALI_PHY_693_DATA */ + 0x00800080 /* DENALI_PHY_694_DATA */ + 0x00800080 /* DENALI_PHY_695_DATA */ + 0x00800080 /* DENALI_PHY_696_DATA */ + 0x00800080 /* DENALI_PHY_697_DATA */ + 0x00800080 /* DENALI_PHY_698_DATA */ + 0x000100da /* DENALI_PHY_699_DATA */ + 0x00000200 /* DENALI_PHY_700_DATA */ + 0x00000000 /* DENALI_PHY_701_DATA */ + 0x00000000 /* DENALI_PHY_702_DATA */ + 0x00000002 /* DENALI_PHY_703_DATA */ + 0x51313152 /* DENALI_PHY_704_DATA */ + 0x80013130 /* DENALI_PHY_705_DATA */ + 0x02000080 /* DENALI_PHY_706_DATA */ + 0x00100001 /* DENALI_PHY_707_DATA */ + 0x0c064208 /* DENALI_PHY_708_DATA */ + 0x000f0c0f /* DENALI_PHY_709_DATA */ + 0x01000140 /* DENALI_PHY_710_DATA */ + 0x0000000c /* DENALI_PHY_711_DATA */ + 0x00000000 /* DENALI_PHY_712_DATA */ + 0x00000000 /* DENALI_PHY_713_DATA */ + 0x00000000 /* DENALI_PHY_714_DATA */ + 0x00000000 /* DENALI_PHY_715_DATA */ + 0x00000000 /* DENALI_PHY_716_DATA */ + 0x00000000 /* DENALI_PHY_717_DATA */ + 0x00000000 /* DENALI_PHY_718_DATA */ + 0x00000000 /* DENALI_PHY_719_DATA */ + 0x00000000 /* DENALI_PHY_720_DATA */ + 0x00000000 /* DENALI_PHY_721_DATA */ + 0x00000000 /* DENALI_PHY_722_DATA */ + 0x00000000 /* DENALI_PHY_723_DATA */ + 0x00000000 /* DENALI_PHY_724_DATA */ + 0x00000000 /* DENALI_PHY_725_DATA */ + 0x00000000 /* DENALI_PHY_726_DATA */ + 0x00000000 /* DENALI_PHY_727_DATA */ + 0x00000000 /* DENALI_PHY_728_DATA */ + 0x00000000 /* DENALI_PHY_729_DATA */ + 0x00000000 /* DENALI_PHY_730_DATA */ + 0x00000000 /* DENALI_PHY_731_DATA */ + 0x00000000 /* DENALI_PHY_732_DATA */ + 0x00000000 /* DENALI_PHY_733_DATA */ + 0x00000000 /* DENALI_PHY_734_DATA */ + 0x00000000 /* DENALI_PHY_735_DATA */ + 0x00000000 /* DENALI_PHY_736_DATA */ + 0x00000000 /* DENALI_PHY_737_DATA */ + 0x00000000 /* DENALI_PHY_738_DATA */ + 0x00000000 /* DENALI_PHY_739_DATA */ + 0x00000000 /* DENALI_PHY_740_DATA */ + 0x00000000 /* DENALI_PHY_741_DATA */ + 0x00000000 /* DENALI_PHY_742_DATA */ + 0x00000000 /* DENALI_PHY_743_DATA */ + 0x00000000 /* DENALI_PHY_744_DATA */ + 0x00000000 /* DENALI_PHY_745_DATA */ + 0x00000000 /* DENALI_PHY_746_DATA */ + 0x00000000 /* DENALI_PHY_747_DATA */ + 0x00000000 /* DENALI_PHY_748_DATA */ + 0x00000000 /* DENALI_PHY_749_DATA */ + 0x00000000 /* DENALI_PHY_750_DATA */ + 0x00000000 /* DENALI_PHY_751_DATA */ + 0x00000000 /* DENALI_PHY_752_DATA */ + 0x00000000 /* DENALI_PHY_753_DATA */ + 0x00000000 /* DENALI_PHY_754_DATA */ + 0x00000000 /* DENALI_PHY_755_DATA */ + 0x00000000 /* DENALI_PHY_756_DATA */ + 0x00000000 /* DENALI_PHY_757_DATA */ + 0x00000000 /* DENALI_PHY_758_DATA */ + 0x00000000 /* DENALI_PHY_759_DATA */ + 0x00000000 /* DENALI_PHY_760_DATA */ + 0x00000000 /* DENALI_PHY_761_DATA */ + 0x00000000 /* DENALI_PHY_762_DATA */ + 0x00000000 /* DENALI_PHY_763_DATA */ + 0x00000000 /* DENALI_PHY_764_DATA */ + 0x00000000 /* DENALI_PHY_765_DATA */ + 0x00000000 /* DENALI_PHY_766_DATA */ + 0x00000000 /* DENALI_PHY_767_DATA */ + 0x15203476 /* DENALI_PHY_768_DATA */ + 0x0004c008 /* DENALI_PHY_769_DATA */ + 0x000000da /* DENALI_PHY_770_DATA */ + 0x00000000 /* DENALI_PHY_771_DATA */ + 0x00000000 /* DENALI_PHY_772_DATA */ + 0x00010000 /* DENALI_PHY_773_DATA */ + 0x01DDDD90 /* DENALI_PHY_774_DATA */ + 0x01DDDD90 /* DENALI_PHY_775_DATA */ + 0x01030000 /* DENALI_PHY_776_DATA */ + 0x01000000 /* DENALI_PHY_777_DATA */ + 0x00c00000 /* DENALI_PHY_778_DATA */ + 0x00000007 /* DENALI_PHY_779_DATA */ + 0x00000000 /* DENALI_PHY_780_DATA */ + 0x00000000 /* DENALI_PHY_781_DATA */ + 0x04000408 /* DENALI_PHY_782_DATA */ + 0x00000408 /* DENALI_PHY_783_DATA */ + 0x00e4e400 /* DENALI_PHY_784_DATA */ + 0x00000000 /* DENALI_PHY_785_DATA */ + 0x00000000 /* DENALI_PHY_786_DATA */ + 0x00000000 /* DENALI_PHY_787_DATA */ + 0x00000000 /* DENALI_PHY_788_DATA */ + 0x00000000 /* DENALI_PHY_789_DATA */ + 0x00000000 /* DENALI_PHY_790_DATA */ + 0x00000000 /* DENALI_PHY_791_DATA */ + 0x00000000 /* DENALI_PHY_792_DATA */ + 0x00000000 /* DENALI_PHY_793_DATA */ + 0x00000000 /* DENALI_PHY_794_DATA */ + 0x00000000 /* DENALI_PHY_795_DATA */ + 0x00000000 /* DENALI_PHY_796_DATA */ + 0x00000000 /* DENALI_PHY_797_DATA */ + 0x00000000 /* DENALI_PHY_798_DATA */ + 0x00000000 /* DENALI_PHY_799_DATA */ + 0x00000000 /* DENALI_PHY_800_DATA */ + 0x00200000 /* DENALI_PHY_801_DATA */ + 0x00000000 /* DENALI_PHY_802_DATA */ + 0x00000000 /* DENALI_PHY_803_DATA */ + 0x00000000 /* DENALI_PHY_804_DATA */ + 0x00000000 /* DENALI_PHY_805_DATA */ + 0x00000000 /* DENALI_PHY_806_DATA */ + 0x00000000 /* DENALI_PHY_807_DATA */ + 0x02800280 /* DENALI_PHY_808_DATA */ + 0x02800280 /* DENALI_PHY_809_DATA */ + 0x02800280 /* DENALI_PHY_810_DATA */ + 0x02800280 /* DENALI_PHY_811_DATA */ + 0x00000280 /* DENALI_PHY_812_DATA */ + 0x00000000 /* DENALI_PHY_813_DATA */ + 0x00000000 /* DENALI_PHY_814_DATA */ + 0x00000000 /* DENALI_PHY_815_DATA */ + 0x00000000 /* DENALI_PHY_816_DATA */ + 0x00000000 /* DENALI_PHY_817_DATA */ + 0x00800080 /* DENALI_PHY_818_DATA */ + 0x00800080 /* DENALI_PHY_819_DATA */ + 0x00800080 /* DENALI_PHY_820_DATA */ + 0x00800080 /* DENALI_PHY_821_DATA */ + 0x00800080 /* DENALI_PHY_822_DATA */ + 0x00800080 /* DENALI_PHY_823_DATA */ + 0x00800080 /* DENALI_PHY_824_DATA */ + 0x00800080 /* DENALI_PHY_825_DATA */ + 0x00800080 /* DENALI_PHY_826_DATA */ + 0x000100da /* DENALI_PHY_827_DATA */ + 0x00000200 /* DENALI_PHY_828_DATA */ + 0x00000000 /* DENALI_PHY_829_DATA */ + 0x00000000 /* DENALI_PHY_830_DATA */ + 0x00000002 /* DENALI_PHY_831_DATA */ + 0x51313152 /* DENALI_PHY_832_DATA */ + 0x80013130 /* DENALI_PHY_833_DATA */ + 0x02000080 /* DENALI_PHY_834_DATA */ + 0x00100001 /* DENALI_PHY_835_DATA */ + 0x0c064208 /* DENALI_PHY_836_DATA */ + 0x000f0c0f /* DENALI_PHY_837_DATA */ + 0x01000140 /* DENALI_PHY_838_DATA */ + 0x0000000c /* DENALI_PHY_839_DATA */ + 0x00000000 /* DENALI_PHY_840_DATA */ + 0x00000000 /* DENALI_PHY_841_DATA */ + 0x00000000 /* DENALI_PHY_842_DATA */ + 0x00000000 /* DENALI_PHY_843_DATA */ + 0x00000000 /* DENALI_PHY_844_DATA */ + 0x00000000 /* DENALI_PHY_845_DATA */ + 0x00000000 /* DENALI_PHY_846_DATA */ + 0x00000000 /* DENALI_PHY_847_DATA */ + 0x00000000 /* DENALI_PHY_848_DATA */ + 0x00000000 /* DENALI_PHY_849_DATA */ + 0x00000000 /* DENALI_PHY_850_DATA */ + 0x00000000 /* DENALI_PHY_851_DATA */ + 0x00000000 /* DENALI_PHY_852_DATA */ + 0x00000000 /* DENALI_PHY_853_DATA */ + 0x00000000 /* DENALI_PHY_854_DATA */ + 0x00000000 /* DENALI_PHY_855_DATA */ + 0x00000000 /* DENALI_PHY_856_DATA */ + 0x00000000 /* DENALI_PHY_857_DATA */ + 0x00000000 /* DENALI_PHY_858_DATA */ + 0x00000000 /* DENALI_PHY_859_DATA */ + 0x00000000 /* DENALI_PHY_860_DATA */ + 0x00000000 /* DENALI_PHY_861_DATA */ + 0x00000000 /* DENALI_PHY_862_DATA */ + 0x00000000 /* DENALI_PHY_863_DATA */ + 0x00000000 /* DENALI_PHY_864_DATA */ + 0x00000000 /* DENALI_PHY_865_DATA */ + 0x00000000 /* DENALI_PHY_866_DATA */ + 0x00000000 /* DENALI_PHY_867_DATA */ + 0x00000000 /* DENALI_PHY_868_DATA */ + 0x00000000 /* DENALI_PHY_869_DATA */ + 0x00000000 /* DENALI_PHY_870_DATA */ + 0x00000000 /* DENALI_PHY_871_DATA */ + 0x00000000 /* DENALI_PHY_872_DATA */ + 0x00000000 /* DENALI_PHY_873_DATA */ + 0x00000000 /* DENALI_PHY_874_DATA */ + 0x00000000 /* DENALI_PHY_875_DATA */ + 0x00000000 /* DENALI_PHY_876_DATA */ + 0x00000000 /* DENALI_PHY_877_DATA */ + 0x00000000 /* DENALI_PHY_878_DATA */ + 0x00000000 /* DENALI_PHY_879_DATA */ + 0x00000000 /* DENALI_PHY_880_DATA */ + 0x00000000 /* DENALI_PHY_881_DATA */ + 0x00000000 /* DENALI_PHY_882_DATA */ + 0x00000000 /* DENALI_PHY_883_DATA */ + 0x00000000 /* DENALI_PHY_884_DATA */ + 0x00000000 /* DENALI_PHY_885_DATA */ + 0x00000000 /* DENALI_PHY_886_DATA */ + 0x00000000 /* DENALI_PHY_887_DATA */ + 0x00000000 /* DENALI_PHY_888_DATA */ + 0x00000000 /* DENALI_PHY_889_DATA */ + 0x00000000 /* DENALI_PHY_890_DATA */ + 0x00000000 /* DENALI_PHY_891_DATA */ + 0x00000000 /* DENALI_PHY_892_DATA */ + 0x00000000 /* DENALI_PHY_893_DATA */ + 0x00000000 /* DENALI_PHY_894_DATA */ + 0x00000000 /* DENALI_PHY_895_DATA */ + 0x41753206 /* DENALI_PHY_896_DATA */ + 0x0004c008 /* DENALI_PHY_897_DATA */ + 0x000000da /* DENALI_PHY_898_DATA */ + 0x00000000 /* DENALI_PHY_899_DATA */ + 0x00000000 /* DENALI_PHY_900_DATA */ + 0x00010000 /* DENALI_PHY_901_DATA */ + 0x01DDDD90 /* DENALI_PHY_902_DATA */ + 0x01DDDD90 /* DENALI_PHY_903_DATA */ + 0x01030000 /* DENALI_PHY_904_DATA */ + 0x01000000 /* DENALI_PHY_905_DATA */ + 0x00c00000 /* DENALI_PHY_906_DATA */ + 0x00000007 /* DENALI_PHY_907_DATA */ + 0x00000000 /* DENALI_PHY_908_DATA */ + 0x00000000 /* DENALI_PHY_909_DATA */ + 0x04000408 /* DENALI_PHY_910_DATA */ + 0x00000408 /* DENALI_PHY_911_DATA */ + 0x00e4e400 /* DENALI_PHY_912_DATA */ + 0x00000000 /* DENALI_PHY_913_DATA */ + 0x00000000 /* DENALI_PHY_914_DATA */ + 0x00000000 /* DENALI_PHY_915_DATA */ + 0x00000000 /* DENALI_PHY_916_DATA */ + 0x00000000 /* DENALI_PHY_917_DATA */ + 0x00000000 /* DENALI_PHY_918_DATA */ + 0x00000000 /* DENALI_PHY_919_DATA */ + 0x00000000 /* DENALI_PHY_920_DATA */ + 0x00000000 /* DENALI_PHY_921_DATA */ + 0x00000000 /* DENALI_PHY_922_DATA */ + 0x00000000 /* DENALI_PHY_923_DATA */ + 0x00000000 /* DENALI_PHY_924_DATA */ + 0x00000000 /* DENALI_PHY_925_DATA */ + 0x00000000 /* DENALI_PHY_926_DATA */ + 0x00000000 /* DENALI_PHY_927_DATA */ + 0x00000000 /* DENALI_PHY_928_DATA */ + 0x00200000 /* DENALI_PHY_929_DATA */ + 0x00000000 /* DENALI_PHY_930_DATA */ + 0x00000000 /* DENALI_PHY_931_DATA */ + 0x00000000 /* DENALI_PHY_932_DATA */ + 0x00000000 /* DENALI_PHY_933_DATA */ + 0x00000000 /* DENALI_PHY_934_DATA */ + 0x00000000 /* DENALI_PHY_935_DATA */ + 0x02800280 /* DENALI_PHY_936_DATA */ + 0x02800280 /* DENALI_PHY_937_DATA */ + 0x02800280 /* DENALI_PHY_938_DATA */ + 0x02800280 /* DENALI_PHY_939_DATA */ + 0x00000280 /* DENALI_PHY_940_DATA */ + 0x00000000 /* DENALI_PHY_941_DATA */ + 0x00000000 /* DENALI_PHY_942_DATA */ + 0x00000000 /* DENALI_PHY_943_DATA */ + 0x00000000 /* DENALI_PHY_944_DATA */ + 0x00000000 /* DENALI_PHY_945_DATA */ + 0x00800080 /* DENALI_PHY_946_DATA */ + 0x00800080 /* DENALI_PHY_947_DATA */ + 0x00800080 /* DENALI_PHY_948_DATA */ + 0x00800080 /* DENALI_PHY_949_DATA */ + 0x00800080 /* DENALI_PHY_950_DATA */ + 0x00800080 /* DENALI_PHY_951_DATA */ + 0x00800080 /* DENALI_PHY_952_DATA */ + 0x00800080 /* DENALI_PHY_953_DATA */ + 0x00800080 /* DENALI_PHY_954_DATA */ + 0x000100da /* DENALI_PHY_955_DATA */ + 0x00000200 /* DENALI_PHY_956_DATA */ + 0x00000000 /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + 0x00000002 /* DENALI_PHY_959_DATA */ + 0x51313152 /* DENALI_PHY_960_DATA */ + 0x80013130 /* DENALI_PHY_961_DATA */ + 0x02000080 /* DENALI_PHY_962_DATA */ + 0x00100001 /* DENALI_PHY_963_DATA */ + 0x0c064208 /* DENALI_PHY_964_DATA */ + 0x000f0c0f /* DENALI_PHY_965_DATA */ + 0x01000140 /* DENALI_PHY_966_DATA */ + 0x0000000c /* DENALI_PHY_967_DATA */ + 0x00000000 /* DENALI_PHY_968_DATA */ + 0x00000000 /* DENALI_PHY_969_DATA */ + 0x00000000 /* DENALI_PHY_970_DATA */ + 0x00000000 /* DENALI_PHY_971_DATA */ + 0x00000000 /* DENALI_PHY_972_DATA */ + 0x00000000 /* DENALI_PHY_973_DATA */ + 0x00000000 /* DENALI_PHY_974_DATA */ + 0x00000000 /* DENALI_PHY_975_DATA */ + 0x00000000 /* DENALI_PHY_976_DATA */ + 0x00000000 /* DENALI_PHY_977_DATA */ + 0x00000000 /* DENALI_PHY_978_DATA */ + 0x00000000 /* DENALI_PHY_979_DATA */ + 0x00000000 /* DENALI_PHY_980_DATA */ + 0x00000000 /* DENALI_PHY_981_DATA */ + 0x00000000 /* DENALI_PHY_982_DATA */ + 0x00000000 /* DENALI_PHY_983_DATA */ + 0x00000000 /* DENALI_PHY_984_DATA */ + 0x00000000 /* DENALI_PHY_985_DATA */ + 0x00000000 /* DENALI_PHY_986_DATA */ + 0x00000000 /* DENALI_PHY_987_DATA */ + 0x00000000 /* DENALI_PHY_988_DATA */ + 0x00000000 /* DENALI_PHY_989_DATA */ + 0x00000000 /* DENALI_PHY_990_DATA */ + 0x00000000 /* DENALI_PHY_991_DATA */ + 0x00000000 /* DENALI_PHY_992_DATA */ + 0x00000000 /* DENALI_PHY_993_DATA */ + 0x00000000 /* DENALI_PHY_994_DATA */ + 0x00000000 /* DENALI_PHY_995_DATA */ + 0x00000000 /* DENALI_PHY_996_DATA */ + 0x00000000 /* DENALI_PHY_997_DATA */ + 0x00000000 /* DENALI_PHY_998_DATA */ + 0x00000000 /* DENALI_PHY_999_DATA */ + 0x00000000 /* DENALI_PHY_1000_DATA */ + 0x00000000 /* DENALI_PHY_1001_DATA */ + 0x00000000 /* DENALI_PHY_1002_DATA */ + 0x00000000 /* DENALI_PHY_1003_DATA */ + 0x00000000 /* DENALI_PHY_1004_DATA */ + 0x00000000 /* DENALI_PHY_1005_DATA */ + 0x00000000 /* DENALI_PHY_1006_DATA */ + 0x00000000 /* DENALI_PHY_1007_DATA */ + 0x00000000 /* DENALI_PHY_1008_DATA */ + 0x00000000 /* DENALI_PHY_1009_DATA */ + 0x00000000 /* DENALI_PHY_1010_DATA */ + 0x00000000 /* DENALI_PHY_1011_DATA */ + 0x00000000 /* DENALI_PHY_1012_DATA */ + 0x00000000 /* DENALI_PHY_1013_DATA */ + 0x00000000 /* DENALI_PHY_1014_DATA */ + 0x00000000 /* DENALI_PHY_1015_DATA */ + 0x00000000 /* DENALI_PHY_1016_DATA */ + 0x00000000 /* DENALI_PHY_1017_DATA */ + 0x00000000 /* DENALI_PHY_1018_DATA */ + 0x00000000 /* DENALI_PHY_1019_DATA */ + 0x00000000 /* DENALI_PHY_1020_DATA */ + 0x00000000 /* DENALI_PHY_1021_DATA */ + 0x00000000 /* DENALI_PHY_1022_DATA */ + 0x00000000 /* DENALI_PHY_1023_DATA */ + 0x36025174 /* DENALI_PHY_1024_DATA */ + 0x0004c008 /* DENALI_PHY_1025_DATA */ + 0x000000da /* DENALI_PHY_1026_DATA */ + 0x00000000 /* DENALI_PHY_1027_DATA */ + 0x00000000 /* DENALI_PHY_1028_DATA */ + 0x00010000 /* DENALI_PHY_1029_DATA */ + 0x01DDDD90 /* DENALI_PHY_1030_DATA */ + 0x01DDDD90 /* DENALI_PHY_1031_DATA */ + 0x01030000 /* DENALI_PHY_1032_DATA */ + 0x01000000 /* DENALI_PHY_1033_DATA */ + 0x00c00000 /* DENALI_PHY_1034_DATA */ + 0x00000007 /* DENALI_PHY_1035_DATA */ + 0x00000000 /* DENALI_PHY_1036_DATA */ + 0x00000000 /* DENALI_PHY_1037_DATA */ + 0x04000408 /* DENALI_PHY_1038_DATA */ + 0x00000408 /* DENALI_PHY_1039_DATA */ + 0x00e4e400 /* DENALI_PHY_1040_DATA */ + 0x00000000 /* DENALI_PHY_1041_DATA */ + 0x00000000 /* DENALI_PHY_1042_DATA */ + 0x00000000 /* DENALI_PHY_1043_DATA */ + 0x00000000 /* DENALI_PHY_1044_DATA */ + 0x00000000 /* DENALI_PHY_1045_DATA */ + 0x00000000 /* DENALI_PHY_1046_DATA */ + 0x00000000 /* DENALI_PHY_1047_DATA */ + 0x00000000 /* DENALI_PHY_1048_DATA */ + 0x00000000 /* DENALI_PHY_1049_DATA */ + 0x00000000 /* DENALI_PHY_1050_DATA */ + 0x00000000 /* DENALI_PHY_1051_DATA */ + 0x00000000 /* DENALI_PHY_1052_DATA */ + 0x00000000 /* DENALI_PHY_1053_DATA */ + 0x00000000 /* DENALI_PHY_1054_DATA */ + 0x00000000 /* DENALI_PHY_1055_DATA */ + 0x00000000 /* DENALI_PHY_1056_DATA */ + 0x00200000 /* DENALI_PHY_1057_DATA */ + 0x00000000 /* DENALI_PHY_1058_DATA */ + 0x00000000 /* DENALI_PHY_1059_DATA */ + 0x00000000 /* DENALI_PHY_1060_DATA */ + 0x00000000 /* DENALI_PHY_1061_DATA */ + 0x00000000 /* DENALI_PHY_1062_DATA */ + 0x00000000 /* DENALI_PHY_1063_DATA */ + 0x02800280 /* DENALI_PHY_1064_DATA */ + 0x02800280 /* DENALI_PHY_1065_DATA */ + 0x02800280 /* DENALI_PHY_1066_DATA */ + 0x02800280 /* DENALI_PHY_1067_DATA */ + 0x00000280 /* DENALI_PHY_1068_DATA */ + 0x00000000 /* DENALI_PHY_1069_DATA */ + 0x00000000 /* DENALI_PHY_1070_DATA */ + 0x00000000 /* DENALI_PHY_1071_DATA */ + 0x00000000 /* DENALI_PHY_1072_DATA */ + 0x00000000 /* DENALI_PHY_1073_DATA */ + 0x00800080 /* DENALI_PHY_1074_DATA */ + 0x00800080 /* DENALI_PHY_1075_DATA */ + 0x00800080 /* DENALI_PHY_1076_DATA */ + 0x00800080 /* DENALI_PHY_1077_DATA */ + 0x00800080 /* DENALI_PHY_1078_DATA */ + 0x00800080 /* DENALI_PHY_1079_DATA */ + 0x00800080 /* DENALI_PHY_1080_DATA */ + 0x00800080 /* DENALI_PHY_1081_DATA */ + 0x00800080 /* DENALI_PHY_1082_DATA */ + 0x000100da /* DENALI_PHY_1083_DATA */ + 0x00000200 /* DENALI_PHY_1084_DATA */ + 0x00000000 /* DENALI_PHY_1085_DATA */ + 0x00000000 /* DENALI_PHY_1086_DATA */ + 0x00000002 /* DENALI_PHY_1087_DATA */ + 0x51313152 /* DENALI_PHY_1088_DATA */ + 0x80013130 /* DENALI_PHY_1089_DATA */ + 0x02000080 /* DENALI_PHY_1090_DATA */ + 0x00100001 /* DENALI_PHY_1091_DATA */ + 0x0c064208 /* DENALI_PHY_1092_DATA */ + 0x000f0c0f /* DENALI_PHY_1093_DATA */ + 0x01000140 /* DENALI_PHY_1094_DATA */ + 0x0000000c /* DENALI_PHY_1095_DATA */ + 0x00000000 /* DENALI_PHY_1096_DATA */ + 0x00000000 /* DENALI_PHY_1097_DATA */ + 0x00000000 /* DENALI_PHY_1098_DATA */ + 0x00000000 /* DENALI_PHY_1099_DATA */ + 0x00000000 /* DENALI_PHY_1100_DATA */ + 0x00000000 /* DENALI_PHY_1101_DATA */ + 0x00000000 /* DENALI_PHY_1102_DATA */ + 0x00000000 /* DENALI_PHY_1103_DATA */ + 0x00000000 /* DENALI_PHY_1104_DATA */ + 0x00000000 /* DENALI_PHY_1105_DATA */ + 0x00000000 /* DENALI_PHY_1106_DATA */ + 0x00000000 /* DENALI_PHY_1107_DATA */ + 0x00000000 /* DENALI_PHY_1108_DATA */ + 0x00000000 /* DENALI_PHY_1109_DATA */ + 0x00000000 /* DENALI_PHY_1110_DATA */ + 0x00000000 /* DENALI_PHY_1111_DATA */ + 0x00000000 /* DENALI_PHY_1112_DATA */ + 0x00000000 /* DENALI_PHY_1113_DATA */ + 0x00000000 /* DENALI_PHY_1114_DATA */ + 0x00000000 /* DENALI_PHY_1115_DATA */ + 0x00000000 /* DENALI_PHY_1116_DATA */ + 0x00000000 /* DENALI_PHY_1117_DATA */ + 0x00000000 /* DENALI_PHY_1118_DATA */ + 0x00000000 /* DENALI_PHY_1119_DATA */ + 0x00000000 /* DENALI_PHY_1120_DATA */ + 0x00000000 /* DENALI_PHY_1121_DATA */ + 0x00000000 /* DENALI_PHY_1122_DATA */ + 0x00000000 /* DENALI_PHY_1123_DATA */ + 0x00000000 /* DENALI_PHY_1124_DATA */ + 0x00000000 /* DENALI_PHY_1125_DATA */ + 0x00000000 /* DENALI_PHY_1126_DATA */ + 0x00000000 /* DENALI_PHY_1127_DATA */ + 0x00000000 /* DENALI_PHY_1128_DATA */ + 0x00000000 /* DENALI_PHY_1129_DATA */ + 0x00000000 /* DENALI_PHY_1130_DATA */ + 0x00000000 /* DENALI_PHY_1131_DATA */ + 0x00000000 /* DENALI_PHY_1132_DATA */ + 0x00000000 /* DENALI_PHY_1133_DATA */ + 0x00000000 /* DENALI_PHY_1134_DATA */ + 0x00000000 /* DENALI_PHY_1135_DATA */ + 0x00000000 /* DENALI_PHY_1136_DATA */ + 0x00000000 /* DENALI_PHY_1137_DATA */ + 0x00000000 /* DENALI_PHY_1138_DATA */ + 0x00000000 /* DENALI_PHY_1139_DATA */ + 0x00000000 /* DENALI_PHY_1140_DATA */ + 0x00000000 /* DENALI_PHY_1141_DATA */ + 0x00000000 /* DENALI_PHY_1142_DATA */ + 0x00000000 /* DENALI_PHY_1143_DATA */ + 0x00000000 /* DENALI_PHY_1144_DATA */ + 0x00000000 /* DENALI_PHY_1145_DATA */ + 0x00000000 /* DENALI_PHY_1146_DATA */ + 0x00000000 /* DENALI_PHY_1147_DATA */ + 0x00000000 /* DENALI_PHY_1148_DATA */ + 0x00000000 /* DENALI_PHY_1149_DATA */ + 0x00000000 /* DENALI_PHY_1150_DATA */ + 0x00000000 /* DENALI_PHY_1151_DATA */ + 0x00000000 /* DENALI_PHY_1152_DATA */ + 0x00000000 /* DENALI_PHY_1153_DATA */ + 0x00050000 /* DENALI_PHY_1154_DATA */ + 0x00000000 /* DENALI_PHY_1155_DATA */ + 0x00000000 /* DENALI_PHY_1156_DATA */ + 0x00000000 /* DENALI_PHY_1157_DATA */ + 0x00000100 /* DENALI_PHY_1158_DATA */ + 0x00000000 /* DENALI_PHY_1159_DATA */ + 0x00000000 /* DENALI_PHY_1160_DATA */ + 0x00506401 /* DENALI_PHY_1161_DATA */ + 0x01221102 /* DENALI_PHY_1162_DATA */ + 0x00000122 /* DENALI_PHY_1163_DATA */ + 0x00000000 /* DENALI_PHY_1164_DATA */ + 0x000B1F00 /* DENALI_PHY_1165_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1166_DATA */ + 0x0B1F0B1B /* DENALI_PHY_1167_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1168_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1169_DATA */ + 0x00000B00 /* DENALI_PHY_1170_DATA */ + 0x42080010 /* DENALI_PHY_1171_DATA */ + 0x01000100 /* DENALI_PHY_1172_DATA */ + 0x01000100 /* DENALI_PHY_1173_DATA */ + 0x01000100 /* DENALI_PHY_1174_DATA */ + 0x01000100 /* DENALI_PHY_1175_DATA */ + 0x00000000 /* DENALI_PHY_1176_DATA */ + 0x00000000 /* DENALI_PHY_1177_DATA */ + 0x00000000 /* DENALI_PHY_1178_DATA */ + 0x00000000 /* DENALI_PHY_1179_DATA */ + 0x00000000 /* DENALI_PHY_1180_DATA */ + 0x00000803 /* DENALI_PHY_1181_DATA */ + 0x223FFF00 /* DENALI_PHY_1182_DATA */ + 0x000008FF /* DENALI_PHY_1183_DATA */ + 0x0000057F /* DENALI_PHY_1184_DATA */ + 0x0000057F /* DENALI_PHY_1185_DATA */ + 0x00037FFF /* DENALI_PHY_1186_DATA */ + 0x00037FFF /* DENALI_PHY_1187_DATA */ + 0x00004410 /* DENALI_PHY_1188_DATA */ + 0x00004410 /* DENALI_PHY_1189_DATA */ + 0x00004410 /* DENALI_PHY_1190_DATA */ + 0x00004410 /* DENALI_PHY_1191_DATA */ + 0x00004410 /* DENALI_PHY_1192_DATA */ + 0x00037FFF /* DENALI_PHY_1193_DATA */ + 0x00037FFF /* DENALI_PHY_1194_DATA */ + 0x00000000 /* DENALI_PHY_1195_DATA */ + 0x00000000 /* DENALI_PHY_1196_DATA */ + 0x00000000 /* DENALI_PHY_1197_DATA */ + 0x04000000 /* DENALI_PHY_1198_DATA */ + 0x00000000 /* DENALI_PHY_1199_DATA */ + 0x00000000 /* DENALI_PHY_1200_DATA */ + 0x00000108 /* DENALI_PHY_1201_DATA */ + 0x00000000 /* DENALI_PHY_1202_DATA */ + 0x00000000 /* DENALI_PHY_1203_DATA */ + 0x00000000 /* DENALI_PHY_1204_DATA */ + 0x00000001 /* DENALI_PHY_1205_DATA */ + 0x00000000 /* DENALI_PHY_1206_DATA */ + 0x00000000 /* DENALI_PHY_1207_DATA */ + 0x00000000 /* DENALI_PHY_1208_DATA */ + 0x00000000 /* DENALI_PHY_1209_DATA */ + 0x00000000 /* DENALI_PHY_1210_DATA */ + 0x00000000 /* DENALI_PHY_1211_DATA */ + 0x00020100 /* DENALI_PHY_1212_DATA */ + 0x00000000 /* DENALI_PHY_1213_DATA */ + 0x00000000 /* DENALI_PHY_1214_DATA */ + >; +};
Add dmc node to enable ddr driver. dmc is used to initialize the memory controller.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index fbfe296a03..fc91a7c987 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -59,6 +59,15 @@ reg = <0x0 0x2000000 0x0 0xc0000>; u-boot,dm-spl; }; + dmc: dmc@100b0000 { + compatible = "sifive,fu540-c000-ddr"; + reg = <0x0 0x100b0000 0x0 0x0800 + 0x0 0x100b2000 0x0 0x2000 + 0x0 0x100b8000 0x0 0x0fff>; + clocks = <&prci PRCI_CLK_DDRPLL>; + clock-frequency = <933333324>; + u-boot,dm-spl; + }; }; };
Added clock enable and disable functions in prci ops
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Acked-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sifive/fu540-prci.c | 108 ++++++++++++++++++++++++++++---- 1 file changed, 96 insertions(+), 12 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 67e21b6746..7052db4b8a 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -69,6 +69,11 @@ #define PRCI_COREPLLCFG0_LOCK_SHIFT 31 #define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT)
+/* COREPLLCFG1 */ +#define PRCI_COREPLLCFG1_OFFSET 0x8 +#define PRCI_COREPLLCFG1_CKE_SHIFT 31 +#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT) + /* DDRPLLCFG0 */ #define PRCI_DDRPLLCFG0_OFFSET 0xc #define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 @@ -88,7 +93,7 @@
/* DDRPLLCFG1 */ #define PRCI_DDRPLLCFG1_OFFSET 0x10 -#define PRCI_DDRPLLCFG1_CKE_SHIFT 24 +#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 #define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT)
/* GEMGXLPLLCFG0 */ @@ -115,7 +120,7 @@
/* GEMGXLPLLCFG1 */ #define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 -#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 24 +#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 #define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT)
/* CORECLKSEL */ @@ -143,7 +148,7 @@ (0x1 << PRCI_DEVICESRESETREG_GEMGXL_RST_N_SHIFT)
/* CLKMUXSTATUSREG */ -#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c +#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT) @@ -171,6 +176,7 @@ struct __prci_data { * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address + * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address * * @enable_bypass and @disable_bypass are used for WRPLL instances * that contain a separate external glitchless clock mux downstream @@ -181,6 +187,7 @@ struct __prci_wrpll_data { void (*enable_bypass)(struct __prci_data *pd); void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; + u8 cfg1_offs; };
struct __prci_clock; @@ -195,6 +202,7 @@ struct __prci_clock_ops { unsigned long *parent_rate); unsigned long (*recalc_rate)(struct __prci_clock *pc, unsigned long parent_rate); + int (*enable_clk)(struct __prci_clock *pc, bool enable); };
/** @@ -317,7 +325,7 @@ static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) }
/** - * __prci_wrpll_read_cfg() - read the WRPLL configuration from the PRCI + * __prci_wrpll_read_cfg0() - read the WRPLL configuration from the PRCI * @pd: PRCI context * @pwd: PRCI WRPLL metadata * @@ -328,14 +336,14 @@ static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) * Context: Any context. Caller must prevent the records pointed to by * @pd and @pwd from changing during execution. */ -static void __prci_wrpll_read_cfg(struct __prci_data *pd, - struct __prci_wrpll_data *pwd) +static void __prci_wrpll_read_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd) { __prci_wrpll_unpack(&pwd->c, __prci_readl(pd, pwd->cfg0_offs)); }
/** - * __prci_wrpll_write_cfg() - write WRPLL configuration into the PRCI + * __prci_wrpll_write_cfg0() - write WRPLL configuration into the PRCI * @pd: PRCI context * @pwd: PRCI WRPLL metadata * @c: WRPLL configuration record to write @@ -348,15 +356,29 @@ static void __prci_wrpll_read_cfg(struct __prci_data *pd, * Context: Any context. Caller must prevent the records pointed to by * @pd and @pwd from changing during execution. */ -static void __prci_wrpll_write_cfg(struct __prci_data *pd, - struct __prci_wrpll_data *pwd, - struct wrpll_cfg *c) +static void __prci_wrpll_write_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + struct wrpll_cfg *c) { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
memcpy(&pwd->c, c, sizeof(*c)); }
+/** + * __prci_wrpll_write_cfg1() - write Clock enable/disable configuration + * into the PRCI + * @pd: PRCI context + * @pwd: PRCI WRPLL metadata + * @enable: Clock enable or disable value + */ +static void __prci_wrpll_write_cfg1(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + u32 enable) +{ + __prci_writel(enable, pwd->cfg1_offs, pd); +} + /* Core clock mux control */
/** @@ -438,7 +460,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, if (pwd->enable_bypass) pwd->enable_bypass(pd);
- __prci_wrpll_write_cfg(pd, pwd, &pwd->c); + __prci_wrpll_write_cfg0(pd, pwd, &pwd->c);
udelay(wrpll_calc_max_lock_us(&pwd->c));
@@ -448,14 +470,35 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, return 0; }
+static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct __prci_data *pd = pc->pd; + + if (enable) { + __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); + } else { + u32 r; + + r = __prci_readl(pd, pwd->cfg1_offs); + r &= ~PRCI_COREPLLCFG1_CKE_MASK; + + __prci_wrpll_write_cfg1(pd, pwd, r); + } + + return 0; +} + static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { .set_rate = sifive_fu540_prci_wrpll_set_rate, .round_rate = sifive_fu540_prci_wrpll_round_rate, .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, + .enable_clk = sifive_fu540_prci_clock_enable, };
static const struct __prci_clock_ops sifive_fu540_prci_wrpll_ro_clk_ops = { .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, + .enable_clk = sifive_fu540_prci_clock_enable, };
/* TLCLKSEL clock integration */ @@ -485,16 +528,19 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, + .cfg1_offs = PRCI_COREPLLCFG1_OFFSET, .enable_bypass = __prci_coreclksel_use_hfclk, .disable_bypass = __prci_coreclksel_use_corepll, };
static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, + .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, };
static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, + .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, };
/* @@ -581,6 +627,42 @@ static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) return rate; }
+static int sifive_fu540_prci_enable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + + if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) + return -ENXIO; + + pc = &__prci_init_clocks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 1); + + return ret; +} + +static int sifive_fu540_prci_disable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + + if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) + return -ENXIO; + + pc = &__prci_init_clocks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 0); + + return ret; +} + static int sifive_fu540_prci_probe(struct udevice *dev) { int i, err; @@ -603,7 +685,7 @@ static int sifive_fu540_prci_probe(struct udevice *dev) pc = &__prci_init_clocks[i]; pc->pd = pd; if (pc->pwd) - __prci_wrpll_read_cfg(pd, pc->pwd); + __prci_wrpll_read_cfg0(pd, pc->pwd); }
return 0; @@ -612,6 +694,8 @@ static int sifive_fu540_prci_probe(struct udevice *dev) static struct clk_ops sifive_fu540_prci_ops = { .set_rate = sifive_fu540_prci_set_rate, .get_rate = sifive_fu540_prci_get_rate, + .enable = sifive_fu540_prci_enable, + .disable = sifive_fu540_prci_disable, };
static const struct udevice_id sifive_fu540_prci_ids[] = {
Release ddr clock reset once clock is initialized
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sifive/fu540-prci.c | 51 +++++++++++++++++++++++++++++---- 1 file changed, 45 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 7052db4b8a..3728aa533c 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -153,6 +153,12 @@ #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT)
+/* PROCMONCFG */ +#define PRCI_PROCMONCFG_OFFSET 0xF0 +#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 +#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \ + (0x1 << PRCI_PROCMONCFG_CORE_CLOCK_SHIFT) + /* * Private structures */ @@ -177,6 +183,7 @@ struct __prci_data { * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address + * @release_reset: fn ptr to code to release clock reset * * @enable_bypass and @disable_bypass are used for WRPLL instances * that contain a separate external glitchless clock mux downstream @@ -188,6 +195,7 @@ struct __prci_wrpll_data { void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; u8 cfg1_offs; + void (*release_reset)(struct __prci_data *pd); };
struct __prci_clock; @@ -477,6 +485,9 @@ static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable)
if (enable) { __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); + + if (pwd->release_reset) + pwd->release_reset(pd); } else { u32 r;
@@ -496,11 +507,6 @@ static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { .enable_clk = sifive_fu540_prci_clock_enable, };
-static const struct __prci_clock_ops sifive_fu540_prci_wrpll_ro_clk_ops = { - .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, - .enable_clk = sifive_fu540_prci_clock_enable, -}; - /* TLCLKSEL clock integration */
static unsigned long sifive_fu540_prci_tlclksel_recalc_rate( @@ -522,6 +528,38 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { .recalc_rate = sifive_fu540_prci_tlclksel_recalc_rate, };
+/** + * __prci_ddr_release_reset() - Release DDR reset + * @pd: struct __prci_data * for the PRCI containing the DDRCLK mux reg + * + */ +static void __prci_ddr_release_reset(struct __prci_data *pd) +{ + u32 v; + + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= PRCI_DEVICESRESETREG_DDR_CTRL_RST_N_MASK; + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= (PRCI_DEVICESRESETREG_DDR_AXI_RST_N_MASK | + PRCI_DEVICESRESETREG_DDR_AHB_RST_N_MASK | + PRCI_DEVICESRESETREG_DDR_PHY_RST_N_MASK); + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + + /* + * These take like 16 cycles to actually propagate. We can't go sending + * stuff before they come out of reset. So wait. + */ + for (int i = 0; i < 256; i++) + asm volatile ("nop"); +} + /* * PRCI integration data for each WRPLL instance */ @@ -536,6 +574,7 @@ static struct __prci_wrpll_data __prci_corepll_data = { static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, + .release_reset = __prci_ddr_release_reset, };
static struct __prci_wrpll_data __prci_gemgxlpll_data = { @@ -557,7 +596,7 @@ static struct __prci_clock __prci_init_clocks[] = { [PRCI_CLK_DDRPLL] = { .name = "ddrpll", .parent_name = "hfclk", - .ops = &sifive_fu540_prci_wrpll_ro_clk_ops, + .ops = &sifive_fu540_prci_wrpll_clk_ops, .pwd = &__prci_ddrpll_data, }, [PRCI_CLK_GEMGXLPLL] = {
U-Boot ethernet works with FSBL flow where releasing ethernet clock reset is part of FSBL itself but with the SPL, We need to release ethernet clock reset explicitly for U-Boot proper. With this change Release ethernet clock reset code in FSBL might not be needed or unaffected.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/sifive/fu540-prci.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 3728aa533c..fe6e0d4073 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -560,6 +560,25 @@ static void __prci_ddr_release_reset(struct __prci_data *pd) asm volatile ("nop"); }
+/** + * __prci_ethernet_release_reset() - Release ethernet reset + * @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg + * + */ +static void __prci_ethernet_release_reset(struct __prci_data *pd) +{ + u32 v; + + /* Release GEMGXL reset */ + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= PRCI_DEVICESRESETREG_GEMGXL_RST_N_MASK; + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* Procmon => core clock */ + __prci_writel(PRCI_PROCMONCFG_CORE_CLOCK_MASK, PRCI_PROCMONCFG_OFFSET, + pd); +} + /* * PRCI integration data for each WRPLL instance */ @@ -580,6 +599,7 @@ static struct __prci_wrpll_data __prci_ddrpll_data = { static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, + .release_reset = __prci_ethernet_release_reset, };
Set ethernet clock rate to 125 Mhz so that it will work with 1000Mbps, Earlier this is done by FSBL. With this change We can remove the ethernet clock rate code from FSBL.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index fc91a7c987..9bba554f9d 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -82,3 +82,8 @@ &qspi2 { u-boot,dm-spl; }; + +ð0 { + assigned-clocks = <&prci PRCI_CLK_GEMGXLPLL>; + assigned-clock-rates = <125000000>; +};
On Fri, May 29, 2020 at 2:05 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
This sync has changes required to use GPIO in U-Boot and U-Boot SPL.
Sync dts from linux v5.7-rc2 commit: "riscv: dts: Add GPIO reboot method to HiFive Unleashed DTS file" (sha1: 0a91330b2af9f71ceeeed483f92774182b58f6d9)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/dts/fu540-c000.dtsi | 37 ++++++++++++++++++++++++- arch/riscv/dts/hifive-unleashed-a00.dts | 9 ++++++ 2 files changed, 45 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/dts/fu540-c000.dtsi b/arch/riscv/dts/fu540-c000.dtsi index afa43c7ea3..7db8610534 100644 --- a/arch/riscv/dts/fu540-c000.dtsi +++ b/arch/riscv/dts/fu540-c000.dtsi @@ -54,6 +54,7 @@ reg = <1>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu1_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -77,6 +78,7 @@ reg = <2>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu2_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -100,6 +102,7 @@ reg = <3>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu3_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -123,6 +126,7 @@ reg = <4>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu4_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -162,6 +166,13 @@ clocks = <&prci PRCI_CLK_TLCLK>; status = "disabled"; }; + dma: dma@3000000 { + compatible = "sifive,fu540-c000-pdma"; + reg = <0x0 0x3000000 0x0 0x8000>; + interrupt-parent = <&plic0>; + interrupts = <23 24 25 26 27 28 29 30>; + #dma-cells = <1>; + }; uart1: serial@10011000 { compatible = "sifive,fu540-c000-uart", "sifive,uart0"; reg = <0x0 0x10011000 0x0 0x1000>; @@ -246,6 +257,30 @@ #pwm-cells = <3>; status = "disabled"; }; - + l2cache: cache-controller@2010000 { + compatible = "sifive,fu540-c000-ccache", "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <1024>; + cache-size = <2097152>; + cache-unified; + interrupt-parent = <&plic0>; + interrupts = <1 2 3>; + reg = <0x0 0x2010000 0x0 0x1000>; + }; + gpio: gpio@10060000 { + compatible = "sifive,fu540-c000-gpio", "sifive,gpio0"; + interrupt-parent = <&plic0>; + interrupts = <7>, <8>, <9>, <10>, <11>, <12>, <13>, + <14>, <15>, <16>, <17>, <18>, <19>, <20>, + <21>, <22>; + reg = <0x0 0x10060000 0x0 0x1000>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&prci PRCI_CLK_TLCLK>; + status = "disabled"; + }; }; }; diff --git a/arch/riscv/dts/hifive-unleashed-a00.dts b/arch/riscv/dts/hifive-unleashed-a00.dts index 88cfcb96bf..4a2729f5ca 100644 --- a/arch/riscv/dts/hifive-unleashed-a00.dts +++ b/arch/riscv/dts/hifive-unleashed-a00.dts @@ -2,6 +2,7 @@ /* Copyright (c) 2018-2019 SiFive, Inc */
#include "fu540-c000.dtsi" +#include <dt-bindings/gpio/gpio.h>
/* Clock frequency (in Hz) of the PCB crystal for rtcclk */ #define RTCCLK_FREQ 1000000 @@ -41,6 +42,10 @@ clock-frequency = <RTCCLK_FREQ>; clock-output-names = "rtcclk"; }; + gpio-restart { + compatible = "gpio-restart"; + gpios = <&gpio 10 GPIO_ACTIVE_LOW>; + }; };
&uart0 { @@ -94,3 +99,7 @@ &pwm1 { status = "okay"; }; + +&gpio { + status = "okay"; +};
Add SiFive fu540 cpu to support RISC-V arch
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu540/Kconfig | 15 ++++++++++ arch/riscv/cpu/fu540/Makefile | 7 +++++ arch/riscv/cpu/fu540/cpu.c | 22 ++++++++++++++ arch/riscv/cpu/fu540/dram.c | 38 ++++++++++++++++++++++++ arch/riscv/include/asm/arch-fu540/clk.h | 14 +++++++++ arch/riscv/include/asm/arch-fu540/gpio.h | 38 ++++++++++++++++++++++++ board/sifive/fu540/Kconfig | 2 +- 8 files changed, 136 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu540/Kconfig create mode 100644 arch/riscv/cpu/fu540/Makefile create mode 100644 arch/riscv/cpu/fu540/cpu.c create mode 100644 arch/riscv/cpu/fu540/dram.c create mode 100644 arch/riscv/include/asm/arch-fu540/clk.h create mode 100644 arch/riscv/include/asm/arch-fu540/gpio.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fb5fe5afff..d9854f5283 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -56,6 +56,7 @@ source "board/sifive/fu540/Kconfig"
# platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" +source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/generic/Kconfig"
# architecture-specific options below diff --git a/arch/riscv/cpu/fu540/Kconfig b/arch/riscv/cpu/fu540/Kconfig new file mode 100644 index 0000000000..e9302e87c0 --- /dev/null +++ b/arch/riscv/cpu/fu540/Kconfig @@ -0,0 +1,15 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + +config SIFIVE_FU540 + bool + select ARCH_EARLY_INIT_R + imply CPU + imply CPU_RISCV + imply RISCV_TIMER + imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply CMD_CPU + imply SPL_CPU_SUPPORT + imply SPL_OPENSBI + imply SPL_LOAD_FIT diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile new file mode 100644 index 0000000000..44700d998c --- /dev/null +++ b/arch/riscv/cpu/fu540/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com + +obj-y += dram.o +obj-y += cpu.o diff --git a/arch/riscv/cpu/fu540/cpu.c b/arch/riscv/cpu/fu540/cpu.c new file mode 100644 index 0000000000..f13c18942f --- /dev/null +++ b/arch/riscv/cpu/fu540/cpu.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <irq_func.h> +#include <asm/cache.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + disable_interrupts(); + + cache_flush(); + + return 0; +} diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c new file mode 100644 index 0000000000..1dc77efeca --- /dev/null +++ b/arch/riscv/cpu/fu540/dram.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_64BIT + /* + * Ensure that we run from first 4GB so that all + * addresses used by U-Boot are 32bit addresses. + * + * This in-turn ensures that 32bit DMA capable + * devices work fine because DMA mapping APIs will + * provide 32bit DMA addresses only. + */ + if (gd->ram_top > SZ_4G) + return SZ_4G; +#endif + return gd->ram_top; +} diff --git a/arch/riscv/include/asm/arch-fu540/clk.h b/arch/riscv/include/asm/arch-fu540/clk.h new file mode 100644 index 0000000000..d71ed4357c --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/clk.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 SiFive Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#ifndef __CLK_SIFIVE_H +#define __CLK_SIFIVE_H + +/* Note: This is a placeholder header for driver compilation. */ + +#endif diff --git a/arch/riscv/include/asm/arch-fu540/gpio.h b/arch/riscv/include/asm/arch-fu540/gpio.h new file mode 100644 index 0000000000..0d16c59ca6 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/gpio.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 SiFive, Inc. + */ + +#ifndef _GPIO_SIFIVE_H +#define _GPIO_SIFIVE_H + +#define GPIO_INPUT_VAL 0x00 +#define GPIO_INPUT_EN 0x04 +#define GPIO_OUTPUT_EN 0x08 +#define GPIO_OUTPUT_VAL 0x0C +#define GPIO_RISE_IE 0x18 +#define GPIO_RISE_IP 0x1C +#define GPIO_FALL_IE 0x20 +#define GPIO_FALL_IP 0x24 +#define GPIO_HIGH_IE 0x28 +#define GPIO_HIGH_IP 0x2C +#define GPIO_LOW_IE 0x30 +#define GPIO_LOW_IP 0x34 +#define GPIO_OUTPUT_XOR 0x40 + +#define NR_GPIOS 16 + +enum gpio_state { + LOW, + HIGH +}; + +/* Details about a GPIO bank */ +struct sifive_gpio_platdata { + void *base; /* address of registers in physical memory */ +}; + +#define SIFIVE_GENERIC_GPIO_NR(port, index) \ + (((port) * NR_GPIOS) + ((index) & (NR_GPIOS - 1))) + +#endif /* _GPIO_SIFIVE_H */ diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index d41c305227..eb5ba3123d 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -7,7 +7,7 @@ config SYS_VENDOR default "sifive"
config SYS_CPU - default "generic" + default "fu540"
config SYS_CONFIG_NAME default "sifive-fu540"
Add a support for SPL which will boot from L2 LIM (0x0800_0000) and then SPL will boot U-Boot FIT image (OpenSBI FW_DYNAMIC + u-boot.bin) from MMC boot devices.
SPL related code is leveraged from FSBL (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/cpu/fu540/Makefile | 4 + arch/riscv/cpu/fu540/spl.c | 23 ++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 5 ++ arch/riscv/include/asm/arch-fu540/spl.h | 14 ++++ board/sifive/fu540/Kconfig | 10 ++- board/sifive/fu540/Makefile | 4 + board/sifive/fu540/fu540.c | 21 ++++++ board/sifive/fu540/spl.c | 74 +++++++++++++++++++ include/configs/sifive-fu540.h | 18 +++++ 9 files changed, 172 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu540/spl.c create mode 100644 arch/riscv/include/asm/arch-fu540/spl.h create mode 100644 board/sifive/fu540/spl.c
diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile index 44700d998c..043fb961a5 100644 --- a/arch/riscv/cpu/fu540/Makefile +++ b/arch/riscv/cpu/fu540/Makefile @@ -3,5 +3,9 @@ # Copyright (C) 2020 SiFive, Inc # Pragnesh Patel pragnesh.patel@sifive.com
+ifeq ($(CONFIG_SPL_BUILD),y) +obj-y += spl.o +else obj-y += dram.o obj-y += cpu.o +endif diff --git a/arch/riscv/cpu/fu540/spl.c b/arch/riscv/cpu/fu540/spl.c new file mode 100644 index 0000000000..a2034e933f --- /dev/null +++ b/arch/riscv/cpu/fu540/spl.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 SiFive, Inc + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <dm.h> +#include <log.h> + +int soc_spl_init(void) +{ + int ret; + struct udevice *dev; + + /* DDR init */ + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + return 0; +} diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 9787332bf1..303806454b 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "fu540-c000-u-boot.dtsi" +#include "fu540-hifive-unleashed-a00-ddr.dtsi"
/ { aliases { @@ -26,3 +27,7 @@ u-boot,dm-spl; }; }; + +&gpio { + u-boot,dm-spl; +}; diff --git a/arch/riscv/include/asm/arch-fu540/spl.h b/arch/riscv/include/asm/arch-fu540/spl.h new file mode 100644 index 0000000000..0c188be747 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/spl.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifve.com + */ + +#ifndef _SPL_SIFIVE_H +#define _SPL_SIFIVE_H + +int soc_spl_init(void); + +#endif /* _SPL_SIFIVE_H */ diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index eb5ba3123d..4a77a2a37b 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -13,12 +13,20 @@ config SYS_CONFIG_NAME default "sifive-fu540"
config SYS_TEXT_BASE + default 0x80200000 if SPL default 0x80000000 if !RISCV_SMODE default 0x80200000 if RISCV_SMODE
+config SPL_TEXT_BASE + default 0x08000000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x80000000 + config BOARD_SPECIFIC_OPTIONS # dummy def_bool y - select GENERIC_RISCV + select SIFIVE_FU540 + select SUPPORT_SPL select RAM select SPL_RAM if SPL imply CMD_DHCP diff --git a/board/sifive/fu540/Makefile b/board/sifive/fu540/Makefile index 6e1862c475..b05e2f5807 100644 --- a/board/sifive/fu540/Makefile +++ b/board/sifive/fu540/Makefile @@ -3,3 +3,7 @@ # Copyright (c) 2019 Western Digital Corporation or its affiliates.
obj-y += fu540.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index ef2c40da27..fa705dea71 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -14,6 +14,7 @@ #include <linux/delay.h> #include <linux/io.h> #include <misc.h> +#include <spl.h>
/* * This define is a value used for error/unknown serial. @@ -117,3 +118,23 @@ int board_init(void)
return 0; } + +#ifdef CONFIG_SPL +u32 spl_boot_device(void) +{ +#ifdef CONFIG_SPL_MMC_SUPPORT + return BOOT_DEVICE_MMC1; +#else + puts("Unknown boot device\n"); + hang(); +#endif +} +#endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* boot using first FIT config */ + return 0; +} +#endif diff --git a/board/sifive/fu540/spl.c b/board/sifive/fu540/spl.c new file mode 100644 index 0000000000..55325cf99d --- /dev/null +++ b/board/sifive/fu540/spl.c @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2019 SiFive, Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <init.h> +#include <spl.h> +#include <misc.h> +#include <log.h> +#include <linux/delay.h> +#include <asm/gpio.h> +#include <asm/arch/gpio.h> +#include <asm/arch/spl.h> + +#define GEM_PHY_RESET SIFIVE_GENERIC_GPIO_NR(0, 12) + +int init_clk_and_ddr(void) +{ + int ret; + + ret = soc_spl_init(); + if (ret) { + debug("FU540 SPL init failed: %d\n", ret); + return ret; + } + + /* + * GEMGXL init VSC8541 PHY reset sequence; + * leave pull-down active for 2ms + */ + udelay(2000); + ret = gpio_request(GEM_PHY_RESET, "gem_phy_reset"); + if (ret) { + debug("gem_phy_reset gpio request failed: %d\n", ret); + return ret; + } + + /* Set GPIO 12 (PHY NRESET) */ + ret = gpio_direction_output(GEM_PHY_RESET, 1); + if (ret) { + debug("gem_phy_reset gpio direction set failed: %d\n", ret); + return ret; + } + + udelay(1); + + /* Reset PHY again to enter unmanaged mode */ + gpio_set_value(GEM_PHY_RESET, 0); + udelay(1); + gpio_set_value(GEM_PHY_RESET, 1); + mdelay(15); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + ret = spl_early_init(); + if (ret) + panic("spl_early_init() failed: %d\n", ret); + + arch_cpu_init_dm(); + + preloader_console_init(); + + ret = init_clk_and_ddr(); + if (ret) + panic("init_clk_and_ddr() failed: %d\n", ret); +} diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index 2756ed5a77..ef3ae9b650 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -11,6 +11,22 @@
+#ifdef CONFIG_SPL + +#define CONFIG_SPL_MAX_SIZE 0x00100000 +#define CONFIG_SPL_BSS_START_ADDR 0x85000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 + +#define CONFIG_SPL_LOAD_FIT_ADDRESS 0x84000000 + +#define CONFIG_SPL_STACK (0x08000000 + 0x001D0000 - \ + GENERATED_GBL_DATA_SIZE) + +#endif + #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M)
@@ -24,6 +40,7 @@
/* Environment options */
+#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(DHCP, dhcp, na) @@ -43,5 +60,6 @@ #define CONFIG_PREBOOT \ "setenv fdt_addr ${fdtcontroladdr};" \ "fdt addr ${fdtcontroladdr};" +#endif
#endif /* __CONFIG_H */
This is a sample GPT partition layout for SD card, right now three important partitions are added to make the system bootable.
partition layout:
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x00000821 "loader1" attrs: 0x0000000000000000 type: 5b193300-fc78-40cd-8002-e86c45580b47 guid: cbcbef44-e627-42bc-b134-93b6f3784b8c 2 0x00000822 0x00002821 "loader2" attrs: 0x0000000000000000 type: 2e54b353-1271-4842-806f-e436d6af6985 guid: f54eba28-d8de-4852-978d-1a673777e2ae 3 0x00002822 0x00020821 "rootfs" attrs: 0x0000000000000004 type: 0fc63daf-8483-4772-8e79-3d69d8477de4 type: linux guid: 9561df46-8d55-4799-a83b-cfee9ef6ff93
Note: - loader1 would be fsbl or spl - loader2 would be U-Boot or U-Boot proper
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Pragnesh Patel pragnesh.patel@sifive.com --- board/sifive/fu540/Kconfig | 2 ++ include/configs/sifive-fu540.h | 13 +++++++++++++ 2 files changed, 15 insertions(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 4a77a2a37b..86193d7668 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -34,6 +34,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_EXT4 imply CMD_FAT imply CMD_FS_GENERIC + imply CMD_GPT + imply PARTITION_TYPE_GUID imply CMD_NET imply CMD_PING imply CMD_SF diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index ef3ae9b650..72c841eb9b 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -47,6 +47,15 @@
#include <config_distro_bootcmd.h>
+#define TYPE_GUID_LOADER1 "5B193300-FC78-40CD-8002-E86C45580B47" +#define TYPE_GUID_LOADER2 "2E54B353-1271-4842-806F-E436D6AF6985" +#define TYPE_GUID_SYSTEM "0FC63DAF-8483-4772-8E79-3D69D8477DE4" + +#define PARTS_DEFAULT \ + "name=loader1,start=17K,size=1M,type=${type_guid_gpt_loader1};" \ + "name=loader2,size=4MB,type=${type_guid_gpt_loader2};" \ + "name=system,size=-,bootable,type=${type_guid_gpt_system};" + #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ @@ -55,6 +64,10 @@ "scriptaddr=0x88100000\0" \ "pxefile_addr_r=0x88200000\0" \ "ramdisk_addr_r=0x88300000\0" \ + "type_guid_gpt_loader1=" TYPE_GUID_LOADER1 "\0" \ + "type_guid_gpt_loader2=" TYPE_GUID_LOADER2 "\0" \ + "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ BOOTENV
Add U-Boot proper sector start offset for SiFive FU540. This value is based on the partition layout supported by SiFive FU540.
u-boot.itb need to write on this specific offset so-that the SPL will retrieve it from here and load.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Pragnesh Patel pragnesh.patel@sifive.com --- common/spl/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 414b6f396d..8ece9057b1 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -308,7 +308,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ - OMAP44XX || OMAP54XX || AM33XX || AM43XX + OMAP44XX || OMAP54XX || AM33XX || AM43XX || TARGET_SIFIVE_FU540 help Use sector number for specifying U-Boot location on MMC/SD in raw mode. @@ -325,6 +325,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR default 0x300 if ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || OMAP44XX || \ OMAP54XX || AM33XX || AM43XX || ARCH_K3 default 0x4000 if ARCH_ROCKCHIP + default 0x822 if TARGET_SIFIVE_FU540 help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
With sifive_fu540_defconfig:
User can use FSBL or u-boot-spl.bin anyone at a time.
For FSBL, fsbl->fw_payload.bin (opensbi + U-Boot)
For u-boot-spl.bin, u-boot-spl.bin->FIT image (opensbi + U-Boot proper + dtb)
U-Boot SPL will be loaded by ZSBL from SD card (replace fsbl.bin with u-boot-spl.bin) and runs in L2 LIM in machine mode and then load FIT image u-boot.itb from SD card into RAM.
U-Boot SPL expects u-boot.itb FIT image at the starting of SD card sector number (0x822) of GUID type "2E54B353-1271-4842-806F-E436D6AF6985"
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- configs/sifive_fu540_defconfig | 8 +++ doc/board/sifive/fu540.rst | 124 +++++++++++++++++++++++++++++++++ 2 files changed, 132 insertions(+)
diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index f805aacc7a..8d412f8d6a 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -1,6 +1,11 @@ CONFIG_RISCV=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SIZE=0x20000 +CONFIG_SPL_MMC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_SPI_SUPPORT=y CONFIG_TARGET_SIFIVE_FU540=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y @@ -9,7 +14,10 @@ CONFIG_FIT=y CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_CLK=y CONFIG_DM_MTD=y diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 610ba87074..5a37e0021d 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -31,6 +31,9 @@ TODO: stdout-path = "/soc/serial@10010000:115200"; };
+Booting from MMC using FSBL +--------------------------- + Building --------
@@ -421,3 +424,124 @@ as well.
Please press Enter to activate this console. / # + +Booting from MMC using U-Boot SPL +--------------------------------- + +Building +-------- + +Before building U-Boot SPL, OpenSBI must be built first. OpenSBI can be +cloned and built for FU540 as below: + +.. code-block:: console + + git clone https://github.com/riscv/opensbi.git + cd opensbi + make PLATFORM=generic + export OPENSBI=<path to opensbi/build/platform/generic/firmware/fw_dynamic.bin> + +Now build the U-Boot SPL and U-Boot proper + +.. code-block:: console + + cd <U-Boot-dir> + make sifive_fu540_defconfig + make + +This will generate spl/u-boot-spl.bin and FIT image (u-boot.itb) + + +Flashing +-------- + +ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition with GUID type +5B193300-FC78-40CD-8002-E86C45580B47 + +U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a partition with GUID +type 2E54B353-1271-4842-806F-E436D6AF6985 + +FIT image (u-boot.itb) is a combination of fw_dynamic.bin, u-boot-nodtb.bin and +device tree blob (hifive-unleashed-a00.dtb) + +Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch) + +.. code-block:: none + + # sudo sgdisk --clear \ + > --set-alignment=2 \ + > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ + > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ + > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ + > /dev/sda + +Program the SD card + +.. code-block:: none + + sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 + sudo dd if=u-boot.itb of=/dev/sda seek=2082 + +Booting +------- +Once you plugin the sdcard and power up, you should see the U-Boot prompt. + +Sample boot log from HiFive Unleashed board +------------------------------------------- + +.. code-block:: none + + U-Boot SPL 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + Trying to boot from MMC1 + + + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + + CPU: rv64imafdc + Model: SiFive HiFive Unleashed A00 + DRAM: 8 GiB + MMC: spi@10050000:mmc@0: 0 + In: serial@10010000 + Out: serial@10010000 + Err: serial@10010000 + Net: eth0: ethernet@10090000 + Hit any key to stop autoboot: 0 + => version + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + + riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0.37-3f461da) 9.2.0 + GNU ld (crosstool-NG 1.24.0.37-3f461da) 2.32 + => mmc info + Device: spi@10050000:mmc@0 + Manufacturer ID: 3 + OEM: 5344 + Name: SC16G + Bus Speed: 20000000 + Mode: SD Legacy + Rd Block Len: 512 + SD version 2.0 + High Capacity: Yes + Capacity: 14.8 GiB + Bus Width: 1-bit + Erase Group Size: 512 Bytes + => mmc part + + Partition Map for MMC device 0 -- Partition Type: EFI + + Part Start LBA End LBA Name + Attributes + Type GUID + Partition GUID + 1 0x00000022 0x00000821 "loader1" + attrs: 0x0000000000000000 + type: 5b193300-fc78-40cd-8002-e86c45580b47 + guid: 66e2b5d2-74db-4df8-ad6f-694b3617f87f + 2 0x00000822 0x00002821 "loader2" + attrs: 0x0000000000000000 + type: 2e54b353-1271-4842-806f-e436d6af6985 + guid: 8befaeaf-bca0-435d-b002-e201f37c0a2f + 3 0x00002822 0x01dacbde "rootfs" + attrs: 0x0000000000000000 + type: 0fc63daf-8483-4772-8e79-3d69d8477de4 + type: linux + guid: 9faa81b6-39b1-4418-af5e-89c48f29c20d
OpenSBI generic platform support provides platform specific functionality based on the FDT passed by previous booting stage.
Depends on OpenSBI commit: platform: Add generic FDT based platform support (sha1: f1aa9e54e00006ae70aeac638d5b75093520f65d)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com --- doc/board/sifive/fu540.rst | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 5a37e0021d..4d7fded699 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -20,17 +20,6 @@ The support for following drivers are already enabled: 4. SiFive SPI Driver. 5. MMC SPI Driver for MMC/SD support.
-TODO: - -1. U-Boot expects the serial console device entry to be present under /chosen - DT node. Without a serial console U-Boot will panic. Example: - -.. code-block:: none - - chosen { - stdout-path = "/soc/serial@10010000:115200"; - }; - Booting from MMC using FSBL ---------------------------
@@ -61,7 +50,7 @@ firmware. We need to compile OpenSBI with below command:
-make PLATFORM=sifive/fu540 FW_PAYLOAD_PATH=<path to u-boot-dtb.bin> + make PLATFORM=generic FW_PAYLOAD_PATH=<path to u-boot-dtb.bin>
More detailed description of steps required to build FW_PAYLOAD firmware is beyond the scope of this document. Please refer OpenSBI documenation.
Hi Rick,
On Fri, May 29, 2020 at 11:34 AM Pragnesh Patel pragnesh.patel@sifive.com wrote:
This series add support for SPL to FU540. U-Boot SPL can boot from L2 LIM (0x0800_0000) and jump to OpenSBI(FW_DYNAMIC firmware) and U-Boot proper from MMC devices.
This series is also available here [1] for testing [1] https://github.com/pragnesh26992/u-boot/tree/spl
How to test this patch:
Go to OpenSBI-dir : make PLATFORM=generic FW_DYNAMIC=y
Change to u-boot-dir
make all
# sudo sgdisk --clear \ > --set-alignment=2 \ > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ > /dev/sda
Changes in v13:
- Add a new patch to set the ethernet clock rate (riscv: sifive: dts: fu540: set ethernet clock rate)
Changes in v12:
Rebase on mainline U-Boot Added necessary include files which are not part of common header now Remove unnecessary include files
drivers/misc/sifive-otp.c +#include <linux/bitops.h> +#include <linux/delay.h>
board/sifive/fu540/fu540.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c +#include <init.h> +#include <log.h> +#include <linux/delay.h>
drivers/ram/sifive/fu540_ddr.c +#include <linux/bitops.h>
arch/riscv/cpu/fu540/cpu.c -#include <common.h> +#include <asm/cache.h>
arch/riscv/cpu/fu540/spl.c -#include <common.h> +#include <log.h>
board/sifive/fu540/spl.c -#include <common.h> +#include <init.h> +#include <log.h> +#include <linux/delay.h>
Update commit description for Release ethernet clock reset
Update OpenSBI building section in "doc/board/sifive/fu540.rst"
Changes in v11:
- Remove TPL related code and OF_PLATDATA from FU540 DDR driver (drivers/ram/sifive/fu540_ddr.c)
- Update FU540 doc (doc/board/sifive/fu540.rst) Remove unnecessary print
Changes in v10:
- Update commit description for ethernet clock reset (https://patchwork.ozlabs.org/patch/1289003)
- Update commit description for ddr clock initialization (https://patchwork.ozlabs.org/patch/1289000)
Changes in v9:
- Remove cache related patches from this series sifive: dts: fu540: Enable L2 Cache in U-Boot (https://patchwork.ozlabs.org/patch/1286705) riscv: sifive: fu540: enable all cache ways from U-Boot proper (https://patchwork.ozlabs.org/patch/1286706)
- Rename SiFive DDR driver from sdram_fu540.c to fu540_ddr.c and also do some typo correction in driver
- Remove CONFIG_SPL_BUILD for __prci_ddr_release_reset()
- Release ethernet clock reset instead of ethernet clock initialization (https://patchwork.ozlabs.org/patch/1286697)
- Squash fu540 cpu patches (https://patchwork.ozlabs.org/patch/1286699) (https://patchwork.ozlabs.org/patch/1286700)
- Use spl_boot_device() instead of board_boot_order()
Changes in v8:
- Remove SPL_CRC7_SUPPORT Kconfig option and compile crc7.o when CONFIG_MMC_SPI selected
- Add "TODO" in drivers/ram/sifive/sdram_fu540.c
- Remove unnecessary TODO from drivers/clk/sifive/fu540-prci.c
- Make fu540-hifive-unleashed-a00-sdram-ddr4.dtsi file dual-licensed
- Add 2 new patches sifive: fu540: Add sample SD gpt partition layout (https://patchwork.ozlabs.org/patch/1092) sifive: fu540: Add U-Boot proper sector start (https://patchwork.ozlabs.org/patch/1093)
- Remove patch riscv: Enable cpu clock if it is present (https://patchwork.ozlabs.org/patch/1281573)
- Update doc/board/sifive/fu540.rst for PLATFORM=generic
Changes in v7:
- Standardize SD gpt partition layout
- Add delay for SiFive OTP driver
- Use DM way for corepll and ddrpll
- Add new cpu fu540 (arch/riscv/cpu/fu540)
- Update document for FU540 (doc/board/sifive/fu540.rst)
Changes in v6:
- Typo Correction
- Make fu540-c000-u-boot.dtsi and hifive-unleashed-a00-u-boot.dtsi Dual Licensed
- Sync Hifive unleashed dts from Linux
- Add arch/riscv/fu540 for FU540 specific code
Changes in v5:
- Return read/write bytes for sifive_otp_read and sifive_otp_write
- Correct Palmer's email address
Changes in v4:
- Split misc DM driver patch into multiple patches
- Added new SPL_CRC7_SUPPORT Kconfig option
- Added DM driver for DDR
- Added clk_enable and clk_disable ops in SiFive PRCI driver
- Added early clock initialization for SPL in SiFive PRCI driver
- Added SPL config options in sifive_fu540_defconfig instead of creatiing a new config file for SPL
- Update fu540.rst on how to build and flash U-boot SPL
Changes in v3:
- Remove arch-fu540 and arch-sifive from arch/riscv/include/asm/
- Split SPL patches into DDR and SPL and spl defconfig
- Update fu540/MAINTAINERS file
Changes in v2:
- Add DM driver Sifive OTP
- Split SPL patches into multiple patches
- Add a seprate patch for _image_binary_end and crc7.c
- Add a seprate patch to add board -u-boot.dtsi files
- Update FU540 RISC-V documentation
Jagan Teki (2): sifive: fu540: Add sample SD gpt partition layout sifive: fu540: Add U-Boot proper sector start
Pragnesh Patel (17): misc: add driver for the SiFive otp controller riscv: sifive: fu540: Use OTP DM driver for serial environment variable riscv: Add _image_binary_end for SPL lib: Makefile: build crc7.c when CONFIG_MMC_SPI riscv: sifive: dts: fu540: Add board -u-boot.dtsi files sifive: fu540: add ddr driver sifive: dts: fu540: Add DDR controller and phy register settings riscv: sifive: dts: fu540: add U-Boot dmc node clk: sifive: fu540-prci: Add clock enable and disable ops clk: sifive: fu540-prci: Add ddr clock initialization clk: sifive: fu540-prci: Release ethernet clock reset riscv: sifive: dts: fu540: set ethernet clock rate riscv: dts: sifive: Sync hifive-unleashed-a00 dts from linux riscv: cpu: fu540: Add support for cpu fu540 riscv: sifive: fu540: add SPL configuration configs: fu540: Add config options for U-Boot SPL doc: sifive: fu540: Add description for OpenSBI generic platform
Any plan to pull this for the release?
Jagan.
Bin Meng
Jagan Teki
Pragnesh Patel
