[PATCH v2 0/4] firmware: scmi: add SCMI power domain protocol support
This patch series allows users to access SCMI power domain protocol provided by SCMI server (platform). See SCMI specification document v3.2 beta 2[1] for more details about SCMI power domain protocol.
The implementation consists of two layers: - basic helper functions for SCMI power domain protocol in drivers/firmware/scmi/pwdom.c (patch#1) - DM-compliant power domain driver, which utilizes the helper functions, in drivers/power/domain/scmi-power-domain.c (patch#2)
[1] https://developer.arm.com/documentation/den0056/e/?lang=en
DT bindings =========== Standard bindings are applied, i.e.
scmi { ... pwrdom_scmi: protocol@11 { regs = <0x11>; #power-domain-cells = <1>; } ... }
som-device { ... power-domains = <&pwrdom_scmi 2>; }
Test ==== The patch series was tested on the following platform: * sandbox ("ut dm scmi_power_domains")
Prerequisite: ============= * This patch series is based on the master which now includes my "Base protocol support" patches v6[2]
[2] https://lists.denx.de/pipermail/u-boot/2023-September/531623.html
Patches: ======== Patch#1: Add SCMI power domain protocol helpers Patch#2: Add power domain driver Patch#3-#4: Test related
Change history: =============== v2 (Oct 16, 2023) * remove a change on "test_scmi_cmd" because "scmi" command is no longer provided with base protocol v6 * some cleanup v1 (Sep 26, 2023) * initial release
AKASHI Takahiro (4): firmware: scmi: add power domain protocol support power: domain: add SCMI driver sandbox: add SCMI power domain protocol support for testing test: dm: add SCMI power domain protocol test
arch/sandbox/dts/test.dts | 6 + arch/sandbox/include/asm/scmi_test.h | 21 ++ configs/sandbox_defconfig | 1 + drivers/firmware/scmi/Makefile | 1 + drivers/firmware/scmi/pwdom.c | 189 +++++++++++++ drivers/firmware/scmi/sandbox-scmi_agent.c | 265 ++++++++++++++++++- drivers/firmware/scmi/sandbox-scmi_devices.c | 10 + drivers/firmware/scmi/scmi_agent-uclass.c | 11 + drivers/power/domain/Kconfig | 7 + drivers/power/domain/Makefile | 1 + drivers/power/domain/scmi-power-domain.c | 193 ++++++++++++++ include/scmi_agent-uclass.h | 2 + include/scmi_protocols.h | 178 +++++++++++++ test/dm/scmi.c | 103 +++++++ 14 files changed, 987 insertions(+), 1 deletion(-) create mode 100644 drivers/firmware/scmi/pwdom.c create mode 100644 drivers/power/domain/scmi-power-domain.c
In this patch, added are helper functions to directly manipulate SCMI power domain management protocol. DM compliant power domain driver will be implemented on top of those interfaces in a succeeding patch.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/firmware/scmi/Makefile | 1 + drivers/firmware/scmi/pwdom.c | 189 +++++++++++++++++++++++++++++++++ include/scmi_protocols.h | 178 +++++++++++++++++++++++++++++++ 3 files changed, 368 insertions(+) create mode 100644 drivers/firmware/scmi/pwdom.c
diff --git a/drivers/firmware/scmi/Makefile b/drivers/firmware/scmi/Makefile index 1a23d4981709..dae42863589a 100644 --- a/drivers/firmware/scmi/Makefile +++ b/drivers/firmware/scmi/Makefile @@ -4,4 +4,5 @@ obj-y += smt.o obj-$(CONFIG_SCMI_AGENT_SMCCC) += smccc_agent.o obj-$(CONFIG_SCMI_AGENT_MAILBOX) += mailbox_agent.o obj-$(CONFIG_SCMI_AGENT_OPTEE) += optee_agent.o +obj-$(CONFIG_SCMI_POWER_DOMAIN) += pwdom.o obj-$(CONFIG_SANDBOX) += sandbox-scmi_agent.o sandbox-scmi_devices.o diff --git a/drivers/firmware/scmi/pwdom.c b/drivers/firmware/scmi/pwdom.c new file mode 100644 index 000000000000..61b4338663de --- /dev/null +++ b/drivers/firmware/scmi/pwdom.c @@ -0,0 +1,189 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SCMI Power domain management protocol + * + * Copyright (C) 2023 Linaro Limited + * author: AKASHI Takahiro takahiro.akashi@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <scmi_agent.h> +#include <scmi_protocols.h> +#include <string.h> +#include <asm/types.h> + +int scmi_pwd_protocol_attrs(struct udevice *dev, int *num_pwdoms, + u64 *stats_addr, size_t *stats_len) +{ + struct scmi_pwd_protocol_attrs_out out; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PROTOCOL_ATTRIBUTES, + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + if (!dev || !num_pwdoms || !stats_addr || !stats_len) + return -EINVAL; + + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (out.status) + return scmi_to_linux_errno(out.status); + + *num_pwdoms = SCMI_PWD_PROTO_ATTRS_NUM_PWD(out.attributes); + *stats_addr = ((u64)out.stats_addr_high << 32) + out.stats_addr_low; + *stats_len = out.stats_len; + + return 0; +} + +int scmi_pwd_protocol_message_attrs(struct udevice *dev, s32 message_id, + u32 *attributes) +{ + struct scmi_pwd_protocol_msg_attrs_out out; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PROTOCOL_MESSAGE_ATTRIBUTES, + .in_msg = (u8 *)&message_id, + .in_msg_sz = sizeof(message_id), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + if (!dev || !attributes) + return -EINVAL; + + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (out.status) + return scmi_to_linux_errno(out.status); + + *attributes = out.attributes; + + return 0; +} + +int scmi_pwd_attrs(struct udevice *dev, u32 domain_id, u32 *attributes, + u8 **name) +{ + struct scmi_pwd_attrs_out out; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PWD_ATTRIBUTES, + .in_msg = (u8 *)&domain_id, + .in_msg_sz = sizeof(domain_id), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + if (!dev || !attributes || !name) + return -EINVAL; + + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (out.status) + return scmi_to_linux_errno(out.status); + + *name = strdup(out.name); + if (!*name) + return -ENOMEM; + + *attributes = out.attributes; + + return 0; +} + +int scmi_pwd_state_set(struct udevice *dev, u32 flags, u32 domain_id, + u32 pstate) +{ + struct scmi_pwd_state_set_in in; + s32 status; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PWD_STATE_SET, + .in_msg = (u8 *)&in, + .in_msg_sz = sizeof(in), + .out_msg = (u8 *)&status, + .out_msg_sz = sizeof(status), + }; + int ret; + + if (!dev) + return -EINVAL; + + in.flags = flags; + in.domain_id = domain_id; + in.pstate = pstate; + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (status) + return scmi_to_linux_errno(status); + + return 0; +} + +int scmi_pwd_state_get(struct udevice *dev, u32 domain_id, u32 *pstate) +{ + struct scmi_pwd_state_get_out out; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PWD_STATE_GET, + .in_msg = (u8 *)&domain_id, + .in_msg_sz = sizeof(domain_id), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + if (!dev || !pstate) + return -EINVAL; + + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (out.status) + return scmi_to_linux_errno(out.status); + + *pstate = out.pstate; + + return 0; +} + +int scmi_pwd_name_get(struct udevice *dev, u32 domain_id, u8 **name) +{ + struct scmi_pwd_name_get_out out; + struct scmi_msg msg = { + .protocol_id = SCMI_PROTOCOL_ID_POWER_DOMAIN, + .message_id = SCMI_PWD_NAME_GET, + .in_msg = (u8 *)&domain_id, + .in_msg_sz = sizeof(domain_id), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + if (!dev || !name) + return -EINVAL; + + ret = devm_scmi_process_msg(dev, &msg); + if (ret) + return ret; + if (out.status) + return scmi_to_linux_errno(out.status); + + *name = strdup(out.extended_name); + if (!*name) + return -ENOMEM; + + return 0; +} diff --git a/include/scmi_protocols.h b/include/scmi_protocols.h index 163647a57b95..7abb2a6f36ba 100644 --- a/include/scmi_protocols.h +++ b/include/scmi_protocols.h @@ -544,6 +544,184 @@ int scmi_base_set_protocol_permissions(struct udevice *dev, int scmi_base_reset_agent_configuration(struct udevice *dev, u32 agent_id, u32 flags);
+/* + * SCMI Power Domain Management Protocol + */ + +#define SCMI_PWD_PROTOCOL_VERSION 0x30000 +#define SCMI_PWD_PSTATE_TYPE_LOST BIT(30) +#define SCMI_PWD_PSTATE_ID GENMASK(27, 0) + +enum scmi_power_domain_message_id { + SCMI_PWD_ATTRIBUTES = 0x3, + SCMI_PWD_STATE_SET = 0x4, + SCMI_PWD_STATE_GET = 0x5, + SCMI_PWD_STATE_NOTIFY = 0x6, + SCMI_PWD_STATE_CHANGE_REQUESTED_NOTIFY = 0x7, + SCMI_PWD_NAME_GET = 0x8, +}; + +/** + * struct scmi_pwd_protocol_attrs_out + * @status: SCMI command status + * @attributes: Protocol attributes + * @stats_addr_low: Lower 32 bits of address of statistics memory region + * @stats_addr_high: Higher 32 bits of address of statistics memory region + * @stats_len: Length of statistics memory region + */ +struct scmi_pwd_protocol_attrs_out { + s32 status; + u32 attributes; + u32 stats_addr_low; + u32 stats_addr_high; + u32 stats_len; +}; + +#define SCMI_PWD_PROTO_ATTRS_NUM_PWD(attributes) ((attributes) & GENMASK(15, 0)) + +/** + * struct scmi_pwd_protocol_msg_attrs_out + * @status: SCMI command status + * @attributes: Message-specific attributes + */ +struct scmi_pwd_protocol_msg_attrs_out { + s32 status; + u32 attributes; +}; + +#define SCMI_PWD_NAME_LENGTH_MAX 16 + +/** + * struct scmi_pwd_attrs_out + * @status: SCMI command status + * @attributes: Power domain attributes + * @name: Name of power domain + */ +struct scmi_pwd_attrs_out { + s32 status; + u32 attributes; + u8 name[SCMI_PWD_NAME_LENGTH_MAX]; +}; + +#define SCMI_PWD_ATTR_PSTATE_CHANGE_NOTIFY BIT(31) +#define SCMI_PWD_ATTR_PSTATE_ASYNC BIT(30) +#define SCMI_PWD_ATTR_PSTATE_SYNC BIT(29) +#define SCMI_PWD_ATTR_PSTATE_CHANGE_RQ_NOTIFY BIT(28) +#define SCMI_PWD_ATTR_EXTENDED_NAME BIT(27) + +/** + * struct scmi_pwd_state_set_in + * @flags: Flags + * @domain_id: Identifier of power domain + * @pstate: Power state of the domain + */ +struct scmi_pwd_state_set_in { + u32 flags; + u32 domain_id; + u32 pstate; +}; + +#define SCMI_PWD_SET_FLAGS_ASYNC BIT(0) + +/** + * struct scmi_pwd_state_get_out + * @status: SCMI command status + * @pstate: Power state of the domain + */ +struct scmi_pwd_state_get_out { + s32 status; + u32 pstate; +}; + +#define SCMI_PWD_EXTENDED_NAME_MAX 64 +/** + * struct scmi_pwd_name_get_out + * @status: SCMI command status + * @flags: Parameter flags + * @extended_name: Extended name of power domain + */ +struct scmi_pwd_name_get_out { + s32 status; + u32 flags; + u8 extended_name[SCMI_PWD_EXTENDED_NAME_MAX]; +}; + +/** + * scmi_pwd_protocol_attrs - get protocol attributes + * @dev: SCMI protocol device + * @num_pwdoms: Number of power domains + * @stats_addr: Address of statistics memory region + * @stats_len: Length of statistics memory region + * + * Obtain the protocol attributes, the number of power domains and + * the information of statistics memory region. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_protocol_attrs(struct udevice *dev, int *num_pwdoms, + u64 *stats_addr, size_t *stats_len); +/** + * scmi_pwd_protocol_message_attrs - get message-specific attributes + * @dev: SCMI protocol device + * @message_id: SCMI message ID + * @attributes: Message-specific attributes + * + * Obtain the message-specific attributes in @attributes. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_protocol_message_attrs(struct udevice *dev, s32 message_id, + u32 *attributes); +/** + * scmi_pwd_attrs - get power domain attributes + * @dev: SCMI protocol device + * @domain_id: Identifier of power domain + * @attributes: Power domain attributes + * @name: Name of power domain + * + * Obtain the attributes of the given power domain, @domain_id, in @attributes + * as well as its name in @name. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_attrs(struct udevice *dev, u32 message_id, u32 *attributes, + u8 **name); +/** + * scmi_pwd_state_set - set power state + * @dev: SCMI protocol device + * @flags: Parameter flags + * @domain_id: Identifier of power domain + * @pstate: Power state + * + * Change the power state of the given power domain, @domain_id. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_state_set(struct udevice *dev, u32 flags, u32 domain_id, + u32 pstate); +/** + * scmi_pwd_state_get - get power state + * @dev: SCMI protocol device + * @domain_id: Identifier of power domain + * @pstate: Power state + * + * Obtain the power state of the given power domain, @domain_id. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_state_get(struct udevice *dev, u32 domain_id, u32 *pstate); +/** + * scmi_pwd_name_get - get extended name + * @dev: SCMI protocol device + * @domain_id: Identifier of power domain + * @name: Extended name of the domain + * + * Obtain the extended name of the given power domain, @domain_id, in @name. + * + * Return: 0 on success, error code on failure + */ +int scmi_pwd_name_get(struct udevice *dev, u32 domain_id, u8 **name); + /* * SCMI Clock Protocol */
Add power domain driver based on SCMI power domain management protocol.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- v2 * remove tentative code which was enclosed by "#if 0" * free allocated memory at the failure of probe function --- drivers/firmware/scmi/scmi_agent-uclass.c | 11 ++ drivers/power/domain/Kconfig | 7 + drivers/power/domain/Makefile | 1 + drivers/power/domain/scmi-power-domain.c | 193 ++++++++++++++++++++++ include/scmi_agent-uclass.h | 2 + 5 files changed, 214 insertions(+) create mode 100644 drivers/power/domain/scmi-power-domain.c
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 6f585b96f740..0f1003e167e6 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -86,6 +86,9 @@ struct udevice *scmi_get_protocol(struct udevice *dev, case SCMI_PROTOCOL_ID_BASE: proto = priv->base_dev; break; + case SCMI_PROTOCOL_ID_POWER_DOMAIN: + proto = priv->pwdom_dev; + break; case SCMI_PROTOCOL_ID_CLOCK: proto = priv->clock_dev; break; @@ -133,6 +136,9 @@ static int scmi_add_protocol(struct udevice *dev, case SCMI_PROTOCOL_ID_BASE: priv->base_dev = proto; break; + case SCMI_PROTOCOL_ID_POWER_DOMAIN: + priv->pwdom_dev = proto; + break; case SCMI_PROTOCOL_ID_CLOCK: priv->clock_dev = proto; break; @@ -405,6 +411,11 @@ static int scmi_bind_protocols(struct udevice *dev) drv = NULL; name = ofnode_get_name(node); switch (protocol_id) { + case SCMI_PROTOCOL_ID_POWER_DOMAIN: + if (CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN) && + scmi_protocol_is_supported(dev, protocol_id)) + drv = DM_DRIVER_GET(scmi_power_domain); + break; case SCMI_PROTOCOL_ID_CLOCK: if (CONFIG_IS_ENABLED(CLK_SCMI) && scmi_protocol_is_supported(dev, protocol_id)) diff --git a/drivers/power/domain/Kconfig b/drivers/power/domain/Kconfig index 411c210756a3..bd82d2f7044b 100644 --- a/drivers/power/domain/Kconfig +++ b/drivers/power/domain/Kconfig @@ -83,6 +83,13 @@ config SANDBOX_POWER_DOMAIN simply accepts requests to power on/off various HW modules without actually doing anything beyond a little error checking.
+config SCMI_POWER_DOMAIN + bool "Enable SCMI power domain driver" + depends on POWER_DOMAIN && SCMI_FIRMWARE + help + Enable power domain implementation based on SCMI power domain + management protocol. + config TEGRA186_POWER_DOMAIN bool "Enable Tegra186 BPMP-based power domain driver" depends on TEGRA186_BPMP diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index aa5a4ba57cd8..2daab73eb758 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -15,6 +15,7 @@ obj-$(CONFIG_MESON_EE_POWER_DOMAIN) += meson-ee-pwrc.o obj-$(CONFIG_MESON_SECURE_POWER_DOMAIN) += meson-secure-pwrc.o obj-$(CONFIG_SANDBOX_POWER_DOMAIN) += sandbox-power-domain.o obj-$(CONFIG_SANDBOX_POWER_DOMAIN) += sandbox-power-domain-test.o +obj-$(CONFIG_SCMI_POWER_DOMAIN) += scmi-power-domain.o obj-$(CONFIG_TEGRA186_POWER_DOMAIN) += tegra186-power-domain.o obj-$(CONFIG_TI_SCI_POWER_DOMAIN) += ti-sci-power-domain.o obj-$(CONFIG_TI_POWER_DOMAIN) += ti-power-domain.o diff --git a/drivers/power/domain/scmi-power-domain.c b/drivers/power/domain/scmi-power-domain.c new file mode 100644 index 000000000000..2b85efc08914 --- /dev/null +++ b/drivers/power/domain/scmi-power-domain.c @@ -0,0 +1,193 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SCMI Power domain driver + * + * Copyright (C) 2023 Linaro Limited + * author: AKASHI Takahiro takahiro.akashi@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <power-domain.h> +#include <power-domain-uclass.h> +#include <scmi_agent.h> +#include <scmi_protocols.h> +#include <dm/device_compat.h> + +/** + * struct scmi_pwd_properties + * @attributes: Power domain attributes + * @name: Name of the domain + */ +struct scmi_pwd_properties { + u32 attributes; + u8 *name; /* not used now */ +}; + +/** + * struct scmi_power_domain_priv + * @num_pwdoms: Number of power domains + * @prop: Pointer to domain's properties + * @stats_addr: Address of statistics memory region + * @stats_len: Length of statistics memory region + */ +struct scmi_power_domain_priv { + int num_pwdoms; + struct scmi_pwd_properties *prop; + u64 stats_addr; + size_t stats_len; +}; + +/** + * async_is_supported - check asynchronous transition + * @attributes: Power domain attributes + * + * Determine if the power transition can be done asynchronously. + * + * Return: true if supported, false if not + */ +static bool async_is_supported(u32 attributes) +{ + if (attributes & SCMI_PWD_ATTR_PSTATE_ASYNC) + return true; + + /* TODO: check attributes && SCMI_PWD_ATTR_PSTATE_SYNC */ + return false; +} + +/** + * scmi_power_domain_on - Enable the power domain + * @power_domain: Power domain + * + * Turn on the power domain. + * + * Return: 0 on success, error code on failure + */ +static int scmi_power_domain_on(struct power_domain *power_domain) +{ + struct scmi_power_domain_priv *priv = dev_get_priv(power_domain->dev); + u32 flags, pstate; + int ret; + + if (power_domain->id > priv->num_pwdoms) + return -EINVAL; + + if (async_is_supported(priv->prop[power_domain->id].attributes)) + flags = SCMI_PWD_SET_FLAGS_ASYNC; + else + flags = 0; + + /* ON */ + pstate = 0; + + ret = scmi_pwd_state_set(power_domain->dev, flags, power_domain->id, + pstate); + if (ret) { + dev_err(power_domain->dev, "failed to set the state on (%d)\n", + ret); + return ret; + } + + return 0; +} + +/** + * scmi_power_domain_off - Disable the power domain + * @power_domain: Power domain + * + * Turn off the power domain. + * + * Return: 0 on success, error code on failure + */ +static int scmi_power_domain_off(struct power_domain *power_domain) +{ + struct scmi_power_domain_priv *priv = dev_get_priv(power_domain->dev); + u32 flags, pstate; + int ret; + + if (power_domain->id > priv->num_pwdoms) + return -EINVAL; + + if (async_is_supported(priv->prop[power_domain->id].attributes)) + flags = SCMI_PWD_SET_FLAGS_ASYNC; + else + flags = 0; + + /* OFF */ + pstate = SCMI_PWD_PSTATE_TYPE_LOST; + + ret = scmi_pwd_state_set(power_domain->dev, flags, power_domain->id, + pstate); + if (ret) { + dev_err(power_domain->dev, "failed to set the state off (%d)\n", + ret); + return ret; + } + + return 0; +} + +/** + * scmi_power_domain_probe - Probe the power domain + * @dev: Power domain device + * + * Probe the power domain and initialize the properties. + * + * Return: 0 on success, error code on failure + */ +static int scmi_power_domain_probe(struct udevice *dev) +{ + struct scmi_power_domain_priv *priv = dev_get_priv(dev); + u32 version; + int i, ret; + + ret = devm_scmi_of_get_channel(dev); + if (ret) { + dev_err(dev, "failed to get channel (%d)\n", ret); + return ret; + } + + ret = scmi_generic_protocol_version(dev, SCMI_PROTOCOL_ID_POWER_DOMAIN, + &version); + + ret = scmi_pwd_protocol_attrs(dev, &priv->num_pwdoms, &priv->stats_addr, + &priv->stats_len); + if (ret) { + dev_err(dev, "failed to get protocol attributes (%d)\n", ret); + return ret; + } + + priv->prop = calloc(sizeof(*priv->prop), priv->num_pwdoms); + if (!priv->prop) + return -ENOMEM; + + for (i = 0; i < priv->num_pwdoms; i++) { + ret = scmi_pwd_attrs(dev, i, &priv->prop[i].attributes, + &priv->prop[i].name); + if (ret) { + dev_err(dev, "failed to get attributes pwd:%d (%d)\n", + i, ret); + for (i--; i >= 0; i--) + free(priv->prop[i].name); + free(priv->prop); + + return ret; + } + } + + return 0; +} + +struct power_domain_ops scmi_power_domain_ops = { + .on = scmi_power_domain_on, + .off = scmi_power_domain_off, +}; + +U_BOOT_DRIVER(scmi_power_domain) = { + .name = "scmi_power_domain", + .id = UCLASS_POWER_DOMAIN, + .ops = &scmi_power_domain_ops, + .probe = scmi_power_domain_probe, + .priv_auto = sizeof(struct scmi_power_domain_priv), +}; diff --git a/include/scmi_agent-uclass.h b/include/scmi_agent-uclass.h index 35d96069645e..33e0e18c30d4 100644 --- a/include/scmi_agent-uclass.h +++ b/include/scmi_agent-uclass.h @@ -23,6 +23,7 @@ struct scmi_channel; * @agent_name: Agent name * @agent_id: Identifier of agent * @base_dev: SCMI base protocol device + * @pwdom_dev: SCMI power domain management protocol device * @clock_dev: SCMI clock protocol device * @resetdom_dev: SCMI reset domain protocol device * @voltagedom_dev: SCMI voltage domain protocol device @@ -38,6 +39,7 @@ struct scmi_agent_priv { u8 *agent_name; u32 agent_id; struct udevice *base_dev; + struct udevice *pwdom_dev; struct udevice *clock_dev; struct udevice *resetdom_dev; struct udevice *voltagedom_dev;
SCMI power domain management protocol is supported on sandbox for test purpose. Add fake agent interfaces and associated power domain devices.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- v2 * add a comment for a member, pstate, of struct sandbox_scmi_pwd --- arch/sandbox/dts/test.dts | 6 + arch/sandbox/include/asm/scmi_test.h | 21 ++ configs/sandbox_defconfig | 1 + drivers/firmware/scmi/sandbox-scmi_agent.c | 265 ++++++++++++++++++- drivers/firmware/scmi/sandbox-scmi_devices.c | 10 + 5 files changed, 302 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index c0ed2d83f3d2..309127a91004 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -732,6 +732,11 @@ #address-cells = <1>; #size-cells = <0>;
+ pwrdom_scmi: protocol@11 { + reg = <0x11>; + #power-domain-cells = <1>; + }; + clk_scmi: protocol@14 { reg = <0x14>; #clock-cells = <1>; @@ -1635,6 +1640,7 @@
sandbox_scmi { compatible = "sandbox,scmi-devices"; + power-domains = <&pwrdom_scmi 2>; clocks = <&clk_scmi 2>, <&clk_scmi 0>; resets = <&reset_scmi 3>; regul0-supply = <®ul0_scmi>; diff --git a/arch/sandbox/include/asm/scmi_test.h b/arch/sandbox/include/asm/scmi_test.h index ccb0df6c148f..619f8f5098cd 100644 --- a/arch/sandbox/include/asm/scmi_test.h +++ b/arch/sandbox/include/asm/scmi_test.h @@ -6,10 +6,22 @@ #ifndef __SANDBOX_SCMI_TEST_H #define __SANDBOX_SCMI_TEST_H
+#include <power-domain.h> + struct udevice; struct sandbox_scmi_agent; struct sandbox_scmi_service;
+/** + * struct sandbox_scmi_pwd + * @id: Identifier of the power domain used in the SCMI protocol + * @pstate:: Power state of the domain + */ +struct sandbox_scmi_pwd { + uint id; + u32 pstate; +}; + /** * struct sandbox_scmi_clk - Simulated clock exposed by SCMI * @id: Identifier of the clock used in the SCMI protocol @@ -45,6 +57,8 @@ struct sandbox_scmi_voltd {
/** * struct sandbox_scmi_agent - Simulated SCMI service seen by SCMI agent + * @pwdom_version: Implemented power domain protocol version + * @pwdom_count: Simulated power domains array size * @clk: Simulated clocks * @clk_count: Simulated clocks array size * @reset: Simulated reset domains @@ -53,6 +67,9 @@ struct sandbox_scmi_voltd { * @voltd_count: Simulated voltage domains array size */ struct sandbox_scmi_agent { + int pwdom_version; + struct sandbox_scmi_pwd *pwdom; + size_t pwdom_count; struct sandbox_scmi_clk *clk; size_t clk_count; struct sandbox_scmi_reset *reset; @@ -71,6 +88,8 @@ struct sandbox_scmi_service {
/** * struct sandbox_scmi_devices - Reference to devices probed through SCMI + * @pwdom: Array of power domains + * @pwdom_count: Number of power domains probed * @clk: Array the clock devices * @clk_count: Number of clock devices probed * @reset: Array the reset controller devices @@ -79,6 +98,8 @@ struct sandbox_scmi_service { * @regul_count: Number of regulator devices probed */ struct sandbox_scmi_devices { + struct power_domain *pwdom; + size_t pwdom_count; struct clk *clk; size_t clk_count; struct reset_ctl *reset; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 01830c7bd255..dbee9eb7f571 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -241,6 +241,7 @@ CONFIG_PINCTRL_SANDBOX=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_SANDBOX_POWER_DOMAIN=y +CONFIG_SCMI_POWER_DOMAIN=y CONFIG_DM_PMIC=y CONFIG_PMIC_ACT8846=y CONFIG_DM_PMIC_PFUZE100=y diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index eb567dd900d7..9f5f497e0a6c 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -43,6 +43,8 @@ #define SANDBOX_SCMI_AGENT_NAME "OSPM" #define SANDBOX_SCMI_PLATFORM_NAME "platform"
+#define SANDBOX_SCMI_PWD_PROTOCOL_VERSION SCMI_PWD_PROTOCOL_VERSION + /** * struct sandbox_channel - Description of sandbox transport * @channel_id: Channel identifier @@ -64,6 +66,7 @@ struct scmi_channel { };
static u8 protocols[] = { + SCMI_PROTOCOL_ID_POWER_DOMAIN, SCMI_PROTOCOL_ID_CLOCK, SCMI_PROTOCOL_ID_RESET_DOMAIN, SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, @@ -71,6 +74,12 @@ static u8 protocols[] = {
#define NUM_PROTOCOLS ARRAY_SIZE(protocols)
+static struct sandbox_scmi_pwd scmi_pwdom[] = { + { .id = 0 }, + { .id = 1 }, + { .id = 2 }, +}; + static struct sandbox_scmi_clk scmi_clk[] = { { .rate = 333 }, { .rate = 200 }, @@ -458,6 +467,238 @@ static int sandbox_scmi_base_reset_agent_configuration(struct udevice *dev, return 0; }
+/* Power Domain Management Protocol */ + +/** + * sandbox_scmi_pwd_protocol_version - implement SCMI_PROTOCOL_VERSION + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PROTOCOL_VERSION command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_protocol_version(struct udevice *dev, + struct scmi_msg *msg) +{ + struct scmi_protocol_version_out *out = NULL; + + if (!msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + out = (struct scmi_protocol_version_out *)msg->out_msg; + out->version = SANDBOX_SCMI_PWD_PROTOCOL_VERSION; + out->status = SCMI_SUCCESS; + + return 0; +} + +/** + * sandbox_scmi_pwd_protocol_attribs - implement SCMI_PWD_PROTOCOL_ATTRS + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_PROTOCOL_ATTRS command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_protocol_attribs(struct udevice *dev, + struct scmi_msg *msg) +{ + struct scmi_pwd_protocol_attrs_out *out; + + if (!msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + out = (struct scmi_pwd_protocol_attrs_out *)msg->out_msg; + + out->attributes = ARRAY_SIZE(scmi_pwdom); + out->stats_addr_low = 0; + out->stats_addr_high = 0; + out->stats_len = 0; + out->status = SCMI_SUCCESS; + + return 0; +} + +/** + * sandbox_scmi_pwd_protocol_msg_attribs - implement + SCMI_PWD_PROTOCOL_MESSAGE_ATTRS + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_PROTOCOL_MESSAGE_ATTRS command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_protocol_msg_attribs(struct udevice *dev, + struct scmi_msg *msg) +{ + u32 message_id; + struct scmi_pwd_protocol_msg_attrs_out *out; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(message_id) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + message_id = *(u32 *)msg->in_msg; + + out = (struct scmi_pwd_protocol_msg_attrs_out *)msg->out_msg; + if (message_id <= SCMI_PWD_STATE_GET || + message_id == SCMI_PWD_NAME_GET) { + out->attributes = 0; + out->status = SCMI_SUCCESS; + } else { + out->status = SCMI_NOT_FOUND; + } + + return 0; +} + +/** + * sandbox_scmi_pwd_attribs - implement SCMI_PWD_ATTRS + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_ATTRS command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_attribs(struct udevice *dev, struct scmi_msg *msg) +{ + u32 domain_id; + struct scmi_pwd_attrs_out *out; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(domain_id) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + domain_id = *(u32 *)msg->in_msg; + out = (struct scmi_pwd_attrs_out *)msg->out_msg; + + if (domain_id > ARRAY_SIZE(scmi_pwdom)) { + out->status = SCMI_NOT_FOUND; + + return 0; + } + + out->attributes = + SCMI_PWD_ATTR_PSTATE_SYNC | SCMI_PWD_ATTR_EXTENDED_NAME; + /* just 15-char + NULL */ + snprintf(out->name, SCMI_PWD_NAME_LENGTH_MAX, "power-domain--%d", + domain_id); + out->status = SCMI_SUCCESS; + + return 0; +} + +/** + * sandbox_scmi_pwd_state_set - implement SCMI_PWD_STATE_SET + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_STATE_SET command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_state_set(struct udevice *dev, struct scmi_msg *msg) +{ + struct scmi_pwd_state_set_in *in; + s32 *status; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*status)) + return -EINVAL; + + in = (struct scmi_pwd_state_set_in *)msg->in_msg; + status = (s32 *)msg->out_msg; + + if (in->domain_id > ARRAY_SIZE(scmi_pwdom)) { + *status = SCMI_NOT_FOUND; + + return 0; + } + + if ((in->flags & SCMI_PWD_SET_FLAGS_ASYNC) || + (in->pstate != SCMI_PWD_PSTATE_TYPE_LOST && in->pstate)) { + *status = SCMI_INVALID_PARAMETERS; + + return 0; + } + + scmi_pwdom[in->domain_id].pstate = in->pstate; + *status = SCMI_SUCCESS; + + return 0; +} + +/** + * sandbox_scmi_pwd_state_get - implement SCMI_PWD_STATE_GET + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_STATE_GET command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_state_get(struct udevice *dev, struct scmi_msg *msg) +{ + u32 domain_id; + struct scmi_pwd_state_get_out *out; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(domain_id) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + domain_id = *(u32 *)msg->in_msg; + out = (struct scmi_pwd_state_get_out *)msg->out_msg; + + if (domain_id > ARRAY_SIZE(scmi_pwdom)) { + out->status = SCMI_NOT_FOUND; + + return 0; + } + + out->pstate = scmi_pwdom[domain_id].pstate; + out->status = SCMI_SUCCESS; + + return 0; +} + +/** + * sandbox_scmi_pwd_name_get - implement SCMI_PWD_NAME_GET + * @dev: SCMI device + * @msg: SCMI message + * + * Implement SCMI_PWD_NAME_GET command. + * + * Return: 0 on success, error code on failure + */ +static int sandbox_scmi_pwd_name_get(struct udevice *dev, struct scmi_msg *msg) +{ + u32 domain_id; + struct scmi_pwd_name_get_out *out; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(domain_id) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + domain_id = *(u32 *)msg->in_msg; + out = (struct scmi_pwd_name_get_out *)msg->out_msg; + + if (domain_id > ARRAY_SIZE(scmi_pwdom)) { + out->status = SCMI_NOT_FOUND; + + return 0; + } + + snprintf(out->extended_name, SCMI_PWD_EXTENDED_NAME_MAX, + "power-domain--%d-extended", domain_id); + out->status = SCMI_SUCCESS; + + return 0; +} + /* Clock Protocol */
static int sandbox_scmi_clock_protocol_attribs(struct udevice *dev, @@ -918,6 +1159,26 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, break; } break; + case SCMI_PROTOCOL_ID_POWER_DOMAIN: + switch (msg->message_id) { + case SCMI_PROTOCOL_VERSION: + return sandbox_scmi_pwd_protocol_version(dev, msg); + case SCMI_PROTOCOL_ATTRIBUTES: + return sandbox_scmi_pwd_protocol_attribs(dev, msg); + case SCMI_PROTOCOL_MESSAGE_ATTRIBUTES: + return sandbox_scmi_pwd_protocol_msg_attribs(dev, msg); + case SCMI_PWD_ATTRIBUTES: + return sandbox_scmi_pwd_attribs(dev, msg); + case SCMI_PWD_STATE_SET: + return sandbox_scmi_pwd_state_set(dev, msg); + case SCMI_PWD_STATE_GET: + return sandbox_scmi_pwd_state_get(dev, msg); + case SCMI_PWD_NAME_GET: + return sandbox_scmi_pwd_name_get(dev, msg); + default: + break; + } + break; case SCMI_PROTOCOL_ID_CLOCK: switch (msg->message_id) { case SCMI_PROTOCOL_ATTRIBUTES: @@ -960,7 +1221,6 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, break; } break; - case SCMI_PROTOCOL_ID_POWER_DOMAIN: case SCMI_PROTOCOL_ID_SYSTEM: case SCMI_PROTOCOL_ID_PERF: case SCMI_PROTOCOL_ID_SENSOR: @@ -993,6 +1253,9 @@ static int sandbox_scmi_test_probe(struct udevice *dev) struct sandbox_scmi_agent *agent = dev_get_priv(dev);
*agent = (struct sandbox_scmi_agent){ + .pwdom_version = SANDBOX_SCMI_PWD_PROTOCOL_VERSION, + .pwdom = scmi_pwdom, + .pwdom_count = ARRAY_SIZE(scmi_pwdom), .clk = scmi_clk, .clk_count = ARRAY_SIZE(scmi_clk), .reset = scmi_reset, diff --git a/drivers/firmware/scmi/sandbox-scmi_devices.c b/drivers/firmware/scmi/sandbox-scmi_devices.c index 9baeb469ec0a..facb5b06ffb5 100644 --- a/drivers/firmware/scmi/sandbox-scmi_devices.c +++ b/drivers/firmware/scmi/sandbox-scmi_devices.c @@ -29,12 +29,14 @@
/* * struct sandbox_scmi_device_priv - Storage for device handles used by test + * @pwdom: Power domain device * @clk: Array of clock instances used by tests * @reset_clt: Array of the reset controller instances used by tests * @regulators: Array of regulator device references used by the tests * @devices: Resources exposed by sandbox_scmi_devices_ctx() */ struct sandbox_scmi_device_priv { + struct power_domain pwdom; struct clk clk[SCMI_TEST_DEVICES_CLK_COUNT]; struct reset_ctl reset_ctl[SCMI_TEST_DEVICES_RD_COUNT]; struct udevice *regulators[SCMI_TEST_DEVICES_VOLTD_COUNT]; @@ -77,6 +79,8 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) size_t n;
priv->devices = (struct sandbox_scmi_devices){ + .pwdom = &priv->pwdom, + .pwdom_count = 1, .clk = priv->clk, .clk_count = SCMI_TEST_DEVICES_CLK_COUNT, .reset = priv->reset_ctl, @@ -85,6 +89,12 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) .regul_count = SCMI_TEST_DEVICES_VOLTD_COUNT, };
+ ret = power_domain_get_by_index(dev, priv->devices.pwdom, 0); + if (ret) { + dev_err(dev, "%s: Failed on power domain\n", __func__); + return ret; + } + for (n = 0; n < SCMI_TEST_DEVICES_CLK_COUNT; n++) { ret = clk_get_by_index(dev, n, priv->devices.clk + n); if (ret) {
This ut has tests for the SCMI power domain protocol as well as DM interfaces for power domain devices.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- v2 * remove a change at "test_scmi_cmd" because "scmi" command is no longer provided --- test/dm/scmi.c | 103 +++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/test/dm/scmi.c b/test/dm/scmi.c index d4ff60e00069..da45314f2e4c 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -206,6 +206,109 @@ static int dm_test_scmi_base(struct unit_test_state *uts)
DM_TEST(dm_test_scmi_base, UT_TESTF_SCAN_FDT);
+static int dm_test_scmi_power_domains(struct unit_test_state *uts) +{ + struct sandbox_scmi_agent *agent; + struct sandbox_scmi_devices *scmi_devices; + struct udevice *agent_dev, *pwd, *dev; + u32 version, count, attributes, pstate; + u64 stats_addr; + size_t stats_len; + u8 *name; + int ret; + + /* preparation */ + ut_assertok(load_sandbox_scmi_test_devices(uts, &agent, &dev)); + ut_assertnonnull(agent); + scmi_devices = sandbox_scmi_devices_ctx(dev); + ut_assertnonnull(scmi_devices); + ut_asserteq(2, scmi_devices->pwdom->id); /* in test.dts */ + + ut_assertok(uclass_get_device_by_name(UCLASS_SCMI_AGENT, "scmi", + &agent_dev)); + ut_assertnonnull(agent_dev); + pwd = scmi_get_protocol(agent_dev, SCMI_PROTOCOL_ID_POWER_DOMAIN); + ut_assertnonnull(pwd); + + /* + * SCMI Power domain management protocol interfaces + */ + /* version */ + ret = scmi_generic_protocol_version(pwd, SCMI_PROTOCOL_ID_POWER_DOMAIN, + &version); + ut_assertok(ret); + ut_asserteq(agent->pwdom_version, version); + + /* protocol attributes */ + ret = scmi_pwd_protocol_attrs(pwd, &count, &stats_addr, &stats_len); + ut_assertok(ret); + ut_asserteq(agent->pwdom_count, count); + ut_asserteq(0, stats_len); + + /* protocol message attributes */ + ret = scmi_pwd_protocol_message_attrs(pwd, SCMI_PWD_STATE_SET, + &attributes); + ut_assertok(ret); + ret = scmi_pwd_protocol_message_attrs(pwd, SCMI_PWD_STATE_NOTIFY, + &attributes); + ut_asserteq(-ENOENT, ret); /* the protocol not supported */ + + /* power domain attributes */ + ret = scmi_pwd_attrs(pwd, 0, &attributes, &name); + ut_assertok(ret); + ut_asserteq_str("power-domain--0", name); + free(name); + + ret = scmi_pwd_attrs(pwd, 10, &attributes, &name); + ut_asserteq(-ENOENT, ret); /* domain-10 doesn't exist */ + + /* power domain state set/get */ + ret = scmi_pwd_state_set(pwd, 0, 0, 0); + ut_assertok(ret); + ret = scmi_pwd_state_get(pwd, 0, &pstate); + ut_assertok(ret); + ut_asserteq(0, pstate); /* ON */ + + ret = scmi_pwd_state_set(pwd, 0, 0, SCMI_PWD_PSTATE_TYPE_LOST); + ut_assertok(ret); + ret = scmi_pwd_state_get(pwd, 0, &pstate); + ut_assertok(ret); + ut_asserteq(SCMI_PWD_PSTATE_TYPE_LOST, pstate); /* OFF */ + + ret = scmi_pwd_state_set(pwd, 0, 10, 0); + ut_asserteq(-ENOENT, ret); + + /* power domain name get */ + ret = scmi_pwd_name_get(pwd, 0, &name); + ut_assertok(ret); + ut_asserteq_str("power-domain--0-extended", name); + free(name); + + ret = scmi_pwd_name_get(pwd, 10, &name); + ut_asserteq(-ENOENT, ret); /* domain-10 doesn't exist */ + + /* + * U-Boot driver model interfaces + */ + /* power_domain_on */ + ret = power_domain_on(scmi_devices->pwdom); + ut_assertok(ret); + ret = scmi_pwd_state_get(pwd, scmi_devices->pwdom->id, &pstate); + ut_assertok(ret); + ut_asserteq(0, pstate); /* ON */ + + /* power_domain_off */ + ret = power_domain_off(scmi_devices->pwdom); + ut_assertok(ret); + ret = scmi_pwd_state_get(pwd, scmi_devices->pwdom->id, &pstate); + ut_assertok(ret); + ut_asserteq(SCMI_PWD_PSTATE_TYPE_LOST, pstate); /* OFF */ + + return release_sandbox_scmi_test_devices(uts, dev); +} + +DM_TEST(dm_test_scmi_power_domains, UT_TESTF_SCAN_FDT); + static int dm_test_scmi_clocks(struct unit_test_state *uts) { struct sandbox_scmi_agent *agent;
AKASHI Takahiro
